[GRASS-SVN] r58853 -	grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon
    svn_grass at osgeo.org
    Mon Feb  3 08:37:07 PST 2014
Author: neteler
Date: 2014-02-03 08:37:07 -0800 (Mon, 03 Feb 2014)
New Revision: 58853
   grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c
   grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.h
   grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/description.html
r.li.daemon: compilation fix (needed due to r56730); HTML cosmetics
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c	2014-02-03 16:26:58 UTC (rev 58852)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c	2014-02-03 16:37:07 UTC (rev 58853)
@@ -45,9 +45,17 @@
     g_areas g;
     int receiveChannel;
     int res;
-    wd child[WORKERS];
     int i, mypid, doneDir, withoutJob, mv_fd, random_access;
+    int num_workers;
+    /* check if environment variable override was set */
+    const char *p = getenv("WORKERS");
+    num_workers = p ? atoi(p) : DEFAULT_WORKERS;
+    if ((num_workers <= 0) || (num_workers > 1e6))
+	G_fatal_error(_("Invalid number of workers: [%s]"), p);
+    wd child[num_workers];
     /*int mv_rows, mv_cols; */
     list l;
     msg m, doneJob;
@@ -73,7 +81,7 @@
     i = 0;
-    while (i < WORKERS) {
+    while (i < num_workers) {
 	int childpid;
 	/*creating pipe */
@@ -126,7 +134,7 @@
     if (parsed == MVWIN) {
 	/* struct Cell_head cellhd_r, cellhd_new;
 	   char *mapset; */
-	/*creating new raster file */
+	/* create new raster file */
 	mv_fd = G_open_raster_new(output, DCELL_TYPE);
 	if (mv_fd < 0)
 	    G_fatal_error(_("Unable to create raster map <%s>"), output);
@@ -156,14 +164,14 @@
        ------------------analysis loop----------------------
-    /*first job scheduling */
-    while ((i < WORKERS) && next_Area(parsed, l, g, &m) != 0) {
+    /* first job scheduling */
+    while ((i < num_workers) && next_Area(parsed, l, g, &m) != 0) {
 	send(child[i].channel, &m);
 	i++;
-    /*body */
+    /* body */
     while (next_Area(parsed, l, g, &m) != 0) {
 	int j = 0, donePid;
@@ -179,7 +187,7 @@
 		print_Output(res, doneJob);
 	    else {
-		/*raster output */
+		/* raster output */
 		raster_Output(random_access, doneJob.f.f_d.aid, g,
 			      doneJob.f.f_d.res);
@@ -190,19 +198,20 @@
 		error_Output(res, doneJob);
 	    else {
-		/*printf("todo ");fflush(stdout); *//* TODO scrivere su raster NULL ??? */
+		/* printf("todo"); fflush(stdout); */
+		/* TODO write to raster NULL ??? */
 	j = 0;
-	while (j < WORKERS && donePid != child[j].pid)
+	while (j < num_workers && donePid != child[j].pid)
 	    j++;
 	send(child[j].channel, &m);
-    /*kill childs */
+    /* kill childs */
     withoutJob = i;
     while (i > 0) {
 	int j = 0, donePid, status;
@@ -228,13 +237,14 @@
 	    else {
-		/*printf("todo2 ");fflush(stdout); *//*TODO scrivere su raster */
+		/* printf("todo2 "); fflush(stdout); */
+		/* TODO write to raster */
 	i--;
 	    j++;
 	m.type = TERM;
@@ -249,7 +259,7 @@
 	    G_verbose_message(_("r.li.worker (pid %i) terminated successfully"),
 			      donePid);
 	    perc++;
-	    G_percent (perc, WORKERS, 1);
+	    G_percent (perc, num_workers, 1);
 	/* remove pipe */
 	if (close(child[j].channel) != 0)
@@ -259,7 +269,7 @@
     /* kill children without Job */
-    for (i = withoutJob; i < WORKERS; i++) {
+    for (i = withoutJob; i < num_workers; i++) {
 	int status;
 	m.type = TERM;
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.h
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.h	2014-02-03 16:26:58 UTC (rev 58852)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.h	2014-02-03 16:37:07 UTC (rev 58853)
@@ -25,7 +25,7 @@
  * \brief number of r.li.workers to use
-#define WORKERS 10
+#define DEFAULT_WORKERS 10
 #define NORMAL 1
 #define MVWIN 2
 #define GEN 3
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/description.html	2014-02-03 16:26:58 UTC (rev 58852)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/description.html	2014-02-03 16:37:07 UTC (rev 58853)
@@ -10,6 +10,7 @@
 <img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
 <H2>NAME</H2>
 <EM><B>libgrass_rli</B></EM> - r.li landscape index support library
 <H2>DESCRIPTION</H2>
@@ -57,6 +58,7 @@
 Compile it using a changed Makefile based on the file for <em>r.li.patchdensity</em>.
 <H2>NOTES</H2>
 Using GRASS library function to access raster rows can slow down moving windows
 execution. It is recommended to use
 <br><div class="code"><pre>
@@ -66,8 +68,10 @@
 </pre></div><br>
 to use an ad hoc build memory management developed to speed up the system.
 The documentation is in doxygen files.
+<p>
+The <tt>WORKERS</tt> environment variable can be set to the number of
+concurrent processes desired. If not set, the default is 10 concurrent jobs.
 <H2>SEE ALSO</H2>
 <EM><A HREF="http://grass.osgeo.org/gdp/landscape/r_le_manual5.pdf">old r.le manual</A></EM><BR>
@@ -75,7 +79,14 @@
 <EM><A HREF="r.li.patchdensity.html">r.li.patchdensity</A></EM>,
 <EM><A HREF="r.li.setup.html">r.li.setup</A></EM>
+<h2>REFERENCES</h2>
+McGarigal, K., and B. J. Marks. 1995. FRAGSTATS: spatial pattern
+analysis program for quantifying landscape structure. USDA For. Serv.
+Gen. Tech. Rep. PNW-351. (<a href="http://treesearch.fs.fed.us/pubs/3064">PDF</a>)
 <H2>AUTHORS</H2>
 Claudio Porta and Lucio Davide Spano, students of Computer Science
 University of Pisa (Italy).<br>
 Commission from Faunalia Pontedera (PI)<br>
@@ -87,6 +98,8 @@
 <i>Last changed: $Date$</i>
 <HR>
-<P><a href="index.html">Main index</a> - <a href="raster.html">raster index</a> - <a href="full_index.html">Full index</a>
+<P><a href="index.html">Main index</a>
+ - <a href="raster.html">raster index</a>
+ - <a href="full_index.html">Full index</a>
 </body>
 </html>
