[GRASS-SVN] r59091 - grass/trunk/raster/r.li/r.li.daemon
svn_grass at osgeo.org
Tue Feb 18 13:01:41 PST 2014
Author: mmetz
Date: 2014-02-18 13:01:41 -0800 (Tue, 18 Feb 2014)
New Revision: 59091
Removed:
grass/trunk/raster/r.li/r.li.daemon/index.h
grass/trunk/raster/r.li/r.li.daemon/daemon.c
grass/trunk/raster/r.li/r.li.daemon/daemon.h
grass/trunk/raster/r.li/r.li.daemon/worker.c
r.li.daemon: use a function prototype, new modules do not need to modify the daemon code
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.c
--- grass/trunk/raster/r.li/r.li.daemon/daemon.c 2014-02-18 20:27:24 UTC (rev 59090)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.c 2014-02-18 21:01:41 UTC (rev 59091)
@@ -41,7 +41,7 @@
#define random rand
#endif
-int calculateIndex(char *file, int f(int, char **, struct area_entry *, double *),
+int calculateIndex(char *file, rli_func *f,
char **parameters, char *raster, char *output)
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.h
--- grass/trunk/raster/r.li/r.li.daemon/daemon.h 2014-02-18 20:27:24 UTC (rev 59090)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.h 2014-02-18 21:01:41 UTC (rev 59091)
@@ -119,9 +119,18 @@
char *mask_name;
+ * \brief function prototype for index calculation
+ * \param fd file descripter of opened raster map
+ * \param par optional parameters
+ * \param ad definition of the sample area
+ * \param result pointer to store the result
+ * \return RLI_ERRORE error occurs in calculating index
+ * \return RLI_OK otherwise
+typedef int rli_func(int fd, char **par, struct area_entry *ad, double *result);
* \brief applies the f index once for every
* area defined in setup file
@@ -132,7 +141,7 @@
* \return 1 otherwise
char **parameters, char *raster, char *output);
@@ -199,7 +208,7 @@
* \param f the function used for index computing
* \param result where to put the result of index computing
-void worker_init(char *raster, int f(int, char **, struct area_entry *, double *),
+void worker_init(char *raster, rli_func *f,
char **parameters);
void worker_process(msg * ret, msg * m);
void worker_end(void);
@@ -267,4 +276,3 @@
FCELL *RLI_get_fcell_raster_row(int fd, int row, struct area_entry * ad);
-#include "index.h"
Deleted: grass/trunk/raster/r.li/r.li.daemon/index.h
--- grass/trunk/raster/r.li/r.li.daemon/index.h 2014-02-18 20:27:24 UTC (rev 59090)
+++ grass/trunk/raster/r.li/r.li.daemon/index.h 2014-02-18 21:01:41 UTC (rev 59091)
@@ -1,50 +0,0 @@
- * \file index.h
- * \brief declaration of functions for r.li raster analysis
- * \author Claudio Porta, Lucio Davide Spano, Serena Pallecchi students of Computer Science University of Pisa (Italy)
- * Commission from Faunalia Pontedera (PI) www.faunalia.it
- * Luca Delucchi and Duccio Rocchini, Fondazione Edmund Mach, Italy: r.li.pielou, r.li.renyi
- * This program is free software under the GPL (>=v2)
- * Read the COPYING file that comes with GRASS for details.
- * \version 1.1
- ADD HERE INDEX DECLARATIONS
- * \brief calculate patch density index on selected area
- * the abstract function is patch_density= patch_number / area
-int patch_density(int fd, char **par, struct area_entry *ad, double *result);
-int patch_number(int fd, char **par, struct area_entry *ad, double *result);
-int shape_index(int fd, char **par, struct area_entry *ad, double *result);
-int shannon(int fd, char **par, struct area_entry *ad, double *result);
-int pielou(int fd, char **par, struct area_entry *ad, double *result);
-int renyi(int fd, char **par, struct area_entry *ad, double *result);
-int simpson(int fd, char **par, struct area_entry *ad, double *result);
-int meanPatchSize(int fd, char **par, struct area_entry *ad, double *result);
-int meanPixelAttribute(int fd, char **par, struct area_entry *ad, double *result);
-int contrastWeightedEdgeDensity(int fd, char **par, struct area_entry *ad,
- double *result);
-int edgedensity(int fd, char **valore, struct area_entry *ad, double *result);
-int patchAreaDistributionCV(int fd, char **par, struct area_entry *ad, double *result);
-int patchAreaDistributionMN(int fd, char **par, struct area_entry *ad, double *result);
-int patchAreaDistributionSD(int fd, char **par, struct area_entry *ad, double *result);
-int patchAreaDistributionRANGE(int fd, char **par, struct area_entry *ad,
- double *result);
-int dominance(int fd, char **par, struct area_entry *ad, double *result);
-int richness(int fd, char **par, struct area_entry *ad, double *result);
Modified: grass/trunk/raster/r.li/r.li.daemon/worker.c
--- grass/trunk/raster/r.li/r.li.daemon/worker.c 2014-02-18 20:27:24 UTC (rev 59090)
+++ grass/trunk/raster/r.li/r.li.daemon/worker.c 2014-02-18 21:01:41 UTC (rev 59091)
@@ -49,9 +49,9 @@
static fcell_manager fm;
static char *raster;
static char **parameters;
-static int (*func) (int, char **, struct area_entry *, double *);
+static rli_func *func;
-void worker_init(char *r, int f(int, char **, struct area_entry *, double *), char **p)
+void worker_init(char *r, rli_func *f, char **p)
cm = G_malloc(sizeof(struct cell_memory_entry));
fm = G_malloc(sizeof(struct fcell_memory_entry));
