[GRASS-SVN] r58942 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Fri Feb 7 13:12:12 PST 2014
Author: martinl
Date: 2014-02-07 13:12:11 -0800 (Fri, 07 Feb 2014)
New Revision: 58942
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI/lmgr: move icons to directory (continued)
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2014-02-07 20:50:40 UTC (rev 58941)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2014-02-07 21:12:11 UTC (rev 58942)
@@ -1798,15 +1798,15 @@
if not self.currentPage:
self.NewDisplay(show = True)
- self._popupMenu((('layerRast3d', self.OnAddRaster3D),
+ self._popupMenu((('layer3d-raster', self.OnAddRaster3D),
(None, None),
('layerRgb', self.OnAddRasterRGB),
('layerHis', self.OnAddRasterHIS),
(None, None),
('layerShaded', self.OnAddRasterShaded),
(None, None),
- ('layerRArrow', self.OnAddRasterArrow),
- ('layerRNum', self.OnAddRasterNum)))
+ ('layerRastarrow', self.OnAddRasterArrow),
+ ('layerRastnum', self.OnAddRasterNum)))
# show map display
self.GetMapDisplay().Show()
@@ -1826,8 +1826,8 @@
- self._popupMenu((('layerThematic', self.OnAddVectorTheme),
- ('layerChart', self.OnAddVectorChart)))
+ self._popupMenu((('layerThememap', self.OnAddVectorTheme),
+ ('layerThemechart', self.OnAddVectorChart)))
# show map display
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2014-02-07 20:50:40 UTC (rev 58941)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2014-02-07 21:12:11 UTC (rev 58942)
@@ -70,23 +70,23 @@
label = _('Add command layer')),
'quit' : MetaIcon(img = 'quit',
label = _('Quit')),
- 'layerRast' : MetaIcon(img = 'layer-raster-add',
+ 'layerRaster' : MetaIcon(img = 'layer-raster-add',
label = _('Add raster map layer')),
'layerRgb' : MetaIcon(img = 'layer-rgb-add',
label = _('Add RGB map layer')),
'layerHis' : MetaIcon(img = 'layer-his-add',
label = _('Add HIS map layer')),
'layerShaded' : MetaIcon(img = 'layer-shaded-relief-add',
- label = _('Add shaded relief map layer')),
- 'layerRArrow' : MetaIcon(img = 'layer-aspect-arrow-add',
+ label = _('Add shaded relief map layer')),
+ 'layerRastarrow' : MetaIcon(img = 'layer-aspect-arrow-add',
label = _('Add raster flow arrows')),
- 'layerRNum' : MetaIcon(img = 'layer-cell-cats-add',
+ 'layerRastnum' : MetaIcon(img = 'layer-cell-cats-add',
label = _('Add raster cell numbers')),
- 'layerVect' : MetaIcon(img = 'layer-vector-add',
+ 'layerVector' : MetaIcon(img = 'layer-vector-add',
label = _('Add vector map layer')),
- 'layerThematic': MetaIcon(img = 'layer-vector-thematic-add',
+ 'layerThememap': MetaIcon(img = 'layer-vector-thematic-add',
label = _('Add thematic area (choropleth) map layer')),
- 'layerChart' : MetaIcon(img = 'layer-vector-chart-add',
+ 'layerThemechart' : MetaIcon(img = 'layer-vector-chart-add',
label = _('Add thematic chart layer')),
'layerGrid' : MetaIcon(img = 'layer-grid-add',
label = _('Add grid layer')),
@@ -96,10 +96,10 @@
label = _('Add rhumbline layer')),
'layerLabels' : MetaIcon(img = 'layer-label-add',
label = _('Add labels')),
- 'layerRast3d' : MetaIcon(img = 'layer-raster3d-add',
+ 'layer3d-raster' : MetaIcon(img = 'layer-raster3d-add',
label = _('Add 3D raster map layer'),
desc = _('Note that 3D raster data are rendered only in 3D view mode')),
- 'layerWS' : MetaIcon(img = 'layer-wms-add',
+ 'layerWMS' : MetaIcon(img = 'layer-wms-add',
label = _('Add WMS layer.')),
'layerOptions' : MetaIcon(img = 'options',
label = _('Set options'))
@@ -210,16 +210,16 @@
def _setIcons(self, il):
self._icon = {}
- for iconName in ("layerRast", "layerRast3d", "layerRgb",
- "layerHis", "layerShaded", "layerRArrow",
- "layerRNum", "layerVect", "layerThematic",
- "layerChart", "layerGrid", "layerGeodesic",
+ for iconName in ("layerRaster", "layer3d-raster", "layerRgb",
+ "layerHis", "layerShaded", "layerRastarrow",
+ "layerRastnum", "layerVector", "layerThememap",
+ "layerThemechart", "layerGrid", "layerGeodesic",
"layerRhumb", "layerLabels", "layerCmd",
- "layerWS"):
+ "layerWMS"):
iconKey = iconName[len("layer"):].lower()
icon = LMIcons[iconName].GetBitmap(self.bmpsize)
self._icon[iconKey] = il.Add(icon)
def _getSelectedLayer(self):
"""!Get selected layer.
@@ -261,8 +261,8 @@
return None
- def _setIcon(self, item):
- pass
+ def _setIcon(self, item, iconName):
+ self.SetItemImage(item, self._icon[iconName])
def _setGradient(self, iType = None):
"""!Set gradient for items
@@ -1072,62 +1072,18 @@
wx.CallAfter(self.CheckItem, layer, checked)
# add text and icons for each layer ltype
- label = _('(double click to set properties)') + ' ' * 15
- if ltype == 'raster':
- self.SetItemImage(layer, self._icon['rast'])
- self.SetItemText(layer, '%s %s' % (_('raster'), label))
- elif ltype == '3d-raster':
- self.SetItemImage(layer, self._icon['rast3d'])
- self.SetItemText(layer, '%s %s' % (_('3D raster'), label))
- elif ltype == 'rgb':
- self.SetItemImage(layer, self._icon['rgb'])
- self.SetItemText(layer, '%s %s' % (_('RGB'), label))
- elif ltype == 'his':
- self.SetItemImage(layer, self._icon['his'])
- self.SetItemText(layer, '%s %s' % (_('HIS'), label))
- elif ltype == 'shaded':
- self.SetItemImage(layer, self._icon['shaded'])
- self.SetItemText(layer, '%s %s' % (_('shaded relief'), label))
- elif ltype == 'rastnum':
- self.SetItemImage(layer, self._icon['rnum'])
- self.SetItemText(layer, '%s %s' % (_('raster cell numbers'), label))
- elif ltype == 'rastarrow':
- self.SetItemImage(layer, self._icon['rarrow'])
- self.SetItemText(layer, '%s %s' % (_('raster flow arrows'), label))
- elif ltype == 'vector':
- self.SetItemImage(layer, self._icon['vect'])
- self.SetItemText(layer, '%s %s' % (_('vector'), label))
- elif ltype == 'thememap':
- self.SetItemImage(layer, self._icon['theme'])
- self.SetItemText(layer, '%s %s' % (_('thematic area (choropleth) map'), label))
- elif ltype == 'themechart':
- self.SetItemImage(layer, self._icon['chart'])
- self.SetItemText(layer, '%s %s' % (_('thematic charts'), label))
- elif ltype == 'grid':
- self.SetItemImage(layer, self._icon['grid'])
- self.SetItemText(layer, '%s %s' % (_('grid'), label))
- elif ltype == 'geodesic':
- self.SetItemImage(layer, self._icon['geodesic'])
- self.SetItemText(layer, '%s %s' % (_('geodesic line'), label))
- elif ltype == 'rhumb':
- self.SetItemImage(layer, self._icon['rhumb'])
- self.SetItemText(layer, '%s %s' % (_('rhumbline'), label))
- elif ltype == 'labels':
- self.SetItemImage(layer, self._icon['labels'])
- self.SetItemText(layer, '%s %s' % (_('vector labels'), label))
- elif ltype == 'command':
+ if ltype == 'command':
self.SetItemImage(layer, self._icon['cmd'])
elif ltype == 'group':
self.SetItemImage(layer, self.folder, CT.TreeItemIcon_Normal)
self.SetItemImage(layer, self.folder_open, CT.TreeItemIcon_Expanded)
self.SetItemText(layer, grouptext)
- elif ltype == 'wms':
- self.SetItemImage(layer, self._icon['ws'])
- self.SetItemText(layer, '%s %s' % (_('wms'), label))
else:
- self.SetItemImage(layer, self._icon['cmd'])
- self.SetItemText(layer, '%s %s' % (_('unknown'), label))
+ self.SetItemImage(layer, self._icon[ltype])
+ # do not use title() - will not work with ltype == '3d-raster'
+ self.SetItemText(layer, '%s %s' % (LMIcons["layer"+ltype[0].upper()+ltype[1:]].GetLabel(),
+ _('(double click to set properties)') + ' ' * 15))
if ltype != 'group':
if lcmd and len(lcmd) > 1:
cmd = lcmd
