[GRASS-SVN] r59079 - in grass/trunk/raster/r.li: . r.li.cwed r.li.daemon r.li.dominance r.li.edgedensity r.li.mpa r.li.mps r.li.padcv r.li.padrange r.li.padsd r.li.patchdensity r.li.patchnum r.li.pielou r.li.renyi r.li.richness r.li.setup r.li.shannon r.li.shape r.li.simpson
Tue Feb 18 02:07:33 PST 2014
Author: neteler
Date: 2014-02-18 02:07:32 -0800 (Tue, 18 Feb 2014)
New Revision: 59079
   grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
   grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html
   grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html
   grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
   grass/trunk/raster/r.li/r.li.html
   grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html
   grass/trunk/raster/r.li/r.li.mps/r.li.mps.html
   grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html
   grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html
   grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html
   grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
   grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html
   grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html
   grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html
   grass/trunk/raster/r.li/r.li.richness/r.li.richness.html
   grass/trunk/raster/r.li/r.li.setup/r.li.setup.html
   grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html
   grass/trunk/raster/r.li/r.li.shape/r.li.shape.html
   grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html
r.li manual: cosmetics
Modified: grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
--- grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -23,7 +23,7 @@
 <h2>NOTES</h2>
 Do not use absolute path names for the <b>output</b> map/file.
-If the "moving window" method was selected in <b>r.li.setup</b>, then the
+If the "moving window" method was selected in <b>g.gui.rlisetup</b>, then the
 output will be a raster map, otherwise an ASCII file will be generated in
 the <tt>$HOME/.grass7/r.li/output/</tt> folder.
 <p>
@@ -40,7 +40,7 @@
 <h2>EXAMPLES</h2>
 To calculate the contrast weighted edge density index on map <em>my_map</em>, using
 <em>my_conf</em> configuration file (previously defined with
-<em>r.li.setup</em>) and saving results in <em>my_out</em>, run:
+<em>g.gui.rlisetup</em>) and saving results in <em>my_out</em>, run:
 <div class="code"><pre>
 r.li.cwed input=my_map conf=my_conf path=my_file output=my_out \
           path=/path/to/weights.csv
@@ -57,7 +57,7 @@
 <h2>SEE ALSO</h2>
 <em>
 <a href="r.li.html">r.li</a> - package overview<br>
-<a href="r.li.setup.html">r.li.setup</a>
+<a href="g.gui.rlisetup.html">g.gui.rlisetup</a>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html
--- grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -16,7 +16,7 @@
 <h2>DESCRIPTION</h2>
 <em>r.li.daemon</em> provides support for landscape index calculations on raster
-maps. It hides the management of areas, defined using <a href="r.li.setup.html">r.li.setup</a>
+maps. It hides the management of areas, defined using <a href="g.gui.rlisetup.html">g.gui.rlisetup</a>
 command. It is not used like a standalone program, but its functions are
 a library used by all <em>r.li.[index]</em> commands.<br>
 This description is a tutorial for new index definition. <br><br>
@@ -48,7 +48,7 @@
 	from the <i>r.li</i> library, for starting raster analysis.<br>
 	It follows the meaning of parameters:
 	<ul>
-	<li><i>file</i> name of configuration file created using <a href="r.li.setup.html">r.li.setup</a>
+	<li><i>file</i> name of configuration file created using <a href="g.gui.rlisetup.html">g.gui.rlisetup</a>
 	<li><i>f</i> pointer to index function defined above
 	<li><i>parameters</i> pointer to index special parameters
 	<li><i>raster</i> name of raster to use
@@ -74,7 +74,7 @@
 <em><a href="http://grass.osgeo.org/gdp/landscape/r_le_manual5.pdf">old r.le manual</a></em><br>
 <em><a href="r.li.html">r.li</a></em> - package overview <br>
-<em><a href="r.li.setup.html">r.li.setup</a></em>
+<em><a href="g.gui.rlisetup.html">g.gui.rlisetup</a></em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html
--- grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -13,7 +13,7 @@
 <h2>NOTES</h2>
 <p>
@@ -24,11 +24,14 @@
 <h2>EXAMPLES</h2>
 To calculate the dominance diversity index on map <em>my_map</em>, using
 r.li.dominance input=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
-# forest map example:
+Forest map (Spearfish sample dataset) example:
+<div class="code"><pre>
 g.region rast=landcover.30m -p
 r.mapcalc "forests = if(landcover.30m >= 41 && landcover.30m <= 43,1,null())"
 r.li.dominance input=forests conf=movwindow7 out=forests_dominance_mov7
@@ -38,7 +41,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
--- grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -23,7 +23,7 @@
 <h2>NOTES</h2>
 <p>
@@ -41,7 +41,7 @@
 <h2>EXAMPLES</h2>
 To calculate the edge density index on map <em>my_map</em>, using
 r.li.edgedensity input=my_map conf=my_conf output=my_out
 </pre></div>
@@ -51,8 +51,11 @@
 file run:<br>
 r.li.edgedensity input=my_map conf=my_conf output=my_out patch_type=34
+</pre></div>
+<p>
 r.li.edgedensity input=forests conf=movwindow7 out=forests_edgedens_mov7
@@ -62,7 +65,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.html
--- grass/trunk/raster/r.li/r.li.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -30,7 +30,7 @@
 It supports analysis of landscapes composed of a mosaic of
 patches, but, more generally, the modules work with any two-dimensional
 raster map whose cell values are integer (e.g., 1, 2) or floating point
-(e.g., 1.1, 3.2) values. The <em>r.li.setup</em> module has options for
+(e.g., 1.1, 3.2) values. The <em>g.gui.rlisetup</em> module has options for
 controlling the shape, size, number, and distribution of sampling
 areas used to collect information about the landscape structure.
 Sampling area shapes can be the entire map or a moving
@@ -50,7 +50,7 @@
 The general procedure to calculate an index from a raster map is two-fold:
 <ol>
-<li>run <em>r.li.setup</em>: create a configuration file selecting the parts of
+<li>run <em>g.gui.rlisetup</em>: create a configuration file selecting the parts of
     raster to analyze.
 <li>run one or more of the <em>r.li.<b>[index]</b></em> modules (e.g.,
@@ -83,7 +83,7 @@
   g.gui.rlisetup
 </pre></div>
-  <li> The main <em>r.li.setup</em> window is displayed, click on "New"
+  <li> The main <em>g.gui.rlisetup</em> window is displayed, click on "New"
   <li> The new configuration window is now displayed, enter the
 	configuration file name (e.g., "my_conf", do not use absolute paths)
@@ -96,7 +96,7 @@
   <li> Click on "Use keyboard to enter moving window dimension"
   <li> Select "Rectangle" and enter 5 in the "height" and "width" fields
   <li> Click on "Save settings"
-  <li> Close the <em>r.li.setup</em> window
+  <li> Close the <em>g.gui.rlisetup</em> window
   </ol>
 <li> CALCULATE PATCHDENSITY INDEX
@@ -136,7 +136,7 @@
 <b>Core modules</b>:
 <ul>
   <li> <a href="r.li.daemon.html">r.li.daemon</a>: job launch daemon</li>
-  <li> <a href="r.li.setup.html">r.li.setup</a>: Configuration editor for r.li.'index'</li>
+  <li> <a href="g.gui.rlisetup.html">g.gui.rlisetup</a>: Configuration editor for r.li.'index'</li>
 </ul>
 <b>Patch indices</b>:
Modified: grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html
--- grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -14,7 +14,7 @@
 <h2>NOTES</h2>
 <p>
@@ -32,11 +32,14 @@
 <h2>EXAMPLES</h2>
 To calculate the mean pixel attribute index on map <em>my_map</em>, using
 r.li.mpa input=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.mpa input=forests conf=movwindow7 out=forests_mpa_mov7
@@ -46,7 +49,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.mps/r.li.mps.html
--- grass/trunk/raster/r.li/r.li.mps/r.li.mps.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.mps/r.li.mps.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -19,7 +19,7 @@
 <h2>NOTES</h2>
 <p>
@@ -29,11 +29,14 @@
 <h2>EXAMPLES</h2>
 To calculate mean path size index on map <em>my_map</em>, using
 r.li.mps input=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.mps input=forests conf=movwindow7 out=forests_mps_mov7
@@ -43,7 +46,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html
--- grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -2,7 +2,7 @@
 <em>r.li.padcv</em> calculates the coefficient of variation of patch
 area sizes in hectares as:<br>
-<img src="rlipadcv_formula1.png" alt="rlipadcv formula"> <br>
+<img src="rlipadcv_formula1.png" alt="r.li.padcv formula"> <br>
 with:<br>
 <ul>
  <li><b>SD</b>: standard deviation of patch area size
@@ -15,7 +15,7 @@
 <h2>NOTES</h2>
 <p>
@@ -24,11 +24,14 @@
 <h2>EXAMPLES</h2>
 To calculate patch area distribution coefficient of variation index on map <em>my_map</em>, using
 r.li.padcv input=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.padcv input=forests conf=movwindow7 out=forests_padcv_mov7
@@ -38,7 +41,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html
--- grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -2,7 +2,7 @@
 <em>r.li.padrange</em> calculates the range of patch area sizes in
 hectares as:<br>
-<img src="rlipadrange_formula.png" alt="rlipadrange formula"> <br>
+<img src="rlipadrange_formula.png" alt="r.li.padrange formula"> <br>
 with:<br>
 <ul>
   <li><b>a<small><small>max</small></small></b>: max patch area size</li>
@@ -16,7 +16,7 @@
 <h2>NOTES</h2>
 <p>
@@ -26,11 +26,14 @@
 <h2>EXAMPLES</h2>
 To calculate range of patch area size index on map <em>my_map</em>, using
 r.li.padrange input=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.padrange input=forests conf=movwindow7 out=forests_padrange_mov7
@@ -40,7 +43,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html
--- grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -2,7 +2,7 @@
 <em>r.li.padsd</em> calculates the standard deviation of patch
-<img src="rlipadsd_formula.png" alt="rlipadsd formula"> <br>
+<img src="rlipadsd_formula.png" alt="r.li.padsd formula"> <br>
 with:<br>
 <ul>
   <li><b>MPS</b>: mean patch area size</li>
@@ -17,7 +17,7 @@
 <h2>NOTES</h2>
 <p>
@@ -26,11 +26,14 @@
 <h2>EXAMPLES</h2>
 To calculate patch area distribution standard deviation index on map <em>my_map</em>, using
 r.li.padsd input=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.padsd input=forests conf=movwindow7 out=forests_padsd_mov7
@@ -39,7 +42,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
--- grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -19,7 +19,7 @@
 <h2>NOTES</h2>
 <p>
@@ -29,7 +29,7 @@
 <h2>EXAMPLES</h2>
 To calculate patch density index on map <em>my_map</em>, using
 r.li.patchdensity input=my_map conf=my_conf output=my_out
 </pre></div>
@@ -42,8 +42,9 @@
 r.category landcover.30m
 r.mapcalc "forests = if(landcover.30m >= 41 && landcover.30m <= 43, 1, null())"
-# patch density (7x7 moving window defined in r.li.setup):
+# patch density (7x7 moving window defined in g.gui.rlisetup):
 r.li.patchdensity forests conf=movwindow7 out=forests_p_dens7
+r.univar forests_p_dens7
 d.rast.leg forests_p_dens7
 r.to.vect forests out=forests feature=area
@@ -53,7 +54,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html
--- grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -10,7 +10,7 @@
 <h2>NOTES</h2>
 <p>
@@ -20,11 +20,14 @@
 <h2>EXAMPLES</h2>
 To calculate patch number index on map <em>my_map</em>, using
 r.li.patchnum input=my_map conf=my_conf out=my_out
+</pre></div>
+<p>
 r.li.patchnum input=forests conf=movwindow7 out=forests_patchnum_mov7
@@ -34,7 +37,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html
--- grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -1,7 +1,7 @@
 <em>r.li.pielou</em>  calculates the "Pielou's diversity index" as: <br>
-<img src="r_li_pielou.png"><br>
+<img src="r_li_pielou.png" alt="r.li.pielou formula"> <br>
 with:
 <ul>
   <li><b>J</b>: Pielou eveness index</li>
@@ -12,10 +12,11 @@
 <h2>NOTES</h2>
 <p>
+<!-- TODO: verify next: -->
 If the input raster contains NULL value cells, <em>r.li.pielou</em>
 returns -1 for these cells. <br>
 If you want to change these -1 values to NULL, run subsequently on the resulting map:
@@ -27,11 +28,14 @@
 <h2>EXAMPLES</h2>
 To calculate Pielou's diversity index on map <em>my_map</em>, using
 r.li.pielou input=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.pielou input=forests conf=movwindow7 out=forests_pielou_mov7
@@ -41,7 +45,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html
--- grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -1,7 +1,7 @@
 <em>r.li.renyi</em> calculates the "Renyi's diversity index" as:<br>
-<img src="r_li_renyi.png"> <br>
+<img src="r_li_renyi.png alt="r.li.renyi formula"> <br>
 with:
 <ul>
   <li><b>H</b>: Renyi entropy</li>
@@ -14,7 +14,7 @@
 <h2>NOTES</h2>
 <p>
@@ -30,11 +30,14 @@
 <h2>EXAMPLES</h2>
 To calculate Renyi's diversity index on map <em>my_map</em>, using
 r.li.renyi input=my_map conf=my_conf output=my_out alpha=0.6
+</pre></div>
+<p>
 r.li.renyi input=forests conf=movwindow7 out=forests_renyi_mov7_a06 alpha=0.6
@@ -44,7 +47,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.richness/r.li.richness.html
--- grass/trunk/raster/r.li/r.li.richness/r.li.richness.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.richness/r.li.richness.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -2,7 +2,7 @@
 <em>r.li.richness</em> calculates the "richness diversity index" as:
 <br>
-<img src="rliRichness_formula.png" alt="rliRichness formula">
+<img src="rliRichness_formula.png" alt="r.li.richness formula">
 <br>
 with:
 <ul>
@@ -13,7 +13,7 @@
 <h2>NOTES</h2>
 <p>
@@ -31,11 +31,14 @@
 To calculate the richness diversity index on map <em>my_map</em>, using
 r.li.richness input=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.richness input=forests conf=movwindow7 out=forests_richness_mov7
@@ -47,7 +50,7 @@
 <em>
 </em>
Modified: grass/trunk/raster/r.li/r.li.setup/r.li.setup.html
--- grass/trunk/raster/r.li/r.li.setup/r.li.setup.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.setup/r.li.setup.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -1,6 +1,6 @@
-<em>r.li.setup</em>  creates and shows configuration files for the
+<em>g.gui.rlisetup</em>  creates and shows configuration files for the
 other analytical <em>r.li</em> modules. For a general introduction, see
 <a href="r.li.html">r.li</a>.
 <br>
Modified: grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html
--- grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -1,7 +1,7 @@
 <em>r.li.shannon</em> calculates the "Shannon's diversity index" as:<br>
-<img src="rliShannon_formula.png" alt="rliShannon formula"> <br>
+<img src="rliShannon_formula.png" alt="r.li.shannon formula"> <br>
 with:
 <ul>
 <li><b>i</b>: patch type</li>
@@ -13,7 +13,7 @@
 <h2>NOTES</h2>
 <p>
@@ -30,11 +30,14 @@
 <h2>EXAMPLES</h2>
 To calculate Shannon's diversity index on map <em>my_map</em>, using
 r.li.shannon input=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.shannon input=forests conf=movwindow7 out=forests_shannon_mov7
@@ -44,7 +47,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.shape/r.li.shape.html
--- grass/trunk/raster/r.li/r.li.shape/r.li.shape.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.shape/r.li.shape.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -6,7 +6,7 @@
 <h2>NOTES</h2>
 <p>
@@ -23,11 +23,14 @@
 <h2>EXAMPLES</h2>
 To calculate the shape index on map <em>my_map</em>, using
 r.li.shape input=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.shape input=forests conf=movwindow7 out=forests_shape_mov7
@@ -37,7 +40,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html
--- grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html	2014-02-17 21:08:19 UTC (rev 59078)
+++ grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html	2014-02-18 10:07:32 UTC (rev 59079)
@@ -1,7 +1,7 @@
 <em>r.li.simpson</em> calculates the "Simpson's diversity index" as:<br>
-<img src="rliSimpson_formula.png" alt="rliSimpson formula"> <br>
+<img src="rliSimpson_formula.png" alt="r.li.simpson formula"> <br>
 with:
 <ul>
@@ -13,7 +13,7 @@
 <h2>NOTES</h2>
 <p>
@@ -29,11 +29,14 @@
 <h2>EXAMPLES</h2>
 To calculate Simpson's diversity index on map <em>my_map</em>, using
 r.li.simpson input=my_map conf=my_conf output=my_out
+</pre></div>
+<p>
 r.li.simpson input=forests conf=movwindow7 out=forests_simpson_mov7
@@ -43,7 +46,7 @@
 <h2>SEE ALSO</h2>
 <em>
 </em>
 <h2>REFERENCES</h2>
