[GRASS-SVN] r58968 - in grass/trunk/raster/r.li: r.li.cwed r.li.dominance r.li.edgedensity r.li.mpa r.li.mps r.li.padcv r.li.padrange r.li.padsd r.li.patchdensity r.li.patchnum r.li.pielou r.li.renyi r.li.richness r.li.setup r.li.shannon r.li.shape r.li.simpson
Sat Feb 8 22:34:49 PST 2014
Author: hamish
Date: 2014-02-08 22:34:49 -0800 (Sat, 08 Feb 2014)
New Revision: 58968
   grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
   grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html
   grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
   grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html
   grass/trunk/raster/r.li/r.li.mps/r.li.mps.html
   grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html
   grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html
   grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html
   grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
   grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html
   grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html
   grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html
   grass/trunk/raster/r.li/r.li.richness/r.li.richness.html
   grass/trunk/raster/r.li/r.li.setup/r.li.setup.html
   grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html
   grass/trunk/raster/r.li/r.li.shape/r.li.shape.html
   grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html
r.li files moved into ~/.grass7/r.li/
Modified: grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
--- grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -23,7 +23,7 @@
 Do not use absolute path names for the <b>output</b> map/file.
 If the "moving window" method was selected in <b>r.li.setup</b>, then the
 output will be a raster map, otherwise an ASCII file will be generated in
-the <tt>~/.r.li/output/</tt> folder.
+the <tt>~/.grass7/r.li/output/</tt> folder.
 <p>
 <br>
 If the raster is full of null value it is considered to have 0 patch and CWED=0.
Modified: grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html
--- grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -14,7 +14,7 @@
 <p>
 If input raster is full of null values r.li.dominance returns -1.<br>
 If you want to have null values instead run <br>
Modified: grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
--- grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -22,7 +22,7 @@
 <p>
 If input raster is full of null values <em>r.li.edgedensity</em> consider to have 0
 patch.<br>
Modified: grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html
--- grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -18,7 +18,7 @@
 <p>
 If input raster is full of null values r.li.mpa consider to
 have 0 patch.<br>
Modified: grass/trunk/raster/r.li/r.li.mps/r.li.mps.html
--- grass/trunk/raster/r.li/r.li.mps/r.li.mps.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.mps/r.li.mps.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -16,7 +16,7 @@
 <p>
 If the input raster contains NULL value cells, <em>r.li.mps</em>
 returns 0 for these cells. <br>
Modified: grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html
--- grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -17,7 +17,7 @@
 <p>
 If input raster is not full of null values r.li.padcv returns a value >=0 that is PADcv. <br>
 If input raster is full of null values r.li.padcv returns -1. <br>
Modified: grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html
--- grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -23,7 +23,7 @@
 <p>
 If the input raster contains NULL value cells, <em>r.li.padrange</em>
 returns -1 for these cells. <br>
Modified: grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html
--- grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -14,7 +14,7 @@
 <p>
 If input raster is not full of null values <em>r.li.padsd</em> returns a
 value >=0 that is PADsd. <br>
Modified: grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
--- grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -15,7 +15,7 @@
 <p>
 A map of NULL values is considered to have zero patches. <br>
Modified: grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html
--- grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -10,7 +10,7 @@
 <p>
 An that is full of null values is considered to have zero patch. <br>
Modified: grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html
--- grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -14,7 +14,7 @@
 <p>
 If the input raster contains NULL value cells, <em>r.li.pielou</em>
Modified: grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html
--- grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -17,7 +17,7 @@
 <p>
 If input raster contain NULL values <em>r.li.renyi</em> returns -1.<br>
Modified: grass/trunk/raster/r.li/r.li.richness/r.li.richness.html
--- grass/trunk/raster/r.li/r.li.richness/r.li.richness.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.richness/r.li.richness.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -11,7 +11,7 @@
 <p>
 If input raster is full of null values r.li.richness returns -1.<br>
Modified: grass/trunk/raster/r.li/r.li.setup/r.li.setup.html
--- grass/trunk/raster/r.li/r.li.setup/r.li.setup.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.setup/r.li.setup.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -51,7 +51,7 @@
 (the file name can be defined by the user).
 <!-- NOT REALLY CLEAR: -->
 Configuration output files are raster if moving window disposition was
-selected, otherwise they are in <tt>~/.r.li/output</tt> folder.
+selected, otherwise they are in <tt>~/.grass7/r.li/output</tt> folder.
 <br>
 All dimension are percentage of raster rows or columns.
 <li><em><b>Create a new file:</b></em> this create a new configuration
Modified: grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html
--- grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -15,7 +15,7 @@
 <p>
 If input raster is full of null values r.li.shannon returns -1. <br>
Modified: grass/trunk/raster/r.li/r.li.shape/r.li.shape.html
--- grass/trunk/raster/r.li/r.li.shape/r.li.shape.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.shape/r.li.shape.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -8,7 +8,7 @@
 <p>
 If the input raster contains NULL value cells, <em>r.li.shape</em>
Modified: grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html
--- grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html	2014-02-09 06:28:28 UTC (rev 58967)
+++ grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html	2014-02-09 06:34:49 UTC (rev 58968)
@@ -15,7 +15,7 @@
 <p>
 If input raster is full of null values <em>r.li.simpson</em> returns -1.<br>
