[GRASS-SVN] r58821 - in grass/trunk/imagery: i.biomass i.eb.eta i.eb.evapfr i.eb.h_sebal01 i.eb.netrad i.eb.soilheatflux i.vi
svn_grass at osgeo.org
Sat Feb 1 07:04:41 PST 2014
Author: neteler
Date: 2014-02-01 07:04:41 -0800 (Sat, 01 Feb 2014)
New Revision: 58821
grass/trunk/imagery/i.biomass/i.biomass.html
grass/trunk/imagery/i.eb.eta/i.eb.eta.html
grass/trunk/imagery/i.eb.evapfr/i.eb.evapfr.html
grass/trunk/imagery/i.eb.h_sebal01/i.eb.h_sebal01.html
grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html
grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html
grass/trunk/imagery/i.vi/i.vi.html
i.biomass, i.eb.*, i.vi manuals: fix references
Modified: grass/trunk/imagery/i.biomass/i.biomass.html
--- grass/trunk/imagery/i.biomass/i.biomass.html 2014-02-01 11:32:14 UTC (rev 58820)
+++ grass/trunk/imagery/i.biomass/i.biomass.html 2014-02-01 15:04:41 UTC (rev 58821)
@@ -16,7 +16,8 @@
It can use the output of i.eb.evapfr directly as water availability input.
<h2>TODO</h2>
-remove Latitude, DOY and Tsw from input and replace with a raster input compatible with r.sun output.
+Remove Latitude, DOY and Tsw from input and replace with a raster
+input compatible with r.sun output.
<h2>SEE ALSO</h2>
@@ -26,9 +27,14 @@
<h2>REFERENCES</h2>
- <p>[1] Bastiaanssen, W.G.M., Ali, S., 2002. A new crop yield forecasting model based on satellite measurements applied across the Indus Basin, Pakistan. Agriculture, Ecosystems and Environment, 94(3):321-340.
+<p>[1] Bastiaanssen, W.G.M., Ali, S., 2002. A new crop yield
+forecasting model based on satellite measurements applied across the
+Indus Basin, Pakistan. Agriculture, Ecosystems and Environment,
+94(3):321-340. (<a href="http://edepot.wur.nl/206553">PDF</a>)
- <p>[2] Chemin, Y., Platonov, A., Abdullaev, I., Ul-Hassan, M. 2005. Supplementing farm level water productivity assessment by remote sensing in transition economies. Water International. 30(4):513-521.
+<p>[2] Chemin, Y., Platonov, A., Abdullaev, I., Ul-Hassan, M. 2005.
+Supplementing farm level water productivity assessment by remote
+sensing in transition economies. Water International. 30(4):513-521.
<h2>AUTHORS</h2>
Modified: grass/trunk/imagery/i.eb.eta/i.eb.eta.html
--- grass/trunk/imagery/i.eb.eta/i.eb.eta.html 2014-02-01 11:32:14 UTC (rev 58820)
+++ grass/trunk/imagery/i.eb.eta/i.eb.eta.html 2014-02-01 15:04:41 UTC (rev 58821)
@@ -28,19 +28,20 @@
<h2>REFERENCES</h2>
- <p>[1] Bastiaanssen, W.G.M., 1995.
- Estimation of Land surface paramters by remote sensing under clear-sky
+<p>[1] Bastiaanssen, W.G.M., 1995.
+Estimation of Land surface paramters by remote sensing under clear-sky
conditions. PhD thesis, Wageningen University, Wageningen, The Netherlands.
+(<a href="http://edepot.wur.nl/206553">PDF</a>)
- <p>[2] Chemin Y., Alexandridis T.A., 2001. Improving spatial resolution of ET
+<p>[2] Chemin Y., Alexandridis T.A., 2001. Improving spatial resolution of ET
seasonal for irrigated rice in Zhanghe, China. Asian Journal of Geoinformatics.
5(1):3-11,2004.
- <p>[3] Alexandridis T.K., Cherif I., Chemin Y., Silleos N.G., Stavrinos E.,
+<p>[3] Alexandridis T.K., Cherif I., Chemin Y., Silleos N.G., Stavrinos E.,
Zalidis G.C. Integrated methodology for estimating water use in Mediterranean
-agricultural areas. Remote Sensing. -(-):,2009. (submitted))
+agricultural areas. Remote Sensing. 2009, 1, 445-465.
+(<a href="http://www.mdpi.com/2072-4292/1/3/445">PDF</a>)
<h2>AUTHORS</h2>
Yann Chemin, Asian Institute of Technology, Thailand
Modified: grass/trunk/imagery/i.eb.evapfr/i.eb.evapfr.html
--- grass/trunk/imagery/i.eb.evapfr/i.eb.evapfr.html 2014-02-01 11:32:14 UTC (rev 58820)
+++ grass/trunk/imagery/i.eb.evapfr/i.eb.evapfr.html 2014-02-01 15:04:41 UTC (rev 58821)
@@ -17,17 +17,19 @@
<h2>REFERENCES</h2>
5(1):3-11,2004.
<h2>AUTHOR</h2>
Modified: grass/trunk/imagery/i.eb.h_sebal01/i.eb.h_sebal01.html
--- grass/trunk/imagery/i.eb.h_sebal01/i.eb.h_sebal01.html 2014-02-01 11:32:14 UTC (rev 58820)
+++ grass/trunk/imagery/i.eb.h_sebal01/i.eb.h_sebal01.html 2014-02-01 15:04:41 UTC (rev 58821)
@@ -45,6 +45,7 @@
seasonal for irrigated rice in Zhanghe, China}''. Asian Journal of
@@ -52,9 +53,9 @@
-agricultural areas. Remote Sensing, 1(3):445-465, 2009.
<h2>AUTHORS</h2>
Yann Chemin, International Rice Research Institute, Los Banos, The
Modified: grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html
--- grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html 2014-02-01 11:32:14 UTC (rev 58820)
+++ grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html 2014-02-01 15:04:41 UTC (rev 58821)
@@ -26,9 +26,18 @@
<a href="i.albedo.html">i.albedo</a>
</em>
<h2>AUTHOR</h2>
-Yann Chemin, International Rice Research Institute, The Philippines<br>
+Yann Chemin, International Rice Research Institute, The Philippines
+<h2>REFERENCES</h2>
+<ul>
+<li>Bastiaanssen, W.G.M., 1995. Regionalization of surface flux
+densities and moisture indicators in composite terrain; a remote
+sensing approach under clear skies in mediterranean climates. PhD
+thesis, Wageningen Agricultural Univ., The Netherland, 271 pp.
+(<a href="http://edepot.wur.nl/206553">PDF</a>)</li>
+</ul>
<p><i>Last changed: $Date$</i>
Modified: grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html
--- grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html 2014-02-01 11:32:14 UTC (rev 58820)
+++ grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html 2014-02-01 15:04:41 UTC (rev 58821)
@@ -21,15 +21,16 @@
<p>Bastiaanssen, W.G.M., 1995.
Estimation of Land surface parameters by remote sensing under clear-sky
+ (<a href="http://edepot.wur.nl/206553">PDF</a>)
<p>Chemin Y., Alexandridis T.A., 2001. Improving spatial resolution of ET seasonal
for irrigated rice in Zhanghe, China. Asian Journal of Geoinformatics. 5(1):3-11,2004.
-<p>Alexandridis T.K., Cherif I., Chemin Y., Silleos N.G., Stavrinos E.,
- Zalidis G.C. Integrated methodology for estimating water use in Mediterranean
- agricultural areas. Remote Sensing. -(-):,2009. (submitted))
+<p>Alexandridis T.K., Cherif I., Chemin Y., Silleos N.G., Stavrinos E.,
+Zalidis G.C. Integrated methodology for estimating water use in Mediterranean
<h2>AUTHOR</h2>
Yann Chemin, Asian Institute of Technology, Thailand<br>
Modified: grass/trunk/imagery/i.vi/i.vi.html
--- grass/trunk/imagery/i.vi/i.vi.html 2014-02-01 11:32:14 UTC (rev 58820)
+++ grass/trunk/imagery/i.vi/i.vi.html 2014-02-01 15:04:41 UTC (rev 58821)
@@ -284,4 +284,15 @@
Baburao Kamble, Asian Institute of Technology, Thailand<br>
+AVHRR, Landsat TM5:
+<ul>
+</ul>
