[GRASS-SVN] r63838 - in grass/trunk: general/g.list general/g.mapset general/g.mapsets general/g.setproj imagery/i.ortho.photo/i.ortho.elev imagery/i.ortho.photo/i.ortho.rectify imagery/i.rectify raster/r.in.gdal raster/r.proj vector/v.proj vector/v.rectify
Mon Dec 29 11:00:14 PST 2014
Author: martinl
Date: 2014-12-29 11:00:13 -0800 (Mon, 29 Dec 2014)
New Revision: 63838
   grass/trunk/general/g.list/main.c
   grass/trunk/general/g.mapset/main.c
   grass/trunk/general/g.mapsets/main.c
   grass/trunk/general/g.setproj/main.c
   grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c
   grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/target.c
   grass/trunk/imagery/i.rectify/target.c
   grass/trunk/raster/r.in.gdal/main.c
   grass/trunk/raster/r.proj/main.c
   grass/trunk/vector/v.proj/main.c
   grass/trunk/vector/v.rectify/target.c
update to r63837
Modified: grass/trunk/general/g.list/main.c
--- grass/trunk/general/g.list/main.c	2014-12-29 18:58:23 UTC (rev 63837)
+++ grass/trunk/general/g.list/main.c	2014-12-29 19:00:13 UTC (rev 63838)
@@ -300,7 +300,7 @@
 	    else if (strcmp(mapset, ".") == 0)
 		mapset = G_mapset();
-	    else if (G__mapset_permissions(mapset) == -1)
+	    else if (G_mapset_permissions(mapset) == -1)
 		G_fatal_error(_("Mapset <%s> does not exist"), mapset);
 	    G_add_mapset_to_search_path(mapset);
Modified: grass/trunk/general/g.mapset/main.c
--- grass/trunk/general/g.mapset/main.c	2014-12-29 18:58:23 UTC (rev 63837)
+++ grass/trunk/general/g.mapset/main.c	2014-12-29 19:00:13 UTC (rev 63838)
@@ -131,7 +131,7 @@
 	ms = G_get_available_mapsets();
 	for (nmapsets = 0; ms[nmapsets]; nmapsets++) {
-	    if (G__mapset_permissions(ms[nmapsets]) > 0) {
+	    if (G_mapset_permissions(ms[nmapsets]) > 0) {
 		fprintf(stdout, "%s ", ms[nmapsets]);
@@ -152,7 +152,7 @@
     /* Check if the mapset exists and user is owner */
     G_debug(2, "check : %s", mapset_new_path);
-    ret = G__mapset_permissions2(gisdbase_new, location_new, mapset_new);
+    ret = G_mapset_permissions2(gisdbase_new, location_new, mapset_new);
     switch (ret) {
     case 0:
 	G_fatal_error(_("You don't have permission to use the mapset <%s>"),
Modified: grass/trunk/general/g.mapsets/main.c
--- grass/trunk/general/g.mapsets/main.c	2014-12-29 18:58:23 UTC (rev 63837)
+++ grass/trunk/general/g.mapsets/main.c	2014-12-29 19:00:13 UTC (rev 63838)
@@ -170,7 +170,7 @@
         cur_found = FALSE;
         for (ptr = opt.mapset->answers; *ptr != NULL; ptr++) {
             mapset = substitute_mapset(*ptr);
-            if (G__mapset_permissions(mapset) < 0)
+            if (G_mapset_permissions(mapset) < 0)
                 G_fatal_error(_("Mapset <%s> not found"), mapset);
             if (strcmp(mapset, cur_mapset) == 0)
                 cur_found = TRUE;
@@ -204,7 +204,7 @@
                 continue;
             else
                 G_verbose_message(_("Mapset <%s> added to search path"),
Modified: grass/trunk/general/g.setproj/main.c
--- grass/trunk/general/g.setproj/main.c	2014-12-29 18:58:23 UTC (rev 63837)
+++ grass/trunk/general/g.setproj/main.c	2014-12-29 19:00:13 UTC (rev 63838)
@@ -96,7 +96,7 @@
     /* get the output projection parameters, if existing */
     /* Check for ownership here */
-    stat = G__mapset_permissions(set_name);
+    stat = G_mapset_permissions(set_name);
     if (stat == 0) {
 	G_fatal_error(_("PERMANENT: permission denied"));
Modified: grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c
--- grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c	2014-12-29 18:58:23 UTC (rev 63837)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.elev/main.c	2014-12-29 19:00:13 UTC (rev 63838)
@@ -124,7 +124,7 @@
     G_create_alt_env();
     G_setenv_nogisrc("LOCATION_NAME", location);
-    stat = G__mapset_permissions(mapset);
+    stat = G_mapset_permissions(mapset);
     if (stat > 0) {
 	G_setenv_nogisrc("MAPSET", mapset);
 	G_create_alt_search_path();
Modified: grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/target.c
--- grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/target.c	2014-12-29 18:58:23 UTC (rev 63837)
+++ grass/trunk/imagery/i.ortho.photo/i.ortho.rectify/target.c	2014-12-29 19:00:13 UTC (rev 63838)
@@ -21,7 +21,7 @@
     select_target_env();
     if (stat > 0) {
 	G_get_window(&target_window);
Modified: grass/trunk/imagery/i.rectify/target.c
--- grass/trunk/imagery/i.rectify/target.c	2014-12-29 18:58:23 UTC (rev 63837)
+++ grass/trunk/imagery/i.rectify/target.c	2014-12-29 19:00:13 UTC (rev 63838)
@@ -22,7 +22,7 @@
     if (stat > 0) {
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c	2014-12-29 18:58:23 UTC (rev 63837)
+++ grass/trunk/raster/r.in.gdal/main.c	2014-12-29 19:00:13 UTC (rev 63838)
@@ -652,7 +652,7 @@
 		G_setenv_nogisrc("LOCATION_NAME", parm.target->answer);
 		sprintf(target_mapset, "PERMANENT");	/* must exist */
-		if (G__mapset_permissions(target_mapset) == -1) {
+		if (G_mapset_permissions(target_mapset) == -1) {
 		    /* create target location later */
 		    create_target = 1;
@@ -825,7 +825,7 @@
     G_setenv_nogisrc("LOCATION_NAME", (char *)pszDstLoc);
     sprintf(target_mapset, "PERMANENT");	/* to find PROJ_INFO */
-    permissions = G__mapset_permissions(target_mapset);
+    permissions = G_mapset_permissions(target_mapset);
     if (permissions >= 0) {
 	/* Get projection info from target location */
Modified: grass/trunk/raster/r.proj/main.c
--- grass/trunk/raster/r.proj/main.c	2014-12-29 18:58:23 UTC (rev 63837)
+++ grass/trunk/raster/r.proj/main.c	2014-12-29 19:00:13 UTC (rev 63838)
@@ -281,7 +281,7 @@
     G_setenv_nogisrc("GISDBASE", indbase->answer ? indbase->answer : G_gisdbase());
     G_setenv_nogisrc("LOCATION_NAME", inlocation->answer);
-    permissions = G__mapset_permissions(setname);
+    permissions = G_mapset_permissions(setname);
     if (permissions < 0)	/* can't access mapset       */
 	G_fatal_error(_("Mapset <%s> in input location <%s> - %s"),
 		      setname, inlocation->answer,
Modified: grass/trunk/vector/v.proj/main.c
--- grass/trunk/vector/v.proj/main.c	2014-12-29 18:58:23 UTC (rev 63837)
+++ grass/trunk/vector/v.proj/main.c	2014-12-29 19:00:13 UTC (rev 63838)
@@ -182,7 +182,7 @@
     G_setenv_nogisrc("GISDBASE", gbase);
     G_setenv_nogisrc("LOCATION_NAME", iloc_name);
-    stat = G__mapset_permissions(iset_name);
+    stat = G_mapset_permissions(iset_name);
     if (stat >= 0) {		/* yes, we can access the mapset */
 	/* if requested, list the vector maps in source location - MN 5/2001 */
Modified: grass/trunk/vector/v.rectify/target.c
--- grass/trunk/vector/v.rectify/target.c	2014-12-29 18:58:23 UTC (rev 63837)
+++ grass/trunk/vector/v.rectify/target.c	2014-12-29 19:00:13 UTC (rev 63838)
@@ -31,7 +31,7 @@
     if (stat > 0) {
 	select_current_env();
