[GRASS-SVN] r63873 - in grass-addons/grass7: general/g.copyall general/g.isis3mt gui/wxpython/wx.metadata/r.info.iso gui/wxpython/wx.metadata/v.info.iso imagery/i.fusion.brovey imagery/i.segment.hierarchical raster/r.convert raster/r.droka raster/r.forestfrag raster/r.hazard.flood raster/r.mcda.input raster/r.mcda.output raster/r.mcda.roughset raster/r.random.weight raster/r.rock.stability raster/r.shalstab raster/r.soillossbare raster/r.threshold raster/r.to.vect.lines raster/r.to.vect.tiled vector/v.civil/v.civil.river vector/v.civil/v.civil.road vector/v.civil/v.civil.tools vector/v.civil/v.civil.topo vector/v.class.ml vector/v.class.mlpy vector/v.out.png vector/v.stats
svn_grass at osgeo.org
Mon Dec 29 13:19:02 PST 2014
Author: neteler
Date: 2014-12-29 13:19:02 -0800 (Mon, 29 Dec 2014)
New Revision: 63873
grass-addons/grass7/general/g.copyall/g.copyall.py
grass-addons/grass7/general/g.isis3mt/g.isis3mt.py
grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py
grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py
grass-addons/grass7/imagery/i.fusion.brovey/i.fusion.brovey.py
grass-addons/grass7/imagery/i.segment.hierarchical/i.segment.hierarchical.py
grass-addons/grass7/raster/r.convert/r.convert
grass-addons/grass7/raster/r.convert/r.convert.all
grass-addons/grass7/raster/r.droka/r.droka.py
grass-addons/grass7/raster/r.forestfrag/r.forestfrag
grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py
grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py
grass-addons/grass7/raster/r.mcda.output/r.mcda.output.py
grass-addons/grass7/raster/r.mcda.roughset/r.mcda.roughset.py
grass-addons/grass7/raster/r.random.weight/r.random.weight.py
grass-addons/grass7/raster/r.random.weight/r.random.weight_legacy.py
grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py
grass-addons/grass7/raster/r.shalstab/r.shalstab.py
grass-addons/grass7/raster/r.soillossbare/r.soillossbare.py
grass-addons/grass7/raster/r.threshold/r.threshold.py
grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.py
grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py
grass-addons/grass7/vector/v.civil/v.civil.river/v.civil.river.py
grass-addons/grass7/vector/v.civil/v.civil.road/v.civil.road.py
grass-addons/grass7/vector/v.civil/v.civil.tools/v.civil.tools.py
grass-addons/grass7/vector/v.civil/v.civil.topo/v.civil.topo.py
grass-addons/grass7/vector/v.class.ml/v.class.ml.py
grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.py
grass-addons/grass7/vector/v.out.png/v.out.png.py
grass-addons/grass7/vector/v.stats/v.stats.py
Addons: keywords white space and no comma standardization
Modified: grass-addons/grass7/general/g.copyall/g.copyall.py
--- grass-addons/grass7/general/g.copyall/g.copyall.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/general/g.copyall/g.copyall.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -19,43 +19,43 @@
#%Module
-#% description: Copies all or a filtered subset of files of selected type from another mapset to the current working mapset
-#% keywords: copy
-#% keywords: general
-#% overwrite: yes
+#% description: Copies all or a filtered subset of files of selected type from another mapset to the current working mapset
+#% keywords: copy
+#% keywords: general
+#% overwrite: yes
#%End
#%option G_OPT_M_MAPSET
-#% key: mapset
-#% description: Mapset to copy files from
-#% required: yes
+#% key: mapset
+#% description: Mapset to copy files from
+#% required: yes
#%end
#%option
-#% key: datatype
-#% type: string
-#% description: Choose type of GRASS data to copy
-#% options: rast,vect,labels,rast3d,region,group
-#% answer: rast
-#% required: yes
+#% key: datatype
+#% type: string
+#% description: Choose type of GRASS data to copy
+#% options: rast,vect,labels,rast3d,region,group
+#% answer: rast
+#% required: yes
#%end
#%option
-#% key: filter
-#% type: string
-#% description: Search pattern to filter data files to copy
-#% required : no
+#% key: filter
+#% type: string
+#% description: Search pattern to filter data files to copy
+#% required : no
#%end
#%option
-#% key: filter_type
-#% type: string
-#% description: Type of search pattern to use
-#% options: select all, wildcards,regular expressions,extended regular expressions
-#% answer: select all
-#% required : no
+#% key: filter_type
+#% type: string
+#% description: Type of search pattern to use
+#% options: select all, wildcards,regular expressions,extended regular expressions
+#% answer: select all
+#% required : no
#%end
#%option
-#% key: output_prefix
-#% type: string
-#% description: Optional prefix for output raster maps
-#% required : no
+#% key: output_prefix
+#% type: string
+#% description: Optional prefix for output raster maps
+#% required : no
#%end
#% Flag
#% key: t
Modified: grass-addons/grass7/general/g.isis3mt/g.isis3mt.py
--- grass-addons/grass7/general/g.isis3mt/g.isis3mt.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/general/g.isis3mt/g.isis3mt.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -21,9 +21,9 @@
# Add a note to the user to use matchmap=yes in cam2map
#%module
-#% description: Generates an ISIS3 map template file according to the current GRASS coordinate reference system
-#% keywords: coordinates
-#% keywords: projection
+#% description: Generates an ISIS3 map template file according to the current GRASS coordinate reference system
+#% keywords: coordinates
+#% keywords: projection
#%end
#%option
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -13,7 +13,9 @@
#%module
#% description: Creates metadata based on ISO standard for specified raster map.
-#% keywords: raster, metadata, iso
+#% keywords: raster
+#% keywords: metadata
+#% keywords: iso
#%end
#%option G_OPT_R_MAP
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -13,7 +13,9 @@
#%module
#% description: Creates metadata based on ISO standard for specified vector map.
-#% keywords: vector, metadata, iso
+#% keywords: vector
+#% keywords: iso
#%end
#%option G_OPT_V_MAP
Modified: grass-addons/grass7/imagery/i.fusion.brovey/i.fusion.brovey.py
--- grass-addons/grass7/imagery/i.fusion.brovey/i.fusion.brovey.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/imagery/i.fusion.brovey/i.fusion.brovey.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -28,25 +28,25 @@
#%Module
-#% description: Brovey transform to merge multispectral and high-res panchromatic channels
-#% keywords: imagery
-#% keywords: fusion
-#% keywords: Brovey
+#% description: Brovey transform to merge multispectral and high-res panchromatic channels
+#% keywords: imagery
+#% keywords: fusion
+#% keywords: Brovey
#%End
#%Flag
-#% key: l
-#% description: LANDSAT sensor
-#% guisection: Sensor
+#% key: l
+#% description: LANDSAT sensor
+#% guisection: Sensor
#%END
#%Flag
-#% key: q
-#% description: QuickBird sensor
+#% key: q
+#% description: QuickBird sensor
#%END
#%Flag
-#% key: s
-#% description: SPOT sensor
+#% key: s
+#% description: SPOT sensor
#%END
#%option G_OPT_R_INPUT
#% key: ms1
Modified: grass-addons/grass7/imagery/i.segment.hierarchical/i.segment.hierarchical.py
--- grass-addons/grass7/imagery/i.segment.hierarchical/i.segment.hierarchical.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/imagery/i.segment.hierarchical/i.segment.hierarchical.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -16,123 +16,123 @@
#%Module
-#% description: Hierarchical segmentation
-#% keywords: segment
-#% overwrite: yes
+#% description: Hierarchical segmentation
+#% keywords: segment
+#% overwrite: yes
#%End
#%option G_OPT_I_GROUP
-#% key: group
-#% description: Name of input imagery group
-#% required: yes
+#% key: group
+#% description: Name of input imagery group
+#% required: yes
#%end
#%option
-#% key: thresholds
-#% type: double
-#% multiple: yes
-#% description: Segment thresholds
-#% required: yes
-#% answer: 0.02,0.05
+#% key: thresholds
+#% type: double
+#% multiple: yes
+#% description: Segment thresholds
+#% required: yes
+#% answer: 0.02,0.05
#%end
#%option G_OPT_R_OUTPUT
-#% key: output
-#% description: Name of output sement raster map
-#% required: yes
+#% key: output
+#% description: Name of output sement raster map
+#% required: yes
#%end
#%option
-#% key: outputs_prefix
-#% type: string
-#% description: Name for output raster maps from segment
-#% required: no
-#% answer: seg__%.2f
+#% key: outputs_prefix
+#% type: string
+#% description: Name for output raster maps from segment
+#% required: no
+#% answer: seg__%.2f
#%end
#%option
-#% key: method
-#% type: string
-#% description: Segmentation method
-#% required: no
-#% answer: region_growing
-#% guisection: Segment
+#% key: method
+#% type: string
+#% description: Segmentation method
+#% required: no
+#% answer: region_growing
+#% guisection: Segment
#%end
#%option
-#% key: similarity
-#% type: string
-#% description: Similarity calculation method
-#% required: no
-#% answer: euclidean
+#% key: similarity
+#% type: string
+#% description: Similarity calculation method
+#% required: no
+#% answer: euclidean
#%end
#%option
-#% key: minsizes
-#% type: integer
-#% description: Minimum number of cells in a segment
-#% multiple: yes
-#% required: no
+#% key: minsizes
+#% type: integer
+#% description: Minimum number of cells in a segment
+#% multiple: yes
+#% required: no
#%end
#%option
-#% key: memory
-#% type: integer
-#% description: Memory in MB
-#% required: no
-#% answer: 300
+#% key: memory
+#% type: integer
+#% description: Memory in MB
+#% required: no
+#% answer: 300
#%end
#%option
-#% key: iterations
-#% type: integer
-#% description: Maximum number of iterations
-#% required: no
-#% answer: 20
+#% key: iterations
+#% type: integer
+#% description: Maximum number of iterations
+#% required: no
+#% answer: 20
#%end
-#% key: seeds
-#% description: Name for input raster map with starting seeds
-#% required: no
+#% key: seeds
+#% description: Name for input raster map with starting seeds
+#% required: no
#%end
-#% key: bounds
-#% description: Name of input bounding/constraining raster map
-#% required: no
+#% key: bounds
+#% description: Name of input bounding/constraining raster map
+#% required: no
#%end
#%option
-#% key: width
-#% description: Tile width in pixels
-#% type: integer
-#% required: no
-#% guisection: Grid
+#% key: width
+#% description: Tile width in pixels
+#% type: integer
+#% required: no
+#% guisection: Grid
#%end
#%option
-#% key: height
-#% description: Tile height in pixels
-#% type: integer
-#% required: no
+#% key: height
+#% description: Tile height in pixels
+#% type: integer
+#% required: no
#%end
#%option
-#% key: overlap
-#% description: Tile overlap in pixels
-#% type: integer
-#% required: no
-#% answer: 0
+#% key: overlap
+#% description: Tile overlap in pixels
+#% type: integer
+#% required: no
+#% answer: 0
#%end
#%option
-#% key: processes
-#% description: Number of concurrent processes
-#% type: integer
-#% required: no
+#% key: processes
+#% description: Number of concurrent processes
+#% type: integer
+#% required: no
#%end
#%option
-#% key: move
-#% description: Path where move and copy the mapset
-#% type: string
-#% required: no
+#% key: move
+#% description: Path where move and copy the mapset
+#% type: string
+#% required: no
#%end
Modified: grass-addons/grass7/raster/r.convert/r.convert
--- grass-addons/grass7/raster/r.convert/r.convert 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.convert/r.convert 2014-12-29 21:19:02 UTC (rev 63873)
@@ -15,8 +15,10 @@
#%Module
-#% description: Converts a GRASS 4-6 raster map to a GRASS 7 raster map format
-#% keywords: raster, import, conversion
+#% description: Converts a GRASS Version 4-6 raster map to a GRASS 7 raster map format
+#% keywords: import
+#% keywords: conversion
#%end
#%option
#% key: map
Modified: grass-addons/grass7/raster/r.convert/r.convert.all
--- grass-addons/grass7/raster/r.convert/r.convert.all 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.convert/r.convert.all 2014-12-29 21:19:02 UTC (rev 63873)
@@ -13,8 +13,11 @@
#%Module
-#% description: Converts all GRASS 4-6 raster maps in current mapset to GRASS 7 raster map format
-#% keywords: raster, import, conversion, bulk
+#% description: Converts all GRASS Version 4-6 raster maps in current mapset to GRASS 7 raster map format
+#% keywords: bulk
#%end
#%flag
#% key: m
Modified: grass-addons/grass7/raster/r.droka/r.droka.py
--- grass-addons/grass7/raster/r.droka/r.droka.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.droka/r.droka.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -16,8 +16,9 @@
#%Module
-#% description: Calculates run-out distance of a falling rock mass
-#% keywords: rock mass, rockfall
+#% description: Calculates run-out distance of a falling rock mass
+#% keywords: rock mass
+#% keywords: rockfall
#%End
#%option
#% key: dem
Modified: grass-addons/grass7/raster/r.forestfrag/r.forestfrag
--- grass-addons/grass7/raster/r.forestfrag/r.forestfrag 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.forestfrag/r.forestfrag 2014-12-29 21:19:02 UTC (rev 63873)
@@ -27,7 +27,10 @@
#%Module
#% description: creates forest fragmentation index from a GRASS raster map (where forest=1, non-forest=0) based on a method developed by Riitters et. al (2000). The index is computed using a moving window of user-defined size (default=3).
-#% keywords: raster, forest, fragmentation-index, Riitters
+#% keywords: forest
+#% keywords: fragmentation index
+#% keywords: Riitters
#%End
#%Option
Modified: grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py
--- grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -17,32 +17,32 @@
#%module
-#% description: Fast procedure to detect flood prone areas
+#% description: Fast procedure to detect flood prone areas
#%end
#%option
-#% key: map
-#% type: string
-#% gisprompt: old,raster,raster
-#% key_desc: elevation
-#% description: Name of elevation raster map
-#% required: yes
+#% key: map
+#% type: string
+#% gisprompt: old,raster,raster
+#% key_desc: elevation
+#% description: Name of elevation raster map
+#% required: yes
#%end
#%option
-#% key: flood
-#% type: string
-#% gisprompt: new,raster,raster
-#% key_desc: flood
-#% description: Name of output flood raster map
-#% required: yes
+#% key: flood
+#% type: string
+#% gisprompt: new,raster,raster
+#% key_desc: flood
+#% description: Name of output flood raster map
+#% required: yes
#%end
#%option
-#% key: mti
-#% type: string
-#% key_desc: MTI
-#% description: Name of output MTI raster map
-#% required: yes
+#% key: mti
+#% type: string
+#% key_desc: MTI
+#% description: Name of output MTI raster map
+#% required: yes
#%END
import sys
Modified: grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py
--- grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -16,7 +16,8 @@
#%Module
#% description: Generate a raster map classified with Dominance Rough Set Approach. Use *.rls file from JAMM, 4eMka2 etc.
-#% keywords: raster, Dominance Rough Set Approach
+#% keywords: Dominance Rough Set Approach
#% keywords: Multi Criteria Decision Analysis (MCDA)
#%End
#%option
Modified: grass-addons/grass7/raster/r.mcda.output/r.mcda.output.py
--- grass-addons/grass7/raster/r.mcda.output/r.mcda.output.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.mcda.output/r.mcda.output.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -15,7 +15,8 @@
#%Module
#% description: Export criteria raster maps and decision raster map in a *.isf file (e.g. 4eMka2, jMAF) for dominance rough set approach analysis
#%End
#%option
Modified: grass-addons/grass7/raster/r.mcda.roughset/r.mcda.roughset.py
--- grass-addons/grass7/raster/r.mcda.roughset/r.mcda.roughset.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.mcda.roughset/r.mcda.roughset.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -14,7 +14,8 @@
#%Module
#% description: Generate a MCDA map from several criteria maps using Dominance Rough Set Approach.
#%End
#%option
Modified: grass-addons/grass7/raster/r.random.weight/r.random.weight.py
--- grass-addons/grass7/raster/r.random.weight/r.random.weight.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.random.weight/r.random.weight.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -17,7 +17,8 @@
#%module
#% description: Weighted sample
-#% keywords: raster, sample
+#% keywords: sample
#%end
#%option
Modified: grass-addons/grass7/raster/r.random.weight/r.random.weight_legacy.py
--- grass-addons/grass7/raster/r.random.weight/r.random.weight_legacy.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.random.weight/r.random.weight_legacy.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -17,7 +17,8 @@
#%module
#%end
#%option
Modified: grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py
--- grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -16,7 +16,9 @@
#%Module
#% description: Calculates SMR index for a slope area.
-#% keywords: rock mass, planar failure, toppling
+#% keywords: planar failure
+#% keywords: toppling
#% overwrite: yes
#%End
#%option
Modified: grass-addons/grass7/raster/r.shalstab/r.shalstab.py
--- grass-addons/grass7/raster/r.shalstab/r.shalstab.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.shalstab/r.shalstab.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -16,66 +16,66 @@
#%module
-#% description: A model for shallow landslide susceptibility.
-#% keywords: critical rainfall
-#% keywords: landslide
+#% description: A model for shallow landslide susceptibility.
+#% keywords: critical rainfall
+#% keywords: landslide
#%end
#%option
-#% key: dem
-#% type: string
-#% key_desc: name
-#% description: Name of input elevation raster map
-#% required: yes
+#% key: dem
+#% type: string
+#% key_desc: name
+#% description: Name of input elevation raster map
+#% required: yes
#%end
#%option
-#% key: phy
-#% type: string
-#% key_desc: name
-#% description: Soil friction angle (angle)
-#% required: yes
+#% key: phy
+#% type: string
+#% key_desc: name
+#% description: Soil friction angle (angle)
+#% required: yes
#%end
#%option
-#% key: c_soil
-#% type: string
-#% key_desc: name
-#% description: Soil cohesion (N/m^2)
-#% required: yes
+#% key: c_soil
+#% type: string
+#% key_desc: name
+#% description: Soil cohesion (N/m^2)
+#% required: yes
#%end
#%option
-#% key: gamma
-#% type: string
-#% key_desc: name
-#% description: Soil density(Kg/m^3)
-#% required: yes
+#% key: gamma
+#% type: string
+#% key_desc: name
+#% description: Soil density(Kg/m^3)
+#% required: yes
#%end
#%option
-#% key: z
-#% type: string
-#% key_desc: name
-#% description: Vertical thickness of soil (m)
-#% required: yes
+#% key: z
+#% type: string
+#% key_desc: name
+#% description: Vertical thickness of soil (m)
+#% required: yes
#%end
#%option
-#% key: k
-#% type: string
-#% key_desc: name
-#% description: hydraulic conductivity (m/h)
-#% required: yes
+#% key: k
+#% type: string
+#% key_desc: name
+#% description: hydraulic conductivity (m/h)
+#% required: yes
#%end
#%option
-#% key: root
-#% type: string
-#% key_desc: name
-#% description: Root cohesion k (N/m^2)
-#% required: no
+#% key: root
+#% type: string
+#% key_desc: name
+#% description: Root cohesion k (N/m^2)
+#% required: no
#%end
# output
Modified: grass-addons/grass7/raster/r.soillossbare/r.soillossbare.py
--- grass-addons/grass7/raster/r.soillossbare/r.soillossbare.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.soillossbare/r.soillossbare.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -25,9 +25,11 @@
#%Module
-#% description: Calculate annual soil loss [t/(ha*a)] for bare soil.
-# Use r.soillosscropland.py afterwards for grown soil.
-#% keywords: erosion,raster,bare soil, potential soilloss
+#% description: Calculate annual soil loss [t/(ha*a)] for bare soil. Use r.soillosscropland.py afterwards for grown soil.
+#% keywords: erosion
+#% keywords: bare soil
+#% keywords: potential soilloss
#%end
#%option
Modified: grass-addons/grass7/raster/r.threshold/r.threshold.py
--- grass-addons/grass7/raster/r.threshold/r.threshold.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.threshold/r.threshold.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -19,7 +19,8 @@
#%module
#% description: Find optimal threshold for stream extraction
#% keywords: raster
-#% keywords: hydrology, threshold
+#% keywords: hydrology
+#% keywords: threshold
#%end
#%option
Modified: grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.py
--- grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.to.vect.lines/r.to.vect.lines.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -22,7 +22,9 @@
#%module
#% description: Convert raster rows to vector lines.
-#% keywords: raster, conversion, wiggles
+#% keywords: wiggles
#%end
#%option
#% key: input
Modified: grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py
--- grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -20,7 +20,11 @@
#%module
#% description: Converts a raster map into vector tiles.
-#% keywords: raster, conversion, geometry, vectorization, tiling
+#% keywords: geometry
+#% keywords: vectorization
+#% keywords: tiling
#% overwrite: yes
#%end
Modified: grass-addons/grass7/vector/v.civil/v.civil.river/v.civil.river.py
--- grass-addons/grass7/vector/v.civil/v.civil.river/v.civil.river.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/vector/v.civil/v.civil.river/v.civil.river.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -20,7 +20,10 @@
#%Module
#% description: Export - Import geometry data to/from an 1-D hydrodynamic model.
-#% keywords: vector, Hec-Ras, hydraulic, river
+#% keywords: Hec-Ras
+#% keywords: hydraulic
+#% keywords: river
#%End
#### Required section ####
Modified: grass-addons/grass7/vector/v.civil/v.civil.road/v.civil.road.py
--- grass-addons/grass7/vector/v.civil/v.civil.road/v.civil.road.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/vector/v.civil/v.civil.road/v.civil.road.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -19,8 +19,11 @@
#%Module
-#% description: Generate a alignment for desing roads, channels, ports...
-#% keywords: vector, ROADS, CHANNELS, PORTS.
+#% description: Generate an alignment for desired roads, channels, ports...
+#% keywords: road
+#% keywords: channel
+#% keywords: port
#%End
Modified: grass-addons/grass7/vector/v.civil/v.civil.tools/v.civil.tools.py
--- grass-addons/grass7/vector/v.civil/v.civil.tools/v.civil.tools.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/vector/v.civil/v.civil.tools/v.civil.tools.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -20,7 +20,9 @@
#%module
#% description: Road tool for use with v.civil.road
-#% keywords: vector, Road, civil
+#% keywords: road
+#% keywords: civil
#%end
#### Input section ####
Modified: grass-addons/grass7/vector/v.civil/v.civil.topo/v.civil.topo.py
--- grass-addons/grass7/vector/v.civil/v.civil.topo/v.civil.topo.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/vector/v.civil/v.civil.topo/v.civil.topo.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -20,8 +20,10 @@
#%module
-#% description: Create and modific Points-Breaklines maps, and triangulate, with triangle with v.triangle and nn with r.surf.nnbathy
-#% keywords: vector, TOPO, topography
+#% description: Create and modify Points-Breaklines maps, and triangulate, with triangle with v.triangle and nn with r.surf.nnbathy
+#% keywords: TOPO
+#% keywords: topography
#%end
Modified: grass-addons/grass7/vector/v.class.ml/v.class.ml.py
--- grass-addons/grass7/vector/v.class.ml/v.class.ml.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/vector/v.class.ml/v.class.ml.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -16,347 +16,347 @@
#%Module
-#% description: Vector
-#% keywords: machine learning
-#% keywords: classification
-#% overwrite: yes
+#% description: Vector
+#% keywords: machine learning
+#% keywords: classification
+#% overwrite: yes
#%End
-#% key: vector
-#% description: Name of input vector map
-#% required: yes
+#% key: vector
+#% description: Name of input vector map
+#% required: yes
#%end
-#% key: vtraining
-#% description: Name of training vector map
-#% required: no
+#% key: vtraining
+#% description: Name of training vector map
+#% required: no
#%end
#%option
-#% key: vlayer
-#% type: string
-#% multiple: no
-#% description: layer name or number to use for data
-#% required: no
+#% key: vlayer
+#% type: string
+#% multiple: no
+#% description: layer name or number to use for data
+#% required: no
#%end
#%option
-#% key: tlayer
-#% type: string
-#% multiple: no
-#% description: layer number/name for the training layer
-#% required: no
+#% key: tlayer
+#% type: string
+#% multiple: no
+#% description: layer number/name for the training layer
+#% required: no
#%end
#%option
-#% key: rlayer
-#% type: string
-#% multiple: no
-#% description: layer number/name for the ML results
-#% required: no
+#% key: rlayer
+#% type: string
+#% multiple: no
+#% description: layer number/name for the ML results
+#% required: no
#%end
#%option
-#% key: npy_data
-#% type: string
-#% multiple: no
-#% description: Data with statistics in npy format.
-#% answer: data.npy
-#% required: no
+#% key: npy_data
+#% type: string
+#% multiple: no
+#% description: Data with statistics in npy format.
+#% answer: data.npy
+#% required: no
#%end
#%option
-#% key: npy_cats
-#% type: string
-#% multiple: no
-#% description: Numpy array with vector cats.
-#% answer: cats.npy
-#% required: no
+#% key: npy_cats
+#% type: string
+#% multiple: no
+#% description: Numpy array with vector cats.
+#% answer: cats.npy
+#% required: no
#%end
#%option
-#% key: npy_cols
-#% type: string
-#% multiple: no
-#% description: Numpy array with columns names.
-#% answer: cols.npy
-#% required: no
+#% key: npy_cols
+#% type: string
+#% multiple: no
+#% description: Numpy array with columns names.
+#% answer: cols.npy
+#% required: no
#%end
#%option
-#% key: npy_index
-#% type: string
-#% multiple: no
-#% description: Boolean numpy array with training indexes.
-#% answer: indx.npy
-#% required: no
+#% key: npy_index
+#% type: string
+#% multiple: no
+#% description: Boolean numpy array with training indexes.
+#% answer: indx.npy
+#% required: no
#%end
#%option
-#% key: npy_tdata
-#% type: string
-#% multiple: no
-#% description: training npy file with training set, default: training_data.npy
-#% answer: training_data.npy
-#% required: no
+#% key: npy_tdata
+#% type: string
+#% multiple: no
+#% description: training npy file with training set, default: training_data.npy
+#% answer: training_data.npy
+#% required: no
#%end
#%option
-#% key: npy_tclasses
-#% type: string
-#% multiple: no
-#% description: training npy file with the classes, default: training_classes.npy
-#% answer: training_classes.npy
-#% required: no
+#% key: npy_tclasses
+#% type: string
+#% multiple: no
+#% description: training npy file with the classes, default: training_classes.npy
+#% answer: training_classes.npy
+#% required: no
#%end
#%option
-#% key: npy_btdata
-#% type: string
-#% multiple: no
-#% answer: Xbt.npy
-#% required: no
+#% key: npy_btdata
+#% type: string
+#% multiple: no
+#% answer: Xbt.npy
+#% required: no
#%end
#%option
-#% key: npy_btclasses
-#% type: string
-#% multiple: no
-#% answer: Ybt.npy
-#% required: no
+#% key: npy_btclasses
+#% type: string
+#% multiple: no
+#% answer: Ybt.npy
+#% required: no
#%end
#%option
-#% key: imp_csv
-#% type: string
-#% multiple: no
-#% description: CSV file name with the feature importances rank using extra tree algorithms
-#% answer: features_importances.csv
-#% required: no
+#% key: imp_csv
+#% type: string
+#% multiple: no
+#% description: CSV file name with the feature importances rank using extra tree algorithms
+#% answer: features_importances.csv
+#% required: no
#%end
#%option
-#% key: imp_fig
-#% type: string
-#% multiple: no
-#% description: Figure file name with feature importances rank using extra tree algorithms
-#% answer: features_importances.png
-#% required: no
+#% key: imp_fig
+#% type: string
+#% multiple: no
+#% description: Figure file name with feature importances rank using extra tree algorithms
+#% answer: features_importances.png
+#% required: no
#%end
#%option
-#% key: scalar
-#% type: string
-#% multiple: yes
-#% description: scaler method, center the data before scaling, if no, not scale at all
-#% required: no
-#% answer: with_mean,with_std
+#% key: scalar
+#% type: string
+#% multiple: yes
+#% description: scaler method, center the data before scaling, if no, not scale at all
+#% required: no
+#% answer: with_mean,with_std
#%end
#%option
-#% key: decomposition
-#% type: string
-#% multiple: no
-#% description: choose a decomposition method (PCA, KernelPCA, ProbabilisticPCA, RandomizedPCA, FastICA, TruncatedSVD) and set the parameters using the | to separate the decomposition method from the parameters like: PCA|n_components=98
-#% required: no
-#% answer:
+#% key: decomposition
+#% type: string
+#% multiple: no
+#% description: choose a decomposition method (PCA, KernelPCA, ProbabilisticPCA, RandomizedPCA, FastICA, TruncatedSVD) and set the parameters using the | to separate the decomposition method from the parameters like: PCA|n_components=98
+#% required: no
+#% answer:
#%end
#%option
-#% key: n_training
-#% type: integer
-#% multiple: no
-#% description: Number of random training per class to training the machine learning algorithms
-#% required: no
+#% key: n_training
+#% type: integer
+#% multiple: no
+#% description: Number of random training per class to training the machine learning algorithms
+#% required: no
#%end
#%option
-#% key: pyclassifiers
-#% type: string
-#% multiple: no
-#% description: a python file with classifiers
-#% required: no
+#% key: pyclassifiers
+#% type: string
+#% multiple: no
+#% description: a python file with classifiers
+#% required: no
#%end
#%option
-#% key: pyvar
-#% type: string
-#% multiple: no
-#% description: name of the python variable that must be a list of dictionary
-#% required: no
+#% key: pyvar
+#% type: string
+#% multiple: no
+#% description: name of the python variable that must be a list of dictionary
+#% required: no
#%end
#%option
-#% key: pyindx
-#% type: string
-#% multiple: no
-#% description: specify the index or range of index of the classifiers that you want to use
-#% required: no
+#% key: pyindx
+#% type: string
+#% multiple: no
+#% description: specify the index or range of index of the classifiers that you want to use
+#% required: no
#%end
#%option
-#% key: pyindx_optimize
-#% type: string
-#% multiple: no
-#% description: Index of the classifiers to optimize the training set
-#% required: no
+#% key: pyindx_optimize
+#% type: string
+#% multiple: no
+#% description: Index of the classifiers to optimize the training set
+#% required: no
#%end
#%option
-#% key: nan
-#% type: string
-#% multiple: yes
-#% description: Column pattern:Value or Numpy funtion to use to substitute NaN values
-#% required: no
-#% answer: *_skewness:nanmean,*_kurtosis:nanmean
+#% key: nan
+#% type: string
+#% multiple: yes
+#% description: Column pattern:Value or Numpy funtion to use to substitute NaN values
+#% required: no
+#% answer: *_skewness:nanmean,*_kurtosis:nanmean
#%end
#%option
-#% key: inf
-#% type: string
-#% multiple: yes
-#% description: Key:Value or Numpy funtion to use to substitute Inf values
-#% required: no
+#% key: inf
+#% type: string
+#% multiple: yes
+#% description: Key:Value or Numpy funtion to use to substitute Inf values
+#% required: no
#%end
#%option
-#% key: neginf
-#% type: string
-#% multiple: yes
-#% description: Key:Value or Numpy funtion to use to substitute neginf values
-#% required: no
-#% answer:
+#% key: neginf
+#% type: string
+#% multiple: yes
+#% description: Key:Value or Numpy funtion to use to substitute neginf values
+#% required: no
+#% answer:
#%end
#%option
-#% key: posinf
-#% type: string
-#% multiple: yes
-#% description: Key:Value or Numpy funtion to use to substitute posinf values
-#% required: no
-#% answer:
+#% key: posinf
+#% type: string
+#% multiple: yes
+#% description: Key:Value or Numpy funtion to use to substitute posinf values
+#% required: no
+#% answer:
#%end
#%option
-#% key: csv_test_cls
-#% type: string
-#% multiple: no
-#% description: csv file name with results of different machine learning scores
-#% required: no
-#% answer: test_classifiers.csv
+#% key: csv_test_cls
+#% type: string
+#% multiple: no
+#% description: csv file name with results of different machine learning scores
+#% required: no
+#% answer: test_classifiers.csv
#%end
#%option
-#% key: report_class
-#% type: string
-#% multiple: no
-#% description: text file name with the report of different machine learning algorithms
-#% required: no
-#% answer: classification_report.txt
+#% key: report_class
+#% type: string
+#% multiple: no
+#% description: text file name with the report of different machine learning algorithms
+#% required: no
+#% answer: classification_report.txt
#%end
#%option
-#% key: svc_c_range
-#% type: double
-#% multiple: yes
-#% description: C value range list to explore SVC domain
-#% required: no
-#% answer: 1e-2,1e-1,1e0,1e1,1e2,1e3,1e4,1e5,1e6,1e7,1e8
+#% key: svc_c_range
+#% type: double
+#% multiple: yes
+#% description: C value range list to explore SVC domain
+#% required: no
+#% answer: 1e-2,1e-1,1e0,1e1,1e2,1e3,1e4,1e5,1e6,1e7,1e8
#%end
#%option
-#% key: svc_gamma_range
-#% type: double
-#% multiple: yes
-#% description: gamma value range list to explore SVC domain
-#% required: no
-#% answer: 1e-6,1e-5,1e-4,1e-3,1e-2,1e-1,1e0,1e1,1e2,1e3,1e4
+#% key: svc_gamma_range
+#% type: double
+#% multiple: yes
+#% description: gamma value range list to explore SVC domain
+#% required: no
+#% answer: 1e-6,1e-5,1e-4,1e-3,1e-2,1e-1,1e0,1e1,1e2,1e3,1e4
#%end
#%option
-#% key: svc_kernel_range
-#% type: string
-#% multiple: yes
-#% description: kernel value range list to explore SVC domain
-#% required: no
-#% answer: linear,poly,rbf,sigmoid
+#% key: svc_kernel_range
+#% type: string
+#% multiple: yes
+#% description: kernel value range list to explore SVC domain
+#% required: no
+#% answer: linear,poly,rbf,sigmoid
#%end
#%option
-#% key: svc_poly_range
-#% type: string
-#% multiple: yes
-#% description: polynomial order list to explore SVC domain
-#% required: no
-#% answer:
+#% key: svc_poly_range
+#% type: string
+#% multiple: yes
+#% description: polynomial order list to explore SVC domain
+#% required: no
+#% answer:
#%end
#%option
-#% key: svc_n_jobs
-#% type: integer
-#% multiple: no
-#% description: number of jobs to use during the domain exploration
-#% required: no
-#% answer: 1
+#% key: svc_n_jobs
+#% type: integer
+#% multiple: no
+#% description: number of jobs to use during the domain exploration
+#% required: no
+#% answer: 1
#%end
#%option
-#% key: svc_c
-#% type: double
-#% multiple: no
-#% description: definitive C value
-#% required: no
+#% key: svc_c
+#% type: double
+#% multiple: no
+#% description: definitive C value
+#% required: no
#%end
#%option
-#% key: svc_gamma
-#% type: double
-#% multiple: no
-#% description: definitive gamma value
-#% required: no
+#% key: svc_gamma
+#% type: double
+#% multiple: no
+#% description: definitive gamma value
+#% required: no
#%end
#%option
-#% key: svc_kernel
-#% type: string
-#% multiple: no
-#% description: definitive kernel value. Available kernel are: ‘linear’, ‘poly’, ‘rbf’, ‘sigmoid’, ‘precomputed’
-#% required: no
-#% answer: rbf
+#% key: svc_kernel
+#% type: string
+#% multiple: no
+#% description: definitive kernel value. Available kernel are: ‘linear’, ‘poly’, ‘rbf’, ‘sigmoid’, ‘precomputed’
+#% required: no
+#% answer: rbf
#%end
#%option
-#% key: svc_img
-#% type: string
-#% multiple: no
-#% description: filename pattern with the image of SVC parameter
-#% required: no
-#% answer: domain_%s.svg
+#% key: svc_img
+#% type: string
+#% multiple: no
+#% description: filename pattern with the image of SVC parameter
+#% required: no
+#% answer: domain_%s.svg
#%end
#%option
-#% key: rst_names
-#% type: string
-#% multiple: no
-#% description: filename pattern for raster
-#% required: no
-#% answer: %s
+#% key: rst_names
+#% type: string
+#% multiple: no
+#% description: filename pattern for raster
+#% required: no
+#% answer: %s
#%end
#%flag
-#% key: e
-#% description: Extract the training set from the vtraining map
+#% key: e
+#% description: Extract the training set from the vtraining map
#%end
#%flag
-#% key: n
-#% description: Export to numpy files
+#% key: n
+#% description: Export to numpy files
#%end
#%flag
-#% key: f
-#% description: Feature importances using extra trees algorithm
+#% key: f
+#% description: Feature importances using extra trees algorithm
#%end
#%flag
-#% key: b
-#% description: Balance the training using the class with the minor number of data
+#% key: b
+#% description: Balance the training using the class with the minor number of data
#%end
#%flag
-#% key: o
-#% description: Optimize the training samples
+#% key: o
+#% description: Optimize the training samples
#%end
#%flag
-#% key: c
-#% description: Classify the whole dataset
+#% key: c
+#% description: Classify the whole dataset
#%end
#%flag
-#% key: r
-#% description: Export the classify results to raster maps
+#% key: r
+#% description: Export the classify results to raster maps
#%end
#%flag
-#% key: t
-#% description: Test different classification methods
+#% key: t
+#% description: Test different classification methods
#%end
#%flag
-#% key: v
-#% description: add to test to compute the Bias variance
+#% key: v
+#% description: add to test to compute the Bias variance
#%end
#%flag
-#% key: x
-#% description: add to test to compute extra parameters like: confusion matrix, ROC, PR
+#% key: x
+#% description: add to test to compute extra parameters like: confusion matrix, ROC, PR
#%end
#%flag
-#% key: d
-#% description: Explore the SVC domain
+#% key: d
+#% description: Explore the SVC domain
#%end
#%flag
-#% key: a
-#% description: append the classification results
+#% key: a
+#% description: append the classification results
#%end
from __future__ import (absolute_import, division, print_function,
Modified: grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.py
--- grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/vector/v.class.mlpy/v.class.mlpy.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -2,7 +2,7 @@
-# MODULE: Map Swipe
+# MODULE: v.class.mlpy
# AUTHOR(S): Vaclav Petras
# PURPOSE: Classifies features in vecor map.
# COPYRIGHT: (C) 2012 by Vaclav Petras, and the GRASS Development Team
@@ -20,8 +20,10 @@
#%module
-#% description: Vector supervised classification tool which uses attributes as classification parametres (order of columns matters, names not), cat column identifies feature, class_column is excluded from classification parametres.
-#% keywords: vector, classification, supervised
+#% description: Vector supervised classification tool which uses attributes as classification parametres (order of columns matters, names not), cat column identifies feature, class_column is excluded from classification parametres.
+#% keywords: supervised
#%end
#% key: input
Modified: grass-addons/grass7/vector/v.out.png/v.out.png.py
--- grass-addons/grass7/vector/v.out.png/v.out.png.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/vector/v.out.png/v.out.png.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -16,7 +16,9 @@
#%module
#% description: Export vector map as PNG
-#% keywords: vector, export, PNG
+#% keywords: export
+#% keywords: PNG
#%end
#%option G_OPT_V_INPUT
#%end
Modified: grass-addons/grass7/vector/v.stats/v.stats.py
--- grass-addons/grass7/vector/v.stats/v.stats.py 2014-12-29 21:06:44 UTC (rev 63872)
+++ grass-addons/grass7/vector/v.stats/v.stats.py 2014-12-29 21:19:02 UTC (rev 63873)
@@ -16,122 +16,122 @@
#%Module
-#% description: Vector stats
-#% keywords: statistics
-#% keywords: shape
-#% overwrite: yes
+#% description: Vector stats
+#% keywords: statistics
+#% keywords: shape
+#% overwrite: yes
#%End
-#% key: vector
-#% required: yes
+#% key: vector
+#% required: yes
#%end
#%option
-#% key: layer
-#% type: integer
-#% description: Vector layer
-#% multiple: no
-#% required: no
-#% answer: 1
+#% key: layer
+#% type: integer
+#% description: Vector layer
+#% multiple: no
+#% required: no
+#% answer: 1
#%end
#%option G_OPT_R_INPUTS
-#% key: rasters
-#% description: Name of input raster maps
-#% multiple: yes
-#% required: no
+#% key: rasters
+#% description: Name of input raster maps
+#% multiple: yes
+#% required: no
#%end
-#% key: zones
-#% description: Name of raster zones map
-#% multiple: no
-#% required: no
+#% key: zones
+#% description: Name of raster zones map
+#% multiple: no
+#% required: no
#%end
#%option
-#% key: rprefix
-#% description: Raster prefixes
-#% multiple: yes
-#% required: no
+#% key: rprefix
+#% description: Raster prefixes
+#% multiple: yes
+#% required: no
#%end
#%option
-#% key: skipshape
-#% type: string
-#% multiple: yes
-#% description: Skip shape columns
-#% required: no
-#% answer: area_id
+#% key: skipshape
+#% type: string
+#% multiple: yes
+#% description: Skip shape columns
+#% required: no
+#% answer: area_id
#%end
#%option
-#% key: skipunivar
-#% type: string
-#% multiple: yes
-#% required: no
-#% answer: label,all_cells,non_null_cells,null_cells,mean_of_abs,sum,sum_abs
+#% key: skipunivar
+#% type: string
+#% multiple: yes
+#% required: no
+#% answer: label,all_cells,non_null_cells,null_cells,mean_of_abs,sum,sum_abs
#%end
#%option
-#% key: shpcsv
-#% type: string
-#% multiple: no
-#% description: CSV with the vector statistics of the shape
-#% required: no
+#% key: shpcsv
+#% type: string
+#% multiple: no
+#% description: CSV with the vector statistics of the shape
+#% required: no
#%end
#%option
-#% key: rstcsv
-#% type: string
-#% multiple: yes
-#% description: CSV with the statistics of the raster maps
-#% required: no
+#% key: rstcsv
+#% type: string
+#% multiple: yes
+#% description: CSV with the statistics of the raster maps
+#% required: no
#%end
#%option
-#% key: rstpercentile
-#% type: integer
-#% multiple: no
-#% description: Raster percentile to use
-#% required: no
-#% answer: 90
+#% key: rstpercentile
+#% type: integer
+#% multiple: no
+#% description: Raster percentile to use
+#% required: no
+#% answer: 90
#%end
#%option
-#% key: newlayer
-#% type: integer
-#% description: New vector layer that will be add to the vector map
-#% multiple: no
-#% required: no
-#% answer: 2
+#% key: newlayer
+#% type: integer
+#% description: New vector layer that will be add to the vector map
+#% multiple: no
+#% required: no
+#% answer: 2
#%end
#%option
-#% key: newlayername
-#% type: string
-#% multiple: no
-#% required: no
+#% key: newlayername
+#% type: string
+#% multiple: no
+#% required: no
#%end
#%option
-#% key: newtabname
-#% type: string
-#% multiple: no
-#% required: no
+#% key: newtabname
+#% type: string
+#% multiple: no
+#% required: no
#%end
#%option
-#% key: separator
-#% type: string
-#% multiple: no
-#% required: no
-#% answer: ;
+#% key: separator
+#% type: string
+#% multiple: no
+#% required: no
+#% answer: ;
#%end
#%option
-#% key: nprocs
-#% type: integer
-#% description: Number of process that will be used
-#% multiple: no
-#% required: no
-#% answer: 1
+#% key: nprocs
+#% type: integer
+#% description: Number of process that will be used
+#% multiple: no
+#% required: no
+#% answer: 1
#%end
#%flag
-#% key: r
-#% description: Read from existing CSV files
+#% key: r
+#% description: Read from existing CSV files
#%end
import sys
