[GRASS-SVN] r58887 - in grass/trunk: include/Make include/defs lib/iostream
svn_grass at osgeo.org
Wed Feb 5 11:34:21 PST 2014
Author: neteler
Date: 2014-02-05 11:34:20 -0800 (Wed, 05 Feb 2014)
New Revision: 58887
grass/trunk/include/Make/Grass.make
grass/trunk/include/defs/gis.h
grass/trunk/lib/iostream/ami_stream.cpp
libiostream (r.terraflow, r.viewshed): use G_mkstemp() (trac #2153)
Modified: grass/trunk/include/Make/Grass.make
--- grass/trunk/include/Make/Grass.make 2014-02-05 16:36:23 UTC (rev 58886)
+++ grass/trunk/include/Make/Grass.make 2014-02-05 19:34:20 UTC (rev 58887)
@@ -200,6 +200,7 @@
IMAGERYDEPS = $(GISLIB) $(MATHLIB) $(RASTERLIB) $(VECTORLIB)
INTERPFLDEPS = $(BITMAPLIB) $(DBMILIB) $(GMATHLIB) $(INTERPDATALIB) $(QTREELIB) $(VECTORLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
#IORTHODEPS = $(IMAGERYLIB) $(GISLIB)
+IOSTREAMDEPS = $(GISLIB)
LIDARDEPS = $(VECTORLIB) $(DBMILIB) $(GMATHLIB) $(RASTERLIB) $(SEGMENTLIB) $(GISLIB) $(MATHLIB)
LRSDEPS = $(DBMILIB) $(GISLIB)
MANAGEDEPS = $(VECTORLIB) $(GISLIB)
Modified: grass/trunk/include/defs/gis.h
--- grass/trunk/include/defs/gis.h 2014-02-05 16:36:23 UTC (rev 58886)
+++ grass/trunk/include/defs/gis.h 2014-02-05 19:34:20 UTC (rev 58887)
@@ -623,6 +623,11 @@
char *G__tempfile(int);
void G__temp_element(char *);
+/* mkstemp.c */
+char *G_mktemp(char *);
+int G_mkstemp(char *, int, int);
+FILE *G_mkstemp_fp(char *, int, int);
/* timestamp.c */
void G_init_timestamp(struct TimeStamp *);
void G_set_timestamp(struct TimeStamp *, const struct DateTime *);
Modified: grass/trunk/lib/iostream/ami_stream.cpp
--- grass/trunk/lib/iostream/ami_stream.cpp 2014-02-05 16:36:23 UTC (rev 58886)
+++ grass/trunk/lib/iostream/ami_stream.cpp 2014-02-05 19:34:20 UTC (rev 58887)
@@ -43,6 +43,10 @@
#include <errno.h>
#include <unistd.h>
+extern "C" {
+#include <grass/gis.h>
//#include <ami_stream.h>
#include <grass/iostream/ami_stream.h>
@@ -81,19 +85,11 @@
sprintf(tmp_path, "%s/%s_XXXXXX", base_dir, base.c_str());
-#ifdef __MINGW32__
- fd = mktemp(tmp_path) ? open(tmp_path, O_CREAT|O_EXCL|O_RDWR, 0600) : -1;
-#else
- fd = mkstemp(tmp_path);
-#endif
+ fd = G_mkstemp(tmp_path, O_RDWR, 0600);
if (fd == -1) {
cerr << "ami_single_temp_name: ";
-#ifdef __MINGW32__
- perror("mktemp failed: ");
-#else
- perror("mkstemp failed: ");
-#endif
+ perror("G_mkstemp() failed: ");
assert(0);
exit(1);
