[GRASS-SVN] r58829 - grass-addons/grass7/vector/v.surf.mass
svn_grass at osgeo.org
Sat Feb 1 13:17:30 PST 2014
Author: mmetz
Date: 2014-02-01 13:17:30 -0800 (Sat, 01 Feb 2014)
New Revision: 58829
grass-addons/grass7/vector/v.surf.mass/main.c
v.surf.mass: fix weight option
Modified: grass-addons/grass7/vector/v.surf.mass/main.c
--- grass-addons/grass7/vector/v.surf.mass/main.c 2014-02-01 21:01:33 UTC (rev 58828)
+++ grass-addons/grass7/vector/v.surf.mass/main.c 2014-02-01 21:17:30 UTC (rev 58829)
@@ -180,7 +180,7 @@
have_weights = 0;
drastbuf = NULL;
if (w_opt->answer) {
- char * mapset = (char *) G_find_raster2(w_opt->answer, "");
+ char *mapset = (char *) G_find_raster2(w_opt->answer, "");
if (mapset == NULL)
G_fatal_error(_("Raster map <%s> not found"), w_opt->answer);
@@ -224,7 +224,7 @@
if (!areas)
G_fatal_error(_("Out of memory"));
- G_message(_("Reading values..."));
+ G_message(_("Reading area values..."));
/* read values from attribute table or z */
driver = NULL;
if (layer > 0) {
@@ -336,7 +336,7 @@
if (driver)
db_close_database_shutdown_driver(driver);
- G_message(_("Set area id for each cell"));
+ G_message(_("Initialize output"));
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
@@ -367,6 +367,7 @@
+ G_message(_("Set area id for each cell"));
IPoints = NULL;
ibox = NULL;
isl_allocated = 0;
@@ -432,7 +433,7 @@
ap->count++;
if (have_weights) {
thiscell.interp *= thiscell.weight;
- ap->interp += thiscell.interp;
+ ap->interp += thiscell.weight;
segment_put(&out_seg, &thiscell, row, col);
@@ -460,8 +461,9 @@
ap = &areas[thiscell.area];
value = thiscell.interp / ap->count;
- if (have_weights && ap->interp > 0) {
- value *= ap->value / ap->interp;
+ if (have_weights) {
+ if (ap->interp > 0)
+ value = thiscell.interp / ap->interp;
thiscell.interp = value;
@@ -490,7 +492,6 @@
for (col = 0; col < ncols; col++) {
int count = 0;
- double sum = 0.;
segment_get(&out_seg, &thiscell, row, col);
if (thiscell.area == 0 ||
@@ -511,17 +512,15 @@
segment_get(&out_seg, &ngbrcell, nrow, ncol);
if (!Rast_is_d_null_value(&ngbrcell.interp)) {
- value += ngbrcell.interp * ngbrcell.weight;
+ value += ngbrcell.interp;
count++;
- sum += ngbrcell.weight;
- if (sum != 0) {
- value /= sum;
- value -= thiscell.interp / thiscell.weight;
+ if (count != 0) {
+ value /= count;
+ value -= thiscell.interp;
/* relax */
/* value /= 8; */
thiscell.adj = value;
@@ -536,6 +535,8 @@
areas[thiscell.area].adj += thiscell.adj;
areas[thiscell.area].interp += thiscell.interp + thiscell.adj;
+ else
+ areas[thiscell.area].interp += thiscell.interp;
@@ -563,9 +564,6 @@
value = thiscell.adj + areas[thiscell.area].adj;
- if (have_weights && thiscell.weight > 1)
- value /= thiscell.weight;
if (maxadj < value * value) {
maxadj = value * value;
l_row = row;
@@ -648,8 +646,6 @@
if (ap->count)
value = thiscell.adj - ap->adj / ap->count;
l_row = row;
@@ -667,6 +663,45 @@
G_percent(maxiter, maxiter, 1);
+ G_message(_("Weighing output..."));
+ for (i = 1; i <= nareas; i++) {
+ areas[i].interp = .0;
+ areas[i].adj = .0;
+ areas[i].avgdiff = .0;
+ areas[i].count_neg = 0;
+ for (row = 0; row < nrows; row++) {
+ for (col = 0; col < ncols; col++) {
+ segment_get(&out_seg, &thiscell, row, col);
+ if (thiscell.area > 0 &&
+ !Rast_is_d_null_value(&thiscell.interp)) {
+ ap = &areas[thiscell.area];
+ thiscell.interp *= thiscell.weight;
+ ap->interp += thiscell.interp;
+ segment_put(&out_seg, &thiscell, row, col);
+ value = 1;
+ if (ap->interp != 0)
+ value = ap->value / ap->interp;
+ thiscell.interp = value * thiscell.interp;
/* write output */
G_message(_("Writing output <%s>"), out_opt->answer);
drastbuf = Rast_allocate_d_buf();
