[GRASS-SVN] r63883 - in grass/branches/releasebranch_7_0: . gui/wxpython/xml
Tue Dec 30 22:00:26 PST 2014
Author: annakrat
Date: 2014-12-30 22:00:26 -0800 (Tue, 30 Dec 2014)
New Revision: 63883
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml
   grass/branches/releasebranch_7_0/gui/wxpython/xml/wxgui_items.xml
wxGUI: add web service to menu (merge from trunk, r63882)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
 63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63275-63276,63279,63281,63283,63287,63290,63292,63297,63302,63304-63307,63315,63319,63327,63330,63332,63339,63342,63345,63361-63363,63367,63379,63389,63391,63393,63402,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63604,63608-63609,63616,63618,63624,63626,63628,63630,63634,63639,63642,63644,63650,63652,63656,63679,63685,63689,63691,63693,63695,63698,63700-63702,63704,63706-63707,63709,63711,63713,63715,63717-63718
 ,63721-63727,63731,63733,63740-63742,63744,63747-63749,63751-63752,63756,63758,63761,63767,63777,63780,63783,63787,63793,63796-63798,63801,63803,63807-63808,63812,63814,63816,63821,63823-63824,63827-63828,63830-63831,63834-63835,63837-63839,63841,63843-63844,63846-63847,63849,63851,63853,63855-63856,63858-63859,63862,63865,63869,63871
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
 ,63721-63727,63731,63733,63740-63742,63744,63747-63749,63751-63752,63756,63758,63761,63767,63777,63780,63783,63787,63793,63796-63798,63801,63803,63807-63808,63812,63814,63816,63821,63823-63824,63827-63828,63830-63831,63834-63835,63837-63839,63841,63843-63844,63846-63847,63849,63851,63853,63855-63856,63858-63859,63862,63865,63869,63871,63882
Modified: grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml
--- grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml	2014-12-31 05:59:02 UTC (rev 63882)
+++ grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml	2014-12-31 06:00:26 UTC (rev 63883)
@@ -222,6 +222,7 @@
       <wxgui-item name="AddRaster"/>
       <wxgui-item name="AddVector"/>
       <wxgui-item name="AddMultipleRastersOrVectors"/>
+      <wxgui-item name="AddWebServiceLayer"/>
       <separator/>
       <wxgui-item name="NewMapDisplayWindow"/>
       <wxgui-item name="CloseCurrentMapDisplayWindow"/>
Modified: grass/branches/releasebranch_7_0/gui/wxpython/xml/wxgui_items.xml
--- grass/branches/releasebranch_7_0/gui/wxpython/xml/wxgui_items.xml	2014-12-31 05:59:02 UTC (rev 63882)
+++ grass/branches/releasebranch_7_0/gui/wxpython/xml/wxgui_items.xml	2014-12-31 06:00:26 UTC (rev 63883)
@@ -167,6 +167,11 @@
     <description>Add multiple raster or vector map layers to current display</description>
     <shortcut>Ctrl+Shift+L</shortcut>
   </wxgui-item>
+  <wxgui-item name="AddWebServiceLayer">
+    <label>Add web service layer</label>
+    <handler>OnAddWS</handler>
+    <description>Add web service layer</description>
+  </wxgui-item>
   <wxgui-item name="NewMapDisplayWindow">
     <label>New map display window</label>
     <handler>OnNewDisplay</handler>
