[GRASS-SVN] r63851 - in grass/trunk/lib: gis imagery
svn_grass at osgeo.org
Mon Dec 29 11:25:41 PST 2014
Author: martinl
Date: 2014-12-29 11:25:41 -0800 (Mon, 29 Dec 2014)
New Revision: 63851
grass/trunk/lib/gis/color_rules.c
grass/trunk/lib/gis/list.c
grass/trunk/lib/gis/ls.c
grass/trunk/lib/imagery/list_subgp.c
libgis: G__ls -> G_ls2
Modified: grass/trunk/lib/gis/color_rules.c
--- grass/trunk/lib/gis/color_rules.c 2014-12-29 19:18:18 UTC (rev 63850)
+++ grass/trunk/lib/gis/color_rules.c 2014-12-29 19:25:41 UTC (rev 63851)
@@ -112,7 +112,7 @@
G_snprintf(path, GPATH_MAX, "%s/etc/colors", G_gisbase());
- rules = G__ls(path, nrules);
+ rules = G_ls2(path, nrules);
rules = G_realloc(rules, (*nrules + 3) * sizeof (const char *));
Modified: grass/trunk/lib/gis/list.c
--- grass/trunk/lib/gis/list.c 2014-12-29 19:18:18 UTC (rev 63850)
+++ grass/trunk/lib/gis/list.c 2014-12-29 19:25:41 UTC (rev 63851)
@@ -126,7 +126,7 @@
* otherwise the ls must be forced into columnar form.
- list = G__ls(path, &count);
+ list = G_ls2(path, &count);
if (count > 0) {
fprintf(out, _("%s files available in mapset <%s>:\n"), desc, mapset);
Modified: grass/trunk/lib/gis/ls.c
--- grass/trunk/lib/gis/ls.c 2014-12-29 19:18:18 UTC (rev 63850)
+++ grass/trunk/lib/gis/ls.c 2014-12-29 19:25:41 UTC (rev 63851)
@@ -52,10 +52,10 @@
- * \brief Sets a function and its complementary data for G__ls filtering.
+ * \brief Sets a function and its complementary data for G_ls2 filtering.
- * Defines a filter function and its rule data that allow G__ls to filter out
- * unwanted file names. Call this function before G__ls.
+ * Defines a filter function and its rule data that allow G_ls2 to filter out
+ * unwanted file names. Call this function before G_ls2.
* \param func Filter callback function to compare a file name and closure
* pattern (if NULL, no filter will be used).
@@ -92,7 +92,7 @@
* \return Pointer to array of strings containing the listing
-char **G__ls(const char *dir, int *num_files)
+char **G_ls2(const char *dir, int *num_files)
struct dirent *dp;
DIR *dfd;
@@ -136,7 +136,7 @@
void G_ls(const char *dir, FILE * stream)
int i, n;
- char **dir_listing = G__ls(dir, &n);
+ char **dir_listing = G_ls2(dir, &n);
G_ls_format(dir_listing, n, 0, stream);
Modified: grass/trunk/lib/imagery/list_subgp.c
--- grass/trunk/lib/imagery/list_subgp.c 2014-12-29 19:18:18 UTC (rev 63850)
+++ grass/trunk/lib/imagery/list_subgp.c 2014-12-29 19:25:41 UTC (rev 63851)
@@ -47,7 +47,7 @@
if (!G_lstat(path, &sb) == 0 || !S_ISDIR(sb.st_mode))
return NULL;
- subgs = G__ls(path, subgs_num);
+ subgs = G_ls2(path, subgs_num);
return subgs;
