[GRASS-SVN] r59033 - grass/trunk/raster/r.profile
Fri Feb 14 00:53:41 PST 2014
Author: hamish
Date: 2014-02-14 00:53:41 -0800 (Fri, 14 Feb 2014)
New Revision: 59033
   grass/trunk/raster/r.profile/input.c
   grass/trunk/raster/r.profile/local_proto.h
   grass/trunk/raster/r.profile/main.c
   grass/trunk/raster/r.profile/r.profile.html
add option to read from a file, stdin usage moved to coord file called '-'
Modified: grass/trunk/raster/r.profile/input.c
--- grass/trunk/raster/r.profile/input.c	2014-02-14 04:51:02 UTC (rev 59032)
+++ grass/trunk/raster/r.profile/input.c	2014-02-14 08:53:41 UTC (rev 59033)
@@ -6,7 +6,8 @@
 #include "local_proto.h"
-int input(char *blank1, char *word1, char *blank2, char *word2, char *rest)
+int input(char *blank1, char *word1, char *blank2, char *word2, char *rest,
+	  FILE *infile)
     char buf[1024];
     char *b, *w1, *w2;
@@ -18,7 +19,7 @@
     *blank1 = *blank2 = 0;
     *word1 = *word2 = *rest = 0;
-    if (!fgets(buf, 1024, stdin)) {
+    if (!fgets(buf, 1024, infile)) {
 	*buf = 0;
 	return 0;
Modified: grass/trunk/raster/r.profile/local_proto.h
--- grass/trunk/raster/r.profile/local_proto.h	2014-02-14 04:51:02 UTC (rev 59032)
+++ grass/trunk/raster/r.profile/local_proto.h	2014-02-14 08:53:41 UTC (rev 59033)
@@ -14,7 +14,7 @@
 	      char *);
 /* input.c */
-int input(char *, char *, char *, char *, char *);
+int input(char *, char *, char *, char *, char *, FILE *);
 extern int clr;
 extern struct Colors colors;
Modified: grass/trunk/raster/r.profile/main.c
--- grass/trunk/raster/r.profile/main.c	2014-02-14 04:51:02 UTC (rev 59032)
+++ grass/trunk/raster/r.profile/main.c	2014-02-14 08:53:41 UTC (rev 59033)
@@ -24,7 +24,7 @@
     char *name, *outfile;
     int fd, projection;
-    FILE *fp;
+    FILE *fp, *coor_fp;
     double res;
     char *null_string;
     char ebuf[256], nbuf[256], label[512], formatbuff[256];
@@ -37,7 +37,7 @@
     struct Cell_head window;
     struct
-	struct Option *opt1, *profile, *res, *output, *null_str;
+	struct Option *opt1, *profile, *res, *output, *null_str, *coord_file;
 	struct Flag *g, *c;
     parm;
@@ -66,11 +66,16 @@
     parm.profile->required = NO;
     parm.profile->multiple = YES;
     parm.profile->key_desc = "east,north";
-    parm.profile->label = _("Profile coordinate pairs");
-    parm.profile->description =
-	_("If no coordinate pairs are specified, "
-	  "coordinates at standard input are expected.");
+    parm.profile->description = _("Profile coordinate pairs");
+    parm.coord_file = G_define_standard_option(G_OPT_F_INPUT);
+    parm.coord_file->key = "coordinate_file";
+    parm.coord_file->label =
+	_("Name of input file containing coordinate pairs");
+    parm.coord_file->description =
+	_("Use instead of the 'profile' option. \"-\" reads from stdin.");
+    parm.coord_file->required = NO;
     parm.res = G_define_option();
     parm.res->key = "res";
     parm.res->type = TYPE_DOUBLE;
@@ -106,6 +111,11 @@
     null_string = parm.null_str->answer;
+    if ((parm.profile->answer && parm.coord_file->answer) ||
+	(!parm.profile->answer && !parm.coord_file->answer))
+	G_fatal_error(_("Either use profile option or coordinate_file "
+			" option, but not both"));
     G_get_window(&window);
     projection = G_projection();
     if (parm.res->answer) {
@@ -161,9 +171,17 @@
     G_message(formatbuff);
     /* Get Profile Start Coords */
-    if (!parm.profile->answer) {
-	/* Assume input from stdin */
-	for (n = 1; input(b1, ebuf, b2, nbuf, label); n++) {
+    if (parm.coord_file->answer) {
+	if (strcmp("-", parm.coord_file->answer) == 0)
+	    coor_fp = stdin;
+	else
+	    coor_fp = fopen(parm.coord_file->answer, "r");
+	if (coor_fp == NULL)
+	    G_fatal_error(_("Could not open <%s>"), parm.coord_file->answer);
+	for (n = 1; input(b1, ebuf, b2, nbuf, label, coor_fp); n++) {
 	    G_debug(4, "stdin line %d: ebuf=[%s]  nbuf=[%s]", n, ebuf, nbuf);
 	    if (!G_scan_easting(ebuf, &e2, G_projection()) ||
 		!G_scan_northing(nbuf, &n2, G_projection()))
@@ -176,9 +194,12 @@
 	    n1 = n2;
 	    havefirst = TRUE;
+	if (coor_fp != stdin)
+	    fclose(coor_fp);
     else {
-	/* Coords from Command Line */
+	/* Coords given on the Command Line using the profile= option */
 	for (i = 0; parm.profile->answers[i]; i += 2) {
 	    /* Test for number coordinate pairs */
 	    k = i;
Modified: grass/trunk/raster/r.profile/r.profile.html
--- grass/trunk/raster/r.profile/r.profile.html	2014-02-14 04:51:02 UTC (rev 59032)
+++ grass/trunk/raster/r.profile/r.profile.html	2014-02-14 08:53:41 UTC (rev 59033)
@@ -11,8 +11,10 @@
 <p>The <b>profile</b> parameter can be set to comma separated geographic
 coordinates for profile line endpoints.
-Alternatively the coordinate pairs can be piped
-from stdin, one comma separated pair per line.
+Alternatively the coordinate pairs can be piped from the text file specified
+by <b>coordinate_file</b> option, or if set to "-", from <tt>stdin</tt>.
+In these cases the coordinate pairs should be given one comma separated pair
+per line.
 <p>The <b>res</b> parameter sets the distance between each profile point
 (resolution). The resolution must be provided in GRASS database units (i.e.
@@ -39,6 +41,7 @@
 <p>The optional RGB output provides the associated GRASS colour value for
 each profile point.
 <h2>EXAMPLES</h2>
 <b>Example 1</b><br>
@@ -52,6 +55,7 @@
 <p><br>
+<!-- d.where no longer there
 <b>Example 2</b><br>
 Extract a profile with coordinates provided from standard input or an external file:
 <p>First create a points file with <em><a href="d.where.html">d.where</a></em>
@@ -75,14 +79,13 @@
 <div class="code"><pre>
 d.where | r.profile elevation.dem
 </pre></div>
 <p><br>
-<b>Example 3</b><br>
+<b>Example 2</b><br>
 Pipe coordinates into r.profile
-r.profile elevation.dem res=1000 << EOF
+r.profile elevation.dem res=1000 coordinate_file=- << EOF
  591243,4926344
  592509,4922156
  594100,4920793
@@ -109,6 +112,7 @@
 This filters out the everything except the numbers.
 <h2>SEE ALSO</h2>
 <em>
@@ -120,7 +124,9 @@
 <a href="wxGUI.html">wxGUI profile tool</a>
 </em>
 <h2>AUTHOR</h2>
 <a href="mailto:bcovill at tekmap.ns.ca">Bob Covill</a>
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
