[GRASS-SVN] r58988 - grass/branches/develbranch_6/gui/wxpython/gui_core
svn_grass at osgeo.org
Mon Feb 10 17:56:09 PST 2014
Author: annakrat
Date: 2014-02-10 17:56:09 -0800 (Mon, 10 Feb 2014)
New Revision: 58988
grass/branches/develbranch_6/gui/wxpython/gui_core/prompt.py
wxGUI/prompt: fix character events for keyboard layouts different from US (merge from trunk, r58984)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/prompt.py 2014-02-11 01:52:31 UTC (rev 58987)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/prompt.py 2014-02-11 01:56:09 UTC (rev 58988)
@@ -752,6 +752,7 @@
# bindings
self.Bind(wx.EVT_WINDOW_DESTROY, self.OnDestroy)
+ self.Bind(wx.EVT_CHAR, self.OnChar)
self.Bind(wx.EVT_KEY_DOWN, self.OnKeyPressed)
self.Bind(wx.stc.EVT_STC_AUTOCOMP_SELECTION, self.OnItemSelected)
self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemChanged)
@@ -934,16 +935,73 @@
if len(self.autoCompList) > 0:
self.autoCompList.sort()
self.AutoCompShow(lenEntered = 0, itemList = ' '.join(self.autoCompList))
def OnKeyPressed(self, event):
- """!Key press capture for autocompletion, calltips, and command history
+ """!Key pressed capture special treatment for tabulator to show help"""
+ pos = self.GetCurrentPos()
+ if event.GetKeyCode() == wx.WXK_TAB:
+ # show GRASS command calltips (to hide press 'ESC')
+ entry = self.GetTextLeft()
+ try:
+ cmd = entry.split()[0].strip()
+ except IndexError:
+ cmd = ''
+ if cmd not in globalvar.grassCmd:
+ return
+ info = gtask.command_info(GetRealCmd(cmd))
+ self.CallTipSetBackground("#f4f4d1")
+ self.CallTipSetForeground("BLACK")
+ self.CallTipShow(pos, info['usage'] + '\n\n' + info['description'])
+ elif event.GetKeyCode() in (wx.WXK_RETURN, wx.WXK_NUMPAD_ENTER) and \
+ not self.AutoCompActive():
+ # run command on line when <return> is pressed
+ self._runCmd(self.GetCurLine()[0].strip())
+ elif event.GetKeyCode() in [wx.WXK_UP, wx.WXK_DOWN] and \
+ # Command history using up and down
+ if len(self.cmdbuffer) < 1:
+ return
+ self.DocumentEnd()
+ # move through command history list index values
+ if event.GetKeyCode() == wx.WXK_UP:
+ self.cmdindex = self.cmdindex - 1
+ if event.GetKeyCode() == wx.WXK_DOWN:
+ self.cmdindex = self.cmdindex + 1
+ if self.cmdindex < 0:
+ self.cmdindex = 0
+ if self.cmdindex > len(self.cmdbuffer) - 1:
+ self.cmdindex = len(self.cmdbuffer) - 1
+ try:
+ txt = self.cmdbuffer[self.cmdindex]
+ except KeyError:
+ txt = ''
+ # clear current line and insert command history
+ self.DelLineLeft()
+ self.DelLineRight()
+ self.InsertText(pos, txt)
+ self.LineEnd()
+ self.ShowStatusText('')
+ else:
+ event.Skip()
+ def OnChar(self, event):
+ """!Key char capture for autocompletion, calltips, and command history
@todo event.ControlDown() for manual autocomplete
# keycodes used: "." = 46, "=" = 61, "-" = 45
# complete command after pressing '.'
- if event.GetKeyCode() == 46 and not event.ShiftDown():
+ if event.GetKeyCode() == 46:
self.autoCompList = list()
self.InsertText(pos, '.')
@@ -963,8 +1021,10 @@
return
self.ShowList()
- # complete flags after pressing '-'
- elif event.GetKeyCode() == 45 and not event.ShiftDown():
+ # complete flags after pressing '-'
+ elif (event.GetKeyCode() == 45) \
+ or event.GetKeyCode() == wx.WXK_NUMPAD_SUBTRACT \
+ or event.GetKeyCode() == wx.WXK_SUBTRACT:
self.InsertText(pos, '-')
@@ -982,7 +1042,7 @@
self.ShowList()
# complete map or values after parameter
- elif event.GetKeyCode() == 61 and not event.ShiftDown():
+ elif event.GetKeyCode() == 61:
self.InsertText(pos, '=')
self.CharRight()
@@ -997,7 +1057,7 @@
self.ShowList()
# complete mapset ('@')
- elif event.GetKeyCode() == 50 and event.ShiftDown():
+ elif event.GetKeyCode() == 64:
self.InsertText(pos, '@')
self.CharRight()
@@ -1070,60 +1130,6 @@
self.ShowList()
- elif event.GetKeyCode() == wx.WXK_TAB:
- # show GRASS command calltips (to hide press 'ESC')
- entry = self.GetTextLeft()
- try:
- cmd = entry.split()[0].strip()
- except IndexError:
- cmd = ''
- if cmd not in globalvar.grassCmd:
- return
- info = gtask.command_info(GetRealCmd(cmd))
- self.CallTipSetBackground("#f4f4d1")
- self.CallTipSetForeground("BLACK")
- self.CallTipShow(pos, info['usage'] + '\n\n' + info['description'])
- elif event.GetKeyCode() in [wx.WXK_UP, wx.WXK_DOWN] and \
- not self.AutoCompActive():
- # Command history using up and down
- if len(self.cmdbuffer) < 1:
- return
- self.DocumentEnd()
- # move through command history list index values
- if event.GetKeyCode() == wx.WXK_UP:
- self.cmdindex = self.cmdindex - 1
- if event.GetKeyCode() == wx.WXK_DOWN:
- self.cmdindex = self.cmdindex + 1
- if self.cmdindex < 0:
- self.cmdindex = 0
- if self.cmdindex > len(self.cmdbuffer) - 1:
- self.cmdindex = len(self.cmdbuffer) - 1
- try:
- txt = self.cmdbuffer[self.cmdindex]
- except:
- txt = ''
- # clear current line and insert command history
- self.DelLineLeft()
- self.DelLineRight()
- pos = self.GetCurrentPos()
- self.InsertText(pos,txt)
- self.LineEnd()
- self.parent.parent.statusbar.SetStatusText('')
- elif event.GetKeyCode() in [wx.WXK_RETURN, wx.WXK_NUMPAD_ENTER] and \
- self.AutoCompActive() == False:
- # run command on line when <return> is pressed
- self._runCmd(self.GetCurLine()[0].strip())
elif event.GetKeyCode() == wx.WXK_SPACE:
items = self.GetTextLeft().split()
if len(items) == 1:
