[GRASS-SVN] r63858 - in grass/trunk/lib: gis raster
Mon Dec 29 11:34:48 PST 2014
Author: martinl
Date: 2014-12-29 11:34:48 -0800 (Mon, 29 Dec 2014)
New Revision: 63858
   grass/trunk/lib/gis/parser_interface.c
   grass/trunk/lib/raster/get_row.c
   grass/trunk/lib/raster/get_row_colr.c
   grass/trunk/lib/raster/put_row.c
libgis: G__alloca() -> G_alloca()
Modified: grass/trunk/lib/gis/parser_interface.c
--- grass/trunk/lib/gis/parser_interface.c	2014-12-29 19:31:48 UTC (rev 63857)
+++ grass/trunk/lib/gis/parser_interface.c	2014-12-29 19:34:48 UTC (rev 63858)
@@ -59,7 +59,7 @@
 	char *src = (char *) str;
 	size_t srclen = strlen(src);
 	size_t dstlen = srclen * 4 + 1;
-	char *dst = G__alloca(dstlen);
+	char *dst = G_alloca(dstlen);
 	size_t ret;
 	enc = dst;
@@ -90,7 +90,7 @@
 #ifdef HAVE_ICONV_H
     if (enc)
-	G__freea(enc);
+	G_freea(enc);
     if (conv != (iconv_t) -1)
 	iconv_close(conv);
Modified: grass/trunk/lib/raster/get_row.c
--- grass/trunk/lib/raster/get_row.c	2014-12-29 19:31:48 UTC (rev 63857)
+++ grass/trunk/lib/raster/get_row.c	2014-12-29 19:34:48 UTC (rev 63858)
@@ -135,10 +135,10 @@
 	G_fatal_error(_("Error reading raster data for row %d of <%s>"),
 		      row, fcb->name);
-    cmp = G__alloca(readamount);
+    cmp = G_alloca(readamount);
     if (read(fcb->data_fd, cmp, readamount) != readamount) {
-	G__freea(cmp);
+	G_freea(cmp);
 		      row, fcb->name);
@@ -162,7 +162,7 @@
     else
 	memcpy(data_buf, cmp, readamount);
-    G__freea(cmp);
+    G_freea(cmp);
 static void read_data_uncompressed(int fd, int row, unsigned char *data_buf,
@@ -195,7 +195,7 @@
     if (fcb->gdal->vflip)
 	row = fcb->cellhd.rows - 1 - row;
-    buf = fcb->gdal->hflip ? G__alloca(fcb->cellhd.cols * fcb->cur_nbytes)
+    buf = fcb->gdal->hflip ? G_alloca(fcb->cellhd.cols * fcb->cur_nbytes)
 	: data_buf;
     err =
@@ -210,7 +210,7 @@
 	    memcpy(data_buf + i * fcb->cur_nbytes,
 		   buf + (fcb->cellhd.cols - 1 - i) * fcb->cur_nbytes,
 		   fcb->cur_nbytes);
-	G__freea(buf);
+	G_freea(buf);
     if (err != CE_None)
@@ -454,7 +454,7 @@
 static void transfer_to_cell_fi(int fd, void *cell)
     struct fileinfo *fcb = &R__.fileinfo[fd];
-    FCELL *work_buf = G__alloca(R__.rd_window.cols * sizeof(FCELL));
+    FCELL *work_buf = G_alloca(R__.rd_window.cols * sizeof(FCELL));
     int i;
     transfer_to_cell_XX(fd, work_buf);
@@ -463,13 +463,13 @@
 	((CELL *) cell)[i] = (fcb->col_map[i] == 0)
 	    ? 0 : Rast_quant_get_cell_value(&fcb->quant, work_buf[i]);
-    G__freea(work_buf);
+    G_freea(work_buf);
 static void transfer_to_cell_di(int fd, void *cell)
-    DCELL *work_buf = G__alloca(R__.rd_window.cols * sizeof(DCELL));
+    DCELL *work_buf = G_alloca(R__.rd_window.cols * sizeof(DCELL));
     int i;
@@ -478,12 +478,12 @@
 static void transfer_to_cell_if(int fd, void *cell)
-    CELL *work_buf = G__alloca(R__.rd_window.cols * sizeof(CELL));
+    CELL *work_buf = G_alloca(R__.rd_window.cols * sizeof(CELL));
     int i;
@@ -491,12 +491,12 @@
     for (i = 0; i < R__.rd_window.cols; i++)
 	((FCELL *) cell)[i] = work_buf[i];
 static void transfer_to_cell_df(int fd, void *cell)
     int i;
@@ -504,12 +504,12 @@
 static void transfer_to_cell_id(int fd, void *cell)
     int i;
@@ -517,12 +517,12 @@
 	((DCELL *) cell)[i] = work_buf[i];
 static void transfer_to_cell_fd(int fd, void *cell)
     int i;
@@ -530,7 +530,7 @@
@@ -588,7 +588,7 @@
     int i;
     if (fcb->reclass_flag && data_type != CELL_TYPE) {
-	temp_buf = G__alloca(R__.rd_window.cols * sizeof(CELL));
+	temp_buf = G_alloca(R__.rd_window.cols * sizeof(CELL));
 	buf = temp_buf;
 	type = CELL_TYPE;
@@ -615,7 +615,7 @@
 	rast = G_incr_void_ptr(rast, size);
-    G__freea(temp_buf);
+    G_freea(temp_buf);
@@ -854,13 +854,13 @@
 	    fcb->null_cur_row = -1;
 	    if (fcb->map_type == CELL_TYPE) {
 		/* If can't read null row, assume  that all map 0's are nulls */
-		CELL *mask_buf = G__alloca(R__.rd_window.cols * sizeof(CELL));
+		CELL *mask_buf = G_alloca(R__.rd_window.cols * sizeof(CELL));
 		get_map_row_nomask(fd, mask_buf, row, CELL_TYPE);
 		for (j = 0; j < R__.rd_window.cols; j++)
 		    flags[j] = (mask_buf[j] == 0);
-		G__freea(mask_buf);
+		G_freea(mask_buf);
 	    else {		/* fp map */
 		/* if can't read null row, assume  that all data is valid */
@@ -915,14 +915,14 @@
 static void embed_mask(char *flags, int row)
     int i;
     if (R__.auto_mask <= 0)
 	return;
     if (get_map_row_nomask(R__.mask_fd, mask_buf, row, CELL_TYPE) < 0) {
 	return;
@@ -935,7 +935,7 @@
 	if (mask_buf[i] == 0 || Rast_is_c_null_value(&mask_buf[i]))
 	    flags[i] = 1;
 static void get_null_value_row(int fd, char *flags, int row, int with_mask)
@@ -967,7 +967,7 @@
 	&& (R__.auto_mask <= 0 || !with_mask))
 	return;
-    null_buf = G__alloca(R__.rd_window.cols);
+    null_buf = G_alloca(R__.rd_window.cols);
     get_null_value_row(fd, null_buf, row, with_mask);
@@ -982,7 +982,7 @@
 	buf = G_incr_void_ptr(buf, size);
-    G__freea(null_buf);
+    G_freea(null_buf);
@@ -1009,13 +1009,13 @@
     if (!fcb->reclass_flag)
 	get_null_value_row(fd, flags, row, 1);
     else {
-	CELL *buf = G__alloca(R__.rd_window.cols * sizeof(CELL));
+	CELL *buf = G_alloca(R__.rd_window.cols * sizeof(CELL));
 	int i;
 	Rast_get_c_row(fd, buf, row);
 	    flags[i] = Rast_is_c_null_value(&buf[i]) ? 1 : 0;
-	G__freea(buf);
+	G_freea(buf);
Modified: grass/trunk/lib/raster/get_row_colr.c
--- grass/trunk/lib/raster/get_row_colr.c	2014-12-29 19:31:48 UTC (rev 63857)
+++ grass/trunk/lib/raster/get_row_colr.c	2014-12-29 19:34:48 UTC (rev 63858)
@@ -48,7 +48,7 @@
     void *p;
     int i;
-    array = G__alloca(cols * size);
+    array = G_alloca(cols * size);
     Rast_get_row(fd, array, row, type);
@@ -56,10 +56,10 @@
 	for (i = 0, p = array; i < cols; i++, p = G_incr_void_ptr(p, size))
 	    nul[i] = Rast_is_null_value(p, type);
-    set = G__alloca(cols);
+    set = G_alloca(cols);
     Rast_lookup_colors(array, red, grn, blu, set, cols, colors, type);
-    G__freea(array);
-    G__freea(set);
+    G_freea(array);
+    G_freea(set);
Modified: grass/trunk/lib/raster/put_row.c
--- grass/trunk/lib/raster/put_row.c	2014-12-29 19:31:48 UTC (rev 63857)
+++ grass/trunk/lib/raster/put_row.c	2014-12-29 19:34:48 UTC (rev 63858)
@@ -193,7 +193,7 @@
     if (n <= 0)
 	return;
-    work_buf = G__alloca(size + 1);
+    work_buf = G_alloca(size + 1);
     if (compressed)
 	set_file_pointer(fd, row);
@@ -208,7 +208,7 @@
     else
 	write_data(fd, row, work_buf, n);
 static void convert_int(unsigned char *wk, char *null_buf, const CELL * rast,
@@ -348,7 +348,7 @@
     if (n <= 0)
 	return;
-    work_buf = G__alloca(fcb->cellhd.cols * sizeof(CELL) + 1);
+    work_buf = G_alloca(fcb->cellhd.cols * sizeof(CELL) + 1);
     wk = work_buf;
     if (compressed)
@@ -373,7 +373,7 @@
 	    trim_bytes(wk, n, len, len - nbytes);
 	total = nbytes * n;
-	compressed_buf = G__alloca(total + 1);
+	compressed_buf = G_alloca(total + 1);
 	compressed_buf[0] = work_buf[0] = nbytes;
@@ -396,7 +396,7 @@
 			      row, fcb->name);
-	G__freea(compressed_buf);
+	G_freea(compressed_buf);
     else {
 	nwrite = fcb->nbytes * n;
@@ -406,7 +406,7 @@
 			  row, fcb->name);
 static void put_data_gdal(int fd, const void *rast, int row, int n,
@@ -428,7 +428,7 @@
     if (n <= 0)
 	return;
-    work_buf = G__alloca(n * size);
+    work_buf = G_alloca(n * size);
     switch (map_type) {
     case CELL_TYPE:
@@ -458,7 +458,7 @@
     err = Rast_gdal_raster_IO(fcb->gdal->band, GF_Write, 0, row, n, 1,
 			      work_buf, n, 1, datatype, 0, 0);
     if (err != CE_None)
 	G_fatal_error(_("Error writing data via GDAL for row %d of <%s>"),
@@ -696,7 +696,7 @@
 	return;
-    null_buf = G__alloca(fcb->cellhd.cols);
+    null_buf = G_alloca(fcb->cellhd.cols);
     G_zero(null_buf, fcb->cellhd.cols);
     put_raster_data(fd, null_buf, buf, fcb->cur_row, fcb->cellhd.cols,
@@ -719,5 +719,5 @@
     if (!fcb->gdal)
 	put_null_value_row(fd, null_buf);
