[GRASS-SVN] r59059 - in grass/branches/develbranch_6: db/drivers/mysql lib/db/sqlp
svn_grass at osgeo.org
Sat Feb 15 14:26:46 PST 2014
Author: neteler
Date: 2014-02-15 14:26:46 -0800 (Sat, 15 Feb 2014)
New Revision: 59059
grass/branches/develbranch_6/db/drivers/mysql/grass-mesql.html
grass/branches/develbranch_6/db/drivers/mysql/grass-mysql.html
grass/branches/develbranch_6/lib/db/sqlp/description.html
sql.html, MySQL manual: explain syntax error in case of using a reserved SQL word (help for trac #2184)
Modified: grass/branches/develbranch_6/db/drivers/mysql/grass-mesql.html
--- grass/branches/develbranch_6/db/drivers/mysql/grass-mesql.html 2014-02-15 22:25:23 UTC (rev 59058)
+++ grass/branches/develbranch_6/db/drivers/mysql/grass-mesql.html 2014-02-15 22:26:46 UTC (rev 59059)
@@ -1,7 +1,7 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
-<title>GRASS-MySQL embedded driver</title>
+<title>GRASS GIS manual: GRASS-MySQL embedded driver</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link rel="stylesheet" href="grassdocs.css" type="text/css">
</head>
@@ -12,6 +12,11 @@
<!-- meta page description: MySQL embedded driver -->
<h1>MySQL embedded driver in GRASS</h1>
+<h2>KEYWORDS</h2>
+database, attribute table, driver
+<h2>DESCRIPTION</h2>
MySQL database driver in GRASS enables GRASS to store vector
attributes in MySQL embedded database without necessity
to run MySQL server.
@@ -52,6 +57,12 @@
option to avoid warning about missing
"mysql.time_zone_leap_second table". This can be fixed in future.
+<h2>Troubleshooting: SQL syntax error</h2>
+Attempting to use a reserved SQL word as column or table name will result
+in a "SQL syntax" error. The list of reserved words for MySQL can be
+found in the <a href="http://dev.mysql.com/doc/refman/5.7/en/reserved-words.html#table-reserved-words-5.7.4">MySQL manual</a>.
<h2>SEE ALSO</h2>
<em>
Modified: grass/branches/develbranch_6/db/drivers/mysql/grass-mysql.html
--- grass/branches/develbranch_6/db/drivers/mysql/grass-mysql.html 2014-02-15 22:25:23 UTC (rev 59058)
+++ grass/branches/develbranch_6/db/drivers/mysql/grass-mysql.html 2014-02-15 22:26:46 UTC (rev 59059)
@@ -1,7 +1,7 @@
<html>
<head>
-<title>GRASS-MySQL driver</title>
+<title>GRASS GIS manual: GRASS-MySQL driver</title>
</head>
@@ -12,6 +12,11 @@
<!-- meta page description: MySQL driver -->
<h1>MySQL driver in GRASS</h1>
+<h2>KEYWORDS</h2>
attributes in MySQL server.
<p>
@@ -105,6 +110,12 @@
by 'group' parameter of module db.connect are ignored by
GRASS for MySQL driver.
<h2>SEE ALSO</h2>
<em>
Modified: grass/branches/develbranch_6/lib/db/sqlp/description.html
--- grass/branches/develbranch_6/lib/db/sqlp/description.html 2014-02-15 22:25:23 UTC (rev 59058)
+++ grass/branches/develbranch_6/lib/db/sqlp/description.html 2014-02-15 22:26:46 UTC (rev 59059)
@@ -15,13 +15,15 @@
<!-- meta page description: SQL support introduction -->
<h2>SQL support in GRASS GIS</h2>
-GRASS can use various RDBMS and embedded databases.
-SQL queries are directly passed to the underlying
-database system.
-The set of supported SQL commands depends on the RDMBS
-and driver selected.
+GRASS can use various RDBMS
+(<a href="http://en.wikipedia.org/wiki/Relational_database_management_system">Relational
+database management system</a>) and embedded databases. SQL
+(<a href="http://en.wikipedia.org/wiki/Sql">Structured Query
+Language</a>) queries are directly passed to the underlying database
+system. The set of supported SQL commands depends on the RDMBS and
+database driver selected.
-<h2>Drivers</h2>
+<h2>Database drivers</h2>
The list of available drivers can vary in various binary
distributions of GRASS.
<p>
@@ -44,16 +46,14 @@
<tr><td><a href="grass-odbc.html">odbc</a></td><td>UnixODBC. (PostgreSQL, Oracle, etc.)</td>
<td><a href="http://www.unixodbc.org/">http://www.unixodbc.org/</a></td></tr>
</table>
<h2>NOTES</h2>
<ul>
<li> SQL does not support '.' (dots) in table names.
-<li> Supported table name characters are only:<br>
- [A-Za-z][A-Za-z0-9_]*
+<li> Supported table name characters are only: <br>
+<div class="code"><pre>[A-Za-z][A-Za-z0-9_]*</pre></div>
<li> A table name must start with a character, not a number.
<li> Text-string matching requires the text part to be 'single quoted'.
When run from the command line multiple queries should be contained
@@ -61,22 +61,31 @@
d.vect map where="individual='juvenile' and area='beach'"
</pre></div>
-<li> An error message such as "dbmi: Protocol error" either indicates an invalid column name
- or an unsupported column type (then the GRASS SQL parser needs to be extended).
-<li> DBF column names are limited to 10 characters (DBF API definition)
+<li> An error message such as "<tt>dbmi: Protocol
+ error</tt>" either indicates an invalid column name or an
+ unsupported column type (then the GRASS SQL parser needs to be
+ extended).</li>
+<li> DBF column names are limited to 10 characters (DBF API definition).</li>
+<li> Attempts to use a reserved SQL word (depends on database backend) as
+ column or table name will cause a "SQL syntax error".</li>
</ul>
<h2>EXAMPLES</h2>
-Display all vector points except for LAMAR valley and <i>extensive trapping</i> (brackets are superfluous in this example):
+Display all vector points except for <i>LAMAR</i> valley
+and <i>extensive trapping</i> (brackets are superfluous in this
+example):
d.vect trapping_sites_points fcol=black icon=basic/diamond col=white size=13 \
where="valley <> 'LAMAR' OR (valley = 'LAMAR' AND description = 'extensive trapping')"
</pre></div>
<p>
-Select all attributes from table where str1 column values are not 'No Name':
+Select all attributes from table where <i>str1</i> column values are not 'No
+Name':
echo "SELECT * FROM archsites WHERE str1 <> 'No Name'" | db.select
</pre></div>
@@ -162,6 +171,9 @@
<h2>SEE ALSO</h2>
<em>
+<a href="db.select.html">db.select</a>,
+<a href="db.execute.html">db.execute</a>,
+<a href="v.db.select.html">v.db.select</a>,
<a href="v.db.update.html">v.db.update</a>
</em>
<p>
@@ -178,6 +190,6 @@
<a href="index.html">Main index</a> -
<a href="database.html">database index</a> -
<a href="full_index.html">full index</a>
-<p>© 2008-2012 <a href="http://grass.osgeo.org">GRASS Development Team</a>
+<p>© 2008-2014 <a href="http://grass.osgeo.org">GRASS Development Team</a>
</body>
</html>
