[GRASS-SVN] r59083 - grass/trunk/raster/r.li/r.li.daemon
svn_grass at osgeo.org
Tue Feb 18 06:03:45 PST 2014
Author: mmetz
Date: 2014-02-18 06:03:45 -0800 (Tue, 18 Feb 2014)
New Revision: 59083
grass/trunk/raster/r.li/r.li.daemon/daemon.c
grass/trunk/raster/r.li/r.li.daemon/daemon.h
grass/trunk/raster/r.li/r.li.daemon/list.h
grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html
grass/trunk/raster/r.li/r.li.daemon/worker.c
r.li.daemon: fix sampling frame and sample area logic, consider current region
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.c
--- grass/trunk/raster/r.li/r.li.daemon/daemon.c 2014-02-18 14:00:57 UTC (rev 59082)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.c 2014-02-18 14:03:45 UTC (rev 59083)
@@ -195,6 +195,7 @@
double rel_x, rel_y, rel_rl, rel_cl;
double sf_n, sf_s, sf_e, sf_w;
int sf_x, sf_y, sf_rl, sf_cl;
+ int sa_x, sa_y, sa_rl, sa_cl;
int size;
if (stat(path, &s) != 0)
@@ -220,14 +221,28 @@
rel_rl = atof(strtok(NULL, "|"));
rel_cl = atof(strtok(NULL, "\n"));
- /* find raster map */
- Rast_get_cellhd(raster, "", &cellhd);
+ /* use current region ! */
+ Rast_get_window(&cellhd);
/* calculate absolute sampling frame definition */
sf_x = (int)rint(cellhd.cols * rel_x);
sf_y = (int)rint(cellhd.rows * rel_y);
sf_rl = (int)rint(cellhd.rows * rel_rl);
sf_cl = (int)rint(cellhd.cols * rel_cl);
+ /* sanity check */
+ if (sf_x < 0)
+ sf_x = 0;
+ if (sf_y < 0)
+ sf_y = 0;
+ if (sf_x > cellhd.cols)
+ sf_x = cellhd.cols;
+ if (sf_y > cellhd.rows)
+ sf_y = cellhd.rows;
+ if (sf_rl > cellhd.rows - sf_y)
+ sf_rl = cellhd.rows - sf_y;
+ if (sf_cl > cellhd.cols - sf_x)
+ sf_cl = cellhd.cols - sf_x;
/* calculate sample frame boundaries */
sf_n = cellhd.north - (cellhd.ns_res * sf_y);
@@ -250,19 +265,28 @@
if (rel_sa_x == -1.0 && rel_sa_y == -1.0) {
/* runtime disposition */
- int sa_rl, sa_cl;
sa_rl = (int)rint(cellhd.rows * rel_sa_rl);
sa_cl = (int)rint(cellhd.cols * rel_sa_cl);
+ if (sa_rl > cellhd.rows - sf_y)
+ sa_rl = cellhd.rows - sf_y;
+ if (sa_cl > cellhd.cols - sf_x)
+ sa_cl = cellhd.cols - sf_x;
+ /* total sample area */
g->rows = sf_rl;
g->cols = sf_cl;
+ g->x = sf_x;
+ g->y = sf_y;
+ /* current sample area (subset of total sample area) */
g->rl = sa_rl;
g->cl = sa_cl;
- g->count = 1;
g->sf_x = sf_x;
g->sf_y = sf_y;
- g->x = sf_x;
- g->y = sf_y;
+ g->count = 1;
g->maskname = NULL;
return disposeAreas(l, g, strtok(NULL, "\n"));
@@ -273,10 +297,30 @@
toReturn = NORMAL;
/*read file and create list */
m.type = AREA;
- m.f.f_a.x = (int)rint(cellhd.cols * rel_sa_x);
- m.f.f_a.y = (int)rint(cellhd.rows * rel_sa_y);
- m.f.f_a.rl = (int)rint(cellhd.rows * rel_sa_rl);
- m.f.f_a.cl = (int)rint(cellhd.cols * rel_sa_cl);
+ sa_x = (int)rint(cellhd.cols * rel_sa_x);
+ sa_y = (int)rint(cellhd.rows * rel_sa_y);
+ sa_rl = (int)rint(cellhd.rows * rel_sa_rl);
+ sa_cl = (int)rint(cellhd.cols * rel_sa_cl);
+ if (sa_x < 0)
+ sa_x = 0;
+ if (sa_y < 0)
+ sa_y = 0;
+ if (sa_x > cellhd.cols)
+ sa_x = cellhd.cols;
+ if (sa_y > cellhd.rows)
+ sa_y = cellhd.rows;
+ if (sa_rl > cellhd.rows - sa_y)
+ sa_rl = cellhd.rows - sa_y;
+ if (sa_cl > cellhd.cols - sa_x)
+ sa_cl = cellhd.cols - sa_x;
+ m.f.f_a.x = sa_x;
+ m.f.f_a.y = sa_y;
+ m.f.f_a.rl = sa_rl;
+ m.f.f_a.cl = sa_cl;
m.f.f_a.aid = aid;
aid++;
insertNode(l, m);
@@ -302,17 +346,25 @@
if (rel_sa_x == -1 && rel_sa_y == -1) {
- int sa_rl, sa_cl;
g->rows = sf_rl;
g->cols = sf_cl;
+ g->x = sf_x;
+ g->y = sf_y;
g->rl = sa_rl;
g->cl = sa_cl;
g->count = 1;
- g->x = sf_x;
- g->y = sf_y;
g->maskname = maskname;
@@ -321,10 +373,30 @@
msg m;
m.type = MASKEDAREA;
- m.f.f_ma.x = (int)rint(cellhd.cols * rel_sa_x);
- m.f.f_ma.y = (int)rint(cellhd.rows * rel_sa_y);
- m.f.f_ma.rl = (int)rint(cellhd.rows * rel_sa_rl);
- m.f.f_ma.cl = (int)rint(cellhd.cols * rel_sa_cl);
+ if (sa_x < 0)
+ sa_x = 0;
+ if (sa_y < 0)
+ sa_y = 0;
+ m.f.f_ma.x = sa_x;
+ m.f.f_ma.y = sa_y;
+ m.f.f_ma.rl = sa_rl;
+ m.f.f_ma.cl = sa_cl;
m.f.f_ma.aid = aid;
strcpy(m.f.f_ma.mask, maskname);
aid++;
@@ -342,12 +414,11 @@
double sa_n, sa_s, sa_w, sa_e;
int aid = 1;
char maskname[GNAME_MAX] = {'\0'};
- struct Cell_head window;
msg m;
/* Get the window setting. g.region rast=<input raster> */
/* ? same as cellhd above ? */
- G_get_window(&window);
+ /* no. the current window might be different */
do {
strcpy(maskname, strtok(NULL, "|"));
@@ -362,16 +433,36 @@
raster via v.to.rast. See r.li.setup/sample_area_vector.sh.
This is used only for reading the region (NS, EW). */
/* Get start x and y position of masked overlay raster with
- respect to input raster region from window.
- sa_n, sa_e are read from configuration file. */
- m.f.f_ma.x = (int)Rast_easting_to_col(sa_w, &window);
- m.f.f_ma.y = (int)Rast_northing_to_row(sa_n, &window);
+ respect to current region.
+ sa_n, sa_w are read from configuration file. */
+ sa_x = (int)rint((sa_w - cellhd.west) / cellhd.ew_res);
+ sa_y = (int)rint((cellhd.north - sa_n) / cellhd.ns_res);
/* Get row count and column count of overlay raster */
- m.f.f_ma.rl = (int)rint((sa_n - sa_s) / cellhd.ns_res);
- m.f.f_ma.cl = (int)rint((sa_e - sa_w) / cellhd.ew_res);
+ sa_rl = (int)rint((sa_n - sa_s) / cellhd.ns_res);
+ sa_cl = (int)rint((sa_e - sa_w) / cellhd.ew_res);
+ if (sa_x < 0)
+ sa_x = 0;
+ if (sa_y < 0)
+ sa_y = 0;
m.f.f_ma.aid = aid;
aid++;
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.h
--- grass/trunk/raster/r.li/r.li.daemon/daemon.h 2014-02-18 14:00:57 UTC (rev 59082)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.h 2014-02-18 14:03:45 UTC (rev 59083)
@@ -96,10 +96,10 @@
* \brief fields of an area descriptor
- * \member x the x coordinate of upper left corner
- * \member y the y coordinate of upper left corner
- * \member rl area length in rows
- * \member cl area length in columns
+ * \member x column offset = start of sample area
+ * \member y row offset = start of sample area
+ * \member rl sample area length in rows
+ * \member cl sample area length in columns
* \member rc number of rows in the cache
* \member mask file descriptor of mask raster file (-1 if there is no mask)
@@ -212,7 +212,7 @@
* \param cl the lenght in cols of sample area
* \return the name of mask raster file to use
-char *mask_preprocessing(char *mask, char *raster, int rl, int cl);
+char *mask_preprocessing(char *mask, char *raster, struct area_entry *ad);
* \brief writes the output for a raster file
Modified: grass/trunk/raster/r.li/r.li.daemon/list.h
--- grass/trunk/raster/r.li/r.li.daemon/list.h 2014-02-18 14:00:57 UTC (rev 59082)
+++ grass/trunk/raster/r.li/r.li.daemon/list.h 2014-02-18 14:03:45 UTC (rev 59083)
@@ -68,13 +68,15 @@
* \param dist inter-area distance
* \param add_row cell to add in rows
* \param add_col cell to add in columns
- * \param x x coordinate of next area
- * \param y y coordinate of next area
- * \param rl area length in rows
- * \param cl areal length in columns
+ * \param rows area length in rows
+ * \param cols area length in columns
+ * \param x column offset of next area
+ * \param y row offset of next area
+ * \param rl sample area length in rows
+ * \param cl sample area length in columns
* \param count identifier of next area
- * \param sf_x x coordinate of sample frame
- * \param sf_y y coordinate of sample frame
+ * \param sf_x column offset of sample frame
+ * \param sf_y row offset of sample frame
* \param maskname name of mask for the area
struct g_area
Modified: grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html
--- grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html 2014-02-18 14:00:57 UTC (rev 59082)
+++ grass/trunk/raster/r.li/r.li.daemon/r.li.daemon.html 2014-02-18 14:03:45 UTC (rev 59083)
@@ -88,7 +88,7 @@
University of Pisa (Italy).<br>
Commission from Faunalia Pontedera (PI)<br>
Rewritten from "r.le.setup" by William L. Baker<br>
-Rewritten to produce correct results by Markus Metz<br>
+Various bug fixes by Markus Metz<br>
This program is free software under the GPL (>=v2)
Read the COPYING file that comes with GRASS for details.
Modified: grass/trunk/raster/r.li/r.li.daemon/worker.c
--- grass/trunk/raster/r.li/r.li.daemon/worker.c 2014-02-18 14:00:57 UTC (rev 59082)
+++ grass/trunk/raster/r.li/r.li.daemon/worker.c 2014-02-18 14:03:45 UTC (rev 59083)
@@ -64,8 +64,10 @@
/* open raster map */
fd = Rast_open_old(raster, "");
- Rast_get_cellhd(raster, "", &hd);
+ /* get current window */
+ Rast_get_window(&hd);
/* read data type to allocate cache */
data_type = Rast_map_type(raster, "");
@@ -127,8 +129,8 @@
ad->raster = raster;
/* mask preprocessing */
- ad->mask_name = mask_preprocessing(m->f.f_ma.mask,
- raster, ad->rl, ad->cl);
+ ad->mask_name = mask_preprocessing(m->f.f_ma.mask, raster, ad);
if (ad->mask_name == NULL) {
G_message(_("unable to open <%s> mask ... continuing without!"),
m->f.f_ma.mask);
@@ -145,6 +147,12 @@
G_fatal_error("Program error, worker() type=%d", m->type);
break;
+ /* sanity check on the sample area ? */
+ /* 0 <= ad->x < hd.cols */
+ /* 0 <= ad->y < hd.rows */
+ /* ad->rl + ad->y <= hd.rows */
+ /* ad->cl + ad->x <= hd.cols */
/* memory menagement */
if (ad->rc > used) {
@@ -208,45 +216,33 @@
Rast_close(fd);
const char *tmp_file;
- struct Cell_head cell, oldcell;
int mask_fd, old_fd, *buf, i, j;
CELL *old;
- double add_row, add_col;
- buf = G_malloc(cl * sizeof(int));
+ buf = G_malloc(ad->cl * sizeof(int));
G_debug(3, "daemon mask preproc: raster=[%s] mask=[%s] rl=%d cl=%d",
- raster, mask, rl, cl);
+ raster, mask, ad->rl, ad->cl);
- /* open raster */
- Rast_get_cellhd(raster, "", &cell);
- /* open raster */
- Rast_get_cellhd(mask, "", &oldcell);
- add_row = 1.0 * oldcell.rows / rl;
- add_col = 1.0 * oldcell.cols / cl;
tmp_file = G_tempfile();
mask_fd = open(tmp_file, O_RDWR | O_CREAT, 0755);
old_fd = Rast_open_old(mask, "");
old = Rast_allocate_c_buf();
- for (i = 0; i < rl; i++) {
- int riga;
+ /* write out sample area size: ad->rl rows and ad->cl columns */
- riga = (int)rint(i * add_row);
- Rast_get_c_row_nomask(old_fd, old, riga);
- for (j = 0; j < cl; j++) {
- int colonna;
+ for (i = 0; i < ad->rl; i++) {
- colonna = (int)rint(j * add_col);
- buf[j] = old[colonna];
+ Rast_get_c_row_nomask(old_fd, old, i + ad->y);
+ for (j = 0; j < ad->cl; j++) {
+ /* NULL -> 0, else 1 */
+ buf[j] = !Rast_is_c_null_value(&old[j + ad->x]);
- if (write(mask_fd, buf, cl * sizeof(int)) < 0)
+ if (write(mask_fd, buf, ad->cl * sizeof(int)) < 0)
return NULL;
