[GRASS-SVN] r59002 - in grass/trunk: gui/wxpython/rlisetup raster/r.li raster/r.li/r.li.cwed raster/r.li/r.li.dominance raster/r.li/r.li.edgedensity raster/r.li/r.li.mpa raster/r.li/r.li.mps raster/r.li/r.li.padcv raster/r.li/r.li.padrange raster/r.li/r.li.padsd raster/r.li/r.li.patchdensity raster/r.li/r.li.patchnum raster/r.li/r.li.pielou raster/r.li/r.li.renyi raster/r.li/r.li.richness raster/r.li/r.li.setup raster/r.li/r.li.shannon raster/r.li/r.li.shape raster/r.li/r.li.simpson
svn_grass at osgeo.org
Tue Feb 11 08:23:59 PST 2014
Author: neteler
Date: 2014-02-11 08:23:59 -0800 (Tue, 11 Feb 2014)
New Revision: 59002
grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html
grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html
grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
grass/trunk/raster/r.li/r.li.html
grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html
grass/trunk/raster/r.li/r.li.mps/r.li.mps.html
grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html
grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html
grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html
grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html
grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html
grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html
grass/trunk/raster/r.li/r.li.richness/r.li.richness.html
grass/trunk/raster/r.li/r.li.setup/r.li.setup.html
grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html
grass/trunk/raster/r.li/r.li.shape/r.li.shape.html
grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html
r.li.* manuals: cosmetics
Modified: grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html
--- grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -2,20 +2,32 @@
<!-- meta page index: wxGUI -->
<h2>DESCRIPTION</h2>
-The <b>RLi Setup</b> is a <em><a href="wxGUI.html">wxGUI</a></em>
+The <b>g.gui.rlisetup</b> is a <em><a href="wxGUI.html">wxGUI</a></em>
component which allows the user to create a configuration file
-for <em>r.li</em> modules.
+for the analytical <em>r.li</em> modules. For a general introduction, see
+<a href="r.li.html">r.li</a>.
+<br>
+The configurations are raster map independent, it means that you can use
+a file created on a raster map for analyze any other you have. <br>
+The program is completely interactive and uses a GUI to help you
+in your choices.
+<p>
+TODO: merge in material from GRASS GIS 6 (raster/r.li/r.li.setup/r.li.setup.html)
-<!-- TODO: merge in material from raster/r.li/r.li.setup/r.li.setup.html -->
+<h2>NOTES</h2>
+Configuration files are raster map independent because areas are saved using
+relative coordinates.
<h2>EXAMPLES</h2>
<h3>Moving window analysis on full region</h3>
-<i>TODO: update to new g.gui dialog:</i>
-Example for a 7x7 moving window analysis on full region:
+<i>TODO: update examples to new g.gui.rlisetup dialog:</i>
+<p>
+Example for a 7x7 moving window analysis on full region, the output
+is a raster map:
+<p>
Click on "New", then:
<ul>
<li> Configuration file name: "movwindow7"</li>
@@ -47,43 +59,79 @@
<p>
Now an anaysis can be performed using one of the analytical modules, e.g.
<div class="code"><pre>
+g.region rast=forests -p
r.li.patchdensity input=forests conf=movwindow7 output=forests_p_dens7
+r.univar forests_p_dens7
</pre></div>
-The result is a new raster map "forests_p_dens7".
+The result is the new raster map "forests_p_dens7" which shows (in this example)
+the patch density of the forest areas.
<br>
See the respective modules for further examples.
-<!-- TODO: add configuration example which results in ASCII output rather than raster map -->
-<h2>NOTES</h2>
+<h3>Whole region analysis</h3>
-Configuration files are raster map independent because areas are
-saved using relative coordinates.
+<!-- TODO: find a better example and briefly explain the meaning of result -->
+Example for a whole region analysis, the output is a text file:
+Click on "New", then:
+<ul>
+ <li> Configuration file name: "whole_region"</li>
+ <li> Raster map name to use to select areas: "lsat7_2000_40"</li>
+</ul>
+1. Setup sampling frame:
+<ul>
+<li> Define a sampling frame (region for analysis): "Whole map layer", then "OK"</li>
+</ul>
+2. Setup sampling frame
+<ul>
+<li> Define sampling areas: "Whole map layer", then "OK"</li>
+</ul>
+3. Save settings: click on button
+<br>
+(4.) Close
+<p>
+Now an anaysis can be performed using one of the analytical modules, e.g.
+<div class="code"><pre>
+g.region rast=lsat7_2002_40 -p
+r.li.shannon input=lsat7_2000_40 conf=whole_region output=lsat7_2000_40_shannon
+</pre></div>
+The result is the new text file "forests_p_dens7" (stored in folder <tt>$HOME/.r.li/output/</tt>.
+<br>
+See the respective modules for further examples.
<h2>SEE ALSO</h2>
<em>
- <a href="wxGUI.html">wxGUI</a><br>
- <a href="wxGUI.components.html">wxGUI components</a>
+<a href="r.li.html">r.li</a> - package overview<br>
+<a href="r.li.daemon.html">r.li.daemon</a>
</em>
<p>
<em>
- <a href="g.gui.html">g.gui</a>,
- <a href="g.gui.animation.html">g.gui.animation</a>,
- <a href="g.gui.dbmgr.html">g.gui.dbmgr</a>,
- <a href="g.gui.gmodeler.html">g.gui.gmodeler</a>,
- <a href="g.gui.iclass.html">g.gui.iclass</a>,
- <a href="g.gui.mapswipe.html">g.gui.mapswipe</a>,
- <a href="g.gui.psmap.html">g.gui.psmap</a>,
- <a href="g.gui.vdigit.html">g.gui.vdigit</a>
+<a href="http://grass.osgeo.org/gdp/landscape/r_le_manual5.pdf">Old r.le suite manual</a>
</em>
+<p>
+<em>
+ <a href="wxGUI.html">wxGUI</a><br>
+ <a href="wxGUI.components.html">wxGUI components</a>
+</em>
+<h2>REFERENCES</h2>
+McGarigal, K., and B. J. Marks. 1995. FRAGSTATS: spatial pattern
+analysis program for quantifying landscape structure. USDA For. Serv.
+Gen. Tech. Rep. PNW-351. (<a href="http://treesearch.fs.fed.us/pubs/3064">PDF</a>)
<h2>AUTHOR</h2>
-Luca Delucchi
+Luca Delucchi<br>
+Rewritten from <em>r.li.setup</em> by Claudio Porta and Lucio Davide Spano
<p>
<i>$Date$</i>
Modified: grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
--- grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -25,7 +25,7 @@
Do not use absolute path names for the <b>output</b> map/file.
If the "moving window" method was selected in <b>r.li.setup</b>, then the
output will be a raster map, otherwise an ASCII file will be generated in
-the <tt>~/.grass7/r.li/output/</tt> folder.
+the <tt>$HOME/.grass7/r.li/output/</tt> folder.
<p>
<!-- TODO: verify next: -->
If the input raster map contains only NULL values it is considered to
Modified: grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html
--- grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -15,7 +15,7 @@
<p>
If the input raster map contains only NULL values then <em>r.li.dominance</em>
Modified: grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
--- grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -23,7 +23,7 @@
<p>
If the input raster map contains only NULL values then <em>r.li.edgedensity</em>
Modified: grass/trunk/raster/r.li/r.li.html
--- grass/trunk/raster/r.li/r.li.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -21,6 +21,7 @@
The <em>r.li</em> suite is a toolset for multiscale analysis of landscape structure.
+<!-- rephrase reference to r.le which is long time ago ...-->
It aims at replacing the <em>r.le</em> suite of modules through a client-server,
multiprocess implementation. External software for quantitative measures of landscape
structure is for example FRAGSTATS (McGarigal and Marks 1995).
@@ -63,29 +64,31 @@
The <em>r.li.daemon</em> module also has a "main" function front-end
which can be run, but it is only a template for development of new
indices so not built by default.
-<!-- mhh ??: -->
+<!-- mhh ??:
The function itself has no meaning, it is only useful as an example and
-for debugging.
+for debugging.
<h2>EXAMPLE</h2>
Calculate a patch density index on the entire 'geology' raster map
in the Spearfish sample dataset, using a 5x5 moving window:
+<!-- TODO: update to new wxGUI: -->
<ol>
<li> CREATE A NEW CONFIGURATION FILE
<ol>
<li> run
- r.li.setup
+ g.gui.rlisetup
</pre></div>
<li> The main <em>r.li.setup</em> window is displayed, click on "New"
<li> The new configuration window is now displayed, enter the
configuration file name (e.g., "my_conf", do not use absolute paths)
- Now it is displayed the new configuration window,
- enter the configuration file name (e.g., "my_conf", do not use absolute paths)
+ Now the new configuration window is displayed.
+ Enter the configuration file name (e.g., "my_conf", do not use absolute paths)
and the name of raster map (e.g., "geology").
The other fields are not needed for this configuration.
<li> Click on "Setup sampling frame", select "Whole map layer" and click "OK"
@@ -202,9 +205,7 @@
<h2>AUTHORS</h2>
-<a href="mailto:porta at cli.di.unipi.it">Claudio Porta</a> and
-<a href="mailto:spano at cli.di.unipi.it">Lucio Davide Spano</a>,
- students of Computer Science
+Claudio Porta and Lucio Davide Spano, students of Computer Science,
University of Pisa (Italy).<br>
Commission from Faunalia Pontedera (PI)<br>
@@ -217,6 +218,6 @@
- <a href="topics.html">Topics index</a>
- <a href="keywords.html">Keywords Index</a>
- <a href="full_index.html">Full index</a>
-<p>© 2003-2014 <a href="http://grass.osgeo.org">GRASS Development Team</a>, GRASS GIS 7.0.svn Reference Manual</p>
+<p>© 2008-2014 <a href="http://grass.osgeo.org">GRASS Development Team</a>, GRASS GIS 7.0.svn Reference Manual</p>
</body>
</html>
Modified: grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html
--- grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -16,7 +16,7 @@
<p>
If the input raster map contains only NULL values then <em>r.li.mpa</em> considers to
Modified: grass/trunk/raster/r.li/r.li.mps/r.li.mps.html
--- grass/trunk/raster/r.li/r.li.mps/r.li.mps.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.mps/r.li.mps.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -15,7 +15,7 @@
<p>
If the input raster contains NULL value cells, <em>r.li.mps</em>
Modified: grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html
--- grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -17,7 +17,7 @@
<p>
If input raster is not full of null values <em>r.li.padcv</em> returns a value >=0 that is PADcv. <br>
If the input raster map contains only NULL values then <em>r.li.padcv</em> returns -1. <br>
Modified: grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html
--- grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -14,7 +14,7 @@
<p>
If the input raster map contains only NULL values then <em>r.li.padrange</em>
Modified: grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html
--- grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -14,7 +14,7 @@
<p>
If input raster is not full of null values <em>r.li.padsd</em> returns a
value >=0 that is PADsd. <br>
Modified: grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
--- grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -13,7 +13,7 @@
<p>
A map of NULL values is considered to have zero patches. <br>
Modified: grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html
--- grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -9,7 +9,7 @@
<p>
<!-- TODO verify: -->
If the input raster map contains only NULL values then it is considered to have zero patch. <br>
Modified: grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html
--- grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -14,7 +14,7 @@
<p>
If the input raster contains NULL value cells, <em>r.li.pielou</em>
returns -1 for these cells. <br>
Modified: grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html
--- grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -16,7 +16,7 @@
<p>
If the input raster map contains only NULL values then <em>r.li.renyi</em>
Modified: grass/trunk/raster/r.li/r.li.richness/r.li.richness.html
--- grass/trunk/raster/r.li/r.li.richness/r.li.richness.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.richness/r.li.richness.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -12,7 +12,7 @@
<p>
If the input raster map contains only NULL values then <em>r.li.richness</em>
Modified: grass/trunk/raster/r.li/r.li.setup/r.li.setup.html
--- grass/trunk/raster/r.li/r.li.setup/r.li.setup.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.setup/r.li.setup.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -1,7 +1,7 @@
<em>r.li.setup</em> creates and shows configuration files for the
-others <em>r.li</em> modules. For a general introduction, see
+other analytical <em>r.li</em> modules. For a general introduction, see
<br>
@@ -49,11 +49,11 @@
rectangles with differents colors (green for the raster map, red for
the sample frame and blue for the sample areas), and other notes
(disposition of sample areas etc). The configuration file is saved
- in <tt>~/.r.li/history/my_conf</tt> (the file name can be defined by
+ in <tt>$HOME/.grass7/r.li/my_conf</tt> (the file name can be defined by
the user). The output can either be a new raster map (in case of
using a "moving window" analysis) or be an ASCII text file (when not
performing a "moving window" analysis) containing the result which
- is then saved to the folder <tt>~/.grass7/r.li/output/</tt>.
+ is then saved to the folder <tt>$HOME/.grass7/r.li/output/</tt>.
<br>
<!-- TODO: applies to all output or only ASCII output?? -->
All dimensions are percentages of raster rows or columns.</li>
@@ -143,18 +143,22 @@
<li><em><b>Close</b></em> module window.</li>
</ol>
+<h2>NOTES</h2>
<h2>EXAMPLES</h2>
+is a raster map:
+<p>
<ul>
-<li> Click on "New"</li>
- <ul>
- <li> Configuration file name: "movwindow7"</li>
- <li> Raster map name to use to select areas: "forests"</li>
- </ul>
+ <li> Configuration file name: "movwindow7"</li>
+ <li> Raster map name to use to select areas: "forests"</li>
</ul>
@@ -166,15 +170,14 @@
<ul>
<li> Define sampling areas: "Moving window", then "OK"</li>
<li> Then click on "Use keyboard to define moving window dimension"</li>
+</ul>
+Select type of shape:
<ul>
- <li>Select type of shape</li>
- <ul>
- <li> [x] Rectangular</li>
- <li> Width size (in cells)?: "7"</li>
- <li> Height size (in cells)?: "7"</li>
- <li> Then "Save settings"</li>
- </ul>
- </ul>
+<li> [x] Rectangular</li>
+<li> Width size (in cells)?: "7"</li>
+<li> Height size (in cells)?: "7"</li>
+<li> Then "Save settings"</li>
</ul>
@@ -183,21 +186,53 @@
<p>
</pre></div>
<br>
-<h2>NOTES</h2>
-Configuration files are raster map independent because areas are saved using
-relative coordinates.
+<ul>
+</ul>
+<ul>
+</ul>
+<ul>
+</ul>
+<br>
+(4.) Close
+<p>
+</pre></div>
+<br>
<h2>SEE ALSO</h2>
<em>
@@ -219,7 +254,7 @@
Claudio Porta and Lucio Davide Spano, students of Computer Science<br>
-Rebuild of <em>r.le.setup</em> from William L. Baker
+Rewritten from <em>r.le.setup</em> by William L. Baker
<p>
<i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html
--- grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -15,7 +15,7 @@
<p>
If the input raster map contains only NULL values then <em>r.li.shannon</em>
Modified: grass/trunk/raster/r.li/r.li.shape/r.li.shape.html
--- grass/trunk/raster/r.li/r.li.shape/r.li.shape.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.shape/r.li.shape.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -8,7 +8,7 @@
<p>
If the input raster map contains only NULL values then <em>r.li.shape</em>
Modified: grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html
--- grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html 2014-02-11 15:15:05 UTC (rev 59001)
+++ grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html 2014-02-11 16:23:59 UTC (rev 59002)
@@ -15,7 +15,7 @@
<p>
If the input raster map contains only NULL values then <em>r.li.simpson</em>
