[GRASS-SVN] r63845 - in grass/branches/releasebranch_7_0: . db/drivers/dbf include/defs lib/gis lib/init lib/vector/Vlib raster/r.flow
svn_grass at osgeo.org
Mon Dec 29 11:09:08 PST 2014
Author: martinl
Date: 2014-12-29 11:09:07 -0800 (Mon, 29 Dec 2014)
New Revision: 63845
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/db/drivers/dbf/table.c
grass/branches/releasebranch_7_0/include/defs/gis.h
grass/branches/releasebranch_7_0/lib/gis/tempfile.c
grass/branches/releasebranch_7_0/lib/init/clean_temp.c
grass/branches/releasebranch_7_0/lib/vector/Vlib/open.c
grass/branches/releasebranch_7_0/raster/r.flow/io.c
libgis: G__temp_element() -> G_temp_element()
update modules
(merge r63843-4 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63275-63276,63279,63281,63283,63287,63290,63292,63297,63302,63304-63307,63315,63319,63327,63330,63332,63339,63342,63345,63361-63363,63367,63379,63389,63391,63393,63402,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63604,63608-63609,63616,63618,63624,63626,63628,63630,63634,63639,63642,63644,63650,63652,63656,63679,63685,63689,63691,63693,63695,63698,63700-63702,63704,63706-63707,63709,63711,63713,63715,63717-63718
,63721-63727,63731,63733,63740-63742,63744,63747-63749,63751-63752,63756,63758,63761,63767,63777,63780,63783,63787,63793,63796-63798,63801,63803,63807-63808,63812,63814,63816,63821,63823-63824,63827-63828,63830-63831,63834-63835,63837-63839,63841
+ /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
,63721-63727,63731,63733,63740-63742,63744,63747-63749,63751-63752,63756,63758,63761,63767,63777,63780,63783,63787,63793,63796-63798,63801,63803,63807-63808,63812,63814,63816,63821,63823-63824,63827-63828,63830-63831,63834-63835,63837-63839,63841,63843-63844
Modified: grass/branches/releasebranch_7_0/db/drivers/dbf/table.c
--- grass/branches/releasebranch_7_0/db/drivers/dbf/table.c 2014-12-29 19:07:57 UTC (rev 63844)
+++ grass/branches/releasebranch_7_0/db/drivers/dbf/table.c 2014-12-29 19:09:07 UTC (rev 63845)
@@ -235,7 +235,7 @@
return DB_OK;
/* Construct our temp name because shapelib doesn't like '.' in name */
- G__temp_element(element);
+ G_temp_element(element);
sprintf(fname, "%d.dbf", getpid());
G_file_name(name, element, fname, G_mapset());
G_debug(2, "Write table to tempfile: '%s'", name);
Modified: grass/branches/releasebranch_7_0/include/defs/gis.h
--- grass/branches/releasebranch_7_0/include/defs/gis.h 2014-12-29 19:07:57 UTC (rev 63844)
+++ grass/branches/releasebranch_7_0/include/defs/gis.h 2014-12-29 19:09:07 UTC (rev 63845)
@@ -657,7 +657,7 @@
void G_init_tempfile(void);
char *G_tempfile(void);
char *G__tempfile(int);
-void G__temp_element(char *);
+void G_temp_element(char *);
/* mkstemp.c */
char *G_mktemp(char *);
Modified: grass/branches/releasebranch_7_0/lib/gis/tempfile.c
--- grass/branches/releasebranch_7_0/lib/gis/tempfile.c 2014-12-29 19:07:57 UTC (rev 63844)
+++ grass/branches/releasebranch_7_0/lib/gis/tempfile.c 2014-12-29 19:09:07 UTC (rev 63845)
@@ -76,7 +76,7 @@
if (pid <= 0)
pid = getpid();
G_init_tempfile();
do {
int uniq = G_counter_next(&unique);
@@ -93,7 +93,7 @@
* \param[out] element element name
-void G__temp_element(char *element)
+void G_temp_element(char *element)
const char *machine;
Modified: grass/branches/releasebranch_7_0/lib/init/clean_temp.c
--- grass/branches/releasebranch_7_0/lib/init/clean_temp.c 2014-12-29 19:07:57 UTC (rev 63844)
+++ grass/branches/releasebranch_7_0/lib/init/clean_temp.c 2014-12-29 19:09:07 UTC (rev 63845)
@@ -134,7 +134,7 @@
sscanf(argv[1], "%d", &ppid);
/* Get the mapset temp directory */
G_file_name(tmppath, element, "", mapset = G_mapset());
/* get user id and current time in seconds */
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/open.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/open.c 2014-12-29 19:07:57 UTC (rev 63844)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/open.c 2014-12-29 19:09:07 UTC (rev 63845)
@@ -1447,7 +1447,7 @@
if (Map->temporary) {
char path_tmp[GPATH_MAX];
- G__temp_element(path_tmp);
+ G_temp_element(path_tmp);
sprintf(path, "%s/%s/%s", path_tmp, GV_DIRECTORY, Map->name);
else {
Modified: grass/branches/releasebranch_7_0/raster/r.flow/io.c
--- grass/branches/releasebranch_7_0/raster/r.flow/io.c 2014-12-29 19:07:57 UTC (rev 63844)
+++ grass/branches/releasebranch_7_0/raster/r.flow/io.c 2014-12-29 19:09:07 UTC (rev 63845)
@@ -47,7 +47,7 @@
const char *location = G_location_path();
const char *el = element;
while (*fullname++ == *location++) ;
while (*fullname++ == *mapset++) ;
while (*fullname++ == *el++) ;
@@ -140,7 +140,7 @@
const char *mapset;
if (new == TEMP)
- G__temp_element(string);
+ G_temp_element(string);
else
sprintf(string, "cell_misc/%s", parm.elevin);
