[GRASS-SVN] r58875 - grass-addons/grass7/raster/r.shalstab
svn_grass at osgeo.org
Tue Feb 4 00:12:26 PST 2014
Author: kikapu
Date: 2014-02-04 00:12:25 -0800 (Tue, 04 Feb 2014)
New Revision: 58875
grass-addons/grass7/raster/r.shalstab/r.shalstab.py
Upgrade
Modified: grass-addons/grass7/raster/r.shalstab/r.shalstab.py
--- grass-addons/grass7/raster/r.shalstab/r.shalstab.py 2014-02-04 00:20:53 UTC (rev 58874)
+++ grass-addons/grass7/raster/r.shalstab/r.shalstab.py 2014-02-04 08:12:25 UTC (rev 58875)
@@ -140,25 +140,46 @@
if gamma_wet == '':
gamma_wet = 2100
# calculate slope
- grass.run_command('r.slope.aspect', elevation=r_elevation, slope='slopes',
- min_slp_allowed=0.0, overwrite='True') #format = 'degrees', precision = float,
+ grass.run_command('r.slope.aspect',
+ elevation = r_elevation,
+ slope = 'slopes',
+ min_slp_allowed = 0.0,
+ overwrite = 'True')
+ #zero value = null
+ grass.run_command('r.null',
+ map = 'slopes',
+ setnull = 0)
# calculate soil transmissivity T (m^2/day)
- grass.mapcalc("T=$k*24*$z*cos(slopes)", k=k, z=z)
+ grass.mapcalc("T=$k*24*$z*cos(slopes)",
+ k = k,
+ z = z)
# calculate dimensionless
grass.mapcalc("C=($root+$c_soil)/($z*cos(slopes)*9.81*$gamma_wet)",
- root=root, c_soil=c_soil, z=z, gamma_wet=gamma_wet)
+ root = root,
+ c_soil = c_soil,
+ z = z,
+ gamma_wet = gamma_wet)
# calculate contribution area
+ grass.run_command('r.watershed',
+ accumulation = 'accum')
- grass.run_command('r.watershed', elevation=r_elevation,
- accumulation='accum')
grass.mapcalc("A=accum*((ewres()+nsres())/2)*((ewres()+nsres())/2)")
+ #stable condition
+ grass.mapcalc("assoluta_stab=(1-1000/($gamma))*tan($phy)",
+ gamma = gamma,
+ phy = phy)
+ grass.mapcalc("assoluta_cond=if(assoluta_stab>tan(slopes),9999,0)")
+ #unstable condition
+ grass.mapcalc("assoluta_instab=C/cos(slopes)+(tan($phy))",
+ phy = phy)
+ grass.mapcalc("cond_instab=if(assoluta_instab<tan(slopes),-9999,0)")
# calculate 1(m/day)
- grass.mapcalc("i_crit_m=T*sin(slopes)*((ewres()+nsres())/2)/A*($gamma/1000*(1-(1-C/(sin(slopes)*cos(slopes)))*tan(slopes)/tan($phy)))",
+ grass.mapcalc("i_crit_m=(T*sin(slopes)*((ewres()+nsres())/2)/A*($gamma/1000*(1-(1-C/(sin(slopes)*cos(slopes))))*(tan(slopes)/tan($phy))))+(assoluta_cond)+(cond_instab)",
phy=phy, gamma=gamma)
# Calculation of critical rain (mm / hr) and riclassification
grass.mapcalc("i_cri_mm=i_crit_m*24000")
- reclass_rules = "0 thru 50 = 2\n51 thru 100 = 3\n101 thru 200 = 4\n201 thru 400 = 5\n401 thru 999 = 6"
+ reclass_rules = "0 thru 30 = 2\n31 thru 100 = 3\n101 thru 150 = 4\n151 thru 200 = 5\n201 thru 999 = 6"
grass.write_command('r.reclass', input='i_cri_mm', output='i_recl',
overwrite='True', rules='-', stdin=reclass_rules)
grass.mapcalc("copia_reclass=i_recl+0")
@@ -177,10 +198,21 @@
grass.run_command('g.rename', rast=("I_cri_average", susceptibility))
grass.run_command('g.rename', rast=("i_cri_mm", critic_rain))
# remove temporary map
- grass.run_command('g.remove', rast=("A", "copia_reclass", "i_crit_m",
- "i_recl", "accum", "slopes", "Stable",
- "T", "Unstable", "C"))
+ grass.run_command('g.remove', rast=("A",
+ "copia_reclass",
+ "i_crit_m",
+ "i_recl",
+ "accum",
+ "slopes",
+ "Stable",
+ "T",
+ "Unstable",
+ "C",
+ "Icritica",
+ "assoluta_stab",
+ "assoluta_cond",
+ "assoluta_instab",
+ "cond_instab"))
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
