[GRASS-SVN] r59081 - grass-addons/grass7/raster/r.shalstab
svn_grass at osgeo.org
Tue Feb 18 04:59:50 PST 2014
Author: kikapu
Date: 2014-02-18 04:59:49 -0800 (Tue, 18 Feb 2014)
New Revision: 59081
grass-addons/grass7/raster/r.shalstab/r.shalstab.py
R.shalstab: new version
Modified: grass-addons/grass7/raster/r.shalstab/r.shalstab.py
--- grass-addons/grass7/raster/r.shalstab/r.shalstab.py 2014-02-18 11:44:10 UTC (rev 59080)
+++ grass-addons/grass7/raster/r.shalstab/r.shalstab.py 2014-02-18 12:59:49 UTC (rev 59081)
@@ -155,7 +155,7 @@
elevation = r_elevation,
accumulation = 'accum')
- grass.mapcalc("A=accum*((ewres()+nsres())/2)*((ewres()+nsres())/2)")
+ grass.mapcalc("A=abs(accum*((ewres()+nsres())/2)*((ewres()+nsres())/2))")
#stable condition
grass.mapcalc("assoluta_stab=(1-1000/($gamma))*tan($phy)",
gamma = gamma,
@@ -166,19 +166,19 @@
phy = phy)
grass.mapcalc("cond_instab=if(assoluta_instab<tan(slopes),-9999,0)")
# calculate 1(m/day)
- grass.mapcalc("i_crit_m=(T*sin(slopes)*((ewres()+nsres())/2)/A*($gamma/1000*(1-(1-C/(sin(slopes)*cos(slopes))))*(tan(slopes)/tan($phy))))+(assoluta_cond)+(cond_instab)",
+ grass.mapcalc("i_crit_m=T*sin(slopes)*(((ewres()+nsres())/2)/A)*($gamma/1000*(1-(1-(C/(sin(slopes))))*(tan(slopes)/tan($phy))))+(assoluta_cond)+(cond_instab)",
phy=phy, gamma=gamma)
# Calculation of critical rain (mm / hr) and riclassification
grass.mapcalc("i_cri_mm=i_crit_m*1000")
- grass.mapcalc("i_cri_mm_reclass=if(i_cri_mm<0, 0, if(i_cri_mm>200,200, i_cri_mm))")
- grass.run_command('r.colors', map='i_cri_mm_reclass', color='precipitation')
+ #grass.mapcalc("i_cri_mm_reclass=if(i_cri_mm<0, 0, if(i_cri_mm>))")
+ grass.run_command('r.colors', map='i_cri_mm', color='precipitation')
reclass_rules = "0 thru 30 = 2\n31 thru 100 = 3\n101 thru 150 = 4\n151 thru 200 = 5\n201 thru 999 = 6"
grass.write_command('r.reclass', input='i_cri_mm', output='i_recl',
overwrite='True', rules='-', stdin=reclass_rules)
grass.mapcalc("copia_reclass=i_recl+0")
grass.run_command('r.null', map='copia_reclass', null=0)
- grass.mapcalc("Stable=if (i_cri_mm>1000, 7, 0)")
- grass.mapcalc("Unstable=if (i_cri_mm<0, 1, 0)")
+ grass.mapcalc("Stable=if(i_cri_mm>1000,7,0)")
+ grass.mapcalc("Unstable=if(i_cri_mm<0,1,0)")
grass.mapcalc("Icritica=copia_reclass+Unstable+Stable")
colors_rules = "1 255:85:255\n2 255:0:0\n3 255:170:0\n4 255:255:0\n" \
"5 85:255:0\n6 170:255:255\n7 255:255:255"
@@ -189,13 +189,13 @@
size=3, output='I_cri_average')
# rename maps
grass.run_command('g.rename', rast=("I_cri_average", susceptibility))
- grass.run_command('g.rename', rast=("i_cri_mm_reclass", critic_rain))
+ grass.run_command('g.rename', rast=("i_cri_mm", critic_rain))
# remove temporary map
grass.run_command('g.remove', rast=("A",
"copia_reclass",
"i_crit_m",
"i_recl",
- # "i_cri_mm",
+ #"i_cri_mm",
"accum",
"slopes",
"Stable",
