[GRASS-SVN] r58929 - grass/branches/develbranch_6/raster/r.li/r.li.setup
Fri Feb 7 02:40:45 PST 2014
Author: hamish
Date: 2014-02-07 02:40:45 -0800 (Fri, 07 Feb 2014)
New Revision: 58929
   grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup
   grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup.main
<ol> the buttons to show order to press them in
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup	2014-02-07 08:17:53 UTC (rev 58928)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup	2014-02-07 10:40:45 UTC (rev 58929)
@@ -5,12 +5,14 @@
 # MODULE:       r.li.setup
 # AUTHOR(S):    Spano Lucio Davide & Claudio Porta
+#               shell scripts rewrite by Hamish Bowman
-# PURPOSE:     Configuration editor for r.li.<index>. It sets sampling frame and
-#              sample areas to analyze, the configuration is raster map indipendent.
+# PURPOSE:      Configuration editor for r.li.<index>. It sets sampling
+#               frame and sample areas to analyze, the configuration is
+#               raster map indipendent.
-# This program is free software under the GPL (>=v2)
-# Read the COPYING file that comes with GRASS for details.
+#   This program is free software under the GPL (>=v2)
+#   Read the COPYING file that comes with GRASS for details.
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup.main
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup.main	2014-02-07 08:17:53 UTC (rev 58928)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup.main	2014-02-07 10:40:45 UTC (rev 58929)
@@ -203,15 +203,15 @@
 	# insert buttons
 	frame .newConf.buttons -relief flat
 	pack .newConf.buttons -side bottom -anchor center -pady 2
-	button .newConf.buttons.save -text "Save settings" -state disabled -command {
+	button .newConf.buttons.save -text "3. Save settings" -state disabled -command {
 		saveSettings .newConf
-	button .newConf.buttons.s_area -text "Setup sampling areas" -state disabled -command {
+	button .newConf.buttons.s_area -text "2. Setup sampling areas" -state disabled -command {
 		setupSamplingArea .newConf
 		.newConf.buttons.save configure -state active
 		.newConf.buttons.s_area configure -state disabled
-	button .newConf.buttons.s_frame -text "Setup sampling frame" -command {
+	button .newConf.buttons.s_frame -text "1. Setup sampling frame" -command {
 		setupSamplingFrame .newConf
 		.newConf.buttons.s_frame configure -state disabled
