[GRASS-SVN] r58896 - grass/branches/develbranch_6/raster/r.li/r.li.daemon
svn_grass at osgeo.org
Wed Feb 5 18:20:00 PST 2014
Author: hamish
Date: 2014-02-05 18:20:00 -0800 (Wed, 05 Feb 2014)
New Revision: 58896
grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
more readable variable name, define variables at start of function, percent done approach needs refinement
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c 2014-02-06 02:08:40 UTC (rev 58895)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c 2014-02-06 02:20:00 UTC (rev 58896)
@@ -56,12 +56,10 @@
wd child[num_workers];
- /*int mv_rows, mv_cols; */
+ /* int mv_rows, mv_cols; */
list l;
msg m, doneJob;
- int perc=0;
g = (g_areas) G_malloc(sizeof(struct generatore));
g->maskname = NULL;
l = (list) G_malloc(sizeof(struct lista));
@@ -255,12 +253,10 @@
if (!(WIFEXITED(status)))
G_warning(_("r.li.worker (pid %i) exited with abnormal status: %i"),
donePid, status);
- else {
+ else
G_verbose_message(_("r.li.worker (pid %i) terminated successfully"),
donePid);
- perc++;
- G_percent (perc, num_workers, 1);
/* remove pipe */
if (close(child[j].channel) != 0)
G_message(_("Cannot close %s file (PIPE)"), child[j].pipe);
@@ -320,7 +316,7 @@
struct stat s;
struct Cell_head cellhd;
- char *buf, *token, *mapset;
+ char *buf, *token, *raster_fqn, *mapset;
int setup;
int letti;
double rel_x, rel_y, rel_rl, rel_cl;
@@ -353,7 +349,7 @@
/* find raster map */
mapset = G_find_cell(raster, "");
- char * raster_ = G_fully_qualified_name(raster, mapset);
+ raster_fqn = G_fully_qualified_name(raster, mapset);
if (G_get_cellhd(raster, mapset, &cellhd) == -1)
G_fatal_error(_("Cannot read raster header file"));
@@ -475,7 +471,7 @@
else if (strcmp("MASKEDOVERLAYAREA", token) == 0) {
double sa_n, sa_s, sa_w, sa_e;
int aid = 1;
- char maskname[GNAME_MAX] = { '\0' };
+ char maskname[GNAME_MAX] = {'\0'};
msg m;
do {
@@ -516,9 +512,10 @@
G_fatal_error(_("Irregular maskedoverlay areas definition"));
token = strtok(NULL, "\n");
- if (strcmp(token, raster_) != 0)
- G_fatal_error(_("The configuration file can be used only with \
- %s rasterfile and not with %s "), token, raster_);
+ if (strcmp(token, raster_fqn) != 0)
+ G_fatal_error(_("The configuration file can be used only with "
+ "rasterfile <%s> and not with <%s>"), token, raster_fqn);
close(setup);
return NORMAL;
