[GRASS-SVN] r59027 - grass/trunk/gui/wxpython/mapdisp
svn_grass at osgeo.org
Thu Feb 13 15:23:34 PST 2014
Author: annakrat
Date: 2014-02-13 15:23:34 -0800 (Thu, 13 Feb 2014)
New Revision: 59027
grass/trunk/gui/wxpython/mapdisp/frame.py
wxGUI/legend: fix various problems related to updating legend with different map
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2014-02-13 16:01:32 UTC (rev 59026)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2014-02-13 23:23:34 UTC (rev 59027)
@@ -364,7 +364,7 @@
self.MapWindow3D.UpdateView(None)
self.MapWindow3D.overlayActivated.connect(self._activateOverlay)
self.MapWindow3D.overlayHidden.connect(self._hideOverlay)
- self.legend.overlayChanged.connect(lambda: self.MapWindow3D.UpdateOverlays())
+ self.legend.overlayChanged.connect(self.MapWindow3D.UpdateOverlays)
else:
self.MapWindow = self.MapWindow3D
os.environ['GRASS_REGION'] = self.Map.SetRegion(windres = True, windres3 = True)
@@ -431,6 +431,7 @@
# TODO: here we end because self.MapWindow3D is None for a while
self._giface.updateMap.disconnect(self.MapWindow3D.UpdateMap)
self._giface.updateMap.connect(self.MapWindow2D.UpdateMap)
+ self.legend.overlayChanged.disconnect(self.MapWindow3D.UpdateOverlays)
self.MapWindow.UpdateMap()
self._mgr.Update()
@@ -988,7 +989,7 @@
if overlayId > 100:
self.OnAddText(None)
elif overlayId == 0:
- self.AddLegend(showDialog=True)
+ self.AddLegend(cmd=self.legend.cmd, showDialog=True)
elif overlayId == 1:
self.AddBarscale(showDialog=True)
elif overlayId == 2:
@@ -1051,7 +1052,20 @@
layers = self._giface.GetLayerList().GetSelectedLayers()
for layer in layers:
if layer.type == 'raster':
- self.legend.cmd.append('map=%s' % layer.maplayer.name)
+ isMap = False
+ # replace map
+ for i, legendParam in enumerate(self.legend.cmd[1:]):
+ idx = i + 1
+ param, val = legendParam.split('=')
+ if param == 'map':
+ self.legend.cmd[idx] = 'map={rast}'.format(rast=layer.maplayer.name)
+ isMap = True
+ elif param in ('use', 'range'):
+ # clear range or use to avoid problems
+ del self.legend.cmd[idx]
+ if not isMap: # for the first time
+ self.legend.cmd.append('map=%s' % layer.maplayer.name)
break
if not showDialog and self.legend.CmdIsValid():
@@ -1059,13 +1073,15 @@
return
# Decoration overlay control dialog
+ # always create new one to avoid problem when switching between maps
if self.legend.dialog:
if self.legend.dialog.IsShown():
self.legend.dialog.SetFocus()
self.legend.dialog.Raise()
else:
- self.legend.dialog.Show()
- else:
+ self.legend.dialog.Destroy()
+ self.legend.dialog = None
+ if not self.legend.dialog:
GUI(parent=self, giface=self._giface, show=True,
modal=False).ParseCommand(self.legend.cmd,
completed=(self.legend.GetOptData, None, None))
