[GRASS-SVN] r58976 - grass/trunk/vector/v.build
svn_grass at osgeo.org
Mon Feb 10 09:20:30 PST 2014
Author: neteler
Date: 2014-02-10 09:20:30 -0800 (Mon, 10 Feb 2014)
New Revision: 58976
grass/trunk/vector/v.build/v.build.html
v.build.html: fix map name
Modified: grass/trunk/vector/v.build/v.build.html
--- grass/trunk/vector/v.build/v.build.html 2014-02-10 08:06:13 UTC (rev 58975)
+++ grass/trunk/vector/v.build/v.build.html 2014-02-10 17:20:30 UTC (rev 58976)
@@ -52,7 +52,7 @@
index is created.
<div class="code"><pre>
-v.build map=urbanareas option=build
+v.build map=urbanarea option=build
</pre></div>
Note that the vector map <i>urbanarea</i> must be located in the
@@ -65,7 +65,7 @@
from other mapsets.
-v.build map=urbanareas option=dump
+v.build map=urbanarea option=dump
</pre></div>
<h2>SEE ALSO</h2>
