[GRASS-SVN] r63879 - grass/branches/releasebranch_7_0
svn_grass at osgeo.org
Tue Dec 30 09:34:27 PST 2014
Author: neteler
Date: 2014-12-30 09:34:27 -0800 (Tue, 30 Dec 2014)
New Revision: 63879
grass/branches/releasebranch_7_0/configure
configure: hardcode GRASS_VERSION_SVN=00000 for platforms without svnversion program available (needed for g.version)configure.in
Modified: grass/branches/releasebranch_7_0/configure
--- grass/branches/releasebranch_7_0/configure 2014-12-30 17:33:56 UTC (rev 63878)
+++ grass/branches/releasebranch_7_0/configure 2014-12-30 17:34:27 UTC (rev 63879)
@@ -1278,7 +1278,7 @@
LIB_VER=`echo ${GRASS_VERSION_NUMBER} | sed 's/^\([0-9.]*\).*$/\1/'`
-GRASS_VERSION_SVN=
+GRASS_VERSION_SVN=00000
# Extract the first word of "svnversion", so it can be a program name with args.
set dummy svnversion; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
@@ -1315,7 +1315,7 @@
if test "$SVN_VERSION" != "no" ; then
GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
if test "$GRASS_VERSION_SVN" = "exported" -o "$GRASS_VERSION_SVN" = "Unversioned directory" ; then
- GRASS_VERSION_SVN=
+ GRASS_VERSION_SVN=00000
fi
fi
@@ -11819,7 +11819,58 @@
fi
fi
+for ac_declaration in \
+ '#include <stdlib.h>' \
+ 'extern "C" void std::exit (int) throw (); using std::exit;' \
+ 'extern "C" void std::exit (int); using std::exit;' \
+ 'extern "C" void exit (int) throw ();' \
+ 'extern "C" void exit (int);' \
+ 'void exit (int);'
+do
+ cat > conftest.$ac_ext <<EOF
+#line 11833 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:11841: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ continue
+fi
+rm -f conftest*
+#line 11851 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:11858: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+ rm -rf conftest*
+ break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+ echo '#ifdef __cplusplus' >>confdefs.h
+ echo $ac_declaration >>confdefs.h
+ echo '#endif' >>confdefs.h
+fi
+else
CXX=
CXXFLAGS=
@@ -11832,7 +11883,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:11836: checking whether to use openDWG" >&5
+echo "configure:11887: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -11852,7 +11903,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:11856: checking for location of openDGW includes" >&5
+echo "configure:11907: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -11878,15 +11929,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11882: checking for $ac_hdr" >&5
+echo "configure:11933: checking for $ac_hdr" >&5
-#line 11885 "configure"
+#line 11936 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11890: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11941: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -11920,7 +11971,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:11924: checking for location of openDWG library" >&5
+echo "configure:11975: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -11961,7 +12012,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:11965: checking whether to use POSIX threads" >&5
+echo "configure:12016: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -11981,7 +12032,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:11985: checking for location of POSIX threads includes" >&5
+echo "configure:12036: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12007,15 +12058,15 @@
do
-echo "configure:12011: checking for $ac_hdr" >&5
+echo "configure:12062: checking for $ac_hdr" >&5
-#line 12014 "configure"
+#line 12065 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12019: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12070: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12049,7 +12100,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12053: checking for location of POSIX threads library" >&5
+echo "configure:12104: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12074,10 +12125,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12078: checking for pthread_create" >&5
+echo "configure:12129: checking for pthread_create" >&5
-#line 12081 "configure"
+#line 12132 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char pthread_create(); below. */
@@ -12100,7 +12151,7 @@
; return 0; }
EOF
-if { (eval echo configure:12104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12127,13 +12178,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12131: checking for pthread_create in -lpthread" >&5
+echo "configure:12182: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpthread $LIBS"
-#line 12137 "configure"
+#line 12188 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12144,7 +12195,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12148: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12194,7 +12245,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12198: checking whether to use OpenMP" >&5
+echo "configure:12249: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -12215,7 +12266,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12219: checking for location of OpenMP includes" >&5
+echo "configure:12270: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12241,15 +12292,15 @@
do
-echo "configure:12245: checking for $ac_hdr" >&5
+echo "configure:12296: checking for $ac_hdr" >&5
-#line 12248 "configure"
+#line 12299 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12304: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12287,7 +12338,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12291: checking for location of OpenMP library" >&5
+echo "configure:12342: checking for location of OpenMP library" >&5
case "$with_openmp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12312,10 +12363,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12316: checking for GOMP_parallel_start" >&5
+echo "configure:12367: checking for GOMP_parallel_start" >&5
-#line 12319 "configure"
+#line 12370 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -12338,7 +12389,7 @@
; return 0; }
EOF
-if { (eval echo configure:12342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -12365,13 +12416,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12369: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12420: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 12375 "configure"
+#line 12426 "configure"
@@ -12382,7 +12433,7 @@
; return 0; }
EOF
-if { (eval echo configure:12386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12455,7 +12506,7 @@
echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12459: checking whether to use OpenCL" >&5
+echo "configure:12510: checking whether to use OpenCL" >&5
echo "$ac_t"""$with_opencl"" 1>&6
case "$with_opencl" in
"no") USE_OPENCL= ;;
@@ -12475,7 +12526,7 @@
echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:12479: checking for location of OpenCL includes" >&5
+echo "configure:12530: checking for location of OpenCL includes" >&5
case "$with_opencl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -12502,15 +12553,15 @@
do
-echo "configure:12506: checking for $ac_hdr" >&5
+echo "configure:12557: checking for $ac_hdr" >&5
-#line 12509 "configure"
+#line 12560 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12514: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12565: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12550,10 +12601,10 @@
LIBS="-framework OpenCL $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:12554: checking for clGetPlatformInfo" >&5
+echo "configure:12605: checking for clGetPlatformInfo" >&5
-#line 12557 "configure"
+#line 12608 "configure"
which can conflict with char clGetPlatformInfo(); below. */
@@ -12576,7 +12627,7 @@
; return 0; }
EOF
-if { (eval echo configure:12580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_clGetPlatformInfo=yes"
else
@@ -12615,15 +12666,15 @@
do
-echo "configure:12619: checking for $ac_hdr" >&5
+echo "configure:12670: checking for $ac_hdr" >&5
-#line 12622 "configure"
+#line 12673 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12678: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12656,7 +12707,7 @@
# With OpenCL library directory
echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:12660: checking for location of OpenCL library" >&5
+echo "configure:12711: checking for location of OpenCL library" >&5
case "$with_opencl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -12680,13 +12731,13 @@
echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:12684: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:12735: checking for clGetPlatformInfo in -lOpenCL" >&5
ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
LIBS="-lOpenCL $LIBS"
-#line 12690 "configure"
+#line 12741 "configure"
@@ -12697,7 +12748,7 @@
clGetPlatformInfo()
; return 0; }
EOF
-if { (eval echo configure:12701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12752: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12757,7 +12808,7 @@
fi
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:12761: checking for special C compiler options needed for large files" >&5
+echo "configure:12812: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -12765,7 +12816,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 12769 "configure"
+#line 12820 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -12781,7 +12832,7 @@
; return 0; }
EOF
-if { (eval echo configure:12785: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12836: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -12790,7 +12841,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 12794 "configure"
+#line 12845 "configure"
@@ -12806,7 +12857,7 @@
; return 0; }
EOF
-if { (eval echo configure:12810: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12861: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -12833,11 +12884,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:12837: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:12888: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 12841 "configure"
+#line 12892 "configure"
@@ -12853,14 +12904,14 @@
; return 0; }
EOF
-if { (eval echo configure:12857: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12908: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 12864 "configure"
+#line 12915 "configure"
#define _FILE_OFFSET_BITS 64
@@ -12878,7 +12929,7 @@
; return 0; }
EOF
-if { (eval echo configure:12882: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12933: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -12904,11 +12955,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:12908: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:12959: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 12912 "configure"
+#line 12963 "configure"
@@ -12924,14 +12975,14 @@
; return 0; }
EOF
-if { (eval echo configure:12928: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12979: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 12935 "configure"
+#line 12986 "configure"
#define _LARGE_FILES 1
@@ -12949,7 +13000,7 @@
; return 0; }
EOF
-if { (eval echo configure:12953: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13004: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -12975,25 +13026,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:12979: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13030: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 12983 "configure"
+#line 13034 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:12990: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13041: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 12997 "configure"
+#line 13048 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13002,7 +13053,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13006: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13057: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13034,25 +13085,25 @@
ac_save_cflags=${CFLAGS}
CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13038: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13089: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13042 "configure"
+#line 13093 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13049: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13100: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13056 "configure"
+#line 13107 "configure"
#include <stdio.h>
@@ -13061,7 +13112,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13065: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13116: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13091,18 +13142,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13095: checking for fseeko" >&5
+echo "configure:13146: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13099 "configure"
+#line 13150 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13119,10 +13170,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13123: checking if system supports Large Files at all" >&5
+echo "configure:13174: checking if system supports Large Files at all" >&5
-#line 13126 "configure"
+#line 13177 "configure"
#include <stdio.h>
@@ -13154,7 +13205,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13158: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13209: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13185,7 +13236,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13189: checking whether to use wxWidgets" >&5
+echo "configure:13240: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -13206,7 +13257,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:13210: checking for $ac_word" >&5
+echo "configure:13261: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -13254,7 +13305,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13258: checking wxWidgets version" >&5
+echo "configure:13309: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -13277,15 +13328,15 @@
do
-echo "configure:13281: checking for $ac_hdr" >&5
+echo "configure:13332: checking for $ac_hdr" >&5
-#line 13284 "configure"
+#line 13335 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
