[GRASS-SVN] r58993 - grass/trunk/raster/r.li/r.li.mps
Tue Feb 11 06:04:03 PST 2014
Author: neteler
Date: 2014-02-11 06:04:03 -0800 (Tue, 11 Feb 2014)
New Revision: 58993
   grass/trunk/raster/r.li/r.li.mps/mps.c
r.li.mps: avoid double free corruption; trivial white space
Modified: grass/trunk/raster/r.li/r.li.mps/mps.c
--- grass/trunk/raster/r.li/r.li.mps/mps.c	2014-02-11 14:03:49 UTC (rev 58992)
+++ grass/trunk/raster/r.li/r.li.mps/mps.c	2014-02-11 14:04:03 UTC (rev 58993)
@@ -6,7 +6,7 @@
  *   This program is free software under the GPL (>=v2)
  *   Read the COPYING file that comes with GRASS for details.
 #include <stdlib.h>
@@ -27,7 +27,6 @@
 int calculateD(int fd, struct area_entry *ad, struct Cell_head hd, double *result);
 int calculateF(int fd, struct area_entry *ad, struct Cell_head hd, double *result);
 int main(int argc, char *argv[])
     struct Option *raster, *conf, *output;
@@ -60,10 +59,8 @@
 int meanPatchSize(int fd, char **par, struct area_entry *ad, double *result)
     int ris = 0;
     double indice = 0;
     struct Cell_head hd;
@@ -91,14 +88,14 @@
 	    G_fatal_error("data type unknown");
 	    return RLI_ERRORE;
-    if (ris != RLI_OK) {
-	return RLI_ERRORE;
+    if (ris != RLI_OK)
+	  return RLI_ERRORE;
     *result = indice;
-    return RLI_OK;
+    return RLI_OK;
@@ -133,11 +130,8 @@
     double EW_DIST1, EW_DIST2, NS_DIST1, NS_DIST2;
     avlID_tree albero = NULL;
     avlID_table *array;
     /* open mask if needed */
     if (ad->mask == 1) {
 	if ((mask_fd = open(ad->mask_name, O_RDONLY, 0755)) < 0)
@@ -469,7 +463,7 @@
     G_free(mask_patch_corr);
-    G_free(buf_sup);
+    /* G_free(buf_sup); */   /* <-- why not free it? */
     return RLI_OK;
@@ -478,16 +472,13 @@
     DCELL *buf;
     DCELL *buf_sup;
     DCELL corrCell;
     DCELL precCell;
     DCELL supCell;
     int i, j;
     int mask_fd = -1, *mask_buf;
     int ris = 0;
     int masked = FALSE;
     long npatch = 0;
     long tot = 0;
     long zero = 0;
@@ -497,7 +488,6 @@
     long doppi = 0;
     long *mask_patch_sup;
     long *mask_patch_corr;
     double indice = 0;
     double area = 0;		/*if all cells are null area=0 */
     double areaCorrect = 0;
@@ -1158,7 +1148,6 @@
 	array = G_malloc(npatch * sizeof(avlID_tableRow));
 	if (array == NULL) {
 	    G_fatal_error("malloc array failed");
@@ -1203,8 +1192,8 @@
     if (masked)
-	G_free(mask_buf);
+	  G_free(mask_buf);
+/* TODO: fix if? */
     return RLI_OK;
