[GRASS-SVN] r59125 - grass/trunk/gui/wxpython/dbmgr
Sun Feb 23 07:01:56 PST 2014
Author: martinl
Date: 2014-02-23 07:01:56 -0800 (Sun, 23 Feb 2014)
New Revision: 59125
   grass/trunk/gui/wxpython/dbmgr/base.py
wxGUI/dbmgr: highlight selected feature only when where cond is given
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py	2014-02-23 14:37:32 UTC (rev 59124)
+++ grass/trunk/gui/wxpython/dbmgr/base.py	2014-02-23 15:01:56 UTC (rev 59125)
@@ -1791,6 +1791,7 @@
         if not win:
             return
+        showSelected = False
         wx.BeginBusyCursor()
         if win.GetSelection() == 0:
             # simple sql statement
@@ -1799,6 +1800,7 @@
             whereVal = self.FindWindowById(self.layerPage[self.selLayer]['where']).GetValue().strip()
             try:
                 if len(whereVal) > 0:
+                    showSelected = True
                     keyColumn = listWin.LoadData(self.selLayer, where = whereCol + whereOpe + whereVal)
                 else:
                     keyColumn = listWin.LoadData(self.selLayer)
@@ -1813,6 +1815,8 @@
                 cols, where = self.ValidateSelectStatement(win.GetValue())
                 if cols is None and where is None:
                     sql = win.GetValue()
+                if where:
             except TypeError:
                 GError(parent = self,
                        message = _("Loading attribute data failed.\n"
@@ -1847,7 +1851,12 @@
         # update map display if needed
         if UserSettings.Get(group = 'atm', key = 'highlight', subkey = 'auto'):
-            self._drawSelected(zoom=False, selectedOnly=False) # TODO: replace by signals
+            # TODO: replace by signals
+            if showSelected:
+                self._drawSelected(zoom=False, selectedOnly=False)
+            else:
+                self.mapdisplay.RemoveQueryLayer()
+                self.mapdisplay.MapWindow.UpdateMap(render=False) # TODO: replace by signals
     def OnBuilder(self,event):
         """!SQL Builder button pressed -> show the SQLBuilder dialog"""
