[GRASS-SVN] r63866 - grass/trunk/scripts/d.vect.thematic
svn_grass at osgeo.org
Mon Dec 29 12:18:09 PST 2014
Author: neteler
Date: 2014-12-29 12:18:09 -0800 (Mon, 29 Dec 2014)
New Revision: 63866
Removed:
grass/trunk/scripts/d.vect.thematic/d.vect.thematic
removed leftover d.vect.thematic shell script (more recent version is in G6.4)
Deleted: grass/trunk/scripts/d.vect.thematic/d.vect.thematic
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic 2014-12-29 20:16:43 UTC (rev 63865)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic 2014-12-29 20:18:09 UTC (rev 63866)
@@ -1,1203 +0,0 @@
-#!/bin/sh
-# MODULE: d.vect.thematic
-# AUTHOR(S): Michael Barton, Arizona State University with contributions
-# by Martin Landa, Jachym Cepicky, Daniel Calvelo Aros and Moritz Lennert
-# PURPOSE: Displays thematic vector map with graduated colors
-# or graduated points and line thickneses
-# COPYRIGHT: (C) 2006 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%Module
-#% description: Displays thematic vector map
-#% keywords: display, vector, thematic, legend
-#%End
-#%option
-#% guisection: Files
-#% key: map
-#% type: string
-#% gisprompt: old,vector,vector
-#% description: Name of vector map
-#% required : yes
-#%end
-#%option
-#% guisection: Theme
-#% key: type
-#% type: string
-#% description: Feature type
-#% options: area,point,centroid,line,boundary
-#% answer: area
-#% required : yes
-#%end
-#%option
-#% key: column
-#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
-#% type: string
-#% description: Name of attribute column to use for thematic display (must be numeric)
-#% required : yes
-#%end
-#%option
-#% key: themetype
-#% type: string
-#% options: graduated_colors,graduated_points,graduated_lines
-#% answer: graduated_colors
-#% description: Type of thematic display
-#% required : yes
-#%end
-#%option
-#% key: themecalc
-#% type: string
-#% options: interval,std_deviation,quartiles,custom_breaks
-#% answer: interval
-#% description: Thematic divisions of data for display
-#% required : yes
-#%end
-#%option
-#% key: breakpoints
-#% type: string
-#% label: Break points for custom breaks option
-#% description: Separate values by spaces (0 10 20 30 ...)
-#% required : no
-#%end
-#%option
-#% key: layer
-#% type: integer
-#% gisprompt: old_layer,layer,layer
-#% description: Layer number
-#% answer: 1
-#% required : no
-#%end
-#%option
-#% guisection: Points
-#% key: icon
-#% type: string
-#% description: Vector point icon for point data
-#% options: basic/box,basic/circle,basic/cross2,basic/diamond,basic/star,basic/cross1,basic/x
-#% answer: basic/circle
-#% required : no
-#%end
-#%option
-#% key: size
-#% type: double
-#% label: Icon size for point data
-#% description: Minimum icon size/line width for graduated points/lines)
-#% answer: 5
-#% required : no
-#%end
-#%option
-#% key: maxsize
-#% type: double
-#% description: Maximum icon size/line width for graduated points and lines
-#% answer: 20
-#% required : no
-#%end
-#%option
-#% key: nint
-#% type: integer
-#% description: Number of classes for interval theme (integer)
-#% answer: 4
-#% required : no
-#%end
-#%option
-#% guisection: Color
-#% key: colorscheme
-#% type: string
-#% label: Color scheme for graduated color mapping
-#% description: Select 'single_color' for graduated point/line display
-#% options: blue-red,red-blue,green-red,red-green,blue-green,green-blue,cyan-yellow,yellow-cyan,custom_gradient,single_color
-#% answer: blue-red
-#% required : yes
-#%end
-#% option
-#% key: pointcolor
-#% type: string
-#% label: Color for graduated points map
-#% description: GRASS named color or R:G:B triplet. Set color scheme to single color
-#% answer: 255:0:0
-#% required : no
-#%end
-#% option
-#% key: linecolor
-#% type: string
-#% label: Color for graduated lines or point/area outlines
-#% description: GRASS named color or R:G:B triplet. Set color scheme to single color.
-#% answer: 0:0:0
-#% required : no
-#%end
-#% option
-#% key: startcolor
-#% type: string
-#% label: Beginning color for custom color gradient
-#% description: Must be expressed as R:G:B triplet
-#% answer: 255:0:0
-#% required : no
-#%end
-#% option
-#% key: endcolor
-#% type: string
-#% label: Ending color for custom color gradient
-#% answer: 0:0:255
-#% required : no
-#%end
-#% option
-#% guisection: Misc
-#% key: monitor
-#% type: string
-#% description: Select x11 display monitor for legend
-#% options: x0,x1,x2,x3,x4,x5,x6,none
-#% answer: x1
-#% required : no
-#%end
-#%flag
-#%key: g
-#%description: Save thematic map commands to group file for GIS Manager
-#%end
-#%option
-#% key: where
-#% type: string
-#% description: WHERE conditions of SQL statement without 'where' keyword
-#% required : no
-#%end
-#%option
-#% key: psmap
-#% type: string
-#% label: Root for the name of psmap instruction files to be in current directory
-#% description: If not set, no psmap instruction files will be created)
-#% required : no
-#%end
-#%option
-#% key: group
-#% type: string
-#% gisprompt: new_file,file,group
-#% description: Name of group file where thematic map commands will be saved
-#% required : no
-#%end
-#%flag
-#%key: l
-#%description: Create graphic legend in x11 display monitor
-#%end
-#%flag
-#% key: f
-#% description: Only draw fills (no outlines) for areas and points
-#%end
-#%flag
-#% key: u
-#% description: Update color values to GRASSRGB column in attribute table
-#%end
-#%flag
-#%key: s
-#%description: Output legend for GIS Manager (for scripting use only)
-#%end
-#%flag
-#%key: m
-#%description: Use math notation brackets in legend
-#%end
-if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program." >&2
- exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec g.parser "$0" "$@"
-fi
-PROG=`basename $0`
-#### check if we have awk
-if [ ! -x "`which awk`" ] ; then
- g.message -e "awk required, please install awk or gawk first"
- exit 1
-fi
-# setting environment, so that awk works properly in all languages
-unset LC_ALL
-LC_NUMERIC=C
-export LC_NUMERIC
-# hard-coded parameter: the maximum number of legend items before
-# we strip them using a middle ellipsis
-MAX_LEG_ITEMS=18
-# check column type
-COLTYPE=`v.info -c "$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" 2> /dev/null | grep -w "$GIS_OPT_COLUMN" | cut -d'|' -f1 | tr -s '[:upper:]' '[:lower:]'`
-#COLTYPE=...
-if [ -z "$COLTYPE" ] ; then
- g.message -e message="No such column [$GIS_OPT_COLUMN]"
- exit 1
-fi
-if [ "$COLTYPE" != "integer" ] && [ "$COLTYPE" != "double precision" ] ; then
- g.message -e message="Column <$GIS_OPT_COLUMN> is of type <$COLTYPE> which is not numeric."
- exit 1
-fi
-# create temporary file to hold output from v.univar
-TMP1="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP1" ] ; then
- g.message -e "Unable to create temporary file for statistics"
- exit 1
-fi
-# create temporary file to hold d.graph commands for legend
-TMP2="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP2" ] ; then
- g.message -e "Unable to create temporary file for legend"
- exit 1
-fi
-# Create temporary file to commands for GIS Manager group
-TMP3="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP3" ] ; then
- g.message -e "Unable to create temporary file for group"
- exit 1
-fi
-# Create temporary file for commands for ps.map map file
-TMP4="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP4" ] ; then
- g.message -e "Unable to create temporary file for ps.map legend"
- exit 1
-fi
-# Create temporary file for commands for ps.map legend file
-TMP5="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP5" ] ; then
- exit 1
-fi
-# create file to hold elements for GIS Manager legend
-TMP6="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP6" ] ; then
- g.message -e "Unable to create temporary file for GIS Manager legend"
- exit 1
-fi
-# Set display variables for group
-atype=0
-ptype=0
-ctype=0
-ltype=0
-btype=0
-case "$GIS_OPT_TYPE" in
- "area" ) atype=1 ;;
- "point" ) ptype=1 ;;
- "centroid" ) ctype=1 ;;
- "line" ) ltype=1 ;;
- "boundary" ) btype=1 ;;
-esac
-cleanup()
- \rm -f "$TMP1" "$TMP1.sort" "$TMP2" "$TMP2.sort" "$TMP3" "$TMP3.sort" \
- "$TMP4" "$TMP4.sort" "$TMP5" "$TMP5.sort" "$TMP6" "$TMP6.sort"
-# what to do in case of user break:
-exitprocedure()
- g.message -e message='User break!'
- cleanup
- exit 1
-# shell check for user break (signal list: trap -l)
-trap "exitprocedure" 2 3 15
-# identify current monitor or start monitor
-if [ "$GIS_FLAG_S" -ne 1 ] ; then
- currmon=`eval d.mon -L | grep "(selected)" | awk '{print $1}'`
-fi
-if [ -z "$currmon" -a "$GIS_FLAG_S" -ne 1 ] ; then
- g.message -e message='*** You must open a display monitor ***'
- cleanup
- exit 2
-fi
-# if running in the GUI, do not create a graphic legend in an xmon
-if [ "$GIS_FLAG_S" -eq 1 ] ; then
- GIS_FLAG_L=0
- # if running in GUI, turn off immediate mode rendering so that the
- # iterated d.vect commands will composite using the display driver
- autowrite=$GRASS_PNG_AUTO_WRITE
- pngread=$GRASS_RENDER_FILE_READ
- GRASS_RENDER_FILE_READ=TRUE
- export GRASS_RENDER_FILE_READ
- GRASS_PNG_AUTO_WRITE=FALSE
- export GRASS_PNG_AUTO_WRITE
-fi
-table=`v.db.connect $GIS_OPT_MAP -g sep=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $2}'`
-database=`v.db.connect $GIS_OPT_MAP -g sep=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $4}'`
-driver=`v.db.connect $GIS_OPT_MAP -g sep=";" | grep -w $GIS_OPT_LAYER | awk -F ";" '{print $5}'`
-if [ -z "$table" ]
- then
- g.message -e message="No table connected or layer <$GIS_OPT_LAYER> does not exist."
- exit 1
- fi
-# update color values to the table?
-if [ "$GIS_FLAG_U" -eq 1 ] ; then
- # test, if the column GRASSRGB is in the table
- if [ -z "`db.columns table=$table database=$database driver=$driver| grep -i grassrgb`" ] ; then
- g.message message="Creating column 'grassrgb' in table '$table'"
- echo "ALTER TABLE $table ADD COLUMN grassrgb varchar(11)" | db.execute database="${database}" driver=${driver}
- fi
-fi
-# Group name
-if [ -z "$GIS_OPT_GROUP" ] ; then
- group="themes"
-else
- group=$GIS_OPT_GROUP
-fi
-echo "Group $group" > "$TMP3"
-# Calculate statistics for thematic intervals
-if [ -z "$GIS_OPT_WHERE" ] ; then
- if [ "$GIS_OPT_TYPE" = "line" ] ; then
- v.univar -e -g map=$GIS_OPT_MAP type=line column=$GIS_OPT_COLUMN > "$TMP1"
- else
- v.univar -e -g map=$GIS_OPT_MAP type=point,centroid column=$GIS_OPT_COLUMN > "$TMP1"
- fi
-else
- v.univar -e -g map=$GIS_OPT_MAP type=line column=$GIS_OPT_COLUMN where="$GIS_OPT_WHERE" > "$TMP1"
- else
- v.univar -e -g map=$GIS_OPT_MAP type=point,centroid column=$GIS_OPT_COLUMN where="$GIS_OPT_WHERE" > "$TMP1"
- fi
-fi
-min=`grep 'min=' "$TMP1" | sed s/min=//`
-max=`grep 'max=' "$TMP1" | sed s/max=//`
-mean=`grep 'mean=' "$TMP1" | sed s/mean=//`
-sd=`grep 'population_stddev=' "$TMP1" | sed s/'population_stddev='//`
-q1=`grep 'first_quartile=' "$TMP1" | sed s/'first_quartile='//`
-q2=`grep 'median=' "$TMP1" | sed s/'median='//`
-q3=`grep 'third_quartile=' "$TMP1" | sed s/'third_quartile='//`
-q4="$max"
-ptsize="$GIS_OPT_SIZE"
-if [ -n "$GIS_OPT_BREAKPOINTS" ] && [ "$GIS_OPT_THEMECALC" != "custom_breaks" ] ; then
- g.message -w "Custom breakpoints ignored due to themecalc setting."
-fi
-# set interval for each thematic map calculation type
-case "$GIS_OPT_THEMECALC" in
-"interval" )
- numint=$GIS_OPT_NINT
- step=`echo $min $max $numint | awk '{print (($2 - $1) / $3)}'`
- breakpoints=`echo $min $max $numint | awk '{for(i=0;i<$3;i++){printf $1+($2-$1)/$3*i " "}printf $2}'`
- annotations=""
-"std_deviation" )
- # 2 standard deviation units on either side of mean,
- # plus min to -2 sd units and +2 sd units to max, if applicable
- breakpoints=`echo $min $max $mean $sd | awk '{printf $1;for(i=-2;i<=2;i++){ith=$3+i*$4;if($1<ith && $2>ith){printf " " ith}}print " " $2}'`
- annotations=`echo $min $max $mean $sd | awk '{printf "";for(i=-2;i<=2;i++){ith=$3+i*$4;if($1<ith && $2>ith){if(i!=0){printf ";"((i<0)?"":"+") i "sd"} }}print ";"}'`
- numint=`echo $breakpoints | awk '{print NF-1}'`
-"quartiles" )
- numint=4
- # one for each quartile
- breakpoints="$min $q1 $q2 $q3 $max"
- annotations=" q1; q2; q3; q4"
-"custom_breaks" )
- if [ -z "$GIS_OPT_BREAKPOINTS" ] ; then
- breakpoints=`cat | awk '{gsub("[^0-9., ]","",$0);print}'`
- else
- breakpoints="$GIS_OPT_BREAKPOINTS"
- fi
- numint=`echo $breakpoints|awk '{print NF-1}'`
- annotations=""
- g.message -e "Unknown themecalc type"
- cleanup
- exit
-esac
-pointstep=`echo $GIS_OPT_MAXSIZE $ptsize $numint | awk '{print (($1 - $2) / ($3-1))}'`
-# Prepare legend cuts for too large numint
-if [ $numint -gt $MAX_LEG_ITEMS ]; then
- xupper=`echo $numint $MAX_LEG_ITEMS | awk '{print int($1 - $2/2)+1}'`
- xlower=`echo $MAX_LEG_ITEMS | awk '{print int($1/2)+1}'`
-else
- xupper=0
- xlower=0
-fi
-# legend title
-echo "color 0:0:0" > "$TMP2"
-echo "size 2 2" >> "$TMP2"
-echo "move 1 95" >> "$TMP2"
-echo "text Thematic map legend for column $GIS_OPT_COLUMN of map $GIS_OPT_MAP" >> "$TMP2"
-echo "size 1.5 1.8" >> "$TMP2"
-echo "move 4 90" >> "$TMP2"
-echo "text Value range: $min - $max" >> "$TMP2"
-echo "title - - - {Thematic map legend for column $GIS_OPT_COLUMN of map $GIS_OPT_MAP}" > "$TMP6"
-echo "text 1% 95% Thematic map legend for column $GIS_OPT_COLUMN of map $GIS_OPT_MAP" >> "$TMP5"
-echo " ref bottom left" >> "$TMP5"
-echo "end" >> "$TMP5"
-echo "text 4% 90% Value range: $min - $max" >> "$TMP5"
-g.message message="Thematic map legend for column $GIS_OPT_COLUMN of map $GIS_OPT_MAP"
-g.message message="Value range: $min - $max"
-# graduated color thematic mapping
-if [ "$GIS_OPT_THEMETYPE" = "graduated_colors" ] ; then
- # set color schemes for graduated color maps
- case "$GIS_OPT_COLORSCHEME" in
- "blue-red" )
- startc="0:0:255"
- endc="255:0:0"
- "red-blue" )
- startc="255:0:0"
- endc="0:0:255"
- "green-red" )
- startc="0:255:0"
- endc="255:0:0"
- "red-green" )
- startc="255:0:0"
- endc="0:255:0"
- "blue-green" )
- startc="0:0:255"
- endc="0:255:0"
- "green-blue" )
- startc="0:255:0"
- endc="0:0:255"
- "cyan-yellow" )
- startc="0:255:255"
- endc="255:255:0"
- "yellow-cyan" )
- startc="255:255:0"
- endc="0:255:255"
- "custom_gradient" )
- startc="$GIS_OPT_STARTCOLOR"
- endc="$GIS_OPT_ENDCOLOR"
- "single_color" )
- if [ "$GIS_OPT_THEMETYPE" = "graduated_points" ]; then
- startc="$GIS_OPT_LINECOLOR"
- endc="$GIS_OPT_LINECOLOR"
- else
- startc="$GIS_OPT_POINTCOLOR"
- endc="$GIS_OPT_POINTCOLOR"
- fi
- g.message -e message="This should not happen: gparser error. Unknown color scheme $GIS_OPT_COLORSCHEME"
- cleanup
- exit
- esac
- for i in 1 2 3; do
- eval color$i=`echo $startc | cut -d':' -f$i`
- eval endcolor$i=`echo $endc | cut -d':' -f$i`
- done
- #The number of color steps is one less then the number of classes
- nclrstep=`expr $numint - 1`
- clrstep1=`expr \( $color1 - $endcolor1 \) / $nclrstep`
- clrstep2=`expr \( $color2 - $endcolor2 \) / $nclrstep`
- clrstep3=`expr \( $color3 - $endcolor3 \) / $nclrstep`
- themecolor="$startc"
- # display graduated color themes
- if [ "$GIS_OPT_THEMECALC" = "interval" ] ; then
- echo "move 4 87" >> "$TMP2"
- echo "text Mapped by $numint intervals of $step" >> "$TMP2"
- echo "subtitle - - - {Mapped by $numint intervals of $step}" >> "$TMP6"
- echo "text 4% 87% Mapped by $numint intervals of $step" >> "$TMP5"
- echo " ref bottom left" >> "$TMP5"
- echo "end" >> "$TMP5"
- g.message message="Mapped by $numint intervals of $step"
- fi
- # display graduated color themes for standard deviation units
- if [ "$GIS_OPT_THEMECALC" = "std_deviation" ] ; then
- echo "text Mapped by standard deviation units of $sd (mean =$mean)" >> "$TMP2"
- echo "subtitle - - - {Mapped by standard deviation units of $sd (mean =$mean)}" >> "$TMP6"
- echo "text 4% 87% Mapped by standard deviation units of $sd (mean =$mean)" >> "$TMP5"
- g.message message="Mapped by standard deviation units of $sd (mean =$mean)"
- fi
- # display graduated color themes for quartiles
- if [ "$GIS_OPT_THEMECALC" = "quartiles" ] ; then
- echo "text Mapped by quartiles (median =$q2)" >> "$TMP2"
- echo "subtitle - - - {Mapped by quartiles (median =$q2)}" >> "$TMP6"
- echo "text 4% 87% Mapped by quartiles (median =$q2)" >> "$TMP5"
- g.message message="Mapped by quartiles (median = $q2)"
- fi
- echo "move 4 83" >> "$TMP2"
- echo "text Color" >> "$TMP2"
- echo "move 14 83" >> "$TMP2"
- echo "text Value" >> "$TMP2"
- echo "move 4 80" >> "$TMP2"
- echo "text =====" >> "$TMP2"
- echo "move 14 80" >> "$TMP2"
- echo "text ============" >> "$TMP2"
- echo "text 4% 83% Color" >> "$TMP5"
- echo "text 14% 83% Value" >> "$TMP5"
- echo "text 4% 80% =====" >> "$TMP5"
- echo "text 14% 80% ============" >> "$TMP5"
- echo "Color(R:G:B)" "Value" | awk '{print $1 "\t" $2}'
- echo "============" "==========" | awk '{print $1 "\t" $2}'
- line1=78
- line2=76
- line3=75
- i=1
- first="true"
- while [ $i -le $numint ]
- do
- if [ "$GIS_FLAG_M" -eq 1 ] ; then
- # math notation
- if [ "$first" = "true" ] ; then
- closebracket="]"
- openbracket="["
- mincomparison=">="
- first="false"
- else
- closebracket="]"
- openbracket="]"
- mincomparison=">"
- fi
- else
- closebracket=""
- openbracket=""
- first="false"
- else
- mincomparison=">"
- fi
- fi
- themecolor="$color1:$color2:$color3"
- if [ "$GIS_FLAG_F" -eq 1 ] ; then
- linecolor="none"
- else
- if [ "$GIS_OPT_TYPE" = "line" -o "$GIS_OPT_TYPE" = "boundary" ] ; then
- linecolor=$themecolor
- else
- linecolor="$GIS_OPT_LINECOLOR"
- fi
- fi
- rangemin=`echo $i $breakpoints | awk '{t=$1+1;print $t}'`
- rangemax=`echo $i $breakpoints | awk '{t=$1+2;print $t}'`
- if [ -z "$annotations" ]; then
- extranote=""
- else
- extranote=`echo $annotations| cut -d';' -f$i`
- fi
- if [ $i -lt $xlower -o $i -ge $xupper ]; then
- xline1=`expr $line2 + 2`
- xline3=`expr $line2 - 1`
- echo "color $themecolor" >> "$TMP2"
- echo "polygon" >> "$TMP2"
- echo "5 $xline1" >> "$TMP2"
- echo "8 $xline1" >> "$TMP2"
- echo "8 $xline3" >> "$TMP2"
- echo "5 $xline3" >> "$TMP2"
- echo "color $linecolor" >> "$TMP2"
- echo "move 5 $xline1" >> "$TMP2"
- echo "draw 8 $xline1" >> "$TMP2"
- echo "draw 8 $xline3" >> "$TMP2"
- echo "draw 5 $xline3" >> "$TMP2"
- echo "draw 5 $xline1" >> "$TMP2"
- echo "move 14 $line2" >> "$TMP2"
- echo "color 0:0:0" >> "$TMP2"
- echo "text $openbracket$rangemin - $rangemax$closebracket $extranote" >> "$TMP2"
- else
- if [ $i -eq $xlower ]; then
- echo "move 10 $line2" >> "$TMP2"
- echo "text ..." >> "$TMP2"
- else
- #undo next increment
- line2=`expr $line2 + 4`
- fi
- fi
- echo "area $themecolor $linecolor - {$openbracket$rangemin - $rangemax$closebracket $extranote}" >> "$TMP6"
- echo "line 5% $xline1% 8% $xline1%" >> "$TMP5"
- echo " color $linecolor" >> "$TMP5"
- echo "text 14% $xline1% $openbracket$rangemin - $rangemax$closebracket $extranote" >> "$TMP5"
- echo " ref center left" >> "$TMP5"
- elif [ "$GIS_OPT_TYPE" = "point" -o "$GIS_OPT_TYPE" = "centroid" ] ; then
- echo "point 8% $xline1%" >> "$TMP5"
- echo " fcolor $themecolor" >> "$TMP5"
- echo " size $GIS_OPT_SIZE" >> "$TMP5"
- echo " symbol $GIS_OPT_ICON" >> "$TMP5"
- else
- echo "rectangle 5% $xline1% 8% $xline3%" >> "$TMP5"
- echo " color 0:0:0" >> "$TMP5"
- echo "text 14% $xline3% $openbracket$rangemin - $rangemax$closebracket DCADCA $extranote" >> "$TMP5"
- fi
- else
- echo "color 0:0:0" >>"$TMP5"
- echo "text 14% $xline3% ..." >> "$TMP5"
- echo "text - - - {...}" >> "$TMP6"
- fi
- fi
- echo $themecolor@$rangemin@$rangemax@$extranote@$openbracket@$closebracket | awk -F@ '{print $1 "\t\t" $5$2" - "$3$6" "$4}'
- if [ -z "$GIS_OPT_WHERE" ] ; then
- sqlwhere="$GIS_OPT_COLUMN $mincomparison $rangemin and $GIS_OPT_COLUMN<=$rangemax"
- else
- sqlwhere="$GIS_OPT_COLUMN $mincomparison $rangemin and $GIS_OPT_COLUMN<=$rangemax AND $GIS_OPT_WHERE"
- fi
- # update color to database?
- if [ $GIS_FLAG_U -eq 1 ] ; then
- echo "UPDATE $table SET GRASSRGB = '$themecolor' WHERE\
- $sqlwhere" | db.execute database="${database}" driver=${driver}
- fi
- # Create group for GIS Manager
- if [ "$GIS_FLAG_G" -eq 1 ] ; then
- # change rgb colors to hex
- xthemecolor=`echo $themecolor | awk -F: '{printf("#%02X%02X%02X\n",$1,$2,$3)}'`
-# xlinecolor=`echo $linecolor | awk -F: '{printf("#%02X%02X%02X\n",$1,$2,$3)}'`
- if [ "$linecolor" = "black" ] ; then
- xlinecolor="#000000"
- else
- xlinecolor=$xthemecolor
- fi
- # create group entry
- echo " _check 1" >> "$TMP3"
- echo " Vector $GIS_OPT_COLUMN = $rangemin - $rangemax" >> "$TMP3"
- echo " map $GIS_OPT_MAP" >> "$TMP3"
- echo " display_shape 1" >> "$TMP3"
- echo " display_cat 0" >> "$TMP3"
- echo " display_topo 0" >> "$TMP3"
- echo " display_dir 0" >> "$TMP3"
- echo " display_attr 0" >> "$TMP3"
- echo " type_point $ptype" >> "$TMP3"
- echo " type_line $ltype" >> "$TMP3"
- echo " type_boundary $btype" >> "$TMP3"
- echo " type_centroid $ctype" >> "$TMP3"
- echo " type_area $atype" >> "$TMP3"
- echo " type_face 0" >> "$TMP3"
- echo " color $xlinecolor" >> "$TMP3"
- echo " fcolor $xthemecolor" >> "$TMP3"
- echo " width $ptsize" >> "$TMP3"
- echo " _use_fcolor 1" >> "$TMP3"
- echo " lcolor #000000" >> "$TMP3"
- echo " sqlcolor 0" >> "$TMP3"
- echo " icon $GIS_OPT_ICON" >> "$TMP3"
- echo " size $ptsize" >> "$TMP3"
- echo " field $GIS_OPT_LAYER" >> "$TMP3"
- echo " lfield $GIS_OPT_LAYER" >> "$TMP3"
- echo " attribute" >> "$TMP3"
- echo " xref left" >> "$TMP3"
- echo " yref center" >> "$TMP3"
- echo " lsize 8" >> "$TMP3"
- echo " cat" >> "$TMP3"
- echo " where "$sqlwhere >> "$TMP3"
- echo " _query_text 0" >> "$TMP3"
- echo " _query_edit 1" >> "$TMP3"
- echo " _use_where 1" >> "$TMP3"
- echo " minreg" >> "$TMP3"
- echo " maxreg" >> "$TMP3"
- echo " _width 0.1" >> "$TMP3"
- echo " End" >> "$TMP3"
- fi
- # display theme vector map
- d.vect map=$GIS_OPT_MAP type=$GIS_OPT_TYPE layer=$GIS_OPT_LAYER \
- where="$sqlwhere" \
- color=$linecolor fcolor=$themecolor icon=$GIS_OPT_ICON size=$ptsize
- echo "vlines $GIS_OPT_MAP" >> "$TMP4"
- echo " type $GIS_OPT_TYPE" >> "$TMP4"
- echo " layer $GIS_OPT_LAYER" >> "$TMP4"
- echo " where $sqlwhere" >> "$TMP4"
- echo " color $linecolor" >> "$TMP4"
- echo " label $rangemin - $rangemax" >> "$TMP4"
- echo "end" >> "$TMP4"
- echo "vpoints $GIS_OPT_MAP" >> "$TMP4"
- echo " fcolor $themecolor" >> "$TMP4"
- echo " symbol $GIS_OPT_ICON" >> "$TMP4"
- else
- echo "vareas $GIS_OPT_MAP" >> "$TMP4"
- fi
- # increment for next theme
- i=`expr $i + 1`
- if [ $i = $numint ] ; then
- color1=$endcolor1
- color2=$endcolor2
- color3=$endcolor3
- else
- color1=`expr $color1 - $clrstep1`
- color2=`expr $color2 - $clrstep2`
- color3=`expr $color3 - $clrstep3`
- fi
- line1=`expr $line1 - 4`
- line2=`expr $line2 - 4`
- line3=`expr $line3 - 4`
- done
-fi
-#graduated points and line widths thematic mapping
-if [ "$GIS_OPT_THEMETYPE" = "graduated_points" -o "$GIS_OPT_THEMETYPE" = "graduated_lines" ] ; then
- #display graduated points/lines by intervals
- fi
- # display graduated points/lines for standard deviation units
- fi
- # display graduated points/lines for quartiles
- fi
- line1=76
- line2=75
- echo "text Size/width" >> "$TMP2"
- echo "move 25 83" >> "$TMP2"
- echo "text ==============" >> "$TMP2"
- echo "move 25 80" >> "$TMP2"
- echo "text 4% 83% Icon size" >> "$TMP5"
- echo "text 25% 83% Value" >> "$TMP5"
- echo "text 4% 80% ============" >> "$TMP5"
- echo "text 25% 80% ============" >> "$TMP5"
- echo "Size/width" "Value" | awk '{print $1 " " $2"\t"$3}'
- echo "==========" "=====" | awk '{print $1 "\t" $2}'
- themecolor=$GIS_OPT_POINTCOLOR
- linecolor="none"
- else
- fi
- i=$numint
- ptsize=$GIS_OPT_MAXSIZE
- while [ $i -ge 1 ]
- do
- # math notation
- if [ "$i" = "1" ] ; then
- closebracket="]"
- openbracket="["
- else
- closebracket="]"
- openbracket="]"
- mincomparison=">"
- fi
- else
- closebracket=""
- openbracket=""
- else
- mincomparison=">"
- fi
- fi
- linecolor="none"
- else
- fi
- extranote=""
- else
- fi
- iconsize=`echo $ptsize | awk '{print int($1 / 2)}'`
- lineht=`echo $ptsize | awk '{print int($1 / 4)}'`
- if [ "$lineht" -lt "4" ] ; then
- lineht=4
- fi
- if [ "$GIS_OPT_THEMETYPE" = "graduated_lines" ]; then
- echo "line $themecolor $linecolor $ptsize {$openbracket$rangemin - $rangemax$closebracket $extranote}" >> "$TMP6"
- else
- echo "point $themecolor $linecolor $ptsize {$openbracket$rangemin - $rangemax$closebracket $extranote}" >> "$TMP6"
- fi
- echo "icon + $iconsize 5 $line1" >> "$TMP2"
- echo "text $ptsize pts" >> "$TMP2"
- echo "move 25 $line2" >> "$TMP2"
- else
- echo "color 0:0:0" >>"$TMP2"
- echo "text - - - ..." >> "$TMP6"
- else
- # undo future line increment
- line2=`expr $line2 + $lineht`
- fi
- fi
- echo "point 8% $line1%" >> "$TMP5"
- echo " size $iconsize" >> "$TMP5"
- echo "text 25% $line1% $openbracket$rangemin - $rangemax$closebracket $extranote" >> "$TMP5"
- else
- echo "text 25% $xline1% ..." >> "$TMP5"
- fi
- fi
- echo $ptsize@$rangemin@$rangemax@$extranote@$openbracket@$closebracket | awk -F@ '{print $1 "\t\t" $5$2" - "$3$6" "$4}'
- else
- fi
- fi
- fi
- #graduates line widths or point sizes
- if [ "$GIS_OPT_THEMETYPE" = "graduated_lines" ] ; then
- color=$linecolor fcolor=$themecolor icon=$GIS_OPT_ICON size=$ptsize \
- width=$ptsize
- else
- fi
- echo " size $ptsize" >> "$TMP4"
- ptsize=`echo $ptsize $pointstep | awk '{print $1 - $2}'`
- line1=`expr $line1 - $lineht`
- line2=`expr $line2 - $lineht`
- i=`expr $i - 1`
- done
-fi
- # reset display parameters
- GRASS_RENDER_FILE_READ=$pngread
- GRASS_PNG_AUTO_WRITE=$autowrite
-fi
-# Create graphic legend
-if [ "$GIS_FLAG_L" -eq 1 -a "$GIS_OPT_MONITOR" != "none" ] ; then
- if [ `eval d.mon -L | grep $GIS_OPT_MONITOR | awk '{print $5}'` = "not" ] ; then
- d.mon start=$GIS_OPT_MONITOR > /dev/null
- else
- d.mon select=$GIS_OPT_MONITOR > /dev/null
- d.erase
- fi
- d.graph input="$TMP2"
- if [ -n "$currmon" ] ; then
- d.mon select=$currmon
- fi
-fi
-# Create group file for GIS Manager
-echo "End" >> "$TMP3"
-if [ "$GIS_FLAG_G" -eq 1 ] ; then
- cat "$TMP3" > "${group}.dm"
-fi
-# Create ps.map map file
-echo "end" >> "$TMP4"
-if [ "$GIS_OPT_PSMAP" ] ; then
- cat "$TMP4" > "$GIS_OPT_PSMAP.psmap"
-fi
-# Create ps.map legend file
- cat "$TMP5" > "$GIS_OPT_PSMAP\_legend.psmap"
-fi
-# Create text file to use with d.graph in GIS Manager
- tmpdir=`eval dirname "$TMP6"`
- tlegfile="$tmpdir/gismlegend.txt"
-# echo $tlegfile > outtxt.txt
- cp "$TMP6" "$tlegfile"
-fi
-cleanup
