[GRASS-SVN] r59013 - in grass/trunk/temporal: . t.rast.mapcalc2 t.rast3d.mapcalc2
svn_grass at osgeo.org
Wed Feb 12 13:25:39 PST 2014
Author: huhabla
Date: 2014-02-12 13:25:39 -0800 (Wed, 12 Feb 2014)
New Revision: 59013
Added:
grass/trunk/temporal/t.rast.mapcalc2/
grass/trunk/temporal/t.rast.mapcalc2/Makefile
grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.html
grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.py
grass/trunk/temporal/t.rast.mapcalc2/test.t.rast.mapcalc2.sh
grass/trunk/temporal/t.rast3d.mapcalc2/
grass/trunk/temporal/t.rast3d.mapcalc2/Makefile
grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html
grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.py
grass/trunk/temporal/t.rast3d.mapcalc2/test.t.rast3d.mapcalc2.sh
grass/trunk/temporal/Makefile
New temporal raster algebra modules added.
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile 2014-02-12 21:19:59 UTC (rev 59012)
+++ grass/trunk/temporal/Makefile 2014-02-12 21:25:39 UTC (rev 59013)
@@ -21,6 +21,7 @@
t.rast.univar \
t.rast.list \
t.rast.mapcalc \
+ t.rast.mapcalc2 \
t.rast.neighbors \
t.rast.series \
t.rast.export \
@@ -31,6 +32,7 @@
t.rast3d.list \
t.rast3d.extract \
t.rast3d.mapcalc \
+ t.rast3d.mapcalc2 \
t.rast3d.univar \
t.rename \
t.select \
Added: grass/trunk/temporal/t.rast.mapcalc2/Makefile
--- grass/trunk/temporal/t.rast.mapcalc2/Makefile (rev 0)
+++ grass/trunk/temporal/t.rast.mapcalc2/Makefile 2014-02-12 21:25:39 UTC (rev 59013)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.rast.mapcalc2
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.html
--- grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.html (rev 0)
+++ grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.html 2014-02-12 21:25:39 UTC (rev 59013)
@@ -0,0 +1,344 @@
+<h2>DESCRIPTION</h2>
+t.rast.mapcalc2 performs temporal and spatial map algebra operations on space time raster datasets (STRDS)
+by using the temporal raster algebra.
+<h3>PROGRAM USE</h3>
+The module expects an <b>expression</b> as input parameter in the following form: <br>
+<br>
+<b> "result = expression" </b>
+<br>
+<br>
+The statement structure is similar to r.mapcalc, see <a href="r.mapcalc.html">r.mapcalc</a>.
+Where <b>result</b> represents the name of a space time raster dataset (STRDS)that will
+contain the result of the calculation that is given as <b>expression</b>
+on the right side of the equality sign.
+These expression can be any valid or nested combination of temporal
+operations and spatial overlay or buffer functions that are provided by the temporal algebra. <br>
+The temporal raster algebra works with space time raster datasets only (STRDS).
+The algebra provides methods for map selection from STRDS based on their temporal relations.
+It is also possible to temporally shift maps, to create temporal buffer and to snap time
+instances to create a valid temporal topology. Furthermore expressions can be nested and
+evaluated in conditional statements (if, else statements). Within if-statements the algebra
+provides temporal variables like start time, end time, day of year, time differences or
+number of maps per time interval to build up conditions.
+<br>
+In addition the algebra provides
+a subset of the spatial operations from <a href="r.mapcalc.html">r.mapcalc</a>.
+All these operations can be assigned to STRDS or to the resulting map lists of operations between STRDS.
+<br>
+<br>
+As default, topological relationships between space time datasets will be
+evaluated only temporal. Use the <b>s</b> flag to activate the
+additionally evaluate the spatial topology based on the spatial extents of maps.
+<br>
+<br>
+The expression option must be passed as <b>quoted</b>
+expression, for example: <br>
+<div class="code"><pre>t.rast.mapcalc2 expression="C = A + B" basename=result</pre></div>
+Where <b>C</b> is the new space time raster dataset that will contain maps
+with the basename "result" that represent the sum of maps from STRDS <b>A</b> and
+equally temporal related maps from STRDS <b>B</b>.
+<br>
+<br>
+The map basename for the result STRDS must always be specified.
+<h2>Temporal raster algebra</h2>
+The temporal raster algebra provides a wide range of temporal and spatial operators and
+functions that will be presented in the following section. <br>
+<br>
+<h3>Temporal relations</h3>
+Several temporal topology relations between space
+time datasets are supported: <br>
+equals A ------
+ B ------
+during A ----
+ B ------
+contains A ------
+ B ----
+starts A ----
+ B ------
+started A ------
+ B ----
+finishs A ----
+ B ------
+finished A ------
+ B ----
+precedes A ----
+ B ----
+follows A ----
+ B ----
+overlapped A ------
+ B ------
+overlaps A ------
+ B ------
+over booth overlaps and overlapped
+</pre></div>
+The relations must be read as: A is related to B, like - A equals B - A is
+during B - A contains B <br>
+<br>
+Topological relations must be specified in {} parentheses. <br>
+<h3>Temporal Selection</h3>
+The temporal selection simply selects parts of a space time dataset without
+processing raster or vector data.
+The algebra provides a selection operator <b>:</b> that selects parts
+of a space time dataset that are temporally equal to parts of a second one
+by default. The following expression
+C = A : B
+</pre></div>
+means: Select all parts of space time dataset A that are equal to B and store
+it in space time dataset C. The parts are time stamped maps. <br>
+<br>
+In addition the inverse selection operator <b>!:</b> is defined as the complement of
+the selection operator, hence the following expression
+C = A !: B
+</pre></div>
+means: select all parts of space time time dataset A that are not equal to B
+and store it in space time dataset (STDS) C. <br>
+<br>
+To select parts of a STDS by different topological relations to other STDS,
+the temporal topology selection operator can be used. The operator consists of
+topological relations, that must be separated by the logical OR operator
+<b>|</b> and the temporal selection operator. Both parts are separated by
+comma and surrounded by curly braces:
+{"topological relations", "temporal selection operator"} <br>
+<br>
+Examples:
+C = A {equals,:} B
+C = A {equals,!:} B
+</pre></div>
+We can now define arbitrary topological relations using logical OR operator
+to connect them:
+C = A {equals|during|overlaps,:} B
+</pre></div>
+Select all parts of A that are equal to B, during B or overlaps B. <br>
+<br>
+The selection operator is implicitly contained in the temporal topology
+selection operator, so that the following statements are exactly the same:
+C = A : B
+C = A {:} B
+C = A {equal,:} B
+</pre></div>
+Same for the complementary selection:
+C = A !: B
+C = A {!:} B
+C = A {equal,!:} B
+</pre></div>
+<h3>Conditional statements</h3>
+Selection operations can be evaluated within conditional statements.
+<br>
+Note A and B can either be space time datasets or expressions.
+if statement decision option temporal relations
+ if(if, then, else)
+ if(conditions, A) A if conditions are True; temporal topological relation between if and then is equal.
+ if(conditions, A, B) A if conditions are True, B otherwise; temporal topological relation between if, then and else is equal.
+ if(topologies, conditions, A) A if conditions are True; temporal topological relation between if and then is explicit specified by topologies.
+ if(topologies, conditions, A, B) A if conditions are True, B otherwise; temporal topological relation between if, then and else is explicit specified by topologies.
+</pre></div>
+The conditions are comparison expressions that are used to evaluate
+space time datasets. Specific values of temporal variables are
+compared by logical operators and evaluated for each map of the STDS.
+<br>
+<br>
+The supported logical operators:
+Symbol description
+ == equal
+ != not equal
+ > greater than
+ >= greater than or equal
+ < less than
+ <= less than or equal
+ && and
+ || or
+</pre></div>
+Temporal functions: <br>
+td(A) Returns a list of time intervals of STDS A
+start_time() Start time as HH::MM:SS
+start_date() Start date as yyyy-mm-DD
+start_datetime() Start datetime as yyyy-mm-DD HH:MM:SS
+end_time() End time as HH:MM:SS
+end_date() End date as yyyy-mm-DD
+end_datetime() End datetime as yyyy-mm-DD HH:MM
+start_doy() Day of year (doy) from the start time [1 - 366]
+start_dow() Day of week (dow) from the start time [1 - 7], the start of the week is Monday == 1
+start_year() The year of the start time [0 - 9999]
+start_month() The month of the start time [1 - 12]
+start_week() Week of year of the start time [1 - 54]
+start_day() Day of month from the start time [1 - 31]
+start_hour() The hour of the start time [0 - 23]
+start_minute() The minute of the start time [0 - 59]
+start_second() The second of the start time [0 - 59]
+end_doy() Day of year (doy) from the end time [1 - 366]
+end_dow() Day of week (dow) from the end time [1 - 7], the start of the week is Monday == 1
+end_year() The year of the end time [0 - 9999]
+end_month() The month of the end time [1 - 12]
+end_week() Week of year of the end time [1 - 54]
+end_day() Day of month from the start time [1 - 31]
+end_hour() The hour of the end time [0 - 23]
+end_minute() The minute of the end time [0 - 59]
+end_second() The second of the end time [0 - 59]
+</pre></div>
+Additionally the number of maps in intervals can be computed and
+used in conditional statements. <br>
+The operator to count the number of maps
+is the hash <b>#</b>.
+A{contains,#}B
+</pre></div>
+This expression computes the number of maps from space
+time dataset B which are during the time intervals of maps from
+space time dataset A.<br>
+A list of integers (scalars) corresponding to the maps of A
+that contain maps from B will be returned. <br>
+<br>
+Furthermore the temporal algebra allows temporal buffering, shifting
+and snapping with the functions buff_t(), tshift() and tsnap()
+respectively.
+buff_t(A, size) Buffer STDS A with granule ("1 month" or 5)
+tshift(A, size) Shift STDS A with granule ("1 month" or 5)
+tsnap(A) Snap time instances and intervals of STDS A
+</pre></div>
+<h3>Temporal Operators</h3>
+<p>
+The temporal algebra defines temporal operators that can be combined
+later with spatial operators to perform spatio-temporal operations.
+The temporal operators process the time instances and intervals of temporal related maps.
+</p>
+AND & Intersection
+OR | Union
+DISJOINT OR + Disjoint union
+LEFT REFERENCE = Use the time stamp of the left space time dataset
+</pre></div><p>
+For example we can compute the intersection, union or disjoint union from time stamps of maps
+that temporally overlap, or we can just keep the time stamp of the left STDS.
+</p>
+<h3>Spatial raster operators</h3>
+The module supports the following raster operations: <br>
+Symbol description precedence
+ % modulus 1
+ / division 1
+ * multiplication 1
+ + addition 2
+ - subtraction 2
+</pre></div>
+And raster functions:
+abs(x) return absolute value of x
+foat(x) convert x to foating point
+if decision options:
+ if(x) 1 if x not zero, 0 otherwise
+ if(x,a) a if x not zero, 0 otherwise
+ if(x,a,b) a if x not zero, b otherwise
+int(x) convert x to integer [ truncates ]
+log(x) natural log of x
+sqrt(x) square root of x
+tan(x) tangent of x (x is in degrees)
+round(x) round x to nearest integer
+sin(x) sine of x (x is in degrees)
+isnull(x) check if x = NULL
+</pre></div>
+<br>
+<p>
+<h3>Combinations of temporal, raster and select operators</h3>
+We combine the temporal topology relations, the temporal operators and the spatial/select operators to create spatio-temporal operators:
+{"list of temporal relations", "temporal operator" "spatial or select operator"}
+</pre></div>
+<p>
+The spatial and the select operators can be used stand-alone.
+In this case the temporal topology relation "equal" and the temporal operator
+"left reference =" is assumed and used as default. This allows the convenient use of the spatial and select
+operators in case of space time raster datasets with equal time stamps.
+</p>
+<div class="code"> <pre>
+</pre></div>
+<h3>Examples: </h3>
+Sum maps from space time dataset A with maps from space time dataset
+B which have equal time stamps and are temporary before Jan. 1. 2005 and
+store them in space time dataset D.
+D = if(start_date() < "2005-01-01", A + B)
+</pre></div>
+<h2>REFERENCES</h2>
+<tt><a href="http://www.dabeaz.com/ply/">PLY(Python-Lex-Yacc)</a></tt>
+<h2>SEE ALSO</h2>
+<em>
+<a href="t.rast.mapcalc.html">t.rast.mapcalc2</a>
+<a href="r.mapcalc.html">r.mapcalc</a>
+<a href="t.vect.mapcalc.html">t.vect.mapcalc</a>
+<a href="t.select.html">t.select</a>
+<a href="t.rast3d.mapcalc.html">t.rast3d.mapcalc</a>
+</em>
+<h2>AUTHOR</h2>
+Thomas Leppelt, Soeren Gebbert, Thuenen Institut, Germany <br>
+<p><i>Last changed: $Date: 2013-07-24 17:35:20 +0100 (Thu, 24 Jul 2013) $</i>
Added: grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.py
--- grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.py (rev 0)
+++ grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.py 2014-02-12 21:25:39 UTC (rev 59013)
@@ -0,0 +1,81 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.rast.mapcal2c
+# AUTHOR(S): Thomas Leppelt, Soeren Gebbert
+# PURPOSE: Provide temporal raster algebra to perform spatial an temporal operations
+# for space time datasets by topological relationships to other space time
+# datasets.
+# COPYRIGHT: (C) 2014 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Apply temporal and spatial oeprations on space time raster datasets using temporal raster algebra.
+#% keywords: temporal
+#% keywords: mapalgebra
+#%end
+#%option
+#% key: expression
+#% type: string
+#% description: The mapcalc expression for temporal and spatial analysis of space time raster datasets.
+#% key_desc: expression
+#% required : yes
+#%end
+#%option
+#% key: basename
+#% type: string
+#% description: The basename of raster maps that are stored within the result space time raster dataset.
+#% key_desc: basename
+#% required : yes
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: Number of r.mapcalc processes to run in parallel
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%flag
+#% key: s
+#% description: Activate spatial topology.
+#%end
+import grass.script
+import grass.temporal as tgis
+import sys
+def main():
+ expression = options['expression']
+ basename = options['basename']
+ nprocs = options["nprocs"]
+ spatial = flags["s"]
+ # Check for PLY istallation
+ try:
+ import ply.lex as lex
+ import ply.yacc as yacc
+ except:
+ grass.script.fatal(_("Please install PLY (Lex and Yacc Python implementation) to use the temporal algebra modules. "
+ "You can use t.rast.mapcalc that provides a limited but useful alternative to "
+ "t.rast.mapcalc2 without PLY requirement."))
+ tgis.init(True)
+ p = tgis.TemporalRasterAlgebraParser(run = True, debug=False, spatial = spatial, nprocs = nprocs)
+ p.parse(expression, basename, grass.script.overwrite())
+if __name__ == "__main__":
+ options, flags = grass.script.parser()
+ sys.exit(main())
Added: grass/trunk/temporal/t.rast.mapcalc2/test.t.rast.mapcalc2.sh
--- grass/trunk/temporal/t.rast.mapcalc2/test.t.rast.mapcalc2.sh (rev 0)
+++ grass/trunk/temporal/t.rast.mapcalc2/test.t.rast.mapcalc2.sh 2014-02-12 21:25:39 UTC (rev 59013)
@@ -0,0 +1,47 @@
+#!/bin/sh
+# Test for t.rast.mapcalc2
+export GRASS_OVERWRITE=1
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create several space time raster datasets
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc expr="a1 = rand(0, 550)"
+r.mapcalc expr="a2 = rand(0, 450)"
+r.mapcalc expr="a3 = rand(0, 320)"
+r.mapcalc expr="a4 = rand(0, 510)"
+r.mapcalc expr="a5 = rand(0, 300)"
+r.mapcalc expr="a6 = rand(0, 650)"
+t.create type=strds temporaltype=absolute output=A1 title="A test" descr="A test"
+t.create type=strds temporaltype=absolute output=A2 title="A test" descr="A test"
+t.register -i type=rast input=A1 maps=a1,a2,a3,a4,a5,a6 start="2001-01-01" increment="3 months"
+t.register type=rast input=A2 maps=a1,a2,a3,a4,a5,a6
+t.info A1
+t.info A2
+# The first @test
+t.rast.mapcalc2 --v expression="B = A1 + A2" base=b nprocs=5
+t.info type=strds input=B
+t.rast.mapcalc2 --v expression="B = if(start_year()>=0&&start_month()>=0&&start_day()>=0&&start_hour()>=0&&start_minute()>=0&&start_second()>=0, A1 + A2) " base=b nprocs=5
+t.rast.mapcalc2 --v expression="B = if(end_year()>=0&&end_month()>=0&&end_day()>=0&&end_hour()>=0&&end_minute()>=0&&end_second()>=0, A1 + A2) " base=b nprocs=5
+t.rast.mapcalc2 --v expression="B = if(start_doy() >= 0 && start_dow() >= 0, A1 + A2) " base=b nprocs=5
+t.rast.mapcalc2 --v expression="B = if(end_doy() >= 0 && end_dow() >= 0, A1 + A2) " base=b nprocs=5
+t.rast.mapcalc2 --v expression="B = A1[-1] + A2[1] " base=b nprocs=5
+# @postprocess
+t.remove -rf type=strds input=A1,A2,B
Property changes on: grass/trunk/temporal/t.rast.mapcalc2/test.t.rast.mapcalc2.sh
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/t.rast3d.mapcalc2/Makefile
--- grass/trunk/temporal/t.rast3d.mapcalc2/Makefile (rev 0)
+++ grass/trunk/temporal/t.rast3d.mapcalc2/Makefile 2014-02-12 21:25:39 UTC (rev 59013)
@@ -0,0 +1,7 @@
+PGM = t.rast3d.mapcalc2
+default: script
Added: grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html
--- grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html (rev 0)
+++ grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html 2014-02-12 21:25:39 UTC (rev 59013)
@@ -0,0 +1,35 @@
+t.rast3d.mapcalc2 performs temporal and spatial map algebra operations on space time 3D raster datasets (STR3DS)
+<br>
+<br>
+<br>
+The statement structure is exact the same as of t.rast.mapcalc2, please study <a href="t.rast.mapcalc2.html">t.rast.mapcalc2</a>.
+<h2>SEE ALSO</h2>
+<em>
+<a href="t.rast.mapcalc2.html">t.rast.mapcalc2</a>
+</em>
+<h2>AUTHOR</h2>
Added: grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.py
--- grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.py (rev 0)
+++ grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.py 2014-02-12 21:25:39 UTC (rev 59013)
@@ -0,0 +1,81 @@
+# MODULE: t.rast3d.mapcalc2
+# PURPOSE: Provide temporal 3D raster algebra to perform spatial an temporal operations
+# datasets.
+# for details.
+#%module
+#% description: Apply temporal and spatial oeprations on space time 3D raster datasets using temporal raster algebra.
+#%end
+#%option
+#% key: expression
+#% type: string
+#% description: The mapcalc expression for temporal and spatial analysis of space time 3D raster datasets.
+#% required : yes
+#%end
+#%option
+#% key: basename
+#% type: string
+#% description: The basename of raster maps that are stored within the result space time 3D raster dataset.
+#% required : yes
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: Number of r3.mapcalc processes to run in parallel
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%flag
+#% key: s
+#%end
+import sys
+def main():
+ try:
+ except:
+ "You can use t.rast3d.mapcalc that provides a limited but useful alternative to "
+ "t.rast3d.mapcalc2 without PLY requirement."))
+ tgis.init(True)
+ p = tgis.TemporalRaster3DAlgebraParser(run = True, debug=False, spatial = spatial, nprocs = nprocs)
+ sys.exit(main())
Added: grass/trunk/temporal/t.rast3d.mapcalc2/test.t.rast3d.mapcalc2.sh
--- grass/trunk/temporal/t.rast3d.mapcalc2/test.t.rast3d.mapcalc2.sh (rev 0)
+++ grass/trunk/temporal/t.rast3d.mapcalc2/test.t.rast3d.mapcalc2.sh 2014-02-12 21:25:39 UTC (rev 59013)
@@ -0,0 +1,47 @@
+#!/bin/sh
+# Test for t.rast3d.mapcalc2
+# raster with r3.mapcalc and create several space time raster datasets
+r3.mapcalc expr="a1 = rand(0, 550)"
+r3.mapcalc expr="a2 = rand(0, 450)"
+r3.mapcalc expr="a3 = rand(0, 320)"
+r3.mapcalc expr="a4 = rand(0, 510)"
+r3.mapcalc expr="a5 = rand(0, 300)"
+r3.mapcalc expr="a6 = rand(0, 650)"
+t.create type=str3ds temporaltype=absolute output=A1 title="A test" descr="A test"
+t.create type=str3ds temporaltype=absolute output=A2 title="A test" descr="A test"
+t.register -i type=rast3d input=A1 maps=a1,a2,a3,a4,a5,a6 start="2001-01-01" increment="3 months"
+t.register type=rast3d input=A2 maps=a1,a2,a3,a4,a5,a6
+t.info type=str3ds input=A1
+t.info type=str3ds input=A2
+# The first @test
+t.rast3d.mapcalc2 --v expression="B = A1 + A2" base=b nprocs=5
+t.info type=str3ds input=B
+t.rast3d.mapcalc2 --v expression="B = if(start_year()>=0&&start_month()>=0&&start_day()>=0&&start_hour()>=0&&start_minute()>=0&&start_second()>=0, A1 + A2) " base=b nprocs=5
+t.rast3d.mapcalc2 --v expression="B = if(end_year()>=0&&end_month()>=0&&end_day()>=0&&end_hour()>=0&&end_minute()>=0&&end_second()>=0, A1 + A2) " base=b nprocs=5
+t.rast3d.mapcalc2 --v expression="B = if(start_doy() >= 0 && start_dow() >= 0, A1 + A2) " base=b nprocs=5
+t.rast3d.mapcalc2 --v expression="B = if(end_doy() >= 0 && end_dow() >= 0, A1 + A2) " base=b nprocs=5
+t.rast3d.mapcalc2 --v expression="B = A1[-1] + A2[1] " base=b nprocs=5
+# @postprocess
+t.remove -rf type=str3ds input=A1,A2,B
Property changes on: grass/trunk/temporal/t.rast3d.mapcalc2/test.t.rast3d.mapcalc2.sh
