[GRASS-SVN] r58848 - in grass/branches/releasebranch_6_4/raster/r.li: r.li.daemon r.li.edgedensity r.li.patchdensity r.li.setup
svn_grass at osgeo.org
Mon Feb 3 06:43:16 PST 2014
Author: neteler
Date: 2014-02-03 06:43:16 -0800 (Mon, 03 Feb 2014)
New Revision: 58848
grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c
grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.h
grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/worker.c
grass/branches/releasebranch_6_4/raster/r.li/r.li.edgedensity/edgedensity.c
grass/branches/releasebranch_6_4/raster/r.li/r.li.patchdensity/main.c
grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/r.li.setup.main
grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/sample_area_vector.sh
r.li.*: fixes for trac #2024 (author: rashadkm)
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c 2014-02-03 11:24:32 UTC (rev 58847)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c 2014-02-03 14:43:16 UTC (rev 58848)
@@ -52,7 +52,7 @@
list l;
msg m, doneJob;
- /* int perc=0; */
+ int perc=0;
g = (g_areas) G_malloc(sizeof(struct generatore));
g->maskname = NULL;
@@ -168,8 +168,7 @@
int j = 0, donePid;
receive(receiveChannel, &doneJob);
- /*perc++; */
- /*G_percent (perc, WORKERS, 1); */
if (doneJob.type == DONE) {
double result;
@@ -246,10 +245,12 @@
if (!(WIFEXITED(status)))
G_warning(_("r.li.worker (pid %i) exited with abnormal status: %i"),
donePid, status);
- else
+ else {
G_verbose_message(_("r.li.worker (pid %i) terminated successfully"),
donePid);
+ perc++;
+ G_percent (perc, WORKERS, 1);
/* remove pipe */
if (close(child[j].channel) != 0)
G_message(_("Cannot close %s file (PIPE)"), child[j].pipe);
@@ -333,7 +334,7 @@
token = strtok(buf, " ");
if (strcmp("SAMPLINGFRAME", token) != 0)
- G_fatal_error(_("Unable to parse configuration file"));
+ G_fatal_error(_("Unable to parse configuration file (sampling frame)"));
rel_x = atof(strtok(NULL, "|"));
rel_y = atof(strtok(NULL, "|"));
@@ -342,6 +343,8 @@
/* find raster map */
mapset = G_find_cell(raster, "");
+ char * raster_ = G_fully_qualified_name(raster, mapset);
if (G_get_cellhd(raster, mapset, &cellhd) == -1)
G_fatal_error(_("Cannot read raster header file"));
@@ -415,7 +418,7 @@
else if (strcmp("MASKEDSAMPLEAREA", token) == 0) {
double rel_sa_x, rel_sa_y, rel_sa_rl, rel_sa_cl;
int aid = 1;
- char maskname[GNAME_MAX];
+ char maskname[GNAME_MAX] = {'\0'};
do {
rel_sa_x = atof(strtok(NULL, "|"));
@@ -423,7 +426,6 @@
rel_sa_rl = atof(strtok(NULL, "|"));
rel_sa_cl = atof(strtok(NULL, "|"));
strcpy(maskname, strtok(NULL, "\n"));
if (rel_sa_x == -1 && rel_sa_y == -1) {
/* runtime disposition */
int sa_rl, sa_cl;
@@ -463,7 +465,7 @@
else if (strcmp("MASKEDOVERLAYAREA", token) == 0) {
double sa_n, sa_s, sa_w, sa_e;
int aid = 1;
+ char maskname[GNAME_MAX] = { '\0' };
msg m;
do {
@@ -474,10 +476,24 @@
sa_w = atof(strtok(NULL, "\n"));
m.type = MASKEDAREA;
- m.f.f_ma.x = (int)rint((cellhd.north - sa_n) * cellhd.ns_res);
- m.f.f_ma.y = (int)rint((cellhd.west + sa_w) * cellhd.ew_res);
- m.f.f_ma.rl = (int)rint((sa_n - sa_s) * cellhd.ns_res);
- m.f.f_ma.cl = (int)rint((sa_e - sa_w) * cellhd.ew_res);
+ struct Cell_head window;
+ /* Get the window setting. g.region rast=<input raster> */
+ G_get_window(&window);
+ /* Each input overlay area from input vector are converted to raster
+ via v.to.rast. See r.li.setup/sample_area_vector.sh. This is to used
+ only for reading the region (NS, EW). */
+ /* Get start x and y position of masked overlay raster with respect
+ to input raster region from window.
+ sa_n, sa_e are read from configuration file. */
+ m.f.f_ma.x = (int)G_easting_to_col(sa_e, &window);
+ m.f.f_ma.y = (int)G_northing_to_row(sa_n, &window);
+ /* Get row count and column count of overlay raster */
+ m.f.f_ma.rl = (int)rint((sa_n - sa_s) / cellhd.ns_res);
+ m.f.f_ma.cl = (int)rint((sa_e - sa_w) / cellhd.ew_res);
m.f.f_ma.aid = aid;
strcpy(m.f.f_ma.mask, maskname);
aid++;
@@ -485,18 +501,20 @@
while ((token = strtok(NULL, " ")) != NULL &&
(strcmp(token, "MASKEDOVERLAYAREA") == 0));
if (strcmp(token, "RASTERMAP") != 0)
G_fatal_error(_("Irregular maskedoverlay areas definition"));
token = strtok(NULL, "\n");
- if (strcmp(token, raster) != 0)
+ if (strcmp(token, raster_) != 0)
G_fatal_error(_("The configuration file can be used only with \
- %s rasterfile"), token);
+ %s rasterfile and not with %s "), token, raster_);
close(setup);
return NORMAL;
else
- G_fatal_error(_("Illegal configuration file (sample area)"));
+ G_fatal_error(_("Unable to parse configuration file (sample area)"));
close(setup);
return ERROR;
@@ -599,7 +617,7 @@
r_strat_len = (int)rint(g->rows / r_strat);
c_strat_len = (int)rint(g->cols / c_strat);
if (r_strat_len < g->rl || c_strat_len < g->cl)
- G_fatal_error(_("Too many strats for raster map"));
+ G_fatal_error(_("Too many stratified random sample for raster map"));
loop = r_strat * c_strat;
srandom(getpid());
for (i = 0; i < loop; i++) {
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.h
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.h 2014-02-03 11:24:32 UTC (rev 58847)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.h 2014-02-03 14:43:16 UTC (rev 58848)
@@ -19,6 +19,7 @@
#include <grass/gis.h>
#include "list.h"
+#include "defs.h"
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/worker.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/worker.c 2014-02-03 11:24:32 UTC (rev 58847)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/worker.c 2014-02-03 14:43:16 UTC (rev 58848)
@@ -235,14 +235,16 @@
G_debug(3, "daemon mask preproc: raster=[%s] mask=[%s] rl=%d cl=%d",
raster, mask, rl, cl);
+ /* mapset is used hold the mapset of input raster */
/* open raster */
if (G_get_cellhd(raster, mapset, &cell) == -1)
return NULL;
- mapset = G_find_cell(mask, "");
+ /* mmapset is used hold the mapset where mask is saved */
+ char *mmapset = G_find_cell(mask, "");
/* open raster */
- if (G_get_cellhd(mask, mapset, &oldcell) == -1)
+ if (G_get_cellhd(mask, mmapset, &oldcell) == -1)
return NULL;
add_row = 1.0 * oldcell.rows / rl;
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.edgedensity/edgedensity.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.edgedensity/edgedensity.c 2014-02-03 11:24:32 UTC (rev 58847)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.edgedensity/edgedensity.c 2014-02-03 14:43:16 UTC (rev 58848)
@@ -16,7 +16,6 @@
#include <fcntl.h> /* for O_RDONLY usage */
#include <math.h>
-#include "../r.li.daemon/defs.h"
#include "../r.li.daemon/avlDefs.h"
#include "../r.li.daemon/avl.h"
#include "../r.li.daemon/daemon.h"
@@ -71,9 +70,9 @@
return calculateIndex(conf->answer, edgedensity, par, raster->answer,
output->answer);
int edgedensity(int fd, char **valore, area_des ad, double *result)
struct Cell_head hd;
@@ -122,7 +121,6 @@
int calculate(int fd, area_des ad, char **valore, double *result)
double indice = 0;
@@ -135,6 +133,8 @@
AVL_table *array;
+ buf_sup = NULL;
long tot = 0;
long zero = 0;
long m = 0;
@@ -153,7 +153,7 @@
/* open mask if needed */
if (ad->mask == 1) {
if ((mask_fd = open(ad->mask_name, O_RDONLY, 0755)) < 0) {
- G_fatal_error("can't open mask");
+ G_fatal_error("can't open mask %s", ad->mask_name);
return RLI_ERRORE;
@@ -180,7 +180,6 @@
G_set_c_null_value(buf_sup + ad->x, ad->cl); /*the first time buf_sup is all null */
for (j = 0; j < ad->rl; j++) { /* for each raster row */
buf_corr = RLI_get_cell_raster_row(fd, j + ad->y, ad); /* read row of raster */
@@ -223,7 +222,6 @@
G_set_c_null_value(&nextCell, 1);
G_set_c_null_value(&prevCell, 1);
G_set_c_null_value(&corrCell, 1);
@@ -316,23 +314,15 @@
bordoCorr = 0;
prevCell = buf_corr[i + ad->x];
if (masked)
mask_sup = mask_corr;
/* calculate index */
if (area == 0)
indice = -1;
@@ -354,7 +344,6 @@
else { /* all classes */
array = G_malloc(m * sizeof(AVL_tableRow));
if (array == NULL) {
G_fatal_error("malloc array failed");
@@ -380,11 +369,11 @@
G_free(mask_inf);
G_free(mask_corr);
- G_free(buf_sup);
+ /* G_free(buf_sup); */
return RLI_OK;
int calculateD(int fd, area_des ad, char **valore, double *result)
double indice = 0;
@@ -489,7 +478,6 @@
G_set_d_null_value(&nextCell, 1);
G_set_d_null_value(&prevCell, 1);
G_set_d_null_value(&corrCell, 1);
@@ -507,8 +495,6 @@
if (!(G_is_null_value(&corrCell, DCELL_TYPE))) {
if ((i + 1) == ad->cl) /*last cell of the row */
else if (masked && mask_corr[i + 1 + ad->x] == 0)
@@ -531,7 +517,6 @@
bordoCorr++;
if ((G_is_null_value(&supCell, DCELL_TYPE)) ||
(corrCell != supCell)) {
bordoCorr++;
@@ -542,7 +527,6 @@
bordoCorr++;
if ((G_is_null_value(&nextCell, DCELL_TYPE)) ||
(corrCell != nextCell)) {
bordoCorr++;
@@ -589,25 +573,18 @@
if (masked)
if (area == 0)
indice = -1;
else {
if (valore != NULL) { /* only 1 class */
char *sval;
double val;
@@ -620,10 +597,8 @@
c1.t = DCELL_TYPE;
e = (double)howManyCell(albero, c1);
somma = e;
@@ -708,7 +683,6 @@
G_set_f_null_value(buf_sup + ad->x, ad->cl); /*the first time buf_sup is all null */
buf_corr = RLI_get_fcell_raster_row(fd, j + ad->y, ad); /* read row of raster */
@@ -716,7 +690,6 @@
if (j > 0) /* not first row */
buf_sup = RLI_get_fcell_raster_row(fd, j - 1 + ad->y, ad);
if ((j + 1) < ad->rl) { /*not last row */
buf_inf = RLI_get_fcell_raster_row(fd, 1 + j + ad->y, ad);
@@ -739,7 +712,6 @@
return RLI_ERRORE;
if (read(mask_fd, mask_inf, (ad->cl * sizeof(int))) < 0) {
G_fatal_error("reading mask_inf");
@@ -754,7 +726,6 @@
G_set_f_null_value(&nextCell, 1);
G_set_f_null_value(&prevCell, 1);
G_set_f_null_value(&corrCell, 1);
@@ -793,7 +764,6 @@
bordoCorr++;
if ((G_is_null_value(&supCell, FCELL_TYPE)) ||
bordoCorr++;
@@ -804,7 +774,6 @@
bordoCorr++;
if ((G_is_null_value(&nextCell, FCELL_TYPE)) ||
bordoCorr++;
@@ -851,25 +820,18 @@
if (masked)
if (area == 0)
indice = -1;
else {
char *sval;
float val;
@@ -885,8 +847,6 @@
G_fatal_error("malloc array failederror");
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.patchdensity/main.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.patchdensity/main.c 2014-02-03 11:24:32 UTC (rev 58847)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.patchdensity/main.c 2014-02-03 14:43:16 UTC (rev 58848)
@@ -20,7 +20,6 @@
#include <grass/glocale.h>
int main(int argc, char *argv[])
@@ -200,6 +199,6 @@
else
*result = -1;
- G_free(sup);
+ /* G_free(sup); */
return RLI_OK;
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/r.li.setup.main
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/r.li.setup.main 2014-02-03 11:24:32 UTC (rev 58847)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/r.li.setup.main 2014-02-03 14:43:16 UTC (rev 58848)
@@ -378,7 +378,8 @@
button .removeconf.buttons.y -text "Yes" -width 8 -command {
if { [ catch { exec rm $env(HOME)/.r.li/history/$selection } ] } then {
tk_messageBox -message "'$selection' Not deleted" -type ok -icon error} else {
- tk_messageBox -message "$selection deleted" -type ok
+ #annoying "deleted" messageBox
+ #tk_messageBox -message "$selection deleted" -type ok
openDir .files "~/.r.li/history"
destroy .removeconf}
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/sample_area_vector.sh
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/sample_area_vector.sh 2014-02-03 11:24:32 UTC (rev 58847)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/sample_area_vector.sh 2014-02-03 14:43:16 UTC (rev 58848)
@@ -50,26 +50,46 @@
f_path="$GISBASE/etc/r.li.setup"
-# list categories
-v.build map=$GIS_OPT_vector option=cdump| grep '|' |cut -f1 -d '|' |\
- tr ' ' -d > $TMP.cat
-# number of categories
-N="`grep -c "" < $TMP.cat`"
-((N= N -3))
+#read categories from input vector, extract,
+#convert to raster and save the bounds to configuration file
-#scanning categories
-I=1
-while(($I<=$N)); do
- #extract vector[i]
- v.extract input=$GIS_OPT_vector output=$GIS_OPT_vector"part"$I \
- type=point,line,boundary,centroid,area,face new=-1 -d where="(CAT=$I)"
+#using v.category instead of v.build with cdump
+v.category input=$GIS_OPT_vector option=print > $TMP.cat
+#get input vector name
+GIS_OPT_input_vector=`echo $GIS_OPT_vector| cut -d'@' -f 1`
+#get input vector mapset
+GIS_OPT_input_mapset=`echo $GIS_OPT_vector| cut -d'@' -f 2`
+#read input vector categories into CAT_LIST array
+IFS=$'\r\n' CAT_LIST=($(cat $TMP.cat))
+TMP_REGION="reg`g.tempfile pid=$$`"
+#save the current region settings temporarily to avoid surpirses later.
+g.region save=$TMP_REGION
+#process each feature in the vector having category values in the CAT_LIST array
+for CAT in "${CAT_LIST[@]}"
+do
+ #vector to store a feature fro $GIS_OPT_vector with category value $CAT.
+ #This temporary vector will be removed at the end.
+ EXTRACT=$GIS_OPT_input_vector"_"$CAT"_part@"$GIS_OPT_input_mapset
+ #extract only a part of $GIS_OPT_vector where category = $CAT and store in $EXTRACT
+ v.extract input=$GIS_OPT_vector output=$EXTRACT type=point,line,boundary,centroid,area,face new=-1 -d where='CAT='$CAT
+ #TODO: anyway to check if x1 is in use?
#opening monitor x1
d.mon stop=x1
d.mon start=x1
#setting region with raster resolution
- g.region vect=$GIS_OPT_vector"part"$I align=$GIS_OPT_raster
- d.rast -o $GIS_OPT_raster
- d.vect $GIS_OPT_vector"part"$I
+ g.region vect=$EXTRACT align=$GIS_OPT_raster
+ d.rast -o $GIS_OPT_raster
+ #render extracted vector map
+ d.vect $EXTRACT
#ask the user if he wants to analyse this vector and a name for raster
#in graphical mode using wish
export name=$TMP.val # where find the answer
@@ -80,10 +100,11 @@
r_name=""
read r_name < $name.var
echo $r_name
if [ $ok -eq 1 ] ; then
#area selected, create mask
- v.to.rast input=$GIS_OPT_vector"part"$I output=$r_name use=cat value=1 rows=4096
- #write info in configuration file
+ v.to.rast input=$EXTRACT output=$r_name use=cat value=1 rows=4096
+ #read the region settings to save to configuration file
g.region -g| grep "n=" | cut -f2 -d'='> $name.var
read north < $name.var
g.region -g| grep "s=" | cut -f2 -d'=' > $name.var
@@ -92,15 +113,19 @@
read east < $name.var
g.region -g| grep "w=" | cut -f2 -d'=' > $name.var
read west < $name.var
- echo "MASKEDOVERLAYAREA $r_name|n=$north|s=$south|e=$east|w=$west" >> $GIS_OPT_conf
+ #write info in configuration file
+ echo "MASKEDOVERLAYAREA $r_name|$north|$south|$east|$west" >> $GIS_OPT_conf
fi
- #clear vector map part
- g.remove vect=$GIS_OPT_vector"part"$I
+ #remove temporary vector map created from v.extract
+ g.remove vect=$EXTRACT
#rm -fR "$GISDBASE"/"$LOCATION"/"$MAPSET"/vector/$GIS_OPT_vector"part"$I
#echo DROP TABLE $GIS_OPT_vector"part"$I | db.execute
- ((I++))
done
d.mon stop=x1
+#restore user region
+g.region region=$TMP_REGION
+#remove temporary region, $TMP_REGION
+g.remove region=$TMP_REGION
# clean tmp files
rm -f $TMP*
