[GRASS-SVN] r58825 - grass/branches/develbranch_6/db/db.login
svn_grass at osgeo.org
Sat Feb 1 08:21:09 PST 2014
Author: neteler
Date: 2014-02-01 08:21:08 -0800 (Sat, 01 Feb 2014)
New Revision: 58825
grass/branches/develbranch_6/db/db.login/description.html
grass/branches/develbranch_6/db/db.login/main.c
db.login: partial backport of trunk r58820
Modified: grass/branches/develbranch_6/db/db.login/description.html
--- grass/branches/develbranch_6/db/db.login/description.html 2014-02-01 16:15:32 UTC (rev 58824)
+++ grass/branches/develbranch_6/db/db.login/description.html 2014-02-01 16:21:08 UTC (rev 58825)
@@ -1,36 +1,40 @@
<h2>DESCRIPTION</h2>
-<em>db.login</em> sets user/password for driver/database.
+<em>db.login</em> sets the user name and optionally also a password for
+the connection to the selected <b>database</b> through the DB <b>driver</b>.
<h2>NOTE</h2>
-This is only related to SQL database backends (PostgreSQL, MySQL etc).
-The passwords are stored in a hidden file in the user account ('home'
-directory) called <em>.grasslogin6</em>. Only the file owner
-can access this file.
+This is only related to SQL database backends
+like <a href="grass-pg.html">PostgreSQL</a>, <a href="grass-mysql.html">MySQL</a>
+or <a href="grass-odbc.html">ODBC</a>. The passwords are stored in a
+hidden unencrypted file in the user account ('home' directory)
+called <em>.grasslogin65</em>. Only the file owner can access this
+file.
<h2>EXAMPLES</h2>
-Example 1: Username specified, password will be invisibly queried interactively:
+Only username specified (password will be interactively queried
+to remain invisible):
<div class="code"><pre>
db.login user=bacava
</pre></div>
<p>
-Example 2: Username and password specified (note that the command
+Username and password specified (note that the command
lines history will store the password in this way):
-db.login user=bacava pass=secret
+db.login user=bacava password=secret
</pre></div>
<p>
-Example 3: Username and empty password specified (note that the command
+Username and empty password specified (note that the command
-db.login user=bacava pass=""
+db.login user=bacava password=""
</pre></div>
<h2>SEE ALSO</h2>
@@ -39,8 +43,12 @@
<a href="db.test.html">db.test</a>
</em>
+<p>
+<a href="sql.html">SQL support in GRASS GIS</a>
<h2>AUTHOR</h2>
Radim Blazek
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/branches/develbranch_6/db/db.login/main.c
--- grass/branches/develbranch_6/db/db.login/main.c 2014-02-01 16:15:32 UTC (rev 58824)
+++ grass/branches/develbranch_6/db/db.login/main.c 2014-02-01 16:21:08 UTC (rev 58825)
@@ -3,13 +3,14 @@
* MODULE: db.login
* AUTHOR(S): Radim Blazek <radim.blazek gmail.com> (original contributor)
- * Glynn Clements <glynn gclements.plus.com>, Markus Neteler <neteler itc.it>
- * PURPOSE:
- * COPYRIGHT: (C) 2004-2006 by the GRASS Development Team
+ * Glynn Clements <glynn gclements.plus.com>
+ * Markus Neteler <neteler itc.it>
+ * PURPOSE: Store db login settings
+ * COPYRIGHT: (C) 2004-2014 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
#include <stdio.h>
@@ -58,6 +59,7 @@
user->required = NO;
user->multiple = NO;
user->description = _("Username");
+ user->guisection = _("Settings");
password = G_define_option();
password->key = "password";
@@ -65,6 +67,7 @@
password->required = NO;
password->multiple = NO;
password->description = _("Password");
+ password->guisection = _("Settings");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -107,7 +110,8 @@
if (password->answer)
- G_warning(_("The password was stored in file"));
+ /* defined in lib/db/dbmi_base/login.c */
+ G_important_message(_("The password was stored in file (%s/.grasslogin65)"), G_home());
exit(EXIT_SUCCESS);
