[GRASS-SVN] r58908 - grass/branches/develbranch_6/raster/r.li/r.li.setup
svn_grass at osgeo.org
Thu Feb 6 14:06:42 PST 2014
Author: hamish
Date: 2014-02-06 14:06:42 -0800 (Thu, 06 Feb 2014)
New Revision: 58908
grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh
grass/branches/develbranch_6/raster/r.li/r.li.setup/square_mouse_selection.sh
fix temp file name
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh 2014-02-06 21:24:16 UTC (rev 58907)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh 2014-02-06 22:06:42 UTC (rev 58908)
@@ -165,11 +165,11 @@
name="$TMP.val"
export name
-# ask if it's ok, save 0,1 to "$name.val" temp file
+# ask if it's ok, save 0,1 to "$name" temp file
"$GRASS_WISH" "$f_path/area_query"
-ok=`cat "$name.val" | cut -f1 -d ' '`
-r_name=`cat "$name.val" | cut -f2 -d' '`
+ok=`cat "$name" | cut -f1 -d ' '`
+r_name=`cat "$name" | cut -f2 -d' '`
if [ "$ok" -eq 1 ] ; then
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/square_mouse_selection.sh
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/square_mouse_selection.sh 2014-02-06 21:24:16 UTC (rev 58907)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/square_mouse_selection.sh 2014-02-06 22:06:42 UTC (rev 58908)
@@ -160,7 +160,7 @@
# ask if the selected area is right
-name="$TMP" # temp file where the answer is written to by the tcl pop-up
+name="$TMP.var" # temp file where the answer is written to by the tcl pop-up
export name
# ask if it's ok, save 0,1 to the "$name" tmp file
