[GRASS-SVN] r59076 - grass/trunk/raster/r.clump
svn_grass at osgeo.org
Mon Feb 17 12:12:22 PST 2014
Author: mmetz
Date: 2014-02-17 12:12:22 -0800 (Mon, 17 Feb 2014)
New Revision: 59076
grass/trunk/raster/r.clump/clump.c
r.clump: do not clump NULL data; slight speed-up
Modified: grass/trunk/raster/r.clump/clump.c
--- grass/trunk/raster/r.clump/clump.c 2014-02-17 19:47:13 UTC (rev 59075)
+++ grass/trunk/raster/r.clump/clump.c 2014-02-17 20:12:22 UTC (rev 59076)
@@ -29,7 +29,7 @@
register int col;
register CELL *prev_clump, *cur_clump;
- register CELL *index;
+ register CELL *index, *index2;
register int n;
CELL *prev_in, *cur_in;
CELL *temp_cell, *temp_clump, *out_cell;
@@ -43,14 +43,14 @@
long cur_time;
int column;
nrows = Rast_window_rows();
ncols = Rast_window_cols();
- /* allocate reclump index */
+ /* allocate clump index */
nalloc = INCR;
index = (CELL *) G_malloc(nalloc * sizeof(CELL));
index[0] = 0;
+ index2 = NULL;
/* allocate CELL buffers one column larger than current window */
len = (ncols + 1) * sizeof(CELL);
@@ -69,20 +69,25 @@
for (pass = 1; pass <= 2; pass++) {
/* second pass must generate a renumbering scheme */
if (pass == 2) {
- CELL cat, *renumber;
+ CELL cat;
- renumber = (CELL *) G_malloc((label + 1) * sizeof(CELL));
cat = 1;
- for (n = 1; n <= label; n++)
- renumber[n] = 0;
- renumber[index[n]] = 1;
- if (renumber[n])
- renumber[n] = cat++;
- index[n] = renumber[index[n]];
- G_free(renumber);
+ index2 = (CELL *) G_malloc((label + 1) * sizeof(CELL));
+ index2[0] = 0;
+ for (n = 1; n <= label; n++) {
+ OLD = n;
+ NEW = index[n];
+ if (OLD != NEW) {
+ /* find final clump id */
+ while (OLD != NEW) {
+ OLD = NEW;
+ NEW = index[OLD];
+ index[n] = NEW;
+ else
+ index2[n] = cat++;
/* fake a previous row which is all zero */
@@ -102,10 +107,11 @@
G_percent(row+1, nrows, 2);
X = 0;
+ Rast_set_c_null_value(&X, 1);
for (col = 1; col <= ncols; col++) {
LEFT = X;
X = cur_in[col];
- if (X == 0) { /* don't clump zero data */
+ if (Rast_is_c_null_value(&X)) { /* don't clump NULL data */
cur_clump[col] = 0;
continue;
@@ -170,14 +176,13 @@
cur_clump[n] = NEW;
- temp_cell = cur_clump++;
+ temp_clump = cur_clump;
n = col - 1;
- while (n-- > 0)
- if (*cur_clump == OLD)
- *cur_clump++ = NEW;
- else
- cur_clump++;
- cur_clump = temp_cell;
+ while (n-- > 0) {
+ temp_clump++; /* skip left edge */
+ if (*temp_clump == OLD)
+ *temp_clump = NEW;
/* to right
for (n = col+1; n <= ncols; n++)
@@ -185,15 +190,14 @@
prev_clump[n] = NEW;
- temp_cell = prev_clump;
- prev_clump += col + 1;
+ temp_clump = prev_clump;
+ temp_clump += col;
n = ncols - col;
- while (n-- > 0)
- if (*prev_clump == OLD)
- *prev_clump++ = NEW;
- else
- prev_clump++;
- prev_clump = temp_cell;
+ while (n-- > 0) {
+ temp_clump++; /* skip col */
/* modify the indexes
if (pass == 1)
@@ -202,16 +206,8 @@
index[n] = NEW;
- if (pass == 1) {
- temp_cell = index++;
- n = label;
- while (n-- > 0)
- if (*index == OLD)
- *index++ = NEW;
- else
- index++;
- index = temp_cell;
+ if (pass == 1)
+ index[OLD] = NEW;
if (pass == 2) {
@@ -221,16 +217,14 @@
Rast_put_row (out_fd, out_cell+1, CELL_TYPE);
- col = ncols;
- temp_clump = cur_clump + 1; /* skip left edge */
temp_cell = out_cell;
- while (col-- > 0)
- *temp_cell++ = index[*temp_clump++];
for (column = 0; column < ncols; column++) {
- if (out_cell[column] == 0)
- Rast_set_null_value(&out_cell[column], 1, CELL_TYPE);
+ temp_cell++; /* skip left edge */
+ *temp_cell = index2[index[*temp_clump++]];
+ if (*temp_cell == 0)
+ Rast_set_null_value(temp_cell, 1, CELL_TYPE);
Rast_put_row(out_fd, out_cell, CELL_TYPE);
