[GRASS-SVN] r58959 - grass/branches/develbranch_6/raster/r.li/r.li.daemon
svn_grass at osgeo.org
Sat Feb 8 20:39:57 PST 2014
Author: hamish
Date: 2014-02-08 20:39:56 -0800 (Sat, 08 Feb 2014)
New Revision: 58959
grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
move G_get_window() out of loop since it doesn't change
Modified: grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c 2014-02-09 01:55:26 UTC (rev 58958)
+++ grass/branches/develbranch_6/raster/r.li/r.li.daemon/daemon.c 2014-02-09 04:39:56 UTC (rev 58959)
@@ -382,7 +382,6 @@
if (rel_sa_x == -1.0 && rel_sa_y == -1.0) {
/* runtime disposition */
int sa_rl, sa_cl;
sa_rl = (int)rint(cellhd.rows * rel_sa_rl);
@@ -419,7 +418,6 @@
strcmp(token, "SAMPLEAREA") == 0);
close(setup);
return toReturn;
else if (strcmp("MASKEDSAMPLEAREA", token) == 0) {
@@ -433,6 +431,7 @@
rel_sa_rl = atof(strtok(NULL, "|"));
rel_sa_cl = atof(strtok(NULL, "|"));
strcpy(maskname, strtok(NULL, "\n"));
if (rel_sa_x == -1 && rel_sa_y == -1) {
int sa_rl, sa_cl;
@@ -464,8 +463,10 @@
insertNode(l, m);
while ((token = strtok(NULL, " ")) != NULL &&
strcmp(token, "MASKEDSAMPLEAREA") == 0);
close(setup);
return NORMAL;
@@ -473,8 +474,13 @@
double sa_n, sa_s, sa_w, sa_e;
int aid = 1;
char maskname[GNAME_MAX] = {'\0'};
+ struct Cell_head window;
msg m;
+ /* Get the window setting. g.region rast=<input raster> */
+ /* ? same as cellhd above ? */
+ G_get_window(&window);
do {
strcpy(maskname, strtok(NULL, "|"));
sa_n = atof(strtok(NULL, "|"));
@@ -484,11 +490,6 @@
m.type = MASKEDAREA;
- struct Cell_head window;
- /* Get the window setting. g.region rast=<input raster> */
- G_get_window(&window);
/* Each input overlay area from input vector are converted to raster
via v.to.rast. See r.li.setup/sample_area_vector.sh. This is to used
only for reading the region (NS, EW). */
