[GRASS-SVN] r58923 - grass/branches/develbranch_6/raster/r.li/r.li.setup
svn_grass at osgeo.org
Thu Feb 6 22:49:16 PST 2014
Author: hamish
Date: 2014-02-06 22:49:15 -0800 (Thu, 06 Feb 2014)
New Revision: 58923
grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh
grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup.procedures.tcl
grass/branches/develbranch_6/raster/r.li/r.li.setup/square_mouse_selection.sh
grass/branches/develbranch_6/raster/r.li/r.li.setup/square_query
fix rectangular query tcl return code,
trivial whitespace and msg cosmetics,
quieten rectangular query shell script,
better defined vector points,
only show area boundaries.
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh 2014-02-07 06:12:50 UTC (rev 58922)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh 2014-02-07 06:49:15 UTC (rev 58923)
@@ -57,7 +57,7 @@
#% required: no
#%end
#%option
-#% key: west
+#% key: west
#% type: string
#% description: Western edge (use only with the 'f' flag)
#% required: no
@@ -142,7 +142,8 @@
if [ -n "$GIS_OPT_vector" ] ; then
d.vect map="$GIS_OPT_vector" type=area fcolor=none width=2
fi
-if [ -n "$GIS_OPT_site" ] ; then
+if [ -n "$GIS_OPT_site" ] ; then
+ d.vect map="$GIS_OPT_site" color=black fcolor=black size=9 icon=basic/circle
d.vect map="$GIS_OPT_site" color=red fcolor=red size=5 icon=basic/circle
fi
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup.procedures.tcl
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup.procedures.tcl 2014-02-07 06:12:50 UTC (rev 58922)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup.procedures.tcl 2014-02-07 06:49:15 UTC (rev 58923)
@@ -211,7 +211,7 @@
file delete $tmp.tmp
$button configure -state disabled
} else {
- tk_messageBox -message "Warning sampling frame not set" -type ok -icon warning
+ tk_messageBox -message "Warning: sampling frame not set" -type ok -icon warning
@@ -496,7 +496,7 @@
tk_messageBox -message "Selected area saved as sample area" -type ok
file delete $env(TMP).tmp
} else {
- tk_messageBox -message "Warning sampling area not set" -type ok -icon warning
+ tk_messageBox -message "Warning: sampling area not set" -type ok -icon warning
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/square_mouse_selection.sh
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/square_mouse_selection.sh 2014-02-07 06:12:50 UTC (rev 58922)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/square_mouse_selection.sh 2014-02-07 06:49:15 UTC (rev 58923)
@@ -1,4 +1,4 @@
-#!/bin/sh
+#!/bin/sh
# This script selects a square area using the mouse
@@ -6,7 +6,7 @@
# Read the COPYING file that comes with GRASS for details.
-#%Module
+#%Module
#% description: Select a rectangular area
#%End
#%option
@@ -55,7 +55,7 @@
#% required: no
#%end
#%option
-#% key: west
+#% key: west
#% type: string
#% required: no
@@ -93,7 +93,7 @@
g.remove region="tmp_rli_sq.$$" --quiet
fi
- rm -f "$TMP" "$TMP.var"
+ rm -f "$TMP" "$TMP.var"
trap "cleanup" 2 3 15
@@ -108,9 +108,7 @@
fi
done
-# open the Xmonitor
-d.mon stop="$XMON"
-d.mon start="$XMON"
+d.mon start="$XMON" --quiet
# setup internal region
@@ -135,12 +133,13 @@
e="$GIS_OPT_east" w="$GIS_OPT_west"
fi
-d.rast -o map="$GIS_OPT_raster"
+d.rast -o map="$GIS_OPT_raster" --quiet
- d.vect map="$GIS_OPT_vector"
+ d.vect map="$GIS_OPT_vector" type=area fcolor=none width=2
fi
fi
@@ -156,6 +155,7 @@
#EOF
+# note if user right clicks to quit without zooming the whole frame is used.
d.zoom
@@ -166,12 +166,17 @@
# ask if it's ok, save 0,1 to the "$name" tmp file
"$GRASS_WISH" "$f_path/square_query"
-read ok < "$TMP.var"
+if [ -e "$name" ] ; then
+ read ok < "$name"
+else
+ ok="-999"
+fi
if [ "$ok" -eq 0 ] ; then
echo "NO" >> "$GIS_OPT_conf"
elif [ "$ok" -eq 1 ] ; then
# write the square boundaries
+ # TODO: is range (0-1, 0-1) valid or a bug?
eval `g.region -g`
echo "SQUAREAREA $n|$s|$e|$w|$nsres|$ewres" >> "$GIS_OPT_conf"
else
@@ -179,7 +184,7 @@
fi
# close the Xmonitor
-d.mon stop="$XMON"
+d.mon stop="$XMON" --quiet
# clean tmp files and temporary region
cleanup
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/square_query
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/square_query 2014-02-07 06:12:50 UTC (rev 58922)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/square_query 2014-02-07 06:49:15 UTC (rev 58923)
@@ -12,17 +12,17 @@
global env
wm title . "Select this area"
wm minsize . 250 100
- label .label -text "Is this area ok?"
+ label .label -text "\nIs this area ok?"
pack .label
frame .buttons
pack .buttons
set val ""
button .buttons.ok -text "Ok" -command {
- exec echo 1 > $env(name).var
+ exec echo 1 > $env(name)
destroy .
button .buttons.no -text "No" -command {
- exec echo 0 > $env(name).var
+ exec echo 0 > $env(name)
destroy .
- grid .buttons.ok .buttons.no
+ grid .buttons.ok .buttons.no -padx 3 -pady 3
