[GRASS-SVN] r58995 - grass/trunk/raster/r.li/r.li.dominance
svn_grass at osgeo.org
Tue Feb 11 06:04:31 PST 2014
Author: neteler
Date: 2014-02-11 06:04:30 -0800 (Tue, 11 Feb 2014)
New Revision: 58995
grass/trunk/raster/r.li/r.li.dominance/dominance.c
r.li.dominance: code style updated to that of r.li.simpson (port of r58994)
Modified: grass/trunk/raster/r.li/r.li.dominance/dominance.c
--- grass/trunk/raster/r.li/r.li.dominance/dominance.c 2014-02-11 14:04:10 UTC (rev 58994)
+++ grass/trunk/raster/r.li/r.li.dominance/dominance.c 2014-02-11 14:04:30 UTC (rev 58995)
@@ -6,8 +6,6 @@
* This program is free software under the GPL (>=v2)
* Read the COPYING file that comes with GRASS for details.
- * \BUGS: please send bugs reports to pallecch at cli.di.unipi.it
@@ -24,7 +22,6 @@
#include "../r.li.daemon/avl.h"
#include "../r.li.daemon/daemon.h"
int calculate(int fd, struct area_entry *ad, double *result);
int calculateD(int fd, struct area_entry *ad, double *result);
int calculateF(int fd, struct area_entry *ad, double *result);
@@ -75,17 +72,17 @@
switch (ad->data_type) {
case CELL_TYPE:
- calculate(fd, ad, &indice);
+ ris = calculate(fd, ad, &indice);
break;
case DCELL_TYPE:
- calculateD(fd, ad, &indice);
+ ris = calculateD(fd, ad, &indice);
break;
case FCELL_TYPE:
- calculateF(fd, ad, &indice);
+ ris = calculateF(fd, ad, &indice);
break;
default:
@@ -93,12 +90,12 @@
G_fatal_error("data type unknown");
return RLI_ERRORE;
- if (ris != RLI_OK) {
- return RLI_ERRORE;
+ if (ris != RLI_OK)
+ return RLI_ERRORE;
*result = indice;
return RLI_OK;
@@ -131,12 +128,10 @@
double t;
double logaritmo;
- generic_cell cc;
avl_tree albero = NULL;
AVL_table *array;
+ generic_cell cc;
cc.t = CELL_TYPE;
@@ -152,15 +147,9 @@
masked = TRUE;
Rast_set_c_null_value(&precCell, 1);
- /*for each row */
- for (j = 0; j < ad->rl; j++) {
- buf = RLI_get_cell_raster_row(fd, j + ad->y, ad);
+ for (j = 0; j < ad->rl; j++) { /* for each row */
if (masked) {
if (read(mask_fd, mask_buf, (ad->cl * sizeof(int))) < 0) {
G_fatal_error("mask read failed");
@@ -168,7 +157,7 @@
+ buf = RLI_get_cell_raster_row(fd, j + ad->y, ad);
for (i = 0; i < ad->cl; i++) { /* for each cell in the row */
area++;
corrCell = buf[i + ad->x];
@@ -183,7 +172,6 @@
if (Rast_is_null_value(&precCell, cc.t)) {
precCell = corrCell;
if (corrCell != precCell) {
if (albero == NULL) {
cc.val.c = precCell;
@@ -193,6 +181,7 @@
G_fatal_error("avl_make error");
return RLI_ERRORE;
+ /* TODO missing?: else - see r.li.simpson/simpson.c */
m++;
else {
@@ -231,10 +220,8 @@
} /* end for */
} /* end for */
+ /*last closing */
if (a != 0) {
- /*last closing */
albero = avl_make(cc, totCorr);
@@ -302,25 +289,18 @@
else /*if a is 0, that is all cell are null, i put index=-1 */
indice = (double)(-1);
- *result = indice;
- if (masked) {
+ if (masked)
G_free(mask_buf);
+ *result = indice;
return RLI_OK;
DCELL *buf;
DCELL corrCell;
DCELL precCell;
@@ -363,14 +343,9 @@
masked = TRUE;
Rast_set_d_null_value(&precCell, 1);
- /*for each row */
- buf = RLI_get_dcell_raster_row(fd, j + ad->y, ad);
if (masked) {
@@ -378,6 +353,7 @@
+ buf = RLI_get_dcell_raster_row(fd, j + ad->y, ad);
for (i = 0; i < ad->cl; i++) { /* for each dcell in the row */
area++;
@@ -443,9 +419,8 @@
G_free(mask_buf);
- if (a != 0) {
/*last closing */
+ if (a != 0) {
cc.val.dc = precCell;
@@ -524,7 +499,6 @@
FCELL *buf;
FCELL corrCell;
FCELL precCell;
@@ -571,11 +545,7 @@
Rast_set_f_null_value(&precCell, 1);
- /*for each row */
- buf = RLI_get_fcell_raster_row(fd, j + ad->y, ad);
if (masked) {
@@ -583,10 +553,13 @@
+ buf = RLI_get_fcell_raster_row(fd, j + ad->y, ad);
for (i = 0; i < ad->cl; i++) { /* for each fcell in the row */
area++;
if (masked && mask_buf[i + ad->x] == 0) {
Rast_set_f_null_value(&corrCell, 1);
area--;
@@ -644,7 +617,6 @@
/*last closing */
if (a != 0) {
@@ -711,18 +683,15 @@
G_free(array);
- indice = (double)(-1);
+ indice = (double)(-1);
- *result = indice;
if (masked) {
G_free(mask_buf);
+ *result = indice;
return RLI_OK;
