[GRASS-SVN] r58890 - grass/trunk/raster/r.out.gdal
svn_grass at osgeo.org
Wed Feb 5 14:11:07 PST 2014
Author: mmetz
Date: 2014-02-05 14:11:07 -0800 (Wed, 05 Feb 2014)
New Revision: 58890
Added:
grass/trunk/raster/r.out.gdal/attr.c
grass/trunk/raster/r.out.gdal/local_proto.h
grass/trunk/raster/r.out.gdal/main.c
r.out.gdal: new flag to write raster attribute table
Added: grass/trunk/raster/r.out.gdal/attr.c
--- grass/trunk/raster/r.out.gdal/attr.c (rev 0)
+++ grass/trunk/raster/r.out.gdal/attr.c 2014-02-05 22:11:07 UTC (rev 58890)
@@ -0,0 +1,140 @@
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+#include "cpl_string.h"
+#include "gdal.h"
+#include "local_proto.h"
+int export_attr(GDALDatasetH hMEMDS, int band,
+ const char *name, const char *mapset,
+ RASTER_MAP_TYPE maptype)
+ struct Categories cats;
+ CELL CellMin;
+ CELL CellMax;
+ DCELL dfCellMin;
+ DCELL dfCellMax;
+ char *label;
+ struct Colors sGrassColors;
+ int rcount;
+ int i;
+ int ret = 0;
+ GDALRasterAttributeTableH hrat;
+ GDALRasterBandH hBand;
+ Rast_init_cats("Labels", &cats);
+ if (Rast_read_cats(name, mapset, &cats))
+ return -1;
+ rcount = 0;
+ Rast_init_colors(&sGrassColors);
+ if (Rast_read_colors(name, mapset, &sGrassColors) >= 0) {
+ rcount = Rast_colors_count(&sGrassColors);
+ if (cats.ncats == 0 && rcount == 0)
+ return 0;
+ /* Get raster band */
+ hBand = GDALGetRasterBand(hMEMDS, band);
+ /* Field usage of raster attribute table:
+ * GFU_Generic = 0, GFU_PixelCount = 1, GFU_Name = 2,
+ * GFU_Min = 3, GFU_Max = 4, GFU_MinMax = 5,
+ * GFU_Red = 6, GFU_Green = 7, GFU_Blue = 8, GFU_Alpha = 9,
+ * GFU_RedMin = 10, GFU_GreenMin = 11, GFU_BlueMin = 12, GFU_AlphaMin = 13,
+ * GFU_RedMax = 14, GFU_GreenMax = 15, GFU_BlueMax = 16, GFU_AlphaMax = 17,
+ * GFU_MaxCount
+ /* TODO: cats.ncats > 0 && rcount > 0
+ * how to merge categories and color rules ?
+ * what to do for a cell value that has a category but no color rule ?
+ * what to do for a cell value that has a color rule but no category ?
+ if (cats.ncats > 0) { /* && rcount == 0 */
+ /* create new raster attribute table */
+ hrat = GDALCreateRasterAttributeTable();
+ if (maptype == CELL_TYPE) {
+ GDALRATCreateColumn(hrat, "min", GFT_Integer, GFU_Min);
+ GDALRATCreateColumn(hrat, "max", GFT_Integer, GFU_Max);
+ else {
+ GDALRATCreateColumn(hrat, "min", GFT_Real, GFU_Min);
+ GDALRATCreateColumn(hrat, "max", GFT_Real, GFU_Max);
+ GDALRATCreateColumn(hrat, "label", GFT_String, GFU_Name);
+ GDALRATSetRowCount(hrat, cats.ncats);
+ for (i = 0; i < cats.ncats; i++) {
+ label = Rast_get_ith_c_cat(&cats, i, &CellMin, &CellMax);
+ GDALRATSetValueAsInt(hrat, i, 0, CellMin);
+ GDALRATSetValueAsInt(hrat, i, 1, CellMax);
+ GDALRATSetValueAsString(hrat, i, 2, label);
+ else {
+ label = Rast_get_ith_d_cat(&cats, i, &dfCellMin, &dfCellMax);
+ GDALRATSetValueAsDouble(hrat, i, 0, dfCellMin);
+ GDALRATSetValueAsDouble(hrat, i, 1, dfCellMax);
+ if (GDALSetDefaultRAT(hBand, hrat) != CE_None) {
+ G_warning(_("Failed to set raster attribute table"));
+ ret = -1;
+ /* GDALRATDumpReadable(hrat, stdout); */
+ GDALDestroyRasterAttributeTable(hrat);
+ else if (cats.ncats == 0 && rcount > 0) {
+ unsigned char r1, g1, b1, r2, g2, b2;
+ GDALRATCreateColumn(hrat, "redmin", GFT_Integer, GFU_RedMin);
+ GDALRATCreateColumn(hrat, "redmax", GFT_Integer, GFU_RedMax);
+ GDALRATCreateColumn(hrat, "greenmin", GFT_Integer, GFU_GreenMin);
+ GDALRATCreateColumn(hrat, "greenmax", GFT_Integer, GFU_GreenMax);
+ GDALRATCreateColumn(hrat, "bluemin", GFT_Integer, GFU_BlueMin);
+ GDALRATCreateColumn(hrat, "bluemax", GFT_Integer, GFU_BlueMax);
+ for (i = 0; i < rcount; i++) {
+ Rast_get_fp_color_rule(&dfCellMin, &r1, &g1, &b1,
+ &dfCellMax, &r2, &g2, &b2,
+ &sGrassColors, i);
+ GDALRATSetValueAsInt(hrat, i, 2, r1);
+ GDALRATSetValueAsInt(hrat, i, 3, r2);
+ GDALRATSetValueAsInt(hrat, i, 4, g1);
+ GDALRATSetValueAsInt(hrat, i, 5, g2);
+ GDALRATSetValueAsInt(hrat, i, 6, b1);
+ GDALRATSetValueAsInt(hrat, i, 7, b2);
+ ret = -1;
+ Rast_free_cats(&cats);
+ Rast_free_colors(&sGrassColors);
+ return ret;
Modified: grass/trunk/raster/r.out.gdal/local_proto.h
--- grass/trunk/raster/r.out.gdal/local_proto.h 2014-02-05 22:01:09 UTC (rev 58889)
+++ grass/trunk/raster/r.out.gdal/local_proto.h 2014-02-05 22:11:07 UTC (rev 58890)
@@ -61,4 +61,8 @@
struct Cell_head *, RASTER_MAP_TYPE, double,
const char *, int);
+/* attr.c */
+int export_attr(GDALDatasetH, int, const char *,
+ const char *, RASTER_MAP_TYPE);
#endif /* __LOCAL_PROTO_H__ */
Modified: grass/trunk/raster/r.out.gdal/main.c
--- grass/trunk/raster/r.out.gdal/main.c 2014-02-05 22:01:09 UTC (rev 58889)
+++ grass/trunk/raster/r.out.gdal/main.c 2014-02-05 22:11:07 UTC (rev 58890)
@@ -107,7 +107,7 @@
struct GModule *module;
- struct Flag *flag_l, *flag_c, *flag_f;
+ struct Flag *flag_l, *flag_c, *flag_f, *flag_t;
struct Option *input, *format, *type, *output, *createopt, *metaopt,
*nodataopt;
@@ -141,6 +141,11 @@
flag_c->description = _("Only applicable to Byte or UInt16 data types.");
flag_c->guisection = _("Creation");
+ flag_t = G_define_flag();
+ flag_t->key = 't';
+ flag_t->label = _("Write raster attribute table");
+ flag_t->description = _("Some export formats may not be supported.");
flag_f = G_define_flag();
flag_f->key = 'f';
flag_f->label = _("Force raster export despite any warnings of data loss");
@@ -589,6 +594,11 @@
G_warning(_("Unable to export raster map <%s>"),
ref.file[band].name);
+ else if (flag_t->answer) {
+ retval = export_attr(hCurrDS, band + 1, ref.file[band].name,
+ ref.file[band].mapset, maptype);
/* Finaly create user requested raster format from memory raster
