[GRASS-SVN] r59109 - in grass/trunk/gui/wxpython: core dbmgr gui_core
svn_grass at osgeo.org
Fri Feb 21 07:20:19 PST 2014
Author: martinl
Date: 2014-02-21 07:20:19 -0800 (Fri, 21 Feb 2014)
New Revision: 59109
grass/trunk/gui/wxpython/core/settings.py
grass/trunk/gui/wxpython/dbmgr/base.py
grass/trunk/gui/wxpython/gui_core/preferences.py
wxGUI/dbmgr: highlight selected features in mapdisplay by default (could be disabled from preferences)
Modified: grass/trunk/gui/wxpython/core/settings.py
--- grass/trunk/gui/wxpython/core/settings.py 2014-02-20 20:34:45 UTC (rev 59108)
+++ grass/trunk/gui/wxpython/core/settings.py 2014-02-21 15:20:19 UTC (rev 59109)
@@ -214,7 +214,8 @@
'atm' : {
'highlight' : {
'color' : (255, 255, 0, 255),
- 'width' : 2
+ 'width' : 2,
+ 'auto' : True,
'leftDbClick' : {
'selection' : 1 # draw selected
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py 2014-02-20 20:34:45 UTC (rev 59108)
+++ grass/trunk/gui/wxpython/dbmgr/base.py 2014-02-21 15:20:19 UTC (rev 59109)
@@ -15,8 +15,10 @@
- base::LayerListCtrl
- base::LayerBook
-(C) 2007-2009, 2011-2012 by the GRASS Development Team
+ at todo Implement giface class
+(C) 2007-2014 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -354,6 +356,14 @@
return cats
+ def GetItems(self):
+ """!Return list of items (category numbers)"""
+ cats = []
+ for item in range(self.GetItemCount()):
+ cats.append(self.GetItemText(item))
+ return cats
def GetColumnText(self, index, col):
"""!Return column text"""
item = self.GetItem(index, col)
@@ -1557,14 +1567,19 @@
event.Skip()
- def _drawSelected(self, zoom):
+ def _drawSelected(self, zoom, selectedOnly=True):
"""!Highlight selected features"""
if not self.map or not self.mapdisplay:
return
tlist = self.FindWindowById(self.layerPage[self.selLayer]['data'])
- cats = map(int, tlist.GetSelectedItems())
+ if selectedOnly:
+ fn = tlist.GetSelectedItems
+ else:
+ fn = tlist.GetItems
+ cats = map(int, fn())
digitToolbar = None
if 'vdigit' in self.mapdisplay.toolbars:
digitToolbar = self.mapdisplay.toolbars['vdigit']
@@ -1578,12 +1593,12 @@
update = True)
else:
# add map layer with higlighted vector features
- self.AddQueryMapLayer() # -> self.qlayer
+ self.AddQueryMapLayer(selectedOnly) # -> self.qlayer
# set opacity based on queried layer
if self.parent and self.mapdisplay.tree and \
self.dbMgrData['treeItem']:
- maptree = self.mapdisplay.tree
+ maptree = self.mapdisplay.tree # TODO: giface
opacity = maptree.GetLayerInfo(self.dbMgrData['treeItem'], key = 'maplayer').GetOpacity()
self.qlayer.SetOpacity(opacity)
if zoom:
@@ -1633,15 +1648,18 @@
else:
self.mapdisplay.MapWindow.UpdateMap(render = False, renderVector = True)
- def AddQueryMapLayer(self):
+ def AddQueryMapLayer(self, selectedOnly = True):
"""!Redraw a map
Return True if map has been redrawn, False if no map is given
- cats = {
- self.selLayer : tlist.GetSelectedItems()
+ if selectedOnly:
+ else:
+ cats = { self.selLayer : fn() }
if self.mapdisplay.Map.GetLayerIndex(self.qlayer) < 0:
self.qlayer = None
@@ -1827,6 +1845,10 @@
self.log.write(_("Number of loaded records: %d") % \
self.FindWindowById(self.layerPage[self.selLayer]['data']).GetItemCount())
+ # update map display if needed
+ if UserSettings.Get(group = 'atm', key = 'highlight', subkey = 'auto'):
+ self._drawSelected(zoom=False, selectedOnly=False) # TODO: replace by signals
def OnBuilder(self,event):
"""!SQL Builder button pressed -> show the SQLBuilder dialog"""
if not self.builder:
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2014-02-20 20:34:45 UTC (rev 59108)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2014-02-21 15:20:19 UTC (rev 59109)
@@ -15,7 +15,7 @@
- preferences::MapsetAccess
- preferences::CheckListMapset
-(C) 2007-2012 by the GRASS Development Team
@@ -1060,12 +1060,13 @@
# highlighting
highlightBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
- label = " %s " % _("Highlighting"))
+ label = " %s " % _("Highlight selected features"))
highlightSizer = wx.StaticBoxSizer(highlightBox, wx.VERTICAL)
flexSizer = wx.FlexGridSizer (cols = 2, hgap = 5, vgap = 5)
flexSizer.AddGrowableCol(0)
+ # color
label = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Color:"))
hlColor = csel.ColourSelect(parent = panel, id = wx.ID_ANY,
colour = self.settings.Get(group = 'atm', key = 'highlight', subkey = 'color'),
@@ -1076,6 +1077,7 @@
flexSizer.Add(label, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL)
flexSizer.Add(hlColor, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ # width
label = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Line width (in pixels):"))
hlWidth = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (50, -1),
initial = self.settings.Get(group = 'atm', key = 'highlight',subkey = 'width'),
@@ -1085,6 +1087,13 @@
flexSizer.Add(hlWidth, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ # auto
+ autoHighlight = wx.CheckBox(parent = panel, id = wx.ID_ANY, label = _("Automatically hightlight selected features in map display"))
+ autoHighlight.SetValue(self.settings.Get(group = 'atm', key = 'highlight', subkey = 'auto'))
+ self.winId['atm:highlight:auto'] = autoHighlight.GetId()
+ flexSizer.Add(autoHighlight, proportion = 1)
highlightSizer.Add(item = flexSizer,
proportion = 0,
flag = wx.ALL | wx.EXPAND,
