[GRASS-SVN] r59133 - grass/trunk/lib/imagery
svn_grass at osgeo.org
Mon Feb 24 02:28:01 PST 2014
Author: turek
Date: 2014-02-24 02:28:01 -0800 (Mon, 24 Feb 2014)
New Revision: 59133
grass/trunk/lib/imagery/iclass_perimeter.c
grass/trunk/lib/imagery/iscatt_core.c
wx.iscatt: make it work in latlong locations
Modified: grass/trunk/lib/imagery/iclass_perimeter.c
--- grass/trunk/lib/imagery/iclass_perimeter.c 2014-02-24 10:14:25 UTC (rev 59132)
+++ grass/trunk/lib/imagery/iclass_perimeter.c 2014-02-24 10:28:01 UTC (rev 59133)
@@ -176,10 +176,22 @@
for (i = 0; i < count; i++) {
G_debug(5, "iclass_make_perimeter(): points: x: %f y: %f",
points->x[i], points->y[i]);
- tmp_points[i].y = Rast_northing_to_row(points->y[i], band_region);
- tmp_points[i].x = Rast_easting_to_col(points->x[i], band_region);
+ /* This functions are no longer used because of the different behaviour
+ of Rast_easting_to_col depending whether location is LL or not.
+ It makes problem in interactive scatter plot tool,
+ which defines its own coordinates systems for the plots and
+ therefore it requires the function to work always in same way
+ without hidden dependency on location type.
+ tmp_points[i].y = Rast_northing_to_row(points->y[i], band_region);
+ tmp_points[i].x = Rast_easting_to_col(points->x[i], band_region);
+ tmp_points[i].y = (band_region->north - points->y[i]) / band_region->ns_res;
+ tmp_points[i].x = (points->x[i] - band_region->west) / band_region->ew_res;
/* find first edge which is not horizontal */
first = -1;
Modified: grass/trunk/lib/imagery/iscatt_core.c
--- grass/trunk/lib/imagery/iscatt_core.c 2014-02-24 10:14:25 UTC (rev 59132)
+++ grass/trunk/lib/imagery/iscatt_core.c 2014-02-24 10:28:01 UTC (rev 59133)
@@ -962,7 +962,7 @@
Vect_append_point(pol, polygon[i * 2], polygon[i * 2 + 1], 0.0);
- Rast_set_window(rast_region);
+ //Rast_set_window(rast_region);
make_perimeter(pol, &perimeter, rast_region);
for (i = 1; i < perimeter.npoints; i += 2) {
