[GRASS-SVN] r58965 - in grass/trunk/raster/r.li: r.li.daemon r.li.setup
Sat Feb 8 22:16:50 PST 2014
Author: hamish
Date: 2014-02-08 22:16:50 -0800 (Sat, 08 Feb 2014)
New Revision: 58965
   grass/trunk/raster/r.li/r.li.daemon/daemon.c
   grass/trunk/raster/r.li/r.li.setup/area_query
   grass/trunk/raster/r.li/r.li.setup/masked_area_selection.sh
   grass/trunk/raster/r.li/r.li.setup/r.li.setup
   grass/trunk/raster/r.li/r.li.setup/r.li.setup.html
   grass/trunk/raster/r.li/r.li.setup/r.li.setup.main
   grass/trunk/raster/r.li/r.li.setup/r.li.setup.procedures.tcl
   grass/trunk/raster/r.li/r.li.setup/r.li.windows.tcl
   grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh
   grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh
   grass/trunk/raster/r.li/r.li.setup/square_query
sync old r.li.setup scripts with devbr6 (up to r58929)
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.c
--- grass/trunk/raster/r.li/r.li.daemon/daemon.c	2014-02-09 06:05:24 UTC (rev 58964)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.c	2014-02-09 06:16:50 UTC (rev 58965)
@@ -371,6 +371,7 @@
 	    aid++;
 	    insertNode(l, m);
 	while ((token = strtok(NULL, " ")) != NULL &&
 	       (strcmp(token, "MASKEDOVERLAYAREA") == 0));
Modified: grass/trunk/raster/r.li/r.li.setup/area_query
--- grass/trunk/raster/r.li/r.li.setup/area_query	2014-02-09 06:05:24 UTC (rev 58964)
+++ grass/trunk/raster/r.li/r.li.setup/area_query	2014-02-09 06:16:50 UTC (rev 58965)
@@ -4,21 +4,22 @@
 # Simply ask if the selected area is ok or not and save the
-# answer in the environment variable "env(name)"
+# answer in the filename given by the environment variable "env(name)"
     wm title . "Select this area"
     wm minsize . 250 100
-    label .label -text "Is this area ok?"
+    label .label -text "\nIs this area ok?"
     pack .label
     frame .buttons
     pack .buttons
-    set val ""
+    set val "$env(input_vector)_$env(CAT)"
     button .buttons.ok -text "Ok" -command {
 	frame .name
 	pack .name
 	frame .name.e
 	pack .name.e
-	label .name.e.n -text "Insert area name"
+	label .name.e.n -text "Enter area name\n(raster map mask name)"
 	entry .name.e.val -textvariable val -width 20
 	grid .name.e.n .name.e.val
 	frame .name.buttons
@@ -27,7 +28,7 @@
 	    if {$val != ""} then {
 		    exec echo 1 $val > $env(name)
 		    destroy .
 	pack  .name.buttons.b
@@ -35,4 +36,11 @@
 	exec echo 0 > $env(name)
 	destroy .
-    grid .buttons.ok .buttons.no
+    # what to call it: "stop"? "abort"? "quit"?
+    button .buttons.abort -text "Done" -command {
+	exec echo -1 > $env(name)
+	destroy .
+    grid .buttons.ok .buttons.no .buttons.abort -padx 2 -pady 2
Modified: grass/trunk/raster/r.li/r.li.setup/masked_area_selection.sh
--- grass/trunk/raster/r.li/r.li.setup/masked_area_selection.sh	2014-02-09 06:05:24 UTC (rev 58964)
+++ grass/trunk/raster/r.li/r.li.setup/masked_area_selection.sh	2014-02-09 06:16:50 UTC (rev 58965)
@@ -57,7 +57,7 @@
 #% required: no
 #%end
 #%option
-#% key: west
+#% key: west
 #% type: string
 #% description: Western edge (use only with the 'f' flag)
 #% required: no
@@ -134,32 +134,33 @@
    fi
 done
-# open the Xmonitor
-d.mon stop="$XMON"
-d.mon start="$XMON"
+d.mon start="$XMON" --quiet
-d.rast -o map="$GIS_OPT_raster"
+d.rast -o map="$GIS_OPT_raster" --quiet
 if [ -n "$GIS_OPT_vector" ] ; then
-    d.vect map="$GIS_OPT_vector"
+    d.vect map="$GIS_OPT_vector" type=area fcolor=none width=2
 fi
-if [ -n "$GIS_OPT_site" ] ; then
+if [ -n "$GIS_OPT_site" ] ; then
+    d.vect map="$GIS_OPT_site" color=black fcolor=black size=9 icon=basic/circle
     d.vect map="$GIS_OPT_site" color=red fcolor=red size=5 icon=basic/circle
 fi
 # setup for drawing area
 if [ "$GIS_FLAG_c" -eq 1 ] ; then
    RDIG_INSTR="$f_path/circle.txt"
+   STYLE="circle"
 else
    RDIG_INSTR="$f_path/polygon.txt"
+   STYLE="polygon"
 fi
 # feed options to r.digit
-r.digit output="tmp_rli_mask.$$" < "$RDIG_INSTR"
+r.digit output="tmp_rli_mask.$$" --quiet < "$RDIG_INSTR"
 # show the selected area
-d.rast -o map="tmp_rli_mask.$$"
+d.rast -o map="tmp_rli_mask.$$" --quiet
 name="$TMP.val"
 export name
@@ -172,10 +173,11 @@
 if [ "$ok" -eq 1 ] ; then
+    mask_name="rli_samp_${STYLE}_${r_name}"
     # r.mask + 'g.region zoom= align=' + 'r.mapcalc cropmap=map' would be cleaner?
-    r.to.vect input="tmp_rli_mask.$$" output="tmp_rli_mask_v$$" feature=area
+    r.to.vect input="tmp_rli_mask.$$" output="tmp_rli_mask_v$$" feature=area --quiet
     g.region vect="tmp_rli_mask_v$$"
-    v.to.rast input="tmp_rli_mask_v$$" output="$r_name" value=1 use=val
+    v.to.rast input="tmp_rli_mask_v$$" output="$mask_name" use=val value=1  --quiet
     # write info in configuration file
     eval `g.region -g`
@@ -184,7 +186,7 @@
     east="$e"
     west="$w"
-    echo "SAMPLEAREAMASKED $r_name $north|$south|$east|$west" >> \
+    echo "SAMPLEAREAMASKED $mask_name $north|$south|$east|$west" >> \
 	    "$GIS_OPT_conf"
     # remove tmp raster and vector
@@ -203,7 +205,7 @@
 fi
-d.mon stop="$XMON"
+d.mon stop="$XMON" --quiet
 # clean tmp files
 cleanup
Modified: grass/trunk/raster/r.li/r.li.setup/r.li.setup
--- grass/trunk/raster/r.li/r.li.setup/r.li.setup	2014-02-09 06:05:24 UTC (rev 58964)
+++ grass/trunk/raster/r.li/r.li.setup/r.li.setup	2014-02-09 06:16:50 UTC (rev 58965)
@@ -5,12 +5,14 @@
 # MODULE:       r.li.setup
 # AUTHOR(S):    Spano Lucio Davide & Claudio Porta
+#               shell scripts rewrite by Hamish Bowman
-# PURPOSE:     Configuration editor for r.li.<index>. It sets sampling frame and
-#              sample areas to analyze, the configuration is raster map indipendent.
+# PURPOSE:      Configuration editor for r.li.<index>. It sets sampling
+#               frame and sample areas to analyze, the configuration is
+#               raster map indipendent.
-# This program is free software under the GPL (>=v2)
-# Read the COPYING file that comes with GRASS for details.
+#   This program is free software under the GPL (>=v2)
+#   Read the COPYING file that comes with GRASS for details.
Modified: grass/trunk/raster/r.li/r.li.setup/r.li.setup.html
--- grass/trunk/raster/r.li/r.li.setup/r.li.setup.html	2014-02-09 06:05:24 UTC (rev 58964)
+++ grass/trunk/raster/r.li/r.li.setup/r.li.setup.html	2014-02-09 06:16:50 UTC (rev 58965)
@@ -32,7 +32,7 @@
   <li> Centered over sites (vector points).
 </ul>
 <li> Moving window: rectagular or circular with size
-<li> Select areas from the overlayed vector map (for details see below)
+<li> Select areas from the overlaid vector map (for details see below)
 </ul>
 <img src="sampleAreas.jpg" alt="Sampling area definition">
@@ -63,9 +63,9 @@
 	  of new configuration file
 	  <li> <em>Raster map name</em> (required): the name of raster
 	  map to use for setting
-	  <li> <em>Vector map to overlay</em> (optional): name of a vector
+	  <li> <em>Vector areas map to overlay</em> (optional): name of a vector
 	  map to overlay in setting
-	  <li> <em>Site file to overlay</em> (optional): name of vector map
+	  <li> <em>Vector points map to overlay</em> (optional): name of vector map
 	  of points type to overlay in setting
 	  </ul>
      <li> Set the sampling frame. The sample frame is a rectangular area
@@ -119,7 +119,7 @@
 	 circular area, it is moved over all the raster increasing only
 	 of a cell for every move(in columns if possible, if not in rows).
 	 It produces a new raster containing the result of all analysis.
-	 <li><em>Select areas from the overlayed vector map</em>:
+	 <li><em>Select areas from the overlaid vector map</em>:
 	 the sample areas are defined by the vector map selected above.
 	 For every cat in vector map, the procedure prompts the
 	 user if he wants to include it as sample area.
Modified: grass/trunk/raster/r.li/r.li.setup/r.li.setup.main
--- grass/trunk/raster/r.li/r.li.setup/r.li.setup.main	2014-02-09 06:05:24 UTC (rev 58964)
+++ grass/trunk/raster/r.li/r.li.setup/r.li.setup.main	2014-02-09 06:16:50 UTC (rev 58965)
@@ -89,13 +89,13 @@
 	pack $widget.samplingArea.choice
 	set selection ""
 	radiobutton $widget.samplingArea.choice.whole -text "Whole map layer" -relief flat -variable selection -value whole -width 40 -anchor w
-	radiobutton $widget.samplingArea.choice.regions -text "Regions" -relief flat -variable selection -value regions -width 40 -anchor w
-	radiobutton $widget.samplingArea.choice.units -text "Sample units" -relief flat -variable selection -value units -width 40 -anchor w
+	radiobutton $widget.samplingArea.choice.regions -text "Regions (digitize polygons with mouse)" -relief flat -variable selection -value regions -width 40 -anchor w
+	radiobutton $widget.samplingArea.choice.units -text "Sample units (digitize box or circular areas\nwith mouse or define using keyboard)" -relief flat -variable selection -value units -width 40 -anchor w
 	radiobutton $widget.samplingArea.choice.window -text "Moving window" -relief flat -variable selection -value window -width 40 -anchor w
 	set vectorAreas [exec cat $env(TMP).set | grep "SAMPLINGFRAME" | tail -n 1 | cut -f2 -d " "]
 	if { $vectorAreas == "0|0|1|1"} then {
-		#inserting select areas from the overlayed vector map
-		radiobutton $widget.samplingArea.choice.vector -text "Select areas from the overlayed vector map" -relief flat -variable selection -value vector -width 40 -anchor w
+		#inserting select areas from the overlaid vector map
+		radiobutton $widget.samplingArea.choice.vector -text "Select areas from the overlaid vector map" -relief flat -variable selection -value vector -width 40 -anchor w
 		pack $widget.samplingArea.choice.whole $widget.samplingArea.choice.regions $widget.samplingArea.choice.units $widget.samplingArea.choice.window $widget.samplingArea.choice.vector
 	} else {
@@ -172,8 +172,8 @@
 	frame .newConf.frame -relief flat
 	pack .newConf.frame -side top -fill y -anchor center
-	set names {{} {Configuration file name:} {Raster map to use to select areas:} {[Vector map to overlay:]}\
-	 {[Site file to overlay:]} }
+	set names {{} {Configuration file name:} {Raster map to use to select areas:} {[Vector areas map to overlay:]}\
+	 {[Vector points map to overlay:]} }
 	label .newConf.frame.label1 -text [lindex $names 1] -anchor e
 	entry .newConf.frame.entry1 -width 35 -textvariable env(CONF)
 	grid .newConf.frame.label1 .newConf.frame.entry1 -sticky ew -pady 2 -padx 1
@@ -203,15 +203,15 @@
 	# insert buttons
 	frame .newConf.buttons -relief flat
 	pack .newConf.buttons -side bottom -anchor center -pady 2
-	button .newConf.buttons.save -text "Save settings" -state disabled -command {
+	button .newConf.buttons.save -text "3. Save settings" -state disabled -command {
 		saveSettings .newConf
-	button .newConf.buttons.s_area -text "Setup sampling areas" -state disabled -command {
+	button .newConf.buttons.s_area -text "2. Setup sampling areas" -state disabled -command {
 		setupSamplingArea .newConf
 		.newConf.buttons.save configure -state active
 		.newConf.buttons.s_area configure -state disabled
-	button .newConf.buttons.s_frame -text "Setup sampling frame" -command {
+	button .newConf.buttons.s_frame -text "1. Setup sampling frame" -command {
 		setupSamplingFrame .newConf
 		.newConf.buttons.s_frame configure -state disabled
@@ -239,7 +239,7 @@
 	frame $widget.newUni.button
 	pack $widget.newUni.button -side left -anchor w
 	#buttons
-	button $widget.newUni.button.b2 -text " Use keyboard to enter sampling units dimension " -width 50 -command {
+	button $widget.newUni.button.b2 -text " Use keyboard to define sampling units dimension " -width 50 -command {
 		 setKeyboardUnit
 		 $setSampleUnits.newUni.button.b2 configure -state disabled
 		 $setSampleUnits.newUni.button.b3 configure -state disabled
@@ -273,7 +273,7 @@
 	frame $widget.newWin.button
 	pack $widget.newWin.button -side left -anchor w
 	#buttons
-	button $widget.newWin.button.b2 -text " Use keyboard to enter moving window dimension " -width 50 -command {
+	button $widget.newWin.button.b2 -text " Use keyboard to define moving window dimension " -width 50 -command {
 		 setKeyboardWindow
 		 $setMovWindow.newWin.button.b2 configure -state disabled
 		 $setMovWindow.newWin.button.b3 configure -state disabled
@@ -366,8 +366,8 @@
 	wm title .removeconf "\[r.li.setup\] Remove Window"
 	# new top label
-	label .removeconf.topLabel -text "Are You sure to remove the ' $selection ' file ?"
-        pack .removeconf.topLabel -side top
+	label .removeconf.topLabel -text "Are you sure to remove the '$selection' file ?"
+        pack .removeconf.topLabel -side top -pady 10 -padx 10
 	# create new frame
 	frame .removeconf.buttons -relief flat
@@ -377,8 +377,7 @@
 	button .removeconf.buttons.y -text "Yes" -width 8 -command {
 	      if { [ catch { exec rm $env(HOME)/.grass7/r.li/$selection } ] } then {
 		tk_messageBox -message "'$selection' Not deleted" -type ok -icon error} else {
-		#annoying "deleted" messageBox
-		#tk_messageBox -message "$selection  deleted" -type ok
+		tk_messageBox -message "'$selection' deleted." -type ok
 		openDir .files "~/.grass7/r.li"
 		destroy .removeconf}
@@ -386,7 +385,7 @@
 	# create no button
 	button .removeconf.buttons.n -text "No" -width 8 -command { destroy .removeconf
 	openDir .files "~/.grass7/r.li"}
-	grid .removeconf.buttons.y  .removeconf.buttons.n
+	grid .removeconf.buttons.y  .removeconf.buttons.n -padx 2 -pady 10
Modified: grass/trunk/raster/r.li/r.li.setup/r.li.setup.procedures.tcl
--- grass/trunk/raster/r.li/r.li.setup/r.li.setup.procedures.tcl	2014-02-09 06:05:24 UTC (rev 58964)
+++ grass/trunk/raster/r.li/r.li.setup/r.li.setup.procedures.tcl	2014-02-09 06:16:50 UTC (rev 58965)
@@ -7,8 +7,8 @@
  #update sample frame environment variables
  proc updateSF_Environment { } {
  	global env
- 	exec g.region rast=$env(RASTER)
-	exec g.region -g > $env(TMP).tmp
+ 	exec g.region rast=$env(RASTER)
+	exec g.region -g > $env(TMP).tmp
 	set n [ exec cat $env(TMP).tmp | grep "n=" | cut -f2 -d= ]
 	set s [ exec cat $env(TMP).tmp | grep "s=" | head -n 1 | cut -f2 -d= ]
 	set w [ exec cat $env(TMP).tmp | grep "w=" | cut -f2 -d= ]
@@ -26,18 +26,18 @@
 	file delete $env(TMP).tmp
 	#debug line
 	#tk_messageBox -message "$env(SF_N)|$env(SF_S)|$env(SF_W)|$env(SF_E)|$env(SF_NSRES)|$env(SF_EWRES)|"
- #shows the instruction for drawing squares
+ #shows the instruction for drawing squares
  proc squareInstruction {} {
  	toplevel .instruction
 	wm title .instruction "\[r.li.setup\] Commands"
 	#wm maxsize .instruction 300 200
 	frame .instruction.txt
-	pack .instruction.txt
-	text .instruction.txt.t -font Helvetica -height 12
+	pack .instruction.txt
+	text .instruction.txt.t -font Helvetica -height 12
 	.instruction.txt.t tag configure big -font {Helvetica 16 bold}
 	.instruction.txt.t tag configure normal -font {Helvetica 14}
 	.instruction.txt.t insert end "Mouse buttons functions \n \n" big
@@ -55,14 +55,14 @@
 	#.instruction.txt configure -state disabled
 	return .instruction
  proc vectorInstruction {} {
@@ -80,14 +80,14 @@
 	return .instruction
  proc circleInstruction {} {
@@ -116,15 +116,15 @@
 	pack .fileBrowser.top -side top -fill y -anchor center
 	listbox .fileBrowser.top.listbox -selectmode single
 	openDir .fileBrowser.top.listbox $path
-	pack .fileBrowser.top.listbox -expand 1 -fill both -padx 7 -pady 7
+	pack .fileBrowser.top.listbox -expand 1 -fill both -padx 7 -pady 7
 	#browser buttons
 	frame .fileBrowser.buttons
 	pack .fileBrowser.buttons -side bottom -pady 2 -anchor center
 	button .fileBrowser.buttons.open -text "Open" -command {set selection [fileSelect .fileBrowser .fileBrowser.top.listbox $p_entry]}
 	pack .fileBrowser.buttons.open
  proc fileSelect {widget listbox entry} {
  set selection [$listbox get [$listbox curselection]]
 		switch [file type $selection] {
@@ -137,10 +137,10 @@
- #Open the specified directory
+ #Open the specified directory
  proc openDir {listbox newpath} {
     catch {cd $newpath}
     $listbox delete 0 end
@@ -174,12 +174,12 @@
 	} else {
 		set ins [squareInstruction]
 		tkwait window $ins
-		catch { exec $env(F_PATH)/square_mouse_selection.sh raster=$env(RASTER) vector=$env(VECTOR) site=$env(SITE) conf=$tmp.tmp }
+		catch { exec $env(F_PATH)/square_mouse_selection.sh raster=$env(RASTER) vector=$env(VECTOR) site=$env(SITE) conf=$tmp.tmp >@stdout 2>@stderr }
 		set ok ""
 		catch {set ok [exec cat $tmp.tmp | grep "SQUAREAREA" | cut -f1 -d\ ]}
 		if { $ok == "SQUAREAREA" } then {
 			#sampling frame accepted
-			set start [exec cat $tmp.tmp | grep "START" | cut -f2 -d\ ]
+			set start [exec cat $tmp.tmp | grep "START" | cut -f2 -d\ ]
 			scan $start %f|%f|%f|%f|%f|%f s_n s_s s_e s_w s_nres s_sres
 			set square [exec cat $tmp.tmp | grep "SQUAREAREA" | cut -f2 -d\ ]
 			#resolution north-south
@@ -191,11 +191,11 @@
 			set env(SF_S) $s
 			set env(SF_E) $e
 			set env(SF_W) $w
-			set rows [exec  r.info map=$env(RASTER) | grep "Rows" | tr -d " " |   cut -f 2 -d: | cut -f 1 -d\| ]
+			set rows [exec r.info map=$env(RASTER) | grep "Rows" | tr -d " " | cut -f 2 -d: | cut -f 1 -d\| ]
 			set cols [exec r.info map=$env(RASTER) | grep "Columns" | tr -d " " | cut -f 2 -d: | cut -f 1 -d\|  ]
 			# calulating area coordinates
-			set env(SF_Y) [expr abs(round(($s_n - $n) / $nres)) ]
-			set env(SF_X) [expr abs(round(($s_w - $w) / $sres)) ]
+			set env(SF_Y) [expr abs(round(($s_n - $n) / $nres)) ]
+			set env(SF_X) [expr abs(round(($s_w - $w) / $sres)) ]
 			set env(SF_RL) [expr abs(round(($n - $s) / $nres)) ]
 			set env(SF_CL) [expr abs(round(($e - $w) / $sres)) ]
 			set env(SF_NSRES) $nres
@@ -206,12 +206,12 @@
 			set cl [ expr double($env(SF_CL)) / double($cols) ]
 			#debug line
 			#tk_messageBox -message "$x|$y|$rl|$cl"
-			exec echo "SAMPLINGFRAME $x|$y|$rl|$cl" >> $tmp.set
+			exec echo "SAMPLINGFRAME $x|$y|$rl|$cl" >> $tmp.set
 			tk_messageBox -message "Selected area set as sampling frame" -type ok
 			file delete $tmp.tmp
 			$button configure -state disabled
 		} else {
-			tk_messageBox -message "Warning sampling frame not set" -type ok -icon warning
+			tk_messageBox -message "Warning: sampling frame not set" -type ok -icon warning
@@ -225,7 +225,7 @@
 set tmp $env(TMP)
 switch $selection {
 	whole {
 		set x [expr double($env(SF_X)) / double($cols) ]
 		set y [expr double($env(SF_Y)) / double($rows) ]
@@ -246,8 +246,8 @@
 	vector {
 		tk_messageBox -message "WARNING: this configuration file will work only on $env(RASTER) raster map" -type ok -icon warning
 		#TODO change here
-		if { $env(RASTER) != "" && $env(VECTOR) != "" && $env(CONF) != "" } then {
-			catch { exec  $env(F_PATH)/sample_area_vector.sh  raster=$env(RASTER) vector=$env(VECTOR) conf=$env(TMP).set }
+		if { $env(RASTER) != "" && $env(VECTOR) != "" && $env(CONF) != "" } then {
+			catch { exec  $env(F_PATH)/sample_area_vector.sh  raster=$env(RASTER) vector=$env(VECTOR) sites=$env(SITE) conf=$env(TMP).set >@stdout 2>@stderr }
 		} else {
 			tk_messageBox -message "Please set configuration file name, raster map and vector file to overlay" -type ok -icon error
@@ -259,84 +259,84 @@
 # defines sampling units distribuition
 proc defineSamplingUnits {selec rl cl maskname} {
 	global env
-	set tmp $env(TMP)
+	set tmp $env(TMP)
 	#da modificare qua per le proiezioni
 	switch $selec {
 		nonoverlapping {
-			toplevel .dialog
+			toplevel .dialog
 			wm title .dialog " Random Nonoverlapping "
-			wm minsize .dialog 300 150
+			wm minsize .dialog 300 100
 			frame .dialog.scale
 			pack .dialog.scale
-			label .dialog.scale.label1 -text " What number of Sampling Units to use?"
+			label .dialog.scale.label1 -text "\n How many Sampling Units to use?"
 			entry .dialog.scale.e1 -width 5 -textvariable number1
-			grid .dialog.scale.label1 .dialog.scale.e1   -padx 3
+			grid .dialog.scale.label1 .dialog.scale.e1  -padx 3
 			button .dialog.button -text " Ok " -command {
 				if  { $number1!="" && ![catch { exec printf %i $number1 }]} then {
 					exec echo "RANDOMNONOVERLAPPING $number1" >> $env(TMP).set
-					tk_messageBox -message "Sampling units distribuition set as Random Nonoverlapping" -type ok
+					tk_messageBox -message "Sampling units distribuition set to Random Nonoverlapping" -type ok
 					set number1 ""
 					destroy .dialog
 				} else {
 					tk_messageBox -message "Please type integer value" -type ok -icon error
-			pack .dialog.button
+			pack .dialog.button -pady 3
-		contiguous {
+		contiguous {
 			exec echo "SYSTEMATICCONTIGUOUS " >> $env(TMP).set
-			tk_messageBox -message "Sampling units distribuition set as Systematic Contiguous" -type ok
+			tk_messageBox -message "Sampling units distribuition set to Systematic Contiguous" -type ok
-		noncontiguous {
-			toplevel .dialog
+		noncontiguous {
+			toplevel .dialog
 			wm title .dialog " Systematic non contiguous "
 			frame .dialog.scale
 			pack .dialog.scale
 			label .dialog.scale.label1 -text " Insert distance between units"
 				exec echo "SYSTEMATICNONCONTIGUOUS $number1" >> $env(TMP).set
-				tk_messageBox -message "Sampling units distribuition set as Systematic Non Contiguous" -type ok
+				tk_messageBox -message "Sampling units distribuition set to Systematic Non Contiguous" -type ok
 				set number1 ""
 				destroy .dialog
 			} else {
-		random {
-			toplevel .dialog
+		random {
+			toplevel .dialog
 			wm title .dialog " Stratified Random "
 			frame .dialog.scale
 			pack .dialog.scale
 			label .dialog.scale.label1 -text " Insert number of row strates "
 			frame .dialog.scale2
 			pack .dialog.scale2
 			label .dialog.scale2.label2 -text " Insert number of column strates "
 			entry .dialog.scale2.e2 -width 5 -textvariable number2
 			grid .dialog.scale2.label2 .dialog.scale2.e2   -padx 3
 			if  { $number1!="" && $number2!="" && ![catch { exec printf %i%i $number1 $number2 }]} then {
 				exec echo "STRATIFIEDRANDOM $number1|$number2" >> $env(TMP).set
-				tk_messageBox -message "Sampling units distribuition set as Stratified random" -type ok
+				tk_messageBox -message "Sampling units distribuition set to Stratified random" -type ok
 				set number1 ""
 				destroy .dialog
 			} else {
@@ -345,8 +345,8 @@
 		pack .dialog.button
-		sites {
+		sites {
 			if { $env(RASTER) == "" || $env(SITE) == "" } then {
 				tk_messageBox -message "Please set raster and site file names first" -icon error
 			} else {
@@ -367,7 +367,7 @@
 			#check if we have integers
 			tk_messageBox -message "Type integer values" -type ok -icon error
 			} else {
 				set rl [expr double($number2) / double($rows) ]
 				set cl [expr double($number1) /double($cols) ]
@@ -380,14 +380,14 @@
 			tk_messageBox -message "Set all entries first" -type ok -icon error
-		circle {
+		circle {
 			if  { $number3 != "" } then {
 				if { [catch { exec printf %i $number3 }]  } then {
 			} else {
 				circleMask $number3 $maskname
 				set rl [expr double($env(CIR_RL)) /double($rows)]
 				set cl [expr double($env(CIR_CL)) /double($cols)]
@@ -413,19 +413,19 @@
 		set ins [vectorInstruction]
 		tkwait window $ins
 		while { $i < $number } {
-		 	catch { exec $env(F_PATH)/masked_area_selection.sh -f north=$env(SF_N) south=$env(SF_S) west=$env(SF_W) east=$env(SF_E) raster=$env(RASTER) vector=$env(VECTOR) site=$env(SITE) conf=$env(TMP).tmp }
+		 	catch { exec $env(F_PATH)/masked_area_selection.sh -f north=$env(SF_N) south=$env(SF_S) west=$env(SF_W) east=$env(SF_E) raster=$env(RASTER) vector=$env(VECTOR) site=$env(SITE) conf=$env(TMP).tmp >@stdout 2>@stderr }
 			set ok ""
 			catch {set ok [exec cat $env(TMP).tmp | grep "SAMPLEAREAMASKED" | cut -f1 -d\ ]}
 			if { $ok == "SAMPLEAREAMASKED" } then {
-				#region accepted
+				#region accepted
 				incr i
 				set r_name [exec cat $env(TMP).tmp | grep "SAMPLEAREAMASKED" | cut -f2 -d\ ]
 				set square [exec cat $env(TMP).tmp | grep "SAMPLEAREAMASKED" | cut -f3 -d\ ]
 				scan $square %f|%f|%f|%f n s e w
-				set abs_y [expr $env(SF_Y) + abs(round(($env(SF_N) - $n) / $env(SF_NSRES))) ]
-				set abs_x [expr $env(SF_X)+ abs(round(($env(SF_W) - $w) / $env(SF_EWRES))) ]
+				set abs_y [expr $env(SF_Y) + abs(round(($env(SF_N) - $n) / $env(SF_NSRES))) ]
+				set abs_x [expr $env(SF_X)+ abs(round(($env(SF_W) - $w) / $env(SF_EWRES))) ]
 				set abs_rl [expr abs(round(($n - $s) / $env(SF_NSRES))) ]
 				set abs_cl [expr abs(round(($e - $w) / $env(SF_EWRES))) ]
 				#debug line
@@ -436,16 +436,16 @@
 				set cl [ expr double($abs_cl) / double($cols) ]
 				#debug line
-				exec echo "MASKEDSAMPLEAREA $x|$y|$rl|$cl|$r_name" >> $env(TMP).set
+				exec echo "MASKEDSAMPLEAREA $x|$y|$rl|$cl|$r_name" >> $env(TMP).set
 				tk_messageBox -message "Selected region saved as sampling area" -type ok
 			} else {
 				tk_messageBox -message "Please redraw region number $i" -type ok -icon warning
@@ -463,13 +463,13 @@
 				tk_messageBox -message "Please enter a raster map and a configuration file name first" -type ok -icon error
 			} else {
 				while { $i < $num } {
-					catch { exec $env(F_PATH)/square_mouse_selection.sh -f north=$env(SF_N) south=$env(SF_S) east=$env(SF_E) west=$env(SF_W) raster=$env(RASTER) vector=$env(VECTOR) site=$env(SITE) conf=$env(TMP).tmp }
+					catch { exec $env(F_PATH)/square_mouse_selection.sh -f north=$env(SF_N) south=$env(SF_S) east=$env(SF_E) west=$env(SF_W) raster=$env(RASTER) vector=$env(VECTOR) site=$env(SITE) conf=$env(TMP).tmp >@stdout 2>@stderr }
 					set ok ""
 					catch {set ok [exec cat $env(TMP).tmp | grep "SQUAREAREA" | cut -f1 -d\ ]}
 						#sampling area accepted
 						incr i
-						set start [exec cat $env(TMP).tmp | grep "START" | cut -f2 -d\ ]
+						set start [exec cat $env(TMP).tmp | grep "START" | cut -f2 -d\ ]
 						set square [exec cat $env(TMP).tmp | grep "SQUAREAREA" | cut -f2 -d\ ]
@@ -477,11 +477,11 @@
 						#resolution east-west
 						set sres ""
 						scan $square %f|%f|%f|%f|%f|%f n s e w nres sres
-						set abs_y [expr abs(round(($s_n - $n) / $nres)) ]
-						set abs_x [expr abs(round(($s_w - $w) / $sres)) ]
+						set abs_y [expr abs(round(($s_n - $n) / $nres)) ]
+						set abs_x [expr abs(round(($s_w - $w) / $sres)) ]
 						set abs_rl [expr abs(round(($n - $s) / $nres)) ]
 						set abs_cl [expr abs(round(($e - $w) / $sres)) ]
 						#debug line
@@ -492,12 +492,12 @@
 						#debug line
-						exec echo "SAMPLEAREA $x|$y|$rl|$cl" >> $env(TMP).set
+						exec echo "SAMPLEAREA $x|$y|$rl|$cl" >> $env(TMP).set
 						tk_messageBox -message "Selected area saved as sample area" -type ok
 					} else {
-						tk_messageBox -message "Warning sampling area not set" -type ok -icon warning
+						tk_messageBox -message "Warning: sampling area not set" -type ok -icon warning
@@ -507,19 +507,19 @@
 			set ins [circleInstruction]
 			tkwait window $ins
-		 		catch { exec $env(F_PATH)/masked_area_selection.sh -f -c north=$env(SF_N) south=$env(SF_S) west=$env(SF_W) east=$env(SF_E) raster=$env(RASTER) vector=$env(VECTOR) site=$env(SITE) conf=$env(TMP).tmp }
+		 		catch { exec $env(F_PATH)/masked_area_selection.sh -f -c north=$env(SF_N) south=$env(SF_S) west=$env(SF_W) east=$env(SF_E) raster=$env(RASTER) vector=$env(VECTOR) site=$env(SITE) conf=$env(TMP).tmp >@stdout 2>@stderr }
 				set ok ""
-					#region accepted
+					#region accepted
 					incr i
 					#debug line
@@ -530,7 +530,7 @@
 					#debug line
 					tk_messageBox -message "Selection saved as sampling area" -type ok
 				} else {
@@ -539,12 +539,12 @@
 #draw moving window with mouse
 proc drawMouseWindow { sel } {
-	global env
+	global env
 	#rectangular or circular window
 	switch $sel {
 		rectangle {
@@ -555,13 +555,13 @@
 			} else {
 				while { $i == 0 } {
 					set ok ""
 						#moving window accepted
 						incr i
@@ -569,7 +569,7 @@
 						set sres ""
 						#calculating moving window width and length
@@ -581,14 +581,14 @@
 						#debug line
 						exec echo "MOVINGWINDOW" >> $env(TMP).set
-						exec echo "SAMPLEAREA -1|-1|$rl|$cl" >> $env(TMP).set
+						exec echo "SAMPLEAREA -1|-1|$rl|$cl" >> $env(TMP).set
 						tk_messageBox -message "Moving window set" -type ok
 					} else {
 						tk_messageBox -message "Moving window not set" -type ok -icon warning
 		circle {
 			#circulars areas
@@ -596,16 +596,16 @@
 			tkwait window $ins
 			while { $i == 0 } {
 				set ok ""
-					#region accepted
+					#region accepted
 					incr i
@@ -616,20 +616,20 @@
 					#debug line
-					exec echo "MASKEDSAMPLEAREA -1|-1|$rl|$cl|$r_name" >> $env(TMP).set
+					exec echo "MASKEDSAMPLEAREA -1|-1|$rl|$cl|$r_name" >> $env(TMP).set
 				} else {
 #create a circle mask for the keyboard circle selection
 proc circleMask { radius name} {
-	global env
+	global env
 	exec g.region -m > $env(TMP).tmp
 	set nsres [ exec cat $env(TMP).tmp | grep "nsres=" | cut -f2 -d= ]
@@ -638,7 +638,7 @@
 	set xcell [expr round((2 * $radius) / $ewres) ]
 	set ycell [expr round((2 * $radius) / $nsres) ]
 	#to create a good raster circle the center of the circle have to be
-	#in the center of a cell, then we need an odd number of cells...
+	#in the center of a cell, then we need an odd number of cells...
 	if { [ expr $xcell % 2 ] == 0 } then {
 		incr xcell
@@ -653,33 +653,33 @@
 	set southEdge [expr double($env(SF_N) - ($ycell * $env(SF_NSRES)))]
 	#restrict region
 	exec g.region n=$env(SF_N) s=$southEdge e=$easthEdge w=$env(SF_W)
-	set xcenter [exec g.region -c | grep "region center easting:" | cut -f2 -d: | tr -d " "]
-	set ycenter [exec g.region -c | grep "region center northing:" | cut -f2 -d: | tr -d " "]
+	set xcenter [exec g.region -c | grep "center easting:" | cut -f2 -d: | tr -d " "]
+	set ycenter [exec g.region -c | grep "center northing:" | cut -f2 -d: | tr -d " "]
 	#debug line
 	#tk_messageBox -message "$xcenter , $ycenter $env(SF_N) $southEdge $env(SF_W) $easthEdge"
 	#creating circle
 	catch {exec r.circle -b output=$name coordinate=$xcenter,$ycenter max=$radius }
-#set sample units from a site file
+#set sample units from a site file
 proc centerOverSites { rl cl name} {
-	global env
+	global env
 	if { $env(SITE) == "" || $env(RASTER) == "" } then {
 		tk_messageBox -message "Please set raster and site file name first" -type ok -icon error
 	} else {
 		#raster boundaries
-		#create ascii site file
+		#create ascii site file
 		exec v.out.ascii input=$env(SITE) output=$env(TMP).asc format=point
-		#counting points
+		#counting points
 		set num [exec cat $env(TMP).asc | grep -c "" ]
 		set i 0
 		# inserting point if they are into sample frame
 			incr i
@@ -696,7 +696,7 @@
 			if { $ok == "TRUE" } then {
 				#the point is into sample frame
-				#calculating what cell contains this point
+				#calculating what cell contains this point
 				set p_c [expr int( abs($x - $env(SF_W)) / $env(SF_EWRES))]
 				set p_r [expr int( abs($y - $env(SF_N)) / $env(SF_NSRES))]
 				#debug line
@@ -704,7 +704,7 @@
 				#the point is the center of the rectangle, we have to see if the rectangle is into sample frame
 				set rl_delta [expr int( $rl/2)]
 				set cl_delta [expr int( $cl/2)]
-				set n_diff [expr ($p_r - $rl_delta) - $env(SF_Y)]
+				set n_diff [expr ($p_r - $rl_delta) - $env(SF_Y)]
 				set s_diff [expr ($env(SF_Y) + $env(SF_RL)) - ($p_r + $rl_delta +1) ]
 				set e_diff [expr ($env(SF_X) + $env(SF_CL)) - ($p_c + $cl_delta + 1) ]
 				set w_diff [expr ($p_c - $cl_delta) - $env(SF_X)]
@@ -723,33 +723,33 @@
-	file delete $env(TMP).tmp $env(TMP).line $env(TMP).asc
+	file delete $env(TMP).tmp $env(TMP).line $env(TMP).asc
 proc saveSettings { widget } {
 	global env
 	#write the sample frame
-	exec cat $env(TMP).set | grep "SAMPLINGFRAME " | tail -n 1 > $env(CONF)
+	exec cat $env(TMP).set | grep "SAMPLINGFRAME " | tail -n 1 > $env(CONF)
 	#write sampling areas
-	catch  { exec cat $env(TMP).set | grep "SAMPLEAREA " >> $env(CONF) }
+	catch  { exec cat $env(TMP).set | grep "SAMPLEAREA " >> $env(CONF) }
 	catch { exec cat $env(TMP).set | grep "MASKEDSAMPLEAREA " >> $env(CONF) }
 	set overlay 0
 	catch { set overlay [ exec cat $env(TMP).set | grep "MASKEDOVERLAYAREA " -c ] }
 	if { $overlay != 0 } then {
-		exec cat $env(TMP).set | grep "MASKEDOVERLAYAREA " >> $env(CONF)
+		exec cat $env(TMP).set | grep "MASKEDOVERLAYAREA " >> $env(CONF)
 		exec echo "RASTERMAP $env(RASTER)" >> $env(CONF)
 		exec echo "VECTORMAP $env(VECTOR)" >> $env(CONF)
 	#write disposition line
-	catch { exec cat $env(TMP).set | grep "MOVINGWINDOW" >> $env(CONF) }
-	catch { exec cat $env(TMP).set | grep "RANDOMNONOVERLAPPING " >> $env(CONF) }
+	catch { exec cat $env(TMP).set | grep "MOVINGWINDOW" >> $env(CONF) }
+	catch { exec cat $env(TMP).set | grep "RANDOMNONOVERLAPPING " >> $env(CONF) }
 	catch { exec cat $env(TMP).set | grep "SYSTEMATICCONTIGUOUS " >> $env(CONF) }
-	catch { exec cat $env(TMP).set | grep "SYSTEMATICNONCONTIGUOUS " >> $env(CONF) }
+	catch { exec cat $env(TMP).set | grep "SYSTEMATICNONCONTIGUOUS " >> $env(CONF) }
 	catch { exec cat $env(TMP).set | grep "STRATIFIEDRANDOM " >> $env(CONF)  }
 	file delete $env(TMP).set
 	destroy $widget
Modified: grass/trunk/raster/r.li/r.li.setup/r.li.windows.tcl
--- grass/trunk/raster/r.li/r.li.setup/r.li.windows.tcl	2014-02-09 06:05:24 UTC (rev 58964)
+++ grass/trunk/raster/r.li/r.li.setup/r.li.windows.tcl	2014-02-09 06:16:50 UTC (rev 58965)
@@ -153,7 +153,7 @@
 	label .kUni.scale.label4 -text " What radius size (in meters) for each sampling unit?" -state disabled
 	entry .kUni.scale.e4 -width 5 -textvariable number4 -state disabled
 	grid .kUni.scale.label4 .kUni.scale.e4 -pady 20 -padx 3
-	label .kUni.scale.label5 -text " Name for the circle mask" -state disabled
+	label .kUni.scale.label5 -text " Name for the circle mask raster map" -state disabled
 	entry .kUni.scale.e5 -width 15 -textvariable maskname -state disabled
 	grid .kUni.scale.label5 .kUni.scale.e5  -padx 3
@@ -196,6 +196,7 @@
 				tk_messageBox -message "Type integer values or set raster map name" -type ok -icon error
 			} else {
+				set maskname "rli_circlemask_$maskname"
 				circleMask $number4 $maskname
 				defineSamplingUnits $selec $env(CIR_RL) $env(CIR_RL) $maskname
 				if { $selec != "sites" } then {
@@ -393,7 +394,7 @@
 		label .load.info.l1 -text "The sampling areas are defined only for $rname file"
 		pack .load.info.l1
 		set vname [exec cat $filename | grep "VECTORMAP " | cut -f2 -d\ ]
-		label .load.info.l2 -text "The overlayed vector file is $vname"
+		label .load.info.l2 -text "The overlaid vector file is $vname"
 		pack .load.info.l2
 	} else {
 		#extract sample areas
Modified: grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh
--- grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh	2014-02-09 06:05:24 UTC (rev 58964)
+++ grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh	2014-02-09 06:16:50 UTC (rev 58965)
@@ -20,10 +20,16 @@
 #% type: string
 #% gisprompt: old,vector,vector
 #% key_desc: name
-#% description: Vector map where areas are defined
+#% description: Vector map containing areas
 #% required: yes
 #%end
 #%option
+#% key: sites
+#% type: string
+#% description: Vector points map to overlay
+#% required: no
+#%end
+#%option
 #% key: conf
 #% type: string
 #% key_desc: name
@@ -88,10 +94,11 @@
    fi
 done
-# open Xmonitor
-d.mon stop="$XMON"
+#d.mon stop="$XMON" --quiet
+# TODO: pause to offer a "resize xmon now" window since it will
+#  be locked during the interactive selection.
 f_path="$GISBASE/etc/r.li.setup"
@@ -100,41 +107,63 @@
 # convert to raster and save the bounds to configuration file
-# using v.category instead of v.build with cdump
-v.category input="$GIS_OPT_vector" option=print | \
+# using v.category instead of v.build with cdump because v.build
+#  needs fully qualified map name and is harder to parse.
+v.category input="$GIS_OPT_vector" type=centroid option=print | \
   sort -n | uniq > "$TMP.cat"
+NUM_CATS=`wc -l < "$TMP.cat"`
+if [ "$NUM_CATS" -gt 30 ] ; then
+    g.message -w "<$GIS_OPT_vector> contains $NUM_CATS areas. Manual selection may be time consuming."
+    # TODO: d.menu [Continue][Abort] on screen display
+elif [ "$NUM_CATS" -eq 0 ] ; then
+    g.message -w "<$GIS_OPT_vector> doesn't contain any areas. Aborting selection."
+    # TODO: d.menu [Ok] on screen display
+fi
 # crop away @mapset part, if present
 input_vector=`echo "$GIS_OPT_vector" | cut -d'@' -f 1`
 # process each feature in the vector that has a cat
+i=0
 while read CAT ; do
-   # skip blank lines..
+   # skip blank lines.. (shouldn't be any)
     if [ -z "$CAT" ] ; then
        continue
     fi
+    i=`expr $i + 1`
     # Temporary vector map to store an individual feature from the input vector
     #  It will be removed at the end of the iteration.
     EXTRACT="tmp_$$_${input_vector}_${CAT}"
     v.extract input="$GIS_OPT_vector" output="$EXTRACT" \
-       type=point,line,centroid,area \
-       new=-1 -d list="$CAT"  # where="CAT = $CAT"
+       type=area new=-1 -d list="$CAT" --quiet
     # set region with raster resolution
     g.region vect="$EXTRACT" align="$GIS_OPT_raster"
     d.erase
-    d.rast -o "$GIS_OPT_raster"
+    d.rast -o "$GIS_OPT_raster" --quiet
     # render extracted vector map  (prehaps fcolor=none for areas?)
-    d.vect "$EXTRACT"
+    d.vect "$EXTRACT" type=boundary width=2
+    if [ -n "$GIS_OPT_SITES" ] ; then
+	d.vect map="$GIS_OPT_SITES" color=black fcolor=black size=9 icon=basic/circle
+	d.vect map="$GIS_OPT_SITES" color=red fcolor=red size=5 icon=basic/circle
+    fi
+    echo " Area $i of $NUM_CATS (category $CAT)" | \
+       d.text color=black size=2.5
     # ask the user to analyse this vector and a name for raster in a Tcl GUI
     name="$TMP.val" # where find the answer
-    export name
+    export name input_vector CAT
     # ask if it's ok, save 0,1 to "$name" temp file
     "$GRASS_WISH" "$f_path/area_query"
@@ -143,15 +172,20 @@
     r_name=`cat "$name" | cut -f2 -d' '`
     # debug or needed?
-    echo "$r_name"
+    g.message -d message="area_query map name (exit code 1) or exit code: $r_name"
 	#area selected, create mask
-	v.to.rast input="$EXTRACT" output="$r_name" use=cat
+	mask_name="rli_samp_${r_name}"
+	v.to.rast input="$EXTRACT" output="$mask_name" use=cat --quiet
 	# save the region settings into the configuration file
 	eval `g.region -g`
-	echo "MASKEDOVERLAYAREA $r_name|$n|$s|$e|$w" >> "$GIS_OPT_conf"
+	echo "MASKEDOVERLAYAREA $mask_name|$n|$s|$e|$w" >> "$GIS_OPT_conf"
+    elif [ "$ok" -eq -1 ] ; then
+	g.remove vect="$EXTRACT" --quiet
+	break
     fi
     #remove temporary vector map created from v.extract
@@ -160,7 +194,7 @@
 done < "$TMP.cat"
-d.mon stop="$XMON"
 # clean tmp files and restore region
Modified: grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh
--- grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh	2014-02-09 06:05:24 UTC (rev 58964)
+++ grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh	2014-02-09 06:16:50 UTC (rev 58965)
@@ -1,4 +1,4 @@
-#!/bin/sh
+#!/bin/sh
 # This script selects a square area using the mouse
@@ -6,7 +6,7 @@
-#%Module
+#%Module
 #% description: Select a rectangular area
 #%End
 #%option
@@ -55,7 +55,7 @@
 #% required: no
 #%end
 #%option
-#% key: west
+#% key: west
 #% type: string
 #% required: no
@@ -93,7 +93,7 @@
       g.remove region="tmp_rli_sq.$$" --quiet
    fi
-   rm -f "$TMP" "$TMP.var"
+   rm -f "$TMP" "$TMP.var"
 trap "cleanup" 2 3 15
@@ -108,9 +108,7 @@
    fi
 done
-d.mon stop="$XMON"
 # setup internal region
@@ -135,12 +133,13 @@
 	     e="$GIS_OPT_east" w="$GIS_OPT_west"
 fi
 fi
 fi
@@ -156,6 +155,7 @@
 #EOF
+# note if user right clicks to quit without zooming the whole frame is used.
 d.zoom
@@ -166,12 +166,17 @@
 # ask if it's ok, save 0,1 to the "$name" tmp file
 "$GRASS_WISH" "$f_path/square_query"
-read ok < "$TMP.var"
+if [ -e "$name" ] ; then
+   read ok < "$name"
+else
+   ok="-999"
+fi
 if [ "$ok" -eq 0 ] ; then
     echo "NO" >> "$GIS_OPT_conf"
 elif [ "$ok" -eq 1 ] ; then
     # write the square boundaries
+    # TODO: is range (0-1, 0-1) valid or a bug?
     eval `g.region -g`
     echo "SQUAREAREA $n|$s|$e|$w|$nsres|$ewres" >> "$GIS_OPT_conf"
 else
@@ -179,7 +184,7 @@
 fi
 # close the Xmonitor
-d.mon stop="$XMON"
 # clean tmp files and temporary region
 cleanup
Modified: grass/trunk/raster/r.li/r.li.setup/square_query
--- grass/trunk/raster/r.li/r.li.setup/square_query	2014-02-09 06:05:24 UTC (rev 58964)
+++ grass/trunk/raster/r.li/r.li.setup/square_query	2014-02-09 06:16:50 UTC (rev 58965)
@@ -12,17 +12,17 @@
     global env
     pack .label
     frame .buttons
     pack .buttons
     set val ""
-	exec echo 1 > $env(name).var
+	exec echo 1 > $env(name)
 	destroy .
     button .buttons.no -text "No" -command {
-	exec echo 0 > $env(name).var
+	exec echo 0 > $env(name)
 	destroy .
+    grid .buttons.ok .buttons.no -padx 3 -pady 3
