[GRASS-SVN] r58906 - grass/branches/develbranch_6/raster/r.li/r.li.setup
svn_grass at osgeo.org
Thu Feb 6 12:59:54 PST 2014
Author: hamish
Date: 2014-02-06 12:59:53 -0800 (Thu, 06 Feb 2014)
New Revision: 58906
grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh
more updates, this script now ready for testing
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh 2014-02-06 20:44:45 UTC (rev 58905)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh 2014-02-06 20:59:53 UTC (rev 58906)
@@ -9,25 +9,33 @@
#%option
#% key: raster
#% type: string
+#% gisprompt: old,cell,raster
+#% key_desc: name
#% description: Raster map to to analyse
#% required: yes
#%end
#%option
#% key: vector
#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc: name
#% description: Vector map to overlay
#% required: no
#%end
#%option
#% key: site
#% type: string
+#% key_desc: name
#% description: Vector points map to overlay
#% required: no
#%end
#%option
#% key: conf
#% type: string
-#% description: Name of configuration file where insert areas
+#% gisprompt: new_file,file,output
+#% key_desc: filename
+#% description: Name of configuration file where areas are to be saved
#% required: yes
#%end
#%option
@@ -91,27 +99,53 @@
exit 1
fi
+cleanup()
+ # remove temporary region
+ eval `g.findfile elem=windows file="tmp_rli_selmsk.$$" | grep '^name='`
+ if [ -n "$name" ] ; then
+ g.region region="tmp_rli_selmsk.$$"
+ g.remove region="tmp_rli_selmsk.$$" --quiet
+ fi
-# FIXME: use WIND_OVERRIDE
+ rm -f "$TMP" "$TMP".val
+trap "cleanup" 2 3 15
-# show the sampling frame
+# setup internal region
+# (WIND_OVERRIDE is already present by the main r.li.setup script)
+g.region save="tmp_rli_selmsk.$$"
+# ?show the sampling frame
if [ "$GIS_FLAG_f" -eq 1 ] ; then
- g.region n="$GIS_OPT_north" s="$GIS_OPT_south" e="$GIS_OPT_east" w="$GIS_OPT_west"
+ g.region n="$GIS_OPT_north" s="$GIS_OPT_south" \
+ e="$GIS_OPT_east" w="$GIS_OPT_west"
else
g.region rast="$GIS_OPT_raster"
fi
-# open x1 Xmonitor
-d.mon stop=x1
-d.mon start=x1
+# find a free Xmonitor
+XMON=x1
+for i in 1 2 3 4 5 6 7 ; do
+ result=`d.mon -L | grep -w "^x$i"`
+ if [ `echo "$result" | grep -c 'not'` -eq 1 ] ; then
+ XMON="x$i"
+ break
+ fi
+done
+# open the Xmonitor
+d.mon stop="$XMON"
+d.mon start="$XMON"
d.rast -o map="$GIS_OPT_raster"
if [ -n "$GIS_OPT_vector" ] ; then
d.vect map="$GIS_OPT_vector"
fi
if [ -n "$GIS_OPT_site" ] ; then
- d.vect map="$GIS_OPT_site"
+ d.vect map="$GIS_OPT_site" color=red fcolor=red size=5 icon=basic/circle
fi
# setup for drawing area
@@ -128,56 +162,51 @@
# show the selected area
d.rast -o map="tmp_rli_mask.$$"
-name=$$.val
+name="$TMP.val"
export name
+# ask if it's ok, save 0,1 to "$name.val" temp file
"$GRASS_WISH" "$f_path/area_query"
- cat $name | cut -f1 -d ' ' > $name.var
- read ok < $name.var
- cat $name | cut -f2 -d' ' > $name.var
- r_name=""
- read r_name < $name.var
- if [ $ok -eq 1 ] ; then
- r.to.vect input="$$" output="v$$" feature=area
- g.region vect="v$$"
- v.to.rast input="v$$" output=$r_name value=1 use=val
- #write info in configuration file
- g.region -g| grep "n=" | cut -f2 -d'='> $name.var
- read north < $name.var
- g.region -g| grep "s=" | cut -f2 -d'=' > $name.var
- read south < $name.var
- g.region -g| grep "e=" | cut -f2 -d'=' > $name.var
- read east < $name.var
- g.region -g| grep "w=" | cut -f2 -d'=' > $name.var
- read west < $name.var
- echo "SAMPLEAREAMASKED $r_name $north|$south|$east|$west" >>\
- $GIS_OPT_conf
- #remove tmp raster and vector
- g.remove rast=$$
- g.remove vect=v$$
- #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/cats/"$$"
- #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/cell/"$$"
- #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/cellhd/"$$"
- #rm -fR "$GISDBASE"/"$LOCATION"/"$MAPSET"/cell_misc/"$$"
- #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/colr/"$$"
- #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/hist/"$$"
- #rm -fR "$GISDBASE"/"$LOCATION"/"$MAPSET"/vector/"v$$"
- echo DROP TABLE "v$$" | db.execute
- if [ $GIS_FLAG_f -eq 1 ] ; then
- g.region n=$GIS_OPT_north s=$GIS_OPT_south e=$GIS_OPT_east w=$GIS_OPT_west
- else
- g.region rast=$GIS_OPT_raster
- fi
+ok=`cat "$name.val" | cut -f1 -d ' '`
+r_name=`cat "$name.val" | cut -f2 -d' '`
+if [ "$ok" -eq 1 ] ; then
+ # r.mask + 'g.region zoom= align=' + 'r.mapcalc cropmap=map' would be cleaner?
+ r.to.vect input="tmp_rli_mask.$$" output="tmp_rli_mask_v$$" feature=area
+ g.region vect="tmp_rli_mask_v$$"
+ v.to.rast input="tmp_rli_mask_v$$" output="$r_name" value=1 use=val
+ # write info in configuration file
+ eval `g.region -g`
+ north="$n"
+ south="$s"
+ east="$e"
+ west="$w"
+ echo "SAMPLEAREAMASKED $r_name $north|$south|$east|$west" >> \
+ "$GIS_OPT_conf"
+ # remove tmp raster and vector
+ g.remove rast="tmp_rli_mask.$$" --quiet
+ g.remove vect="tmp_rli_mask_v$$" --quiet
+# echo DROP TABLE "tmp_rli_mask_v$$" | db.execute
+ if [ "$GIS_FLAG_f" -eq 1 ] ; then
else
- echo 0 >> $GIS_OPT_conf
+ g.region rast="$GIS_OPT_raster"
fi
-d.mon stop=x1
+else
+ echo 0 >> "$GIS_OPT_conf"
+fi
+d.mon stop="$XMON"
# clean tmp files
-#FIXME: use g.tempfile
-rm -f "$$"*
-rm -f "$TMP"*
+cleanup
