[GRASS-SVN] r59135 - grass/trunk/locale/po
svn_grass at osgeo.org
Mon Feb 24 04:40:19 PST 2014
Author: marisn
Date: 2014-02-24 04:40:18 -0800 (Mon, 24 Feb 2014)
New Revision: 59135
grass/trunk/locale/po/grasswxpy_lv.po
Update Latvian translation of wxGUI
Modified: grass/trunk/locale/po/grasswxpy_lv.po
--- grass/trunk/locale/po/grasswxpy_lv.po 2014-02-24 10:30:20 UTC (rev 59134)
+++ grass/trunk/locale/po/grasswxpy_lv.po 2014-02-24 12:40:18 UTC (rev 59135)
@@ -2,6518 +2,3605 @@
# Copyright (C) YEAR THE PACKAGE'S COPYRIGHT HOLDER
# This file is distributed under the same license as the PACKAGE package.
-# Maris Nartiss <maris.kde at gmail.com>, 2012.
-#: ../gui/wxpython/vnet/vnet_data.py:238 ../gui/wxpython/gis_set.py:117
-#: ../gui/wxpython/animation/dialogs.py:297
+# Maris Nartiss <maris.gis at gmail.com>, 2012, 2014.
msgid ""
msgstr ""
"Project-Id-Version: grasswxpy_lv\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2013-10-30 22:30+0100\n"
-"PO-Revision-Date: 2012-08-01 17:07+0300\n"
-"Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
+"POT-Creation-Date: 2012-11-14 12:30+0200\n"
+"PO-Revision-Date: 2014-02-24 14:35+0200\n"
+"Last-Translator: Maris Nartiss <maris.gis at gmail.com>\n"
"Language-Team: Latvian\n"
-"Language: \n"
+"Language: lv_LV\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"X-Generator: KBabel 1.11.4\n"
-"Plural-Forms: nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n != 0 ? 1 : "
-"2);\n"
+"Plural-Forms: nplurals=3; plural=(n%10==1 && n%100!=11 ? 0 : n != 0 ? 1 : 2);\n"
-#: ../gui/wxpython/vnet/vnet_core.py:105
-msgid "Unable to perform analysis."
+#: ../gui/wxpython/psmap/toolbars.py:52
+msgid "Generate text file with mapping instructions"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:210
-#, python-format
-msgid "Temporary map '%s' with result "
+#: ../gui/wxpython/psmap/toolbars.py:54
+msgid "Load text file with mapping instructions"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:215
-msgid "Result changed outside"
+#: ../gui/wxpython/psmap/toolbars.py:56
+msgid "Generate PostScript output"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:252
-msgid "Map can be created only in current mapset"
+#: ../gui/wxpython/psmap/toolbars.py:58
+msgid "Generate PDF output"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:259 ../gui/wxpython/vnet/vnet_core.py:336
-#, python-format
-msgid "Vector map %s already exists. "
+#: ../gui/wxpython/psmap/toolbars.py:60 ../gui/wxpython/gcp/mapdisplay.py:479
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:511
+#: ../gui/wxpython/gui_modules/wxplot.py:511
+#: ../gui/wxpython/gui_modules/histogram.py:433
+#: ../gui/wxpython/gui_modules/mapdisp.py:918
+#: ../gui/wxpython/modules/histogram.py:443 ../gui/wxpython/wxplot/base.py:504
+#: ../gui/wxpython/mapdisp/frame.py:595
+msgid "Page setup"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:262 ../gui/wxpython/vnet/vnet_core.py:339
-#, fuzzy
-msgid "Overwrite vector map"
-msgstr "Jauna vektoru karte"
-#: ../gui/wxpython/vnet/vnet_core.py:288
-msgid "Creation of turntable failed."
+#: ../gui/wxpython/psmap/toolbars.py:61
+msgid "Specify paper size, margins and orientation"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:308
-msgid "Vector map with analysis result does not exist."
+#: ../gui/wxpython/psmap/toolbars.py:63
+msgid "Full extent"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:329
-msgid "Map can be saved only to currently set mapset"
+#: ../gui/wxpython/psmap/toolbars.py:64
+msgid "Zoom to full extent"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:408 ../gui/wxpython/vnet/vnet_core.py:608
-#, python-format
-msgid "Please choose '%s' and '%s' point."
+#: ../gui/wxpython/psmap/toolbars.py:66 ../gui/wxpython/psmap/dialogs.py:618
+#: ../gui/wxpython/psmap/dialogs.py:673
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2243
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2298
+msgid "Map frame"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:615
-msgid "Please choose at least two points."
+#: ../gui/wxpython/psmap/toolbars.py:67
+msgid "Click and drag to place map frame"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:894
-#, python-format
-msgid "Input map '%s' for analysis was changed outside "
+#: ../gui/wxpython/psmap/toolbars.py:69
+msgid "Delete selected object"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:899
-msgid "Input changed outside"
+#: ../gui/wxpython/psmap/toolbars.py:71
+msgid "Show preview"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:974
-#, python-format
-msgid "Temporary map %s already exists.\n"
+#: ../gui/wxpython/psmap/toolbars.py:73
+msgid "Quit Cartographic Composer"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1000
-msgid "Unable to use ctypes. \n"
-msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:75 ../gui/wxpython/psmap/dialogs.py:3705
+#: ../gui/wxpython/psmap/dialogs.py:3710
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5302
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5307
+msgid "Text"
+msgstr "Teksts"
-#: ../gui/wxpython/vnet/vnet_core.py:1001
-#: ../gui/wxpython/vnet/vnet_core.py:1023
-msgid "Snapping mode can not be activated."
-msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:77
+msgid "Map info"
+msgstr "Kartes informācija"
-#: ../gui/wxpython/vnet/vnet_core.py:1032
-msgid "Do you really want to activate snapping and overwrite it?"
-msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:79
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:873
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:916
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:967
+#: ../gui/wxpython/wxplot/dialogs.py:874 ../gui/wxpython/wxplot/dialogs.py:917
+#: ../gui/wxpython/wxplot/dialogs.py:968
+msgid "Legend"
+msgstr "Leģenda"
-#: ../gui/wxpython/vnet/vnet_core.py:1039
-#, python-format
-msgid "Temporary map '%s' was changed outside "
-msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:81 ../gui/wxpython/nviz/tools.py:1957
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2116
+msgid "Scale bar"
+msgstr "Mērogjosla"
-#: ../gui/wxpython/vnet/vnet_core.py:1044
-msgid "Overwrite map"
-msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:83 ../gui/wxpython/psmap/dialogs.py:4061
+#: ../gui/wxpython/psmap/dialogs.py:4109
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5658
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5706
+msgid "Image"
+msgstr "Attēls"
-#: ../gui/wxpython/vnet/widgets.py:85 ../gui/wxpython/vnet/vnet_data.py:237
-#: ../gui/wxpython/gcp/manager.py:1948 ../gui/wxpython/gcp/manager.py:1965
-msgid "use"
-msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:85 ../gui/wxpython/psmap/dialogs.py:4490
+#: ../gui/wxpython/nviz/tools.py:1912
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:6085
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2074
+#: ../gui/wxpython/mapdisp/toolbars.py:35
+msgid "North Arrow"
+msgstr "Ziemeļu bulta"
-#: ../gui/wxpython/vnet/widgets.py:372
-msgid "Invalid value inserted. Operation canceled."
+#: ../gui/wxpython/psmap/toolbars.py:87
+msgid "Add simple graphics"
msgstr ""
-#: ../gui/wxpython/vnet/widgets.py:518
-msgid "Edit point"
-msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:89 ../gui/wxpython/psmap/dialogs.py:4522
+#: ../gui/wxpython/gui_modules/gselect.py:1810
+#: ../gui/wxpython/gui_modules/vdigit.py:548
+#: ../gui/wxpython/gui_core/gselect.py:1885
+#: ../gui/wxpython/vdigit/preferences.py:516
+msgid "Point"
+msgstr "Punkts"
-#: ../gui/wxpython/vnet/toolbars.py:50
-msgid "Insert points from Map Display"
-msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:91
+#: ../gui/wxpython/gui_modules/vdigit.py:549
+#: ../gui/wxpython/vdigit/preferences.py:517
+msgid "Line"
+msgstr "Līnija"
-#: ../gui/wxpython/vnet/toolbars.py:52
-msgid "Activate snapping to nodes"
-msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:93
+msgid "Rectangle"
+msgstr "Taisnstūris"
-#: ../gui/wxpython/vnet/toolbars.py:54
-msgid "Activate mode for turns editing"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:56
-msgid "Activate mode for global turns editing"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:58
-msgid "Add new point"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:60
-msgid "Delete selected point"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:110
-msgid "Execute analysis"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:112
-msgid "Go to previous analysis result"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:114
-msgid "Go to next analysis result"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:116
-msgid "Show analysis result"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:118
-msgid "Save temporary result"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:119
-#, fuzzy
-msgid "Vector network analysis settings"
-msgstr "Vektoru iestatījumi"
-#: ../gui/wxpython/vnet/toolbars.py:121
-#: ../gui/wxpython/gui_core/toolbars.py:69
-#: ../gui/wxpython/iscatt/toolbars.py:46
-msgid "Show manual"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:184
-msgid "Availiable analyses"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:144
+#: ../gui/wxpython/psmap/instructions.py:133
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:337
#, python-format
-msgid "Module <%s> does not support turns costs."
+msgid ""
+"Unable to open file\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:150
+#: ../gui/wxpython/psmap/instructions.py:460
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:643
#, python-format
-msgid "Vector map '%s' does not exist."
+msgid "Instruction file will be loaded with following region: %s\n"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:152
-msgid "Vector map was not chosen."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:161
-#, fuzzy
-msgid "arc layer"
-msgstr "Kartes slāņi"
-#: ../gui/wxpython/vnet/vnet_data.py:162
-msgid "node layer"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:163
-#, fuzzy
-msgid "turntable layer"
-msgstr "Saglabāt kā"
-#: ../gui/wxpython/vnet/vnet_data.py:164
-msgid "unique categories layer"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:170
+#: ../gui/wxpython/psmap/instructions.py:465
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:648
#, python-format
-msgid "Chosen %s '%s' does not exist in vector map '%s'.\n"
+msgid ""
+"Region cannot be set\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:173
+#: ../gui/wxpython/psmap/instructions.py:604
+#: ../gui/wxpython/psmap/instructions.py:754
+#: ../gui/wxpython/psmap/instructions.py:870
+#: ../gui/wxpython/psmap/instructions.py:928
+#: ../gui/wxpython/psmap/instructions.py:1069
+#: ../gui/wxpython/psmap/instructions.py:1124
+#: ../gui/wxpython/psmap/instructions.py:1183
+#: ../gui/wxpython/psmap/instructions.py:1252
+#: ../gui/wxpython/psmap/instructions.py:1358
+#: ../gui/wxpython/psmap/instructions.py:1483
+#: ../gui/wxpython/psmap/instructions.py:1534
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:779
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:929
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1043
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1107
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1256
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1362
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1487
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1538
#, python-format
-msgid "Choose existing %s.\n"
+msgid "Failed to read instruction %s"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:183
+#: ../gui/wxpython/psmap/instructions.py:618
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:793
#, python-format
msgid ""
-"Chosen column '%s' does not exist in attribute table of layer '%s' of vector "
-"map '%s'.\n"
+"Scale has changed, old value: %(old)s\n"
+"new value: %(new)s"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:237
-msgid "type"
-msgstr ""
-msgid "topology"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:238 ../gui/wxpython/vnet/vnet_data.py:684
-msgid "Start point"
-msgstr ""
-#, fuzzy
-msgid "End Point"
-msgstr "Punkts"
-#: ../gui/wxpython/vnet/vnet_data.py:491 ../gui/wxpython/vnet/vnet_data.py:500
-#: ../gui/wxpython/vnet/vnet_data.py:503
-msgid "new point"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:661
-msgid "Arc forward/both direction(s) cost column:"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:662
-msgid "arc forward/both"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:665
-msgid "Arc backward direction cost column:"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:666
-msgid "arc backward"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:669
-msgid "Arcs' cost column (for both directions):"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:670
-msgid "arc"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:674
-msgid "Node cost column:"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:675
-msgid "node"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:681
+#: ../gui/wxpython/psmap/instructions.py:621
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:796
#, python-format
-msgid "Shortest path %s"
+msgid ""
+"Failed to read instruction %s.\n"
+"Use 1:25000 notation."
msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:685
-msgid "End point"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:701
+#: ../gui/wxpython/psmap/instructions.py:629
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:804
#, python-format
-msgid "Traveling salesman %s"
+msgid ""
+"Map frame position changed, old value: %(old1)s %(old2)s\n"
+"new value: %(new1)s %(new2)s"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:717
+#: ../gui/wxpython/psmap/instructions.py:637
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:812
#, python-format
-msgid "Maximum flow %s"
+msgid ""
+"Map frame size changed, old value: %(old1)s %(old2)s\n"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:720
-msgid "Source point"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:721
-msgid "Sink point"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:736
+#: ../gui/wxpython/psmap/instructions.py:684
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:859
#, python-format
-msgid "Subnets for nearest centers %s"
+msgid ""
+"Failed to read instruction %(file)s.\n"
+"Unknown format %(for)s"
msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:752
+#: ../gui/wxpython/psmap/instructions.py:697
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:872
#, python-format
-msgid "Steiner tree for the network and given terminals %s"
+msgid "Failed to read instruction %s."
msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:766
+#: ../gui/wxpython/psmap/instructions.py:811
+#: ../gui/wxpython/psmap/instructions.py:1693
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:967
#, python-format
-msgid "Shortest distance via the network %s"
+msgid ""
+"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
+"which is required by module ps.map."
msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:785
-#, python-format
-msgid "Cost isolines %s"
+#: ../gui/wxpython/psmap/instructions.py:815
+#: ../gui/wxpython/psmap/instructions.py:1697
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:971
+msgid ""
+"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
+"required by module ps.map."
msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:871
-msgid "Overwrite map layer"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:67
-msgid "GRASS GIS Vector Network Analysis Tool"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:165
-msgid "Point list toolbar"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:172
-msgid "Analysis toolbar"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:203
-msgid "Points for analysis:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:206
-#, fuzzy
-msgid "Points"
-msgstr "Punkts"
-#: ../gui/wxpython/vnet/dialogs.py:219
-#, fuzzy
-msgid "Analysis settings:"
-msgstr "Rastra iestatījumi"
-#: ../gui/wxpython/vnet/dialogs.py:222
-msgid "Maximum distance of point to the network:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:234
-#, fuzzy
-msgid "Iso lines:"
-msgstr "Rindas:"
-#: ../gui/wxpython/vnet/dialogs.py:302
-#: ../gui/wxpython/modules/mcalc_builder.py:130
-#: ../gui/wxpython/scripts/vkrige.py:117
-msgid "Output"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:319
-#: ../gui/wxpython/location_wizard/wizard.py:1335
-msgid "Parameters"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:350
-msgid "Add vector map into layer tree"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:469
-msgid "Input tables"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:495
-#, fuzzy
-msgid "Result tables"
-msgstr "Jauna tabula"
-#: ../gui/wxpython/vnet/dialogs.py:507
-msgid "Loading tables..."
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:640
-msgid "Creating turntable..."
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:793
-msgid "Input vector map does not exists."
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:811
-msgid "Analysing..."
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:867 ../gui/wxpython/nviz/tools.py:1892
-#: ../gui/wxpython/gui_core/widgets.py:943
-#: ../gui/wxpython/gui_core/toolbars.py:82
-#: ../gui/wxpython/iscatt/toolbars.py:44
-#: ../gui/wxpython/iscatt/toolbars.py:135
-msgid "Settings"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:934
-msgid "Computing nodes..."
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1129
+#: ../gui/wxpython/psmap/instructions.py:931
#, python-format
-msgid "Color table style %s:"
+msgid "Failed to read instruction %(inst)s: file %(file)s not found."
msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1140
-#, python-format
-msgid "Invert colors %s:"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:197
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1822
+msgid "Units:"
+msgstr "Mērvienības:"
-#: ../gui/wxpython/vnet/dialogs.py:1145
-#, fuzzy
-msgid "Line color:"
-msgstr "Izvēlieties krāsu:"
-#: ../gui/wxpython/vnet/dialogs.py:1146
-msgid "Color for unused point:"
+#: ../gui/wxpython/psmap/dialogs.py:206
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1831
+msgid ""
+"Position of the top left corner\n"
+"from the top left edge of the paper"
msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1147
-msgid "Color for Start/From/Source/Used point:"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:207
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1832
+msgid "X:"
+msgstr "X:"
-#: ../gui/wxpython/vnet/dialogs.py:1148
-msgid "Color for End/To/Sink point:"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:208
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1833
+msgid "Y:"
+msgstr "Y:"
-#: ../gui/wxpython/vnet/dialogs.py:1149
-msgid "Color for selected point:"
+#: ../gui/wxpython/psmap/dialogs.py:220
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1845
+msgid "Position is given:"
msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1162
-#: ../gui/wxpython/gui_core/preferences.py:1030
-#: ../gui/wxpython/psmap/dialogs.py:4900 ../gui/wxpython/gcp/manager.py:2563
-msgid "Line width:"
+#: ../gui/wxpython/psmap/dialogs.py:221
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1846
+msgid "relatively to paper"
msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1163
-#, fuzzy
-msgid "Point size:"
-msgstr "Fonta izmērs:"
-#: ../gui/wxpython/vnet/dialogs.py:1164
-msgid "Point width:"
+#: ../gui/wxpython/psmap/dialogs.py:222
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1847
+msgid "by map coordinates"
msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1165 ../gui/wxpython/iscatt/dialogs.py:341
-msgid "Snapping treshold in pixels:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1166
-msgid "Maximum number of results in history:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1184
-#: ../gui/wxpython/gui_core/preferences.py:90
-#: ../gui/wxpython/wxplot/dialogs.py:686
-#: ../gui/wxpython/wxplot/dialogs.py:1135 ../gui/wxpython/gcp/manager.py:2406
-#: ../gui/wxpython/iscatt/dialogs.py:360
-msgid "Apply changes for the current session"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1186
-#: ../gui/wxpython/gui_core/preferences.py:92
-#: ../gui/wxpython/wxplot/dialogs.py:691
-#: ../gui/wxpython/wxplot/dialogs.py:1137 ../gui/wxpython/gcp/manager.py:2408
-#: ../gui/wxpython/iscatt/dialogs.py:362
+#: ../gui/wxpython/psmap/dialogs.py:238
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1863
msgid ""
-"Apply and save changes to user settings file (default for next sessions)"
+"Position from the top left\n"
+"edge of the paper"
msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1188
-#: ../gui/wxpython/web_services/dialogs.py:131
-#: ../gui/wxpython/web_services/dialogs.py:817
-#: ../gui/wxpython/gui_core/dialogs.py:1560
-#: ../gui/wxpython/gui_core/dialogs.py:1852
-#: ../gui/wxpython/gcp/manager.py:2410 ../gui/wxpython/iscatt/dialogs.py:364
-msgid "Close dialog"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:290
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1915
+msgid "Font:"
+msgstr "Fonts:"
-#: ../gui/wxpython/vnet/dialogs.py:1198
-msgid "Analysis result style:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1228
-#, fuzzy
-msgid "Point style:"
+#: ../gui/wxpython/psmap/dialogs.py:291 ../gui/wxpython/psmap/dialogs.py:3555
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1916
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5152
+#: ../gui/wxpython/gui_modules/preferences.py:2319
+#: ../gui/wxpython/gui_core/preferences.py:1516
+msgid "Font size:"
-#: ../gui/wxpython/vnet/dialogs.py:1250
-#, fuzzy
-msgid "Other settings"
+#: ../gui/wxpython/psmap/dialogs.py:304
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1929
+msgid "Choose color:"
+msgstr "Izvēlieties krāsu:"
-#: ../gui/wxpython/vnet/dialogs.py:1325
-#, fuzzy
-msgid "New vector map with turntable"
+#: ../gui/wxpython/psmap/dialogs.py:352
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1977
+msgid "Close dialog and apply changes"
+msgstr "Pielietot izmaiņas un aizvērt dialogu"
-#: ../gui/wxpython/vnet/dialogs.py:1464
-msgid "Save analysis result"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:354
+#: ../gui/wxpython/gmodeler/preferences.py:452
+#: ../gui/wxpython/gui_modules/gmodeler.py:3819
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1979
+#: ../gui/wxpython/gui_modules/preferences.py:1111
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:672
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1114
+#: ../gui/wxpython/gui_modules/vdigit.py:92
+#: ../gui/wxpython/gui_core/preferences.py:93
+#: ../gui/wxpython/wxplot/dialogs.py:673
+#: ../gui/wxpython/wxplot/dialogs.py:1115
+#: ../gui/wxpython/vdigit/preferences.py:58
+msgid "Close dialog and ignore changes"
+msgstr "Ignorēt izmaiņas un aizvērt dialogu"
-#: ../gui/wxpython/vnet/dialogs.py:1474
-#: ../gui/wxpython/animation/dialogs.py:301
-#: ../gui/wxpython/gui_core/widgets.py:1000
-#: ../gui/wxpython/gui_core/gselect.py:1346
-#: ../gui/wxpython/gui_core/gselect.py:1356
-#: ../gui/wxpython/gui_core/gselect.py:1357
-#: ../gui/wxpython/gmodeler/preferences.py:463
-msgid "Name:"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:358
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1983
+#: ../gui/wxpython/gui_modules/vdigit.py:929
+#: ../gui/wxpython/vdigit/dialogs.py:142
+msgid "Apply changes"
+msgstr "Pielietot izmaiņas"
-#: ../gui/wxpython/vnet/dialogs.py:1575
-msgid "Edit intersection turns costs"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:383
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2008
+msgid "Units"
+msgstr "Mērvienības"
-#: ../gui/wxpython/vnet/dialogs.py:1607
-msgid "Define Global Turn Costs"
-msgstr ""
+msgid "Format"
+msgstr "Formāts"
-#: ../gui/wxpython/nviz/tools.py:88 ../gui/wxpython/nviz/preferences.py:56
-#: ../gui/wxpython/nviz/preferences.py:61
-msgid "View"
-msgstr ""
+msgid "Orientation"
+msgstr "Orientācija"
-#: ../gui/wxpython/nviz/tools.py:92 ../gui/wxpython/animation/dialogs.py:339
-#: ../gui/wxpython/gmodeler/preferences.py:203
-msgid "Data"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:383 ../gui/wxpython/psmap/dialogs.py:2084
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3698
+msgid "Width"
+msgstr "Platums"
-#: ../gui/wxpython/nviz/tools.py:96
-#: ../gui/wxpython/gui_core/preferences.py:400
-msgid "Appearance"
-msgstr ""
+msgid "Height"
+msgstr "Augstums"
-#: ../gui/wxpython/nviz/tools.py:100
-msgid "Analysis"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:384
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2009
+msgid "Left"
+msgstr "Pa kreisi"
-#: ../gui/wxpython/nviz/tools.py:103 ../gui/wxpython/nviz/tools.py:385
-msgid "Animation"
-msgstr ""
+msgid "Right"
+msgstr "Pa labi"
-#: ../gui/wxpython/nviz/tools.py:226
-msgid "Control View"
-msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2287
+#: ../gui/wxpython/location_wizard/dialogs.py:231
+msgid "Top"
+msgstr "Augšā"
-#: ../gui/wxpython/nviz/tools.py:247
-msgid "Adjusts the distance and angular perspective of the image viewpoint"
-msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2295
+#: ../gui/wxpython/location_wizard/dialogs.py:239
+msgid "Bottom"
+msgstr "Lejā"
-#: ../gui/wxpython/nviz/tools.py:252 ../gui/wxpython/nviz/preferences.py:69
-msgid "Perspective:"
+#: ../gui/wxpython/psmap/dialogs.py:439
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2064
+msgid "Literal is not allowed!"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:260
-msgid "Tilts the plane of the surface from the horizontal"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:439 ../gui/wxpython/psmap/dialogs.py:1034
+#: ../gui/wxpython/psmap/dialogs.py:1056 ../gui/wxpython/psmap/dialogs.py:1106
+#: ../gui/wxpython/psmap/dialogs.py:3637
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2659
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2681
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2731
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5234
+#: ../gui/wxpython/wxplot/dialogs.py:477
+msgid "Invalid input"
+msgstr "Nederīga ievade"
-#: ../gui/wxpython/nviz/tools.py:264 ../gui/wxpython/nviz/tools.py:1024
-msgid "Tilt:"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:448
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2073
+msgid "Page size"
+msgstr "Lapas izmērs"
-#: ../gui/wxpython/nviz/tools.py:271
-msgid ""
-"Adjusts the viewing height above the surface (angle of view automatically "
-"adjusts to maintain the same center of view)"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:450
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2075
+msgid "Margins"
+msgstr "Malas"
-#: ../gui/wxpython/nviz/tools.py:276
-msgid "Adjusts the relative height of features above the plane of the surface"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:454
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2079
+msgid "Portrait"
+msgstr "Portrets"
-#: ../gui/wxpython/nviz/tools.py:284 ../gui/wxpython/nviz/tools.py:1040
-#: ../gui/wxpython/nviz/tools.py:1767 ../gui/wxpython/gui_core/dialogs.py:2246
-#: ../gui/wxpython/psmap/dialogs.py:2735 ../gui/wxpython/psmap/dialogs.py:2873
-#: ../gui/wxpython/psmap/dialogs.py:3476
-#: ../gui/wxpython/gmodeler/preferences.py:176
-#: ../gui/wxpython/gmodeler/preferences.py:295
-#: ../gui/wxpython/gmodeler/preferences.py:380
-msgid "Height:"
-msgstr ""
+msgid "Landscape"
+msgstr "Ainava"
-#: ../gui/wxpython/nviz/tools.py:290 ../gui/wxpython/nviz/preferences.py:150
-msgid "Z-exag:"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:506 ../gui/wxpython/psmap/dialogs.py:527
+#: ../gui/wxpython/gui_modules/location_wizard.py:1703
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2131
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2152
+#: ../gui/wxpython/location_wizard/wizard.py:1713
+msgid "custom"
+msgstr "pielāgots"
-#: ../gui/wxpython/nviz/tools.py:303
-msgid "Look:"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:556
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2181
+msgid "Map settings"
+msgstr "Kartes iestatījumi"
-#: ../gui/wxpython/nviz/tools.py:306
-msgid "here"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:562
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2187
+msgid "Map frame settings"
+msgstr "Kartes rāmja iestatījumi"
-#: ../gui/wxpython/nviz/tools.py:309
-msgid ""
-"Allows you to select a point on the surface that becomes the new center of "
-"view. Click on the button and then on the surface."
+#: ../gui/wxpython/psmap/dialogs.py:679
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2304
+msgid "Map frame options:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:315
-msgid "center"
+#: ../gui/wxpython/psmap/dialogs.py:680
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2305
+msgid "fit frame to match selected map"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:318
-msgid "Resets the view to the original default center of view"
+#: ../gui/wxpython/psmap/dialogs.py:681
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2306
+msgid "fit frame to match saved region"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:322
-msgid "top"
+#: ../gui/wxpython/psmap/dialogs.py:682
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2307
+msgid "fit frame to match current computational region"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:325
-msgid ""
-"Sets the viewer directly over the scene's center position. This top view "
-"orients approximately north south."
+#: ../gui/wxpython/psmap/dialogs.py:683
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2308
+msgid "fixed scale and map center"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:329
-msgid "reset"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:691 ../gui/wxpython/psmap/dialogs.py:859
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2316
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2484
+msgid "Map selection"
+msgstr "Kartes izvēle"
-#: ../gui/wxpython/nviz/tools.py:330
-msgid "Reset to default view"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:695 ../gui/wxpython/gcp/manager.py:325
+#: ../gui/wxpython/gmodeler/frame.py:1284
+#: ../gui/wxpython/lmgr/layertree.py:824
+#: ../gui/wxpython/gui_modules/gmodeler.py:4052
+#: ../gui/wxpython/gui_modules/gdialogs.py:1278
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2320
+#: ../gui/wxpython/gui_modules/layertree.py:806
+#: ../gui/wxpython/gui_modules/gcpmanager.py:329
+#: ../gui/wxpython/gui_core/dialogs.py:1299
+#: ../gui/wxpython/gui_core/dialogs.py:1526
+msgid "raster"
+msgstr "rastrs"
-#: ../gui/wxpython/nviz/tools.py:347 ../gui/wxpython/nviz/preferences.py:172
-msgid "Image Appearance"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:696 ../gui/wxpython/gcp/manager.py:325
+#: ../gui/wxpython/gmodeler/frame.py:1285
+#: ../gui/wxpython/lmgr/layertree.py:845
+#: ../gui/wxpython/gui_modules/gmodeler.py:4053
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2321
+#: ../gui/wxpython/gui_modules/layertree.py:827
+msgid "vector"
+msgstr "vektori"
-#: ../gui/wxpython/nviz/tools.py:354 ../gui/wxpython/nviz/preferences.py:178
-#: ../gui/wxpython/web_services/widgets.py:261
-#: ../gui/wxpython/gui_core/preferences.py:678
-msgid "Background color:"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:699 ../gui/wxpython/psmap/dialogs.py:1283
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2324
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2908
+msgid "Map:"
+msgstr "Karte:"
-#: ../gui/wxpython/nviz/tools.py:392
-msgid ""
-"Press 'Record' button and start changing the view. It is recommended to use "
-"fly-through mode (Map Display toolbar) to achieve smooth motion."
-msgstr ""
+msgid "Region:"
+msgstr "Reģions:"
-#: ../gui/wxpython/nviz/tools.py:403
-msgid "Record"
+#: ../gui/wxpython/psmap/dialogs.py:718
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2343
+msgid "Map scale and center"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:405
-msgid "Play"
+#: ../gui/wxpython/psmap/dialogs.py:723
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2348
+msgid "Center:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:407 ../gui/wxpython/animation/toolbars.py:31
-msgid "Pause"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:724
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2349
+msgid "E:"
+msgstr "E:"
-#: ../gui/wxpython/nviz/tools.py:409 ../gui/wxpython/animation/toolbars.py:30
-msgid "Stop"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:725
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2350
+msgid "N:"
+msgstr "N:"
-#: ../gui/wxpython/nviz/tools.py:421
-msgid "Total number of frames :"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:728 ../gui/wxpython/psmap/dialogs.py:4166
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2353
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5763
+msgid "Scale:"
+msgstr "Mērogs:"
-#: ../gui/wxpython/nviz/tools.py:425
-msgid "Frame rate (FPS):"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:729
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2354
+msgid "1 :"
+msgstr "1 :"
-#: ../gui/wxpython/nviz/tools.py:431
-msgid "Frames are recorded with given frequency (FPS). "
+#: ../gui/wxpython/psmap/dialogs.py:749
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2374
+msgid "Map max resolution (dpi):"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:474
-msgid "Save image sequence"
+#: ../gui/wxpython/psmap/dialogs.py:762 ../gui/wxpython/psmap/dialogs.py:2653
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2387
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4250
+msgid "Border"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:481 ../gui/wxpython/psmap/dialogs.py:4119
-msgid "Choose a directory:"
+#: ../gui/wxpython/psmap/dialogs.py:766
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2391
+msgid "draw border around map frame"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:482
-msgid "Choose a directory for images"
+#: ../gui/wxpython/psmap/dialogs.py:772
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2397
+msgid "border color:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:483 ../gui/wxpython/animation/dialogs.py:408
-#: ../gui/wxpython/animation/dialogs.py:967
-#: ../gui/wxpython/animation/dialogs.py:1051
-#: ../gui/wxpython/animation/dialogs.py:1074
-#: ../gui/wxpython/animation/dialogs.py:1091
-#: ../gui/wxpython/animation/dialogs.py:1108
-#: ../gui/wxpython/gui_core/gselect.py:1026
-#: ../gui/wxpython/gui_core/gselect.py:1296
-#: ../gui/wxpython/gui_core/gselect.py:1309
-#: ../gui/wxpython/gui_core/gselect.py:1348
-#: ../gui/wxpython/gui_core/gselect.py:1362
-#: ../gui/wxpython/gui_core/forms.py:1475
-#: ../gui/wxpython/gui_core/forms.py:1531
-#: ../gui/wxpython/gui_core/dialogs.py:1924
-#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
-#: ../gui/wxpython/psmap/dialogs.py:4121
-#: ../gui/wxpython/location_wizard/wizard.py:102
-#: ../gui/wxpython/location_wizard/wizard.py:1168
-#: ../gui/wxpython/location_wizard/wizard.py:1242
-#: ../gui/wxpython/location_wizard/wizard.py:1328
-msgid "Browse"
+#: ../gui/wxpython/psmap/dialogs.py:773
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2398
+msgid "border width (pts):"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:486 ../gui/wxpython/animation/dialogs.py:1039
-msgid "File prefix:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:490
+#: ../gui/wxpython/psmap/dialogs.py:867
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2492
msgid ""
-"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+"Region is set to match this map,\n"
+"raster or vector map must be added later"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:491 ../gui/wxpython/animation/dialogs.py:1041
-msgid "File format:"
+#: ../gui/wxpython/psmap/dialogs.py:874
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2499
+msgid "Region selection"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:546 ../gui/wxpython/nviz/tools.py:1859
-#: ../gui/wxpython/nviz/preferences.py:361
-msgid "Surface"
+#: ../gui/wxpython/psmap/dialogs.py:1033
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2658
+msgid "No map selected!"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:552 ../gui/wxpython/nviz/tools.py:1083
-msgid "Constant surface"
+#: ../gui/wxpython/psmap/dialogs.py:1055
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2680
+msgid "No region selected!"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:557 ../gui/wxpython/nviz/preferences.py:463
-msgid "Vector"
+#: ../gui/wxpython/psmap/dialogs.py:1105
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2730
+msgid "Invalid scale or map center!"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:563
-msgid "Volume"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:598 ../gui/wxpython/nviz/preferences.py:253
-msgid "Lighting"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:603
-msgid "Fringe"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:610 ../gui/wxpython/animation/dialogs.py:869
-msgid "Decorations"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:630 ../gui/wxpython/nviz/tools.py:941
-msgid "Cutting planes"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:652 ../gui/wxpython/nviz/mapwindow.py:1672
-#: ../gui/wxpython/lmgr/layertree.py:738 ../gui/wxpython/menustrings.py:1738
-#: ../gui/wxpython/psmap/dialogs.py:1144
+#: ../gui/wxpython/psmap/dialogs.py:1143 ../gui/wxpython/nviz/tools.py:636
+#: ../gui/wxpython/nviz/mapwindow.py:1624
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2768
+#: ../gui/wxpython/gui_modules/nviz_tools.py:806
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1613
msgid "Raster map"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:675 ../gui/wxpython/nviz/tools.py:1552
-#: ../gui/wxpython/nviz/preferences.py:368
-#: ../gui/wxpython/timeline/frame.py:118
-msgid "Draw"
+#: ../gui/wxpython/psmap/dialogs.py:1165
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2790
+msgid "Choose raster map"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:681 ../gui/wxpython/nviz/tools.py:1559
-#: ../gui/wxpython/nviz/preferences.py:374
-msgid "Mode:"
+#: ../gui/wxpython/psmap/dialogs.py:1169
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2794
+msgid "no raster map"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:684 ../gui/wxpython/nviz/preferences.py:377
-msgid "coarse"
+#: ../gui/wxpython/psmap/dialogs.py:1170
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2795
+msgid "raster:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:685 ../gui/wxpython/nviz/preferences.py:378
-msgid "fine"
+#: ../gui/wxpython/psmap/dialogs.py:1210 ../gui/wxpython/psmap/frame.py:548
+#: ../gui/wxpython/psmap/frame.py:571 ../gui/wxpython/gui_modules/psmap.py:549
+#: ../gui/wxpython/gui_modules/psmap.py:572
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2835
+msgid "Please, create map frame first."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:686 ../gui/wxpython/nviz/preferences.py:379
-msgid "both"
+#: ../gui/wxpython/psmap/dialogs.py:1270 ../gui/wxpython/gmodeler/model.py:669
+#: ../gui/wxpython/gui_modules/gmodeler.py:696
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2895
+msgid "Vector maps"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:695 ../gui/wxpython/nviz/tools.py:957
-#: ../gui/wxpython/nviz/tools.py:1573
-msgid "Shading:"
+#: ../gui/wxpython/psmap/dialogs.py:1279
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2904
+msgid "Add map"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:698 ../gui/wxpython/nviz/tools.py:1298
-#: ../gui/wxpython/nviz/tools.py:1576
-msgid "flat"
+#: ../gui/wxpython/psmap/dialogs.py:1287 ../gui/wxpython/psmap/dialogs.py:1651
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2912
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3272
+msgid "points"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:699 ../gui/wxpython/nviz/tools.py:1577
-msgid "gouraud"
+#: ../gui/wxpython/psmap/dialogs.py:1287 ../gui/wxpython/psmap/dialogs.py:1653
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3274
+msgid "lines"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:707
-msgid "Set to all"
+msgid "areas"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:708
-msgid "Use draw settings for all loaded surfaces"
+#: ../gui/wxpython/psmap/dialogs.py:1289
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2913
+msgid "Data Type"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:716 ../gui/wxpython/nviz/preferences.py:406
-msgid "Coarse mode:"
+#: ../gui/wxpython/psmap/dialogs.py:1292
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2915
+#: ../gui/wxpython/gui_modules/dbm.py:915
+msgid "Add"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:719 ../gui/wxpython/nviz/tools.py:759
-#: ../gui/wxpython/nviz/preferences.py:393
-#: ../gui/wxpython/nviz/preferences.py:410
-msgid "resolution:"
+#: ../gui/wxpython/psmap/dialogs.py:1304
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2927
+msgid "Manage vector maps"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:732 ../gui/wxpython/nviz/preferences.py:422
-msgid "style:"
+#: ../gui/wxpython/psmap/dialogs.py:1312
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2935
+msgid "The topmost vector map overlaps the others"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:735 ../gui/wxpython/nviz/preferences.py:425
-msgid "wire"
+#: ../gui/wxpython/psmap/dialogs.py:1314 ../gui/wxpython/psmap/dialogs.py:2636
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2937
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4233
+msgid "Up"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:736 ../gui/wxpython/nviz/preferences.py:426
-msgid "surface"
+#: ../gui/wxpython/psmap/dialogs.py:1315 ../gui/wxpython/psmap/dialogs.py:2637
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2938
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4234
+msgid "Down"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:748
-msgid "Change wire color"
+#: ../gui/wxpython/psmap/dialogs.py:1316 ../gui/wxpython/menustrings.py:171
+#: ../gui/wxpython/nviz/tools.py:1078 ../gui/wxpython/nviz/tools.py:1942
+#: ../gui/wxpython/nviz/tools.py:1990
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2939
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1248
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2104
+msgid "Delete"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:755 ../gui/wxpython/nviz/preferences.py:389
-msgid "Fine mode:"
+#: ../gui/wxpython/psmap/dialogs.py:1317
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2940
+msgid "Properties..."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:781
-msgid "Surface attributes"
+#: ../gui/wxpython/psmap/dialogs.py:1517
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3139
+msgid "Raster map settings"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:788 ../gui/wxpython/nviz/tools.py:2399
-#: ../gui/wxpython/psmap/dialogs.py:4597 ../gui/wxpython/psmap/dialogs.py:4852
-#: ../gui/wxpython/iclass/dialogs.py:370 ../gui/wxpython/wxplot/dialogs.py:918
-#: ../gui/wxpython/wxplot/dialogs.py:968
-#: ../gui/wxpython/gmodeler/preferences.py:89
-#: ../gui/wxpython/gmodeler/preferences.py:327
-msgid "Color"
+#: ../gui/wxpython/psmap/dialogs.py:1554
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3176
+msgid "Vector maps settings"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:789 ../gui/wxpython/nviz/tools.py:2400
-#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:994
-#: ../gui/wxpython/psmap/dialogs.py:1727
-msgid "Mask"
+#: ../gui/wxpython/psmap/dialogs.py:1589
+#, python-format
+msgid "%s properties"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:790 ../gui/wxpython/nviz/tools.py:2401
-msgid "Transparency"
+#: ../gui/wxpython/psmap/dialogs.py:1640
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3261
+msgid "Data selection"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:791 ../gui/wxpython/nviz/tools.py:2402
-msgid "Shininess"
+#: ../gui/wxpython/psmap/dialogs.py:1647
+#: ../gui/wxpython/gui_modules/gdialogs.py:1505
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3268
+#: ../gui/wxpython/gui_core/dialogs.py:1595
+msgid "Feature type"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:797 ../gui/wxpython/nviz/tools.py:2413
-msgid "map"
+#: ../gui/wxpython/psmap/dialogs.py:1651
+msgid "centroids"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:800 ../gui/wxpython/nviz/tools.py:2418
-msgid "unset"
+#: ../gui/wxpython/psmap/dialogs.py:1653
+msgid "boundaries"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:805 ../gui/wxpython/nviz/tools.py:2423
-msgid "constant"
+#: ../gui/wxpython/psmap/dialogs.py:1669
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3290
+msgid "Layer selection"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:857 ../gui/wxpython/nviz/tools.py:1676
-#: ../gui/wxpython/psmap/dialogs.py:2705 ../gui/wxpython/psmap/dialogs.py:3246
-#: ../gui/wxpython/psmap/dialogs.py:3441 ../gui/wxpython/psmap/dialogs.py:3815
-#: ../gui/wxpython/psmap/dialogs.py:3819 ../gui/wxpython/psmap/dialogs.py:4221
-#: ../gui/wxpython/psmap/dialogs.py:4226 ../gui/wxpython/psmap/dialogs.py:4679
-#: ../gui/wxpython/psmap/dialogs.py:4684
-msgid "Position"
+#: ../gui/wxpython/psmap/dialogs.py:1675
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3296
+msgid "Database connection is not defined in DB file."
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:862
-msgid "Changes the x, y, and z position of the current surface"
+#: ../gui/wxpython/psmap/dialogs.py:1676
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3297
+msgid "Select layer:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:872 ../gui/wxpython/nviz/tools.py:1059
-#: ../gui/wxpython/nviz/tools.py:1690 ../gui/wxpython/nviz/tools.py:2583
-msgid "Reset"
+#: ../gui/wxpython/psmap/dialogs.py:1699
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
+msgid "list of categories (e.g. 1,3,5-7)"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:873 ../gui/wxpython/nviz/tools.py:1691
-msgid "Reset to default position"
+#: ../gui/wxpython/psmap/dialogs.py:1726 ../gui/wxpython/menustrings.py:322
+#: ../gui/wxpython/nviz/tools.py:774 ../gui/wxpython/nviz/tools.py:2340
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3347
+#: ../gui/wxpython/gui_modules/nviz_tools.py:944
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2492
+msgid "Mask"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:947
-msgid "Active cutting plane:"
+#: ../gui/wxpython/psmap/dialogs.py:1729
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3350
+msgid "Use current mask"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:959
-msgid "clear"
+#: ../gui/wxpython/psmap/dialogs.py:1746 ../gui/wxpython/psmap/dialogs.py:1845
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3367
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3466
+msgid "Colors"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:960
-msgid "top color"
+#: ../gui/wxpython/psmap/dialogs.py:1751 ../gui/wxpython/psmap/dialogs.py:1850
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3372
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3471
+msgid "Outline"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:961
-msgid "bottom color"
+#: ../gui/wxpython/psmap/dialogs.py:1755 ../gui/wxpython/psmap/dialogs.py:1859
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3376
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3480
+msgid "draw outline"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:962
-msgid "blend"
+#: ../gui/wxpython/psmap/dialogs.py:1758 ../gui/wxpython/psmap/dialogs.py:1863
+#: ../gui/wxpython/psmap/dialogs.py:3750 ../gui/wxpython/psmap/dialogs.py:3755
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3379
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3484
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5347
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5352
+msgid "Width (pts):"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:963
-msgid "shaded"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:975
-msgid "Horizontal X:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:977
-msgid "Sets the X coordinate of the current cutting plane"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:991
-msgid "Horizontal Y:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:993
-msgid "Sets the Y coordinate of the current cutting plane"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1008
-#: ../gui/wxpython/mapwin/decorations.py:335
-msgid "Rotation:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1010
-msgid "Rotates the current cutting plane about vertical axis"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1026
-msgid "Rotates the current cutting plane about horizontal axis"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1042
-msgid ""
-"Sets the Z coordinate of the current cutting plane (only meaningful when "
-"tilt is not 0)"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1094 ../gui/wxpython/menustrings.py:5
-#: ../gui/wxpython/menustrings.py:1673
-msgid "New"
-msgstr "Jauns"
-#: ../gui/wxpython/nviz/tools.py:1098 ../gui/wxpython/nviz/tools.py:1976
-#: ../gui/wxpython/nviz/tools.py:2024 ../gui/wxpython/menustrings.py:179
-#: ../gui/wxpython/menustrings.py:1754 ../gui/wxpython/psmap/dialogs.py:1315
-msgid "Delete"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1111
-msgid "Fine resolution:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1123
-msgid "Value:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1135 ../gui/wxpython/nviz/tools.py:2572
-msgid "Transparency:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1147 ../gui/wxpython/nviz/tools.py:1789
-#: ../gui/wxpython/nviz/tools.py:1910 ../gui/wxpython/nviz/preferences.py:334
-#: ../gui/wxpython/nviz/preferences.py:491
-#: ../gui/wxpython/nviz/preferences.py:545
-#: ../gui/wxpython/gui_core/preferences.py:1093
-#: ../gui/wxpython/psmap/dialogs.py:1777 ../gui/wxpython/psmap/dialogs.py:1880
-#: ../gui/wxpython/gcp/manager.py:2472
+#: ../gui/wxpython/psmap/dialogs.py:1776 ../gui/wxpython/psmap/dialogs.py:1879
+#: ../gui/wxpython/gcp/manager.py:2447 ../gui/wxpython/nviz/tools.py:1127
+#: ../gui/wxpython/nviz/tools.py:1757 ../gui/wxpython/nviz/tools.py:1876
+#: ../gui/wxpython/nviz/preferences.py:333
+#: ../gui/wxpython/nviz/preferences.py:490
+#: ../gui/wxpython/nviz/preferences.py:544
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3397
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3500
+#: ../gui/wxpython/gui_modules/preferences.py:1874
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:331
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:488
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:542
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1297
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1919
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2038
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2450
+#: ../gui/wxpython/gui_core/preferences.py:1048
msgid "Color:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1177 ../gui/wxpython/lmgr/layertree.py:741
-#: ../gui/wxpython/menustrings.py:1740 ../gui/wxpython/psmap/dialogs.py:2617
-msgid "Vector map"
+#: ../gui/wxpython/psmap/dialogs.py:1795 ../gui/wxpython/psmap/dialogs.py:1899
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3416
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3520
+msgid "Fill"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1201
-msgid "Show vector lines"
+#: ../gui/wxpython/psmap/dialogs.py:1799
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3420
+msgid "fill color"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1211 ../gui/wxpython/nviz/preferences.py:469
-msgid "Vector lines"
+#: ../gui/wxpython/psmap/dialogs.py:1802 ../gui/wxpython/psmap/dialogs.py:1905
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3423
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3526
+msgid "choose color:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1217
-msgid "Line:"
+#: ../gui/wxpython/psmap/dialogs.py:1814 ../gui/wxpython/psmap/dialogs.py:1918
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3435
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3539
+msgid "color from map table column:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1220
-msgid "width:"
+#: ../gui/wxpython/psmap/dialogs.py:1861
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3482
+msgid "No effect for fill color from table column"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1236 ../gui/wxpython/nviz/tools.py:1387
-msgid "color:"
+#: ../gui/wxpython/psmap/dialogs.py:1903
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3524
+msgid "Color of lines:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1252 ../gui/wxpython/nviz/tools.py:1432
-msgid "use color for thematic mapping"
+#: ../gui/wxpython/psmap/dialogs.py:1948 ../gui/wxpython/psmap/dialogs.py:2079
+#: ../gui/wxpython/psmap/dialogs.py:2148
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3569
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3693
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3762
+msgid "Size and style"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1254
-msgid "use width for thematic mapping"
+#: ../gui/wxpython/psmap/dialogs.py:1953 ../gui/wxpython/gcp/manager.py:2406
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3574
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2409
+#: ../gui/wxpython/gui_modules/vdigit.py:114
+#: ../gui/wxpython/vdigit/preferences.py:80
+msgid "Symbology"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1267 ../gui/wxpython/nviz/tools.py:1279
-#: ../gui/wxpython/nviz/tools.py:1445 ../gui/wxpython/nviz/tools.py:1454
-msgid "Set options..."
+#: ../gui/wxpython/psmap/dialogs.py:1958 ../gui/wxpython/nviz/tools.py:1396
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3579
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1566
+msgid "symbol:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1292 ../gui/wxpython/nviz/tools.py:1466
-#: ../gui/wxpython/vdigit/preferences.py:129
-msgid "Display"
+#: ../gui/wxpython/psmap/dialogs.py:1967
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3585
+msgid "eps file:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1297 ../gui/wxpython/nviz/tools.py:4848
-msgid "on surface(s):"
+#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
+#: ../gui/wxpython/psmap/dialogs.py:4121 ../gui/wxpython/nviz/tools.py:467
+#: ../gui/wxpython/gui_modules/gselect.py:882
+#: ../gui/wxpython/gui_modules/gselect.py:1170
+#: ../gui/wxpython/gui_modules/gselect.py:1179
+#: ../gui/wxpython/gui_modules/gselect.py:1188
+#: ../gui/wxpython/gui_modules/gselect.py:1459
+#: ../gui/wxpython/gui_modules/gselect.py:1643
+#: ../gui/wxpython/gui_modules/location_wizard.py:134
+#: ../gui/wxpython/gui_modules/location_wizard.py:1138
+#: ../gui/wxpython/gui_modules/location_wizard.py:1212
+#: ../gui/wxpython/gui_modules/location_wizard.py:1295
+#: ../gui/wxpython/gui_modules/gdialogs.py:1910
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3589
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3774
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5718
+#: ../gui/wxpython/gui_modules/menuform.py:1367
+#: ../gui/wxpython/gui_modules/menuform.py:1422
+#: ../gui/wxpython/gui_modules/nviz_tools.py:634
+#: ../gui/wxpython/location_wizard/wizard.py:98
+#: ../gui/wxpython/location_wizard/wizard.py:1148
+#: ../gui/wxpython/location_wizard/wizard.py:1222
+#: ../gui/wxpython/location_wizard/wizard.py:1305
+#: ../gui/wxpython/gui_core/gselect.py:881
+#: ../gui/wxpython/gui_core/gselect.py:1191
+#: ../gui/wxpython/gui_core/gselect.py:1200
+#: ../gui/wxpython/gui_core/gselect.py:1209
+#: ../gui/wxpython/gui_core/gselect.py:1527
+#: ../gui/wxpython/gui_core/gselect.py:1725
+#: ../gui/wxpython/gui_core/forms.py:1351
+#: ../gui/wxpython/gui_core/forms.py:1407
+#: ../gui/wxpython/gui_core/dialogs.py:2014
+msgid "Browse"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1307 ../gui/wxpython/nviz/tools.py:1474
-msgid "Height above surface:"
+msgid "Type filename or click browse to choose file"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1343
-msgid "Show vector points"
+#: ../gui/wxpython/psmap/dialogs.py:1972 ../gui/wxpython/psmap/dialogs.py:2161
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3590
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3775
+msgid "Choose a file"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1352 ../gui/wxpython/nviz/preferences.py:509
-msgid "Vector points"
+#: ../gui/wxpython/psmap/dialogs.py:1995 ../gui/wxpython/psmap/dialogs.py:2706
+#: ../gui/wxpython/psmap/dialogs.py:3471
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3609
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4303
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5068
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:899
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:950
+#: ../gui/wxpython/wxplot/dialogs.py:900 ../gui/wxpython/wxplot/dialogs.py:951
+msgid "Size"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1359
-msgid "Icon:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1362 ../gui/wxpython/psmap/dialogs.py:2000
+#: ../gui/wxpython/psmap/dialogs.py:2000 ../gui/wxpython/nviz/tools.py:1346
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3614
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1516
msgid "size:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1419 ../gui/wxpython/psmap/dialogs.py:1958
-msgid "symbol:"
+#: ../gui/wxpython/psmap/dialogs.py:2002
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3616
+msgid "size from map table column:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1434
-msgid "use size for thematic mapping"
+#: ../gui/wxpython/psmap/dialogs.py:2004
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3618
+msgid "scale:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1529 ../gui/wxpython/lmgr/layertree.py:744
-msgid "3D raster map"
+#: ../gui/wxpython/psmap/dialogs.py:2036
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3650
+msgid "Rotation"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1562
-msgid "isosurfaces"
+#: ../gui/wxpython/psmap/dialogs.py:2042
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3656
+msgid "rotate symbols:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1563
-msgid "slices"
+#: ../gui/wxpython/psmap/dialogs.py:2043
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3657
+msgid "counterclockwise in degrees:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1586
-msgid "Resolution:"
+#: ../gui/wxpython/psmap/dialogs.py:2045
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3659
+msgid "from map table column:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1600
-msgid "Draw wire box"
+#: ../gui/wxpython/psmap/dialogs.py:2088
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3702
+msgid "Set width (pts):"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1616 ../gui/wxpython/nviz/tools.py:3754
-msgid "List of isosurfaces"
+#: ../gui/wxpython/psmap/dialogs.py:2097
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3711
+msgid "multiply width by category value"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1732
-msgid "Show light model"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2114 ../gui/wxpython/psmap/dialogs.py:4893
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3728
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:864
+#: ../gui/wxpython/wxplot/dialogs.py:865
+msgid "Line style"
+msgstr "Līnijas stils"
-#: ../gui/wxpython/nviz/tools.py:1745
-msgid "Light source position"
+#: ../gui/wxpython/psmap/dialogs.py:2118
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3732
+msgid "Choose line style:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1761
-msgid "Adjusts the light height"
+#: ../gui/wxpython/psmap/dialogs.py:2128
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3742
+msgid "Choose linecap:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1785
-msgid "Light color and intensity"
+#: ../gui/wxpython/psmap/dialogs.py:2153
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3767
+msgid "Pattern"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1799 ../gui/wxpython/nviz/preferences.py:307
-msgid "Brightness:"
+#: ../gui/wxpython/psmap/dialogs.py:2158
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3772
+msgid "use pattern:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1801
-msgid "Adjusts the brightness of the light"
+#: ../gui/wxpython/psmap/dialogs.py:2159
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3773
+msgid "Choose pattern file:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1810 ../gui/wxpython/nviz/preferences.py:321
-msgid "Ambient:"
+#: ../gui/wxpython/psmap/dialogs.py:2163
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3777
+msgid "pattern line width (pts):"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1812
-msgid "Adjusts the ambient light"
+#: ../gui/wxpython/psmap/dialogs.py:2165
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3779
+msgid "pattern scale factor:"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1873
-msgid "Edges with fringe"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2481
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4078
+msgid "Raster legend"
+msgstr "Rastra leģenda"
-#: ../gui/wxpython/nviz/tools.py:1875
-msgid "N && W"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2485
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4082
+msgid "Show raster legend"
+msgstr "Rādīt rastra leģendu"
-#: ../gui/wxpython/nviz/tools.py:1876
-msgid "N && E"
+#: ../gui/wxpython/psmap/dialogs.py:2491
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4088
+msgid "Source raster"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1877
-msgid "S && W"
+#: ../gui/wxpython/psmap/dialogs.py:2496
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4093
+msgid "current raster"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1878
-msgid "S && E"
+#: ../gui/wxpython/psmap/dialogs.py:2497
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4094
+msgid "select raster"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1898
-msgid "Elevation of fringe from bottom:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1946 ../gui/wxpython/menustrings.py:1752
-#: ../gui/wxpython/psmap/toolbars.py:94 ../gui/wxpython/psmap/dialogs.py:4494
-msgid "North Arrow"
-msgstr "Ziemeļu bulta"
-#: ../gui/wxpython/nviz/tools.py:1951
-msgid "Arrow length (in map units):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1961
-msgid "Arrow color:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1970
-msgid "Place arrow"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1991 ../gui/wxpython/menustrings.py:1746
-#: ../gui/wxpython/psmap/toolbars.py:90
-msgid "Scale bar"
-msgstr "Mērogjosla"
-#: ../gui/wxpython/nviz/tools.py:1996
-msgid "Scale bar length (in map units):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2006
-msgid "Scale bar color:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2015
-msgid "Place new scale bar"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2087
-msgid "Do you want to record new animation without saving the previous one?"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2090
-msgid "Animation already axists"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2252
-msgid "No file prefix given."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2256
+#: ../gui/wxpython/psmap/dialogs.py:2504 ../gui/wxpython/psmap/dialogs.py:3190
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4101
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4787
#, python-format
-msgid "Directory %s does not exist."
+msgid "%(rast)s: type %(type)s"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2275 ../gui/wxpython/nviz/tools.py:2320
-#: ../gui/wxpython/nviz/tools.py:4579 ../gui/wxpython/nviz/mapwindow.py:2214
-#: ../gui/wxpython/nviz/mapwindow.py:2232
-msgid "constant#"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2523
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4120
+msgid "Type of legend"
+msgstr "Leģendas tips"
-#: ../gui/wxpython/nviz/tools.py:2386
-msgid "Isosurface attributes"
+#: ../gui/wxpython/psmap/dialogs.py:2527
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4124
+msgid "discrete legend (categorical maps)"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2392
-msgid "toggle normal direction"
+#: ../gui/wxpython/psmap/dialogs.py:2529
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4126
+msgid "continuous color gradient legend (floating point map)"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2398
-msgid "Isosurface value"
+#: ../gui/wxpython/psmap/dialogs.py:2540
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4137
+msgid "Advanced legend settings"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2501
-msgid "Slice attributes"
+#: ../gui/wxpython/psmap/dialogs.py:2544
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4141
+msgid "draw \"no data\" box"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2507
-msgid "Slice parallel to axis:"
+#: ../gui/wxpython/psmap/dialogs.py:2550
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4147
+msgid "draw ticks across color table"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2640
-msgid "W"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2561
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4158
+#: ../gui/wxpython/gui_modules/colorrules.py:831
+#: ../gui/wxpython/modules/colorrules.py:838
+#: ../gui/wxpython/modules/colorrules.py:1455
+#: ../gui/wxpython/modules/colorrules.py:1458
+msgid "range"
+msgstr "diapazons"
-#: ../gui/wxpython/nviz/tools.py:2641
-msgid "N"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2598
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4195
+msgid "Vector legend"
+msgstr "Vektoru leģenda"
-#: ../gui/wxpython/nviz/tools.py:2642
-msgid "S"
+#: ../gui/wxpython/psmap/dialogs.py:2602
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4199
+msgid "Show vector legend"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2643
-msgid "E"
+#: ../gui/wxpython/psmap/dialogs.py:2608
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4205
+msgid "Source vector maps"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2644
-msgid "NW"
+#: ../gui/wxpython/psmap/dialogs.py:2614
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4211
+msgid "Choose vector maps and their order in legend"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2645
-msgid "NE"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2618 ../gui/wxpython/nviz/tools.py:1157
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4215
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1327
+msgid "Vector map"
+msgstr "Vektoru karte"
-#: ../gui/wxpython/nviz/tools.py:2646
-msgid "SE"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2619
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4216
+msgid "Label"
+msgstr "Birka"
-#: ../gui/wxpython/nviz/tools.py:2647
-msgid "SW"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2638 ../gui/wxpython/psmap/dialogs.py:2944
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4235
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4541
+msgid "Edit label"
+msgstr "Rediģēt birku"
-#: ../gui/wxpython/nviz/tools.py:3136 ../gui/wxpython/nviz/tools.py:4905
-msgid "Level"
+#: ../gui/wxpython/psmap/dialogs.py:2657
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4254
+msgid "draw border around legend"
msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3760
-msgid "List of slices"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2694
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4291
+msgid "Size and position"
+msgstr "Novietojums un izmērs"
-#: ../gui/wxpython/nviz/tools.py:3952 ../gui/wxpython/nviz/tools.py:3954
-msgid "Level {level}"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2704 ../gui/wxpython/psmap/dialogs.py:3246
+#: ../gui/wxpython/psmap/dialogs.py:3441 ../gui/wxpython/psmap/dialogs.py:3815
+#: ../gui/wxpython/psmap/dialogs.py:3819 ../gui/wxpython/psmap/dialogs.py:4221
+#: ../gui/wxpython/psmap/dialogs.py:4226 ../gui/wxpython/psmap/dialogs.py:4675
+#: ../gui/wxpython/psmap/dialogs.py:4680 ../gui/wxpython/nviz/tools.py:841
+#: ../gui/wxpython/nviz/tools.py:1645
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4301
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4843
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5038
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5412
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5416
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5818
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5823
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1011
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1807
+msgid "Position"
+msgstr "Novietojums"
-#: ../gui/wxpython/nviz/tools.py:3961 ../gui/wxpython/nviz/tools.py:3963
-msgid "Slice parallel to {axis}"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4240 ../gui/wxpython/nviz/tools.py:4918
-msgid "Slice parallel to"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4450
-#, python-format
-msgid "Scalebar %d"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4585
-msgid "None"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4587 ../gui/wxpython/menustrings.py:488
-#: ../gui/wxpython/menustrings.py:1153
-msgid "Plane"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4747
-msgid "Vector map is 3D"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4750
-msgid "Vector map is 2D"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4752
-#, python-format
-msgid "%(features)d features (%(points)d points)"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4848
-msgid "as 3D"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4850
-msgid "on surface"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4938
-msgid "range:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5006 ../gui/wxpython/nviz/tools.py:5017
-msgid "North edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5007 ../gui/wxpython/nviz/tools.py:5018
-msgid "South edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5008 ../gui/wxpython/nviz/tools.py:5015
-#: ../gui/wxpython/nviz/tools.py:5024
-msgid "West edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5009 ../gui/wxpython/nviz/tools.py:5016
-#: ../gui/wxpython/nviz/tools.py:5025
-msgid "East edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5011 ../gui/wxpython/nviz/tools.py:5022
-#: ../gui/wxpython/nviz/tools.py:5030
-msgid "Northing (Y):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5012 ../gui/wxpython/nviz/tools.py:5021
-#: ../gui/wxpython/nviz/tools.py:5031
-msgid "Height (Z):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5013 ../gui/wxpython/nviz/tools.py:5020
-#: ../gui/wxpython/nviz/tools.py:5029
-msgid "Easting (X):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5026
-msgid "Bottom edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5027
-msgid "Top edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5132
-msgid "Adjusts the distance and direction of the image viewpoint"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5164
-msgid ""
-"Adjusts the light direction. Click and drag the puck to change the light "
-"direction."
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:32
-#, fuzzy
-msgid "3D view default settings"
-msgstr "Mainīt iestatījumus"
-msgid "Revert settings to default, changes are not applied"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:72
-#: ../gui/wxpython/nviz/preferences.py:135
-#: ../gui/wxpython/nviz/preferences.py:153
-msgid "value:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:84
-msgid "step:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:99
-#: ../gui/wxpython/nviz/preferences.py:266
-msgid "Position:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:102
-#: ../gui/wxpython/nviz/preferences.py:269
-msgid "x:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:132
-msgid "Twist:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:205
-msgid "Fly-through"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:209
-#: ../gui/wxpython/mapdisp/toolbars.py:59
-msgid "Fly-through mode"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:215
-msgid "Move exag:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:227
-msgid "Turn exag:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:258
-msgid "Light"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:293
-msgid "z:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:437
-msgid "wire color:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:476
-#: ../gui/wxpython/gui_core/dialogs.py:2242
-#: ../gui/wxpython/psmap/dialogs.py:2723
+#: ../gui/wxpython/psmap/dialogs.py:2722
#: ../gui/wxpython/gmodeler/preferences.py:158
#: ../gui/wxpython/gmodeler/preferences.py:277
#: ../gui/wxpython/gmodeler/preferences.py:362
+#: ../gui/wxpython/nviz/preferences.py:475
+#: ../gui/wxpython/gui_modules/gmodeler.py:3525
+#: ../gui/wxpython/gui_modules/gmodeler.py:3644
+#: ../gui/wxpython/gui_modules/gmodeler.py:3729
+#: ../gui/wxpython/gui_modules/gdialogs.py:2308
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4319
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:473
+#: ../gui/wxpython/gui_core/dialogs.py:2381
msgid "Width:"
-msgstr ""
+msgstr "Platums:"
-#: ../gui/wxpython/nviz/preferences.py:516
-msgid "Size:"
+#: ../gui/wxpython/psmap/dialogs.py:2728
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4325
+msgid "Leave the edit field empty, to use default values."
msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:531
-msgid "Marker:"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2734 ../gui/wxpython/psmap/dialogs.py:2872
+#: ../gui/wxpython/psmap/dialogs.py:3477
+#: ../gui/wxpython/gmodeler/preferences.py:176
+#: ../gui/wxpython/gmodeler/preferences.py:295
+#: ../gui/wxpython/gmodeler/preferences.py:380
+#: ../gui/wxpython/nviz/tools.py:272 ../gui/wxpython/nviz/tools.py:1021
+#: ../gui/wxpython/nviz/tools.py:1735
+#: ../gui/wxpython/gui_modules/gmodeler.py:3543
+#: ../gui/wxpython/gui_modules/gmodeler.py:3662
+#: ../gui/wxpython/gui_modules/gmodeler.py:3747
+#: ../gui/wxpython/gui_modules/gdialogs.py:2312
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4331
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4469
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5074
+#: ../gui/wxpython/gui_modules/nviz_tools.py:439
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1191
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1897
+#: ../gui/wxpython/gui_core/dialogs.py:2385
+msgid "Height:"
+msgstr "Augstums:"
-#: ../gui/wxpython/nviz/preferences.py:629
-#, python-format
-msgid "3D view settings saved to file <%s>."
-msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:32 ../gui/wxpython/wxplot/profile.py:31
+#: ../gui/wxpython/psmap/dialogs.py:2750
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4347
msgid ""
-"This module requires the NumPy module, which could not be imported. It "
-"probably is not installed (it's not part of the standard Python "
-"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
-"information on downloading source or binaries."
+"Width of the color symbol (for lines)\n"
+"in front of the legend text"
msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:329 ../gui/wxpython/nviz/wxnviz.py:340
-#: ../gui/wxpython/mapswipe/g.gui.mapswipe.py:82
-#: ../gui/wxpython/modules/histogram.py:348
-#: ../gui/wxpython/iclass/g.gui.iclass.py:76
-#, python-format
-msgid "Raster map <%s> not found"
-msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2756 ../gui/wxpython/psmap/dialogs.py:2861
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4353
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4458
+msgid "Columns:"
+msgstr "Kolonas:"
-#: ../gui/wxpython/nviz/wxnviz.py:417 ../gui/wxpython/dbmgr/g.gui.dbmgr.py:49
-#: ../gui/wxpython/iclass/g.gui.iclass.py:80
-#, python-format
-msgid "Vector map <%s> not found"
+#: ../gui/wxpython/psmap/dialogs.py:2760
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4357
+msgid "column span:"
msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:482 ../gui/wxpython/nviz/wxnviz.py:494
-#, python-format
-msgid "3d raster map <%s> not found"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:224
+#: ../gui/wxpython/psmap/dialogs.py:2762
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4359
msgid ""
-"Opening 3D view was not successful. Please try to change the value of depth "
-"buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
+"Column separation distance between the left edges\n"
+"of two columns in a multicolumn legend"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:559
-#, python-format
-msgid ""
-"Image is too large, your OpenGL implementation supports maximum texture size "
-"%d px."
+#: ../gui/wxpython/psmap/dialogs.py:2787 ../gui/wxpython/psmap/dialogs.py:3265
+#: ../gui/wxpython/psmap/dialogs.py:3721
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4384
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4862
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5318
+#: ../gui/wxpython/gui_modules/preferences.py:1407
+#: ../gui/wxpython/gui_modules/preferences.py:1550
+#: ../gui/wxpython/gui_modules/preferences.py:2270
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:599
+#: ../gui/wxpython/gui_core/preferences.py:409
+#: ../gui/wxpython/gui_core/preferences.py:585
+#: ../gui/wxpython/gui_core/preferences.py:1467
+#: ../gui/wxpython/wxplot/dialogs.py:600
+msgid "Font settings"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1057
-msgid "Easting"
+#: ../gui/wxpython/psmap/dialogs.py:2944
+msgid "Edit legend label:"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1058
-msgid "Northing"
+#: ../gui/wxpython/psmap/dialogs.py:2985
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4582
+msgid "No raster map selected!"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1059
-msgid "Elevation"
+#: ../gui/wxpython/psmap/dialogs.py:2986
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4583
+msgid "No raster"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1065
-msgid "Surface map name"
+#: ../gui/wxpython/psmap/dialogs.py:3221
+msgid "Mapinfo settings"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1066
-msgid "Surface map elevation"
+#: ../gui/wxpython/psmap/dialogs.py:3283
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4880
+msgid "Color settings"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1067
-msgid "Surface map color"
+#: ../gui/wxpython/psmap/dialogs.py:3289
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4886
+msgid "use border color:"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1076
-msgid "XY distance from previous"
+#: ../gui/wxpython/psmap/dialogs.py:3290
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4887
+msgid "use background color:"
msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1077
-msgid "XYZ distance from previous"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1078
-msgid "Distance along surface"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1083
-msgid "Distance along exag. surface"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1090
-msgid "No point on surface"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1547
-msgid "Loading raster map"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1551
-msgid "Loading 3d raster map"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1557
-msgid "failed"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1559
-#, python-format
-msgid "Unsupported layer type '%s'"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1671
-msgid "Unable to unload raster map"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1676
-msgid "Unable to unload 3d raster map"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1677
-msgid "3d raster map"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1687
-msgid "unloaded successfully"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1739
-#, python-format
-msgid "Loading vector map <%(name)s> (%(type)s) failed"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1798
-#, python-format
-msgid "Unable to unload vector map <%(name)s> (%(type)s)"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1801
-#, python-format
-msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2154
-#, python-format
-msgid "Vector point layer not found (id = %d)"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2156
-#, python-format
-msgid "Unable to set data layer properties (id = %d)"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2159
-#, python-format
+#: ../gui/wxpython/psmap/dialogs.py:3430
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5027
msgid ""
-"Setting data layer properties failed.\n"
-"\n"
-"%s"
+"Units of current projection are not supported,\n"
+" meters will be used!"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:38
-msgid "The Timeline Tool needs \"Matplotlib\" package to be installed."
+#: ../gui/wxpython/psmap/dialogs.py:3431
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5028
+msgid "Unsupported units"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:73
-msgid "Timeline Tool"
+#: ../gui/wxpython/psmap/dialogs.py:3476
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5073
+msgid "Length:"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:120 ../gui/wxpython/menustrings.py:1714
-#: ../gui/wxpython/menustrings.py:1757
-msgid "Help"
-msgstr "Palīdzība"
-#: ../gui/wxpython/timeline/frame.py:123
-msgid "3D plot of spatio-temporal extents"
+#: ../gui/wxpython/psmap/dialogs.py:3480
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5077
+msgid "Scalebar length is given in map units"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:126
-msgid "3D plot of spatio-temporal extents (matplotlib >= 1.0.0)"
+#: ../gui/wxpython/psmap/dialogs.py:3483
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5080
+msgid "Scalebar height is real height on paper"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:131
-#, fuzzy
-msgid "Select space time dataset(s):"
-msgstr "Rastra datu importēšana"
-#: ../gui/wxpython/timeline/frame.py:153
-#, python-format
-msgid "Dataset <%s> not found in temporal database"
+#: ../gui/wxpython/psmap/dialogs.py:3485
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5082
+msgid "default"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:165
-msgid ""
-"Datasets have different temporal type (absolute x relative), which is not "
-"allowed."
+#: ../gui/wxpython/psmap/dialogs.py:3524
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5121
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:908
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:959
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1007
+#: ../gui/wxpython/wxplot/dialogs.py:909 ../gui/wxpython/wxplot/dialogs.py:960
+#: ../gui/wxpython/wxplot/dialogs.py:1008
+msgid "Style"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:180
-msgid "Datasets have different time unit which is not allowed."
+#: ../gui/wxpython/psmap/dialogs.py:3529
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5126
+msgid "Type:"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:255
-#, python-format
-msgid "X [%s]"
+#: ../gui/wxpython/psmap/dialogs.py:3545
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5142
+msgid "Number of segments:"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:256
-#, python-format
-msgid "Y [%s]"
+#: ../gui/wxpython/psmap/dialogs.py:3549
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5146
+msgid "Label every "
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:258
-#, fuzzy
-msgid "X"
-msgstr "X:"
-#: ../gui/wxpython/timeline/frame.py:259
-#, fuzzy
-msgid "Y"
-msgstr "Y:"
-#: ../gui/wxpython/timeline/frame.py:261
-msgid "Time"
+#: ../gui/wxpython/psmap/dialogs.py:3550
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5147
+msgid "segments"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:316
-#, python-format
-msgid "Time [%s]"
+#: ../gui/wxpython/psmap/dialogs.py:3559
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5156
+msgid "transparent text background"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:339 ../gui/wxpython/timeline/frame.py:437
-#, fuzzy
-msgid "Invalid input data"
-msgstr "Tabulas nosaukums"
-#: ../gui/wxpython/timeline/frame.py:397
-#: ../gui/wxpython/animation/temporal_manager.py:212
-#: ../gui/wxpython/animation/utils.py:61 ../gui/wxpython/animation/utils.py:68
-#: ../gui/wxpython/animation/utils.py:106
-#, fuzzy, python-format
-msgid "Space time dataset <%s> not found."
-msgstr "Karte <%s> nav atrasta."
-#: ../gui/wxpython/timeline/frame.py:410
-#, python-format
-msgid "Please specify the space time dataset <%s>."
+#: ../gui/wxpython/psmap/dialogs.py:3636
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5233
+msgid "Length of scale bar is not defined"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:411
-msgid "Ambiguous dataset name"
+#: ../gui/wxpython/psmap/dialogs.py:3713
+#: ../gui/wxpython/gui_modules/gdialogs.py:794
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5310
+#: ../gui/wxpython/gui_core/dialogs.py:798
+msgid "Enter text:"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:489
-msgid "Space time raster dataset: %s"
-#: ../gui/wxpython/timeline/frame.py:491
-msgid "Space time vector dataset: %s"
-msgstr "Vektordatu importēšana"
-#: ../gui/wxpython/timeline/frame.py:493
-msgid "Space time 3D raster dataset: %s"
-#: ../gui/wxpython/timeline/frame.py:495
-msgid "Mapset: %s"
-msgstr "Karšu kopa"
-#: ../gui/wxpython/timeline/frame.py:496
-msgid "Map name: %s"
-msgstr "Kartes slāņi"
-#: ../gui/wxpython/timeline/frame.py:497
-#, python-format
-msgid "Start time: %s"
+#: ../gui/wxpython/psmap/dialogs.py:3739
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5336
+msgid "Text effects"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:498
-#, python-format
-msgid "End time: %s"
+#: ../gui/wxpython/psmap/dialogs.py:3744
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5341
+msgid "text background"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:501
-msgid "WARNING: invalid topology"
+#: ../gui/wxpython/psmap/dialogs.py:3747
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5344
+msgid "highlight"
msgstr ""
-#: ../gui/wxpython/timeline/frame.py:503
-msgid ""
-"\n"
-"Press Del to dismiss."
+#: ../gui/wxpython/psmap/dialogs.py:3752
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5349
+msgid "text border"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:137
-#, fuzzy
-msgid " Requested data settings "
-msgstr "Rastra iestatījumi"
-#: ../gui/wxpython/web_services/widgets.py:147
-msgid "Request"
+#: ../gui/wxpython/psmap/dialogs.py:3829
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5426
+msgid "Offset"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:152
-msgid "List of layers "
+#: ../gui/wxpython/psmap/dialogs.py:3832
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5429
+msgid "horizontal (pts):"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:168
-#, fuzzy
-msgid "Source projection:"
-msgstr "Projekcija"
-#: ../gui/wxpython/web_services/widgets.py:213
-#, fuzzy
-msgid "Advanced request settings"
-#: ../gui/wxpython/web_services/widgets.py:220
-msgid "Order of layers in raster"
+#: ../gui/wxpython/psmap/dialogs.py:3833
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5430
+msgid "vertical (pts):"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:223
-#: ../gui/wxpython/psmap/dialogs.py:1313 ../gui/wxpython/psmap/dialogs.py:2635
-msgid "Up"
+#: ../gui/wxpython/psmap/dialogs.py:3846
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5443
+msgid " Reference point"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:224
-#: ../gui/wxpython/psmap/dialogs.py:1314 ../gui/wxpython/psmap/dialogs.py:2636
-msgid "Down"
+#: ../gui/wxpython/psmap/dialogs.py:3872
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5469
+msgid "Text rotation"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:230
-#, fuzzy
-msgid "Reprojection method:"
-msgstr "Projekcijas kods:"
-#: ../gui/wxpython/web_services/widgets.py:234
-msgid "Nearest neighbor"
+#: ../gui/wxpython/psmap/dialogs.py:3875
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5472
+msgid "rotate text (counterclockwise)"
msgstr ""
-msgid "Linear interpolation"
+#: ../gui/wxpython/psmap/dialogs.py:3951
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5548
+msgid "No text entered!"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:235
-msgid "Cubic interpolation"
+#: ../gui/wxpython/psmap/dialogs.py:3951 ../gui/wxpython/gmodeler/frame.py:881
+#: ../gui/wxpython/lmgr/layertree.py:548
+#: ../gui/wxpython/gui_modules/workspace.py:1367
+#: ../gui/wxpython/gui_modules/gcmd.py:65
+#: ../gui/wxpython/gui_modules/gmodeler.py:1623
+#: ../gui/wxpython/gui_modules/location_wizard.py:561
+#: ../gui/wxpython/gui_modules/location_wizard.py:746
+#: ../gui/wxpython/gui_modules/location_wizard.py:1468
+#: ../gui/wxpython/gui_modules/location_wizard.py:1526
+#: ../gui/wxpython/gui_modules/location_wizard.py:2170
+#: ../gui/wxpython/gui_modules/location_wizard.py:2187
+#: ../gui/wxpython/gui_modules/location_wizard.py:2494
+#: ../gui/wxpython/gui_modules/dbm.py:161
+#: ../gui/wxpython/gui_modules/dbm.py:1408
+#: ../gui/wxpython/gui_modules/dbm.py:1517
+#: ../gui/wxpython/gui_modules/dbm.py:1603
+#: ../gui/wxpython/gui_modules/dbm.py:1615
+#: ../gui/wxpython/gui_modules/dbm.py:1630
+#: ../gui/wxpython/gui_modules/dbm.py:1947
+#: ../gui/wxpython/gui_modules/dbm.py:2767
+#: ../gui/wxpython/gui_modules/dbm.py:2865
+#: ../gui/wxpython/gui_modules/dbm.py:2872
+#: ../gui/wxpython/gui_modules/dbm.py:2912
+#: ../gui/wxpython/gui_modules/preferences.py:1216
+#: ../gui/wxpython/gui_modules/preferences.py:2139
+#: ../gui/wxpython/gui_modules/preferences.py:2168
+#: ../gui/wxpython/gui_modules/preferences.py:2177
+#: ../gui/wxpython/gui_modules/preferences.py:2187
+#: ../gui/wxpython/gui_modules/layertree.py:514
+#: ../gui/wxpython/gui_modules/layertree.py:550
+#: ../gui/wxpython/gui_modules/wxplot.py:1042
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1824
+#: ../gui/wxpython/gui_modules/vdigit.py:1028
+#: ../gui/wxpython/gui_modules/vdigit.py:1220
+#: ../gui/wxpython/location_wizard/wizard.py:525
+#: ../gui/wxpython/location_wizard/wizard.py:710
+#: ../gui/wxpython/location_wizard/wizard.py:1478
+#: ../gui/wxpython/location_wizard/wizard.py:1536
+#: ../gui/wxpython/location_wizard/dialogs.py:114
+#: ../gui/wxpython/location_wizard/dialogs.py:131
+#: ../gui/wxpython/location_wizard/dialogs.py:438
+#: ../gui/wxpython/gui_core/preferences.py:216
+#: ../gui/wxpython/gui_core/preferences.py:1314
+#: ../gui/wxpython/gui_core/preferences.py:1343
+#: ../gui/wxpython/gui_core/preferences.py:1352
+#: ../gui/wxpython/gui_core/preferences.py:1361
+#: ../gui/wxpython/wxplot/profile.py:346
+#: ../gui/wxpython/core/workspace.py:1038 ../gui/wxpython/core/gcmd.py:109
+#: ../gui/wxpython/mapdisp/mapwindow.py:1716 ../gui/wxpython/gis_set.py:207
+#: ../gui/wxpython/gis_set.py:448 ../gui/wxpython/gis_set.py:484
+#: ../gui/wxpython/gis_set.py:550 ../gui/wxpython/vdigit/dialogs.py:241
+#: ../gui/wxpython/vdigit/dialogs.py:433
+#: ../gui/wxpython/scripts/r.li.setup.py:337
+msgid "Error"
msgstr ""
-msgid "Cubic spline interpolation"
+#: ../gui/wxpython/psmap/dialogs.py:4119 ../gui/wxpython/nviz/tools.py:465
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5716
+#: ../gui/wxpython/gui_modules/nviz_tools.py:632
+msgid "Choose a directory:"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:238
-msgid "Maximum columns to request from server at time:"
+#: ../gui/wxpython/psmap/dialogs.py:4120
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5717
+msgid "Choose a directory with images"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:242
-msgid "Maximum rows to request from server at time:"
+#: ../gui/wxpython/psmap/dialogs.py:4152
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5749
+msgid "Note: only EPS format supported"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:257
-msgid "Do not request transparent data"
+#: ../gui/wxpython/psmap/dialogs.py:4161
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5758
+msgid "Scale And Rotation"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:270
-#, fuzzy
-msgid "Additional query parameters for server:"
-msgstr "Pievienot vairākas rastra vai vektoru kartes"
-#: ../gui/wxpython/web_services/widgets.py:472
-#, python-format
-msgid ""
-"Unable to download %s capabilities file\n"
-"from <%s>:\n"
+#: ../gui/wxpython/psmap/dialogs.py:4192 ../gui/wxpython/psmap/dialogs.py:4650
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5789
+msgid "Rotation angle (deg):"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:486
-#, python-format
-msgid ""
-"%s web service was not found in fetched capabilities file from <%s>:\n"
-"%s\n"
+#: ../gui/wxpython/psmap/dialogs.py:4201 ../gui/wxpython/psmap/dialogs.py:4659
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5798
+msgid "Counterclockwise rotation in degrees"
msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:760
-msgid "Source image format"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:793
-msgid "Select layer in layer list.\n"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:798
-msgid "Select source image format.\n"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:803
-msgid "Select source projection.\n"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:807
-msgid "Choose output layer name.\n"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:844
-#: ../gui/wxpython/gui_core/ghelp.py:337 ../gui/wxpython/gui_core/ghelp.py:339
-#: ../gui/wxpython/gui_core/ghelp.py:402
-#: ../gui/wxpython/gmodeler/frame.py:1322
-#: ../gui/wxpython/gmodeler/frame.py:1364
-#: ../gui/wxpython/gmodeler/frame.py:1467
-#: ../gui/wxpython/gmodeler/dialogs.py:412
-#: ../gui/wxpython/gmodeler/dialogs.py:514
-msgid "Name"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:845
-#: ../gui/wxpython/dbmgr/base.py:2014 ../gui/wxpython/dbmgr/dialogs.py:756
-#: ../gui/wxpython/gmodeler/preferences.py:208
-msgid "Type"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:847
-#: ../gui/wxpython/gui_core/dialogs.py:1511
-msgid "Layer name"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:881
-#, fuzzy
-msgid "layer"
-msgstr "Slānis:"
-#: ../gui/wxpython/web_services/widgets.py:901
-msgid "style"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:90
-msgid " Server settings "
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:93
-msgid "Server:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:97
-msgid "&Connect"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:98
-msgid "Connect to the server"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:102
-msgid "Show advanced connection settings"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:103
-msgid "Hide advanced connection settings"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:118
-#, fuzzy
-msgid " Layer Manager Settings "
-#: ../gui/wxpython/web_services/dialogs.py:121
-msgid "Output layer name:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:231
-msgid "Username:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:235
-msgid "Password:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:276
-#: ../gui/wxpython/gui_core/gselect.py:1662
-msgid "No data source defined, settings are not saved."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:354
-#, python-format
-msgid "Connecting to <%s>..."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:420
-msgid "Available web services"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:428
-#, python-format
-msgid "Connected to <%s>"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:433
-#, python-format
-msgid "Unable to connect to <%s>"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:477
-#: ../gui/wxpython/web_services/dialogs.py:820
-msgid "Add web service layer"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:487
-#: ../gui/wxpython/dbmgr/base.py:2720
-msgid "&Add layer"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:488
-msgid "Add selected web service layers as map layer into layer tree"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:580
-msgid "Web service layer properties"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:625
-msgid "&Apply"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:626
-#: ../gui/wxpython/psmap/dialogs.py:359 ../gui/wxpython/vdigit/dialogs.py:144
-msgid "Apply changes"
-msgstr "Pielietot izmaiņas"
-#: ../gui/wxpython/web_services/dialogs.py:630
-#: ../gui/wxpython/iscatt/dialogs.py:75
-msgid "&OK"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:631
-#: ../gui/wxpython/vdigit/dialogs.py:148
-msgid "Apply changes and close dialog"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:791
-msgid "Name for output raster layer:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:797
-#: ../gui/wxpython/menustrings.py:221
-msgid "Region"
-msgstr "Reģions"
-#: ../gui/wxpython/web_services/dialogs.py:806
-msgid "Overwrite existing layer"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:810
-msgid "Choose named region:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:819
-#, fuzzy
-msgid "&Save layer"
-msgstr "Saglabāt kā"
-#: ../gui/wxpython/web_services/dialogs.py:935
-msgid "Missing output raster."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:939
-msgid "Output map can be added only to current mapset."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:943
-#, python-format
-msgid "Output map <%s> already exists"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:964
-#, python-format
-msgid "Region <%s> does not exists."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:988
-msgid "Downloading data..."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1015
-msgid "Unable to fetch data.\n"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:85
-msgid "GRASS GIS Layer Manager"
-msgstr "GRASS GIS slāņu pārvaldnieks"
-#: ../gui/wxpython/lmgr/frame.py:132
-msgid "Workspace Toolbar"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:135
-msgid "Data Toolbar"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:138 ../gui/wxpython/animation/frame.py:139
-#: ../gui/wxpython/mapswipe/frame.py:286
-msgid "Misc Toolbar"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:141
-msgid "Tools Toolbar"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:144
-msgid "Vector Toolbar"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:147
-msgid "3D view Toolbar"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:251 ../gui/wxpython/lmgr/frame.py:1359
-msgid "Rename Map Display"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:279
-msgid "Map layers"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:289
-msgid "Command console"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:306
-msgid "Search modules"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:313
-#: ../gui/wxpython/gui_core/preferences.py:320
-msgid "Python shell"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:346 ../gui/wxpython/animation/dialogs.py:699
-#: ../gui/wxpython/mapdisp/toolbars.py:86
-msgid "3D view"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:385
-#, python-format
+#: ../gui/wxpython/psmap/dialogs.py:4299
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5896
msgid ""
-"Location <%s> created.\n"
-"\n"
-"Do you want to switch to the new location?"
+"PIL\n"
+"missing"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:388
-msgid "Switch to new location?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:401 ../gui/wxpython/lmgr/frame.py:873
+#: ../gui/wxpython/psmap/dialogs.py:4316
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5913
#, python-format
-msgid ""
-"Current location is <%(loc)s>.\n"
-"Current mapset is <%(mapset)s>."
+msgid "Unable to read file %s"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:407 ../gui/wxpython/gis_set.py:487
-msgid "Do you want to set the default region extents and resolution now?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:409 ../gui/wxpython/gis_set.py:486
+#: ../gui/wxpython/psmap/dialogs.py:4374
#, python-format
-msgid "Location <%s> created"
+msgid "size: %(width)s x %(height)s pts"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:487
-msgid "Choose model to run"
+#: ../gui/wxpython/psmap/dialogs.py:4396
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5991
+msgid "No image selected."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:489 ../gui/wxpython/gmodeler/frame.py:378
-#: ../gui/wxpython/gmodeler/frame.py:422
-msgid "GRASS Model File (*.gxm)|*.gxm"
+#: ../gui/wxpython/psmap/dialogs.py:4493
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:6088
+msgid "North Arrow settings"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:545 ../gui/wxpython/lmgr/frame.py:2034
-msgid "Do you want to save changes in the workspace?"
+#: ../gui/wxpython/psmap/dialogs.py:4504
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:6099
+msgid "Compute convergence"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:547 ../gui/wxpython/lmgr/frame.py:2036
-msgid "Do you want to store current settings to workspace file?"
+#: ../gui/wxpython/psmap/dialogs.py:4560
+msgid "Symbol"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:555
-#, python-format
-msgid "Close Map Display %s"
+#: ../gui/wxpython/psmap/dialogs.py:4566
+msgid "Select symbol:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:629
-#, python-format
+#: ../gui/wxpython/psmap/dialogs.py:4580
msgid ""
-"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
-"layer instead."
+"Note: Selected symbol is not displayed\n"
+"in draft mode (only in preview mode)"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:776 ../gui/wxpython/lmgr/frame.py:1574
-msgid "Selected map layer is not vector."
+#: ../gui/wxpython/psmap/dialogs.py:4593 ../gui/wxpython/psmap/dialogs.py:4848
+#: ../gui/wxpython/gmodeler/preferences.py:88
+#: ../gui/wxpython/gmodeler/preferences.py:326
+#: ../gui/wxpython/nviz/tools.py:773 ../gui/wxpython/nviz/tools.py:2339
+#: ../gui/wxpython/gui_modules/gmodeler.py:3455
+#: ../gui/wxpython/gui_modules/gmodeler.py:3693
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:893
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:944
+#: ../gui/wxpython/gui_modules/nviz_tools.py:943
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2491
+#: ../gui/wxpython/iclass/dialogs.py:226 ../gui/wxpython/wxplot/dialogs.py:894
+#: ../gui/wxpython/wxplot/dialogs.py:945
+msgid "Color"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:781
-msgid "Editing is allowed only for vector maps from the current mapset."
+#: ../gui/wxpython/psmap/dialogs.py:4598 ../gui/wxpython/psmap/dialogs.py:4852
+msgid "Outline color:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:796
-msgid "Choose script file to run"
+#: ../gui/wxpython/psmap/dialogs.py:4600 ../gui/wxpython/psmap/dialogs.py:4615
+#: ../gui/wxpython/psmap/dialogs.py:4854 ../gui/wxpython/psmap/dialogs.py:4875
+#: ../gui/wxpython/gui_modules/gdialogs.py:2138
+#: ../gui/wxpython/gui_core/dialogs.py:2242
+msgid "transparent"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:798
-msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
+#: ../gui/wxpython/psmap/dialogs.py:4613 ../gui/wxpython/psmap/dialogs.py:4873
+msgid "Fill color:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:809
-#, python-format
-msgid "Script file '%s' doesn't exist. Operation canceled."
+#: ../gui/wxpython/psmap/dialogs.py:4636
+msgid "Size and Rotation"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:816
-#, python-format
-msgid ""
-"Script <%s> is not executable. Do you want to set the permissions that "
-"allows you to run this script (note that you must be the owner of the file)?"
+#: ../gui/wxpython/psmap/dialogs.py:4641
+msgid "Size (pt):"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:821
-msgid "Set permission?"
+#: ../gui/wxpython/psmap/dialogs.py:4643
+msgid "Symbol size in points"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:830
-msgid "Unable to set permission. Operation canceled."
+#: ../gui/wxpython/psmap/dialogs.py:4817
+msgid "Rectangle settings"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:841
-#, python-format
-msgid ""
-"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
-"directory to GRASS_ADDON_PATH?"
+#: ../gui/wxpython/psmap/dialogs.py:4819
+msgid "Line settings"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:844
-msgid "Update Addons path?"
+#: ../gui/wxpython/psmap/dialogs.py:4896 ../gui/wxpython/gcp/manager.py:2538
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2541
+#: ../gui/wxpython/gui_core/preferences.py:987
+msgid "Line width:"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:849
-#, python-format
-msgid "Launching script '%s'..."
+#: ../gui/wxpython/psmap/dialogs.py:4905
+msgid "Line width in points"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:861
-msgid "No location/mapset provided. Operation canceled."
+#: ../gui/wxpython/psmap/utils.py:91
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:98
+msgid "inch"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:880 ../gui/wxpython/gis_set.py:843
-msgid "Enter name for new mapset:"
+#: ../gui/wxpython/psmap/utils.py:92
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:99
+#: ../gui/wxpython/gui_modules/vclean.py:204
+#: ../gui/wxpython/modules/vclean.py:194
+msgid "point"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:881 ../gui/wxpython/gis_set.py:474
-#: ../gui/wxpython/gis_set.py:844 ../gui/wxpython/menustrings.py:245
-msgid "Create new mapset"
+#: ../gui/wxpython/psmap/utils.py:93
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:100
+msgid "centimeter"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:887 ../gui/wxpython/lmgr/frame.py:908
-msgid "No mapset provided. Operation canceled."
+#: ../gui/wxpython/psmap/utils.py:94
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:101
+msgid "millimeter"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:896 ../gui/wxpython/lmgr/frame.py:915
-#, python-format
-msgid "Current mapset is <%s>."
+#: ../gui/wxpython/psmap/utils.py:95
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:102
+msgid "meters"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:920
-msgid "Choose a working directory"
+#: ../gui/wxpython/psmap/utils.py:96
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:103
+msgid "kilometers"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:959
-msgid "System Info"
+#: ../gui/wxpython/psmap/utils.py:97
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:104
+msgid "feet"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:973
-#, fuzzy
-msgid "GRASS version"
-msgstr "Sākt GRASS sesiju"
-#: ../gui/wxpython/lmgr/frame.py:974
-msgid "GRASS SVN Revision"
+#: ../gui/wxpython/psmap/utils.py:98
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:105
+msgid "miles"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:975 ../gui/wxpython/gui_core/ghelp.py:146
-msgid "Build Date"
+#: ../gui/wxpython/psmap/utils.py:99 ../gui/wxpython/psmap/utils.py:103
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:106
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:110
+msgid "nautical miles"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:976
-msgid "GIS Library Revision"
+#: ../gui/wxpython/psmap/utils.py:101
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:108
+msgid "pixel"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:980
-msgid "Platform"
+#: ../gui/wxpython/psmap/utils.py:102
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:109
+msgid "meter"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1036
-msgid ""
-"Current workspace is not empty. Do you want to store current settings to "
-"workspace file?"
+#: ../gui/wxpython/psmap/utils.py:104
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:111
+msgid "degree"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1039
-msgid "Create new workspace?"
+#: ../gui/wxpython/psmap/utils.py:344
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:6330
+msgid "Unable to run `ps.map -b`"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1065
-msgid "Choose workspace file"
+#: ../gui/wxpython/psmap/frame.py:50 ../gui/wxpython/gui_modules/psmap.py:55
+msgid "GRASS GIS Cartographic Composer"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1066 ../gui/wxpython/lmgr/frame.py:1257
-msgid "GRASS Workspace File (*.gxw)|*.gxw"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1101 ../gui/wxpython/animation/nviztask.py:46
-#, python-format
+#: ../gui/wxpython/psmap/frame.py:179 ../gui/wxpython/gui_modules/psmap.py:180
msgid ""
-"Reading workspace file <%s> failed.\n"
-"Invalid file, unable to parse XML document."
+"Python Imaging Library is not available.\n"
+"'Preview' functionality won't work."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1105 ../gui/wxpython/lmgr/frame.py:1234
-msgid "Please wait, loading workspace..."
+#: ../gui/wxpython/psmap/frame.py:230 ../gui/wxpython/gui_modules/psmap.py:231
+msgid "Program ps2pdf is not available. Please install it first to create PDF."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1218
-msgid "Choose GRC file to load"
+#: ../gui/wxpython/psmap/frame.py:274 ../gui/wxpython/gui_modules/psmap.py:275
+msgid "Generating PDF..."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1219
-msgid "Old GRASS Workspace File (*.grc)|*.grc"
+#: ../gui/wxpython/psmap/frame.py:276 ../gui/wxpython/gui_modules/psmap.py:277
+msgid "Generating PostScript..."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1256
-msgid "Choose file to save current workspace"
+#: ../gui/wxpython/psmap/frame.py:278 ../gui/wxpython/gui_modules/psmap.py:279
+msgid "Generating preview..."
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1271 ../gui/wxpython/lmgr/frame.py:1287
+#: ../gui/wxpython/psmap/frame.py:288 ../gui/wxpython/gui_modules/psmap.py:289
#, python-format
-msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
+msgid "Ps.map exited with return code %s"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1273 ../gui/wxpython/lmgr/frame.py:1290
-#: ../gui/wxpython/menustrings.py:10
-msgid "Save workspace"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1311
-msgid "Writing current settings to workspace file failed."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1322 ../gui/wxpython/gmodeler/frame.py:898
+#: ../gui/wxpython/psmap/frame.py:303 ../gui/wxpython/gui_modules/psmap.py:304
#, python-format
-msgid "Unable to open file <%s> for writing."
+msgid "ps2pdf exited with return code %s"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1358
-msgid "Enter new name:"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1364
+#: ../gui/wxpython/psmap/frame.py:307 ../gui/wxpython/gui_modules/psmap.py:308
#, python-format
-msgid "GRASS GIS Map Display: %(name)s - Location: %(loc)s"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1441
-#, python-format
msgid ""
-"Unable to launch \"Supervised Classification Tool\".\n"
+"Program ps2pdf is not available. Please install it to create PDF.\n"
"\n"
-"Reason: %s"
+" %s"
msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1682
-msgid "Add selected map layers into layer tree"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1716 ../gui/wxpython/lmgr/frame.py:1760
-#, python-format
-msgid "Unsupported map layer type <%s>."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1889
-msgid ""
-"Note that cell values can only be displayed for regions of less than 10,000 "
-"cells."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1971
-#, python-format
-msgid ""
-"Do you want to remove map layer(s)\n"
-"%s\n"
-"from layer tree?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1974
-msgid "Do you want to remove selected map layer(s) from layer tree?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1978
-msgid "Remove map layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2043
-msgid "Quit GRASS GUI"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2074
-msgid "No map layer selected. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2075 ../gui/wxpython/gis_set.py:581
-#: ../gui/wxpython/gis_set.py:617 ../gui/wxpython/core/gcmd.py:149
-msgid "Message"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2084
-msgid ""
-"Display resolution is currently not constrained to computational settings. "
-"It's suggested to constrain map to region geometry. Do you want to constrain "
-"the resolution?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2093
-msgid "Constrain map to region geometry?"
-msgstr ""
-#: ../gui/wxpython/lmgr/menudata.py:42
-msgid ""
-"Unable to parse user toolboxes XML files. Default main menu will be loaded."
-msgstr ""
-#: ../gui/wxpython/lmgr/menudata.py:64
-msgid ""
-"Unable to parse user toolboxes XML files. Default module tree will be loaded."
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:36
-#, python-format
-msgid "Welcome to wxGUI Interactive Python Shell %s"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:37
-#, python-format
-msgid "Type %s for more GRASS scripting related information."
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:38
-#, python-format
-msgid "Type %s to add raster or vector to the layer tree."
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:48
-msgid "Delete all text from the shell"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:98
-#, python-format
-msgid "Raster or vector map <%s> not found"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:105
-#, python-format
-msgid "Raster map <%s> added"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:107
-#, python-format
-msgid "Vector map <%s> added"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:46
-msgid "Start new map display"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:48
-msgid "Create new workspace (Ctrl+N)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:50
-msgid "Open existing workspace file (Ctrl+O)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:52
-msgid "Save current workspace to file (Ctrl+S)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:81
-msgid "Add multiple raster or vector map layers (Ctrl+Shift+L)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:82
-msgid "Add raster map layer (Ctrl+Shift+R)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:84
-msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:85
-msgid "Add vector map layer (Ctrl+Shift+V)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:87
-msgid "Add various vector map layers (thematic, chart...)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:89
-msgid "Add web service layer (WMS, WMTS, NASA OnEarth)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:91
-msgid "Add group"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:93
-msgid "Add various overlays"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:95
-msgid "Remove selected map layer(s) from layer tree"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:136
-msgid "Import/link raster or vector data"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:138
-msgid "Raster Map Calculator"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:140 ../gui/wxpython/gui_core/forms.py:1183
-msgid "Graphical Modeler"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:142
-msgid "Georectifier"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:144 ../gui/wxpython/menustrings.py:212
-msgid "Cartographic Composer"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:175
-msgid "GUI settings"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:176
-msgid "GRASS manual"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:201
-#, fuzzy
-msgid "Edit selected vector map"
+#: ../gui/wxpython/psmap/frame.py:324 ../gui/wxpython/gui_modules/psmap.py:325
+#, fuzzy, python-format
+msgid "Unable to generate preview. %s"
msgstr "Jauna vektoru karte"
-#: ../gui/wxpython/lmgr/toolbars.py:203
-msgid "Show attribute data for selected vector map"
+#: ../gui/wxpython/psmap/frame.py:333 ../gui/wxpython/gui_modules/psmap.py:334
+msgid "Preview generated"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:232
-msgid "Generate command for m.nviz.image"
+#: ../gui/wxpython/psmap/frame.py:361 ../gui/wxpython/gui_modules/psmap.py:362
+msgid "Save file as"
msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:233
-msgid "Generate command for m.nviz.image based on current state"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:235
-msgid "3D view mode settings"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:236
-msgid "Show 3D view mode settings dialog"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:238
-msgid "Show 3D view mode manual"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:57
-#: ../gui/wxpython/gui_core/dialogs.py:1717 ../gui/wxpython/menustrings.py:30
-msgid "Import raster data"
-#: ../gui/wxpython/lmgr/layertree.py:59
-#: ../gui/wxpython/gui_core/dialogs.py:1715 ../gui/wxpython/menustrings.py:162
-msgid "Link external raster data"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:61
-msgid "Set raster output format"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:63
-#: ../gui/wxpython/gui_core/dialogs.py:1711 ../gui/wxpython/menustrings.py:59
-msgid "Import vector data"
-#: ../gui/wxpython/lmgr/layertree.py:65
-#: ../gui/wxpython/gui_core/dialogs.py:1709 ../gui/wxpython/menustrings.py:164
-msgid "Link external vector data"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:67
-msgid "Set vector output format"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:69
-msgid "Import data from WMS server"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:71
-msgid "Add command layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:73
-#: ../gui/wxpython/gui_core/toolbars.py:71 ../gui/wxpython/menustrings.py:1733
-msgid "Quit"
-msgstr "Iziet"
-#: ../gui/wxpython/lmgr/layertree.py:75 ../gui/wxpython/iclass/toolbars.py:49
-msgid "Add RGB map layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:77
-msgid "Add HIS map layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:79
-msgid "Add shaded relief map layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:81
-msgid "Add raster flow arrows"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:83
-msgid "Add raster cell numbers"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:85
-msgid "Add thematic area (choropleth) map layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:87
-msgid "Add thematic chart layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:89
-msgid "Add grid layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:91
-msgid "Add geodesic line layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:93
-msgid "Add rhumbline layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:95 ../gui/wxpython/psmap/toolbars.py:104
-msgid "Add labels"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:97
-msgid "Add 3D raster map layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:98
-msgid "Note that 3D raster data are rendered only in 3D view mode"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:100
-msgid "Add WMS layer."
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:102
-#: ../gui/wxpython/animation/dialogs.py:361
-msgid "Set options"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:172
+#: ../gui/wxpython/psmap/frame.py:399 ../gui/wxpython/gui_modules/psmap.py:400
#, python-format
-msgid "GRASS GIS Map Display: %(id)d - Location: %(loc)s"
+msgid "Failed to read file %s."
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:182
-msgid "Map Layers"
-#: ../gui/wxpython/lmgr/layertree.py:419
-#: ../gui/wxpython/animation/dialogs.py:583
-#: ../gui/wxpython/animation/dialogs.py:929
-#: ../gui/wxpython/menustrings.py:1589 ../gui/wxpython/iscatt/dialogs.py:72
-#: ../gui/wxpython/rlisetup/frame.py:45 ../gui/wxpython/gmodeler/frame.py:1204
-msgid "Remove"
+#: ../gui/wxpython/psmap/frame.py:587 ../gui/wxpython/gui_modules/psmap.py:628
+msgid "Scalebar is not appropriate for this projection"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:423 ../gui/wxpython/menustrings.py:177
-#: ../gui/wxpython/menustrings.py:1587 ../gui/wxpython/rlisetup/frame.py:51
-msgid "Rename"
+#: ../gui/wxpython/psmap/frame.py:1018
+#: ../gui/wxpython/gui_modules/psmap.py:959
+msgid "wxGUI Cartographic Composer"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:441 ../gui/wxpython/iscatt/frame.py:543
-msgid "Change opacity level"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:443
-#: ../gui/wxpython/gmodeler/frame.py:1236
-msgid "Properties"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:447
-msgid "3D view properties"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:452
-msgid "Zoom to selected map(s)"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:454
-msgid "Set computational region from selected map(s)"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:466 ../gui/wxpython/lmgr/layertree.py:552
-#: ../gui/wxpython/animation/dialogs.py:875
-#: ../gui/wxpython/menustrings.py:1617
-msgid "Export"
-msgstr "Eksportēt"
-#: ../gui/wxpython/lmgr/layertree.py:473 ../gui/wxpython/lmgr/layertree.py:559
-msgid "Make a copy in the current mapset"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:478 ../gui/wxpython/lmgr/layertree.py:564
-#: ../gui/wxpython/lmgr/layertree.py:582
-msgid "Set color table"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:481
-msgid "Show attribute data"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:484
-msgid "Start editing"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:485
-msgid "Stop editing"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:496
-msgid "Use as background vector map for digitizer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:503
-msgid "Rebuild topology"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:516
-msgid "SQL Spatial Query"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:538 ../gui/wxpython/lmgr/layertree.py:576
-#: ../gui/wxpython/lmgr/layertree.py:586
-#: ../gui/wxpython/gmodeler/preferences.py:429
-msgid "Metadata"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:544
-msgid "Zoom to selected map(s) (ignore NULLs)"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:546
-msgid "Set computational region from selected map(s) (ignore NULLs)"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:566 ../gui/wxpython/menustrings.py:748
-#: ../gui/wxpython/menustrings.py:1413
-msgid "Histogram"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:568 ../gui/wxpython/lmgr/layertree.py:584
-#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1193
-msgid "Univariate raster statistics"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:570
-#, fuzzy
-msgid "Report raster statistics"
-msgstr "Vispārēja statistika"
-#: ../gui/wxpython/lmgr/layertree.py:574
-msgid "Profile"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:591
-msgid "Save web service layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:695
-msgid "Unable to create profile of raster map."
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:697 ../gui/wxpython/gis_set.py:225
-#: ../gui/wxpython/gis_set.py:593 ../gui/wxpython/gis_set.py:630
-#: ../gui/wxpython/gui_core/preferences.py:216
-#: ../gui/wxpython/gui_core/preferences.py:1375
-#: ../gui/wxpython/gui_core/preferences.py:1404
-#: ../gui/wxpython/gui_core/preferences.py:1413
-#: ../gui/wxpython/gui_core/preferences.py:1422
-#: ../gui/wxpython/psmap/dialogs.py:3951
-#: ../gui/wxpython/location_wizard/wizard.py:539
-#: ../gui/wxpython/location_wizard/wizard.py:723
-#: ../gui/wxpython/location_wizard/wizard.py:1501
-#: ../gui/wxpython/location_wizard/wizard.py:1567
-#: ../gui/wxpython/location_wizard/dialogs.py:120
-#: ../gui/wxpython/location_wizard/dialogs.py:137
-#: ../gui/wxpython/location_wizard/dialogs.py:445
-#: ../gui/wxpython/vdigit/dialogs.py:243 ../gui/wxpython/vdigit/dialogs.py:435
-#: ../gui/wxpython/gmodeler/frame.py:899
-#: ../gui/wxpython/core/workspace.py:1054 ../gui/wxpython/core/gcmd.py:115
-msgid "Error"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:725
-#, python-format
+#: ../gui/wxpython/psmap/frame.py:1020
+#: ../gui/wxpython/gui_modules/psmap.py:961
msgid ""
-"Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII "
-"characters excluding %(chars)s and space."
+"(C) 2011 by the GRASS Development Team\n"
+"\n"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:728 ../gui/wxpython/gis_set.py:980
-#, fuzzy
-msgid "Invalid name"
-#: ../gui/wxpython/lmgr/layertree.py:746
-#, python-format
-msgid "Unsupported map type <%s>"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:751
-#, python-format
-msgid "Enter name for the new %s in the current mapset:"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:752
-#, python-format
-msgid "Make a copy of %s <%s>"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:766
-#, python-format
+#: ../gui/wxpython/psmap/frame.py:1021 ../gui/wxpython/gmodeler/frame.py:707
+#: ../gui/wxpython/gui_modules/gmodeler.py:1449
+#: ../gui/wxpython/gui_modules/psmap.py:962
msgid ""
-"%s <%s> already exists in the current mapset. Do you want to overwrite it?"
+"This program is free software under the GNU General Public License(>=v2). "
+"Read the file COPYING that comes with GRASS for details."
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:769
-#: ../gui/wxpython/gui_core/dialogs.py:392
-msgid "Overwrite?"
+#: ../gui/wxpython/psmap/frame.py:1324
+#: ../gui/wxpython/gui_modules/psmap.py:1197
+msgid "Click and drag to resize object"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:776
-#, python-format
-msgid "Unable to make copy of <%s>"
+#: ../gui/wxpython/gcp/mapdisplay.py:45
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:72
+msgid "GRASS GIS Manage Ground Control Points"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:783
-#, python-format
-msgid "Unable to make copy of <%s>. Mapset <%s> is not current mapset."
+#: ../gui/wxpython/gcp/mapdisplay.py:149
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:178
+msgid "GCP List"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:800
-msgid "Unable to display histogram of raster map. No map name defined."
+#: ../gui/wxpython/gcp/mapdisplay.py:154
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:183
+msgid "Source Display"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:847
-#: ../gui/wxpython/animation/dialogs.py:698
-#: ../gui/wxpython/mapdisp/frame.py:252 ../gui/wxpython/mapdisp/frame.py:312
-#: ../gui/wxpython/mapdisp/frame.py:491 ../gui/wxpython/mapdisp/toolbars.py:80
-msgid "2D view"
+#: ../gui/wxpython/gcp/mapdisplay.py:158
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:187
+msgid "Target Display"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:849 ../gui/wxpython/mapdisp/frame.py:254
-#, python-format
-msgid ""
-"Unable to start wxGUI vector digitizer.\n"
-"Details: %s"
+#: ../gui/wxpython/gcp/mapdisplay.py:220
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:249
+#: ../gui/wxpython/gui_modules/mapdisp.py:704
+#: ../gui/wxpython/iclass/frame.py:247 ../gui/wxpython/mapdisp/frame.py:380
+msgid "Map Toolbar"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:905
-#, python-format
-msgid "Set opacity of <%s>"
+#: ../gui/wxpython/gcp/mapdisplay.py:233
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:262
+msgid "GCP Display toolbar"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1010
-msgid "Layer group:"
+#: ../gui/wxpython/gcp/mapdisplay.py:246
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:275
+msgid "GCP Manager toolbar"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1015
-#: ../gui/wxpython/lmgr/layertree.py:1538
-msgid "Click to edit layer settings"
+#: ../gui/wxpython/gcp/mapdisplay.py:435
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:467
+#: ../gui/wxpython/gui_modules/mapdisp.py:874
+#: ../gui/wxpython/mapdisp/frame.py:551
+msgid "Nothing to render (empty map). Operation canceled."
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1057
-msgid "(double click to set properties)"
+#: ../gui/wxpython/gcp/mapdisplay.py:450 ../gui/wxpython/gmodeler/frame.py:543
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:482
+#: ../gui/wxpython/gui_modules/gmodeler.py:1249
+#: ../gui/wxpython/gui_modules/histogram.py:404
+#: ../gui/wxpython/gui_modules/mapdisp.py:889
+#: ../gui/wxpython/modules/histogram.py:414
+#: ../gui/wxpython/mapdisp/frame.py:566
+msgid "Choose a file name to save the image (no need to add extension)"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1060
-#: ../gui/wxpython/gui_core/dialogs.py:1210
-#: ../gui/wxpython/gui_core/dialogs.py:1440
-#: ../gui/wxpython/psmap/dialogs.py:696 ../gui/wxpython/gcp/manager.py:329
-#: ../gui/wxpython/gmodeler/frame.py:1334
-msgid "raster"
-msgstr "rastrs"
-#: ../gui/wxpython/lmgr/layertree.py:1063
-msgid "3D raster"
-msgstr "3D rastrs"
-#: ../gui/wxpython/lmgr/layertree.py:1066
-msgid "RGB"
-msgstr "RGB"
-#: ../gui/wxpython/lmgr/layertree.py:1069
-msgid "HIS"
-msgstr "HIS"
-#: ../gui/wxpython/lmgr/layertree.py:1072
-msgid "shaded relief"
+#: ../gui/wxpython/gcp/mapdisplay.py:483
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:515
+#: ../gui/wxpython/gui_modules/wxplot.py:512
+#: ../gui/wxpython/gui_modules/histogram.py:437
+#: ../gui/wxpython/gui_modules/mapdisp.py:922
+#: ../gui/wxpython/modules/histogram.py:447 ../gui/wxpython/wxplot/base.py:505
+#: ../gui/wxpython/mapdisp/frame.py:599
+msgid "Print preview"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1075
-msgid "raster cell numbers"
+#: ../gui/wxpython/gcp/mapdisplay.py:487
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:519
+#: ../gui/wxpython/gui_modules/wxplot.py:513
+#: ../gui/wxpython/gui_modules/histogram.py:441
+#: ../gui/wxpython/gui_modules/mapdisp.py:926
+#: ../gui/wxpython/gui_core/toolbars.py:60
+#: ../gui/wxpython/modules/histogram.py:451 ../gui/wxpython/wxplot/base.py:506
+#: ../gui/wxpython/mapdisp/frame.py:603
+msgid "Print display"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1078
-msgid "raster flow arrows"
+#: ../gui/wxpython/gcp/mapdisplay.py:573
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:605
+msgid "Zoom to computational region (set with g.region)"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1081
-#: ../gui/wxpython/psmap/dialogs.py:697 ../gui/wxpython/gcp/manager.py:329
-#: ../gui/wxpython/gmodeler/frame.py:1335
-msgid "vector"
-msgstr "vektori"
-#: ../gui/wxpython/lmgr/layertree.py:1084
-msgid "thematic area (choropleth) map"
+#: ../gui/wxpython/gcp/mapdisplay.py:577
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:609
+#: ../gui/wxpython/gui_modules/mapdisp.py:1672
+#: ../gui/wxpython/mapdisp/frame.py:1275
+msgid "Zoom to default region"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1087
-msgid "thematic charts"
+#: ../gui/wxpython/gcp/mapdisplay.py:581
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:613
+#: ../gui/wxpython/gui_modules/mapdisp.py:1676
+#: ../gui/wxpython/mapdisp/frame.py:1279
+msgid "Zoom to saved region"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1090
-msgid "grid"
+#: ../gui/wxpython/gcp/mapdisplay.py:585
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:617
+msgid "Set computational region from display"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1093
-msgid "geodesic line"
+#: ../gui/wxpython/gcp/mapdisplay.py:589
+#: ../gui/wxpython/gui_modules/gcpmapdisp.py:621
+#: ../gui/wxpython/gui_modules/mapdisp.py:1684
+#: ../gui/wxpython/mapdisp/frame.py:1287
+msgid "Save display geometry to named region"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1096
-msgid "rhumbline"
+#: ../gui/wxpython/gcp/manager.py:133
+#: ../gui/wxpython/gui_modules/gcpmanager.py:144
+msgid "Setup for georectification"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1099
-msgid "vector labels"
+#: ../gui/wxpython/gcp/manager.py:166 ../gui/wxpython/gcp/manager.py:170
+#: ../gui/wxpython/gui_modules/gcpmanager.py:177
+#: ../gui/wxpython/gui_modules/gcpmanager.py:181
+msgid "Georectifying setup canceled."
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1108
-msgid "wms"
+#: ../gui/wxpython/gcp/manager.py:310
+#: ../gui/wxpython/gui_modules/gcpmanager.py:314
+msgid "Select map type and location/mapset"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1111
-#: ../gui/wxpython/gui_core/ghelp.py:206 ../gui/wxpython/gmodeler/model.py:936
-#: ../gui/wxpython/gmodeler/model.py:1003 ../gui/wxpython/core/gconsole.py:603
-msgid "unknown"
+#: ../gui/wxpython/gcp/manager.py:324
+#: ../gui/wxpython/gui_modules/gcpmanager.py:328
+msgid "Map type to georectify"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1342
-msgid "Please wait, updating data..."
+#: ../gui/wxpython/gcp/manager.py:332
+#: ../gui/wxpython/gui_modules/gcpmanager.py:336
+msgid "Select source location:"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1613
-msgid "opacity:"
+#: ../gui/wxpython/gcp/manager.py:341
+#: ../gui/wxpython/gui_modules/gcpmanager.py:345
+msgid "Select source mapset:"
msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1631 ../gui/wxpython/gis_set.py:534
-#: ../gui/wxpython/animation/utils.py:85 ../gui/wxpython/animation/utils.py:93
-#: ../gui/wxpython/mapswipe/frame.py:353
-#, python-format
-msgid "Map <%s> not found."
-#: ../gui/wxpython/mapwin/decorations.py:308
-msgid "Show text object"
+#: ../gui/wxpython/gcp/manager.py:394
+#: ../gui/wxpython/gui_modules/gcpmanager.py:398
+msgid "You must select a valid location before selecting a mapset"
msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:318
-#: ../gui/wxpython/psmap/dialogs.py:3713
-msgid "Enter text:"
+#: ../gui/wxpython/gcp/manager.py:407
+#: ../gui/wxpython/gui_modules/gcpmanager.py:411
+msgid "You must select a valid location and mapset in order to continue"
msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:348
-#: ../gui/wxpython/animation/dialogs.py:956
-#: ../gui/wxpython/gui_core/preferences.py:422
-#: ../gui/wxpython/gui_core/preferences.py:615
-msgid "Set font"
+#: ../gui/wxpython/gcp/manager.py:426
+#: ../gui/wxpython/gui_modules/gcpmanager.py:430
+msgid "Select image/map group to georectify"
msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:359
-msgid ""
-"Drag text with mouse in pointer mode to position.\n"
-"Double-click to change options"
+#: ../gui/wxpython/gcp/manager.py:445
+#: ../gui/wxpython/gui_modules/gcpmanager.py:449
+msgid "Select group:"
msgstr ""
-#: ../gui/wxpython/mapwin/base.py:194
-#, python-format
-msgid ""
-"Error occured during calling of handler: %s \n"
-"Handler was unregistered."
+#: ../gui/wxpython/gcp/manager.py:456
+#: ../gui/wxpython/gui_modules/gcpmanager.py:460
+msgid "Create group if none exists"
msgstr ""
-#: ../gui/wxpython/mapwin/base.py:273
-#, python-format
-msgid ""
-"Error occured during unregistration of handler: %s \n"
-" Handler was unregistered."
+#: ../gui/wxpython/gcp/manager.py:460
+#: ../gui/wxpython/gui_modules/gcpmanager.py:464
+#: ../gui/wxpython/iclass/dialogs.py:53
+msgid "Create/edit group..."
msgstr ""
-#: ../gui/wxpython/mapwin/base.py:302
-#, python-format
-msgid "Handler: %s was not registered"
+#: ../gui/wxpython/gcp/manager.py:461
+#: ../gui/wxpython/gui_modules/gcpmanager.py:465
+msgid "Add vector map to group..."
msgstr ""
-#: ../gui/wxpython/mapwin/base.py:306
-#, python-format
-msgid ""
-" Handler was unregistered"
+#: ../gui/wxpython/gcp/manager.py:473 ../gui/wxpython/gcp/manager.py:2639
+#: ../gui/wxpython/gui_modules/gcpmanager.py:477
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2631
+msgid "Extension for output maps:"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:137
-#, fuzzy
-msgid "legend"
-msgstr "Leģenda"
-#, fuzzy
-msgid "scale bar"
-msgstr "Mērogjosla"
-#, fuzzy
-msgid "north arrow"
-msgstr "Ziemeļu bulta"
-#: ../gui/wxpython/mapwin/buffered.py:202
-msgid "Copy coordinates to clipboard"
+#: ../gui/wxpython/gcp/manager.py:532
+#: ../gui/wxpython/gui_modules/gcpmanager.py:536
+msgid "You must select a valid image/map group in order to continue"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:212
-#, fuzzy
-msgid "Hide {overlay}"
-msgstr "Pievienot rastru"
-#: ../gui/wxpython/mapwin/buffered.py:219
-#, fuzzy
-msgid "Resize legend"
-msgstr "Kartes mērogs"
-#: ../gui/wxpython/mapwin/buffered.py:540
-#: ../gui/wxpython/modules/histogram.py:178
-msgid "Please wait, exporting image..."
+#: ../gui/wxpython/gcp/manager.py:539
+#: ../gui/wxpython/gui_modules/gcpmanager.py:543
+msgid "You must enter an map name extension in order to continue"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:748
-msgid "Unable to draw registered graphics. The graphics was unregistered."
+#: ../gui/wxpython/gcp/manager.py:605
+#: ../gui/wxpython/gui_modules/gcpmanager.py:609
+msgid "Select maps to display for ground control point (GCP) creation"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1669
-msgid "Zoom to saved region extents"
+#: ../gui/wxpython/gcp/manager.py:613 ../gui/wxpython/gcp/manager.py:2575
+#: ../gui/wxpython/gui_modules/gcpmanager.py:617
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2573
+msgid "Select source map to display:"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1671
-msgid "Set compulational region from named region"
+#: ../gui/wxpython/gcp/manager.py:624 ../gui/wxpython/gcp/manager.py:2580
+msgid "Select target raster map to display:"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1683
-#, python-format
-msgid "Region <%s> not found. Operation canceled."
+#: ../gui/wxpython/gcp/manager.py:635 ../gui/wxpython/gcp/manager.py:2585
+msgid "Select target vector map to display:"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1712
-msgid "Save display extents to region file"
+#: ../gui/wxpython/gcp/manager.py:698
+#: ../gui/wxpython/gui_modules/gcpmanager.py:684
+msgid "You must select a source map in order to continue"
msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1714
-msgid "Save computational region to region file"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1724
+#: ../gui/wxpython/gcp/manager.py:724 ../gui/wxpython/gcp/manager.py:754
+#: ../gui/wxpython/gui_modules/gcpmanager.py:708
#, python-format
-msgid "Region file <%s> already exists. Do you want to overwrite it?"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1726
-#: ../gui/wxpython/wxplot/dialogs.py:803
-#: ../gui/wxpython/core/workspace.py:1070 ../gui/wxpython/core/gcmd.py:140
-msgid "Warning"
-msgstr "Brīdinājums"
-#: ../gui/wxpython/mapwin/graphics.py:215
-#: ../gui/wxpython/mapwin/graphics.py:328
-#, python-format
-msgid "Property does not exist: %s"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:101
-msgid "Choose project location and mapset"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:104
-msgid "Manage"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:106
-#, python-format
msgid ""
-"Welcome to GRASS GIS %s\n"
-"The world's leading open source GIS"
+"No maps in selected group <%s>.\n"
+"Please edit group or select another group."
msgstr ""
-#: ../gui/wxpython/gis_set.py:110
-msgid ""
-"Select an existing project location and mapset\n"
-"or define a new location"
+#: ../gui/wxpython/gcp/manager.py:782
+#: ../gui/wxpython/gui_modules/gcpmanager.py:734
+msgid "Manage Ground Control Points"
msgstr ""
-#: ../gui/wxpython/gis_set.py:114
-#: ../gui/wxpython/location_wizard/wizard.py:111
-msgid "GIS Data Directory:"
-msgstr "GIS datu mape:"
-#: ../gui/wxpython/gis_set.py:127
-msgid ""
-"Project location\n"
-"(projection/coordinate system)"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:130
-msgid ""
-"Accessible mapsets\n"
-"(directories of GIS files)"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:133
-msgid ""
-"Create new mapset\n"
-"in selected location"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:136
-msgid "Define new location"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:139
-msgid ""
-"Rename/delete selected\n"
-"mapset or location"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:144
-msgid "Start &GRASS"
-msgstr "Startēt &GRASS"
-#: ../gui/wxpython/gis_set.py:150
-msgid "&Browse"
-msgstr "&Pārlūkot"
-#: ../gui/wxpython/gis_set.py:152
-msgid "&Create mapset"
-msgstr "Izveidot &karšu kopu"
-#: ../gui/wxpython/gis_set.py:154
-msgid "&Location wizard"
-msgstr "&Novietojuma vednis"
-#: ../gui/wxpython/gis_set.py:155
-msgid ""
-"Start location wizard. After location is created successfully, GRASS session "
-"is started."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:159
-msgid "Rename mapset"
-msgstr ""
-msgid "Rename location"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:160
-msgid "Delete mapset"
-msgstr ""
-msgid "Delete location"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:202
-msgid "Welcome to GRASS GIS"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:210
-msgid "Enter GRASS session"
-#: ../gui/wxpython/gis_set.py:226 ../gui/wxpython/gis_set.py:697
-msgid "Unable to set GRASS database. Check your locale settings."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:244
-msgid "ERROR: Location <%s> not found\n"
-#: ../gui/wxpython/gis_set.py:261
-msgid "ERROR: Mapset <%s> not found\n"
-#: ../gui/wxpython/gis_set.py:405
+#: ../gui/wxpython/gcp/manager.py:1026
#, python-format
-msgid "Invalid line in GISRC file (%s):%s\n"
+msgid "At least %d GCPs required. Operation canceled."
msgstr ""
-#: ../gui/wxpython/gis_set.py:419
-#, fuzzy
-msgid "Warning: "
-#: ../gui/wxpython/gis_set.py:427 ../gui/wxpython/core/gcmd.py:399
-#: ../gui/wxpython/core/gcmd.py:403
-msgid "Error: "
-msgstr "Kļūda: "
-#: ../gui/wxpython/gis_set.py:456
-#, python-format
-msgid ""
-"Do you want to import <%(name)s> to the newly created location? The "
-"location's default region will be set from this imported map."
+#: ../gui/wxpython/gcp/manager.py:1158
+#: ../gui/wxpython/gui_modules/toolbars.py:441
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1122
+msgid "source"
msgstr ""
-#: ../gui/wxpython/gis_set.py:461
-#, fuzzy
-msgid "Import data?"
-#: ../gui/wxpython/gis_set.py:473
-msgid "Do you want to create new mapset?"
+#: ../gui/wxpython/gcp/manager.py:1160
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1124
+msgid "target"
msgstr ""
-#: ../gui/wxpython/gis_set.py:526
-#, python-format
-msgid ""
-"Import of <%(name)s> failed.\n"
-"Reason: %(msg)s"
+#: ../gui/wxpython/gcp/manager.py:1162
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1126
+msgid "Set GCP coordinates"
msgstr ""
-#: ../gui/wxpython/gis_set.py:529
+#: ../gui/wxpython/gcp/manager.py:1163
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1127
#, python-format
-msgid "Data file <%(name)s> imported successfully."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:564
msgid ""
-"Mapset <PERMANENT> is required for valid GRASS location.\n"
+"Set %(coor)s coordinates for GCP No. %(key)s? \n"
"\n"
-"This mapset cannot be renamed."
+"East: %(coor0)s \n"
+"North: %(coor1)s"
msgstr ""
-#: ../gui/wxpython/gis_set.py:569 ../gui/wxpython/gis_set.py:605
-#, python-format
-msgid ""
-"Current name: %s\n"
-"\n"
-"Enter new name:"
+#: ../gui/wxpython/gcp/manager.py:1229
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1191
+msgid "Writing POINTS file failed"
msgstr ""
-#: ../gui/wxpython/gis_set.py:570
-msgid "Rename selected mapset"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:582
+#: ../gui/wxpython/gcp/manager.py:1238
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1200
#, python-format
-msgid ""
-"Unable to rename mapset.\n"
-"\n"
-"Mapset <%s> already exists in location."
+msgid "POINTS file saved for group <%s>"
msgstr ""
-#: ../gui/wxpython/gis_set.py:594
-#, python-format
-msgid ""
-"\n"
-"%s"
+#: ../gui/wxpython/gcp/manager.py:1254
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1216
+msgid "source mapwin not defined"
msgstr ""
-#: ../gui/wxpython/gis_set.py:606
-msgid "Rename selected location"
+#: ../gui/wxpython/gcp/manager.py:1259
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1221
+msgid "target mapwin not defined"
msgstr ""
-#: ../gui/wxpython/gis_set.py:618
-#, python-format
-msgid ""
-"Unable to rename location.\n"
-"\n"
-"Location <%s> already exists in GRASS database."
+#: ../gui/wxpython/gcp/manager.py:1287
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1249
+msgid "Reading POINTS file failed"
msgstr ""
-#: ../gui/wxpython/gis_set.py:631
-#, python-format
+#: ../gui/wxpython/gcp/manager.py:1358
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1320
msgid ""
-"\n"
-"%s"
+"Insufficient points defined and active (checked) for selected rectification "
+"method.\n"
+"3+ points needed for 1st order,\n"
+"6+ points for 2nd order, and\n"
+"10+ points for 3rd order."
msgstr ""
-#: ../gui/wxpython/gis_set.py:643
-msgid ""
-"\n"
-"This mapset cannot be deleted."
+#: ../gui/wxpython/gcp/manager.py:1385
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1347
+msgid "Rectifying images, please wait..."
msgstr ""
-#: ../gui/wxpython/gis_set.py:647
+#: ../gui/wxpython/gcp/manager.py:1426
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1399
#, python-format
-msgid ""
-"Do you want to continue with deleting mapset <%(mapset)s> from location <"
-"%(location)s>?\n"
-"\n"
-"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
+msgid "Transforming <%s>..."
msgstr ""
-#: ../gui/wxpython/gis_set.py:652
-msgid "Delete selected mapset"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:661
-msgid "Unable to delete mapset"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:672
+#: ../gui/wxpython/gcp/manager.py:1430
#, python-format
-msgid ""
-"Do you want to continue with deleting location <%s>?\n"
-"\n"
-"ALL MAPS included in this location will be PERMANENTLY DELETED!"
+msgid "Rectifying vector map <%s>, please wait..."
msgstr ""
-#: ../gui/wxpython/gis_set.py:676
-msgid "Delete selected location"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:687
-msgid "Unable to delete location"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:708
+#: ../gui/wxpython/gcp/manager.py:1463
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1416
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1487
#, python-format
-msgid "No GRASS location found in '%s'."
+msgid "Georectification of vector map <%s> failed"
msgstr ""
-#: ../gui/wxpython/gis_set.py:815
-#, python-format
-msgid "Path '%s' doesn't exist."
+#: ../gui/wxpython/gcp/manager.py:1469
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1493
+msgid "GCP Manager settings"
msgstr ""
-#: ../gui/wxpython/gis_set.py:830 ../gui/wxpython/gui_core/gselect.py:1025
-msgid "Choose GIS Data Directory"
+#: ../gui/wxpython/gcp/manager.py:1514
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1538
+msgid "Quit GCP Manager"
msgstr ""
-#: ../gui/wxpython/gis_set.py:856
-#, python-format
-msgid "Mapset <%s> already exists."
+#: ../gui/wxpython/gcp/manager.py:1515
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1539
+msgid "Save ground control points?"
msgstr ""
-#: ../gui/wxpython/gis_set.py:861
-#, python-format
+#: ../gui/wxpython/gcp/manager.py:1594
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1618
msgid ""
-"Mapset <%s> is reserved for direct read access to OGR layers. Please "
-"consider to use another name for your mapset.\n"
-"\n"
-"Are you really sure that you want to create this mapset?"
+"Could not calculate RMS Error.\n"
+"Possible error with m.transform."
msgstr ""
-#: ../gui/wxpython/gis_set.py:865
-msgid "Reserved mapset name"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:887
-#, python-format
-msgid "Unable to create new mapset: %s"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:900
-#, python-format
+#: ../gui/wxpython/gcp/manager.py:1719
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1743
msgid ""
-"GRASS is already running in selected mapset <%(mapset)s>\n"
-"(file %(lock)s found).\n"
-"\n"
-"Concurrent use not allowed.\n"
-"\n"
-"Do you want to try to remove .gislock (note that you need permission for "
-"this operation) and continue?"
+"Could not calculate new extends.\n"
msgstr ""
-#: ../gui/wxpython/gis_set.py:906 ../gui/wxpython/gis_set.py:918
-msgid "Lock file found"
+#: ../gui/wxpython/gcp/manager.py:1850
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1874
+msgid "Adjust source display to target display"
msgstr ""
-#: ../gui/wxpython/gis_set.py:914
-msgid ""
-"ARE YOU REALLY SURE?\n"
-"\n"
-"If you really are running another GRASS session doing this could corrupt "
-"your data. Have another look in the processor manager just to be sure..."
+#: ../gui/wxpython/gcp/manager.py:1854
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1878
+msgid "Adjust target display to source display"
msgstr ""
-#: ../gui/wxpython/gis_set.py:929
-#, python-format
-msgid ""
-"Unable to remove '%(lock)s'.\n"
-"\n"
-"Details: %(reason)s"
+#: ../gui/wxpython/gcp/manager.py:1926 ../gui/wxpython/gcp/manager.py:1943
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1939
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1956
+msgid "use"
msgstr ""
-#: ../gui/wxpython/gis_set.py:977
-#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for location or mapset. Please use only "
-"ASCII characters excluding %(chars)s and space."
+#: ../gui/wxpython/gcp/manager.py:1927 ../gui/wxpython/gcp/manager.py:1944
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1940
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1957
+msgid "source E"
msgstr ""
-#: ../gui/wxpython/gis_set.py:1045
-msgid "Starting GRASS for the first time"
+#: ../gui/wxpython/gcp/manager.py:1928 ../gui/wxpython/gcp/manager.py:1945
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1941
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1958
+msgid "source N"
msgstr ""
-#: ../gui/wxpython/gis_set.py:1046
-msgid ""
-"GRASS needs a directory in which to store its data. Create one now if you "
-"have not already done so. A popular choice is \"grassdata\", located in your "
-"home directory."
+#: ../gui/wxpython/gcp/manager.py:1929 ../gui/wxpython/gcp/manager.py:1946
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1942
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1959
+msgid "target E"
msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:109
-msgid ""
-"It is not allowed to display data with different temporal types (absolute "
-"and relative)."
+#: ../gui/wxpython/gcp/manager.py:1930 ../gui/wxpython/gcp/manager.py:1947
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1943
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1960
+msgid "target N"
msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:122
-#, python-format
-msgid "It is not allowed to display data with different units (%s)."
+#: ../gui/wxpython/gcp/manager.py:1931 ../gui/wxpython/gcp/manager.py:1948
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1944
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1961
+msgid "Forward error"
msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:133
-msgid ""
-"You are going to display data with different temporal types of maps "
-"(interval and point). It is recommended to use data of one temporal type to "
-"avoid confusion."
+#: ../gui/wxpython/gcp/manager.py:1932 ../gui/wxpython/gcp/manager.py:1949
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1945
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1962
+msgid "Backward error"
msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:317
-#, python-format
-msgid "Topology of Space time dataset %s is invalid."
+#: ../gui/wxpython/gcp/manager.py:2080
+msgid "Invalid coordinate value. Operation canceled."
msgstr ""
-#: ../gui/wxpython/animation/controller.py:222
-#, python-format
-msgid "Maximum number of animations is %s."
+#: ../gui/wxpython/gcp/manager.py:2124
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2128
+msgid "Create vector map group"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:242
-#: ../gui/wxpython/animation/dialogs.py:676
-msgid ""
-"More animations are using one window. Please select different window for "
-"each animation."
+#: ../gui/wxpython/gcp/manager.py:2197
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2201
+msgid "Select vector map(s) to add to group:"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:287
-#: ../gui/wxpython/animation/dialogs.py:553
-#: ../gui/wxpython/psmap/dialogs.py:440 ../gui/wxpython/psmap/dialogs.py:1035
-#: ../gui/wxpython/psmap/dialogs.py:1057 ../gui/wxpython/psmap/dialogs.py:1107
-#: ../gui/wxpython/psmap/dialogs.py:3637 ../gui/wxpython/wxplot/dialogs.py:496
-msgid "Invalid input"
+#: ../gui/wxpython/gcp/manager.py:2244
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2248
+msgid "Edit GCP"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:411
-msgid "Failed to display legend."
+#: ../gui/wxpython/gcp/manager.py:2255
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2259
+msgid "Ground Control Point No."
msgstr ""
-#: ../gui/wxpython/animation/controller.py:442
-msgid "Inconsistent number of maps, please check input data."
+#: ../gui/wxpython/gcp/manager.py:2274
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2278
+msgid "source E:"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:467
-msgid "No animation to export."
+#: ../gui/wxpython/gcp/manager.py:2275
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2279
+msgid "target E:"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:501
-msgid "Preparing export, please wait..."
+#: ../gui/wxpython/gcp/manager.py:2276
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2280
+msgid "source N:"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:535
-#: ../gui/wxpython/animation/frame.py:502
-#, python-format
-msgid "%(from)s %(dash)s %(to)s"
+#: ../gui/wxpython/gcp/manager.py:2277
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2281
+msgid "target N:"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:538
-#, python-format
-msgid "%(start)s %(unit)s"
+#: ../gui/wxpython/gcp/manager.py:2380
+#: ../gui/wxpython/gui_modules/preferences.py:1106
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:665
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1111
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2383
+#: ../gui/wxpython/gui_core/preferences.py:88
+#: ../gui/wxpython/wxplot/dialogs.py:666
+#: ../gui/wxpython/wxplot/dialogs.py:1112
+msgid "Apply changes for the current session"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:553
-msgid "Exporting images, please wait..."
+#: ../gui/wxpython/gcp/manager.py:2382
+#: ../gui/wxpython/gui_modules/preferences.py:1108
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:670
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1112
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2385
+#: ../gui/wxpython/gui_core/preferences.py:90
+#: ../gui/wxpython/wxplot/dialogs.py:671
+#: ../gui/wxpython/wxplot/dialogs.py:1113
+msgid "Apply and save changes to user settings file (default for next sessions)"
msgstr ""
-#: ../gui/wxpython/animation/controller.py:567
-msgid "Exporting animation, please wait..."
+#: ../gui/wxpython/gcp/manager.py:2384 ../gui/wxpython/ogc_services/wms.py:76
+#: ../gui/wxpython/gui_modules/gdialogs.py:1546
+#: ../gui/wxpython/gui_modules/gdialogs.py:1834
+#: ../gui/wxpython/gui_modules/ogc_services.py:77
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2387
+#: ../gui/wxpython/gui_core/dialogs.py:1636
+#: ../gui/wxpython/gui_core/dialogs.py:1938
+msgid "Close dialog"
msgstr ""
-#: ../gui/wxpython/animation/frame.py:45 ../gui/wxpython/menustrings.py:208
-msgid "Animation tool"
+#: ../gui/wxpython/gcp/manager.py:2415
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2418
+msgid "Highlight highest RMS error only"
msgstr ""
-#: ../gui/wxpython/animation/frame.py:118
-#: ../gui/wxpython/mapswipe/frame.py:274
-msgid "Main Toolbar"
+#: ../gui/wxpython/gcp/manager.py:2421
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2424
+msgid "Highlight RMS error > M + SD * factor:"
msgstr ""
-#: ../gui/wxpython/animation/frame.py:128
-msgid "Animation Toolbar"
-msgstr ""
-#: ../gui/wxpython/animation/frame.py:241
-msgid "Window size has changed, rerender maps if needed"
-msgstr ""
-#: ../gui/wxpython/animation/frame.py:504
-#, python-format
-msgid "to %(to)s"
-msgstr ""
-#: ../gui/wxpython/animation/nviztask.py:55
-#, python-format
-msgid "No 3d view information in workspace file <%s>."
-msgstr ""
-#: ../gui/wxpython/animation/g.gui.animation.py:89
-msgid "Options 'rast', 'vect', 'strds' and 'stvds' are mutually exclusive."
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:27
-msgid "Change animation speed"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:28
-msgid "Play forward"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:29
-msgid "Play back"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:32
-msgid "Repeat"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:34
-msgid "Play back and forward"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:35
-#: ../gui/wxpython/animation/toolbars.py:36
-#: ../gui/wxpython/animation/dialogs.py:267
-msgid "Add new animation"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:37
-#: ../gui/wxpython/animation/toolbars.py:38
-msgid "Add, edit or remove animation"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:39
-#: ../gui/wxpython/animation/toolbars.py:40
-#: ../gui/wxpython/animation/dialogs.py:850
-msgid "Export animation"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:45
-msgid "Adjust speed of animation"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:90
-msgid "Simple mode"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:94
-msgid "Frame duration:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:118
-msgid "ms"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:112
-msgid "Temporal mode"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:116
-msgid "Time unit:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:117
-msgid "Duration of time unit:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:169
-msgid "year"
-msgstr ""
-msgid "month"
-msgstr ""
-msgid "day"
-msgstr ""
-msgid "hour"
-msgstr ""
-msgid "minute"
-msgstr ""
-msgid "second"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:232
-msgid "Animation speed is too high."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:269
-msgid "Edit animation"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:281
-msgid "top left"
-msgstr ""
-msgid "top right"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:282
-msgid "bottom left"
-msgstr ""
-msgid "bottom right"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:304
-msgid "Window position:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:307
-msgid "View mode:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:359
-#: ../gui/wxpython/psmap/dialogs.py:2486
-msgid "Show raster legend"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:363
+#: ../gui/wxpython/gcp/manager.py:2422
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2425
msgid ""
-"By default, legend is created for the first raster map in case of multiple "
-"maps and for the first raster map of space time raster dataset."
+"Highlight GCPs with an RMS error larger than \n"
+"mean + standard deviation * given factor. \n"
+"Recommended values for this factor are between 1 and 2."
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:375
-msgid "Input data type:"
+#: ../gui/wxpython/gcp/manager.py:2438
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2441
+msgid "Symbol settings"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:400
-msgid "3D view parameters"
+#: ../gui/wxpython/gcp/manager.py:2464
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2467
+msgid "Color for high RMS error:"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:406
-#, fuzzy
-msgid "Workspace file:"
-msgstr "Darbtelpa"
-#: ../gui/wxpython/animation/dialogs.py:407
-msgid "Choose workspace file to import 3D view parameters"
+#: ../gui/wxpython/gcp/manager.py:2481
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2484
+msgid "Color for selected GCP:"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:413
-msgid "Parameter for animation:"
+#: ../gui/wxpython/gcp/manager.py:2498
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2501
+msgid "Color for unused GCPs:"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:474
-msgid "Select raster maps for animation"
+#: ../gui/wxpython/gcp/manager.py:2514
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2517
+msgid "Show unused GCPs"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:562
-msgid "Add, edit or remove animations"
+#: ../gui/wxpython/gcp/manager.py:2523
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2526
+#: ../gui/wxpython/gui_core/preferences.py:999
+msgid "Symbol size:"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:570
-msgid "List of animations"
+#: ../gui/wxpython/gcp/manager.py:2606
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2598
+msgid "Rectification"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:579 ../gui/wxpython/dbmgr/base.py:2033
-#: ../gui/wxpython/psmap/dialogs.py:1293 ../gui/wxpython/iscatt/dialogs.py:71
-msgid "Add"
+#: ../gui/wxpython/gcp/manager.py:2612
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2604
+msgid "Select rectification order"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:581
-msgid "Edit"
+#: ../gui/wxpython/gcp/manager.py:2613
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2605
+msgid "1st order"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:630
-#, python-format
-msgid "Maximum number of animations is %d."
+msgid "2nd order"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:691
-#, fuzzy
-msgid "Multiple raster maps"
-msgstr "Pievienot vairākas rastra vai vektoru kartes"
-#: ../gui/wxpython/animation/dialogs.py:692
-#, fuzzy
-msgid "Multiple vector maps"
-msgstr "Jauna vektoru karte"
-#: ../gui/wxpython/animation/dialogs.py:693
-#, fuzzy
-msgid "Space time raster dataset"
-msgstr "Rastra datu importēšana"
-#: ../gui/wxpython/animation/dialogs.py:694
-#, fuzzy
-msgid "Space time vector dataset"
-msgstr "Vektordatu importēšana"
-#: ../gui/wxpython/animation/dialogs.py:714
-msgid "No animation name selected."
+msgid "3rd order"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:748
-msgid "No data selected."
+#: ../gui/wxpython/gcp/manager.py:2622
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2614
+msgid "Select interpolation method:"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:786
-msgid "No workspace file selected."
+#: ../gui/wxpython/gcp/manager.py:2633
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2625
+msgid "clip to computational region in target location"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:789
-#, fuzzy, python-format
-msgid "File %s not found"
-msgstr "Karte <%s> nav atrasta."
-#: ../gui/wxpython/animation/dialogs.py:798
-#, python-format
-msgid "Animation %d"
+#: ../gui/wxpython/gcp/manager.py:2672
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2664
+msgid "RMS threshold factor must be > 0"
msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:868
-#: ../gui/wxpython/psmap/dialogs.py:384
-msgid "Format"
-msgstr "Formāts"
-#: ../gui/wxpython/animation/dialogs.py:920
-msgid "Add time stamp"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1751
-#, fuzzy
-msgid "Add image"
-#: ../gui/wxpython/menustrings.py:1749
-#, fuzzy
-msgid "Add text"
-#: ../gui/wxpython/animation/dialogs.py:940
-msgid "Add time stamp, image or text decoration by one of the buttons above."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:942
-msgid "Add image or text decoration by one of the buttons above."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:951
-#, fuzzy
-msgid "Font settings:"
-msgstr "Rādīt iestatījumus"
-#: ../gui/wxpython/animation/dialogs.py:953
-msgid "Sample text"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:965
-#, fuzzy
-msgid "Image file:"
-msgstr "Attēls"
-#: ../gui/wxpython/animation/dialogs.py:966
-msgid "Choose image file"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:974
-#, fuzzy
-msgid "Text:"
-msgstr "Teksts"
-#: ../gui/wxpython/animation/dialogs.py:987
-msgid "Placement as percentage of screen coordinates (X: 0, Y: 0 is top left):"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:996
-#: ../gui/wxpython/psmap/dialogs.py:208
-msgid "X:"
-msgstr "X:"
-#: ../gui/wxpython/animation/dialogs.py:998
-#: ../gui/wxpython/psmap/dialogs.py:209
-msgid "Y:"
-msgstr "Y:"
-#: ../gui/wxpython/animation/dialogs.py:1011
-msgid "To enable export to GIF and SWF, please install visvis library."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1018
-#: ../gui/wxpython/animation/dialogs.py:1020
-msgid "image sequence"
-msgstr ""
-msgid "animated GIF"
-msgstr ""
-#, fuzzy
-msgid "SWF"
-msgstr "WFS"
-msgid "AVI"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1024
-#, fuzzy
-msgid "Export to:"
-msgstr "Eksportēt"
-#: ../gui/wxpython/animation/dialogs.py:1040
-#: ../gui/wxpython/core/settings.py:624
-msgid "animation"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1049
-#: ../gui/wxpython/gui_core/gselect.py:1307
-#: ../gui/wxpython/gui_core/gselect.py:1360
-#, fuzzy
-msgid "Directory:"
-msgstr "Mape"
-#: ../gui/wxpython/animation/dialogs.py:1050
-msgid "Choose directory for export"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1072
-#, fuzzy
-msgid "GIF file:"
-msgstr "Fails:"
-#: ../gui/wxpython/animation/dialogs.py:1073
-#: ../gui/wxpython/animation/dialogs.py:1090
-#: ../gui/wxpython/animation/dialogs.py:1107
-msgid "Choose file to save animation"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1089
-#, fuzzy
-msgid "SWF file:"
-msgstr "Fails:"
-#: ../gui/wxpython/animation/dialogs.py:1106
-msgid "AVI file:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1110
-msgid "Video codec:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1125
-#, python-format
-msgid "Current frame rate: %.2f fps"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1244
-msgid "File %s not found."
-#: ../gui/wxpython/animation/dialogs.py:1246
-msgid "Decoration image file is missing."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1253
-msgid "Directory %s not found."
-#: ../gui/wxpython/animation/dialogs.py:1255
-msgid "Export directory is missing."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1259
-#: ../gui/wxpython/animation/dialogs.py:1263
-msgid "Export file is missing."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1299
-msgid "Time stamp"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1750 ../gui/wxpython/psmap/toolbars.py:92
-#: ../gui/wxpython/psmap/dialogs.py:4061 ../gui/wxpython/psmap/dialogs.py:4109
-msgid "Image"
-msgstr "Attēls"
-#: ../gui/wxpython/menustrings.py:1748 ../gui/wxpython/psmap/toolbars.py:84
-#: ../gui/wxpython/psmap/dialogs.py:3705 ../gui/wxpython/psmap/dialogs.py:3710
-msgid "Text"
-msgstr "Teksts"
-#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:52
-#, python-format
-msgid "Loading attribute data for vector map <%s>..."
-msgstr ""
-#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:54
-msgid "GRASS GIS Attribute Table Manager"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:70
-#, fuzzy
-msgid "GRASS GIS Attribute Table Manager - "
-msgstr "GRASS GIS slāņu pārvaldnieks"
-#: ../gui/wxpython/dbmgr/manager.py:72
-msgid "READONLY - "
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:85
-#, python-format
+#: ../gui/wxpython/gcp/manager.py:2675
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2667
msgid ""
-"Database connection for vector map <%s> is not defined in DB file. You can "
-"define new connection in 'Manage layers' tab."
+"RMS threshold factor is < 1\n"
+"Too many points might be highlighted"
msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:90
-msgid "Please wait, loading attribute data..."
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:99
-msgid "Browse data"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:105
-msgid "Manage tables"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:110
-msgid "Manage layers"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:121
-msgid "Close Attribute Table Manager"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:123
-msgid "Reload attribute data (selected layer only)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:183 ../gui/wxpython/dbmgr/base.py:278
-#: ../gui/wxpython/dbmgr/base.py:798 ../gui/wxpython/dbmgr/base.py:952
-#: ../gui/wxpython/dbmgr/base.py:1254 ../gui/wxpython/dbmgr/base.py:1827
+#: ../gui/wxpython/gcp/manager.py:2826
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2786
#, python-format
-msgid "Number of loaded records: %d"
+msgid "GCP Manager settings saved to file '%s'."
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:145 ../gui/wxpython/iscatt/controllers.py:141
-msgid "Loading data..."
+#: ../gui/wxpython/gmodeler/model.py:58
+#: ../gui/wxpython/gui_modules/gmodeler.py:90
+msgid "model"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:152
-#, python-format
-msgid ""
-"Attribute table <%s> not found. For creating the table switch to 'Manage "
-"layers' tab."
+#: ../gui/wxpython/gmodeler/model.py:59
+#: ../gui/wxpython/gui_modules/gmodeler.py:91
+msgid "Script generated by wxGUI Graphical Modeler."
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:163
+#: ../gui/wxpython/gmodeler/model.py:388 ../gui/wxpython/gmodeler/model.py:450
#, python-format
-msgid "Column <%(column)s> not found in in the table <%(table)s>."
+msgid "undefined variable '%s'"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:236
-msgid "Can display only 256 columns."
+#: ../gui/wxpython/gmodeler/model.py:483
+#: ../gui/wxpython/gui_modules/gmodeler.py:515
+msgid "Running model..."
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:251
-#, python-format
-msgid "Inconsistent number of columns in the table <%(table)s>."
+#: ../gui/wxpython/gmodeler/model.py:502
+#: ../gui/wxpython/gui_modules/gmodeler.py:534
+msgid "Model is empty. Nothing to run."
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:261
-msgid "Viewing limit: 100000 records."
+#: ../gui/wxpython/gmodeler/model.py:511 ../gui/wxpython/gmodeler/frame.py:501
+#: ../gui/wxpython/gui_modules/gmodeler.py:543
+#: ../gui/wxpython/gui_modules/gmodeler.py:1207
+msgid "Validating model..."
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:302
-msgid "Unknown value"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:308
-msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:317
+#: ../gui/wxpython/gmodeler/model.py:517
+#: ../gui/wxpython/gui_modules/gmodeler.py:549
#, python-format
msgid ""
-"Error loading attribute data. Record number: %(rec)d. Unable to convert "
-"value '%(val)s' in key column (%(key)s) to integer.\n"
+"Model is not valid. Do you want to run the model anyway?\n"
"\n"
-"Details: %(detail)s"
+"%s"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:402
-msgid "Sort ascending"
+#: ../gui/wxpython/gmodeler/model.py:519
+#: ../gui/wxpython/gui_modules/gmodeler.py:551
+msgid "Run model?"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:403
-msgid "Sort descending"
+#: ../gui/wxpython/gmodeler/model.py:554
+#: ../gui/wxpython/gui_modules/gmodeler.py:582
+msgid "Variables below not defined:"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:406
-msgid "Calculate (only numeric columns)"
-msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:663
+#: ../gui/wxpython/gui_modules/gmodeler.py:690
+msgid "Raster maps"
+msgstr "Rastra kartes"
-#: ../gui/wxpython/dbmgr/base.py:408
-msgid "Field calculator"
+#: ../gui/wxpython/gmodeler/model.py:666
+#: ../gui/wxpython/gui_modules/gmodeler.py:693
+msgid "3D raster maps"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:413 ../gui/wxpython/dbmgr/base.py:1991
-#: ../gui/wxpython/modules/colorrules.py:1019
-msgid "Add column"
-msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:925 ../gui/wxpython/gmodeler/model.py:992
+#: ../gui/wxpython/gui_modules/gmodeler.py:1917
+#: ../gui/wxpython/gui_modules/gmodeler.py:1984
+#: ../gui/wxpython/gui_core/goutput.py:869
+msgid "unknown"
+msgstr "nezināms"
-#: ../gui/wxpython/dbmgr/base.py:424
-msgid "Area size"
-msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1240
+#: ../gui/wxpython/gui_modules/gmodeler.py:2231
+msgid "<not defined>"
+msgstr "<nav definēts>"
-#: ../gui/wxpython/dbmgr/base.py:425
-msgid "Line length"
-msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1350
+#: ../gui/wxpython/gui_modules/gmodeler.py:4328
+msgid "Condition: "
+msgstr "Nosacījums: "
-#: ../gui/wxpython/dbmgr/base.py:426
-msgid "Compactness of an area"
-msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1352
+#: ../gui/wxpython/gui_modules/gmodeler.py:4330
+msgid "Condition: not defined"
+msgstr "Nosacījums: nav definēts"
-#: ../gui/wxpython/dbmgr/base.py:427
-msgid "Fractal dimension of boundary defining a polygon"
-msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1413
+#: ../gui/wxpython/gui_modules/gmodeler.py:4426
+msgid "loop"
+msgstr "cilpa"
-#: ../gui/wxpython/dbmgr/base.py:428
-msgid "Perimeter length of an area"
+#: ../gui/wxpython/gmodeler/model.py:1454
+#: ../gui/wxpython/gui_modules/gmodeler.py:4803
+msgid "if-else"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:429
-msgid "Number of features for each category"
+#: ../gui/wxpython/gmodeler/model.py:2148
+#: ../gui/wxpython/gui_modules/gmodeler.py:3898
+msgid "Model parameters"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:430
-msgid "Slope steepness of 3D line"
+#: ../gui/wxpython/gmodeler/model.py:2165
+msgid "Delete intermediate data when finish"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:431
-msgid "Line sinuousity"
-msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:2173
+#: ../gui/wxpython/gmodeler/frame.py:1454
+#: ../gui/wxpython/gui_modules/gmodeler.py:3916
+#: ../gui/wxpython/gui_modules/vclean.py:165
+#: ../gui/wxpython/gui_modules/menuform.py:503
+#: ../gui/wxpython/gui_modules/ghelp.py:229
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:131
+#: ../gui/wxpython/gui_core/forms.py:460 ../gui/wxpython/gui_core/ghelp.py:212
+#: ../gui/wxpython/modules/vclean.py:156
+#: ../gui/wxpython/modules/mcalc_builder.py:127
+#: ../gui/wxpython/scripts/vkrige.py:152
+msgid "&Run"
+msgstr "&Darbināt"
-#: ../gui/wxpython/dbmgr/base.py:432
-msgid "Line azimuth"
-msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:2217
+#: ../gui/wxpython/gmodeler/frame.py:112
+#: ../gui/wxpython/gui_modules/gmodeler.py:837
+#: ../gui/wxpython/gui_modules/gmodeler.py:3951
+msgid "Variables"
+msgstr "Mainīgie"
-#: ../gui/wxpython/dbmgr/base.py:527
-#, python-format
-msgid "Add column to table <%s>"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:28
+#: ../gui/wxpython/menustrings.py:936
+#: ../gui/wxpython/gui_modules/gmodeler.py:3395
+msgid "Modeler settings"
+msgstr "Modelētāja iestatījumi"
-#: ../gui/wxpython/dbmgr/base.py:894
-msgid "Unable to add column to the table. No column name defined."
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:45
+#: ../gui/wxpython/gui_modules/gmodeler.py:3412
+#: ../gui/wxpython/gui_modules/preferences.py:1272
+#: ../gui/wxpython/gui_modules/vdigit.py:151
+#: ../gui/wxpython/gui_core/preferences.py:274
+#: ../gui/wxpython/vdigit/preferences.py:118
+msgid "General"
+msgstr "Vispārēji"
-#: ../gui/wxpython/dbmgr/base.py:907
-#, python-format
-msgid "Column <%(column)s> already exists in table <%(table)s>."
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:50
+#: ../gui/wxpython/gui_modules/gmodeler.py:3417
+msgid "Item properties"
+msgstr "Vienuma īpašības"
-#: ../gui/wxpython/dbmgr/base.py:981
-msgid "Attribute data - right-click to edit/manage records"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:58
+#: ../gui/wxpython/gui_modules/gmodeler.py:3425
+msgid "Disabled:"
+msgstr "Atslēgts:"
-#: ../gui/wxpython/dbmgr/base.py:996 ../gui/wxpython/dbmgr/base.py:1952
-#: ../gui/wxpython/dbmgr/base.py:2535 ../gui/wxpython/dbmgr/base.py:2665
-#: ../gui/wxpython/dbmgr/base.py:2918
-msgid "Table"
-msgstr "Tabula"
+#: ../gui/wxpython/gmodeler/preferences.py:83
+#: ../gui/wxpython/gui_modules/gmodeler.py:3450
+msgid "Action"
+msgstr "Darbība"
-#: ../gui/wxpython/dbmgr/base.py:998 ../gui/wxpython/dbmgr/base.py:1954
-msgid " (readonly)"
-msgstr "(tikai lasīšanai)"
+#: ../gui/wxpython/gmodeler/preferences.py:96
+#: ../gui/wxpython/gmodeler/preferences.py:334
+#: ../gui/wxpython/gui_modules/gmodeler.py:3463
+#: ../gui/wxpython/gui_modules/gmodeler.py:3701
+msgid "Valid:"
+msgstr "Derīgs:"
-#: ../gui/wxpython/dbmgr/base.py:1012
-msgid "SQL Query"
-msgstr "SQL vaicājums"
+#: ../gui/wxpython/gmodeler/preferences.py:113
+#: ../gui/wxpython/gui_modules/gmodeler.py:3480
+msgid "Invalid:"
+msgstr "Nederīgs:"
-#: ../gui/wxpython/dbmgr/base.py:1041
-msgid "Simple"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:130
+#: ../gui/wxpython/gui_modules/gmodeler.py:3497
+msgid "Running:"
+msgstr "Darbojas:"
-#: ../gui/wxpython/dbmgr/base.py:1044
-msgid "Apply SELECT statement and reload data records"
+#: ../gui/wxpython/gmodeler/preferences.py:150
+#: ../gui/wxpython/gmodeler/preferences.py:269
+#: ../gui/wxpython/gmodeler/preferences.py:354
+#: ../gui/wxpython/gui_modules/gmodeler.py:3517
+#: ../gui/wxpython/gui_modules/gmodeler.py:3636
+#: ../gui/wxpython/gui_modules/gmodeler.py:3721
+msgid "Shape size"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1058 ../gui/wxpython/dbmgr/base.py:1075
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:389
-#, python-format
-msgid "Example: %s"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:202
+#: ../gui/wxpython/nviz/tools.py:88
+#: ../gui/wxpython/gui_modules/gmodeler.py:3569
+#: ../gui/wxpython/gui_modules/nviz_tools.py:255
+msgid "Data"
+msgstr "Dati"
-#: ../gui/wxpython/dbmgr/base.py:1066
-msgid "Advanced"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:207
+#: ../gui/wxpython/gui_modules/gmodeler.py:3574
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:923
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:974
+#: ../gui/wxpython/dbmgr/manager.py:896 ../gui/wxpython/wxplot/dialogs.py:924
+#: ../gui/wxpython/wxplot/dialogs.py:975
+msgid "Type"
+msgstr "Tips"
-#: ../gui/wxpython/dbmgr/base.py:1068
-msgid "SQL Builder"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:215
+#: ../gui/wxpython/gui_modules/gmodeler.py:3582
+msgid "Raster:"
+msgstr "Rastrs:"
-#: ../gui/wxpython/dbmgr/base.py:1219 ../gui/wxpython/core/settings.py:817
-msgid "Edit selected record"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:232
+#: ../gui/wxpython/gui_modules/gmodeler.py:3599
+msgid "3D raster:"
+msgstr "3D rastrs:"
-#: ../gui/wxpython/dbmgr/base.py:1223 ../gui/wxpython/dbmgr/base.py:1398
-msgid "Insert new record"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:249
+#: ../gui/wxpython/gui_modules/gmodeler.py:3616
+msgid "Vector:"
+msgstr "Vektori:"
-#: ../gui/wxpython/dbmgr/base.py:1224
-msgid "Delete selected record(s)"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:321
+#: ../gui/wxpython/gui_modules/gmodeler.py:3688
+msgid "Loop"
+msgstr "Cilpa"
-#: ../gui/wxpython/dbmgr/base.py:1225
-msgid "Delete all records"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:421
+#: ../gui/wxpython/menustrings.py:950
+#: ../gui/wxpython/gui_modules/gmodeler.py:3788
+msgid "Model properties"
+msgstr "Modeļa īpašības"
-#: ../gui/wxpython/dbmgr/base.py:1231 ../gui/wxpython/gui_core/widgets.py:745
-#: ../gui/wxpython/gui_core/dialogs.py:1326
-msgid "Select all"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:428
+#: ../gui/wxpython/lmgr/layertree.py:417 ../gui/wxpython/lmgr/layertree.py:450
+#: ../gui/wxpython/gui_modules/gmodeler.py:3795
+#: ../gui/wxpython/gui_modules/layertree.py:383
+#: ../gui/wxpython/gui_modules/layertree.py:416
+msgid "Metadata"
+msgstr "Metadati"
-#: ../gui/wxpython/dbmgr/base.py:1232 ../gui/wxpython/gui_core/widgets.py:746
-#: ../gui/wxpython/gui_core/dialogs.py:1328
-msgid "Deselect all"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:430
+#: ../gui/wxpython/gui_modules/gmodeler.py:3797
+msgid "Commands"
+msgstr "Komandas"
-#: ../gui/wxpython/dbmgr/base.py:1234
-msgid "Highlight selected features"
+#: ../gui/wxpython/gmodeler/preferences.py:442
+#: ../gui/wxpython/gui_modules/gmodeler.py:3809
+#: ../gui/wxpython/gui_modules/gdialogs.py:1536
+#: ../gui/wxpython/gui_modules/vclean.py:144
+#: ../gui/wxpython/gui_modules/preferences.py:1724
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:228
+#: ../gui/wxpython/gui_core/preferences.py:798
+#: ../gui/wxpython/gui_core/dialogs.py:1626
+#: ../gui/wxpython/modules/vclean.py:135
+#: ../gui/wxpython/modules/mcalc_builder.py:224
+#: ../gui/wxpython/scripts/vkrige.py:139
+msgid "Allow output files to overwrite existing files"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1235
-msgid "Highlight selected features and zoom"
+#: ../gui/wxpython/gmodeler/preferences.py:450
+#: ../gui/wxpython/gui_modules/gmodeler.py:3817
+msgid "Apply properties"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1239 ../gui/wxpython/dbmgr/base.py:1710
-msgid "Extract selected features"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:464
+#: ../gui/wxpython/gui_modules/gselect.py:1224
+#: ../gui/wxpython/gui_modules/gselect.py:1227
+#: ../gui/wxpython/gui_modules/gselect.py:1236
+#: ../gui/wxpython/gui_modules/gselect.py:1373
+#: ../gui/wxpython/gui_modules/gmodeler.py:3831
+#: ../gui/wxpython/gui_core/gselect.py:1245
+#: ../gui/wxpython/gui_core/gselect.py:1248
+#: ../gui/wxpython/gui_core/gselect.py:1257
+#: ../gui/wxpython/gui_core/gselect.py:1258
+#: ../gui/wxpython/gui_core/gselect.py:1400
+msgid "Name:"
+msgstr "Nosaukums:"
-#: ../gui/wxpython/dbmgr/base.py:1240
-msgid "Delete selected features"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:473
+#: ../gui/wxpython/gui_modules/gmodeler.py:3840
+msgid "Description:"
+msgstr "Apraksts:"
-#: ../gui/wxpython/dbmgr/base.py:1248 ../gui/wxpython/dbmgr/base.py:2218
-#: ../gui/wxpython/vdigit/dialogs.py:280
-#: ../gui/wxpython/gmodeler/dialogs.py:752
-#: ../gui/wxpython/gmodeler/dialogs.py:927
-msgid "Reload"
-msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:482
+#: ../gui/wxpython/gui_modules/gmodeler.py:3849
+msgid "Author(s):"
+msgstr "Autors:"
-#: ../gui/wxpython/dbmgr/base.py:1301
-msgid "Update existing record"
-msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:47
+#: ../gui/wxpython/gui_modules/gmodeler.py:2241
+msgid "Data properties"
+msgstr "Datu īpašības"
-#: ../gui/wxpython/dbmgr/base.py:1327 ../gui/wxpython/dbmgr/base.py:1433
-#, python-format
-msgid "Value '%(value)s' needs to be entered as %(type)s."
-msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:73
+#: ../gui/wxpython/gui_modules/gmodeler.py:2268
+#: ../gui/wxpython/iclass/dialogs.py:93
+msgid "Name of raster map:"
+msgstr "Rastra kartes nosaukums:"
-#: ../gui/wxpython/dbmgr/base.py:1341
-#, python-format
-msgid ""
-"Unable to update existing record.\n"
-"%s"
-msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:75
+#: ../gui/wxpython/gui_modules/gmodeler.py:2270
+#: ../gui/wxpython/iclass/dialogs.py:95
+msgid "Name of vector map:"
+msgstr "Vektoru kartes nosaukums:"
-#: ../gui/wxpython/dbmgr/base.py:1409
-#, python-format
-msgid "Record with category number %d already exists in the table."
-msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:78
+#: ../gui/wxpython/gui_modules/gmodeler.py:2273
+msgid "Name of element:"
+msgstr "Elementa nosaukums:"
-#: ../gui/wxpython/dbmgr/base.py:1419
-#, python-format
-msgid "Category number (column %s) is missing."
+#: ../gui/wxpython/gmodeler/dialogs.py:117
+#: ../gui/wxpython/gui_modules/gmodeler.py:2565
+msgid "Add new GRASS module to the model"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1444
-#, python-format
-msgid ""
-"Unable to insert new record.\n"
-"%s"
-msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:135
+#: ../gui/wxpython/gmodeler/dialogs.py:391
+#: ../gui/wxpython/gmodeler/dialogs.py:493
+#: ../gui/wxpython/gui_modules/gmodeler.py:2583
+#: ../gui/wxpython/gui_modules/gmodeler.py:4359
+#: ../gui/wxpython/gui_modules/gmodeler.py:4839
+#: ../gui/wxpython/gui_modules/preferences.py:1709
+#: ../gui/wxpython/gui_core/preferences.py:783
+msgid "Command"
+msgstr "Komanda"
-#: ../gui/wxpython/dbmgr/base.py:1494
-#, python-format
+#: ../gui/wxpython/gmodeler/dialogs.py:204
+#: ../gui/wxpython/gui_modules/gmodeler.py:2652
msgid ""
-"Selected data records (%d) will be permanently deleted from table. Do you "
-"want to delete them?"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1497 ../gui/wxpython/dbmgr/base.py:1543
-#: ../gui/wxpython/gmodeler/dialogs.py:872
-msgid "Delete records"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1540
-#, python-format
-msgid ""
-"All data records (%d) will be permanently deleted from table. Do you want to "
-"delete them?"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1706
-msgid "Nothing to extract."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1739
-msgid "Nothing to delete."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1789 ../gui/wxpython/dbmgr/base.py:1812
-#, python-format
-msgid ""
-"Loading attribute data failed.\n"
+"Command not defined.\n"
"\n"
-"%s"
+"Unable to add new action to the model."
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1800
+#: ../gui/wxpython/gmodeler/dialogs.py:210
+#: ../gui/wxpython/gui_modules/gmodeler.py:2658
#, python-format
msgid ""
-"Invalid SQL select statement.\n"
+"'%s' is not a GRASS module.\n"
"\n"
-"%s"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1968 ../gui/wxpython/dbmgr/sqlbuilder.py:86
-msgid "Database connection"
+#: ../gui/wxpython/gmodeler/dialogs.py:245
+#: ../gui/wxpython/gui_modules/gmodeler.py:2766
+msgid "Relation properties"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1980
-#, python-format
-msgid "Table <%s> - right-click to delete column(s)"
-msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:262
+#: ../gui/wxpython/gui_modules/gmodeler.py:2783
+msgid "From"
+msgstr "No"
-#: ../gui/wxpython/dbmgr/base.py:1999 ../gui/wxpython/dbmgr/base.py:2050
-#: ../gui/wxpython/dbmgr/dialogs.py:749
-msgid "Column"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2026 ../gui/wxpython/dbmgr/dialogs.py:763
-msgid "Length"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2042 ../gui/wxpython/menustrings.py:908
-#: ../gui/wxpython/menustrings.py:1573
-msgid "Rename column"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2062 ../gui/wxpython/gmodeler/dialogs.py:286
+#: ../gui/wxpython/gmodeler/dialogs.py:264
+#: ../gui/wxpython/gui_modules/gmodeler.py:2785
+#: ../gui/wxpython/gui_modules/dbm.py:935 ../gui/wxpython/dbmgr/manager.py:944
msgid "To"
-msgstr ""
+msgstr "Uz"
-#: ../gui/wxpython/dbmgr/base.py:2069
-msgid "&Rename"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2162
-msgid "Unable to rename column. No column name defined."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2170
+#: ../gui/wxpython/gmodeler/dialogs.py:306
+#: ../gui/wxpython/gui_modules/gmodeler.py:2827
#, python-format
-msgid ""
-"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
-"exists in the table <%(table)s>."
-msgstr ""
+msgid "Data: %s"
+msgstr "Dati: %s"
-#: ../gui/wxpython/dbmgr/base.py:2186
-#, python-format
-msgid ""
-"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
-"%(table)s>."
-msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:312
+#: ../gui/wxpython/gui_modules/gmodeler.py:2833
+msgid "Command:"
+msgstr "Komanda:"
-#: ../gui/wxpython/dbmgr/base.py:2213
-msgid "Drop selected column"
+#: ../gui/wxpython/gmodeler/dialogs.py:318
+#: ../gui/wxpython/gui_modules/gmodeler.py:2839
+msgid "Option:"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2216
-msgid "Drop all columns"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2235
-#, python-format
+#: ../gui/wxpython/gmodeler/dialogs.py:333
+#: ../gui/wxpython/gui_modules/gmodeler.py:2854
msgid ""
-"Selected column '%s' will PERMANENTLY removed from table. Do you want to "
-"drop the column?"
+"Relation doesn't start with data item.\n"
+"Unable to add relation."
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2238 ../gui/wxpython/dbmgr/base.py:2275
-msgid "Drop column(s)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2272
-#, python-format
+#: ../gui/wxpython/gmodeler/dialogs.py:340
+#: ../gui/wxpython/gui_modules/gmodeler.py:2861
msgid ""
-"Selected columns\n"
-"%s\n"
-"will PERMANENTLY removed from table. Do you want to drop the columns?"
+"Relation doesn't point to GRASS command.\n"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2360
-msgid "List of layers"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2440 ../gui/wxpython/dbmgr/base.py:2841
-#: ../gui/wxpython/dbmgr/base.py:3261
-#, python-format
-msgid "Drop also linked attribute table (%s)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2481
-msgid "Column name"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2481 ../gui/wxpython/gmodeler/frame.py:1322
-#: ../gui/wxpython/gmodeler/frame.py:1371
-msgid "Data type"
-msgstr ""
-msgid "Data length"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2535 ../gui/wxpython/dbmgr/base.py:2648
-#: ../gui/wxpython/dbmgr/base.py:2898 ../gui/wxpython/dbmgr/dialogs.py:490
-#: ../gui/wxpython/vdigit/preferences.py:379
-#: ../gui/wxpython/vdigit/preferences.py:381
-#: ../gui/wxpython/vdigit/dialogs.py:113 ../gui/wxpython/vdigit/dialogs.py:557
-msgid "Layer"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2535 ../gui/wxpython/dbmgr/base.py:2654
-#: ../gui/wxpython/dbmgr/base.py:2906
-msgid "Driver"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2535 ../gui/wxpython/dbmgr/base.py:2659
-#: ../gui/wxpython/dbmgr/base.py:2912 ../gui/wxpython/gui_core/gselect.py:1240
-msgid "Database"
-msgstr ""
-msgid "Key"
-msgstr "Atslēga"
-#: ../gui/wxpython/dbmgr/base.py:2611
+#: ../gui/wxpython/gmodeler/dialogs.py:353
+#: ../gui/wxpython/gui_modules/gmodeler.py:2874
msgid ""
-"Unknown default DB connection. Please define DB connection using db.connect "
-"module."
+"No relevant option found.\n"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2630
-msgid "Add layer"
+#: ../gui/wxpython/gmodeler/dialogs.py:384
+#: ../gui/wxpython/gui_modules/gmodeler.py:4352
+msgid "Condition"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2640
-msgid "Layer description"
+#: ../gui/wxpython/gmodeler/dialogs.py:390
+#: ../gui/wxpython/gmodeler/dialogs.py:492
+#: ../gui/wxpython/gmodeler/frame.py:1417
+#: ../gui/wxpython/gui_modules/gmodeler.py:4358
+#: ../gui/wxpython/gui_modules/gmodeler.py:4514
+#: ../gui/wxpython/gui_modules/gmodeler.py:4838
+msgid "ID"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2670 ../gui/wxpython/dbmgr/base.py:2708
-#: ../gui/wxpython/dbmgr/base.py:2924
-msgid "Key column"
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1272
+#: ../gui/wxpython/gmodeler/frame.py:1315
+#: ../gui/wxpython/gui_modules/gmodeler.py:4040
+#: ../gui/wxpython/gui_modules/gmodeler.py:4083
+#: ../gui/wxpython/gui_modules/ghelp.py:705
+#: ../gui/wxpython/gui_modules/ghelp.py:707
+#: ../gui/wxpython/gui_modules/ghelp.py:768
+#: ../gui/wxpython/gui_core/ghelp.py:647 ../gui/wxpython/gui_core/ghelp.py:649
+#: ../gui/wxpython/gui_core/ghelp.py:712
+msgid "Name"
+msgstr "Nosaukums"
-#: ../gui/wxpython/dbmgr/base.py:2675
-msgid "Insert record for each category into table"
+#: ../gui/wxpython/gmodeler/dialogs.py:409
+#: ../gui/wxpython/gui_modules/gmodeler.py:4434
+msgid "Loop properties"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2690
-msgid "You need to add categories by v.category module."
+#: ../gui/wxpython/gmodeler/dialogs.py:415
+#: ../gui/wxpython/gui_modules/gmodeler.py:4440
+msgid "List of items in loop"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2695
-msgid "Table description"
+#: ../gui/wxpython/gmodeler/dialogs.py:418
+#: ../gui/wxpython/gui_modules/gmodeler.py:4443
+msgid "Series"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2703
-msgid "Table name"
-msgstr "Tabulas nosaukums"
-#: ../gui/wxpython/dbmgr/base.py:2716
-msgid "&Create table"
+#: ../gui/wxpython/gmodeler/dialogs.py:419
+#: ../gui/wxpython/gui_modules/gmodeler.py:4444
+msgid "Define map series as condition for the loop"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2724
-msgid "&Set default"
+#: ../gui/wxpython/gmodeler/dialogs.py:463
+#: ../gui/wxpython/gui_modules/gmodeler.py:4488
+msgid "Define series of maps"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2824
-msgid "Remove layer"
+#: ../gui/wxpython/gmodeler/dialogs.py:478
+#: ../gui/wxpython/gui_modules/gmodeler.py:4824
+msgid "If-else properties"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2827
-msgid "Layer to remove"
+#: ../gui/wxpython/gmodeler/dialogs.py:484
+#: ../gui/wxpython/gui_modules/gmodeler.py:4830
+msgid "List of items in 'if' block"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2848
-msgid "&Remove layer"
+#: ../gui/wxpython/gmodeler/dialogs.py:489
+#: ../gui/wxpython/gui_modules/gmodeler.py:4835
+msgid "List of items in 'else' block"
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2891
-msgid "Modify layer"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2963
-msgid "&Modify layer"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3011
-msgid ""
-"Unable to get list of tables.\n"
-"Please use db.connect to set database parameters."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3108
-msgid "Unable to create new table. Table name or key column name is missing."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3114
+#: ../gui/wxpython/gmodeler/dialogs.py:653
+#: ../gui/wxpython/gui_modules/gmodeler.py:4217
#, python-format
-msgid "Unable to create new table. Table <%s> already exists in the database."
+msgid "Variable <%s> already exists in the model. Adding variable failed."
msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3152
-#, python-format
-msgid ""
-"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
-"exists."
+#: ../gui/wxpython/gmodeler/dialogs.py:682
+#: ../gui/wxpython/gui_modules/gmodeler.py:4246
+msgid "Do you want to delete all variables from the model?"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:98 ../gui/wxpython/menustrings.py:890
-#: ../gui/wxpython/menustrings.py:1555
-msgid "Query"
+#: ../gui/wxpython/gmodeler/dialogs.py:684
+#: ../gui/wxpython/gui_modules/gmodeler.py:4248
+msgid "Delete variables"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:114
-msgid "Set SQL statement to default"
+#: ../gui/wxpython/gmodeler/dialogs.py:723
+#: ../gui/wxpython/gmodeler/dialogs.py:897
+#: ../gui/wxpython/gui_modules/gmodeler.py:4287
+#: ../gui/wxpython/gui_modules/gmodeler.py:4698
+#: ../gui/wxpython/gui_modules/vdigit.py:1059
+#: ../gui/wxpython/vdigit/dialogs.py:272
+msgid "Delete selected"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:116
-#, fuzzy
-msgid "Apply SQL statement in Attribute Table Manager"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:118
-msgid "Close the dialog"
+#: ../gui/wxpython/gmodeler/dialogs.py:724
+#: ../gui/wxpython/gmodeler/dialogs.py:898
+#: ../gui/wxpython/gui_modules/gmodeler.py:4288
+#: ../gui/wxpython/gui_modules/gmodeler.py:4699
+#: ../gui/wxpython/gui_modules/vdigit.py:1063
+#: ../gui/wxpython/vdigit/dialogs.py:276
+msgid "Delete all"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:169
-msgid "Columns"
+#: ../gui/wxpython/gmodeler/dialogs.py:730
+#: ../gui/wxpython/gmodeler/dialogs.py:905
+#: ../gui/wxpython/gui_modules/gmodeler.py:4294
+#: ../gui/wxpython/gui_modules/gmodeler.py:4706
+#: ../gui/wxpython/gui_modules/dbm.py:1145
+#: ../gui/wxpython/gui_modules/dbm.py:1660
+#: ../gui/wxpython/gui_modules/vdigit.py:1065
+#: ../gui/wxpython/dbmgr/manager.py:1149 ../gui/wxpython/dbmgr/manager.py:1675
+#: ../gui/wxpython/vdigit/dialogs.py:278
+msgid "Reload"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:180
-msgid "Interactive insertion"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:194
-msgid "Values"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:204
-msgid "Get all values"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:207
-msgid "Get sample"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:208
-msgid "Get first 256 unique values as sample"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:228
-msgid "Close dialog on apply"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:373
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:515
+#: ../gui/wxpython/gmodeler/dialogs.py:847
+#: ../gui/wxpython/gui_modules/gmodeler.py:4648
+#: ../gui/wxpython/gui_modules/dbm.py:1177
#, python-format
-msgid "GRASS SQL Builder (%(type)s) - <%(map)s>"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:376
-msgid "Column to show (SELECT clause)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:377
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:519
-msgid "Constraint for query (WHERE clause)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:392
-msgid "Verify"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:393
-msgid "Verify SQL statement"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:401
-msgid "SQL statement not verified"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:445
-msgid "SQL statement is not valid"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:447
-#, python-format
msgid ""
-"SQL statement is not valid.\n"
-"\n"
-"%s"
+"Selected data records (%d) will permanently deleted from table. Do you want "
+"to delete them?"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:449
-msgid "SQL statement is valid"
+#: ../gui/wxpython/gmodeler/dialogs.py:850
+#: ../gui/wxpython/gui_modules/gmodeler.py:4651
+#: ../gui/wxpython/gui_modules/dbm.py:1180
+#: ../gui/wxpython/gui_modules/dbm.py:1226
+#: ../gui/wxpython/dbmgr/manager.py:1184 ../gui/wxpython/dbmgr/manager.py:1230
+msgid "Delete records"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:518
-msgid "Column to set (SET clause)"
+#: ../gui/wxpython/gmodeler/dialogs.py:904
+#: ../gui/wxpython/gui_modules/gmodeler.py:4705
+msgid "Normalize"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:520
-msgid "Calculate column value to set"
+#: ../gui/wxpython/gmodeler/frame.py:59
+#: ../gui/wxpython/gui_modules/gmodeler.py:786
+msgid "GRASS GIS Graphical Modeler"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:570
-msgid "Functions"
+#: ../gui/wxpython/gmodeler/frame.py:110
+#: ../gui/wxpython/gui_modules/gmodeler.py:835
+msgid "Model"
msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:603
-#, fuzzy
-msgid "SQL statement was not applied"
-msgstr "SQL izteikums"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:607
-#, fuzzy
-msgid "SQL statement applied"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:638
-msgid "Dbf driver does not support usage of SQL functions."
+#: ../gui/wxpython/gmodeler/frame.py:111
+#: ../gui/wxpython/gui_modules/gmodeler.py:836
+msgid "Items"
msgstr ""
-#, python-format
-msgid ""
-"No attribute table found.\n"
-"\n"
-"Do you want to create a new attribute table and defined a link to vector map "
-"<%s>?"
+#: ../gui/wxpython/gmodeler/frame.py:113
+msgid "Python editor"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:77
-msgid "Create table?"
+#: ../gui/wxpython/gmodeler/frame.py:114
+#: ../gui/wxpython/gui_modules/gmodeler.py:838
+#: ../gui/wxpython/gui_modules/menuform.py:842
+#: ../gui/wxpython/gui_core/forms.py:801 ../gui/wxpython/scripts/vkrige.py:108
+msgid "Command output"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:97
-msgid "Close dialog on submit"
+#: ../gui/wxpython/gmodeler/frame.py:179
+#: ../gui/wxpython/gui_core/goutput.py:1358
+msgid "Python script contains local modifications"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:109
-msgid "No attributes found"
+#: ../gui/wxpython/gmodeler/frame.py:181
+#: ../gui/wxpython/gmodeler/frame.py:1601
+msgid "Python script is up-to-date"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:115 ../gui/wxpython/menustrings.py:679
-#: ../gui/wxpython/menustrings.py:1344
-msgid "Update attributes"
+#: ../gui/wxpython/gmodeler/frame.py:196
+#: ../gui/wxpython/gui_modules/gmodeler.py:905
+msgid "Redrawing model..."
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:117
-msgid "Define attributes"
+#: ../gui/wxpython/gmodeler/frame.py:231
+#: ../gui/wxpython/gui_modules/gmodeler.py:937
+msgid "Do you want to save changes in the model?"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:119
-msgid "Display attributes"
+#: ../gui/wxpython/gmodeler/frame.py:233
+#: ../gui/wxpython/gui_modules/gmodeler.py:939
+msgid "Do you want to store current model settings to model file?"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:123
-msgid "&Reload"
+#: ../gui/wxpython/gmodeler/frame.py:239
+#: ../gui/wxpython/gui_modules/gmodeler.py:945
+msgid "Quit Graphical Modeler"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:124 ../gui/wxpython/dbmgr/dialogs.py:594
-msgid "&Submit"
+#: ../gui/wxpython/gmodeler/frame.py:300
+msgid "No intermediate data to delete."
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:142 ../gui/wxpython/vdigit/dialogs.py:168
-msgid "Feature id:"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:225
+#: ../gui/wxpython/gmodeler/frame.py:304
+#: ../gui/wxpython/gui_modules/gmodeler.py:1010
#, python-format
-msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
+msgid "Do you want to permanently delete data?%s"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:433
-msgid "Unknown"
+#: ../gui/wxpython/gmodeler/frame.py:305
+#: ../gui/wxpython/gui_modules/gmodeler.py:1011
+msgid "Delete intermediate data?"
msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:491 ../gui/wxpython/dbmgr/dialogs.py:609
-#: ../gui/wxpython/vdigit/dialogs.py:120 ../gui/wxpython/vdigit/dialogs.py:558
-msgid "Category"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:34
-#, fuzzy
-msgid "Query results"
-msgstr "Vaicājumu rīks"
-#: ../gui/wxpython/gui_core/query.py:46
-msgid "Right click to copy selected values to clipboard."
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:50
-msgid "Feature"
-msgstr ""
-msgid "Value"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:66
-msgid "Copy all to clipboard"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:69
-msgid "Redirect to console"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:117 ../gui/wxpython/gui_core/query.py:118
+#: ../gui/wxpython/gmodeler/frame.py:319
+#: ../gui/wxpython/gui_modules/gmodeler.py:1025
#, python-format
-msgid "Copy from '%s' column"
+msgid "%d maps deleted from current mapset"
msgstr ""
-#: ../gui/wxpython/gui_core/query.py:119
-msgid "Copy selected lines"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:122 ../gui/wxpython/gui_core/query.py:125
-#, python-format
-msgid "Copy '%s'"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:126
-#, fuzzy
-msgid "Copy line"
-msgstr "Rindas:"
-#: ../gui/wxpython/gui_core/query.py:148
-#, fuzzy
-msgid "Query results:"
-#: ../gui/wxpython/gui_core/query.py:151
-msgid " "
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:228
-msgid "east, north"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:239
-msgid "Nothing found"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:57
-msgid "User settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:80
-msgid "Set to default"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:88
-msgid "Revert settings to default and apply changes"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:95
-#: ../gui/wxpython/psmap/dialogs.py:355 ../gui/wxpython/wxplot/dialogs.py:693
-#: ../gui/wxpython/wxplot/dialogs.py:1138
-#: ../gui/wxpython/vdigit/preferences.py:62
-#: ../gui/wxpython/gmodeler/preferences.py:453
-msgid "Close dialog and ignore changes"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:153
-msgid "Settings applied to current session but not saved"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:215
-msgid "Key column cannot be empty string."
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:253
-msgid "GUI Settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:274
-#: ../gui/wxpython/vdigit/preferences.py:122
-#: ../gui/wxpython/gmodeler/preferences.py:46
-msgid "General"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:280
-msgid "Layer Manager settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:290
-msgid "Ask when removing map layer from layer tree"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:300
-msgid "Ask when quiting wxGUI or closing display"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:310
-#: ../gui/wxpython/gui_core/preferences.py:320
-#, python-format
-msgid "Hide '%s' tab (requires GUI restart)"
-msgstr ""
-msgid "Search module"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:333
-msgid "Automatically copy selected text to clipboard (in Command console)"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:348
-msgid "Workspace settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:355
-msgid "Suppress positioning Map Display Window(s)"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:367
-msgid "Suppress positioning Layer Manager window"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:378
-msgid "Save current window layout as default"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:381
+#: ../gui/wxpython/gmodeler/frame.py:334 ../gui/wxpython/gmodeler/frame.py:449
+#: ../gui/wxpython/gui_modules/gmodeler.py:1040
+#: ../gui/wxpython/gui_modules/gmodeler.py:1155
msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
+"Current model is not empty. Do you want to store current settings to model "
+"file?"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:404
-#: ../gui/wxpython/gui_core/preferences.py:600
-#: ../gui/wxpython/gui_core/preferences.py:1528
-#: ../gui/wxpython/psmap/dialogs.py:2788 ../gui/wxpython/psmap/dialogs.py:3265
-#: ../gui/wxpython/psmap/dialogs.py:3721 ../gui/wxpython/wxplot/dialogs.py:620
-msgid "Font settings"
+#: ../gui/wxpython/gmodeler/frame.py:337 ../gui/wxpython/gmodeler/frame.py:452
+#: ../gui/wxpython/gui_modules/gmodeler.py:1043
+#: ../gui/wxpython/gui_modules/gmodeler.py:1158
+msgid "Create new model?"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:417
-msgid "Font for command output:"
+#: ../gui/wxpython/gmodeler/frame.py:364
+#: ../gui/wxpython/gui_modules/gmodeler.py:1070
+msgid "Choose model file"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:431
-msgid "Language settings"
+#: ../gui/wxpython/gmodeler/frame.py:366 ../gui/wxpython/gmodeler/frame.py:410
+#: ../gui/wxpython/lmgr/frame.py:392
+#: ../gui/wxpython/gui_modules/gmodeler.py:1072
+#: ../gui/wxpython/gui_modules/gmodeler.py:1116
+msgid "GRASS Model File (*.gxm)|*.gxm"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:440
-msgid "Choose language (requires to save and GRASS restart):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:463
-msgid "Appearance settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:473
-msgid "Element list:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:495
-msgid "Menu style (requires to save and GUI restart):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:519
-msgid "Height of map selection popup window (in pixels):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:543
-msgid "Icon theme (requires GUI restart):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:563
-msgid "Module dialog style:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:596
-msgid "Map Display"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:610
-msgid "Default font for GRASS displays:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:628
-msgid "Default display settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:638
-msgid "Display driver:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:658
-msgid "Statusbar mode:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:697
-#: ../gui/wxpython/mapdisp/statusbar.py:488
-msgid "Align region extent based on display size"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:710
-#: ../gui/wxpython/mapdisp/statusbar.py:527
-msgid "Constrain display resolution to computational settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:723
-msgid "Enable auto-rendering"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:736
-msgid "Enable auto-zooming to selected map layer"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:749
-msgid "Mouse wheel action:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:764
-msgid "Mouse scrolling direction:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:790
-#, fuzzy
-msgid "Advanced display settings"
-msgstr "Mainīt iestatījumus"
-#: ../gui/wxpython/gui_core/preferences.py:796
-msgid "3D view depth buffer (possible values are 16, 24, 32):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:828
-msgid "Modules"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:831
-#, fuzzy
-msgid "Module dialog settings"
-#: ../gui/wxpython/gui_core/preferences.py:842
-#: ../gui/wxpython/gui_core/dialogs.py:1547
-#: ../gui/wxpython/modules/mcalc_builder.py:235
-#: ../gui/wxpython/modules/vclean.py:143 ../gui/wxpython/scripts/vkrige.py:141
-#: ../gui/wxpython/gmodeler/preferences.py:443
-msgid "Allow output files to overwrite existing files"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:852
-msgid "Close dialog when module is successfully finished"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:862
-#: ../gui/wxpython/gui_core/dialogs.py:227
-msgid "Add created map into layer tree"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:873
-msgid "Allow interactive input"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:883
-msgid "Verbosity level:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:908
-msgid "Layers"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:914
-msgid "Default raster settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:924
-msgid "Make null cells opaque"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:935
-msgid "Default color table"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:962
-msgid "Default vector settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:968
-msgid "Display:"
-msgstr "Attēlot:"
-#: ../gui/wxpython/gui_core/preferences.py:987
-msgid "Feature color:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:999
-#: ../gui/wxpython/gui_core/preferences.py:1021
-#: ../gui/wxpython/gui_core/forms.py:1444
-msgid "Transparent"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1009
-msgid "Area fill color:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1042
-#: ../gui/wxpython/gcp/manager.py:2548
-msgid "Symbol size:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1052
-msgid "Symbol:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1079
-#: ../gui/wxpython/vdigit/preferences.py:361
-msgid "Attributes"
-msgstr "Atribūti"
-#: ../gui/wxpython/gui_core/preferences.py:1087
-msgid "Highlighting"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1103
-msgid "Line width (in pixels):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1126
-msgid "Data browser"
-msgstr "Datu pārlūks"
-#: ../gui/wxpython/gui_core/preferences.py:1131
-msgid "Left mouse double click:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1143
-msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1154
-msgid "Ask when deleting data record(s) from table"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1175
-msgid "Create table"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1182
-#: ../gui/wxpython/gui_core/dialogs.py:261
-msgid "Key column:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1209
-#: ../gui/wxpython/mapdisp/statusbar.py:765
-msgid "Projection"
-msgstr "Projekcija"
-#: ../gui/wxpython/gui_core/preferences.py:1216
-msgid "Projection statusbar settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1224
-msgid ""
-"\n"
-"Note: This only controls the coordinates displayed in the lower-left of the "
-"Map Display\n"
-"window's status bar. It is purely cosmetic and does not affect the working "
-"location's\n"
-"projection in any way. You will need to enable the Projection check box in "
-"the drop-down\n"
-"menu located at the bottom of the Map Display window.\n"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1239
-#: ../gui/wxpython/location_wizard/wizard.py:1319
-msgid "EPSG code:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1256
-msgid "Proj.4 string (required):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1272
-msgid "EPSG file:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1287
-msgid ""
-"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
-"directly."
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1295
-msgid "&Load EPSG codes"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1307
-msgid "Coordinates format"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1315
-#, fuzzy
-msgid "Lat/long projections"
-#: ../gui/wxpython/gui_core/preferences.py:1334
-msgid "Precision:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1374
+#: ../gui/wxpython/gmodeler/frame.py:382
+#: ../gui/wxpython/gui_modules/gmodeler.py:1088
#, python-format
-msgid "Unable to read EPSG codes: %s"
+msgid "%(items)d items (%(actions)d actions) loaded into model"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1403
-#: ../gui/wxpython/gui_core/preferences.py:1412
-#: ../gui/wxpython/gui_core/preferences.py:1421
+#: ../gui/wxpython/gmodeler/frame.py:389 ../gui/wxpython/gmodeler/frame.py:426
+#: ../gui/wxpython/gui_modules/gmodeler.py:1095
+#: ../gui/wxpython/gui_modules/gmodeler.py:1132
#, python-format
-msgid "EPSG code %s not found"
+msgid "Model file <%s> already exists. Do you want to overwrite this file?"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1429
-msgid "Select default display font"
+#: ../gui/wxpython/gmodeler/frame.py:392 ../gui/wxpython/menustrings.py:923
+#: ../gui/wxpython/gui_modules/gmodeler.py:1098
+msgid "Save model"
msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1534
-msgid "Select font:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1558
-msgid "Character encoding:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1576
-#: ../gui/wxpython/psmap/dialogs.py:292 ../gui/wxpython/psmap/dialogs.py:3555
-msgid "Font size:"
-msgstr "Fonta izmērs:"
-#: ../gui/wxpython/gui_core/preferences.py:1664
-msgid "Manage access to mapsets"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1677
-msgid ""
-"Check a mapset to make it accessible, uncheck it to hide it.\n"
-" Notes:\n"
-" - The current mapset is always accessible.\n"
-" - You may only write to the current mapset.\n"
-" - You may only write to mapsets which you own."
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1750
-#: ../gui/wxpython/gui_core/gselect.py:465
-msgid "Mapset"
-msgstr "Karšu kopa"
-#: ../gui/wxpython/gui_core/preferences.py:1751
-msgid "Owner"
-msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:133
-msgid "Double-click or Ctrl-Enter to run selected module"
-msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:150 ../gui/wxpython/gui_core/forms.py:507
-#: ../gui/wxpython/modules/mcalc_builder.py:141
-#: ../gui/wxpython/modules/vclean.py:164 ../gui/wxpython/scripts/vkrige.py:155
-#: ../gui/wxpython/gmodeler/frame.py:1504
-#: ../gui/wxpython/gmodeler/model.py:2190
-msgid "&Run"
-msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:151
-msgid "Run selected module from the tree"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:81
-msgid " (...)"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:808
-msgid "Fulltext search"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:809
-msgid "Type to search in all modules. Press Enter for next match."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:866
-msgid "Searching, please type more characters."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:875
+#: ../gui/wxpython/gmodeler/frame.py:399 ../gui/wxpython/gmodeler/frame.py:439
+#: ../gui/wxpython/gui_modules/gmodeler.py:1105
+#: ../gui/wxpython/gui_modules/gmodeler.py:1145
#, python-format
-msgid "%d modules match"
+msgid "File <%s> saved"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:949
-msgid "Save current settings"
+#: ../gui/wxpython/gmodeler/frame.py:408
+#: ../gui/wxpython/gui_modules/gmodeler.py:1114
+msgid "Choose file to save current model"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:952
-msgid "Delete currently selected settings"
+#: ../gui/wxpython/gmodeler/frame.py:428
+#: ../gui/wxpython/gui_modules/gmodeler.py:1134
+#: ../gui/wxpython/iclass/frame.py:892
+msgid "File already exists"
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:970
-msgid "Load settings:"
+#: ../gui/wxpython/gmodeler/frame.py:497
+#: ../gui/wxpython/gui_modules/gmodeler.py:1203
+msgid "Model is empty. Nothing to validate."
msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:991
+#: ../gui/wxpython/gmodeler/frame.py:507
+#: ../gui/wxpython/gui_modules/gmodeler.py:1213
#, python-format
-msgid "Settings <%s> not found"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1001
-#: ../gui/wxpython/gui_core/widgets.py:1017
-msgid "Save settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1006
-msgid "Name not given, settings is not saved."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1015
-#, python-format
-msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1056
-msgid "No settings is defined. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1090
-msgid "Unable to save settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:431
-msgid "Not selectable element"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:476
-msgid "Type: "
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:487
-#, python-format
-msgid "GSelect: invalid item: %s"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1208
-msgid "Output settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1210
-msgid "Source settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1226
-msgid "Native"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1232
-msgid "File"
-msgstr "Fails"
-#: ../gui/wxpython/gui_core/gselect.py:1236
-#: ../gui/wxpython/gui_core/forms.py:1530
-msgid "Directory"
-msgstr "Mape"
-#: ../gui/wxpython/gui_core/gselect.py:1244
-msgid "Protocol"
-msgstr "Protokols"
-#: ../gui/wxpython/gui_core/gselect.py:1248
-msgid "PostGIS (PG)"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1258
-msgid "Output type"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1260
-msgid "Source type"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1280
-msgid "All files"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1285
-#, fuzzy
-msgid "ZIP files"
-msgstr "Teksta faili"
-#: ../gui/wxpython/gui_core/gselect.py:1286
-#, fuzzy
-msgid "GZIP files"
-#: ../gui/wxpython/gui_core/gselect.py:1287
-#, fuzzy
-msgid "TAR files"
-#: ../gui/wxpython/gui_core/gselect.py:1288
-#, fuzzy
-msgid "TARGZ files"
-#: ../gui/wxpython/gui_core/gselect.py:1294
-msgid "File:"
-msgstr "Fails:"
-#: ../gui/wxpython/gui_core/gselect.py:1295
-msgid "Choose file to import"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1308
-#: ../gui/wxpython/gui_core/gselect.py:1361
-msgid "Choose input directory"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1322
-msgid "Extension:"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1347
-msgid "Choose file"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1438
-#: ../gui/wxpython/gui_core/gselect.py:1468
-#: ../gui/wxpython/gui_core/gselect.py:1510
-#: ../gui/wxpython/gui_core/gselect.py:1542
-msgid "Creation options:"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1451
-#: ../gui/wxpython/gui_core/gselect.py:1484
-#: ../gui/wxpython/gui_core/gselect.py:1527
-msgid "Format:"
-msgstr "Formāts:"
-#: ../gui/wxpython/gui_core/gselect.py:1534
-msgid "Protocol:"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1557
-msgid "No settings available"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1793
-#: ../gui/wxpython/location_wizard/wizard.py:776
-msgid "No"
-msgstr "Nē"
-#: ../gui/wxpython/gui_core/gselect.py:1795
-msgid "Yes"
-msgstr "Jā"
-#: ../gui/wxpython/gui_core/gselect.py:1949
-#: ../gui/wxpython/psmap/toolbars.py:96 ../gui/wxpython/psmap/dialogs.py:4526
-#: ../gui/wxpython/vdigit/preferences.py:536
-msgid "Point"
-msgstr "Punkts"
-msgid "LineString"
-msgstr ""
-msgid "Polygon"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1957
-msgid "Feature type:"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:36
-msgid "Display map"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:37
-msgid "Re-render modified map layers only"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:39
-msgid "Render map"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:40
-msgid "Force re-rendering all map layers"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:42
-msgid "Erase display"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:43
-msgid "Erase display canvas with given background color"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:45
-msgid "Pointer"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:47
-msgid "Zoom in"
-msgstr "Tuvināt"
-#: ../gui/wxpython/gui_core/toolbars.py:48
-msgid "Drag or click mouse to zoom"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:50
-msgid "Zoom out"
-msgstr "Tālināt"
-#: ../gui/wxpython/gui_core/toolbars.py:51
-msgid "Drag or click mouse to unzoom"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:53
-msgid "Return to previous zoom"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:55
-msgid "Various zoom options"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:56
-msgid "Zoom to computational, default, saved region, ..."
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:58
-msgid "Zoom to selected map layer(s)"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:60
-msgid "Pan"
-msgstr "Pārcentrēt"
-#: ../gui/wxpython/gui_core/toolbars.py:61
-msgid "Drag with mouse to pan"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:63
-msgid "Save display to graphic file"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:65
-#: ../gui/wxpython/modules/histogram.py:456 ../gui/wxpython/wxplot/base.py:538
-#: ../gui/wxpython/gcp/mapdisplay.py:420 ../gui/wxpython/mapdisp/frame.py:612
-msgid "Print display"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:67
-msgid "Select font"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:73
-msgid "Add raster map layer"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:75
-msgid "Add vector map layer"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:77
-msgid "Add map elements"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:78
-msgid "Overlay elements like scale and legend onto map"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:80
-msgid "Create histogram with d.histogram"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:265
-msgid "Select graphics tool"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:46 ../gui/wxpython/menustrings.py:925
-#: ../gui/wxpython/menustrings.py:926
-msgid "About GRASS GIS"
-msgstr "Par GRASS GIS"
-#: ../gui/wxpython/gui_core/ghelp.py:57
-msgid "Info"
-msgstr "Informācija"
-#: ../gui/wxpython/gui_core/ghelp.py:58
-msgid "Copyright"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:59
-msgid "License"
-msgstr "Licence"
-#: ../gui/wxpython/gui_core/ghelp.py:60
-msgid "Authors"
-msgstr "Autori"
-#: ../gui/wxpython/gui_core/ghelp.py:61
-msgid "Contributors"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:62
-msgid "Extra contributors"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:63
-msgid "Translators"
-msgstr "Tulkotāji"
-#: ../gui/wxpython/gui_core/ghelp.py:64
-msgid "Translation status"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:124
-msgid "Official GRASS site:"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:135
-msgid "Code Revision"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:198 ../gui/wxpython/gui_core/ghelp.py:410
-msgid "Language"
-msgstr "Valoda"
-#: ../gui/wxpython/gui_core/ghelp.py:227 ../gui/wxpython/gui_core/ghelp.py:251
-#: ../gui/wxpython/gui_core/ghelp.py:275 ../gui/wxpython/gui_core/ghelp.py:332
-#: ../gui/wxpython/gui_core/ghelp.py:394 ../gui/wxpython/gui_core/ghelp.py:544
-#, python-format
-msgid "%s file missing"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:318 ../gui/wxpython/gui_core/ghelp.py:380
-#, python-format
-msgid "Error when reading file '%s'."
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:319 ../gui/wxpython/gui_core/ghelp.py:381
-msgid "Lines:"
-msgstr "Rindas:"
-#: ../gui/wxpython/gui_core/ghelp.py:337 ../gui/wxpython/gui_core/ghelp.py:339
-#: ../gui/wxpython/gui_core/ghelp.py:406
-msgid "E-mail"
-msgstr "E-pasts"
-msgid "Country"
-msgstr "Valsts"
-#: ../gui/wxpython/gui_core/ghelp.py:339
-msgid "OSGeo_ID"
-msgstr "OSGeo_ID"
-#: ../gui/wxpython/gui_core/ghelp.py:414
-msgid "Nation"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:449
-#, python-format
-msgid " %d translated"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:453 ../gui/wxpython/gui_core/ghelp.py:479
-#, python-format
-msgid " %d fuzzy"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:457 ../gui/wxpython/gui_core/ghelp.py:488
-#, python-format
-msgid " %d untranslated"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:470
-#, python-format
-msgid "%d translated"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:541
-#, python-format
-msgid "File <%s> not found"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:695
-msgid "&Next"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:698
-msgid "&Previous"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:471
-msgid "Enter parameters for '"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:482
-msgid "Close this window without executing the command (Ctrl+Q)"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:508
-msgid "Run the command (Ctrl+R)"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:514
-msgid "Copy the current command string to the clipboard"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:530
-msgid "Show manual page of the command (Ctrl+H)"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:561
-msgid "Add created map(s) into layer tree"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:576
-#: ../gui/wxpython/gui_core/dialogs.py:1552
-msgid "Close dialog on finish"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:578
msgid ""
-"Close dialog when command is successfully finished. Change this settings in "
-"Preferences dialog ('Command' tab)."
+"Model is not valid.\n"
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:745
-#, python-format
-msgid "'%s' copied to clipboard"
+#: ../gui/wxpython/gmodeler/frame.py:510
+#: ../gui/wxpython/gui_modules/gmodeler.py:1216
+msgid "Model is valid."
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:811 ../gui/wxpython/gui_core/forms.py:824
-msgid "Required"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:814 ../gui/wxpython/gui_core/forms.py:824
-msgid "Optional"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:890
-#: ../gui/wxpython/gui_core/forms.py:1596
-msgid "Parameterized in model"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:966
-msgid "[multiple]"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1015
-msgid "valid range"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1269
-msgid "Show graphical representation of temporal extent of dataset(s) ."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1411 ../gui/wxpython/core/utils.py:988
-msgid "Select Color"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1473
-#: ../gui/wxpython/gui_core/forms.py:1529
+#: ../gui/wxpython/gmodeler/frame.py:571 ../gui/wxpython/gmodeler/frame.py:578
+#: ../gui/wxpython/gui_modules/gmodeler.py:1277
+#: ../gui/wxpython/gui_modules/gmodeler.py:1320
#, python-format
-msgid "Choose %s"
+msgid "Model exported to <%s>"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1474
-#: ../gui/wxpython/gmodeler/frame.py:1337
-msgid "file"
+#: ../gui/wxpython/gmodeler/frame.py:703
+#: ../gui/wxpython/gui_modules/gmodeler.py:1445
+msgid "wxGUI Graphical Modeler"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1502
-#: ../gui/wxpython/modules/mcalc_builder.py:148
-msgid "&Load"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1504
-#, fuzzy
-msgid "&Save as"
-msgstr "Saglabāt kā"
-#: ../gui/wxpython/gui_core/forms.py:1508
-msgid "or enter values interactively"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1769
-#: ../gui/wxpython/scripts/vkrige.py:106 ../gui/wxpython/gmodeler/frame.py:129
-msgid "Command output"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1778
-msgid "Manual"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1819
-msgid "Nothing to load."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1827
+#: ../gui/wxpython/gmodeler/frame.py:706
+#: ../gui/wxpython/gui_modules/gmodeler.py:1448
#, python-format
msgid ""
-"Unable to load file.\n"
+"(C) 2010-%s by the GRASS Development Team\n"
"\n"
-"Reason: %s"
msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1853
-#: ../gui/wxpython/modules/colorrules.py:607
-msgid "Nothing to save."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1857
-msgid "Save input as..."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2164
-msgid "No dataset given."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2203 ../gui/wxpython/core/gcmd.py:702
+#: ../gui/wxpython/gmodeler/frame.py:804
+#: ../gui/wxpython/gui_modules/gmodeler.py:1546
#, python-format
-msgid "Error in %s"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2317
-#, python-format
-msgid "Unable to parse command '%s'"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2323
-#, python-format
-msgid "%(cmd)s: parameter '%(key)s' not available"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2413
-msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2426
-#, python-format
-msgid "usage: %s <grass command>"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:119
-msgid "Click here to show search module engine"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:120
-msgid "Click here to hide search module engine"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:135
-msgid "Command prompt"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:137
-msgid "Output window"
-msgstr "Izvades logs"
-#: ../gui/wxpython/gui_core/goutput.py:144
-msgid "Clear output window content"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:146
-msgid "Clear command prompt content"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:148
-msgid "Save output window content to the file"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:150
-msgid "Abort running command"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:152
-#, fuzzy
-msgid "&Log file"
-msgstr "Attēls"
-#: ../gui/wxpython/gui_core/goutput.py:154
msgid ""
-"Toggle to save list of executed commands into a file; content saved when "
-"switching off."
+"Reading model file <%s> failed.\n"
+"Invalid file, unable to parse XML document."
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:377
-#: ../gui/wxpython/gui_core/goutput.py:467
-msgid "Save file as..."
-msgstr "Saglabāt failu kā..."
-#: ../gui/wxpython/gui_core/goutput.py:379
-#: ../gui/wxpython/gui_core/goutput.py:469
-#, python-format
-msgid "%(txt)s (*.txt)|*.txt|%(files)s (*)|*"
+#: ../gui/wxpython/gmodeler/frame.py:810
+#: ../gui/wxpython/gui_modules/gmodeler.py:1552
+msgid "Please wait, loading model..."
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:380
-#: ../gui/wxpython/gui_core/goutput.py:470
-msgid "Text files"
-msgid "Files"
-msgstr "Faili"
-#: ../gui/wxpython/gui_core/goutput.py:392
-#, python-format
-msgid ""
-"Unable to write file '%(path)s'.\n"
-"\n"
-"Details: %(error)s"
+#: ../gui/wxpython/gmodeler/frame.py:870
+#: ../gui/wxpython/gui_modules/gmodeler.py:1612
+msgid "Writing current settings to model file failed."
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:395
+#: ../gui/wxpython/gmodeler/frame.py:880 ../gui/wxpython/lmgr/frame.py:1078
+#: ../gui/wxpython/gui_modules/gmodeler.py:1622
+#: ../gui/wxpython/gui_modules/wxplot.py:1041
+#: ../gui/wxpython/wxplot/profile.py:345
#, python-format
-msgid "Command output saved into '%s'"
+msgid "Unable to open file <%s> for writing."
msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:448
-#: ../gui/wxpython/core/gconsole.py:458
-#, python-format
-msgid ""
-"Unable to write file '%(filePath)s'.\n"
-"\n"
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1176
+#: ../gui/wxpython/lmgr/layertree.py:310
+#: ../gui/wxpython/gui_modules/gmodeler.py:2481
+#: ../gui/wxpython/gui_modules/layertree.py:277
+msgid "Remove"
+msgstr "Noņemt"
-#: ../gui/wxpython/gui_core/goutput.py:453
-#, python-format
-msgid "Command log saved to '%s'"
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1180
+#: ../gui/wxpython/gui_modules/gmodeler.py:2485
+msgid "Disable"
+msgstr "Atslēgt"
-#: ../gui/wxpython/gui_core/mapdisp.py:107
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:94
-#: ../gui/wxpython/core/render.py:463
-#, python-format
-msgid "GRASS module '%s' not found. Unable to start map display window."
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1183
+#: ../gui/wxpython/gui_modules/gmodeler.py:2488
+msgid "Enable"
+msgstr "Ieslēgt"
-#: ../gui/wxpython/gui_core/dialogs.py:74
-msgid "Required item is not set."
+#: ../gui/wxpython/gmodeler/frame.py:1188
+#: ../gui/wxpython/gui_modules/gmodeler.py:2493
+msgid "Add control point"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:104
-msgid "Select GRASS location and mapset"
+#: ../gui/wxpython/gmodeler/frame.py:1190
+#: ../gui/wxpython/gui_modules/gmodeler.py:2495
+msgid "Remove control point"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:116
-msgid "Location or mapset is missing."
+#: ../gui/wxpython/gmodeler/frame.py:1197
+#: ../gui/wxpython/gui_modules/gmodeler.py:2502
+msgid "Intermediate"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:123
-msgid "Name of GRASS location:"
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1208
+#: ../gui/wxpython/lmgr/layertree.py:324
+#: ../gui/wxpython/gui_modules/gmodeler.py:2513
+#: ../gui/wxpython/gui_modules/layertree.py:291
+msgid "Properties"
+msgstr "Īpašības"
-#: ../gui/wxpython/gui_core/dialogs.py:129
-#: ../gui/wxpython/gui_core/dialogs.py:176
-msgid "Name of mapset:"
+#: ../gui/wxpython/gmodeler/frame.py:1269
+#: ../gui/wxpython/gui_modules/gmodeler.py:4037
+msgid "List of variables - right-click to delete"
msgstr ""
-msgid "Select mapset in GRASS location"
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1322
+#: ../gui/wxpython/gui_modules/gmodeler.py:4090
+#: ../gui/wxpython/gui_modules/dbm.py:881
+#: ../gui/wxpython/gui_modules/dbm.py:2235
+#: ../gui/wxpython/dbmgr/manager.py:2260
+msgid "Data type"
+msgstr "Datu tips"
-#: ../gui/wxpython/gui_core/dialogs.py:168
-msgid "Name of mapset is missing."
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1273
+#: ../gui/wxpython/gmodeler/frame.py:1328
+#: ../gui/wxpython/gui_modules/gmodeler.py:4041
+#: ../gui/wxpython/gui_modules/gmodeler.py:4096
+msgid "Default value"
+msgstr "Noklusējuma vērtība"
-#: ../gui/wxpython/gui_core/dialogs.py:187
-#: ../gui/wxpython/gui_core/dialogs.py:324 ../gui/wxpython/menustrings.py:544
-#: ../gui/wxpython/menustrings.py:1209
-msgid "Create new vector map"
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1335
+#: ../gui/wxpython/gui_modules/gmodeler.py:4103
+#: ../gui/wxpython/gui_modules/location_wizard.py:373
+#: ../gui/wxpython/gui_modules/location_wizard.py:874
+#: ../gui/wxpython/gui_modules/location_wizard.py:1037
+#: ../gui/wxpython/gui_modules/location_wizard.py:1302
+#: ../gui/wxpython/location_wizard/wizard.py:337
+#: ../gui/wxpython/location_wizard/wizard.py:838
+#: ../gui/wxpython/location_wizard/wizard.py:1007
+#: ../gui/wxpython/location_wizard/wizard.py:1312
+msgid "Description"
+msgstr "Apraksts"
-#: ../gui/wxpython/gui_core/dialogs.py:212
-msgid "Create attribute table"
+#: ../gui/wxpython/gmodeler/frame.py:1277
+#: ../gui/wxpython/gui_modules/gmodeler.py:4045
+msgid "Add new variable"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:236
-msgid "Name of new vector map is missing."
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1281
+#: ../gui/wxpython/gui_modules/gmodeler.py:4049
+msgid "integer"
+msgstr "vesels skaitlis"
-#: ../gui/wxpython/gui_core/dialogs.py:247
-msgid "Name for new vector map:"
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1282
+#: ../gui/wxpython/gui_modules/gmodeler.py:4050
+msgid "float"
+msgstr "daļskaitlis"
-#: ../gui/wxpython/gui_core/dialogs.py:357
-#, python-format
-msgid "Unable to create vector map <%s>."
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1283
+#: ../gui/wxpython/gui_modules/gmodeler.py:4051
+msgid "string"
+msgstr "teksts"
-#: ../gui/wxpython/gui_core/dialogs.py:362
-#, python-format
-msgid ""
-"Invalid or empty key column.\n"
-"Unable to create vector map <%s>."
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1286
+#: ../gui/wxpython/gui_modules/gmodeler.py:4054
+msgid "mapset"
+msgstr "karšu kopa"
-#: ../gui/wxpython/gui_core/dialogs.py:389
-#, python-format
-msgid ""
-"Vector map <%s> already exists in the current mapset. Do you want to "
-"overwrite it?"
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1287
+#: ../gui/wxpython/gui_modules/gmodeler.py:4055
+msgid "file"
+msgstr "fails"
-#: ../gui/wxpython/gui_core/dialogs.py:449
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:103
-#, python-format
-msgid "New vector map <%s> created"
+#: ../gui/wxpython/gmodeler/frame.py:1294
+#: ../gui/wxpython/gui_modules/gmodeler.py:4062
+msgid "Add new variable to the model"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:471
-msgid "Load region:"
+#: ../gui/wxpython/gmodeler/frame.py:1414
+#: ../gui/wxpython/gui_modules/gmodeler.py:4511
+msgid "List of items - right-click to delete"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:475
-msgid "Save region:"
+msgid "In block"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:517
-msgid "Create or edit imagery groups"
+#: ../gui/wxpython/gmodeler/frame.py:1418
+#: ../gui/wxpython/gui_modules/gmodeler.py:4515
+msgid "Command / Condition"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:550
-msgid "Apply changes to selected group and close dialog"
+#: ../gui/wxpython/gmodeler/frame.py:1451
+msgid "Python script"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:551
-msgid "Apply changes to selected group"
+#: ../gui/wxpython/gmodeler/frame.py:1455
+msgid "Run python script"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:552
-msgid "Close dialog, changes are not applied"
+#: ../gui/wxpython/gmodeler/frame.py:1458
+msgid "Save python script to file"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:593
-#: ../gui/wxpython/gui_core/dialogs.py:1265
+#: ../gui/wxpython/gmodeler/frame.py:1461
msgid ""
-"Put here a regular expression. Characters '.*' stand for anything, character "
-"'^' stands for the beginning and '$' for the end."
+"Refresh python script based on the model.\n"
+"It will discards all local changes."
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:600
-msgid "Select existing group or enter name of new group:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:611
-msgid "Edit/create subgroup"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:620
-msgid "Select exising subgroup or enter name of new subgroup:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:641
-#: ../gui/wxpython/gui_core/dialogs.py:686
-#: ../gui/wxpython/gui_core/dialogs.py:1252
-msgid "Pattern:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:656
-#: ../gui/wxpython/gui_core/dialogs.py:700
-#: ../gui/wxpython/gui_core/dialogs.py:1271
-msgid "List of maps:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:666
-msgid "Select map layers and add them to the list."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:670
-msgid "Remove selected layer(s) from list."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:705
-msgid "Check maps from group to be included into subgroup."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:811
-msgid "Add selected map layers into group"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:940
+#: ../gui/wxpython/gmodeler/frame.py:1499
#, python-format
-msgid "Group <%s> was changed, do you want to apply changes?"
+msgid "Unable to launch Python script. %s"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:942
-#: ../gui/wxpython/gui_core/dialogs.py:954
-msgid "Unapplied changes"
+#: ../gui/wxpython/gmodeler/frame.py:1524
+#: ../gui/wxpython/gui_modules/gmodeler.py:1285
+msgid "Choose file to save"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:952
-#, python-format
-msgid "Subgroup <%s> was changed, do you want to apply changes?"
+#: ../gui/wxpython/gmodeler/frame.py:1526
+#: ../gui/wxpython/gui_modules/gmodeler.py:1287
+msgid "Python script (*.py)|*.py"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1008
-msgid "No raster maps selected."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1037
+#: ../gui/wxpython/gmodeler/frame.py:1540
+#: ../gui/wxpython/gui_modules/gmodeler.py:1301
#, python-format
-msgid "No changes to apply in group <%s>."
+msgid "File <%s> already exists. Do you want to overwrite this file?"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1040
-#, python-format
-msgid "Group <%s> was successfully created."
+#: ../gui/wxpython/gmodeler/frame.py:1542
+#: ../gui/wxpython/gui_modules/gmodeler.py:1303
+msgid "Save file"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1042
-#, python-format
-msgid "Group <%s> was successfully changed."
+#: ../gui/wxpython/gmodeler/frame.py:1577
+msgid ""
+"Python script is locally modificated. Refresh will discard all changes. Do "
+"you really want to continue?"
msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1045
-#, python-format
-msgid "Creating of new group <%s> failed."
-msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1580
+msgid "Update"
+msgstr "Atjaunināt"
-#: ../gui/wxpython/gui_core/dialogs.py:1047
-#, python-format
-msgid "Changing of group <%s> failed."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1085
-msgid "No group selected."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1091
-msgid "No subgroup selected."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1194
-msgid "Use fully-qualified map names"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1220
-msgid "Map type:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1235
-msgid "Select toggle"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1242
-msgid "Mapset:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1327
-msgid "Invert selection"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1461
-#, python-format
-msgid "Dynamic series (%s)"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1486
-msgid "Multiple import"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1502
-msgid "List of raster layers"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1504
-msgid "List of vector layers"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1506
-#, python-format
-msgid "List of %s layers"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1507
-msgid "right click to (un)select all"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1510
-msgid "Layer id"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1512
-msgid "Name for output GRASS map (editable)"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1514
-#: ../gui/wxpython/psmap/dialogs.py:1648
-msgid "Feature type"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1515
-#, fuzzy
-msgid "Projection match"
-#: ../gui/wxpython/gui_core/dialogs.py:1521
-#: ../gui/wxpython/modules/extensions.py:68
-msgid "Options"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1563
-#: ../gui/wxpython/gui_core/dialogs.py:1737
-msgid "&Import"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1564
-#: ../gui/wxpython/gui_core/dialogs.py:1738
-msgid "Import selected layers"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1723
-msgid "this might not work for multiple bands"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1725
-msgid "Add linked layers into layer tree ({mightNotWork})"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1728
-msgid "Add imported layers into layer tree ({mightNotWork})"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1734
-msgid "&Link"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1735
-msgid "Link selected layers"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1747
-msgid "No layers selected. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1844
-msgid "Define output format for vector data"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1846
-msgid "Define output format for raster data"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1854
-msgid "Set external format and close dialog"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1906
-msgid "No data source selected."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1919
-msgid "Import DXF layers"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1923
-msgid "Choose DXF file to import"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1929
-msgid "Add imported layers into layer tree"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1943
-msgid "No layers selected."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2070
-msgid "Set Map Layer Opacity"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2095
-#: ../gui/wxpython/psmap/dialogs.py:4604 ../gui/wxpython/psmap/dialogs.py:4619
-#: ../gui/wxpython/psmap/dialogs.py:4858 ../gui/wxpython/psmap/dialogs.py:4879
-msgid "transparent"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2098
-msgid "opaque"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2194
-msgid "Set image size"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2203
-msgid "Image size"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2250
-msgid "Template:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2288
-msgid "GRASS GIS SQL Query Utility"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2299
-msgid " SQL statement "
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2344
-msgid "Symbols"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2371
-msgid "Symbol directory:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2379
-msgid "Symbol name:"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:3 ../gui/wxpython/menustrings.py:1672
-#: ../gui/wxpython/menustrings.py:1720
+#: ../gui/wxpython/menustrings.py:2 ../gui/wxpython/menustrings.py:917
msgid "&File"
msgstr "&Fails"
-#: ../gui/wxpython/menustrings.py:4
+#: ../gui/wxpython/menustrings.py:3
msgid "Workspace"
msgstr "Darbtelpa"
-#: ../gui/wxpython/menustrings.py:6
+#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:918
+#: ../gui/wxpython/nviz/tools.py:1074
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1244
+msgid "New"
+msgstr "Jauns"
+#: ../gui/wxpython/menustrings.py:5
msgid "Create new workspace"
-msgstr ""
+msgstr "Izveidot jaunu darbtelpu"
-#: ../gui/wxpython/menustrings.py:7 ../gui/wxpython/menustrings.py:1675
+#: ../gui/wxpython/menustrings.py:6 ../gui/wxpython/menustrings.py:920
msgid "Open"
msgstr "Atvērt"
-#: ../gui/wxpython/menustrings.py:8
+#: ../gui/wxpython/menustrings.py:7
msgid "Load workspace from file"
-msgstr ""
+msgstr "Ielādēt darbtelpu no faila"
-#: ../gui/wxpython/menustrings.py:9 ../gui/wxpython/menustrings.py:1677
-#: ../gui/wxpython/modules/colorrules.py:416
+#: ../gui/wxpython/menustrings.py:8 ../gui/wxpython/menustrings.py:922
+#: ../gui/wxpython/gui_modules/colorrules.py:407
+#: ../gui/wxpython/modules/colorrules.py:410
msgid "Save"
msgstr "Saglabāt"
-#: ../gui/wxpython/menustrings.py:11 ../gui/wxpython/menustrings.py:1679
+#: ../gui/wxpython/menustrings.py:9 ../gui/wxpython/lmgr/frame.py:1029
+#: ../gui/wxpython/lmgr/frame.py:1046
+msgid "Save workspace"
+msgstr "Saglabāt darbtelpu"
+#: ../gui/wxpython/menustrings.py:10 ../gui/wxpython/menustrings.py:924
msgid "Save as"
+#: ../gui/wxpython/menustrings.py:11
msgid "Save workspace to file"
-msgstr ""
+msgstr "Saglabāt darbtelpu failā"
-#: ../gui/wxpython/menustrings.py:13 ../gui/wxpython/menustrings.py:1681
+#: ../gui/wxpython/menustrings.py:12 ../gui/wxpython/menustrings.py:926
msgid "Close"
msgstr "Aizvērt"
-#: ../gui/wxpython/menustrings.py:14
+#: ../gui/wxpython/menustrings.py:13
msgid "Close workspace file"
-msgstr ""
+msgstr "Aizvērt darbtelpas failu"
+#: ../gui/wxpython/menustrings.py:14
msgid "Load GRC file (Tcl/Tk GUI)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:16
+#: ../gui/wxpython/menustrings.py:15
msgid "Load map layers from GRC file to layer tree"
msgstr ""
+#: ../gui/wxpython/menustrings.py:16
msgid "Map display"
msgstr "Kartes skats"
-#: ../gui/wxpython/menustrings.py:18
+#: ../gui/wxpython/menustrings.py:17
msgid "Add raster"
msgstr "Pievienot rastru"
-#: ../gui/wxpython/menustrings.py:19
+#: ../gui/wxpython/menustrings.py:18
msgid "Add raster map layer to current display"
msgstr ""
-#: ../gui/wxpython/menustrings.py:20
+#: ../gui/wxpython/menustrings.py:19
msgid "Add vector"
msgstr "Pievienot vektorus"
-#: ../gui/wxpython/menustrings.py:21
+#: ../gui/wxpython/menustrings.py:20
msgid "Add vector map layer to current display"
msgstr ""
-#: ../gui/wxpython/menustrings.py:22
+#: ../gui/wxpython/menustrings.py:21
msgid "Add multiple rasters or vectors"
msgstr "Pievienot vairākas rastra vai vektoru kartes"
-#: ../gui/wxpython/menustrings.py:23
+#: ../gui/wxpython/menustrings.py:22
msgid "Add multiple raster or vector map layers to current display"
msgstr ""
-#: ../gui/wxpython/menustrings.py:24
+#: ../gui/wxpython/menustrings.py:23
msgid "New map display window"
-msgstr ""
+msgstr "Jauns kartes skata logs"
-#: ../gui/wxpython/menustrings.py:25
+#: ../gui/wxpython/menustrings.py:24
msgid "Open new map display window"
-msgstr ""
+msgstr "Atver jaunu kartes skata logu"
-#: ../gui/wxpython/menustrings.py:26 ../gui/wxpython/menustrings.py:27
+#: ../gui/wxpython/menustrings.py:25 ../gui/wxpython/menustrings.py:26
msgid "Close current map display window"
-msgstr ""
+msgstr "Aizvērt pašreizējo kartes skata logu"
-#: ../gui/wxpython/menustrings.py:28 ../gui/wxpython/menustrings.py:29
+#: ../gui/wxpython/menustrings.py:27 ../gui/wxpython/menustrings.py:28
msgid "Close all open map display windows"
-msgstr ""
+msgstr "Aizvērt visus šobrīd atvērtos kartes skata logus"
-#: ../gui/wxpython/menustrings.py:31
+#: ../gui/wxpython/menustrings.py:29 ../gui/wxpython/lmgr/layertree.py:51
+#: ../gui/wxpython/gui_modules/gdialogs.py:1705
+#: ../gui/wxpython/gui_core/dialogs.py:1795
+msgid "Import raster data"
+msgstr "Rastra datu importēšana"
+#: ../gui/wxpython/menustrings.py:30
msgid "Common formats import"
msgstr "Biežāk sastopamie formāti"
-#: ../gui/wxpython/menustrings.py:32
+#: ../gui/wxpython/menustrings.py:31
msgid "Import raster data into a GRASS map layer using GDAL."
msgstr ""
-#: ../gui/wxpython/menustrings.py:33
+#: ../gui/wxpython/menustrings.py:32
msgid "ASCII x,y,z point import and gridding"
msgstr ""
-#: ../gui/wxpython/menustrings.py:34
+#: ../gui/wxpython/menustrings.py:33
msgid ""
"Create a raster map from an assemblage of many coordinates using univariate "
"statistics."
msgstr ""
-#: ../gui/wxpython/menustrings.py:35
+#: ../gui/wxpython/menustrings.py:34
msgid "ASCII grid import"
-msgstr ""
+msgstr "ASCII tīkla imports"
-#: ../gui/wxpython/menustrings.py:36
+#: ../gui/wxpython/menustrings.py:35
msgid "Converts a GRASS ASCII raster file to binary raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:37
+#: ../gui/wxpython/menustrings.py:36
msgid "ASCII polygons, lines, and point import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:38
+#: ../gui/wxpython/menustrings.py:37
msgid "Creates raster maps from ASCII polygon/line/point data files."
msgstr ""
-#: ../gui/wxpython/menustrings.py:39
+#: ../gui/wxpython/menustrings.py:38
msgid "Raw binary array import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:40
+#: ../gui/wxpython/menustrings.py:39
msgid "Import a binary raster file into a GRASS raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:41
+#: ../gui/wxpython/menustrings.py:40
msgid "ESRI ASCII grid import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:42
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
+#: ../gui/wxpython/menustrings.py:41
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:43
+#: ../gui/wxpython/menustrings.py:42
msgid "GRIDATB.FOR import"
msgstr "GRIDATB.FOR importēšana"
-#: ../gui/wxpython/menustrings.py:44
-msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
+#: ../gui/wxpython/menustrings.py:43
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:45
+#: ../gui/wxpython/menustrings.py:44
msgid "Matlab 2D array import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:46
+#: ../gui/wxpython/menustrings.py:45
msgid "Imports a binary MAT-File(v4) to a GRASS raster."
msgstr ""
-#: ../gui/wxpython/menustrings.py:47
+#: ../gui/wxpython/menustrings.py:46
msgid "PNG import"
msgstr "PNG importēšana"
-#: ../gui/wxpython/menustrings.py:48
+#: ../gui/wxpython/menustrings.py:47
msgid "Imports non-georeferenced PNG format image."
msgstr ""
-#: ../gui/wxpython/menustrings.py:49
+#: ../gui/wxpython/menustrings.py:48
msgid "SPOT NDVI import"
msgstr "SPOT NDVI importēšana"
-#: ../gui/wxpython/menustrings.py:50
+#: ../gui/wxpython/menustrings.py:49
msgid "Imports SPOT VGT NDVI data into a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:51
+#: ../gui/wxpython/menustrings.py:50
msgid "SRTM HGT import"
msgstr "SRTM HGT importēšana"
-#: ../gui/wxpython/menustrings.py:52
+#: ../gui/wxpython/menustrings.py:51
msgid "Imports SRTM HGT files into raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:53
+#: ../gui/wxpython/menustrings.py:52
msgid "Terra ASTER HDF import"
msgstr "Terra ASTER HDF importēšana"
-#: ../gui/wxpython/menustrings.py:54
+#: ../gui/wxpython/menustrings.py:53
msgid ""
"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
"using gdalwarp."
msgstr ""
-#: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:83
+#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:85
msgid "LAS LiDAR points import"
msgstr "LAS LiDAR punktu importēšana"
-#: ../gui/wxpython/menustrings.py:56
-msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
+#: ../gui/wxpython/menustrings.py:55
+msgid "Create a raster map from LAS LiDAR points using univariate statistics."
msgstr ""
+#: ../gui/wxpython/menustrings.py:56
+msgid "WMS import"
+msgstr "WMS importēšana"
#: ../gui/wxpython/menustrings.py:57
-msgid "Unpack raster map"
+msgid "Download and import data from WMS servers."
msgstr ""
#: ../gui/wxpython/menustrings.py:58
+msgid "Unpack raster map"
+msgstr "Atpakot rastra karti"
+#: ../gui/wxpython/menustrings.py:59
msgid "Unpacks a raster map packed with r.pack."
msgstr ""
-#: ../gui/wxpython/menustrings.py:60
+#: ../gui/wxpython/menustrings.py:60 ../gui/wxpython/lmgr/layertree.py:57
+#: ../gui/wxpython/gui_modules/gdialogs.py:1699
+#: ../gui/wxpython/gui_core/dialogs.py:1789
+msgid "Import vector data"
+msgstr "Vektordatu importēšana"
+#: ../gui/wxpython/menustrings.py:61
msgid "Common import formats"
-#: ../gui/wxpython/menustrings.py:61
+#: ../gui/wxpython/menustrings.py:62
msgid "Converts vector layers into a GRASS vector map using OGR."
msgstr ""
-#: ../gui/wxpython/menustrings.py:62
+#: ../gui/wxpython/menustrings.py:63
msgid "ASCII points or GRASS ASCII format"
msgstr ""
-#: ../gui/wxpython/menustrings.py:63
+#: ../gui/wxpython/menustrings.py:64
msgid "Creates a vector map from an ASCII points file or ASCII vector file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:64
+#: ../gui/wxpython/menustrings.py:65
msgid "ASCII points as a vector lines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:65
+#: ../gui/wxpython/menustrings.py:66
msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
msgstr ""
-#: ../gui/wxpython/menustrings.py:66
+#: ../gui/wxpython/menustrings.py:67
msgid "Historical GRASS vector import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:67
+#: ../gui/wxpython/menustrings.py:68
msgid "Imports older versions of GRASS vector maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:68
+#: ../gui/wxpython/menustrings.py:69
msgid "Historical GRASS vector import (all maps)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:69
+#: ../gui/wxpython/menustrings.py:70
msgid ""
"Converts all older versions of GRASS vector maps in current mapset to "
"current format."
msgstr ""
-#: ../gui/wxpython/menustrings.py:70
+#: ../gui/wxpython/menustrings.py:71
msgid "DXF import"
-msgstr ""
+msgstr "DXF imports"
-#: ../gui/wxpython/menustrings.py:71
+#: ../gui/wxpython/menustrings.py:72
msgid "Converts files in DXF format to GRASS vector map format."
msgstr ""
-#: ../gui/wxpython/menustrings.py:72
+#: ../gui/wxpython/menustrings.py:73
msgid "WFS"
msgstr "WFS"
-#: ../gui/wxpython/menustrings.py:73
-msgid "Imports GetFeature from a WFS server."
-msgstr ""
#: ../gui/wxpython/menustrings.py:74
-msgid "ESRI e00 import"
+msgid "Imports GetFeature from WFS."
msgstr ""
#: ../gui/wxpython/menustrings.py:75
+msgid "ESRI e00 import"
+msgstr "ESRI e00 imports"
+#: ../gui/wxpython/menustrings.py:76
msgid "Imports E00 file into a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:76
+#: ../gui/wxpython/menustrings.py:77
msgid "GPS data import"
+msgstr "GPS datu imports"
+#: ../gui/wxpython/menustrings.py:78
+msgid ""
+"Import waypoints, routes, and tracks from a GPS receiver or many common GPS "
+"file formats."
msgstr ""
-#: ../gui/wxpython/menustrings.py:77
+#: ../gui/wxpython/menustrings.py:79
msgid "Geonames import"
-msgstr ""
+msgstr "Geonames imports"
-#: ../gui/wxpython/menustrings.py:78
+#: ../gui/wxpython/menustrings.py:80
msgid "Imports geonames.org country files into a vector points map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:79
+#: ../gui/wxpython/menustrings.py:81
msgid "GEOnet import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:80
+#: ../gui/wxpython/menustrings.py:82
msgid ""
"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
"points map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:81
+#: ../gui/wxpython/menustrings.py:83
msgid "Matlab array or Mapgen format import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:82
+#: ../gui/wxpython/menustrings.py:84
msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
msgstr ""
-#: ../gui/wxpython/menustrings.py:84
+#: ../gui/wxpython/menustrings.py:86
msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
msgstr ""
-#: ../gui/wxpython/menustrings.py:85
-#, fuzzy
-msgid "Unpack vector map"
-msgstr "Jauna vektoru karte"
-#: ../gui/wxpython/menustrings.py:86
-msgid "Unpacks a vector map packed with v.pack."
-msgstr ""
#: ../gui/wxpython/menustrings.py:87
msgid "Import 3D raster data"
-msgstr ""
+msgstr "Importēt 3D rastra datus"
#: ../gui/wxpython/menustrings.py:88
msgid "ASCII 3D import"
@@ -6524,10048 +3611,12076 @@
msgstr ""
#: ../gui/wxpython/menustrings.py:90
-msgid "Raw binary array 3D import"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:91
-msgid "Imports a binary raster file into a GRASS 3D raster map."
-msgstr ""
msgid "Vis5D import"
msgstr ""
-#: ../gui/wxpython/menustrings.py:93
+#: ../gui/wxpython/menustrings.py:91
msgid "Import 3-dimensional Vis5D files."
msgstr ""
-#: ../gui/wxpython/menustrings.py:94
+#: ../gui/wxpython/menustrings.py:92
msgid "Import database table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:95
+#: ../gui/wxpython/menustrings.py:93
msgid "Multiple import formats using OGR"
msgstr ""
-#: ../gui/wxpython/menustrings.py:96
+#: ../gui/wxpython/menustrings.py:94
msgid "Imports attribute tables in various formats."
msgstr ""
-#: ../gui/wxpython/menustrings.py:97
+#: ../gui/wxpython/menustrings.py:95
msgid "Export raster map"
-msgstr ""
+msgstr "Eksportēt rastra karti"
-#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:131
+#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:129
msgid "Common export formats"
-msgstr ""
+msgstr "Biežāk lietotie formāti"
-#: ../gui/wxpython/menustrings.py:99
+#: ../gui/wxpython/menustrings.py:97
msgid "Exports GRASS raster maps into GDAL supported formats."
msgstr ""
-#: ../gui/wxpython/menustrings.py:100
+#: ../gui/wxpython/menustrings.py:98
msgid "ASCII grid export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:101
+#: ../gui/wxpython/menustrings.py:99
msgid "Converts a raster map layer into a GRASS ASCII text file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:102
+#: ../gui/wxpython/menustrings.py:100
msgid "ASCII x,y,z points export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:103
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
+#: ../gui/wxpython/menustrings.py:101
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:104
+#: ../gui/wxpython/menustrings.py:102
msgid "ESRI ASCII grid export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:105
+#: ../gui/wxpython/menustrings.py:103
msgid "Converts a raster map layer into an ESRI ARCGRID file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:106
+#: ../gui/wxpython/menustrings.py:104
msgid "GRIDATB.FOR export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:107
+#: ../gui/wxpython/menustrings.py:105
msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:108
+#: ../gui/wxpython/menustrings.py:106
msgid "Matlab 2D array export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:109
+#: ../gui/wxpython/menustrings.py:107
msgid "Exports a GRASS raster to a binary MAT-File."
msgstr ""
-#: ../gui/wxpython/menustrings.py:110
+#: ../gui/wxpython/menustrings.py:108
msgid "Raw binary array export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:111
+#: ../gui/wxpython/menustrings.py:109
msgid "Exports a GRASS raster to a binary array."
msgstr ""
-#: ../gui/wxpython/menustrings.py:112
+#: ../gui/wxpython/menustrings.py:110
msgid "MPEG-1 export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:113
+#: ../gui/wxpython/menustrings.py:111
msgid "Converts raster map series to MPEG movie."
msgstr ""
-#: ../gui/wxpython/menustrings.py:114
+#: ../gui/wxpython/menustrings.py:112
msgid "PNG export"
-msgstr ""
+msgstr "PNG eksports"
-#: ../gui/wxpython/menustrings.py:115
+#: ../gui/wxpython/menustrings.py:113
msgid "Export a GRASS raster map as a non-georeferenced PNG image."
msgstr ""
-#: ../gui/wxpython/menustrings.py:116
+#: ../gui/wxpython/menustrings.py:114
msgid "PPM export"
-msgstr ""
+msgstr "PPM eksports"
-#: ../gui/wxpython/menustrings.py:117
+#: ../gui/wxpython/menustrings.py:115
msgid "Converts a GRASS raster map to a PPM image file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:118
+#: ../gui/wxpython/menustrings.py:116
msgid "PPM from RGB export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:119
+#: ../gui/wxpython/menustrings.py:117
msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:141
+#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:137
msgid "POV-Ray export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:121
+#: ../gui/wxpython/menustrings.py:119
msgid "Converts a raster map layer into a height-field file for POV-Ray."
msgstr ""
-#: ../gui/wxpython/menustrings.py:122
+#: ../gui/wxpython/menustrings.py:120
msgid "TIFF export"
-msgstr ""
+msgstr "TIFF eksports"
-#: ../gui/wxpython/menustrings.py:123
+#: ../gui/wxpython/menustrings.py:121
msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:124
+#: ../gui/wxpython/menustrings.py:122
msgid "VRML export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:125
+#: ../gui/wxpython/menustrings.py:123
msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:145
-#: ../gui/wxpython/menustrings.py:156
+#: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:141
+#: ../gui/wxpython/menustrings.py:148
msgid "VTK export"
-msgstr ""
+msgstr "VTK eksports"
-#: ../gui/wxpython/menustrings.py:127
+#: ../gui/wxpython/menustrings.py:125
msgid "Converts raster maps into the VTK-ASCII format."
msgstr ""
-#: ../gui/wxpython/menustrings.py:128
+#: ../gui/wxpython/menustrings.py:126
msgid "Pack raster map"
-msgstr ""
+msgstr "Sapakot rastra karti"
-#: ../gui/wxpython/menustrings.py:129
+#: ../gui/wxpython/menustrings.py:127
msgid "Packs up a raster map and support files for copying."
msgstr ""
-#: ../gui/wxpython/menustrings.py:130
+#: ../gui/wxpython/menustrings.py:128
msgid "Export vector map"
-msgstr ""
+msgstr "Eksportēt vektrodatus"
-#: ../gui/wxpython/menustrings.py:132
+#: ../gui/wxpython/menustrings.py:130
msgid "Converts a vector map to any of the supported OGR vector formats."
msgstr ""
-#: ../gui/wxpython/menustrings.py:133
+#: ../gui/wxpython/menustrings.py:131
msgid "ASCII points or GRASS ASCII vector export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:134
-msgid ""
-"Exports a vector map to a GRASS ASCII vector representation. By default only "
-"features with category are exported. To export all features use 'layer=-1'."
+#: ../gui/wxpython/menustrings.py:132
+msgid "Exports a vector map to a GRASS ASCII vector representation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:135
+#: ../gui/wxpython/menustrings.py:133
msgid "DXF export"
-msgstr ""
+msgstr "DXF eksports"
-#: ../gui/wxpython/menustrings.py:136
+#: ../gui/wxpython/menustrings.py:134
msgid "Exports vector map to DXF file format."
msgstr ""
-#: ../gui/wxpython/menustrings.py:137
+#: ../gui/wxpython/menustrings.py:135
msgid "Multiple GPS export formats using GPSBabel"
msgstr ""
-#: ../gui/wxpython/menustrings.py:138
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GPSBabel."
+#: ../gui/wxpython/menustrings.py:136
+msgid "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
msgstr ""
-#: ../gui/wxpython/menustrings.py:139
-msgid "PostGIS export"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:140
-msgid "Exports a vector map layer to PostGIS feature table."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:142
+#: ../gui/wxpython/menustrings.py:138
msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
msgstr ""
-#: ../gui/wxpython/menustrings.py:143
+#: ../gui/wxpython/menustrings.py:139
msgid "SVG export"
-msgstr ""
+msgstr "SVG eksports"
-#: ../gui/wxpython/menustrings.py:144
+#: ../gui/wxpython/menustrings.py:140
msgid "Exports a vector map to SVG file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:146
+#: ../gui/wxpython/menustrings.py:142
msgid "Converts a vector map to VTK ASCII output."
msgstr ""
-#: ../gui/wxpython/menustrings.py:147
-#, fuzzy
-msgid "Pack vector map"
-#: ../gui/wxpython/menustrings.py:148
-msgid "Packs up a vector map and support files for copying."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:149
+#: ../gui/wxpython/menustrings.py:143
msgid "Export 3D raster maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:150
+#: ../gui/wxpython/menustrings.py:144
msgid "ASCII 3D export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:151
+#: ../gui/wxpython/menustrings.py:145
msgid "Converts a 3D raster map layer into a ASCII text file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:152
-msgid "Raw binary array 3D export"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:153
-msgid "Exports a GRASS 3D raster map to a binary array."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:154
+#: ../gui/wxpython/menustrings.py:146
msgid "Vis5D export"
msgstr ""
-#: ../gui/wxpython/menustrings.py:155
+#: ../gui/wxpython/menustrings.py:147
msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:157
+#: ../gui/wxpython/menustrings.py:149
msgid "Converts 3D raster maps into the VTK-ASCII format."
msgstr ""
-#: ../gui/wxpython/menustrings.py:158
+#: ../gui/wxpython/menustrings.py:150
msgid "Export database table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:159
+#: ../gui/wxpython/menustrings.py:151
msgid "Common export formats using OGR"
msgstr ""
-#: ../gui/wxpython/menustrings.py:160
+#: ../gui/wxpython/menustrings.py:152
msgid "Exports attribute tables into various formats."
msgstr ""
-#: ../gui/wxpython/menustrings.py:161
+#: ../gui/wxpython/menustrings.py:153
msgid "Link external formats"
msgstr ""
-#: ../gui/wxpython/menustrings.py:163
+#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/lmgr/layertree.py:53
+#: ../gui/wxpython/gui_modules/gdialogs.py:1703
+#: ../gui/wxpython/gui_core/dialogs.py:1793
+msgid "Link external raster data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:155
msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:165
+#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/lmgr/layertree.py:59
+#: ../gui/wxpython/gui_modules/gdialogs.py:1697
+#: ../gui/wxpython/gui_core/dialogs.py:1787
+msgid "Link external vector data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:157
msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:166
+#: ../gui/wxpython/menustrings.py:158
msgid "Output format for raster data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:167
+#: ../gui/wxpython/menustrings.py:159
msgid "Defines raster output format utilizing GDAL library."
msgstr ""
-#: ../gui/wxpython/menustrings.py:168
+#: ../gui/wxpython/menustrings.py:160
msgid "Output format for vector data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:169
+#: ../gui/wxpython/menustrings.py:161
msgid "Defines vector output format utilizing OGR library."
msgstr ""
-#: ../gui/wxpython/menustrings.py:170
+#: ../gui/wxpython/menustrings.py:162
msgid "Manage maps and volumes"
-msgstr ""
+msgstr "Pārvaldīt kartes un tilpumus"
-#: ../gui/wxpython/menustrings.py:171
+#: ../gui/wxpython/menustrings.py:163
msgid "Copy"
-msgstr ""
+msgstr "Kopēt"
+#: ../gui/wxpython/menustrings.py:164
msgid ""
"Copies available data files in the current mapset search path to the user's "
"current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:1599
+#: ../gui/wxpython/menustrings.py:165
msgid "List"
-msgstr ""
+msgstr "Parādīt"
-#: ../gui/wxpython/menustrings.py:174
+#: ../gui/wxpython/menustrings.py:166
msgid "Lists available GRASS data base files of the user-specified data type."
msgstr ""
-#: ../gui/wxpython/menustrings.py:175
+#: ../gui/wxpython/menustrings.py:167
msgid "List filtered"
msgstr ""
-#: ../gui/wxpython/menustrings.py:176
+#: ../gui/wxpython/menustrings.py:168
msgid ""
"Lists available GRASS data base files of the user-specified data type "
"optionally using the search pattern."
msgstr ""
-#: ../gui/wxpython/menustrings.py:178
+#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/lmgr/layertree.py:314
+#: ../gui/wxpython/gui_modules/layertree.py:281
+msgid "Rename"
+msgstr "Pārsaukt"
+#: ../gui/wxpython/menustrings.py:170
msgid "Renames data base element files in the user's current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:180
+#: ../gui/wxpython/menustrings.py:172
msgid "Removes data base element files from the user's current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:181
+#: ../gui/wxpython/menustrings.py:173
msgid "Delete filtered"
msgstr ""
-#: ../gui/wxpython/menustrings.py:182
+#: ../gui/wxpython/menustrings.py:174
msgid ""
"Removes data base element files from the user's current mapset using regular "
"expressions."
msgstr ""
-#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:316
-#: ../gui/wxpython/menustrings.py:603 ../gui/wxpython/menustrings.py:837
-#: ../gui/wxpython/menustrings.py:981 ../gui/wxpython/menustrings.py:1268
-#: ../gui/wxpython/menustrings.py:1502
+#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:309
+#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:825
msgid "Map type conversions"
msgstr ""
-#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:317
-#: ../gui/wxpython/menustrings.py:982
+#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:310
msgid "Raster to vector"
msgstr ""
-#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:318
-#: ../gui/wxpython/menustrings.py:983
+#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:311
msgid "Converts a raster map into a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:319
-#: ../gui/wxpython/menustrings.py:984
+#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:312
msgid "Raster series to volume"
msgstr ""
-#: ../gui/wxpython/menustrings.py:187 ../gui/wxpython/menustrings.py:320
-#: ../gui/wxpython/menustrings.py:985
+#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:313
msgid "Converts 2D raster map slices to one 3D raster volume map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:321
-#: ../gui/wxpython/menustrings.py:986
+#: ../gui/wxpython/menustrings.py:180 ../gui/wxpython/menustrings.py:314
msgid "Raster 2.5D to volume"
msgstr ""
-#: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:322
-#: ../gui/wxpython/menustrings.py:987
+#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:315
msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:604
-#: ../gui/wxpython/menustrings.py:1269
+#: ../gui/wxpython/menustrings.py:182 ../gui/wxpython/menustrings.py:594
msgid "Vector to raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:605
-#: ../gui/wxpython/menustrings.py:1270
+#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:595
msgid "Converts (rasterize) a vector map into a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:192 ../gui/wxpython/menustrings.py:606
-#: ../gui/wxpython/menustrings.py:1271
+#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:596
msgid "Vector to volume"
msgstr ""
-#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:607
-#: ../gui/wxpython/menustrings.py:1272
+#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:597
msgid "Converts a vector map (only points) into a 3D raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:194 ../gui/wxpython/menustrings.py:608
-#: ../gui/wxpython/menustrings.py:1273
+#: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:598
msgid "2D vector to 3D vector"
msgstr ""
-#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:609
-#: ../gui/wxpython/menustrings.py:1274
+#: ../gui/wxpython/menustrings.py:187 ../gui/wxpython/menustrings.py:599
msgid "Performs transformation of 2D vector features to 3D."
msgstr ""
-#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:610
-#: ../gui/wxpython/menustrings.py:1275
+#: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:600
msgid "Sites to vector"
msgstr ""
-#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:611
-#: ../gui/wxpython/menustrings.py:1276
+#: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:601
msgid "Converts a GRASS site_lists file into a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:198 ../gui/wxpython/menustrings.py:838
-#: ../gui/wxpython/menustrings.py:1503
+#: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:826
msgid "Volume to raster series"
msgstr ""
-#: ../gui/wxpython/menustrings.py:199 ../gui/wxpython/menustrings.py:839
-#: ../gui/wxpython/menustrings.py:1504
+#: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:827
msgid "Converts 3D raster maps to 2D raster maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:200
+#: ../gui/wxpython/menustrings.py:192
msgid "Georectify"
-msgstr ""
+msgstr "Ģeoreferencēt"
-#: ../gui/wxpython/menustrings.py:201
+#: ../gui/wxpython/menustrings.py:193
msgid "Manage Ground Control Points for Georectification"
msgstr ""
-#: ../gui/wxpython/menustrings.py:202
+#: ../gui/wxpython/menustrings.py:194
msgid "Graphical modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:203
+#: ../gui/wxpython/menustrings.py:195
msgid "Launch Graphical modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:204 ../gui/wxpython/menustrings.py:1709
+#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:954
msgid "Run model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:205
+#: ../gui/wxpython/menustrings.py:197
msgid "Run model prepared by Graphical modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:206
+#: ../gui/wxpython/menustrings.py:198
msgid "3D image rendering"
msgstr ""
-#: ../gui/wxpython/menustrings.py:207
-msgid ""
-"Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D "
-"vector data, and volumes (3D raster data) in 3D."
+#: ../gui/wxpython/menustrings.py:199
+msgid "Creates a 3D rendering of GIS data."
msgstr ""
-#: ../gui/wxpython/menustrings.py:209
+#: ../gui/wxpython/menustrings.py:200
+msgid "Animation tool (experimental - addons)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:201
msgid "Launch animation tool."
msgstr ""
-#: ../gui/wxpython/menustrings.py:210
+#: ../gui/wxpython/menustrings.py:202
msgid "Bearing/distance to coordinates"
msgstr ""
-#: ../gui/wxpython/menustrings.py:211
+#: ../gui/wxpython/menustrings.py:203
msgid ""
"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa. It assumes a cartesian coordinate system"
+"coordinates and vice versa."
msgstr ""
-#: ../gui/wxpython/menustrings.py:213
+#: ../gui/wxpython/menustrings.py:204 ../gui/wxpython/lmgr/toolbars.py:144
+msgid "Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:205
msgid "Launch Cartographic Composer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:214
+#: ../gui/wxpython/menustrings.py:206
#, fuzzy
msgid "Map Swipe"
-#: ../gui/wxpython/menustrings.py:215
+#: ../gui/wxpython/menustrings.py:207
msgid "Launch Map Swipe"
msgstr ""
-#: ../gui/wxpython/menustrings.py:216
+#: ../gui/wxpython/menustrings.py:208
msgid "Launch script"
msgstr ""
-#: ../gui/wxpython/menustrings.py:217
+#: ../gui/wxpython/menustrings.py:209
msgid "Launches script file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:218
+#: ../gui/wxpython/menustrings.py:210
msgid "Exit GUI"
msgstr "Iziet no GUI"
-#: ../gui/wxpython/menustrings.py:219
-#, fuzzy
-msgid "Quit the GRASS wxGUI session."
-msgstr "Sākt GRASS sesiju"
+#: ../gui/wxpython/menustrings.py:211
+msgid "Quit wxGUI session"
+msgstr "Pabeigt wxGUI sesiju"
-#: ../gui/wxpython/menustrings.py:220 ../gui/wxpython/menustrings.py:1689
+#: ../gui/wxpython/menustrings.py:212 ../gui/wxpython/menustrings.py:934
msgid "&Settings"
msgstr "Ie&statījumi"
-#: ../gui/wxpython/menustrings.py:222
+#: ../gui/wxpython/menustrings.py:213
+msgid "Region"
+msgstr "Reģions"
+#: ../gui/wxpython/menustrings.py:214
msgid "Display region"
msgstr "Attēlot reģionu"
-#: ../gui/wxpython/menustrings.py:223 ../gui/wxpython/menustrings.py:225
+#: ../gui/wxpython/menustrings.py:215 ../gui/wxpython/menustrings.py:217
msgid "Manages the boundary definitions for the geographic region."
msgstr ""
-#: ../gui/wxpython/menustrings.py:224
+#: ../gui/wxpython/menustrings.py:216
msgid "Set region"
msgstr "Iestatīt reģionu"
-#: ../gui/wxpython/menustrings.py:226
+#: ../gui/wxpython/menustrings.py:218
msgid "GRASS working environment"
-msgstr ""
+msgstr "GRASS darba vide"
-#: ../gui/wxpython/menustrings.py:227
+#: ../gui/wxpython/menustrings.py:219
msgid "Mapset access"
msgstr "Karšu kopu piekļuve"
-#: ../gui/wxpython/menustrings.py:228
+#: ../gui/wxpython/menustrings.py:220
msgid "Set/unset access to other mapsets in current location"
msgstr ""
-#: ../gui/wxpython/menustrings.py:229
+#: ../gui/wxpython/menustrings.py:221
msgid "User access"
msgstr ""
-#: ../gui/wxpython/menustrings.py:230
-msgid ""
-"Controls access to the current mapset for other users on the system. If no "
-"option given, prints current status."
+#: ../gui/wxpython/menustrings.py:222
+msgid "Controls access to the current mapset for other users on the system."
msgstr ""
-#: ../gui/wxpython/menustrings.py:231
+#: ../gui/wxpython/menustrings.py:223
msgid "Change working environment"
msgstr ""
-#: ../gui/wxpython/menustrings.py:232
-msgid ""
-"Changes/reports current mapset. Optionally create new mapset or list "
-"available mapsets in given location."
+#: ../gui/wxpython/menustrings.py:224
+msgid "Changes/reports current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:233
+#: ../gui/wxpython/menustrings.py:225
msgid "Change location and mapset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:234
+#: ../gui/wxpython/menustrings.py:226
msgid "Change current location and mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:235
+#: ../gui/wxpython/menustrings.py:227
msgid "Change mapset"
-msgstr ""
+msgstr "Mainīt karšu kopu"
-#: ../gui/wxpython/menustrings.py:236
+#: ../gui/wxpython/menustrings.py:228
msgid "Change current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:237 ../gui/wxpython/menustrings.py:238
+#: ../gui/wxpython/menustrings.py:229 ../gui/wxpython/menustrings.py:230
msgid "Change working directory"
msgstr ""
-#: ../gui/wxpython/menustrings.py:239
+#: ../gui/wxpython/menustrings.py:231
msgid "Show settings"
msgstr "Rādīt iestatījumus"
-#: ../gui/wxpython/menustrings.py:240
+#: ../gui/wxpython/menustrings.py:232 ../gui/wxpython/menustrings.py:234
msgid "Outputs and modifies the user's current GRASS variable settings."
msgstr ""
-#: ../gui/wxpython/menustrings.py:241
+#: ../gui/wxpython/menustrings.py:233
msgid "Change settings"
msgstr "Mainīt iestatījumus"
-#: ../gui/wxpython/menustrings.py:242
-msgid ""
-"Outputs and modifies the user's current GRASS variable settings. Prints all "
-"defined GRASS variables if no option is given."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:243
+#: ../gui/wxpython/menustrings.py:235
msgid "Create new location"
msgstr ""
-#: ../gui/wxpython/menustrings.py:244
+#: ../gui/wxpython/menustrings.py:236
msgid "Launches location wizard to create new GRASS location."
msgstr ""
-#: ../gui/wxpython/menustrings.py:246
+#: ../gui/wxpython/menustrings.py:237 ../gui/wxpython/lmgr/frame.py:674
+#: ../gui/wxpython/gis_set.py:694
+msgid "Create new mapset"
+msgstr "Izveidot jaunu karšu kopu"
+#: ../gui/wxpython/menustrings.py:238
msgid "Creates new mapset in the current location, changes current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:247
+#: ../gui/wxpython/menustrings.py:239
msgid "Version and copyright"
msgstr ""
-#: ../gui/wxpython/menustrings.py:248
+#: ../gui/wxpython/menustrings.py:240
msgid "Displays version and copyright information."
msgstr ""
-#: ../gui/wxpython/menustrings.py:249
+#: ../gui/wxpython/menustrings.py:241
msgid "Map projections"
-msgstr ""
+msgstr "Kartes projekcijas"
-#: ../gui/wxpython/menustrings.py:250
+#: ../gui/wxpython/menustrings.py:242
msgid "Display map projection"
msgstr ""
-#: ../gui/wxpython/menustrings.py:251
+#: ../gui/wxpython/menustrings.py:243
msgid ""
"Converts co-ordinate system descriptions (i.e. projection information) "
"between various formats (including GRASS format)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:252
+#: ../gui/wxpython/menustrings.py:244
msgid "Manage projections"
msgstr ""
-#: ../gui/wxpython/menustrings.py:253
+#: ../gui/wxpython/menustrings.py:245
msgid ""
"Prints and manipulates GRASS projection information files (in various co-"
-"ordinate system descriptions). Can also be used to create new GRASS "
-"locations."
+"ordinate system descriptions)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:254
+#: ../gui/wxpython/menustrings.py:246
msgid "Convert coordinates"
msgstr ""
-#: ../gui/wxpython/menustrings.py:255
+#: ../gui/wxpython/menustrings.py:247
msgid "Converts coordinates from one projection to another (cs2cs frontend)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:256
+#: ../gui/wxpython/menustrings.py:248
msgid "Addons extensions"
msgstr ""
-#: ../gui/wxpython/menustrings.py:257
+#: ../gui/wxpython/menustrings.py:249
msgid "Install extension from addons"
msgstr ""
-#: ../gui/wxpython/menustrings.py:258
+#: ../gui/wxpython/menustrings.py:250
msgid "Installs new extension from GRASS AddOns SVN repository."
msgstr ""
-#: ../gui/wxpython/menustrings.py:259
+#: ../gui/wxpython/menustrings.py:251
msgid "Update installed extensions"
msgstr ""
-#: ../gui/wxpython/menustrings.py:260
+#: ../gui/wxpython/menustrings.py:252
+msgid "Rebuilds all locally installed GRASS Addons extensions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:253
msgid "Uninstall extension"
msgstr ""
-#: ../gui/wxpython/menustrings.py:261
+#: ../gui/wxpython/menustrings.py:254
msgid "Removes installed GRASS AddOns extension."
msgstr ""
-#: ../gui/wxpython/menustrings.py:262 ../gui/wxpython/menustrings.py:1690
+#: ../gui/wxpython/menustrings.py:255 ../gui/wxpython/menustrings.py:935
msgid "Preferences"
msgstr ""
-#: ../gui/wxpython/menustrings.py:263
+#: ../gui/wxpython/menustrings.py:256
msgid "User GUI preferences (display font, commands, digitizer, etc.)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:929
+#: ../gui/wxpython/menustrings.py:257
msgid "&Raster"
msgstr "&Rastrs"
-#: ../gui/wxpython/menustrings.py:265 ../gui/wxpython/menustrings.py:930
+#: ../gui/wxpython/menustrings.py:258
msgid "Develop raster map"
-msgstr ""
+msgstr "Veidot rastra karti"
-#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:931
+#: ../gui/wxpython/menustrings.py:259
msgid "Compress/decompress"
msgstr ""
-#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:932
+#: ../gui/wxpython/menustrings.py:260
msgid "Compresses and decompresses raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:933
+#: ../gui/wxpython/menustrings.py:261
msgid "Region boundaries"
msgstr ""
-#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:934
+#: ../gui/wxpython/menustrings.py:262
msgid "Sets the boundary definitions for a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:935
+#: ../gui/wxpython/menustrings.py:263
msgid "Manage NULL values"
-msgstr ""
+msgstr "Pārvaldīt NULL vērtības"
-#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:936
+#: ../gui/wxpython/menustrings.py:264
msgid "Manages NULL-values of given raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:937
+#: ../gui/wxpython/menustrings.py:265
msgid "Quantization"
msgstr ""
-#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:938
+#: ../gui/wxpython/menustrings.py:266
msgid "Produces the quantization file for a floating-point map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:939
+#: ../gui/wxpython/menustrings.py:267
msgid "Timestamp"
msgstr ""
-#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:940
-msgid ""
-"Modifies a timestamp for a raster map. Print/add/remove a timestamp for a "
-"raster map."
+#: ../gui/wxpython/menustrings.py:268
+msgid "Modifies a timestamp for a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:941
+#: ../gui/wxpython/menustrings.py:269
msgid "Resample using aggregate statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:942
+#: ../gui/wxpython/menustrings.py:270
msgid "Resamples raster map layers to a coarser grid using aggregation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:943
+#: ../gui/wxpython/menustrings.py:271
msgid "Resample using multiple methods"
msgstr ""
-#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:944
+#: ../gui/wxpython/menustrings.py:272
msgid "Resamples raster map layers to a finer grid using interpolation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:945
+#: ../gui/wxpython/menustrings.py:273
msgid "Resample using nearest neighbor"
msgstr ""
-#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:946
+#: ../gui/wxpython/menustrings.py:274
msgid "GRASS raster map layer data resampling capability."
msgstr ""
-#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:947
+#: ../gui/wxpython/menustrings.py:275
msgid "Resample using spline tension"
msgstr ""
-#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:948
+#: ../gui/wxpython/menustrings.py:276
msgid ""
"Reinterpolates and optionally computes topographic analysis from input "
"raster map to a new raster map (possibly with different resolution) using "
"regularized spline with tension and smoothing."
msgstr ""
-#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:949
+#: ../gui/wxpython/menustrings.py:277
msgid "Resample using bspline"
msgstr ""
-#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:950
-msgid ""
-"Performs cubic or linear spline interpolation with Tykhonov regularization."
+#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:487
+msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
msgstr ""
-#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:951
+#: ../gui/wxpython/menustrings.py:279
msgid "Resample using analytic kernel"
msgstr ""
-#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:952
+#: ../gui/wxpython/menustrings.py:280
msgid "Resamples raster map layers using an analytic kernel."
msgstr ""
-#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:567
-#: ../gui/wxpython/menustrings.py:953 ../gui/wxpython/menustrings.py:1232
+#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:557
msgid "Support file maintenance"
msgstr ""
-#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:954
+#: ../gui/wxpython/menustrings.py:282
msgid "Allows creation and/or modification of raster map layer support files."
msgstr ""
-#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:955
+#: ../gui/wxpython/menustrings.py:283
msgid "Update map statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:956
+#: ../gui/wxpython/menustrings.py:284
msgid "Update raster map statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:957
+#: ../gui/wxpython/menustrings.py:285
msgid "Reproject raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:958
+#: ../gui/wxpython/menustrings.py:286
msgid "Re-projects a raster map from given location to the current location."
msgstr ""
-#: ../gui/wxpython/menustrings.py:294 ../gui/wxpython/menustrings.py:959
+#: ../gui/wxpython/menustrings.py:287
msgid "Tiling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:295 ../gui/wxpython/menustrings.py:960
+#: ../gui/wxpython/menustrings.py:288
msgid ""
"Produces tilings of the source projection for use in the destination region "
"and projection."
msgstr ""
-#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:586
-#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1251
+#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:576
msgid "Manage colors"
-msgstr ""
+msgstr "Pārvaldīt krāsas"
-#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:587
-#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1252
+#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:577
msgid "Color tables"
-msgstr ""
+msgstr "Krāsu tabulas"
-#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:963
+#: ../gui/wxpython/menustrings.py:291
msgid "Creates/modifies the color table associated with a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:964
+#: ../gui/wxpython/menustrings.py:292
msgid "Color tables (stddev)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:965
+#: ../gui/wxpython/menustrings.py:293
msgid "Sets color rules based on stddev from a raster map's mean value."
msgstr ""
-#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:589
-#: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1254
-msgid "Manage color rules interactively"
+#: ../gui/wxpython/menustrings.py:294
+msgid "Create color rules"
msgstr ""
-#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:967
+#: ../gui/wxpython/menustrings.py:295
msgid "Interactive management of raster color tables."
msgstr ""
-#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:591
-#: ../gui/wxpython/menustrings.py:968 ../gui/wxpython/menustrings.py:1256
+#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:581
msgid "Export color table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:969
+#: ../gui/wxpython/menustrings.py:297
msgid "Exports the color table associated with a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:970
+#: ../gui/wxpython/menustrings.py:298
msgid "Blend 2 color rasters"
msgstr ""
-#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:971
+#: ../gui/wxpython/menustrings.py:299
msgid "Blends color components of two raster maps by a given ratio."
msgstr ""
-#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:972
+#: ../gui/wxpython/menustrings.py:300
msgid "Create RGB"
msgstr ""
-#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:973
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+#: ../gui/wxpython/menustrings.py:301
+msgid "Combines red, green and blue raster maps into a single composite raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:744
-#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1409
+#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:730
msgid "RGB to HIS"
msgstr ""
-#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:975
+#: ../gui/wxpython/menustrings.py:303
msgid ""
"Generates red, green and blue raster map layers combining hue, intensity and "
"saturation (HIS) values from user-specified input raster map layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:976
+#: ../gui/wxpython/menustrings.py:304
msgid "Query raster maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:977
+#: ../gui/wxpython/menustrings.py:305
msgid "Query values by coordinates"
msgstr ""
-#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:978
+#: ../gui/wxpython/menustrings.py:306
msgid "Queries raster maps on their category values and category labels."
msgstr ""
-#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:979
+#: ../gui/wxpython/menustrings.py:307
msgid "Query colors by value"
msgstr ""
-#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:980
+#: ../gui/wxpython/menustrings.py:308
msgid "Queries colors for a raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:323 ../gui/wxpython/menustrings.py:988
+#: ../gui/wxpython/menustrings.py:316
msgid "Buffer rasters"
msgstr ""
-#: ../gui/wxpython/menustrings.py:324 ../gui/wxpython/menustrings.py:989
+#: ../gui/wxpython/menustrings.py:317
msgid ""
"Creates a raster map showing buffer zones surrounding cells that contain non-"
"NULL category values."
msgstr ""
-#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:990
+#: ../gui/wxpython/menustrings.py:318
msgid "Concentric circles"
msgstr ""
-#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:991
+#: ../gui/wxpython/menustrings.py:319
msgid "Creates a raster map containing concentric rings around a given point."
msgstr ""
-#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:992
+#: ../gui/wxpython/menustrings.py:320
msgid "Closest points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:993
+#: ../gui/wxpython/menustrings.py:321
msgid "Locates the closest points between objects in two raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:995
+#: ../gui/wxpython/menustrings.py:323
msgid "Creates a MASK for limiting raster operation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:331 ../gui/wxpython/menustrings.py:996
+#: ../gui/wxpython/menustrings.py:324
msgid "Raster map calculator"
msgstr ""
-#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:997
+#: ../gui/wxpython/menustrings.py:325
msgid "Raster map calculator."
msgstr ""
-#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:998
+#: ../gui/wxpython/menustrings.py:326
msgid "Neighborhood analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:999
-#: ../gui/wxpython/rlisetup/wizard.py:603
+#: ../gui/wxpython/menustrings.py:327
msgid "Moving window"
msgstr ""
-#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1000
+#: ../gui/wxpython/menustrings.py:328
msgid ""
"Makes each cell category value a function of the category values assigned to "
"the cells around it, and stores new cell values in an output raster map "
"layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:336 ../gui/wxpython/menustrings.py:1001
+#: ../gui/wxpython/menustrings.py:329
msgid "Neighborhood points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1002
-msgid ""
-"Neighborhood analysis tool for vector point maps. Makes each cell value a "
-"function of the attribute values assigned to the vector points or centroids "
-"around it, and stores new cell values in an output raster map."
+#: ../gui/wxpython/menustrings.py:330
+msgid "Neighborhood analysis tool for vector point maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1003
+#: ../gui/wxpython/menustrings.py:331
msgid "Overlay rasters"
msgstr ""
-#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1004
+#: ../gui/wxpython/menustrings.py:332
msgid "Cross product"
msgstr ""
-#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1005
+#: ../gui/wxpython/menustrings.py:333
msgid ""
"Creates a cross product of the category values from multiple raster map "
"layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1006
+#: ../gui/wxpython/menustrings.py:334
msgid "Raster series"
msgstr ""
-#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1007
+#: ../gui/wxpython/menustrings.py:335
msgid ""
"Makes each output cell value a function of the values assigned to the "
"corresponding cells in the input raster map layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1008
+#: ../gui/wxpython/menustrings.py:336
msgid "Patch raster maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1009
+#: ../gui/wxpython/menustrings.py:337
msgid ""
"Creates a composite raster map layer by using known category values from one "
"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1010
+#: ../gui/wxpython/menustrings.py:338
msgid "Statistical overlay"
msgstr ""
-#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1011
+#: ../gui/wxpython/menustrings.py:339
msgid ""
"Calculates category or object oriented statistics (accumulator-based "
"statistics)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1012
+#: ../gui/wxpython/menustrings.py:340
msgid "Quantiles overlay"
msgstr ""
-#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1013
+#: ../gui/wxpython/menustrings.py:341
msgid "Compute category quantiles using two passes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1014
+#: ../gui/wxpython/menustrings.py:342
msgid "Solar radiance and shadows"
msgstr ""
-#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1015
-msgid "LatLong map"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1016
-msgid "Creates a latitude/longitude raster map."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1017
+#: ../gui/wxpython/menustrings.py:343
msgid "Solar irradiance and irradiation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1018
-msgid ""
-"Solar irradiance and irradiation model. Computes direct (beam), diffuse and "
-"reflected solar irradiation raster maps for given day, latitude, surface and "
-"atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, "
-"declination, extraterrestrial irradiance, daylight length) are saved in the "
-"map history file. Alternatively, a local time can be specified to compute "
-"solar incidence angle and/or irradiance raster maps. The shadowing effect of "
-"the topography is optionally incorporated."
+#: ../gui/wxpython/menustrings.py:344
+msgid "Solar irradiance and irradiation model."
msgstr ""
-#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1019
+#: ../gui/wxpython/menustrings.py:345
msgid "Shadows map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1020
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map. "
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
+#: ../gui/wxpython/menustrings.py:346
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1021
-msgid "Sunshine hours and solar angles"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1022
-msgid ""
-"Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: "
-"the angle between the direction of the geometric center of the sun's "
-"apparent disk and the (idealized) horizon. Solar azimuth: the angle from due "
-"north in clockwise direction."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1023
+#: ../gui/wxpython/menustrings.py:347
msgid "Terrain analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1024
+#: ../gui/wxpython/menustrings.py:348
msgid "Generate contour lines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1025
+#: ../gui/wxpython/menustrings.py:349
msgid "Produces a vector map of specified contours from a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1026
+#: ../gui/wxpython/menustrings.py:350
msgid "Cost surface"
msgstr ""
-#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1027
+#: ../gui/wxpython/menustrings.py:351
msgid ""
"Creates a raster map showing the cumulative cost of moving between different "
"geographic locations on an input raster map whose cell category values "
"represent cost."
msgstr ""
-#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1028
+#: ../gui/wxpython/menustrings.py:352
msgid "Cumulative movement costs"
msgstr ""
-#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1029
+#: ../gui/wxpython/menustrings.py:353
msgid ""
-"Outputs a raster map showing the anisotropic cumulative cost. Computes "
-"anisotropic cumulative cost of moving between different geographic locations "
-"on an input elevation raster map whose cell category values represent "
-"elevation combined with an input raster map layer whose cell values "
-"represent friction cost."
+"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
+"between different geographic locations on an input elevation raster map "
+"layer whose cell category values represent elevation combined with an input "
+"raster map layer whose cell values represent friction cost."
msgstr ""
-#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1030
+#: ../gui/wxpython/menustrings.py:354
msgid "Least cost route or flow"
msgstr ""
-#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1031
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
+#: ../gui/wxpython/menustrings.py:355
+msgid "Traces a flow through an elevation model on a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1032
+#: ../gui/wxpython/menustrings.py:356
msgid "Shaded relief"
msgstr ""
-#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1033
-msgid "Creates shaded relief map from an elevation map (DEM). "
+#: ../gui/wxpython/menustrings.py:357
+msgid "Creates shaded relief map from an elevation map (DEM)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1034
+#: ../gui/wxpython/menustrings.py:358
msgid "Slope and aspect"
msgstr ""
-#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1035
+#: ../gui/wxpython/menustrings.py:359
msgid ""
"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map. Aspect is calculated counterclockwise from east."
+"from a elevation raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1036
+#: ../gui/wxpython/menustrings.py:360
msgid "Terrain parameters"
msgstr ""
-#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1037
-msgid ""
-"Extracts terrain parameters from a DEM. Uses a multi-scale approach by "
-"taking fitting quadratic parameters to any size window (via least squares)."
+#: ../gui/wxpython/menustrings.py:361
+msgid "Extracts terrain parameters from a DEM."
msgstr ""
-#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1038
+#: ../gui/wxpython/menustrings.py:362
msgid "Textural features"
msgstr ""
-#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1039
+#: ../gui/wxpython/menustrings.py:363
msgid "Generate images with textural features from a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1040
+#: ../gui/wxpython/menustrings.py:364
msgid "Visibility"
-msgstr ""
+msgstr "Redzamība"
-#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1041
-msgid ""
-"Computes the viewshed of a point on an elevation raster map. Default format: "
-"NULL (invisible), vertical angle wrt viewpoint (visible)."
+#: ../gui/wxpython/menustrings.py:365
+msgid "Computes the viewshed of a point on a raster terrain."
msgstr ""
-#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1042
+#: ../gui/wxpython/menustrings.py:366
msgid "Visibility [DEPRECATED]"
msgstr ""
-#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1043
+#: ../gui/wxpython/menustrings.py:367
msgid "Line-of-sight raster analysis program."
msgstr ""
-#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1044
+#: ../gui/wxpython/menustrings.py:368
msgid "Distance to features"
msgstr ""
-#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1045
-msgid "Generates a raster map containing distances to nearest raster features."
+#: ../gui/wxpython/menustrings.py:369
+msgid "Generates a raster map of distance to features in input raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1046
+#: ../gui/wxpython/menustrings.py:370
msgid "Horizon angle"
msgstr ""
-#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1047
-msgid ""
-"Horizon angle computation from a digital elevation model. Computes horizon "
-"angle height from a digital elevation model. The module has two different "
-"modes of operation: 1. Computes the entire horizon around a single point "
-"whose coordinates are given with the 'coord' option. The horizon height (in "
-"radians). 2. Computes one or more raster maps of the horizon height in a "
-"single direction. The input for this is the angle (in degrees), which is "
-"measured counterclockwise with east=0, north=90 etc. The output is the "
-"horizon height in radians."
+#: ../gui/wxpython/menustrings.py:371
+msgid "Horizon angle computation from a digital elevation model."
msgstr ""
-#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1048
+#: ../gui/wxpython/menustrings.py:372
msgid "Transform features"
msgstr ""
-#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1049
+#: ../gui/wxpython/menustrings.py:373
msgid "Clump"
msgstr ""
-#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1050
+#: ../gui/wxpython/menustrings.py:374
msgid ""
"Recategorizes data in a raster map by grouping cells that form physically "
"discrete areas into unique categories."
msgstr ""
-#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1051
+#: ../gui/wxpython/menustrings.py:375
msgid "Grow"
msgstr ""
-#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1052
+#: ../gui/wxpython/menustrings.py:376
msgid "Generates a raster map layer with contiguous areas grown by one cell."
msgstr ""
-#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1053
+#: ../gui/wxpython/menustrings.py:377
msgid "Thin"
msgstr ""
-#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1054
+#: ../gui/wxpython/menustrings.py:378
msgid "Thins non-zero cells that denote linear features in a raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1055
+#: ../gui/wxpython/menustrings.py:379
msgid "Hydrologic modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1056
+#: ../gui/wxpython/menustrings.py:380
msgid "Carve stream channels"
msgstr ""
-#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1057
-msgid ""
-"Generates stream channels. Takes vector stream data, transforms it to raster "
-"and subtracts depth from the output DEM."
+#: ../gui/wxpython/menustrings.py:381
+msgid "Generates stream channels."
msgstr ""
-#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1058
+#: ../gui/wxpython/menustrings.py:382
msgid "Fill lake"
msgstr "Ezera aizpildīšana"
-#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1059
+#: ../gui/wxpython/menustrings.py:383
msgid "Fills lake at given point to given level."
msgstr ""
-#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1060
+#: ../gui/wxpython/menustrings.py:384
msgid "Depressionless map and flowlines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1061
+#: ../gui/wxpython/menustrings.py:385
msgid ""
"Filters and generates a depressionless elevation map and a flow direction "
"map from a given elevation raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1062
+#: ../gui/wxpython/menustrings.py:386
msgid "Flow accumulation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1063
+#: ../gui/wxpython/menustrings.py:387
msgid "Flow computation for massive grids (float version)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1064
+#: ../gui/wxpython/menustrings.py:388
msgid "Flow lines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1065
-msgid ""
-"Constructs flowlines. Computes flowlines, flowpath lengths, and "
-"flowaccumulation (contributing areas) from a elevation raster map."
+#: ../gui/wxpython/menustrings.py:389
+msgid "Constructs flowlines."
msgstr ""
-#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1066
+#: ../gui/wxpython/menustrings.py:390
msgid "Watershed analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1067
+#: ../gui/wxpython/menustrings.py:391
msgid "Calculates hydrological parameters and RUSLE factors."
msgstr ""
-#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1068
+#: ../gui/wxpython/menustrings.py:392
msgid "Watershed subbasins"
msgstr ""
-#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1069
+#: ../gui/wxpython/menustrings.py:393
msgid "Generates watershed subbasins raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1070
+#: ../gui/wxpython/menustrings.py:394
msgid "Watershed basin creation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1071
-msgid "Creates watershed basins from a drainage direction map."
+#: ../gui/wxpython/menustrings.py:395
+msgid "Creates watershed basins."
msgstr ""
-#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1072
+#: ../gui/wxpython/menustrings.py:396
msgid "SIMWE Overland flow modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1073
+#: ../gui/wxpython/menustrings.py:397
msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1074
+#: ../gui/wxpython/menustrings.py:398
msgid "SIMWE Sediment flux modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1075
+#: ../gui/wxpython/menustrings.py:399
msgid ""
"Sediment transport and erosion/deposition simulation using path sampling "
"method (SIMWE)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1076
+#: ../gui/wxpython/menustrings.py:400
msgid "Topographic index map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1077
+#: ../gui/wxpython/menustrings.py:401
msgid "Creates topographic index map from elevation raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1078
+#: ../gui/wxpython/menustrings.py:402
msgid "TOPMODEL simulation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1079
+#: ../gui/wxpython/menustrings.py:403
msgid "Simulates TOPMODEL which is a physically based hydrologic model."
msgstr ""
-#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1080
+#: ../gui/wxpython/menustrings.py:404
msgid "USLE K-factor"
msgstr ""
-#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1081
+#: ../gui/wxpython/menustrings.py:405
msgid "Computes USLE Soil Erodibility Factor (K)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1082
+#: ../gui/wxpython/menustrings.py:406
msgid "USLE R-factor"
msgstr ""
-#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1083
+#: ../gui/wxpython/menustrings.py:407
msgid "Computes USLE R factor, Rainfall erosivity index."
msgstr ""
-#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:850
-#: ../gui/wxpython/menustrings.py:1084 ../gui/wxpython/menustrings.py:1515
+#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:838
msgid "Groundwater modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1085
+#: ../gui/wxpython/menustrings.py:409
msgid "Groundwater flow"
msgstr ""
-#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1086
+#: ../gui/wxpython/menustrings.py:410
msgid ""
"Numerical calculation program for transient, confined and unconfined "
"groundwater flow in two dimensions."
msgstr ""
-#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1087
+#: ../gui/wxpython/menustrings.py:411
msgid "Groundwater solute transport"
msgstr ""
-#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1088
+#: ../gui/wxpython/menustrings.py:412
msgid ""
"Numerical calculation program for transient, confined and unconfined solute "
"transport in two dimensions"
msgstr ""
-#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1089
+#: ../gui/wxpython/menustrings.py:413
msgid "Landscape structure modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1090
+#: ../gui/wxpython/menustrings.py:414
msgid "Analyze landscape"
msgstr ""
-#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1091
+#: ../gui/wxpython/menustrings.py:415
+msgid ""
+"Contains a set of measures for attributes, diversity, texture, "
+"juxtaposition, and edge."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:416
msgid "Analyze patches"
msgstr ""
-#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1092
+#: ../gui/wxpython/menustrings.py:417
+msgid ""
+"Calculates attribute, patch size, core (interior) size, shape, fractal "
+"dimension, and perimeter measures for sets of patches in a landscape."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:418
msgid "Landscape patch analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1093
+#: ../gui/wxpython/menustrings.py:419
msgid "Set up sampling and analysis framework"
msgstr ""
-#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1094
+#: ../gui/wxpython/menustrings.py:420
msgid "Configuration editor for r.li.'index'"
msgstr ""
-#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1095
+#: ../gui/wxpython/menustrings.py:421
msgid "Edge density"
msgstr ""
-#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1096
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+#: ../gui/wxpython/menustrings.py:422
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
-#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1097
+#: ../gui/wxpython/menustrings.py:423
msgid "Contrast weighted edge density"
msgstr ""
-#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1098
+#: ../gui/wxpython/menustrings.py:424
msgid "Calculates contrast weighted edge density index on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1099
+#: ../gui/wxpython/menustrings.py:425
msgid "Patch area mean"
msgstr ""
-#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1100
+#: ../gui/wxpython/menustrings.py:426
msgid ""
"Calculates mean patch size index on a raster map, using a 4 neighbour "
"algorithm"
msgstr ""
-#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1101
+#: ../gui/wxpython/menustrings.py:427
msgid "Patch area range"
msgstr ""
-#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:1102
+#: ../gui/wxpython/menustrings.py:428
msgid "Calculates range of patch area size on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1103
+#: ../gui/wxpython/menustrings.py:429
msgid "Patch area Std Dev"
msgstr ""
-#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1104
+#: ../gui/wxpython/menustrings.py:430
msgid "Calculates standard deviation of patch area a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1105
+#: ../gui/wxpython/menustrings.py:431
msgid "Patch area Coeff Var"
msgstr ""
-#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1106
+#: ../gui/wxpython/menustrings.py:432
msgid "Calculates coefficient of variation of patch area on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1107
+#: ../gui/wxpython/menustrings.py:433
msgid "Patch density"
msgstr ""
-#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1108
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+#: ../gui/wxpython/menustrings.py:434
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
-#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1109
+#: ../gui/wxpython/menustrings.py:435
msgid "Patch number"
msgstr ""
-#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1110
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+#: ../gui/wxpython/menustrings.py:436
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
msgstr ""
-#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1111
+#: ../gui/wxpython/menustrings.py:437
msgid "Dominance's diversity"
msgstr ""
-#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:453
-#: ../gui/wxpython/menustrings.py:1112 ../gui/wxpython/menustrings.py:1118
+#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:444
msgid "Calculates dominance's diversity index on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1113
+#: ../gui/wxpython/menustrings.py:439
msgid "Shannon's diversity"
msgstr ""
-#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1114
+#: ../gui/wxpython/menustrings.py:440
msgid "Calculates Shannon's diversity index on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1115
+#: ../gui/wxpython/menustrings.py:441
msgid "Simpson's diversity"
msgstr ""
-#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1116
+#: ../gui/wxpython/menustrings.py:442
msgid "Calculates Simpson's diversity index on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1117
+#: ../gui/wxpython/menustrings.py:443
msgid "Richness"
msgstr ""
-#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1119
+#: ../gui/wxpython/menustrings.py:445
msgid "Shape index"
msgstr ""
-#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1120
+#: ../gui/wxpython/menustrings.py:446
msgid "Calculates shape index on a raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1121
+#: ../gui/wxpython/menustrings.py:447
msgid "Wildfire modeling"
msgstr ""
-#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1122
+#: ../gui/wxpython/menustrings.py:448
msgid "Rate of spread"
msgstr ""
-#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1123
-msgid ""
-"Generates rate of spread raster map layers. Generates three, or four raster "
-"map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the "
-"maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally "
-"4) the maximum potential spotting distance."
+#: ../gui/wxpython/menustrings.py:449
+msgid "Generates rate of spread raster map layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1124
+#: ../gui/wxpython/menustrings.py:450
msgid "Least-cost spread paths"
msgstr ""
-#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1125
+#: ../gui/wxpython/menustrings.py:451
msgid ""
"Recursively traces the least cost path backwards to cells from which the "
"cumulative cost was determined."
msgstr ""
-#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1126
+#: ../gui/wxpython/menustrings.py:452
msgid "Anisotropic spread simulation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1127
+#: ../gui/wxpython/menustrings.py:453
msgid ""
"Simulates elliptically anisotropic spread on a graphics window and generates "
"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins. It "
-"optionally produces raster maps to contain backlink UTM coordinates for "
-"tracing spread paths."
+"the rates of spread (ROS), the ROS directions and the spread origins."
msgstr ""
-#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1128
+#: ../gui/wxpython/menustrings.py:454
msgid "Change category values and labels"
msgstr ""
-#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1129
+#: ../gui/wxpython/menustrings.py:455
msgid "Interactively edit category values"
msgstr ""
-#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1130
+#: ../gui/wxpython/menustrings.py:456
msgid "Edits cell values in a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1131
+#: ../gui/wxpython/menustrings.py:457
msgid "Reclassify by size"
msgstr ""
-#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1132
+#: ../gui/wxpython/menustrings.py:458
msgid ""
"Reclasses a raster map greater or less than user specified area size (in "
"hectares)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:677
-#: ../gui/wxpython/menustrings.py:1133 ../gui/wxpython/menustrings.py:1342
+#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:663
msgid "Reclassify"
msgstr ""
-#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1134
-msgid ""
-"Reclassify raster map based on category values. Creates a new raster map "
-"whose category values are based upon a reclassification of the categories in "
-"an existing raster map."
+#: ../gui/wxpython/menustrings.py:460
+msgid "Reclassify raster map based on category values."
msgstr ""
-#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1135
+#: ../gui/wxpython/menustrings.py:461
msgid "Recode"
msgstr ""
-#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1136
+#: ../gui/wxpython/menustrings.py:462
msgid "Recodes categorical raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1137
+#: ../gui/wxpython/menustrings.py:463
msgid "Rescale"
msgstr ""
-#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1138
+#: ../gui/wxpython/menustrings.py:464
msgid "Rescales the range of category values in a raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1139
+#: ../gui/wxpython/menustrings.py:465
msgid "Rescale with histogram"
msgstr ""
-#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1140
+#: ../gui/wxpython/menustrings.py:466
msgid ""
"Rescales histogram equalized the range of category values in a raster map "
"layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1141
+#: ../gui/wxpython/menustrings.py:467
msgid "Generate random cells"
msgstr ""
-#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1142
+#: ../gui/wxpython/menustrings.py:468
msgid "Random cells"
msgstr ""
-#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1143
+#: ../gui/wxpython/menustrings.py:469
msgid "Generates random cell values with spatial dependence."
msgstr ""
-#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1144
+#: ../gui/wxpython/menustrings.py:470
msgid "Random cells and vector points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1145
+#: ../gui/wxpython/menustrings.py:471
msgid ""
"Creates a raster map layer and vector point map containing randomly located "
"points."
msgstr ""
-#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1146
+#: ../gui/wxpython/menustrings.py:472
msgid "Generate surfaces"
msgstr ""
-#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1147
+#: ../gui/wxpython/menustrings.py:473
msgid "Fractal surface"
msgstr ""
-#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1148
+#: ../gui/wxpython/menustrings.py:474
msgid "Creates a fractal surface of a given fractal dimension."
msgstr ""
-#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1149
+#: ../gui/wxpython/menustrings.py:475
msgid "Gaussian kernel density surface"
msgstr ""
-#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:1150
+#: ../gui/wxpython/menustrings.py:476
msgid ""
-"Generates a raster density map from vector points map. Density is computed "
-"using a moving kernel. Optionally generates a vector density map on a vector "
-"network."
+"Generates a raster density map from vector point data using a moving kernel "
+"or optionally generates a vector density map on a vector network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1151
+#: ../gui/wxpython/menustrings.py:477
msgid "Gaussian deviates surface"
msgstr ""
-#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1152
+#: ../gui/wxpython/menustrings.py:478
msgid ""
-"Generates a raster map using gaussian random number generator. Mean and "
-"standard deviation of gaussian deviates can be expressed by the user."
+"GRASS module to produce a raster map layer of gaussian deviates whose mean "
+"and standard deviation can be expressed by the user. It uses a gaussian "
+"random number generator."
msgstr ""
-#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1154
+#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/nviz/tools.py:4476
+#: ../gui/wxpython/gui_modules/nviz_tools.py:4590
+msgid "Plane"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:480
msgid ""
"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
"point."
msgstr ""
-#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1155
+#: ../gui/wxpython/menustrings.py:481
msgid "Random deviates surface"
msgstr ""
-#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1156
+#: ../gui/wxpython/menustrings.py:482
msgid ""
-"Produces a raster surface map of uniform random deviates with defined range."
+"Produces a raster map of uniform random deviates whose range can be "
+"expressed by the user."
msgstr ""
-#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1157
+#: ../gui/wxpython/menustrings.py:483
msgid "Random surface with spatial dependence"
msgstr ""
-#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1158
+#: ../gui/wxpython/menustrings.py:484
msgid "Generates random surface(s) with spatial dependence."
msgstr ""
-#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1159
+#: ../gui/wxpython/menustrings.py:485
msgid "Interpolate surfaces"
msgstr ""
-#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1160
+#: ../gui/wxpython/menustrings.py:486
msgid "Bilinear and bicubic from vector points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1161
-msgid ""
-"Performs bicubic or bilinear spline interpolation with Tykhonov "
-"regularization."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1162
+#: ../gui/wxpython/menustrings.py:488
msgid "IDW from raster points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1163
+#: ../gui/wxpython/menustrings.py:489
msgid "Surface interpolation utility for raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1164
+#: ../gui/wxpython/menustrings.py:490
msgid "IDW from raster points (alternate method for sparse points)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1165
+#: ../gui/wxpython/menustrings.py:491
msgid "Surface generation program."
msgstr ""
-#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1166
+#: ../gui/wxpython/menustrings.py:492
msgid "IDW from vector points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1167
+#: ../gui/wxpython/menustrings.py:493
msgid ""
"Surface interpolation from vector point data by Inverse Distance Squared "
"Weighting."
msgstr ""
-#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1168
+#: ../gui/wxpython/menustrings.py:494
msgid "Raster contours"
msgstr ""
-#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1169
+#: ../gui/wxpython/menustrings.py:495
msgid "Generates surface raster map from rasterized contours."
msgstr ""
-#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1170
+#: ../gui/wxpython/menustrings.py:496
msgid "Regularized spline tension"
msgstr ""
-#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1171
+#: ../gui/wxpython/menustrings.py:497
msgid ""
-"Performs surface interpolation from vector points map by splines. Spatial "
-"approximation and topographic analysis from given point or isoline data in "
-"vector format to floating point raster format using regularized spline with "
-"tension."
+"Spatial approximation and topographic analysis from given point or isoline "
+"data in vector format to floating point raster format using regularized "
+"spline with tension."
msgstr ""
-#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1172
+#: ../gui/wxpython/menustrings.py:498
msgid "Ordinary or block kriging"
msgstr ""
-#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1173
+#: ../gui/wxpython/menustrings.py:499
msgid "Performs ordinary or block kriging."
msgstr ""
-#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1174
+#: ../gui/wxpython/menustrings.py:500
msgid "Fill NULL cells"
-msgstr ""
+msgstr "Aizpildīt NULL šūnas"
-#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1175
+#: ../gui/wxpython/menustrings.py:501
msgid "Fills no-data areas in raster maps using spline interpolation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:716
-#: ../gui/wxpython/menustrings.py:824 ../gui/wxpython/menustrings.py:1176
-#: ../gui/wxpython/menustrings.py:1381 ../gui/wxpython/menustrings.py:1489
-#: ../gui/wxpython/menustrings.py:1659
-msgid "Reports and statistics"
-msgstr ""
+#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:812
+msgid "Report and statistics"
+msgstr "Atskaites un statistika"
-#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1177
+#: ../gui/wxpython/menustrings.py:503
msgid "Basic raster metadata"
-msgstr ""
+msgstr "Rastra metadati"
-#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1178
+#: ../gui/wxpython/menustrings.py:504
msgid "Outputs basic information about a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1179
+#: ../gui/wxpython/menustrings.py:505
msgid "Manage category information"
msgstr ""
-#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1180
+#: ../gui/wxpython/menustrings.py:506
msgid ""
"Manages category values and labels associated with user-specified raster map "
"layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1181
+#: ../gui/wxpython/menustrings.py:507
msgid "General statistics"
msgstr "Vispārēja statistika"
-#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1182
+#: ../gui/wxpython/menustrings.py:508
msgid "Generates area statistics for raster map layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1183
+#: ../gui/wxpython/menustrings.py:509
msgid "Quantiles for large data sets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1184
+#: ../gui/wxpython/menustrings.py:510
msgid "Compute quantiles using two passes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1185
+#: ../gui/wxpython/menustrings.py:511
msgid "Range of category values"
msgstr ""
-#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1186
+#: ../gui/wxpython/menustrings.py:512
msgid "Prints terse list of category values found in a raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1187
+#: ../gui/wxpython/menustrings.py:513
msgid "Sum area by raster map and category"
msgstr ""
-#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1188
+#: ../gui/wxpython/menustrings.py:514
msgid "Reports statistics for raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1189
+#: ../gui/wxpython/menustrings.py:515
msgid "Statistics for clumped cells"
msgstr ""
-#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1190
+#: ../gui/wxpython/menustrings.py:516
msgid ""
-"Calculates the volume of data \"clumps\". Optionally produces a GRASS vector "
-"points map containing the calculated centroids of these clumps."
+"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
+"vector points map containing the calculated centroids of these clumps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1191
+#: ../gui/wxpython/menustrings.py:517
msgid "Total corrected area"
msgstr ""
-#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1192
+#: ../gui/wxpython/menustrings.py:518
msgid "Prints estimation of surface area for raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1194
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/lmgr/layertree.py:446
+#: ../gui/wxpython/gui_modules/layertree.py:412
+msgid "Univariate raster statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1195
+#: ../gui/wxpython/menustrings.py:520
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:521
msgid "Sample transects"
msgstr ""
-#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1196
+#: ../gui/wxpython/menustrings.py:522
msgid "Outputs the raster map layer values lying on user-defined line(s)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1197
+#: ../gui/wxpython/menustrings.py:523
msgid "Sample transects (bearing/distance)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1198
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+#: ../gui/wxpython/menustrings.py:524
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1199
+#: ../gui/wxpython/menustrings.py:525
msgid "Covariance/correlation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1200
+#: ../gui/wxpython/menustrings.py:526
msgid ""
"Outputs a covariance/correlation matrix for user-specified raster map "
"layer(s)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1201
+#: ../gui/wxpython/menustrings.py:527
msgid "Linear regression"
msgstr ""
-#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1202
+#: ../gui/wxpython/menustrings.py:528
msgid "Calculates linear regression from two raster maps: y = a + b*x."
msgstr ""
-#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1203
-#, fuzzy
-msgid "Multiple regression"
-msgstr "Pievienot vairākas rastra vai vektoru kartes"
-#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1204
-msgid "Calculates multiple linear regression from raster maps."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1205
+#: ../gui/wxpython/menustrings.py:529
msgid "Mutual category occurrences"
msgstr ""
-#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1206
+#: ../gui/wxpython/menustrings.py:530
msgid ""
"Tabulates the mutual occurrence (coincidence) of categories for two raster "
"map layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1207
+#: ../gui/wxpython/menustrings.py:531
msgid "&Vector"
msgstr "&Vektors"
-#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1208
+#: ../gui/wxpython/menustrings.py:532
msgid "Develop vector map"
-msgstr ""
+msgstr "Izveidot vektordatu karti"
-#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1210
+#: ../gui/wxpython/menustrings.py:533
+#: ../gui/wxpython/gui_modules/gdialogs.py:224
+#: ../gui/wxpython/gui_modules/gdialogs.py:366
+#: ../gui/wxpython/gui_core/dialogs.py:227
+#: ../gui/wxpython/gui_core/dialogs.py:369
+msgid "Create new vector map"
+msgstr "Izveidot jaunu vektordatu karti"
+#: ../gui/wxpython/menustrings.py:534
msgid "Create new empty vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1211
+#: ../gui/wxpython/menustrings.py:535
msgid "Edit vector map (non-interactively)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1212
+#: ../gui/wxpython/menustrings.py:536
msgid ""
"Edits a vector map, allows adding, deleting and modifying selected vector "
"features."
msgstr ""
-#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1213
+#: ../gui/wxpython/menustrings.py:537
msgid "Convert object types"
msgstr ""
-#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1214
+#: ../gui/wxpython/menustrings.py:538
msgid "Changes type of vector features."
msgstr ""
-#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1215
+#: ../gui/wxpython/menustrings.py:539
msgid "Parallel lines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1216
+#: ../gui/wxpython/menustrings.py:540
msgid "Creates parallel line to input vector lines."
msgstr ""
-#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1217
+#: ../gui/wxpython/menustrings.py:541
msgid "Dissolve boundaries"
msgstr ""
-#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1218
+#: ../gui/wxpython/menustrings.py:542
msgid ""
"Dissolves boundaries between adjacent areas sharing a common category number "
"or attribute."
msgstr ""
-#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1219
+#: ../gui/wxpython/menustrings.py:543
msgid "Create 3D vector over raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1220
-msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
+#: ../gui/wxpython/menustrings.py:544
+msgid "Converts vector map to 3D by sampling of elevation raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1221
+#: ../gui/wxpython/menustrings.py:545
msgid "Extrude 3D vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1222
-msgid ""
-"Extrudes flat vector features to 3D vector features with defined height. "
-"Optionally the height can be derived from sampling of elevation raster map."
+#: ../gui/wxpython/menustrings.py:546
+msgid "Extrudes flat vector features to 3D with defined height."
msgstr ""
-#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1223
+#: ../gui/wxpython/menustrings.py:547
msgid "Create labels"
msgstr ""
-#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1224
+#: ../gui/wxpython/menustrings.py:548
msgid "Creates paint labels for a vector map from attached attributes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1225
+#: ../gui/wxpython/menustrings.py:549
msgid "Create optimally placed labels"
msgstr ""
-#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1226
+#: ../gui/wxpython/menustrings.py:550
+msgid "Create optimally placed labels for vector map(s)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:551
msgid "Reposition vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1227
+#: ../gui/wxpython/menustrings.py:552
msgid ""
-"Performs an affine transformation (shift, scale and rotate) on vector map."
+"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
+"vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1228
+#: ../gui/wxpython/menustrings.py:553
msgid "Rectify vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1229
+#: ../gui/wxpython/menustrings.py:554
msgid ""
"Rectifies a vector by computing a coordinate transformation for each object "
"in the vector based on the control points."
msgstr ""
-#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1230
+#: ../gui/wxpython/menustrings.py:555
msgid "Reproject vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:566 ../gui/wxpython/menustrings.py:1231
+#: ../gui/wxpython/menustrings.py:556
msgid "Re-projects a vector map from one location to the current location."
msgstr ""
-#: ../gui/wxpython/menustrings.py:568 ../gui/wxpython/menustrings.py:1233
+#: ../gui/wxpython/menustrings.py:558
msgid "Updates vector map metadata."
msgstr ""
-#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1234
+#: ../gui/wxpython/menustrings.py:559
msgid "Topology maintenance"
msgstr ""
-#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1235
+#: ../gui/wxpython/menustrings.py:560
msgid "Create or rebuild topology"
msgstr ""
-#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1236
-msgid ""
-"Creates topology for vector map. Optionaly also checks for topological "
-"errors."
+#: ../gui/wxpython/menustrings.py:561
+msgid "Creates topology for vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1237
+#: ../gui/wxpython/menustrings.py:562
msgid "Rebuild topology on all vector maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1238
+#: ../gui/wxpython/menustrings.py:563
msgid "Rebuilds topology on all vector maps in the current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1239
+#: ../gui/wxpython/menustrings.py:564
msgid "Build polylines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1240
+#: ../gui/wxpython/menustrings.py:565
msgid "Builds polylines from lines or boundaries."
msgstr ""
-#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1241
+#: ../gui/wxpython/menustrings.py:566
msgid "Split lines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1242
+#: ../gui/wxpython/menustrings.py:567
msgid "Splits vector lines to shorter segments."
msgstr ""
-#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1243
+#: ../gui/wxpython/menustrings.py:568
msgid "Split polylines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1244
+#: ../gui/wxpython/menustrings.py:569
msgid "Creates points/segments from input vector lines and positions."
msgstr ""
-#: ../gui/wxpython/menustrings.py:580 ../gui/wxpython/menustrings.py:1245
+#: ../gui/wxpython/menustrings.py:570
msgid "Clean vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1246
+#: ../gui/wxpython/menustrings.py:571
msgid "Toolset for cleaning topology of vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1247
+#: ../gui/wxpython/menustrings.py:572
msgid "Smooth or simplify"
msgstr ""
-#: ../gui/wxpython/menustrings.py:583 ../gui/wxpython/menustrings.py:1248
-msgid "Performs vector based generalization."
+#: ../gui/wxpython/menustrings.py:573
+msgid "Tool for vector based generalization."
msgstr ""
-#: ../gui/wxpython/menustrings.py:584 ../gui/wxpython/menustrings.py:1249
+#: ../gui/wxpython/menustrings.py:574
msgid "Add centroids"
msgstr ""
-#: ../gui/wxpython/menustrings.py:585 ../gui/wxpython/menustrings.py:1250
+#: ../gui/wxpython/menustrings.py:575
msgid "Adds missing centroids to closed boundaries."
msgstr ""
-#: ../gui/wxpython/menustrings.py:588 ../gui/wxpython/menustrings.py:1253
+#: ../gui/wxpython/menustrings.py:578
msgid "Creates/modifies the color table associated with a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:1255
+#: ../gui/wxpython/menustrings.py:579
+msgid "Color rules"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:580
msgid "Interactive management of vector color tables."
msgstr ""
-#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:1257
+#: ../gui/wxpython/menustrings.py:582
msgid "Exports the color table associated with a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:1258
+#: ../gui/wxpython/menustrings.py:583
msgid "Query vector map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:1259
+#: ../gui/wxpython/menustrings.py:584
msgid "Query with coordinate(s)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1260
+#: ../gui/wxpython/menustrings.py:585
msgid "Queries a vector map at given locations."
msgstr ""
-#: ../gui/wxpython/menustrings.py:596 ../gui/wxpython/menustrings.py:893
-#: ../gui/wxpython/menustrings.py:1261 ../gui/wxpython/menustrings.py:1558
+#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:881
msgid "Query vector attribute data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:894
-#: ../gui/wxpython/menustrings.py:1262 ../gui/wxpython/menustrings.py:1559
+#: ../gui/wxpython/menustrings.py:587 ../gui/wxpython/menustrings.py:882
msgid "Prints vector map attributes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:598 ../gui/wxpython/menustrings.py:1263
+#: ../gui/wxpython/menustrings.py:588
msgid "Feature selection"
msgstr ""
-#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:1264
+#: ../gui/wxpython/menustrings.py:589
msgid "Select by attributes"
msgstr ""
-#: ../gui/wxpython/menustrings.py:600 ../gui/wxpython/menustrings.py:1265
+#: ../gui/wxpython/menustrings.py:590
msgid ""
"Selects vector features from an existing vector map and creates a new vector "
"map containing only the selected features."
msgstr ""
-#: ../gui/wxpython/menustrings.py:601 ../gui/wxpython/menustrings.py:1266
+#: ../gui/wxpython/menustrings.py:591
msgid "Select by another map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:602 ../gui/wxpython/menustrings.py:1267
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
+#: ../gui/wxpython/menustrings.py:592
+msgid "Selects features from vector map (A) by features from other vector map (B)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:612 ../gui/wxpython/menustrings.py:1277
+#: ../gui/wxpython/menustrings.py:602
msgid "Buffer vectors"
msgstr ""
-#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:1278
+#: ../gui/wxpython/menustrings.py:603
msgid "Creates a buffer around vector features of given type."
msgstr ""
-#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:1279
+#: ../gui/wxpython/menustrings.py:604
msgid "Lidar analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:1280
-msgid "Identify and remove outliers"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:713
-#: ../gui/wxpython/menustrings.py:1281 ../gui/wxpython/menustrings.py:1378
-msgid "Removes outliers from vector point data."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1282
+#: ../gui/wxpython/menustrings.py:605
msgid "Detect edges"
msgstr ""
-#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1283
+#: ../gui/wxpython/menustrings.py:606
msgid "Detects the object's edges from a LIDAR data set."
msgstr ""
-#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1284
+#: ../gui/wxpython/menustrings.py:607
msgid "Detect interiors"
msgstr ""
-#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1285
+#: ../gui/wxpython/menustrings.py:608
msgid ""
"Building contour determination and Region Growing algorithm for determining "
"the building inside"
msgstr ""
-#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:1286
+#: ../gui/wxpython/menustrings.py:609
msgid "Correct and reclassify objects"
msgstr ""
-#: ../gui/wxpython/menustrings.py:622 ../gui/wxpython/menustrings.py:1287
+#: ../gui/wxpython/menustrings.py:610
msgid ""
"Correction of the v.lidar.growing output. It is the last of the three "
"algorithms for LIDAR filtering."
msgstr ""
-#: ../gui/wxpython/menustrings.py:623 ../gui/wxpython/menustrings.py:1288
+#: ../gui/wxpython/menustrings.py:611
msgid "Linear referencing"
msgstr ""
-#: ../gui/wxpython/menustrings.py:624 ../gui/wxpython/menustrings.py:1289
+#: ../gui/wxpython/menustrings.py:612
msgid "Create LRS"
msgstr ""
-#: ../gui/wxpython/menustrings.py:625 ../gui/wxpython/menustrings.py:1290
-msgid "Creates a linear reference system."
+#: ../gui/wxpython/menustrings.py:613
+msgid "Create Linear Reference System"
msgstr ""
-#: ../gui/wxpython/menustrings.py:626 ../gui/wxpython/menustrings.py:1291
+#: ../gui/wxpython/menustrings.py:614
msgid "Create stationing"
msgstr ""
-#: ../gui/wxpython/menustrings.py:627 ../gui/wxpython/menustrings.py:1292
-msgid "Creates stationing from input lines, and linear reference system."
+#: ../gui/wxpython/menustrings.py:615
+msgid "Create stationing from input lines, and linear reference system"
msgstr ""
-#: ../gui/wxpython/menustrings.py:628 ../gui/wxpython/menustrings.py:1293
+#: ../gui/wxpython/menustrings.py:616
msgid "Create points/segments"
msgstr ""
-#: ../gui/wxpython/menustrings.py:629 ../gui/wxpython/menustrings.py:1294
+#: ../gui/wxpython/menustrings.py:617
msgid ""
"Creates points/segments from input lines, linear reference system and "
"positions read from stdin or a file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1295
+#: ../gui/wxpython/menustrings.py:618
msgid "Find line id and offset"
msgstr ""
-#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:1296
+#: ../gui/wxpython/menustrings.py:619
msgid ""
"Finds line id and real km+offset for given points in vector map using linear "
"reference system."
msgstr ""
-#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1297
+#: ../gui/wxpython/menustrings.py:620
msgid "Nearest features"
msgstr ""
-#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1298
+#: ../gui/wxpython/menustrings.py:621
msgid ""
"Finds the nearest element in vector map 'to' for elements in vector map "
"'from'."
msgstr ""
-#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:1299
+#: ../gui/wxpython/menustrings.py:622
msgid "Network analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1300
-#: ../gui/wxpython/mapdisp/toolbars.py:51
-msgid "Vector network analysis tool"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1301
-msgid "Tool for interactive vector network analysis."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1302
+#: ../gui/wxpython/menustrings.py:623
msgid "Network preparation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1303
+#: ../gui/wxpython/menustrings.py:624
msgid "Performs network maintenance."
msgstr ""
-#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1304
+#: ../gui/wxpython/menustrings.py:625
msgid "Allocate subnets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1305
-msgid ""
-"Allocate subnets for nearest centers (direction from center). center node "
-"must be opened (costs >= 0). Costs of center node are used in calculation"
+#: ../gui/wxpython/menustrings.py:626
+msgid "Allocate subnets for nearest centers (direction from center)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:641 ../gui/wxpython/menustrings.py:1306
+#: ../gui/wxpython/menustrings.py:627
msgid "Split net"
msgstr ""
-#: ../gui/wxpython/menustrings.py:642 ../gui/wxpython/menustrings.py:1307
-msgid ""
-"Splits net by cost isolines. Splits net to bands between cost isolines "
-"(direction from centre). Centre node must be opened (costs >= 0). Costs of "
-"centre node are used in calculation."
+#: ../gui/wxpython/menustrings.py:628
+msgid "Splits net by cost isolines."
msgstr ""
-#: ../gui/wxpython/menustrings.py:643 ../gui/wxpython/menustrings.py:1308
+#: ../gui/wxpython/menustrings.py:629
msgid "Shortest path"
msgstr ""
-#: ../gui/wxpython/menustrings.py:644 ../gui/wxpython/menustrings.py:1309
+#: ../gui/wxpython/menustrings.py:630
msgid "Finds shortest path on vector network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1310
+#: ../gui/wxpython/menustrings.py:631
msgid "Shortest path for sets of features"
msgstr ""
-#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1311
+#: ../gui/wxpython/menustrings.py:632
msgid ""
"Computes shortest distance via the network between the given sets of "
-"features. Finds the shortest paths from each 'from' point to the nearest "
-"'to' feature and various information about this relation are uploaded to the "
-"attribute table."
+"features."
msgstr ""
-#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1312
+#: ../gui/wxpython/menustrings.py:633
msgid "Shortest path using timetables"
msgstr ""
-#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1313
+#: ../gui/wxpython/menustrings.py:634
msgid "Finds shortest path using timetables."
msgstr ""
-#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1314
+#: ../gui/wxpython/menustrings.py:635
msgid "Shortest path for all pairs"
msgstr ""
-#: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/menustrings.py:1315
+#: ../gui/wxpython/menustrings.py:636
msgid "Computes the shortest path between all pairs of nodes in the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1316
+#: ../gui/wxpython/menustrings.py:637
msgid "Visibility network"
msgstr ""
-#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1317
-msgid "Performs visibility graph construction."
+#: ../gui/wxpython/menustrings.py:638
+msgid "Visibility graph construction."
msgstr ""
-#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1318
+#: ../gui/wxpython/menustrings.py:639
msgid "Bridges and articulation points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1319
+#: ../gui/wxpython/menustrings.py:640
msgid "Computes bridges and articulation points in the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1320
+#: ../gui/wxpython/menustrings.py:641
msgid "Maximum flow"
msgstr ""
-#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:1321
+#: ../gui/wxpython/menustrings.py:642
msgid "Computes the maximum flow between two sets of nodes in the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:657 ../gui/wxpython/menustrings.py:1322
+#: ../gui/wxpython/menustrings.py:643
msgid "Vertex connectivity"
msgstr ""
-#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:1323
+#: ../gui/wxpython/menustrings.py:644
msgid "Computes vertex connectivity between two sets of nodes in the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:659 ../gui/wxpython/menustrings.py:1324
+#: ../gui/wxpython/menustrings.py:645
msgid "Components"
msgstr ""
-#: ../gui/wxpython/menustrings.py:660 ../gui/wxpython/menustrings.py:1325
+#: ../gui/wxpython/menustrings.py:646
msgid "Computes strongly and weakly connected components in the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:661 ../gui/wxpython/menustrings.py:1326
+#: ../gui/wxpython/menustrings.py:647
msgid "Centrality"
msgstr ""
-#: ../gui/wxpython/menustrings.py:662 ../gui/wxpython/menustrings.py:1327
+#: ../gui/wxpython/menustrings.py:648
msgid ""
"Computes degree, centrality, betweeness, closeness and eigenvector "
"centrality measures in the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1328
+#: ../gui/wxpython/menustrings.py:649
msgid "Steiner tree"
msgstr ""
-#: ../gui/wxpython/menustrings.py:664 ../gui/wxpython/menustrings.py:1329
-msgid ""
-"Creates Steiner tree for the network and given terminals. Note that 'Minimum "
-"Steiner Tree' problem is NP-hard and heuristic algorithm is used in this "
-"module so the result may be sub optimal."
+#: ../gui/wxpython/menustrings.py:650
+msgid "Create Steiner tree for the network and given terminals"
msgstr ""
-#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1330
+#: ../gui/wxpython/menustrings.py:651
msgid "Minimum spanning tree"
msgstr ""
-#: ../gui/wxpython/menustrings.py:666 ../gui/wxpython/menustrings.py:1331
+#: ../gui/wxpython/menustrings.py:652
msgid "Computes minimum spanning tree for the network."
msgstr ""
-#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1332
+#: ../gui/wxpython/menustrings.py:653
msgid "Traveling salesman analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1333
-msgid ""
-"Creates a cycle connecting given nodes (Traveling salesman problem). Note "
-"that TSP is NP-hard, heuristic algorithm is used by this module and created "
-"cycle may be sub optimal"
+#: ../gui/wxpython/menustrings.py:654
+msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:669 ../gui/wxpython/menustrings.py:670
-#: ../gui/wxpython/menustrings.py:1334 ../gui/wxpython/menustrings.py:1335
+#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:656
msgid "Overlay vector maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:671 ../gui/wxpython/menustrings.py:1336
+#: ../gui/wxpython/menustrings.py:657
msgid "Overlays two vector maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1337
+#: ../gui/wxpython/menustrings.py:658
msgid "Patch vector maps"
msgstr ""
-#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1338
+#: ../gui/wxpython/menustrings.py:659
msgid "Creates a new vector map by combining other vector maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1339
+#: ../gui/wxpython/menustrings.py:660
msgid "Manage categories"
msgstr ""
-#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1340
+#: ../gui/wxpython/menustrings.py:661
msgid "Change or report categories"
msgstr ""
-#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1341
+#: ../gui/wxpython/menustrings.py:662
msgid "Attaches, deletes or reports vector categories to map geometry."
msgstr ""
-#: ../gui/wxpython/menustrings.py:678 ../gui/wxpython/menustrings.py:1343
+#: ../gui/wxpython/menustrings.py:664
msgid ""
"Changes vector category values for an existing vector map according to "
"results of SQL queries or a value in attribute table column."
msgstr ""
-#: ../gui/wxpython/menustrings.py:680 ../gui/wxpython/menustrings.py:1345
+#: ../gui/wxpython/menustrings.py:665
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:111
+#: ../gui/wxpython/dbmgr/dialogs.py:112
+msgid "Update attributes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:666
msgid "Update area attributes from raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1346
+#: ../gui/wxpython/menustrings.py:667
msgid ""
"Calculates univariate statistics from a raster map based on vector polygon "
"map and uploads statistics to new attribute columns."
msgstr ""
-#: ../gui/wxpython/menustrings.py:682 ../gui/wxpython/menustrings.py:1347
+#: ../gui/wxpython/menustrings.py:668
msgid "Update area attributes from vector"
msgstr ""
-#: ../gui/wxpython/menustrings.py:683 ../gui/wxpython/menustrings.py:1348
+#: ../gui/wxpython/menustrings.py:669
msgid "Count points in areas, calculate statistics from point attributes."
msgstr ""
-#: ../gui/wxpython/menustrings.py:684 ../gui/wxpython/menustrings.py:1349
+#: ../gui/wxpython/menustrings.py:670
msgid "Update point attributes from areas"
msgstr ""
-#: ../gui/wxpython/menustrings.py:685 ../gui/wxpython/menustrings.py:1350
+#: ../gui/wxpython/menustrings.py:671
msgid "Uploads vector values at positions of vector points to the table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:686 ../gui/wxpython/menustrings.py:1351
+#: ../gui/wxpython/menustrings.py:672
msgid "Update database values from vector"
msgstr ""
-#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:1352
-msgid "Populates attribute values from vector features."
+#: ../gui/wxpython/menustrings.py:673
+msgid "Populates database values from vector features."
msgstr ""
-#: ../gui/wxpython/menustrings.py:688 ../gui/wxpython/menustrings.py:1353
+#: ../gui/wxpython/menustrings.py:674
msgid "Sample raster maps at point locations"
msgstr ""
-#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1354
+#: ../gui/wxpython/menustrings.py:675
msgid "Uploads raster values at positions of vector points to the table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:690 ../gui/wxpython/menustrings.py:1355
+#: ../gui/wxpython/menustrings.py:676
msgid "Sample raster neighborhood around points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:691 ../gui/wxpython/menustrings.py:1356
+#: ../gui/wxpython/menustrings.py:677
msgid "Samples a raster map at vector point locations."
msgstr ""
-#: ../gui/wxpython/menustrings.py:692 ../gui/wxpython/menustrings.py:1357
+#: ../gui/wxpython/menustrings.py:678
msgid "Generate area for current region"
msgstr ""
-#: ../gui/wxpython/menustrings.py:693 ../gui/wxpython/menustrings.py:1358
+#: ../gui/wxpython/menustrings.py:679
msgid "Creates a vector polygon from the current region extent."
msgstr ""
-#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1359
+#: ../gui/wxpython/menustrings.py:680
msgid "Generate areas from points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:695 ../gui/wxpython/menustrings.py:1360
+#: ../gui/wxpython/menustrings.py:681
msgid "Convex hull"
msgstr ""
-#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1361
-msgid "Produces a 2D/3D convex hull for a given vector map."
+#: ../gui/wxpython/menustrings.py:682
+msgid "Produces a convex hull for a given vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:697 ../gui/wxpython/menustrings.py:1362
+#: ../gui/wxpython/menustrings.py:683
msgid "Delaunay triangles"
msgstr ""
-#: ../gui/wxpython/menustrings.py:698 ../gui/wxpython/menustrings.py:1363
+#: ../gui/wxpython/menustrings.py:684
msgid ""
"Creates a Delaunay triangulation from an input vector map containing points "
"or centroids."
msgstr ""
-#: ../gui/wxpython/menustrings.py:699 ../gui/wxpython/menustrings.py:1364
+#: ../gui/wxpython/menustrings.py:685
msgid "Voronoi diagram/Thiessen polygons"
msgstr ""
-#: ../gui/wxpython/menustrings.py:700 ../gui/wxpython/menustrings.py:1365
+#: ../gui/wxpython/menustrings.py:686
msgid ""
"Creates a Voronoi diagram in current region from an input vector map "
"containing points or centroids."
msgstr ""
-#: ../gui/wxpython/menustrings.py:701 ../gui/wxpython/menustrings.py:1366
+#: ../gui/wxpython/menustrings.py:687
msgid "Generate grid"
msgstr ""
-#: ../gui/wxpython/menustrings.py:702 ../gui/wxpython/menustrings.py:1367
+#: ../gui/wxpython/menustrings.py:688
msgid "Creates a vector map of a user-defined grid."
msgstr ""
-#: ../gui/wxpython/menustrings.py:703 ../gui/wxpython/menustrings.py:1368
+#: ../gui/wxpython/menustrings.py:689
msgid "Generate points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:704 ../gui/wxpython/menustrings.py:1369
+#: ../gui/wxpython/menustrings.py:690
msgid "Generate from database"
msgstr ""
-#: ../gui/wxpython/menustrings.py:705 ../gui/wxpython/menustrings.py:1370
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
+#: ../gui/wxpython/menustrings.py:691
+msgid "Creates new vector (points) map from database table containing coordinates."
msgstr ""
-#: ../gui/wxpython/menustrings.py:706 ../gui/wxpython/menustrings.py:1371
+#: ../gui/wxpython/menustrings.py:692
msgid "Generate points along lines"
msgstr ""
-#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1372
+#: ../gui/wxpython/menustrings.py:693
msgid "Creates points along input lines in new vector map with 2 layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:708 ../gui/wxpython/menustrings.py:1373
+#: ../gui/wxpython/menustrings.py:694
msgid "Generate random points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:709 ../gui/wxpython/menustrings.py:1374
+#: ../gui/wxpython/menustrings.py:695
msgid "Generates randomly 2D/3D vector points map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1375
+#: ../gui/wxpython/menustrings.py:696
msgid "Perturb points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1376
+#: ../gui/wxpython/menustrings.py:697
msgid "Random location perturbations of vector points."
msgstr ""
-#: ../gui/wxpython/menustrings.py:712 ../gui/wxpython/menustrings.py:1377
+#: ../gui/wxpython/menustrings.py:698
msgid "Remove outliers in point sets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:714 ../gui/wxpython/menustrings.py:1379
+#: ../gui/wxpython/menustrings.py:699
+msgid "Removes outliers from vector point data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:700
msgid "Test/training point sets"
msgstr ""
-#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1380
+#: ../gui/wxpython/menustrings.py:701
msgid "Randomly partition points into test/train sets."
msgstr ""
-#: ../gui/wxpython/menustrings.py:717 ../gui/wxpython/menustrings.py:1382
+#: ../gui/wxpython/menustrings.py:702
+msgid "Reports and statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:703
msgid "Basic vector metadata"
msgstr ""
-#: ../gui/wxpython/menustrings.py:718 ../gui/wxpython/menustrings.py:1383
+#: ../gui/wxpython/menustrings.py:704
msgid "Outputs basic information about a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:719 ../gui/wxpython/menustrings.py:1384
+#: ../gui/wxpython/menustrings.py:705
msgid "Classify attribute data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1385
+#: ../gui/wxpython/menustrings.py:706
msgid "Classifies attribute data, e.g. for thematic mapping"
msgstr ""
-#: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1386
+#: ../gui/wxpython/menustrings.py:707
msgid "Report topology by category"
msgstr ""
-#: ../gui/wxpython/menustrings.py:722 ../gui/wxpython/menustrings.py:1387
+#: ../gui/wxpython/menustrings.py:708
msgid "Reports geometry statistics for vector maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:723 ../gui/wxpython/menustrings.py:1388
+#: ../gui/wxpython/menustrings.py:709
msgid "Univariate attribute statistics for points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:1389
-msgid ""
-"Calculates univariate statistics for attribute. Variance and standard "
-"deviation is calculated only for points if specified."
+#: ../gui/wxpython/menustrings.py:710
+msgid "Calculates univariate statistics for attribute."
msgstr ""
-#: ../gui/wxpython/menustrings.py:725 ../gui/wxpython/menustrings.py:1390
+#: ../gui/wxpython/menustrings.py:711
msgid "Univariate statistics for attribute columns"
msgstr ""
-#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1391
+#: ../gui/wxpython/menustrings.py:712
msgid ""
"Calculates univariate statistics on selected table column for a GRASS vector "
"map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1392
+#: ../gui/wxpython/menustrings.py:713
msgid "Quadrat indices"
msgstr ""
-#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1393
+#: ../gui/wxpython/menustrings.py:714
msgid "Indices for quadrat counts of sites lists."
msgstr ""
-#: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:1394
+#: ../gui/wxpython/menustrings.py:715
msgid "Test normality"
msgstr ""
-#: ../gui/wxpython/menustrings.py:730 ../gui/wxpython/menustrings.py:1395
+#: ../gui/wxpython/menustrings.py:716
msgid "Tests for normality for vector points."
msgstr ""
-#: ../gui/wxpython/menustrings.py:731 ../gui/wxpython/menustrings.py:1396
+#: ../gui/wxpython/menustrings.py:717
msgid "&Imagery"
msgstr ""
-#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1397
+#: ../gui/wxpython/menustrings.py:718
msgid "Develop images and groups"
msgstr ""
-#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1398
+#: ../gui/wxpython/menustrings.py:719
msgid "Create/edit group"
msgstr ""
-#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/menustrings.py:1399
+#: ../gui/wxpython/menustrings.py:720
msgid "Creates, edits, and lists groups of imagery files."
msgstr ""
-#: ../gui/wxpython/menustrings.py:735 ../gui/wxpython/menustrings.py:1400
+#: ../gui/wxpython/menustrings.py:721
msgid "Target group"
msgstr ""
-#: ../gui/wxpython/menustrings.py:736 ../gui/wxpython/menustrings.py:1401
+#: ../gui/wxpython/menustrings.py:722
msgid "Targets an imagery group to a GRASS location and mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1402
+#: ../gui/wxpython/menustrings.py:723
msgid "Mosaic images"
msgstr ""
-#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1403
+#: ../gui/wxpython/menustrings.py:724
msgid "Mosaics several images and extends colormap."
msgstr ""
-#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1404
+#: ../gui/wxpython/menustrings.py:725
msgid "Manage image colors"
msgstr ""
-#: ../gui/wxpython/menustrings.py:740 ../gui/wxpython/menustrings.py:1405
+#: ../gui/wxpython/menustrings.py:726
msgid "Color balance for RGB"
msgstr ""
-#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1406
+#: ../gui/wxpython/menustrings.py:727
msgid "Performs auto-balancing of colors for LANDSAT images."
msgstr ""
-#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1407
+#: ../gui/wxpython/menustrings.py:728
msgid "HIS to RGB"
msgstr ""
-#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1408
+#: ../gui/wxpython/menustrings.py:729
msgid ""
"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
"RGB (Red-Green-Blue) color space."
msgstr ""
-#: ../gui/wxpython/menustrings.py:745 ../gui/wxpython/menustrings.py:1410
+#: ../gui/wxpython/menustrings.py:731
msgid ""
"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
"Intensity-Saturation) color space."
msgstr ""
-#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1411
+#: ../gui/wxpython/menustrings.py:732
msgid "Rectify image or raster"
msgstr ""
-#: ../gui/wxpython/menustrings.py:747 ../gui/wxpython/menustrings.py:1412
+#: ../gui/wxpython/menustrings.py:733
msgid ""
"Rectifies an image by computing a coordinate transformation for each pixel "
"in the image based on the control points."
msgstr ""
-#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1414
+#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/lmgr/layertree.py:444
+#: ../gui/wxpython/gui_modules/layertree.py:410
+msgid "Histogram"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:735
msgid "Generate histogram of image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1415
+#: ../gui/wxpython/menustrings.py:736
msgid "Spectral response"
msgstr ""
-#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1416
-msgid ""
-"Displays spectral response at user specified locations in group or images."
+#: ../gui/wxpython/menustrings.py:737
+msgid "Displays spectral response at user specified locations in group or images."
msgstr ""
-#: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1417
+#: ../gui/wxpython/menustrings.py:738
msgid "Pan sharpening"
msgstr ""
-#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1418
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
+#: ../gui/wxpython/menustrings.py:739
+msgid "Sharpen image by merging multispectral and high-res panchromatic channels"
msgstr ""
-#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1419
+#: ../gui/wxpython/menustrings.py:740
msgid "Classify image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1420
+#: ../gui/wxpython/menustrings.py:741
msgid "Clustering input for unsupervised classification"
msgstr ""
-#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1421
+#: ../gui/wxpython/menustrings.py:742
msgid ""
"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm. The resulting signature file is used as input for i."
-"maxlik, to generate an unsupervised image classification."
+"clustering algorithm."
msgstr ""
-#: ../gui/wxpython/menustrings.py:757 ../gui/wxpython/menustrings.py:1422
+#: ../gui/wxpython/menustrings.py:743
msgid "Input for supervised MLC"
msgstr ""
-#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1423
+#: ../gui/wxpython/menustrings.py:744
msgid "Generates statistics for i.maxlik from raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1424
+#: ../gui/wxpython/menustrings.py:745
msgid "Maximum likelihood classification (MLC)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1425
-msgid ""
-"Classifies the cell spectral reflectances in imagery data. Classification is "
-"based on the spectral signature information generated by either i.cluster, i."
-"class, or i.gensig."
+#: ../gui/wxpython/menustrings.py:746
+msgid "Classifies the cell spectral reflectances in imagery data."
msgstr ""
-#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1426
+#: ../gui/wxpython/menustrings.py:747
msgid "Interactive input for supervised classification"
msgstr ""
-#: ../gui/wxpython/menustrings.py:762 ../gui/wxpython/menustrings.py:1427
-msgid ""
-"Generates spectral signatures by allowing the user to outline training areas."
+#: ../gui/wxpython/menustrings.py:748
+msgid "Generates spectral signatures by allowing the user to outline training areas."
msgstr ""
-#: ../gui/wxpython/menustrings.py:763 ../gui/wxpython/menustrings.py:1428
+#: ../gui/wxpython/menustrings.py:749
msgid "Input for supervised SMAP"
msgstr ""
-#: ../gui/wxpython/menustrings.py:764 ../gui/wxpython/menustrings.py:1429
+#: ../gui/wxpython/menustrings.py:750
msgid "Generates statistics for i.smap from raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1430
+#: ../gui/wxpython/menustrings.py:751
msgid "Sequential maximum a posteriori classification (SMAP)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:766 ../gui/wxpython/menustrings.py:1431
+#: ../gui/wxpython/menustrings.py:752
msgid ""
"Performs contextual image classification using sequential maximum a "
"posteriori (SMAP) estimation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:767 ../gui/wxpython/menustrings.py:1432
-#, fuzzy
-msgid "Object segmentation"
-msgstr "Orientācija"
-#: ../gui/wxpython/menustrings.py:768 ../gui/wxpython/menustrings.py:1433
-msgid "Identifies segments (objects) from imagery data."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:769 ../gui/wxpython/menustrings.py:1434
+#: ../gui/wxpython/menustrings.py:753
msgid "Filter image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:770 ../gui/wxpython/menustrings.py:1435
+#: ../gui/wxpython/menustrings.py:754
msgid "Edge detection"
msgstr ""
-#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1436
+#: ../gui/wxpython/menustrings.py:755
msgid "Zero-crossing \"edge detection\" raster function for image processing."
msgstr ""
-#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1437
+#: ../gui/wxpython/menustrings.py:756
msgid "Matrix/convolving filter"
msgstr ""
-#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1438
+#: ../gui/wxpython/menustrings.py:757
msgid "Performs raster map matrix filter."
msgstr ""
-#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1439
+#: ../gui/wxpython/menustrings.py:758
msgid "Transform image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1440
+#: ../gui/wxpython/menustrings.py:759
msgid "Canonical correlation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1441
-msgid "Canonical components analysis (CCA) program for image processing."
+#: ../gui/wxpython/menustrings.py:760
+msgid "Canonical components analysis (cca) program for image processing."
msgstr ""
-#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1442
+#: ../gui/wxpython/menustrings.py:761
msgid "Principal components"
msgstr ""
-#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1443
+#: ../gui/wxpython/menustrings.py:762
msgid "Principal components analysis (PCA) for image processing."
msgstr ""
-#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1444
+#: ../gui/wxpython/menustrings.py:763
msgid "Fast Fourier"
msgstr ""
-#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1445
+#: ../gui/wxpython/menustrings.py:764
msgid "Fast Fourier Transform (FFT) for image processing."
msgstr ""
-#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1446
+#: ../gui/wxpython/menustrings.py:765
msgid "Inverse Fast Fourier"
msgstr ""
-#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1447
+#: ../gui/wxpython/menustrings.py:766
msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
msgstr ""
-#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1448
+#: ../gui/wxpython/menustrings.py:767
msgid "Satellite images tools"
msgstr ""
-#: ../gui/wxpython/menustrings.py:784 ../gui/wxpython/menustrings.py:1449
+#: ../gui/wxpython/menustrings.py:768
msgid "Aster DN to radiance/reflectance"
msgstr ""
-#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1450
+#: ../gui/wxpython/menustrings.py:769
msgid ""
"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
"from ASTER DN."
msgstr ""
-#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1451
+#: ../gui/wxpython/menustrings.py:770
msgid "Landsat DN to radiance/reflectance"
msgstr ""
-#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1452
+#: ../gui/wxpython/menustrings.py:771
msgid ""
"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
+"Landsat MSS/TM/ETM+."
msgstr ""
-#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1453
+#: ../gui/wxpython/menustrings.py:772
msgid "Landsat cloud cover assessment"
msgstr ""
-#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1454
+#: ../gui/wxpython/menustrings.py:773
msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1455
+#: ../gui/wxpython/menustrings.py:774
msgid "Modis quality control"
msgstr ""
-#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1456
+#: ../gui/wxpython/menustrings.py:775
msgid "Extracts quality control parameters from Modis QC layers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1457
+#: ../gui/wxpython/menustrings.py:776
msgid "Atmospheric correction"
msgstr ""
-#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1458
-msgid ""
-"Performs atmospheric correction using the 6S algorithm. 6S - Second "
-"Simulation of Satellite Signal in the Solar Spectrum."
+#: ../gui/wxpython/menustrings.py:777
+msgid "Performs atmospheric correction using the 6S algorithm."
msgstr ""
-#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1459
+#: ../gui/wxpython/menustrings.py:778
+msgid "LatLong map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:779
+msgid "Creates a latitude/longitude map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:780
+msgid "Sunshine hours"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:781
+msgid "Creates a sunshine hours map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:782
msgid "Satellite images products"
msgstr ""
-#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1460
+#: ../gui/wxpython/menustrings.py:783
msgid "Vegetation indices"
msgstr ""
-#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1461
-msgid ""
-"Calculates different types of vegetation indices. Uses red and nir bands "
-"mostly, and some indices require additional bands."
+#: ../gui/wxpython/menustrings.py:784
+msgid "Calculates different types of vegetation indices."
msgstr ""
-#: ../gui/wxpython/menustrings.py:797 ../gui/wxpython/menustrings.py:1462
+#: ../gui/wxpython/menustrings.py:785
msgid "Tasseled cap vegetation index"
msgstr ""
-#: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1463
-msgid ""
-"Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
+#: ../gui/wxpython/menustrings.py:786
+msgid "Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
msgstr ""
-#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1464
+#: ../gui/wxpython/menustrings.py:787
msgid "Albedo"
msgstr ""
-#: ../gui/wxpython/menustrings.py:800 ../gui/wxpython/menustrings.py:1465
+#: ../gui/wxpython/menustrings.py:788
msgid "Computes broad band albedo from surface reflectance."
msgstr ""
-#: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1466
+#: ../gui/wxpython/menustrings.py:789
msgid "Emissivity"
msgstr ""
-#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1467
-msgid "Computes emissivity from NDVI, generic method for sparse land."
+#: ../gui/wxpython/menustrings.py:790
+msgid "Computes emissivity from NDVI, generic method for spares land."
msgstr ""
-#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1468
+#: ../gui/wxpython/menustrings.py:791
msgid "Biomass growth"
msgstr ""
-#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1469
+#: ../gui/wxpython/menustrings.py:792
msgid "Computes biomass growth, precursor of crop yield calculation."
msgstr ""
-#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1470
+#: ../gui/wxpython/menustrings.py:793
msgid "Evapotranspiration calculation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1471
+#: ../gui/wxpython/menustrings.py:794
msgid "Instantaneaous Net Radiation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1472
+#: ../gui/wxpython/menustrings.py:795
msgid "Net radiation approximation (Bastiaanssen, 1995)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1473
+#: ../gui/wxpython/menustrings.py:796
msgid "Soil heat flux"
msgstr ""
-#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1474
+#: ../gui/wxpython/menustrings.py:797
msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1475
+#: ../gui/wxpython/menustrings.py:798
msgid "Sensible heat flux"
msgstr ""
-#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1476
+#: ../gui/wxpython/menustrings.py:799
msgid "Computes sensible heat flux iteration SEBAL 01."
msgstr ""
-#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1477
+#: ../gui/wxpython/menustrings.py:800
msgid "Evaporative fraction"
msgstr ""
-#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:1478
+#: ../gui/wxpython/menustrings.py:801
msgid ""
"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
"moisture (Makin, Molden and Bastiaanssen, 2001)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1479
+#: ../gui/wxpython/menustrings.py:802
msgid "Actual Evapotranspiration"
msgstr ""
-#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1480
+#: ../gui/wxpython/menustrings.py:803
msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1481
+#: ../gui/wxpython/menustrings.py:804
msgid "Temporal integration of ETa"
msgstr ""
-#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1482
+#: ../gui/wxpython/menustrings.py:805
msgid ""
"Computes temporal integration of satellite ET actual (ETa) following the "
"daily ET reference (ETo) from meteorological station(s)."
msgstr ""
-#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:1483
+#: ../gui/wxpython/menustrings.py:806
msgid "Hargreaves methods Evapotranspiration"
msgstr ""
-#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1484
+#: ../gui/wxpython/menustrings.py:807
msgid ""
"Computes evapotranspiration calculation modified or original Hargreaves "
"formulation, 2001."
msgstr ""
-#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1485
+#: ../gui/wxpython/menustrings.py:808
msgid "Penman-Monteith Evapotranspiration"
msgstr ""
-#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/menustrings.py:1486
+#: ../gui/wxpython/menustrings.py:809
msgid ""
"Computes potential evapotranspiration calculation with hourly Penman-"
"Monteith."
msgstr ""
-#: ../gui/wxpython/menustrings.py:822 ../gui/wxpython/menustrings.py:1487
+#: ../gui/wxpython/menustrings.py:810
msgid "Priestley-Taylor Evapotranspiration"
msgstr ""
-#: ../gui/wxpython/menustrings.py:823 ../gui/wxpython/menustrings.py:1488
+#: ../gui/wxpython/menustrings.py:811
msgid ""
"Computes evapotranspiration calculation Prestley and Taylor formulation, "
"1972."
msgstr ""
-#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:1490
+#: ../gui/wxpython/menustrings.py:813
msgid "Bit pattern comparison "
msgstr ""
-#: ../gui/wxpython/menustrings.py:826 ../gui/wxpython/menustrings.py:1491
+#: ../gui/wxpython/menustrings.py:814
msgid "Compares bit patterns with a raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:827 ../gui/wxpython/menustrings.py:1492
+#: ../gui/wxpython/menustrings.py:815
msgid "Kappa analysis"
msgstr ""
-#: ../gui/wxpython/menustrings.py:828 ../gui/wxpython/menustrings.py:1493
+#: ../gui/wxpython/menustrings.py:816
msgid ""
-"Calculates error matrix and kappa parameter for accuracy assessment of "
+"Calculate error matrix and kappa parameter for accuracy assessment of "
"classification result."
msgstr ""
-#: ../gui/wxpython/menustrings.py:829 ../gui/wxpython/menustrings.py:1494
+#: ../gui/wxpython/menustrings.py:817
msgid "OIF for LandSat TM"
msgstr ""
-#: ../gui/wxpython/menustrings.py:830 ../gui/wxpython/menustrings.py:1495
+#: ../gui/wxpython/menustrings.py:818
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
msgstr ""
-#: ../gui/wxpython/menustrings.py:831 ../gui/wxpython/menustrings.py:1496
+#: ../gui/wxpython/menustrings.py:819
msgid "V&olumes"
msgstr "&Tilpumi"
-#: ../gui/wxpython/menustrings.py:832 ../gui/wxpython/menustrings.py:1497
+#: ../gui/wxpython/menustrings.py:820
msgid "Develop volumes"
msgstr ""
-#: ../gui/wxpython/menustrings.py:833 ../gui/wxpython/menustrings.py:1498
+#: ../gui/wxpython/menustrings.py:821
msgid "Manage 3D NULL values"
msgstr ""
-#: ../gui/wxpython/menustrings.py:834 ../gui/wxpython/menustrings.py:1499
+#: ../gui/wxpython/menustrings.py:822
msgid "Explicitly create the 3D NULL-value bitmap file."
msgstr ""
-#: ../gui/wxpython/menustrings.py:835 ../gui/wxpython/menustrings.py:1500
+#: ../gui/wxpython/menustrings.py:823
msgid "Manage timestamp"
msgstr ""
-#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1501
+#: ../gui/wxpython/menustrings.py:824
msgid "Print/add/remove a timestamp for a 3D raster map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1505
+#: ../gui/wxpython/menustrings.py:828
msgid "3D color tables"
msgstr ""
-#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1506
+#: ../gui/wxpython/menustrings.py:829
msgid "Creates/modifies the color table associated with a 3D raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1507
+#: ../gui/wxpython/menustrings.py:830
msgid "Export 3D color table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1508
+#: ../gui/wxpython/menustrings.py:831
msgid "Exports the color table associated with a 3D raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:844 ../gui/wxpython/menustrings.py:1509
+#: ../gui/wxpython/menustrings.py:832
msgid "3D Mask"
msgstr "3D maska"
-#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:1510
+#: ../gui/wxpython/menustrings.py:833
msgid "Establishes the current working 3D raster mask."
msgstr ""
-#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:1511
+#: ../gui/wxpython/menustrings.py:834
msgid "Volume calculator"
msgstr ""
-#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1512
+#: ../gui/wxpython/menustrings.py:835
msgid "3D raster map calculator."
msgstr ""
-#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1513
+#: ../gui/wxpython/menustrings.py:836
msgid "Cross section"
msgstr ""
-#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1514
+#: ../gui/wxpython/menustrings.py:837
msgid ""
"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
"map"
msgstr ""
-#: ../gui/wxpython/menustrings.py:851 ../gui/wxpython/menustrings.py:1516
+#: ../gui/wxpython/menustrings.py:839
msgid ""
"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
+"three dimensions"
msgstr ""
-#: ../gui/wxpython/menustrings.py:852 ../gui/wxpython/menustrings.py:1517
+#: ../gui/wxpython/menustrings.py:840
msgid "Interpolate volume from points"
msgstr ""
-#: ../gui/wxpython/menustrings.py:853 ../gui/wxpython/menustrings.py:1518
+#: ../gui/wxpython/menustrings.py:841
msgid ""
"Interpolates point data to a 3D raster map using regularized spline with "
"tension (RST) algorithm."
msgstr ""
-#: ../gui/wxpython/menustrings.py:854 ../gui/wxpython/menustrings.py:1519
+#: ../gui/wxpython/menustrings.py:842
#, fuzzy
-msgid "Reports and Statistics"
+msgid "Report and Statistics"
-#: ../gui/wxpython/menustrings.py:855 ../gui/wxpython/menustrings.py:1520
+#: ../gui/wxpython/menustrings.py:843
msgid "Basic volume metadata"
msgstr ""
-#: ../gui/wxpython/menustrings.py:856 ../gui/wxpython/menustrings.py:1521
+#: ../gui/wxpython/menustrings.py:844
msgid "Outputs basic information about a user-specified 3D raster map layer."
msgstr ""
-#: ../gui/wxpython/menustrings.py:857 ../gui/wxpython/menustrings.py:1522
+#: ../gui/wxpython/menustrings.py:845
msgid "Voxel statistics"
msgstr ""
-#: ../gui/wxpython/menustrings.py:858 ../gui/wxpython/menustrings.py:1523
+#: ../gui/wxpython/menustrings.py:846
msgid "Generates volume statistics for 3D raster maps."
msgstr ""
-#: ../gui/wxpython/menustrings.py:859 ../gui/wxpython/menustrings.py:1524
+#: ../gui/wxpython/menustrings.py:847
msgid "Univariate statistics for volumes"
msgstr ""
-#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/menustrings.py:1525
+#: ../gui/wxpython/menustrings.py:848
msgid ""
"Calculates univariate statistics from the non-null 3d cells of a raster3d "
"map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:861 ../gui/wxpython/menustrings.py:1526
+#: ../gui/wxpython/menustrings.py:849
msgid "&Database"
msgstr ""
-#: ../gui/wxpython/menustrings.py:862 ../gui/wxpython/menustrings.py:1527
+#: ../gui/wxpython/menustrings.py:850
msgid "Database information"
msgstr ""
-#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1528
+#: ../gui/wxpython/menustrings.py:851
msgid "List databases"
msgstr ""
-#: ../gui/wxpython/menustrings.py:864 ../gui/wxpython/menustrings.py:1529
-msgid "Lists all databases for a given driver and location."
+#: ../gui/wxpython/menustrings.py:852
+msgid "List all databases for a given driver and location."
msgstr ""
-#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1530
+#: ../gui/wxpython/menustrings.py:853
msgid "List drivers"
msgstr ""
-#: ../gui/wxpython/menustrings.py:866 ../gui/wxpython/menustrings.py:1531
+#: ../gui/wxpython/menustrings.py:854
msgid "Lists all database drivers."
msgstr ""
-#: ../gui/wxpython/menustrings.py:867 ../gui/wxpython/menustrings.py:1532
+#: ../gui/wxpython/menustrings.py:855
msgid "List tables"
msgstr ""
-#: ../gui/wxpython/menustrings.py:868 ../gui/wxpython/menustrings.py:1533
+#: ../gui/wxpython/menustrings.py:856
msgid "Lists all tables for a given database."
msgstr ""
-#: ../gui/wxpython/menustrings.py:869 ../gui/wxpython/menustrings.py:1534
+#: ../gui/wxpython/menustrings.py:857
msgid "Describe table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:870 ../gui/wxpython/menustrings.py:1535
+#: ../gui/wxpython/menustrings.py:858
msgid "Describes a table in detail."
msgstr ""
-#: ../gui/wxpython/menustrings.py:871 ../gui/wxpython/menustrings.py:1536
+#: ../gui/wxpython/menustrings.py:859
msgid "List columns"
msgstr ""
-#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1537
+#: ../gui/wxpython/menustrings.py:860
msgid "List all columns for a given table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:1538
+#: ../gui/wxpython/menustrings.py:861
msgid "Manage databases"
msgstr ""
-#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:1539
+#: ../gui/wxpython/menustrings.py:862
msgid "Connect"
msgstr "Pieslēgties"
-#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:1540
+#: ../gui/wxpython/menustrings.py:863
msgid "Prints/sets general DB connection for current mapset."
msgstr ""
-#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1541
+#: ../gui/wxpython/menustrings.py:864
msgid "Login"
msgstr ""
-#: ../gui/wxpython/menustrings.py:877 ../gui/wxpython/menustrings.py:1542
+#: ../gui/wxpython/menustrings.py:865
msgid "Sets user/password for DB driver/database."
msgstr ""
-#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:1543
+#: ../gui/wxpython/menustrings.py:866
msgid "Create database"
msgstr ""
-#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1544
+#: ../gui/wxpython/menustrings.py:867
msgid "Creates an empty database."
msgstr ""
-#: ../gui/wxpython/menustrings.py:880 ../gui/wxpython/menustrings.py:1545
+#: ../gui/wxpython/menustrings.py:868
msgid "Drop database"
msgstr ""
-#: ../gui/wxpython/menustrings.py:881 ../gui/wxpython/menustrings.py:1546
-msgid "Removes an existing database."
+#: ../gui/wxpython/menustrings.py:869
+msgid "Removes a database."
msgstr ""
-#: ../gui/wxpython/menustrings.py:882 ../gui/wxpython/menustrings.py:1547
+#: ../gui/wxpython/menustrings.py:870
msgid "Drop table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1548
+#: ../gui/wxpython/menustrings.py:871
msgid "Drops an attribute table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1549
+#: ../gui/wxpython/menustrings.py:872
msgid "Copy table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:885 ../gui/wxpython/menustrings.py:1550
-msgid ""
-"Copy a table. Either 'from_table' (optionally with 'where') can be used or "
-"'select' option, but not 'from_table' and 'select' at the same time."
-msgstr ""
+#: ../gui/wxpython/menustrings.py:873
+#, fuzzy
+msgid "Copy a table."
+msgstr "Rindas:"
-#: ../gui/wxpython/menustrings.py:886 ../gui/wxpython/menustrings.py:906
-#: ../gui/wxpython/menustrings.py:1551 ../gui/wxpython/menustrings.py:1571
+#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:894
msgid "Drop column"
msgstr ""
-#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:1552
+#: ../gui/wxpython/menustrings.py:875
msgid "Drops a column from selected attribute table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1553
+#: ../gui/wxpython/menustrings.py:876
msgid "Test"
msgstr "Testēt"
-#: ../gui/wxpython/menustrings.py:889 ../gui/wxpython/menustrings.py:1554
+#: ../gui/wxpython/menustrings.py:877
msgid "Test database driver, database must exist and set by db.connect."
msgstr ""
-#: ../gui/wxpython/menustrings.py:891 ../gui/wxpython/menustrings.py:1556
+#: ../gui/wxpython/menustrings.py:878
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:99
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:99
+msgid "Query"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:879
msgid "Query any table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1557
-msgid "Selects data from attribute table. Performs SQL query statement(s)."
+#: ../gui/wxpython/menustrings.py:880
+msgid "Selects data from attribute table (performs SQL query statement(s))."
msgstr ""
-#: ../gui/wxpython/menustrings.py:895 ../gui/wxpython/menustrings.py:1560
+#: ../gui/wxpython/menustrings.py:883
msgid "SQL statement"
msgstr "SQL izteikums"
-#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1561
-msgid "Executes any SQL statement. For SELECT statements use 'db.select'."
-msgstr ""
+#: ../gui/wxpython/menustrings.py:884
+#, fuzzy
+msgid "Executes any SQL statement."
+msgstr "SQL izteikums"
-#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1562
+#: ../gui/wxpython/menustrings.py:885
msgid "Vector database connections"
msgstr ""
-#: ../gui/wxpython/menustrings.py:898 ../gui/wxpython/menustrings.py:1563
+#: ../gui/wxpython/menustrings.py:886
msgid "New table"
msgstr "Jauna tabula"
-#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1564
+#: ../gui/wxpython/menustrings.py:887
msgid ""
"Creates and connects a new attribute table to a given layer of an existing "
"vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:900 ../gui/wxpython/menustrings.py:1565
+#: ../gui/wxpython/menustrings.py:888
msgid "Remove table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1566
+#: ../gui/wxpython/menustrings.py:889
msgid "Removes existing attribute table of a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:1567
+#: ../gui/wxpython/menustrings.py:890
msgid "Join table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1568
-msgid "Joins a database table to a vector map table."
+#: ../gui/wxpython/menustrings.py:891
+msgid "Allows to join a table to a vector map table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:1569
+#: ../gui/wxpython/menustrings.py:892
msgid "Add columns"
msgstr ""
-#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1570
+#: ../gui/wxpython/menustrings.py:893
msgid ""
"Adds one or more columns to the attribute table connected to a given vector "
"map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:907 ../gui/wxpython/menustrings.py:1572
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+#: ../gui/wxpython/menustrings.py:895
+msgid "Drops a column from the attribute table connected to a given vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:909 ../gui/wxpython/menustrings.py:1574
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
+#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/gui_modules/dbm.py:925
+#: ../gui/wxpython/dbmgr/manager.py:924
+msgid "Rename column"
msgstr ""
-#: ../gui/wxpython/menustrings.py:910 ../gui/wxpython/menustrings.py:1575
+#: ../gui/wxpython/menustrings.py:897
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:898
msgid "Change values"
msgstr ""
-#: ../gui/wxpython/menustrings.py:911 ../gui/wxpython/menustrings.py:1576
-msgid "Updates a column in the attribute table connected to a vector map."
+#: ../gui/wxpython/menustrings.py:899
+msgid "Allows to update a column in the attribute table connected to a vector map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:912 ../gui/wxpython/menustrings.py:1577
+#: ../gui/wxpython/menustrings.py:900
msgid "Drop row"
msgstr ""
-#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:1578
+#: ../gui/wxpython/menustrings.py:901
msgid "Removes a vector feature from a vector map through attribute selection."
msgstr ""
-#: ../gui/wxpython/menustrings.py:914 ../gui/wxpython/menustrings.py:1579
+#: ../gui/wxpython/menustrings.py:902
msgid "Reconnect vectors to database"
msgstr ""
-#: ../gui/wxpython/menustrings.py:915 ../gui/wxpython/menustrings.py:1580
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a "
-"new database."
+#: ../gui/wxpython/menustrings.py:903
+msgid "Reconnects vectors to a new database."
msgstr ""
-#: ../gui/wxpython/menustrings.py:916 ../gui/wxpython/menustrings.py:1581
+#: ../gui/wxpython/menustrings.py:904
msgid "Set vector map - database connection"
msgstr ""
-#: ../gui/wxpython/menustrings.py:917 ../gui/wxpython/menustrings.py:1582
+#: ../gui/wxpython/menustrings.py:905
msgid "Prints/sets DB connection for a vector map to attribute table."
msgstr ""
-#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1713
-#: ../gui/wxpython/menustrings.py:1756
+#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:958
msgid "&Help"
msgstr "&Palīdzība"
-#: ../gui/wxpython/menustrings.py:919
+#: ../gui/wxpython/menustrings.py:907
msgid "GRASS help"
msgstr "GRASS palīdzība"
-#: ../gui/wxpython/menustrings.py:920 ../gui/wxpython/menustrings.py:922
+#: ../gui/wxpython/menustrings.py:908 ../gui/wxpython/menustrings.py:910
msgid "Display the HTML man pages of GRASS GIS"
msgstr ""
-#: ../gui/wxpython/menustrings.py:921
+#: ../gui/wxpython/menustrings.py:909
msgid "GUI help"
msgstr ""
-#: ../gui/wxpython/menustrings.py:923
+#: ../gui/wxpython/menustrings.py:911
msgid "About system"
-msgstr ""
+msgstr "Par sistēmu"
-#: ../gui/wxpython/menustrings.py:924
+#: ../gui/wxpython/menustrings.py:912
msgid "Prints system information"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1583
-msgid "Temporal"
-msgstr ""
+#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:914
+#: ../gui/wxpython/gui_modules/ghelp.py:484
+#: ../gui/wxpython/gui_core/ghelp.py:386
+msgid "About GRASS GIS"
+msgstr "Par GRASS GIS"
-#: ../gui/wxpython/menustrings.py:1584
-msgid "Manage datasets"
+#: ../gui/wxpython/menustrings.py:919
+msgid "Create new model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1585 ../gui/wxpython/rlisetup/frame.py:48
-#, fuzzy
-msgid "Create"
-msgstr "Izveidot &karšu kopu"
-#: ../gui/wxpython/menustrings.py:1586
-#, fuzzy
-msgid "Creates a space time dataset."
-msgstr "Rastra datu importēšana"
-#: ../gui/wxpython/menustrings.py:1588
-#, fuzzy
-msgid "Renames a space time dataset"
-#: ../gui/wxpython/menustrings.py:1590
-msgid "Removes space time datasets from temporal database."
+#: ../gui/wxpython/menustrings.py:921
+msgid "Load model from file"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1591
-msgid "Update metadata"
+#: ../gui/wxpython/menustrings.py:925
+msgid "Save model to file"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1592
-msgid "Modifies the metadata of a space time dataset."
+#: ../gui/wxpython/menustrings.py:927
+msgid "Close model file"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1593
-msgid "Merge"
+#: ../gui/wxpython/menustrings.py:928
+msgid "Export to image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1594
-msgid "Merge several space time datasets into a single one"
+#: ../gui/wxpython/menustrings.py:929
+msgid "Export model to image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1595
-msgid "Temporally shift"
+#: ../gui/wxpython/menustrings.py:930
+msgid "Export to Python"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1596
-msgid "Temporally shift the maps of a space time dataset."
+#: ../gui/wxpython/menustrings.py:931
+msgid "Export model to Python script"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1597
-#, fuzzy
-msgid "Snap maps of dataset"
-#: ../gui/wxpython/menustrings.py:1598
-msgid "Temporally snap the maps of a space time dataset."
+#: ../gui/wxpython/menustrings.py:932
+msgid "Quit modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1600
-msgid "List space time datasets and maps registered in the temporal database."
+#: ../gui/wxpython/menustrings.py:933
+msgid "Close modeler window"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1601
-msgid "Manage maps in datasets"
-msgstr ""
+#: ../gui/wxpython/menustrings.py:937
+msgid "&Model"
+msgstr "&Modelis"
-#: ../gui/wxpython/menustrings.py:1602
-msgid "Register maps in datasets"
+#: ../gui/wxpython/menustrings.py:938
+msgid "Add command"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1603
-msgid "Registers raster, vector and raster3d maps in a space time datasets."
+#: ../gui/wxpython/menustrings.py:939
+msgid "Add action (GRASS command) to model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1604
-msgid "Unregister maps from datasets"
-msgstr ""
+#: ../gui/wxpython/menustrings.py:940
+msgid "Add data"
+msgstr "Pievienot datus"
-#: ../gui/wxpython/menustrings.py:1605
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a "
-"specific space time dataset."
+#: ../gui/wxpython/menustrings.py:941
+msgid "Add data item to model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1606
-#, fuzzy
-msgid "List raster dataset maps"
-#: ../gui/wxpython/menustrings.py:1607
-#, fuzzy
-msgid "Lists registered maps of a space time raster dataset."
-#: ../gui/wxpython/menustrings.py:1608
-#, fuzzy
-msgid "List vector dataset maps"
-msgstr "Vektordatu importēšana"
-#: ../gui/wxpython/menustrings.py:1609
-#, fuzzy
-msgid "Lists registered maps of a space time vector dataset."
-#: ../gui/wxpython/menustrings.py:1610
-#, fuzzy
-msgid "List raster3D dataset maps"
-#: ../gui/wxpython/menustrings.py:1611
-#, fuzzy
-msgid "Lists registered maps of a space time raster3d dataset."
-#: ../gui/wxpython/menustrings.py:1612
-#, fuzzy
-msgid "Import"
-#: ../gui/wxpython/menustrings.py:1613
-#, fuzzy
-msgid "Import raster dataset"
-#: ../gui/wxpython/menustrings.py:1614
-#, fuzzy
-msgid "Imports space time raster dataset."
-#: ../gui/wxpython/menustrings.py:1615
-#, fuzzy
-msgid "Import vector dataset"
-#: ../gui/wxpython/menustrings.py:1616
-#, fuzzy
-msgid "Import a space time vector dataset archive file"
-#: ../gui/wxpython/menustrings.py:1618
-#, fuzzy
-msgid "Export raster dataset"
-#: ../gui/wxpython/menustrings.py:1619
-#, fuzzy
-msgid "Exports space time raster dataset."
-#: ../gui/wxpython/menustrings.py:1620
-msgid "Export raster dataset as VTK time series"
+#: ../gui/wxpython/menustrings.py:942
+msgid "Define relation"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1621
-#, fuzzy
-msgid "Exports space time raster dataset as VTK time series."
-#: ../gui/wxpython/menustrings.py:1622
-#, fuzzy
-msgid "Export vector dataset"
-#: ../gui/wxpython/menustrings.py:1623
-msgid "Export a space time vector dataset.as GRASS specific archive file"
+#: ../gui/wxpython/menustrings.py:943
+msgid "Define relation between data and action items"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1624
-#, fuzzy
-msgid "Convert raster dataset to volume"
-#: ../gui/wxpython/menustrings.py:1625
-msgid "Converts a space time raster dataset into a raster3d map."
+#: ../gui/wxpython/menustrings.py:944
+msgid "Add loop / series"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1626
-#, fuzzy
-msgid "Extraction"
-msgstr "Projekcija"
-#: ../gui/wxpython/menustrings.py:1627
-#, fuzzy
-msgid "Extract subset of raster dataset"
-#: ../gui/wxpython/menustrings.py:1628
-#, fuzzy
-msgid "Extracts a subset of a space time raster datasets."
-#: ../gui/wxpython/menustrings.py:1629
-#, fuzzy
-msgid "Extract subset of vector dataset"
-#: ../gui/wxpython/menustrings.py:1630
-#, fuzzy
-msgid "Extracts a subset of a space time vector dataset."
-#: ../gui/wxpython/menustrings.py:1631
-#, fuzzy
-msgid "Extract subset of raster3D dataset"
-#: ../gui/wxpython/menustrings.py:1632
-#, fuzzy
-msgid "Extracts a subset of a space time raster3d dataset."
-#: ../gui/wxpython/menustrings.py:1633
-msgid "Query vector dataset attribute data"
+#: ../gui/wxpython/menustrings.py:945
+msgid "Adds loop (series) to model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1634
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
+#: ../gui/wxpython/menustrings.py:946
+msgid "Add condition"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1635
-msgid "Raster dataset color table"
+#: ../gui/wxpython/menustrings.py:947
+msgid "Adds condition (if/else) to model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1636
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
+#: ../gui/wxpython/menustrings.py:948
+msgid "Remove item"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1637
-msgid "Raster calculations"
+#: ../gui/wxpython/menustrings.py:949
+msgid "Remove action/data from model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1638
-msgid ""
-"Perform spatio-temporal mapcalc expressions on temporal sampled maps of "
-"space time raster datasets."
+#: ../gui/wxpython/menustrings.py:951
+msgid "Model properties (name, purpose, etc.)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1639
-msgid "Raster3D calculations"
+#: ../gui/wxpython/menustrings.py:952
+msgid "Delete intermediate data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1640
-msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time raster3d "
-"datasets."
+#: ../gui/wxpython/menustrings.py:953
+msgid "Delete intermediate data defined in the model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1641
-#, fuzzy
-msgid "Interpolate gaps in raster datasets"
-#: ../gui/wxpython/menustrings.py:1642
-msgid ""
-"Replace gaps in a space time raster dataset with interpolated raster maps."
+#: ../gui/wxpython/menustrings.py:955
+msgid "Run entire model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1643
-#, fuzzy
-msgid "Aggregation"
-#: ../gui/wxpython/menustrings.py:1644
-msgid "Neighborhood analysis in raster dataset"
+#: ../gui/wxpython/menustrings.py:956
+msgid "Validate model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1645
-msgid ""
-"Performs a neighborhood analysis for each map in a space time raster dataset."
+#: ../gui/wxpython/menustrings.py:957
+msgid "Validate entire model"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1646
-#, fuzzy
-msgid "Aggregation in raster datasets"
+#: ../gui/wxpython/menustrings.py:959
+msgid "Help"
+msgstr "Palīdzība"
-#: ../gui/wxpython/menustrings.py:1647
-msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
+#: ../gui/wxpython/menustrings.py:960
+msgid "Display the HTML man pages of Graphical modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1648
-msgid "Temporal aggregation"
+#: ../gui/wxpython/menustrings.py:961
+msgid "About Graphical Modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1649
-msgid ""
-"Temporally aggregates the maps of a space time raster dataset by a user "
-"defined granularity."
+#: ../gui/wxpython/menustrings.py:962
+msgid "Display information about Graphical Modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1650
-msgid "Temporal aggregation by dataset"
+#: ../gui/wxpython/lmgr/toolbars.py:50
+msgid "Start new map display"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1651
-msgid ""
-"Aggregated data of an existing space time raster dataset using the time "
-"intervals of a second space time dataset."
+#: ../gui/wxpython/lmgr/toolbars.py:52
+msgid "Create new workspace (Ctrl+N)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1652
-msgid "Sampling"
+#: ../gui/wxpython/lmgr/toolbars.py:54
+msgid "Open existing workspace file (Ctrl+O)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1653
-msgid "Temporal sampling"
+#: ../gui/wxpython/lmgr/toolbars.py:56
+msgid "Save current workspace to file (Ctrl+S)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1654
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and "
-"print the result to stdout."
+#: ../gui/wxpython/lmgr/toolbars.py:85
+msgid "Add multiple raster or vector map layers (Ctrl+Shift+L)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1655
-msgid "Query raster dataset by vector points dataset"
+#: ../gui/wxpython/lmgr/toolbars.py:86
+msgid "Add raster map layer (Ctrl+Shift+R)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1656
-msgid ""
-"Store raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
+#: ../gui/wxpython/lmgr/toolbars.py:88
+msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1657
-msgid "Observe specific locations in raster dataset"
+#: ../gui/wxpython/lmgr/toolbars.py:89
+msgid "Add vector map layer (Ctrl+Shift+V)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1658
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
+#: ../gui/wxpython/lmgr/toolbars.py:91
+msgid "Add various vector map layers (thematic, chart...)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1660
-#, fuzzy
-msgid "Space time datasets metadata"
-#: ../gui/wxpython/menustrings.py:1661
-msgid "Lists information about space time datasets and maps."
+#: ../gui/wxpython/lmgr/toolbars.py:93
+msgid "Add group"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1662
-msgid "Univariate raster dataset statistics"
+#: ../gui/wxpython/lmgr/toolbars.py:95
+msgid "Add grid or vector labels overlay"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1663
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered "
-"raster map of a space time raster dataset."
+#: ../gui/wxpython/lmgr/toolbars.py:97 ../gui/wxpython/iclass/toolbars.py:41
+msgid "Delete selected map layer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1664
-msgid "Univariate vector dataset statistics"
+#: ../gui/wxpython/lmgr/toolbars.py:134
+msgid "Import/link raster or vector data"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1665
-msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
+#: ../gui/wxpython/lmgr/toolbars.py:136 ../gui/wxpython/ogc_services/wms.py:37
+#: ../gui/wxpython/gui_modules/ogc_services.py:38
+msgid "Import data from WMS server"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1666
-msgid "Univariate raster3D dataset statistics"
+#: ../gui/wxpython/lmgr/toolbars.py:138
+msgid "Raster Map Calculator"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1667
-msgid ""
-"raster3d map of a space time raster3d dataset."
+#: ../gui/wxpython/lmgr/toolbars.py:140
+msgid "Graphical Modeler"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1668
-msgid "Report temporal topology"
+#: ../gui/wxpython/lmgr/toolbars.py:142
+msgid "Georectifier"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1669
-msgid "Lists temporal topology of a space time dataset."
+#: ../gui/wxpython/lmgr/toolbars.py:177
+msgid "GUI settings"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1674
-msgid "Create new model"
+#: ../gui/wxpython/lmgr/toolbars.py:178
+msgid "GRASS manual"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1676
-msgid "Load model from file"
-msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:203
+#, fuzzy
+msgid "Edit vector maps"
+msgstr "Jauna vektoru karte"
-#: ../gui/wxpython/menustrings.py:1678 ../gui/wxpython/gmodeler/frame.py:404
-msgid "Save model"
+#: ../gui/wxpython/lmgr/toolbars.py:205
+msgid "Show attribute table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1680
-msgid "Save model to file"
+#: ../gui/wxpython/lmgr/toolbars.py:234
+msgid "Generate command for m.nviz.image"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1682
-msgid "Close model file"
+#: ../gui/wxpython/lmgr/toolbars.py:235
+msgid "Generate command for m.nviz.image based on current state"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1683
-msgid "Export to image"
+#: ../gui/wxpython/lmgr/toolbars.py:237
+msgid "3D view mode settings"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1684
-msgid "Export model to image"
+#: ../gui/wxpython/lmgr/toolbars.py:238
+msgid "Show 3D view mode settings dialog"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1685
-msgid "Export to Python"
+#: ../gui/wxpython/lmgr/toolbars.py:240
+msgid "Show 3D view mode manual"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1686
-msgid "Export model to Python script"
+#: ../gui/wxpython/lmgr/pyshell.py:35
+#: ../gui/wxpython/gui_modules/gpyshell.py:36
+#, python-format
+msgid "Welcome to wxGUI Interactive Python Shell %s"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1687
-msgid "Quit modeler"
+#: ../gui/wxpython/lmgr/pyshell.py:36
+#: ../gui/wxpython/gui_modules/gpyshell.py:37
+#, python-format
+msgid "Type %s for more GRASS scripting related information."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1688
-msgid "Close modeler window"
+#: ../gui/wxpython/lmgr/pyshell.py:37
+#: ../gui/wxpython/gui_modules/gpyshell.py:38
+#, python-format
+msgid "Type %s to add raster or vector to the layer tree."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1691
-#: ../gui/wxpython/gmodeler/preferences.py:29
-msgid "Modeler settings"
+#: ../gui/wxpython/lmgr/pyshell.py:46
+#: ../gui/wxpython/gui_modules/gpyshell.py:47
+msgid "Delete all text from the shell"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1692
-msgid "&Model"
+#: ../gui/wxpython/lmgr/pyshell.py:96
+#: ../gui/wxpython/gui_modules/gpyshell.py:97
+#, python-format
+msgid "Raster or vector map <%s> not found"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1693
-msgid "Add command"
+#: ../gui/wxpython/lmgr/pyshell.py:103
+#: ../gui/wxpython/gui_modules/gpyshell.py:104
+#, python-format
+msgid "Raster map <%s> added"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1694
-msgid "Add action (GRASS command) to model"
+#: ../gui/wxpython/lmgr/pyshell.py:105
+#: ../gui/wxpython/gui_modules/gpyshell.py:106
+#, python-format
+msgid "Vector map <%s> added"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1695
-msgid "Add data"
-msgstr "Pievienot datus"
-#: ../gui/wxpython/menustrings.py:1696
-msgid "Add data item to model"
+#: ../gui/wxpython/lmgr/layertree.py:55
+msgid "Set raster output format"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1697
-msgid "Define relation"
+#: ../gui/wxpython/lmgr/layertree.py:61
+msgid "Set vector output format"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1698
-msgid "Define relation between data and action items"
+#: ../gui/wxpython/lmgr/layertree.py:63
+msgid "Add command layer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1699
-msgid "Add loop / series"
-msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:65
+#: ../gui/wxpython/gui_core/toolbars.py:66
+msgid "Quit"
+msgstr "Iziet"
-#: ../gui/wxpython/menustrings.py:1700
-msgid "Adds loop (series) to model"
+#: ../gui/wxpython/lmgr/layertree.py:67
+msgid "Add RGB map layer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1701
-msgid "Add condition"
+#: ../gui/wxpython/lmgr/layertree.py:69
+msgid "Add HIS map layer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1702
-msgid "Adds condition (if/else) to model"
+#: ../gui/wxpython/lmgr/layertree.py:71
+msgid "Add shaded relief map layer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1703
-msgid "Remove item"
+#: ../gui/wxpython/lmgr/layertree.py:73
+msgid "Add raster flow arrows"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1704
-msgid "Remove action/data from model"
+#: ../gui/wxpython/lmgr/layertree.py:75
+msgid "Add raster cell numbers"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1705
-#: ../gui/wxpython/gmodeler/preferences.py:422
-msgid "Model properties"
+#: ../gui/wxpython/lmgr/layertree.py:77
+msgid "Add thematic area (choropleth) map layer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1706
-msgid "Model properties (name, purpose, etc.)"
+#: ../gui/wxpython/lmgr/layertree.py:79
+msgid "Add thematic chart layer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1707
-msgid "Delete intermediate data"
+#: ../gui/wxpython/lmgr/layertree.py:81
+msgid "Add grid layer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1708
-msgid "Delete intermediate data defined in the model"
+#: ../gui/wxpython/lmgr/layertree.py:83
+msgid "Add geodesic line layer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1710
-msgid "Run entire model"
+#: ../gui/wxpython/lmgr/layertree.py:85
+msgid "Add rhumbline layer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1711
-msgid "Validate model"
+#: ../gui/wxpython/lmgr/layertree.py:87
+msgid "Add labels"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1712
-msgid "Validate entire model"
+#: ../gui/wxpython/lmgr/layertree.py:89
+msgid "Add 3D raster map layer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1715
-msgid "Display the HTML man pages of Graphical modeler"
+#: ../gui/wxpython/lmgr/layertree.py:90
+msgid "Note that 3D raster data are rendered only in 3D view mode"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1716
-msgid "About Graphical Modeler"
+#: ../gui/wxpython/lmgr/layertree.py:92
+#: ../gui/wxpython/gui_modules/gdialogs.py:580
+#: ../gui/wxpython/gui_core/dialogs.py:583
+msgid "Set options"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1717
-msgid "Display information about Graphical Modeler"
+#: ../gui/wxpython/lmgr/layertree.py:155
+#: ../gui/wxpython/gui_modules/layertree.py:121
+#, python-format
+msgid "GRASS GIS Map Display: %(id)d - Location: %(loc)s"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1721 ../gui/wxpython/psmap/toolbars.py:69
-#: ../gui/wxpython/modules/histogram.py:448 ../gui/wxpython/wxplot/base.py:536
-#: ../gui/wxpython/gcp/mapdisplay.py:412 ../gui/wxpython/mapdisp/frame.py:604
-msgid "Page setup"
-msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:165
+#: ../gui/wxpython/gui_modules/layertree.py:131
+msgid "Map Layers"
+msgstr "Kartes slāņi"
-#: ../gui/wxpython/menustrings.py:1722 ../gui/wxpython/psmap/toolbars.py:70
-msgid "Specify paper size, margins and orientation"
+#: ../gui/wxpython/lmgr/layertree.py:322
+#: ../gui/wxpython/gui_modules/layertree.py:289
+msgid "Change opacity level"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1723
-msgid "Load instruction file"
+#: ../gui/wxpython/lmgr/layertree.py:332
+#: ../gui/wxpython/gui_modules/layertree.py:299
+msgid "3D view properties"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1724 ../gui/wxpython/psmap/toolbars.py:63
-msgid "Load text file with mapping instructions"
-msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:336
+#: ../gui/wxpython/gui_modules/layertree.py:303
+msgid "Zoom to selected map(s)"
+msgstr "Tuvināt līdz izvēlētajām kartēm"
-#: ../gui/wxpython/menustrings.py:1725
-msgid "Export instruction file"
+#: ../gui/wxpython/lmgr/layertree.py:338
+#: ../gui/wxpython/gui_modules/layertree.py:305
+msgid "Set computational region from selected map(s)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1726 ../gui/wxpython/psmap/toolbars.py:61
-msgid "Generate text file with mapping instructions"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:1727
-#, fuzzy
-msgid "Export to PostScript"
+#: ../gui/wxpython/lmgr/layertree.py:350 ../gui/wxpython/lmgr/layertree.py:436
+#: ../gui/wxpython/gui_modules/layertree.py:317
+#: ../gui/wxpython/gui_modules/layertree.py:402
+msgid "Export"
msgstr "Eksportēt"
-#: ../gui/wxpython/menustrings.py:1728 ../gui/wxpython/psmap/toolbars.py:65
-msgid "Generate PostScript output"
+#: ../gui/wxpython/lmgr/layertree.py:357 ../gui/wxpython/lmgr/layertree.py:442
+#: ../gui/wxpython/gui_modules/layertree.py:324
+#: ../gui/wxpython/gui_modules/layertree.py:408
+msgid "Set color table"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1729
-#, fuzzy
-msgid "Export to PDF"
-msgstr "Eksportēt"
+#: ../gui/wxpython/lmgr/layertree.py:360
+#: ../gui/wxpython/gui_modules/layertree.py:327
+msgid "Show attribute data"
+msgstr "Rādīt atribūtu datus"
-#: ../gui/wxpython/menustrings.py:1730 ../gui/wxpython/psmap/toolbars.py:67
-msgid "Generate PDF output"
+#: ../gui/wxpython/lmgr/layertree.py:363
+#: ../gui/wxpython/gui_modules/layertree.py:330
+msgid "Start editing"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1731 ../gui/wxpython/menustrings.py:1732
-msgid "Launch ps.map dialog"
+#: ../gui/wxpython/lmgr/layertree.py:364
+#: ../gui/wxpython/gui_modules/layertree.py:331
+msgid "Stop editing"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1734
-msgid "Close Cartographic Composer"
+#: ../gui/wxpython/lmgr/layertree.py:375
+#: ../gui/wxpython/gui_modules/layertree.py:342
+msgid "Use as background vector map for digitizer"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1735
-msgid "&Insert"
+#: ../gui/wxpython/lmgr/layertree.py:382
+#: ../gui/wxpython/gui_modules/layertree.py:349
+msgid "Rebuild topology"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1736 ../gui/wxpython/psmap/toolbars.py:75
-#: ../gui/wxpython/psmap/dialogs.py:619 ../gui/wxpython/psmap/dialogs.py:674
-msgid "Map frame"
+#: ../gui/wxpython/lmgr/layertree.py:395
+#: ../gui/wxpython/gui_modules/layertree.py:361
+msgid "SQL Spatial Query"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1737
-msgid "Add or edit map frame"
+#: ../gui/wxpython/lmgr/layertree.py:430
+#: ../gui/wxpython/gui_modules/layertree.py:396
+msgid "Zoom to selected map(s) (ignore NULLs)"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1739
-#, fuzzy
-msgid "Add or edit raster map"
-msgstr "Pievienot rastru"
+#: ../gui/wxpython/lmgr/layertree.py:432
+#: ../gui/wxpython/gui_modules/layertree.py:398
+msgid "Set computational region from selected map(s) (ignore NULLs)"
+msgstr ""
-#: ../gui/wxpython/menustrings.py:1741
-#, fuzzy
-msgid "Add or edit vector map"
-msgstr "Jauna vektoru karte"
+#: ../gui/wxpython/lmgr/layertree.py:448
+#: ../gui/wxpython/gui_modules/layertree.py:414
+msgid "Profile"
+msgstr "Profils"
-#: ../gui/wxpython/menustrings.py:1742
-#, fuzzy
-msgid "Map legend"
-msgstr "Kartes mērogs"
-#: ../gui/wxpython/menustrings.py:1743
-msgid "Add or edit raster and vector legend"
+#: ../gui/wxpython/lmgr/layertree.py:546
+#: ../gui/wxpython/gui_modules/layertree.py:512
+msgid "Unable to create profile of raster map."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1744 ../gui/wxpython/psmap/toolbars.py:86
-msgid "Map info"
-msgstr "Kartes informācija"
-#: ../gui/wxpython/menustrings.py:1745
-msgid "Add or edit map info"
+#: ../gui/wxpython/lmgr/layertree.py:581
+msgid "Unable to display histogram of raster map. No map name defined."
msgstr ""
-#: ../gui/wxpython/menustrings.py:1747
-msgid "Add or edit scale bar"
+#: ../gui/wxpython/lmgr/layertree.py:610
+#: ../gui/wxpython/gui_modules/layertree.py:592
+#: ../gui/wxpython/gui_modules/mapdisp.py:520
+#: ../gui/wxpython/mapdisp/frame.py:197
+#, python-format
+msgid ""
+"Unable to start wxGUI vector digitizer.\n"
+"Do you want to start TCL/TK digitizer (v.digit) instead?\n"
+"\n"
+"Details: %s"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1753
+#: ../gui/wxpython/lmgr/layertree.py:614
+#: ../gui/wxpython/gui_modules/toolbars.py:222
+#: ../gui/wxpython/gui_modules/layertree.py:596
+#: ../gui/wxpython/gui_modules/mapdisp.py:524
+#: ../gui/wxpython/gui_modules/mapdisp.py:535
+#: ../gui/wxpython/gui_modules/mapdisp.py:587
+#: ../gui/wxpython/gui_modules/mapdisp.py:735
+#: ../gui/wxpython/mapdisp/toolbars.py:80 ../gui/wxpython/mapdisp/frame.py:201
+#: ../gui/wxpython/mapdisp/frame.py:212 ../gui/wxpython/mapdisp/frame.py:264
+#: ../gui/wxpython/mapdisp/frame.py:411
+msgid "2D view"
+msgstr "2D skats"
+#: ../gui/wxpython/lmgr/layertree.py:617
+#: ../gui/wxpython/gui_modules/layertree.py:599
+#: ../gui/wxpython/gui_modules/mapdisp.py:527
+#: ../gui/wxpython/mapdisp/frame.py:204
#, fuzzy
-msgid "Add north arrow"
-msgstr "Ziemeļu bulta"
+msgid "Vector digitizer failed"
+msgstr "GRASS GIS slāņu pārvaldnieks"
-#: ../gui/wxpython/menustrings.py:1755 ../gui/wxpython/psmap/toolbars.py:78
-msgid "Delete selected object"
+#: ../gui/wxpython/lmgr/layertree.py:679
+#, python-format
+msgid "Set opacity of <%s>"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1758
-msgid "Display the HTML man pages of Cartographic Composer"
-msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:775
+#: ../gui/wxpython/gui_modules/layertree.py:757
+msgid "Layer group:"
+msgstr "Slāņu grupa:"
-#: ../gui/wxpython/menustrings.py:1759
-msgid "About Cartographic Composer"
+#: ../gui/wxpython/lmgr/layertree.py:780
+#: ../gui/wxpython/lmgr/layertree.py:1345
+#: ../gui/wxpython/gui_modules/layertree.py:762
+#: ../gui/wxpython/gui_modules/layertree.py:1347
+msgid "Click to edit layer settings"
msgstr ""
-#: ../gui/wxpython/menustrings.py:1760
-msgid "Display information about Cartographic Composer"
+#: ../gui/wxpython/lmgr/layertree.py:821
+#: ../gui/wxpython/gui_modules/layertree.py:803
+msgid "(double click to set properties)"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:51
-msgid "GRASS GIS Cartographic Composer"
-msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:827
+#: ../gui/wxpython/gui_modules/gdialogs.py:1278
+#: ../gui/wxpython/gui_modules/layertree.py:809
+#: ../gui/wxpython/gui_core/dialogs.py:1299
+msgid "3D raster"
+msgstr "3D rastrs"
-#: ../gui/wxpython/psmap/frame.py:182
-msgid ""
-"Python Imaging Library is not available.\n"
-"'Preview' functionality won't work."
-msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:830
+#: ../gui/wxpython/gui_modules/layertree.py:812
+msgid "RGB"
+msgstr "RGB"
-#: ../gui/wxpython/psmap/frame.py:234
-msgid "Program ps2pdf is not available. Please install it first to create PDF."
-msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:833
+#: ../gui/wxpython/gui_modules/layertree.py:815
+msgid "HIS"
+msgstr "HIS"
-#: ../gui/wxpython/psmap/frame.py:278
-msgid "Generating PDF..."
+#: ../gui/wxpython/lmgr/layertree.py:836
+#: ../gui/wxpython/gui_modules/layertree.py:818
+msgid "shaded relief"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:280
-msgid "Generating PostScript..."
+#: ../gui/wxpython/lmgr/layertree.py:839
+#: ../gui/wxpython/gui_modules/layertree.py:821
+msgid "raster cell numbers"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:282
-msgid "Generating preview..."
+#: ../gui/wxpython/lmgr/layertree.py:842
+#: ../gui/wxpython/gui_modules/layertree.py:824
+msgid "raster flow arrows"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:292
-#, python-format
-msgid "Ps.map exited with return code %s"
+#: ../gui/wxpython/lmgr/layertree.py:848
+#: ../gui/wxpython/gui_modules/layertree.py:830
+msgid "thematic area (choropleth) map"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:322
-#, python-format
-msgid "%(prg)s exited with return code %(code)s"
+#: ../gui/wxpython/lmgr/layertree.py:851
+#: ../gui/wxpython/gui_modules/layertree.py:833
+msgid "thematic charts"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:325
-msgid "PDF generated"
+#: ../gui/wxpython/lmgr/layertree.py:854
+#: ../gui/wxpython/gui_modules/layertree.py:836
+msgid "grid"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:328
-#, python-format
-msgid ""
-"Program ps2pdf is not available. Please install it to create PDF.\n"
-"\n"
-" %s"
+#: ../gui/wxpython/lmgr/layertree.py:857
+#: ../gui/wxpython/gui_modules/layertree.py:839
+msgid "geodesic line"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:331
-msgid "PostScript file generated"
+#: ../gui/wxpython/lmgr/layertree.py:860
+#: ../gui/wxpython/gui_modules/layertree.py:842
+msgid "rhumbline"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:337
-msgid "Generating preview, wait please"
+#: ../gui/wxpython/lmgr/layertree.py:863
+#: ../gui/wxpython/gui_modules/layertree.py:845
+msgid "vector labels"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:351
-msgid "Preview not available"
+#: ../gui/wxpython/lmgr/layertree.py:1098
+#: ../gui/wxpython/lmgr/layertree.py:1147
+#: ../gui/wxpython/gui_modules/layertree.py:1100
+#: ../gui/wxpython/gui_modules/layertree.py:1149
+msgid "Please wait, updating data..."
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:352
-msgid "Preview is not available probably due to missing Ghostscript."
+#: ../gui/wxpython/lmgr/layertree.py:1432
+#: ../gui/wxpython/gui_modules/layertree.py:1434
+msgid "opacity:"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:354
-msgid "Please follow instructions on GRASS Trac Wiki."
-msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1450
+#: ../gui/wxpython/gui_modules/layertree.py:1452
+#, python-format
+msgid "Map <%s> not found."
+msgstr "Karte <%s> nav atrasta."
-#: ../gui/wxpython/psmap/frame.py:365
-msgid "Preview generated"
-msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:74
+msgid "GRASS GIS Layer Manager"
-#: ../gui/wxpython/psmap/frame.py:395
-msgid "Save file as"
+#: ../gui/wxpython/lmgr/frame.py:115
+msgid "Workspace Toolbar"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:437
-#, python-format
-msgid "Failed to read file %s."
+#: ../gui/wxpython/lmgr/frame.py:118
+msgid "Data Toolbar"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:565 ../gui/wxpython/psmap/frame.py:588
-#: ../gui/wxpython/psmap/dialogs.py:1211
-msgid "Please, create map frame first."
+#: ../gui/wxpython/lmgr/frame.py:121
+msgid "Misc Toolbar"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:604
-msgid "Scalebar is not appropriate for this projection"
+#: ../gui/wxpython/lmgr/frame.py:124
+msgid "Tools Toolbar"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1024
-msgid "Press button with green triangle icon to generate preview."
+#: ../gui/wxpython/lmgr/frame.py:127
+msgid "Vector Toolbar"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1048
-msgid "wxGUI Cartographic Composer"
+#: ../gui/wxpython/lmgr/frame.py:130
+msgid "3D view Toolbar"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1099
-msgid "MAP FRAME"
+#: ../gui/wxpython/lmgr/frame.py:224 ../gui/wxpython/lmgr/frame.py:1119
+msgid "Rename Map Display"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1100
-msgid "RASTER LEGEND"
+#: ../gui/wxpython/lmgr/frame.py:252
+msgid "Map layers"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1101
-msgid "VECTOR LEGEND"
+#: ../gui/wxpython/lmgr/frame.py:256 ../gui/wxpython/lmgr/frame.py:436
+msgid "Command console"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1102
-msgid "MAP INFO"
+#: ../gui/wxpython/lmgr/frame.py:262
+#: ../gui/wxpython/gui_modules/preferences.py:1309
+#: ../gui/wxpython/gui_core/preferences.py:311
+msgid "Search module"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1103
-msgid "SCALE BAR"
+#: ../gui/wxpython/lmgr/frame.py:269
+#: ../gui/wxpython/gui_modules/preferences.py:1319
+#: ../gui/wxpython/gui_core/preferences.py:321
+msgid "Python shell"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1104
-msgid "IMAGE"
-msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:299
+#: ../gui/wxpython/gui_modules/toolbars.py:228
+#: ../gui/wxpython/mapdisp/toolbars.py:86
+msgid "3D view"
+msgstr "3D skats"
-#: ../gui/wxpython/psmap/frame.py:1105
-msgid "NORTH ARROW"
+#: ../gui/wxpython/lmgr/frame.py:333
+#, python-format
+msgid ""
+"Location <%s> created.\n"
+"\n"
+"Do you want to switch to the new location?"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1353
-msgid "Click and drag to resize object"
+#: ../gui/wxpython/lmgr/frame.py:336
+msgid "Switch to new location?"
msgstr ""
-#: ../gui/wxpython/psmap/frame.py:2173
-msgid "labels: "
+#: ../gui/wxpython/lmgr/frame.py:349 ../gui/wxpython/lmgr/frame.py:666
+#, python-format
+msgid ""
+"Current location is <%(loc)s>.\n"
+"Current mapset is <%(mapset)s>."
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:93
-msgid "inch"
+#: ../gui/wxpython/lmgr/frame.py:390
+msgid "Choose model to run"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:94 ../gui/wxpython/modules/vclean.py:202
-msgid "point"
+#: ../gui/wxpython/lmgr/frame.py:450 ../gui/wxpython/lmgr/frame.py:1711
+msgid "Do you want to save changes in the workspace?"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:95
-msgid "centimeter"
+#: ../gui/wxpython/lmgr/frame.py:452 ../gui/wxpython/lmgr/frame.py:1713
+msgid "Do you want to store current settings to workspace file?"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:96
-msgid "millimeter"
+#: ../gui/wxpython/lmgr/frame.py:460
+#, python-format
+msgid "Close Map Display %s"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:97
-msgid "meters"
+#: ../gui/wxpython/lmgr/frame.py:568 ../gui/wxpython/lmgr/frame.py:1328
+msgid "Selected map layer is not vector."
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:98
-msgid "kilometers"
+#: ../gui/wxpython/lmgr/frame.py:573
+msgid "Editing is allowed only for vector maps from the current mapset."
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:99
-msgid "feet"
+#: ../gui/wxpython/lmgr/frame.py:588
+msgid "Choose script file to run"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:100
-msgid "miles"
+#: ../gui/wxpython/lmgr/frame.py:590
+msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:101 ../gui/wxpython/psmap/utils.py:105
-msgid "nautical miles"
+#: ../gui/wxpython/lmgr/frame.py:601
+#, python-format
+msgid "Script file '%s' doesn't exist. Operation canceled."
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:103
-msgid "pixel"
+#: ../gui/wxpython/lmgr/frame.py:608
+#, python-format
+msgid ""
+"Script <%s> is not executable. Do you want to set the permissions that "
+"allows you to run this script (note that you must be the owner of the file)?"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:104
-msgid "meter"
+#: ../gui/wxpython/lmgr/frame.py:613
+msgid "Set permission?"
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:106
-msgid "degree"
+#: ../gui/wxpython/lmgr/frame.py:622
+msgid "Unable to set permission. Operation canceled."
msgstr ""
-#: ../gui/wxpython/psmap/utils.py:346
-msgid "Unable to run `ps.map -b`"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:133
+#: ../gui/wxpython/lmgr/frame.py:633
#, python-format
msgid ""
-"Unable to open file\n"
-"%s"
+"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
+"directory to GRASS_ADDON_PATH?"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:467
-#, python-format
-msgid "Instruction file will be loaded with following region: %s\n"
+#: ../gui/wxpython/lmgr/frame.py:636
+msgid "Update Addons path?"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:472
+#: ../gui/wxpython/lmgr/frame.py:642
#, python-format
-msgid ""
-"Region cannot be set\n"
-"%s"
+msgid "Launching script '%s'..."
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:611
-#: ../gui/wxpython/psmap/instructions.py:761
-#: ../gui/wxpython/psmap/instructions.py:877
-#: ../gui/wxpython/psmap/instructions.py:935
-#: ../gui/wxpython/psmap/instructions.py:1076
-#: ../gui/wxpython/psmap/instructions.py:1131
-#: ../gui/wxpython/psmap/instructions.py:1190
-#: ../gui/wxpython/psmap/instructions.py:1259
-#: ../gui/wxpython/psmap/instructions.py:1365
-#: ../gui/wxpython/psmap/instructions.py:1490
-#: ../gui/wxpython/psmap/instructions.py:1541
-#: ../gui/wxpython/psmap/instructions.py:1850
-#, python-format
-msgid "Failed to read instruction %s"
+#: ../gui/wxpython/lmgr/frame.py:654
+msgid "No location/mapset provided. Operation canceled."
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:625
-#, python-format
-msgid ""
-"Scale has changed, old value: %(old)s\n"
-"new value: %(new)s"
+#: ../gui/wxpython/lmgr/frame.py:673 ../gui/wxpython/gis_set.py:693
+msgid "Enter name for new mapset:"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:628
-#, python-format
-msgid ""
-"Failed to read instruction %s.\n"
-"Use 1:25000 notation."
+#: ../gui/wxpython/lmgr/frame.py:680 ../gui/wxpython/lmgr/frame.py:701
+msgid "No mapset provided. Operation canceled."
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:636
+#: ../gui/wxpython/lmgr/frame.py:689 ../gui/wxpython/lmgr/frame.py:708
#, python-format
-msgid ""
-"Map frame position changed, old value: %(old1)s %(old2)s\n"
-"new value: %(new1)s %(new2)s"
+msgid "Current mapset is <%s>."
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:644
-#, python-format
-msgid ""
-"Map frame size changed, old value: %(old1)s %(old2)s\n"
+#: ../gui/wxpython/lmgr/frame.py:713
+msgid "Choose a working directory"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:691
-#, python-format
+#: ../gui/wxpython/lmgr/frame.py:793
msgid ""
-"Failed to read instruction %(file)s.\n"
-"Unknown format %(for)s"
+"Current workspace is not empty. Do you want to store current settings to "
+"workspace file?"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:704
-#, python-format
-msgid "Failed to read instruction %s."
+#: ../gui/wxpython/lmgr/frame.py:796
+msgid "Create new workspace?"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:818
-#: ../gui/wxpython/psmap/instructions.py:1700
-#, python-format
-msgid ""
-"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
-"which is required by module ps.map."
+#: ../gui/wxpython/lmgr/frame.py:822
+msgid "Choose workspace file"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:822
-#: ../gui/wxpython/psmap/instructions.py:1704
-msgid ""
-"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
-"required by module ps.map."
+#: ../gui/wxpython/lmgr/frame.py:823 ../gui/wxpython/lmgr/frame.py:1013
+msgid "GRASS Workspace File (*.gxw)|*.gxw"
msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:938
+#: ../gui/wxpython/lmgr/frame.py:858
#, python-format
-msgid "Failed to read instruction %(inst)s: file %(file)s not found."
+msgid ""
+"Reading workspace file <%s> failed.\n"
+"Invalid file, unable to parse XML document."
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:72
-msgid "Full extent"
+#: ../gui/wxpython/lmgr/frame.py:862 ../gui/wxpython/lmgr/frame.py:990
+msgid "Please wait, loading workspace..."
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:73
-msgid "Zoom to full extent"
+#: ../gui/wxpython/lmgr/frame.py:974
+msgid "Choose GRC file to load"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:76
-msgid "Click and drag to place map frame"
+#: ../gui/wxpython/lmgr/frame.py:975
+msgid "Old GRASS Workspace File (*.grc)|*.grc"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:80
-msgid "Show preview"
+#: ../gui/wxpython/lmgr/frame.py:1012
+msgid "Choose file to save current workspace"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:82
-msgid "Quit Cartographic Composer"
+#: ../gui/wxpython/lmgr/frame.py:1027 ../gui/wxpython/lmgr/frame.py:1043
+#, python-format
+msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:88 ../gui/wxpython/wxplot/dialogs.py:898
-#: ../gui/wxpython/wxplot/dialogs.py:941 ../gui/wxpython/wxplot/dialogs.py:991
-msgid "Legend"
-msgstr "Leģenda"
-#: ../gui/wxpython/psmap/toolbars.py:98
-#: ../gui/wxpython/vdigit/preferences.py:537
-msgid "Line"
-msgstr "Līnija"
-#: ../gui/wxpython/psmap/toolbars.py:100
-#: ../gui/wxpython/rlisetup/wizard.py:720
-#: ../gui/wxpython/rlisetup/wizard.py:868
-msgid "Rectangle"
-msgstr "Taisnstūris"
-#: ../gui/wxpython/psmap/toolbars.py:102
-#, fuzzy
-msgid "Add overlays"
-#: ../gui/wxpython/psmap/toolbars.py:192
-msgid "Add simple graphics: points"
+#: ../gui/wxpython/lmgr/frame.py:1067
+msgid "Writing current settings to workspace file failed."
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:204
-msgid "Add simple graphics: lines"
+#: ../gui/wxpython/lmgr/frame.py:1118
+msgid "Enter new name:"
msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:216
-msgid "Add simple graphics: rectangles"
+#: ../gui/wxpython/lmgr/frame.py:1124
+#, python-format
+msgid "GRASS GIS Map Display: %(name)s - Location: %(loc)s"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:198
-msgid "Units:"
-msgstr "Mērvienības:"
-#: ../gui/wxpython/psmap/dialogs.py:207
+#: ../gui/wxpython/lmgr/frame.py:1182
+#, python-format
msgid ""
-"Position of the top left corner\n"
-"from the top left edge of the paper"
+"Unable to launch \"Supervised Classification Tool\".\n"
+"\n"
+"Reason: %s"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:221
-msgid "Position is given:"
+#: ../gui/wxpython/lmgr/frame.py:1301
+msgid "Nothing to import. No WMS layer selected."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:222
-msgid "relative to paper"
+#: ../gui/wxpython/lmgr/frame.py:1337
+msgid "Please wait, loading attribute data..."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:223
-msgid "by map coordinates"
+#: ../gui/wxpython/lmgr/frame.py:1412
+msgid "Add selected map layers into layer tree"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:237
-msgid ""
-"Position from the top left\n"
-"edge of the paper"
+#: ../gui/wxpython/lmgr/frame.py:1443
+#, python-format
+msgid "Unsupported map layer type <%s>."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:291
-msgid "Font:"
-msgstr "Fonts:"
-#: ../gui/wxpython/psmap/dialogs.py:305
-msgid "Choose color:"
-msgstr "Izvēlieties krāsu:"
-#: ../gui/wxpython/psmap/dialogs.py:353
-msgid "Close dialog and apply changes"
+#: ../gui/wxpython/lmgr/frame.py:1566
+msgid ""
+"Note that cell values can only be displayed for regions of less than 10,000 "
+"cells."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:384 ../gui/wxpython/rlisetup/wizard.py:705
-#: ../gui/wxpython/rlisetup/wizard.py:858
-msgid "Units"
-msgstr "Mērvienības"
-msgid "Orientation"
-msgstr "Orientācija"
-#: ../gui/wxpython/psmap/dialogs.py:384 ../gui/wxpython/psmap/dialogs.py:2085
-msgid "Width"
-msgstr "Platums"
-msgid "Height"
-msgstr "Augstums"
-#: ../gui/wxpython/psmap/dialogs.py:385
-msgid "Left"
+#: ../gui/wxpython/lmgr/frame.py:1648
+#, python-format
+msgid ""
+"Do you want to remove map layer(s)\n"
+"%s\n"
+"from layer tree?"
msgstr ""
-msgid "Right"
+#: ../gui/wxpython/lmgr/frame.py:1651
+msgid "Do you want to remove selected map layer(s) from layer tree?"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:238
-msgid "Top"
+#: ../gui/wxpython/lmgr/frame.py:1655
+msgid "Remove map layer"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:246
-msgid "Bottom"
-msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1720
+msgid "Quit GRASS GUI"
+msgstr "Iziet no GRASS GUI"
-#: ../gui/wxpython/psmap/dialogs.py:440
-msgid "Literal is not allowed!"
+#: ../gui/wxpython/lmgr/frame.py:1749
+msgid "No map layer selected. Operation canceled."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:449
-msgid "Page size"
-msgstr "Lapas izmērs"
+#: ../gui/wxpython/lmgr/frame.py:1750 ../gui/wxpython/gui_modules/gcmd.py:99
+#: ../gui/wxpython/gui_modules/dbm.py:2065
+#: ../gui/wxpython/gui_modules/dbm.py:2096
+#: ../gui/wxpython/gui_modules/ghelp.py:293
+#: ../gui/wxpython/gui_core/ghelp.py:276 ../gui/wxpython/core/gcmd.py:143
+#: ../gui/wxpython/gis_set.py:436 ../gui/wxpython/gis_set.py:471
+msgid "Message"
+msgstr "Paziņojums"
-#: ../gui/wxpython/psmap/dialogs.py:451
-msgid "Margins"
+#: ../gui/wxpython/lmgr/frame.py:1759
+msgid ""
+"Display resolution is currently not constrained to computational settings. "
+"It's suggested to constrain map to region geometry. Do you want to constrain "
+"the resolution?"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:455
-msgid "Portrait"
+#: ../gui/wxpython/lmgr/frame.py:1768
+msgid "Constrain map to region geometry?"
msgstr ""
-msgid "Landscape"
+#: ../gui/wxpython/ogc_services/wms.py:53
+#: ../gui/wxpython/gui_modules/ogc_services.py:54
+msgid " Server settings "
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:507 ../gui/wxpython/psmap/dialogs.py:528
-#: ../gui/wxpython/location_wizard/wizard.py:1780
-msgid "custom"
+#: ../gui/wxpython/ogc_services/wms.py:55
+#: ../gui/wxpython/gui_modules/ogc_services.py:56
+msgid "Server:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:557
-msgid "Map settings"
+#: ../gui/wxpython/ogc_services/wms.py:62
+#: ../gui/wxpython/gui_modules/ogc_services.py:63
+msgid " List of layers "
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:563
-msgid "Map frame settings"
+#: ../gui/wxpython/ogc_services/wms.py:68
+#: ../gui/wxpython/gui_modules/gdialogs.py:1712
+#: ../gui/wxpython/gui_modules/gdialogs.py:1915
+#: ../gui/wxpython/gui_modules/ogc_services.py:69
+#: ../gui/wxpython/gui_core/dialogs.py:1803
+#: ../gui/wxpython/gui_core/dialogs.py:2019
+msgid "Add imported layers into layer tree"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:680
-msgid "Map frame options:"
-msgstr ""
+#: ../gui/wxpython/ogc_services/wms.py:78
+#: ../gui/wxpython/gui_modules/ogc_services.py:79
+msgid "&Connect"
+msgstr "&Pieslēgties"
-#: ../gui/wxpython/psmap/dialogs.py:681
-msgid "fit frame to match selected map"
+#: ../gui/wxpython/ogc_services/wms.py:79
+#: ../gui/wxpython/gui_modules/ogc_services.py:80
+msgid "Connect to the server"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:682
-msgid "fit frame to match saved region"
-msgstr ""
+#: ../gui/wxpython/ogc_services/wms.py:84
+#: ../gui/wxpython/gui_modules/gdialogs.py:1549
+#: ../gui/wxpython/gui_modules/gdialogs.py:1724
+#: ../gui/wxpython/gui_modules/ogc_services.py:85
+#: ../gui/wxpython/gui_core/dialogs.py:1639
+#: ../gui/wxpython/gui_core/dialogs.py:1815
+msgid "&Import"
+msgstr "&Importēt"
-#: ../gui/wxpython/psmap/dialogs.py:683
-msgid "fit frame to match current computational region"
+#: ../gui/wxpython/ogc_services/wms.py:85
+#: ../gui/wxpython/gui_modules/gdialogs.py:1550
+#: ../gui/wxpython/gui_modules/gdialogs.py:1725
+#: ../gui/wxpython/gui_modules/ogc_services.py:86
+#: ../gui/wxpython/gui_core/dialogs.py:1640
+#: ../gui/wxpython/gui_core/dialogs.py:1816
+msgid "Import selected layers"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:684
-msgid "fixed scale and map center"
+#: ../gui/wxpython/ogc_services/wms.py:239
+#: ../gui/wxpython/gui_modules/ogc_services.py:240
+msgid "Layer / Style"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:692 ../gui/wxpython/psmap/dialogs.py:860
-msgid "Map selection"
+#: ../gui/wxpython/ogc_services/wms.py:240
+#: ../gui/wxpython/gui_modules/ogc_services.py:241
+msgid "Title"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:700 ../gui/wxpython/psmap/dialogs.py:1284
-msgid "Map:"
-msgstr "Karte:"
+#: ../gui/wxpython/ogc_services/wms.py:250
+#: ../gui/wxpython/gui_modules/ogc_services.py:251
+#: ../gui/wxpython/gui_core/preferences.py:863
+msgid "Layers"
+msgstr "Slāņi"
-msgid "Region:"
-msgstr "Reģions:"
+#: ../gui/wxpython/nviz/tools.py:84 ../gui/wxpython/nviz/preferences.py:55
+#: ../gui/wxpython/nviz/preferences.py:60
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:53
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:58
+#: ../gui/wxpython/gui_modules/nviz_tools.py:251
+msgid "View"
+msgstr "Skats"
-#: ../gui/wxpython/psmap/dialogs.py:719
-msgid "Map scale and center"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:92
+#: ../gui/wxpython/gui_modules/preferences.py:1403
+#: ../gui/wxpython/gui_modules/nviz_tools.py:259
+#: ../gui/wxpython/gui_core/preferences.py:405
+msgid "Appearance"
+msgstr "Izskats"
-#: ../gui/wxpython/psmap/dialogs.py:724
-msgid "Center:"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:96
+#: ../gui/wxpython/gui_modules/nviz_tools.py:263
+msgid "Analysis"
+msgstr "Analīze"
-#: ../gui/wxpython/psmap/dialogs.py:725
-msgid "E:"
-msgstr "E:"
+#: ../gui/wxpython/nviz/tools.py:99 ../gui/wxpython/nviz/tools.py:369
+#: ../gui/wxpython/gui_modules/nviz_tools.py:266
+#: ../gui/wxpython/gui_modules/nviz_tools.py:536
+msgid "Animation"
+msgstr "Animācija"
-#: ../gui/wxpython/psmap/dialogs.py:726
-msgid "N:"
-msgstr "N:"
+#: ../gui/wxpython/nviz/tools.py:219
+#: ../gui/wxpython/gui_modules/nviz_tools.py:386
+msgid "Control View"
+msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:729 ../gui/wxpython/psmap/dialogs.py:4166
-msgid "Scale:"
-msgstr "Mērogs:"
+#: ../gui/wxpython/nviz/tools.py:244 ../gui/wxpython/nviz/preferences.py:68
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:66
+#: ../gui/wxpython/gui_modules/nviz_tools.py:411
+msgid "Perspective:"
+msgstr "Perspektīva:"
-#: ../gui/wxpython/psmap/dialogs.py:730
-msgid "1 :"
-msgstr "1 :"
-#: ../gui/wxpython/psmap/dialogs.py:750
-msgid "Map max resolution (dpi):"
+#: ../gui/wxpython/nviz/tools.py:255 ../gui/wxpython/nviz/preferences.py:131
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:129
+#: ../gui/wxpython/gui_modules/nviz_tools.py:422
+msgid "Twist:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:763 ../gui/wxpython/psmap/dialogs.py:2654
-msgid "Border"
+#: ../gui/wxpython/nviz/tools.py:278 ../gui/wxpython/nviz/preferences.py:149
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:147
+#: ../gui/wxpython/gui_modules/nviz_tools.py:445
+msgid "Z-exag:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:767
-msgid "draw border around map frame"
+#: ../gui/wxpython/nviz/tools.py:291
+#: ../gui/wxpython/gui_modules/nviz_tools.py:458
+msgid "Look:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:773
-msgid "border color:"
+#: ../gui/wxpython/nviz/tools.py:294
+#: ../gui/wxpython/gui_modules/nviz_tools.py:461
+msgid "here"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:774
-msgid "border width (pts):"
+#: ../gui/wxpython/nviz/tools.py:300
+#: ../gui/wxpython/gui_modules/nviz_tools.py:467
+msgid "center"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:868
-msgid ""
-"Region is set to match this map,\n"
-"raster or vector map must be added later"
+#: ../gui/wxpython/nviz/tools.py:306
+#: ../gui/wxpython/gui_modules/nviz_tools.py:473
+msgid "top"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:875
-msgid "Region selection"
+#: ../gui/wxpython/nviz/tools.py:312
+#: ../gui/wxpython/gui_modules/nviz_tools.py:479
+msgid "reset"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1034
-msgid "No map selected!"
+#: ../gui/wxpython/nviz/tools.py:313
+#: ../gui/wxpython/gui_modules/nviz_tools.py:480
+msgid "Reset to default view"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1056
-msgid "No region selected!"
+#: ../gui/wxpython/nviz/tools.py:331 ../gui/wxpython/nviz/preferences.py:171
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:169
+#: ../gui/wxpython/gui_modules/nviz_tools.py:498
+msgid "Image Appearance"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1106
-msgid "Invalid scale or map center!"
+#: ../gui/wxpython/nviz/tools.py:339 ../gui/wxpython/nviz/preferences.py:178
+#: ../gui/wxpython/gui_modules/preferences.py:1630
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:176
+#: ../gui/wxpython/gui_modules/nviz_tools.py:506
+#: ../gui/wxpython/gui_core/preferences.py:665
+msgid "Background color:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1166
-msgid "Choose raster map"
+#: ../gui/wxpython/nviz/tools.py:376
+#: ../gui/wxpython/gui_modules/nviz_tools.py:543
+msgid ""
+"Press 'Record' button and start changing the view. It is recommended to use "
+"fly-through mode (Map Display toolbar) to achieve smooth motion."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1170
-msgid "no raster map"
+#: ../gui/wxpython/nviz/tools.py:387
+#: ../gui/wxpython/gui_modules/nviz_tools.py:554
+msgid "Record"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1171
-msgid "raster:"
+#: ../gui/wxpython/nviz/tools.py:389
+#: ../gui/wxpython/gui_modules/nviz_tools.py:556
+msgid "Play"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1271 ../gui/wxpython/gmodeler/model.py:680
-msgid "Vector maps"
+#: ../gui/wxpython/nviz/tools.py:391
+#: ../gui/wxpython/gui_modules/nviz_tools.py:558
+msgid "Pause"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1280
-msgid "Add map"
+#: ../gui/wxpython/nviz/tools.py:393
+#: ../gui/wxpython/gui_modules/nviz_tools.py:560
+msgid "Stop"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1288 ../gui/wxpython/psmap/dialogs.py:1652
-msgid "points"
+#: ../gui/wxpython/nviz/tools.py:405
+#: ../gui/wxpython/gui_modules/nviz_tools.py:572
+msgid "Total number of frames :"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1288 ../gui/wxpython/psmap/dialogs.py:1654
-msgid "lines"
+#: ../gui/wxpython/nviz/tools.py:409
+#: ../gui/wxpython/gui_modules/nviz_tools.py:576
+msgid "Frame rate (FPS):"
msgstr ""
-msgid "areas"
+#: ../gui/wxpython/nviz/tools.py:415
+#: ../gui/wxpython/gui_modules/nviz_tools.py:582
+msgid "Frames are recorded with given frequency (FPS). "
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1290
-msgid "Data Type"
+#: ../gui/wxpython/nviz/tools.py:458
+#: ../gui/wxpython/gui_modules/nviz_tools.py:625
+msgid "Save image sequence"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1305
-msgid "Manage vector maps"
+#: ../gui/wxpython/nviz/tools.py:466
+#: ../gui/wxpython/gui_modules/nviz_tools.py:633
+msgid "Choose a directory for images"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1311
-msgid "The topmost vector map overlaps the others"
+#: ../gui/wxpython/nviz/tools.py:470
+#: ../gui/wxpython/gui_modules/nviz_tools.py:637
+msgid "File prefix:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1316
-msgid "Properties..."
+#: ../gui/wxpython/nviz/tools.py:474
+#: ../gui/wxpython/gui_modules/nviz_tools.py:641
+msgid "Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1518
-msgid "Raster map settings"
+#: ../gui/wxpython/nviz/tools.py:475
+#: ../gui/wxpython/gui_modules/nviz_tools.py:642
+msgid "File format:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1555
-msgid "Vector maps settings"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:530 ../gui/wxpython/nviz/tools.py:1825
+#: ../gui/wxpython/nviz/preferences.py:360
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:358
+#: ../gui/wxpython/gui_modules/nviz_tools.py:700
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1987
+msgid "Surface"
+msgstr "Virsma"
-#: ../gui/wxpython/psmap/dialogs.py:1590
-#, python-format
-msgid "%s properties"
+#: ../gui/wxpython/nviz/tools.py:536 ../gui/wxpython/nviz/tools.py:1063
+#: ../gui/wxpython/gui_modules/nviz_tools.py:706
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1233
+msgid "Constant surface"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1641
-msgid "Data selection"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:541 ../gui/wxpython/nviz/preferences.py:462
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:460
+#: ../gui/wxpython/gui_modules/nviz_tools.py:711
+msgid "Vector"
+msgstr "Vektors"
-#: ../gui/wxpython/psmap/dialogs.py:1652
-msgid "centroids"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:547
+#: ../gui/wxpython/gui_modules/nviz_tools.py:717
+msgid "Volume"
+msgstr "Tilpums"
-#: ../gui/wxpython/psmap/dialogs.py:1654
-msgid "boundaries"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:582 ../gui/wxpython/nviz/preferences.py:252
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:250
+#: ../gui/wxpython/gui_modules/nviz_tools.py:752
+msgid "Lighting"
+msgstr "Apgaismojums"
-#: ../gui/wxpython/psmap/dialogs.py:1670
-msgid "Layer selection"
+#: ../gui/wxpython/nviz/tools.py:587
+#: ../gui/wxpython/gui_modules/nviz_tools.py:757
+msgid "Fringe"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1676
-msgid "Database connection is not defined in DB file."
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:594
+#: ../gui/wxpython/gui_modules/nviz_tools.py:764
+msgid "Decorations"
+msgstr "Dekorācijas"
-#: ../gui/wxpython/psmap/dialogs.py:1677
-msgid "Select layer:"
+#: ../gui/wxpython/nviz/tools.py:614 ../gui/wxpython/nviz/tools.py:926
+#: ../gui/wxpython/gui_modules/nviz_tools.py:784
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1096
+msgid "Cutting planes"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1700
-msgid "list of categories (e.g. 1,3,5-7)"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:659 ../gui/wxpython/nviz/tools.py:1521
+#: ../gui/wxpython/nviz/preferences.py:367
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:365
+#: ../gui/wxpython/gui_modules/nviz_tools.py:829
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1691
+msgid "Draw"
+msgstr "Zīmēt"
-#: ../gui/wxpython/psmap/dialogs.py:1730
-msgid "Use current mask"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:666 ../gui/wxpython/nviz/tools.py:1528
+#: ../gui/wxpython/nviz/preferences.py:373
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:371
+#: ../gui/wxpython/gui_modules/nviz_tools.py:836
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1698
+msgid "Mode:"
+msgstr "Režīms:"
-#: ../gui/wxpython/psmap/dialogs.py:1747 ../gui/wxpython/psmap/dialogs.py:1846
-msgid "Colors"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:669 ../gui/wxpython/nviz/preferences.py:376
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:374
+#: ../gui/wxpython/gui_modules/nviz_tools.py:839
+msgid "coarse"
+msgstr "rupjš"
-#: ../gui/wxpython/psmap/dialogs.py:1752 ../gui/wxpython/psmap/dialogs.py:1851
-msgid "Outline"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:670 ../gui/wxpython/nviz/preferences.py:377
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:375
+#: ../gui/wxpython/gui_modules/nviz_tools.py:840
+msgid "fine"
+msgstr "smalks"
-#: ../gui/wxpython/psmap/dialogs.py:1756 ../gui/wxpython/psmap/dialogs.py:1860
-msgid "draw outline"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:671 ../gui/wxpython/nviz/preferences.py:378
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:376
+#: ../gui/wxpython/gui_modules/nviz_tools.py:841
+msgid "both"
+msgstr "abi"
-#: ../gui/wxpython/psmap/dialogs.py:1759 ../gui/wxpython/psmap/dialogs.py:1864
-#: ../gui/wxpython/psmap/dialogs.py:3750 ../gui/wxpython/psmap/dialogs.py:3755
-msgid "Width (pts):"
+#: ../gui/wxpython/nviz/tools.py:680 ../gui/wxpython/nviz/tools.py:942
+#: ../gui/wxpython/nviz/tools.py:1542
+#: ../gui/wxpython/gui_modules/nviz_tools.py:850
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1112
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1712
+msgid "Shading:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1796 ../gui/wxpython/psmap/dialogs.py:1900
-#: ../gui/wxpython/wxplot/dialogs.py:933 ../gui/wxpython/wxplot/dialogs.py:983
-msgid "Fill"
+#: ../gui/wxpython/nviz/tools.py:683 ../gui/wxpython/nviz/tools.py:1279
+#: ../gui/wxpython/nviz/tools.py:1545
+#: ../gui/wxpython/gui_modules/nviz_tools.py:853
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1449
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1715
+msgid "flat"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1800
-msgid "fill color"
+#: ../gui/wxpython/nviz/tools.py:684 ../gui/wxpython/nviz/tools.py:1546
+#: ../gui/wxpython/gui_modules/nviz_tools.py:854
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1716
+msgid "gouraud"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1803 ../gui/wxpython/psmap/dialogs.py:1906
-msgid "choose color:"
+#: ../gui/wxpython/nviz/tools.py:692
+#: ../gui/wxpython/gui_modules/nviz_tools.py:862
+msgid "Set to all"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1815 ../gui/wxpython/psmap/dialogs.py:1919
-msgid "color from map table column:"
+#: ../gui/wxpython/nviz/tools.py:693
+#: ../gui/wxpython/gui_modules/nviz_tools.py:863
+msgid "Use draw settings for all loaded surfaces"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1862
-msgid "No effect for fill color from table column"
+#: ../gui/wxpython/nviz/tools.py:701 ../gui/wxpython/nviz/preferences.py:405
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:403
+#: ../gui/wxpython/gui_modules/nviz_tools.py:871
+msgid "Coarse mode:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1904
-msgid "Color of lines:"
+#: ../gui/wxpython/nviz/tools.py:704 ../gui/wxpython/nviz/tools.py:744
+#: ../gui/wxpython/nviz/preferences.py:392
+#: ../gui/wxpython/nviz/preferences.py:409
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:390
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:407
+#: ../gui/wxpython/gui_modules/nviz_tools.py:874
+#: ../gui/wxpython/gui_modules/nviz_tools.py:914
+msgid "resolution:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1949 ../gui/wxpython/psmap/dialogs.py:2080
-#: ../gui/wxpython/psmap/dialogs.py:2149
-msgid "Size and style"
+#: ../gui/wxpython/nviz/tools.py:717 ../gui/wxpython/nviz/preferences.py:421
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:419
+#: ../gui/wxpython/gui_modules/nviz_tools.py:887
+msgid "style:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1954 ../gui/wxpython/gcp/manager.py:2432
-#: ../gui/wxpython/vdigit/preferences.py:84
-msgid "Symbology"
+#: ../gui/wxpython/nviz/tools.py:720 ../gui/wxpython/nviz/preferences.py:424
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:422
+#: ../gui/wxpython/gui_modules/nviz_tools.py:890
+msgid "wire"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1967
-msgid "eps file:"
+#: ../gui/wxpython/nviz/tools.py:721 ../gui/wxpython/nviz/preferences.py:425
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:423
+#: ../gui/wxpython/gui_modules/nviz_tools.py:891
+msgid "surface"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
-msgid "Type filename or click browse to choose file"
+#: ../gui/wxpython/nviz/tools.py:733
+#: ../gui/wxpython/gui_modules/nviz_tools.py:903
+msgid "Change wire color"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1972 ../gui/wxpython/psmap/dialogs.py:2161
-msgid "Choose a file"
+#: ../gui/wxpython/nviz/tools.py:740 ../gui/wxpython/nviz/preferences.py:388
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:386
+#: ../gui/wxpython/gui_modules/nviz_tools.py:910
+msgid "Fine mode:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1996 ../gui/wxpython/psmap/dialogs.py:2707
-#: ../gui/wxpython/psmap/dialogs.py:3471 ../gui/wxpython/wxplot/dialogs.py:924
-#: ../gui/wxpython/wxplot/dialogs.py:974
-msgid "Size"
+#: ../gui/wxpython/nviz/tools.py:765
+#: ../gui/wxpython/gui_modules/nviz_tools.py:935
+msgid "Surface attributes"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2002
-msgid "size from map table column:"
+#: ../gui/wxpython/nviz/tools.py:775 ../gui/wxpython/nviz/tools.py:2341
+#: ../gui/wxpython/gui_modules/nviz_tools.py:945
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2493
+msgid "Transparency"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2004
-msgid "scale:"
+#: ../gui/wxpython/nviz/tools.py:776 ../gui/wxpython/nviz/tools.py:2342
+#: ../gui/wxpython/gui_modules/nviz_tools.py:946
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2494
+msgid "Shininess"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2037
-msgid "Rotation"
+#: ../gui/wxpython/nviz/tools.py:782 ../gui/wxpython/nviz/tools.py:2353
+#: ../gui/wxpython/gui_modules/nviz_tools.py:952
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2505
+msgid "map"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2042
-msgid "rotate symbols:"
+#: ../gui/wxpython/nviz/tools.py:785 ../gui/wxpython/nviz/tools.py:2358
+#: ../gui/wxpython/gui_modules/nviz_tools.py:955
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2510
+msgid "unset"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2043
-msgid "counterclockwise in degrees:"
+#: ../gui/wxpython/nviz/tools.py:790 ../gui/wxpython/nviz/tools.py:2363
+#: ../gui/wxpython/gui_modules/nviz_tools.py:960
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2515
+msgid "constant"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2045
-msgid "from map table column:"
+#: ../gui/wxpython/nviz/tools.py:856 ../gui/wxpython/nviz/tools.py:1039
+#: ../gui/wxpython/nviz/tools.py:1660 ../gui/wxpython/nviz/tools.py:2523
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1026
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1209
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1822
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2675
+msgid "Reset"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2089
-msgid "Set width (pts):"
+#: ../gui/wxpython/nviz/tools.py:857 ../gui/wxpython/nviz/tools.py:1661
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1027
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1823
+msgid "Reset to default position"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2098
-msgid "multiply width by category value"
+#: ../gui/wxpython/nviz/tools.py:932
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1102
+msgid "Active cutting plane:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2115 ../gui/wxpython/psmap/dialogs.py:4897
-#: ../gui/wxpython/wxplot/dialogs.py:889
-msgid "Line style"
+#: ../gui/wxpython/nviz/tools.py:944
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1114
+msgid "clear"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2119
-msgid "Choose line style:"
+#: ../gui/wxpython/nviz/tools.py:945
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1115
+msgid "top color"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2129
-msgid "Choose linecap:"
+#: ../gui/wxpython/nviz/tools.py:946
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1116
+msgid "bottom color"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2154
-msgid "Pattern"
+#: ../gui/wxpython/nviz/tools.py:947
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1117
+msgid "blend"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2158
-msgid "use pattern:"
+#: ../gui/wxpython/nviz/tools.py:948
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1118
+msgid "shaded"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2159
-msgid "Choose pattern file:"
+#: ../gui/wxpython/nviz/tools.py:960
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1130
+msgid "Horizontal X:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2163
-msgid "pattern line width (pts):"
+#: ../gui/wxpython/nviz/tools.py:975
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1145
+msgid "Horizontal Y:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2165
-msgid "pattern scale factor:"
+#: ../gui/wxpython/nviz/tools.py:991
+#: ../gui/wxpython/gui_modules/gdialogs.py:810
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1161
+#: ../gui/wxpython/gui_core/dialogs.py:814
+msgid "Rotation:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2482
-msgid "Raster legend"
+#: ../gui/wxpython/nviz/tools.py:1006
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1176
+msgid "Tilt:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2492
-msgid "Source raster"
+#: ../gui/wxpython/nviz/tools.py:1091
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1261
+msgid "Fine resolution:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2497
-msgid "current raster"
+#: ../gui/wxpython/nviz/tools.py:1103
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1273
+msgid "Value:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2498
-msgid "select raster"
+#: ../gui/wxpython/nviz/tools.py:1115 ../gui/wxpython/nviz/tools.py:2512
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1285
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2664
+msgid "Transparency:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2505 ../gui/wxpython/psmap/dialogs.py:3190
-#, python-format
-msgid "%(rast)s: type %(type)s"
+#: ../gui/wxpython/nviz/tools.py:1181
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1351
+msgid "Show vector lines"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2524
-msgid "Type of legend"
+#: ../gui/wxpython/nviz/tools.py:1191 ../gui/wxpython/nviz/preferences.py:468
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:466
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1361
+msgid "Vector lines"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2528
-msgid "discrete legend (categorical maps)"
+#: ../gui/wxpython/nviz/tools.py:1198
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1368
+msgid "Line:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2530
-msgid "continuous color gradient legend (floating point map)"
+#: ../gui/wxpython/nviz/tools.py:1201
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1371
+msgid "width:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2541
-msgid "Advanced legend settings"
+#: ../gui/wxpython/nviz/tools.py:1217 ../gui/wxpython/nviz/tools.py:1364
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1387
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1534
+msgid "color:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2545
-msgid "draw \"no data\" box"
+#: ../gui/wxpython/nviz/tools.py:1233 ../gui/wxpython/nviz/tools.py:1409
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1403
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1579
+msgid "use color for thematic mapping"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2551
-msgid "draw ticks across color table"
+#: ../gui/wxpython/nviz/tools.py:1235
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1405
+msgid "use width for thematic mapping"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2562
-#: ../gui/wxpython/modules/colorrules.py:875
-#: ../gui/wxpython/modules/colorrules.py:1491
-#: ../gui/wxpython/modules/colorrules.py:1494
-msgid "range"
+#: ../gui/wxpython/nviz/tools.py:1248 ../gui/wxpython/nviz/tools.py:1260
+#: ../gui/wxpython/nviz/tools.py:1422 ../gui/wxpython/nviz/tools.py:1431
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1418
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1430
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1592
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1601
+msgid "Set options..."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2599
-msgid "Vector legend"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1273
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1443
+#: ../gui/wxpython/gui_modules/vdigit.py:158
+#: ../gui/wxpython/vdigit/preferences.py:125
+msgid "Display"
+msgstr "Rādīt"
-#: ../gui/wxpython/psmap/dialogs.py:2603
-msgid "Show vector legend"
+#: ../gui/wxpython/nviz/tools.py:1278
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1448
+msgid "on surface(s):"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2609
-msgid "Source vector maps"
+#: ../gui/wxpython/nviz/tools.py:1288 ../gui/wxpython/nviz/tools.py:1444
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1458
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1614
+msgid "Height above surface:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2613
-msgid "Choose vector maps and their order in legend"
+#: ../gui/wxpython/nviz/tools.py:1323
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1493
+msgid "Show vector points"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2618
-msgid "Label"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1332 ../gui/wxpython/nviz/preferences.py:508
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:506
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1502
+msgid "Vector points"
+msgstr "Vektoru punktus"
-#: ../gui/wxpython/psmap/dialogs.py:2637 ../gui/wxpython/psmap/dialogs.py:2945
-msgid "Edit label"
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1343
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1513
+msgid "Icon:"
+msgstr "Ikona:"
-#: ../gui/wxpython/psmap/dialogs.py:2658
-msgid "draw border around legend"
+#: ../gui/wxpython/nviz/tools.py:1411
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1581
+msgid "use size for thematic mapping"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2695
-msgid "Size and position"
+#: ../gui/wxpython/nviz/tools.py:1441
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1611
+msgid "Display on surface(s):"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2729
-msgid "Leave the edit field empty, to use default values."
-msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1498
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1668
+msgid "3D raster map"
+msgstr "3D rastra karte"
-#: ../gui/wxpython/psmap/dialogs.py:2751
-msgid ""
-"Width of the color symbol (for lines)\n"
-"in front of the legend text"
+#: ../gui/wxpython/nviz/tools.py:1531
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1701
+msgid "isosurfaces"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2757 ../gui/wxpython/psmap/dialogs.py:2862
-msgid "Columns:"
+#: ../gui/wxpython/nviz/tools.py:1532
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1702
+msgid "slices"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2761
-msgid "column span:"
+#: ../gui/wxpython/nviz/tools.py:1555
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1725
+msgid "Resolution:"
+msgstr "Izšķirtspēja:"
+#: ../gui/wxpython/nviz/tools.py:1569
+msgid "Draw wire box"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2763
-msgid ""
-"Column separation distance between the left edges\n"
-"of two columns in a multicolumn legend"
+#: ../gui/wxpython/nviz/tools.py:1585 ../gui/wxpython/nviz/tools.py:3657
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1747
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3809
+msgid "List of isosurfaces"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2945
-msgid "Edit legend label:"
+#: ../gui/wxpython/nviz/tools.py:1701
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1863
+msgid "Show light model"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2986
-msgid "No raster map selected!"
+#: ../gui/wxpython/nviz/tools.py:1714
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1876
+msgid "Light source position"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2987
-msgid "No raster"
+#: ../gui/wxpython/nviz/tools.py:1753
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1915
+msgid "Light color and intensity"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3221
-msgid "Mapinfo settings"
+#: ../gui/wxpython/nviz/tools.py:1767 ../gui/wxpython/nviz/preferences.py:306
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:304
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1929
+msgid "Brightness:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3283
-msgid "Color settings"
+#: ../gui/wxpython/nviz/tools.py:1777 ../gui/wxpython/nviz/preferences.py:320
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:318
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1939
+msgid "Ambient:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3289
-msgid "use border color:"
+#: ../gui/wxpython/nviz/tools.py:1839
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2001
+msgid "Edges with fringe"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3290
-msgid "use background color:"
+#: ../gui/wxpython/nviz/tools.py:1841
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2003
+msgid "N && W"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3430
-msgid ""
-"Units of current projection are not supported,\n"
-" meters will be used!"
+#: ../gui/wxpython/nviz/tools.py:1842
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2004
+msgid "N && E"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3431
-msgid "Unsupported units"
+#: ../gui/wxpython/nviz/tools.py:1843
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2005
+msgid "S && W"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3475
-msgid "Length:"
+#: ../gui/wxpython/nviz/tools.py:1844
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2006
+msgid "S && E"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3479
-msgid "Scalebar length is given in map units"
+#: ../gui/wxpython/nviz/tools.py:1858
+#: ../gui/wxpython/gui_modules/gselect.py:1100
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2020
+#: ../gui/wxpython/gui_core/gselect.py:1109
+#: ../gui/wxpython/gui_core/toolbars.py:77
+msgid "Settings"
+msgstr "Iestatījumi"
+#: ../gui/wxpython/nviz/tools.py:1864
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2026
+msgid "Elevation of fringe from bottom:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3482
-msgid "Scalebar height is real height on paper"
+#: ../gui/wxpython/nviz/tools.py:1917
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2079
+msgid "Arrow length (in map units):"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3484
-msgid "default"
+#: ../gui/wxpython/nviz/tools.py:1927
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2089
+msgid "Arrow color:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3524 ../gui/wxpython/wxplot/dialogs.py:948
-#: ../gui/wxpython/wxplot/dialogs.py:998
-msgid "Style"
+#: ../gui/wxpython/nviz/tools.py:1936
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2098
+msgid "Place arrow"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3529
-msgid "Type:"
+#: ../gui/wxpython/nviz/tools.py:1962
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2121
+msgid "Scale bar length (in map units):"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3545
-msgid "Number of segments:"
+#: ../gui/wxpython/nviz/tools.py:1972
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2131
+msgid "Scale bar color:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3549
-msgid "Label every "
+#: ../gui/wxpython/nviz/tools.py:1981
+msgid "Place new scale bar"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3550
-msgid "segments"
+#: ../gui/wxpython/nviz/tools.py:2027
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2179
+msgid "Do you want to record new animation without saving the previous one?"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3559
-msgid "transparent text background"
+#: ../gui/wxpython/nviz/tools.py:2030
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2182
+msgid "Animation already axists"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3636
-msgid "Length of scale bar is not defined"
+#: ../gui/wxpython/nviz/tools.py:2192
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2344
+msgid "No file prefix given."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3739
-msgid "Text effects"
+#: ../gui/wxpython/nviz/tools.py:2196
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2348
+#, python-format
+msgid "Directory %s does not exist."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3744
-msgid "text background"
+#: ../gui/wxpython/nviz/tools.py:2215 ../gui/wxpython/nviz/tools.py:2260
+#: ../gui/wxpython/nviz/tools.py:4468 ../gui/wxpython/nviz/mapwindow.py:2160
+#: ../gui/wxpython/nviz/mapwindow.py:2178
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2367
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2412
+#: ../gui/wxpython/gui_modules/nviz_tools.py:4582
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:2138
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:2156
+msgid "constant#"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3747
-msgid "highlight"
+#: ../gui/wxpython/nviz/tools.py:2326
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2478
+msgid "Isosurface attributes"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3752
-msgid "text border"
+#: ../gui/wxpython/nviz/tools.py:2332
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2484
+msgid "toggle normal direction"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3829
-msgid "Offset"
+#: ../gui/wxpython/nviz/tools.py:2338
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2490
+msgid "Isosurface value"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3832
-msgid "horizontal (pts):"
+#: ../gui/wxpython/nviz/tools.py:2441
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2593
+msgid "Slice attributes"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3833
-msgid "vertical (pts):"
+#: ../gui/wxpython/nviz/tools.py:2447
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2599
+msgid "Slice parallel to axis:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3846
-msgid " Reference point"
+#: ../gui/wxpython/nviz/tools.py:2578
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2730
+msgid "W"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3872
-msgid "Text rotation"
+#: ../gui/wxpython/nviz/tools.py:2579
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2731
+msgid "N"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3875
-msgid "rotate text (counterclockwise)"
+#: ../gui/wxpython/nviz/tools.py:2580
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2732
+msgid "S"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3951
-msgid "No text entered!"
+#: ../gui/wxpython/nviz/tools.py:2581
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2733
+msgid "E"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4120
-msgid "Choose a directory with images"
+#: ../gui/wxpython/nviz/tools.py:2582
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2734
+msgid "NW"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4152
-msgid "Note: only EPS format supported"
+#: ../gui/wxpython/nviz/tools.py:2583
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2735
+msgid "NE"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4161
-msgid "Scale And Rotation"
+#: ../gui/wxpython/nviz/tools.py:2584
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2736
+msgid "SE"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4192 ../gui/wxpython/psmap/dialogs.py:4654
-msgid "Rotation angle (deg):"
+#: ../gui/wxpython/nviz/tools.py:2585
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2737
+msgid "SW"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4201 ../gui/wxpython/psmap/dialogs.py:4663
-msgid "Counterclockwise rotation in degrees"
+#: ../gui/wxpython/nviz/tools.py:3067 ../gui/wxpython/nviz/tools.py:3855
+#: ../gui/wxpython/nviz/tools.py:3857 ../gui/wxpython/nviz/tools.py:4813
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3219
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3996
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3998
+#: ../gui/wxpython/gui_modules/nviz_tools.py:4925
+msgid "Level"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4299
-msgid ""
-"PIL\n"
-"missing"
+#: ../gui/wxpython/nviz/tools.py:3663
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3815
+msgid "List of slices"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4319
-#, python-format
-msgid "Unable to read file %s"
+#: ../gui/wxpython/nviz/tools.py:3864 ../gui/wxpython/nviz/tools.py:3866
+#: ../gui/wxpython/nviz/tools.py:4143 ../gui/wxpython/nviz/tools.py:4826
+#: ../gui/wxpython/gui_modules/nviz_tools.py:4005
+#: ../gui/wxpython/gui_modules/nviz_tools.py:4007
+#: ../gui/wxpython/gui_modules/nviz_tools.py:4284
+#: ../gui/wxpython/gui_modules/nviz_tools.py:4937
+msgid "Slice parallel to"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4378
+#: ../gui/wxpython/nviz/tools.py:4348
#, python-format
-msgid "size: %(width)s x %(height)s pts"
+msgid "Scalebar %d"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4400
-msgid "No image selected."
+#: ../gui/wxpython/nviz/tools.py:4474
+#: ../gui/wxpython/gui_modules/nviz_tools.py:4588
+msgid "None"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4497
-msgid "North Arrow settings"
+#: ../gui/wxpython/nviz/tools.py:4664
+#: ../gui/wxpython/gui_modules/nviz_tools.py:4778
+msgid "Vector map is 3D"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4508
-msgid "Compute convergence"
+#: ../gui/wxpython/nviz/tools.py:4667
+#: ../gui/wxpython/gui_modules/nviz_tools.py:4781
+msgid "Vector map is 2D"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4564
-msgid "Symbol"
+#: ../gui/wxpython/nviz/tools.py:4669
+#: ../gui/wxpython/gui_modules/nviz_tools.py:4783
+#, python-format
+msgid "%(features)d features (%(points)d points)"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4569
-msgid "Select symbol:"
+#: ../gui/wxpython/nviz/tools.py:4846
+#: ../gui/wxpython/gui_modules/nviz_tools.py:4956
+msgid "range:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4583
-msgid ""
-"Note: Selected symbol is not displayed\n"
-"in draft mode (only in preview mode)"
+#: ../gui/wxpython/nviz/tools.py:4914 ../gui/wxpython/nviz/tools.py:4925
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5024
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5035
+msgid "North edge:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4602 ../gui/wxpython/psmap/dialogs.py:4856
-msgid "Outline color:"
+#: ../gui/wxpython/nviz/tools.py:4915 ../gui/wxpython/nviz/tools.py:4926
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5025
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5036
+msgid "South edge:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4617 ../gui/wxpython/psmap/dialogs.py:4877
-msgid "Fill color:"
+#: ../gui/wxpython/nviz/tools.py:4916 ../gui/wxpython/nviz/tools.py:4923
+#: ../gui/wxpython/nviz/tools.py:4932
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5026
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5033
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5042
+msgid "West edge:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4640
-msgid "Size and Rotation"
+#: ../gui/wxpython/nviz/tools.py:4917 ../gui/wxpython/nviz/tools.py:4924
+#: ../gui/wxpython/nviz/tools.py:4933
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5027
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5034
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5043
+msgid "East edge:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4645
-msgid "Size (pt):"
+#: ../gui/wxpython/nviz/tools.py:4919 ../gui/wxpython/nviz/tools.py:4930
+#: ../gui/wxpython/nviz/tools.py:4938
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5029
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5040
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5048
+msgid "Northing (Y):"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4647
-msgid "Symbol size in points"
+#: ../gui/wxpython/nviz/tools.py:4920 ../gui/wxpython/nviz/tools.py:4929
+#: ../gui/wxpython/nviz/tools.py:4939
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5030
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5039
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5049
+msgid "Height (Z):"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4821
-msgid "Rectangle settings"
+#: ../gui/wxpython/nviz/tools.py:4921 ../gui/wxpython/nviz/tools.py:4928
+#: ../gui/wxpython/nviz/tools.py:4937
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5031
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5038
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5047
+msgid "Easting (X):"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4823
-msgid "Line settings"
+#: ../gui/wxpython/nviz/tools.py:4934
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5044
+msgid "Bottom edge:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4909
-msgid "Line width in points"
+#: ../gui/wxpython/nviz/tools.py:4935
+#: ../gui/wxpython/gui_modules/nviz_tools.py:5045
+msgid "Top edge:"
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4977
-#, fuzzy
-msgid "Vector labels"
-msgstr "&Vektors"
-#: ../gui/wxpython/psmap/dialogs.py:4996
-msgid "Vector label files created beforehand by v.label module"
+#: ../gui/wxpython/nviz/mapwindow.py:504
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:509
+#, python-format
+msgid ""
+"Image is too large, your OpenGL implementation supports maximum texture size "
+"%d px."
msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5004
-msgid "You can select multiple label files."
+#: ../gui/wxpython/nviz/mapwindow.py:1018
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1006
+msgid "Easting"
msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:40
-#, fuzzy
-msgid "GRASS GIS Map Swipe"
-msgstr "GRASS GIS slāņu pārvaldnieks"
-#: ../gui/wxpython/mapswipe/frame.py:262 ../gui/wxpython/iclass/frame.py:289
-#: ../gui/wxpython/gcp/mapdisplay.py:248 ../gui/wxpython/mapdisp/frame.py:455
-#: ../gui/wxpython/rlisetup/sampling_frame.py:74
-msgid "Map Toolbar"
+#: ../gui/wxpython/nviz/mapwindow.py:1019
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1007
+msgid "Northing"
msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:351
-#, fuzzy, python-format
-msgid "Map <%s> not found. "
-msgstr "Karte <%s> nav atrasta."
-#: ../gui/wxpython/mapswipe/frame.py:467 ../gui/wxpython/gcp/mapdisplay.py:368
-#: ../gui/wxpython/mapdisp/frame.py:561
-msgid "Nothing to render (empty map). Operation canceled."
+#: ../gui/wxpython/nviz/mapwindow.py:1020
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1008
+msgid "Elevation"
msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:473
-#: ../gui/wxpython/modules/histogram.py:419
-#: ../gui/wxpython/gcp/mapdisplay.py:383 ../gui/wxpython/mapdisp/frame.py:576
-#: ../gui/wxpython/gmodeler/frame.py:555
-msgid "Choose a file name to save the image (no need to add extension)"
+#: ../gui/wxpython/nviz/mapwindow.py:1027
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1015
+msgid "Surface map name"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:27
-#: ../gui/wxpython/modules/vclean.py:461
-msgid "Tools"
+#: ../gui/wxpython/nviz/mapwindow.py:1028
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1016
+msgid "Surface map elevation"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:28
-msgid "Quit Map Swipe"
+#: ../gui/wxpython/nviz/mapwindow.py:1029
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1017
+msgid "Surface map color"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:29
-#: ../gui/wxpython/mapswipe/dialogs.py:28
-msgid "Select raster maps"
+#: ../gui/wxpython/nviz/mapwindow.py:1038
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1026
+msgid "XY distance from previous"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:104
-msgid "Swipe mode"
+#: ../gui/wxpython/nviz/mapwindow.py:1039
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1027
+msgid "XYZ distance from previous"
msgstr ""
-msgid "Mirror mode"
+#: ../gui/wxpython/nviz/mapwindow.py:1040
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1028
+msgid "Distance along surface"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:113
-msgid "Choose view mode"
+#: ../gui/wxpython/nviz/mapwindow.py:1045
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1033
+msgid "Distance along exag. surface"
msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:137
-#, fuzzy
-msgid "Switch orientation"
-#: ../gui/wxpython/mapswipe/toolbars.py:139
-msgid "Switch maps"
+#: ../gui/wxpython/nviz/mapwindow.py:1052
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1040
+msgid "No point on surface"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:51
-msgid "Name of top/left raster map:"
+#: ../gui/wxpython/nviz/mapwindow.py:1502
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1491
+msgid "Loading raster map"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:57
-msgid "Name of bottom/right raster map:"
+#: ../gui/wxpython/nviz/mapwindow.py:1506
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1495
+msgid "Loading 3d raster map"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:68
-msgid "Name of the first map is missing."
+#: ../gui/wxpython/nviz/mapwindow.py:1512
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1501
+msgid "failed"
msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:70
-msgid "Name of the second map is missing."
+#: ../gui/wxpython/nviz/mapwindow.py:1514
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1503
+#, python-format
+msgid "Unsupported layer type '%s'"
msgstr ""
-#: ../gui/wxpython/modules/histogram.py:269
-msgid "GRASS GIS Histogramming Tool (d.histogram)"
+#: ../gui/wxpython/nviz/mapwindow.py:1623
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1612
+msgid "Unable to unload raster map"
msgstr ""
-#: ../gui/wxpython/modules/histogram.py:373
-msgid "Select font for histogram text"
+#: ../gui/wxpython/nviz/mapwindow.py:1628
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1617
+msgid "Unable to unload 3d raster map"
msgstr ""
-#: ../gui/wxpython/modules/histogram.py:452 ../gui/wxpython/wxplot/base.py:537
-#: ../gui/wxpython/gcp/mapdisplay.py:416 ../gui/wxpython/mapdisp/frame.py:608
-msgid "Print preview"
+#: ../gui/wxpython/nviz/mapwindow.py:1629
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1618
+msgid "3d raster map"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:58
-msgid "GRASS GIS Raster Map Calculator"
+#: ../gui/wxpython/nviz/mapwindow.py:1639
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1628
+msgid "unloaded successfully"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:61
-msgid "GRASS GIS 3D Raster Map Calculator"
+#: ../gui/wxpython/nviz/mapwindow.py:1691
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1680
+#, python-format
+msgid "Loading vector map <%(name)s> (%(type)s) failed"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:72
-msgid "mapcalc statement"
+#: ../gui/wxpython/nviz/mapwindow.py:1750
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1739
+#, python-format
+msgid "Unable to unload vector map <%(name)s> (%(type)s)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:128
-msgid "Operators"
+#: ../gui/wxpython/nviz/mapwindow.py:1753
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1742
+#, python-format
+msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:132
-msgid "Operands"
+#: ../gui/wxpython/nviz/mapwindow.py:2104
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:2082
+#, python-format
+msgid "Vector point layer not found (id = %d)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:134
-msgid "Expression"
+#: ../gui/wxpython/nviz/mapwindow.py:2106
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:2084
+#, python-format
+msgid "Unable to set data layer properties (id = %d)"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:146
-msgid "Save expression to file"
+#: ../gui/wxpython/nviz/mapwindow.py:2109
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:2087
+#, python-format
+msgid ""
+"Setting data layer properties failed.\n"
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:149
-msgid "Load expression from file"
+#: ../gui/wxpython/nviz/mapwindow.py:2235
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:2213
+msgid "At least one raster map required"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:153
-msgid "exponent"
-msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:31
+#, fuzzy
+msgid "3D view settings"
+msgstr "Mainīt iestatījumus"
-#: ../gui/wxpython/modules/mcalc_builder.py:155
-msgid "divide"
+#: ../gui/wxpython/nviz/preferences.py:48
+msgid "Revert settings to default, changes are not applied"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:157
-msgid "add"
+#: ../gui/wxpython/nviz/preferences.py:71
+#: ../gui/wxpython/nviz/preferences.py:134
+#: ../gui/wxpython/nviz/preferences.py:152
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:69
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:132
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:150
+msgid "value:"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:159
-msgid "subtract"
+#: ../gui/wxpython/nviz/preferences.py:83
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:81
+msgid "step:"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:161
-msgid "modulus"
+#: ../gui/wxpython/nviz/preferences.py:98
+#: ../gui/wxpython/nviz/preferences.py:265
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:96
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:263
+msgid "Position:"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:163
-msgid "multiply"
+#: ../gui/wxpython/nviz/preferences.py:101
+#: ../gui/wxpython/nviz/preferences.py:268
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:99
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:266
+msgid "x:"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:168
-msgid "left shift"
+#: ../gui/wxpython/nviz/preferences.py:204
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:202
+msgid "Fly-through"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:170
-msgid "right shift"
+#: ../gui/wxpython/nviz/preferences.py:208
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:206
+#: ../gui/wxpython/mapdisp/toolbars.py:58
+msgid "Fly-through mode"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:172
-msgid "right shift (unsigned)"
+#: ../gui/wxpython/nviz/preferences.py:215
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:213
+msgid "Move exag:"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:174
-msgid "greater than"
+#: ../gui/wxpython/nviz/preferences.py:227
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:225
+msgid "Turn exag:"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:176
-msgid "greater than or equal to"
+#: ../gui/wxpython/nviz/preferences.py:257
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:255
+msgid "Light"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:178
-msgid "less than"
+#: ../gui/wxpython/nviz/preferences.py:292
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:290
+msgid "z:"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:180
-msgid "less than or equal to"
+#: ../gui/wxpython/nviz/preferences.py:436
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:434
+msgid "wire color:"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:182
-msgid "equal to"
+#: ../gui/wxpython/nviz/preferences.py:515
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:513
+msgid "Size:"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:184
-msgid "not equal to"
+#: ../gui/wxpython/nviz/preferences.py:530
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:528
+msgid "Marker:"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:187
-msgid "one's complement"
+#: ../gui/wxpython/nviz/preferences.py:628
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:626
+#, python-format
+msgid "3D view settings saved to file <%s>."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:189
-msgid "NOT"
+#: ../gui/wxpython/nviz/wxnviz.py:32 ../gui/wxpython/gui_modules/wxplot.py:43
+#: ../gui/wxpython/wxplot/profile.py:31
+msgid ""
+"This module requires the NumPy module, which could not be imported. It "
+"probably is not installed (it's not part of the standard Python "
+"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
+"information on downloading source or binaries."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:191
-msgid "bitwise AND"
+#: ../gui/wxpython/nviz/wxnviz.py:50 ../gui/wxpython/gui_modules/wxnviz.py:41
+#, python-format
+msgid "3D view mode: %s\n"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:193
-msgid "bitwise OR"
+#: ../gui/wxpython/nviz/wxnviz.py:326 ../gui/wxpython/nviz/wxnviz.py:337
+#: ../gui/wxpython/gui_modules/histogram.py:333
+#: ../gui/wxpython/gui_modules/wxnviz.py:313
+#: ../gui/wxpython/gui_modules/wxnviz.py:324
+#: ../gui/wxpython/modules/histogram.py:343
+#, python-format
+msgid "Raster map <%s> not found"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:195
-msgid "logical AND"
+#: ../gui/wxpython/nviz/wxnviz.py:414
+#: ../gui/wxpython/gui_modules/wxnviz.py:401
+#, python-format
+msgid "Vector map <%s> not found"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:197
-msgid "logical AND (ignores NULLs)"
+#: ../gui/wxpython/nviz/wxnviz.py:479 ../gui/wxpython/nviz/wxnviz.py:491
+#: ../gui/wxpython/gui_modules/wxnviz.py:466
+#: ../gui/wxpython/gui_modules/wxnviz.py:478
+#, python-format
+msgid "3d raster map <%s> not found"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:199
-msgid "logical OR"
+#: ../gui/wxpython/gui_modules/dbm_base.py:43
+#: ../gui/wxpython/gui_modules/dbm.py:293 ../gui/wxpython/dbmgr/manager.py:297
+#: ../gui/wxpython/dbmgr/vinfo.py:42
+msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:201
-msgid "logical OR (ignores NULLs)"
+#: ../gui/wxpython/gui_modules/gselect.py:324
+#: ../gui/wxpython/gui_core/gselect.py:325
+msgid "Not selectable element"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:203
-msgid "conditional"
-msgstr ""
+#: ../gui/wxpython/gui_modules/gselect.py:345
+#: ../gui/wxpython/gui_modules/preferences.py:2506
+#: ../gui/wxpython/gui_core/gselect.py:346
+#: ../gui/wxpython/gui_core/preferences.py:1703
+msgid "Mapset"
+msgstr "Karšu kopa"
-#: ../gui/wxpython/modules/mcalc_builder.py:216
-msgid "Name for new 3D raster map to create"
+#: ../gui/wxpython/gui_modules/gselect.py:369
+#: ../gui/wxpython/gui_core/gselect.py:370
+#, python-format
+msgid "GSelect: invalid item: %s"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:218
-msgid "Name for new raster map to create"
-msgstr ""
+#: ../gui/wxpython/gui_modules/gselect.py:881
+#: ../gui/wxpython/gui_core/gselect.py:880 ../gui/wxpython/gis_set.py:677
+msgid "Choose GIS Data Directory"
+msgstr "Izvēlieties ĢIS datu mapi"
-#: ../gui/wxpython/modules/mcalc_builder.py:222
-msgid "Insert existing 3D raster map"
+#: ../gui/wxpython/gui_modules/gselect.py:1104
+#: ../gui/wxpython/gui_core/gselect.py:1113
+msgid "Output settings"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:224
-msgid "Insert existing raster map"
+#: ../gui/wxpython/gui_modules/gselect.py:1106
+#: ../gui/wxpython/gui_core/gselect.py:1115
+msgid "Source settings"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:228
-msgid "Insert mapcalc function"
+#: ../gui/wxpython/gui_modules/gselect.py:1117
+#: ../gui/wxpython/gui_core/gselect.py:1131
+msgid "Native"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:239
-msgid "Add created raster map into layer tree"
-msgstr ""
+#: ../gui/wxpython/gui_modules/gselect.py:1121
+#: ../gui/wxpython/gui_modules/menuform.py:1366
+#: ../gui/wxpython/gui_core/gselect.py:1135
+#: ../gui/wxpython/gui_core/forms.py:1350
+msgid "File"
+msgstr "Fails"
-#: ../gui/wxpython/modules/mcalc_builder.py:486
-msgid "You must enter the name of a new raster map to create."
-msgstr ""
+#: ../gui/wxpython/gui_modules/gselect.py:1125
+#: ../gui/wxpython/gui_modules/menuform.py:1421
+#: ../gui/wxpython/gui_core/gselect.py:1139
+#: ../gui/wxpython/gui_core/forms.py:1406
+msgid "Directory"
+msgstr "Mape"
-#: ../gui/wxpython/modules/mcalc_builder.py:496
-msgid "You must enter an expression to create a new raster map."
-msgstr ""
+#: ../gui/wxpython/gui_modules/gselect.py:1129
+#: ../gui/wxpython/gui_modules/dbm.py:2288
+#: ../gui/wxpython/gui_modules/dbm.py:2414
+#: ../gui/wxpython/gui_modules/dbm.py:2666
+#: ../gui/wxpython/gui_core/gselect.py:1143
+#: ../gui/wxpython/dbmgr/manager.py:2314 ../gui/wxpython/dbmgr/manager.py:2438
+#: ../gui/wxpython/dbmgr/manager.py:2692
+msgid "Database"
+msgstr "Datubāze"
-#: ../gui/wxpython/modules/mcalc_builder.py:535
-msgid "Choose a file name to save the expression"
-msgstr ""
+#: ../gui/wxpython/gui_modules/gselect.py:1133
+#: ../gui/wxpython/gui_core/gselect.py:1147
+msgid "Protocol"
+msgstr "Protokols"
-#: ../gui/wxpython/modules/mcalc_builder.py:536
-#: ../gui/wxpython/modules/mcalc_builder.py:557
-msgid "Expression file (*)|*"
+#: ../gui/wxpython/gui_modules/gselect.py:1152
+#: ../gui/wxpython/gui_core/gselect.py:1173
+msgid "Output type"
msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:556
-msgid "Choose a file name to load the expression"
+#: ../gui/wxpython/gui_modules/gselect.py:1154
+#: ../gui/wxpython/gui_core/gselect.py:1175
+msgid "Source type"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:74
-msgid "Check all"
-msgstr ""
+#: ../gui/wxpython/gui_modules/gselect.py:1162
+#: ../gui/wxpython/gui_modules/gselect.py:1165
+#: ../gui/wxpython/gui_modules/gselect.py:1452
+#: ../gui/wxpython/gui_modules/gselect.py:1454
+#: ../gui/wxpython/gui_modules/gselect.py:1636
+#: ../gui/wxpython/gui_modules/gselect.py:1638
+#: ../gui/wxpython/gui_core/gselect.py:1183
+#: ../gui/wxpython/gui_core/gselect.py:1186
+#: ../gui/wxpython/gui_core/gselect.py:1520
+#: ../gui/wxpython/gui_core/gselect.py:1522
+#: ../gui/wxpython/gui_core/gselect.py:1718
+#: ../gui/wxpython/gui_core/gselect.py:1720
+msgid "All files"
+msgstr "Visi faili"
-#: ../gui/wxpython/modules/colorrules.py:77
-msgid "Clear all"
+#: ../gui/wxpython/gui_modules/gselect.py:1169
+#: ../gui/wxpython/gui_modules/gselect.py:1458
+#: ../gui/wxpython/gui_core/gselect.py:1190
+#: ../gui/wxpython/gui_core/gselect.py:1526
+msgid "Choose file to import"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:133
-msgid "Enter vector attribute values"
+#: ../gui/wxpython/gui_modules/gselect.py:1178
+#: ../gui/wxpython/gui_core/gselect.py:1199
+msgid "Choose input directory"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:290
-msgid "Bad color format. Use color format '0:0:0'"
+#: ../gui/wxpython/gui_modules/gselect.py:1187
+#: ../gui/wxpython/gui_modules/gselect.py:1642
+#: ../gui/wxpython/gui_core/gselect.py:1208
+#: ../gui/wxpython/gui_core/gselect.py:1724
+msgid "Choose file"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:381
-#: ../gui/wxpython/wxplot/dialogs.py:371
-msgid "Select raster map:"
-msgstr ""
+#: ../gui/wxpython/gui_modules/gselect.py:1221
+#: ../gui/wxpython/gui_core/gselect.py:1242
+msgid "File:"
+msgstr "Fails:"
-#: ../gui/wxpython/modules/colorrules.py:383
-msgid "Select vector map:"
-msgstr ""
+#: ../gui/wxpython/gui_modules/gselect.py:1230
+#: ../gui/wxpython/gui_core/gselect.py:1251
+msgid "Protocol:"
+msgstr "Protokols:"
-#: ../gui/wxpython/modules/colorrules.py:400
-msgid "Import or export color table:"
-msgstr ""
+#: ../gui/wxpython/gui_modules/gselect.py:1257
+#: ../gui/wxpython/gui_core/gselect.py:1281
+msgid "Extension:"
+msgstr "Paplašinājums:"
-#: ../gui/wxpython/modules/colorrules.py:405
-msgid "Choose file to load color table"
+#: ../gui/wxpython/gui_modules/gselect.py:1285
+#: ../gui/wxpython/gui_core/gselect.py:1309
+msgid "Load settings:"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:406
-msgid "Load"
-msgstr "Ielādēt"
+#: ../gui/wxpython/gui_modules/gselect.py:1303
+#: ../gui/wxpython/gui_core/gselect.py:1330
+msgid "Format:"
+msgstr "Formāts:"
-#: ../gui/wxpython/modules/colorrules.py:407
-msgid "Type filename or click to choose file and load color table"
+#: ../gui/wxpython/gui_modules/gselect.py:1325
+#: ../gui/wxpython/gui_core/gselect.py:1352
+msgid "Creation options:"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:413
-msgid "Choose file to save color table"
+#: ../gui/wxpython/gui_modules/gselect.py:1362
+#: ../gui/wxpython/gui_core/gselect.py:1389
+#, python-format
+msgid "Settings <%s> not found"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:414
-msgid "Type filename or click to choose file and save color table"
-msgstr ""
+#: ../gui/wxpython/gui_modules/gselect.py:1374
+#: ../gui/wxpython/gui_core/gselect.py:1401
+#: ../gui/wxpython/gui_core/gselect.py:1422
+msgid "Save settings"
+msgstr "Saglabāt iestatījumus"
-#: ../gui/wxpython/modules/colorrules.py:422
-#, fuzzy
-msgid "&Set"
-msgstr "Ie&statījumi"
-#: ../gui/wxpython/modules/colorrules.py:429
-msgid "Load color table:"
+#: ../gui/wxpython/gui_modules/gselect.py:1380
+#: ../gui/wxpython/gui_core/gselect.py:1408
+msgid "Name not given, settings is not saved."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:433
-msgid "Load color table from file:"
+#: ../gui/wxpython/gui_modules/gselect.py:1392
+#: ../gui/wxpython/gui_core/gselect.py:1461
+msgid "Unable to save settings"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:436
-msgid "Save color table to file:"
+#: ../gui/wxpython/gui_modules/gselect.py:1810
+#: ../gui/wxpython/gui_core/gselect.py:1885
+msgid "LineString"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:465
-msgid "Reload default table"
+msgid "Polygon"
+msgstr "Poligons"
+#: ../gui/wxpython/gui_modules/gselect.py:1818
+#: ../gui/wxpython/gui_core/gselect.py:1893
+msgid "Feature type:"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:523
-#: ../gui/wxpython/iclass/toolbars.py:66
-msgid "Preview"
-msgstr "Priekšskatījums"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:357
+#: ../gui/wxpython/mapdisp/statusbar.py:357
+msgid "Render"
+msgstr "Zīmēt"
-#: ../gui/wxpython/modules/colorrules.py:527
-msgid "Show preview of map (current Map Display extent is used)."
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:363
+#: ../gui/wxpython/mapdisp/statusbar.py:363
+msgid "Enable/disable auto-rendering"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:557
-#: ../gui/wxpython/modules/colorrules.py:1712
-msgid "No valid color rules given."
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:385
+#: ../gui/wxpython/mapdisp/statusbar.py:385
+msgid "Show comp. extent"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:640
-msgid "Invalid color table format"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:388
+#: ../gui/wxpython/mapdisp/statusbar.py:388
+msgid "Show computational extent"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:717
-#, python-format
-msgid "Invalid rule value '%s'. Unable to apply color table."
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:392
+#: ../gui/wxpython/mapdisp/statusbar.py:392
+msgid ""
+"Show/hide computational region extent (set with g.region). Display region "
+"drawn as a blue box inside the computational region, computational region "
+"inside a display region as a red box)."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:795
-msgid "Create new color table for raster map"
-msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:432
+#: ../gui/wxpython/mapdisp/statusbar.py:432
+msgid "Display mode"
+msgstr "Ekrāna režīms"
-#: ../gui/wxpython/modules/colorrules.py:871
-msgid "Enter raster category values or percents"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:435
+#: ../gui/wxpython/gui_modules/preferences.py:1649
+#: ../gui/wxpython/gui_core/preferences.py:684
+#: ../gui/wxpython/mapdisp/statusbar.py:435
+msgid "Align region extent based on display size"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:877
-msgid "fp range"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:439
+#: ../gui/wxpython/mapdisp/statusbar.py:439
+msgid ""
+"Align region extent based on display size from center point. Default value "
+"for new map displays can be set up in 'User GUI settings' dialog."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:878
-#, python-format
-msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:452
+#: ../gui/wxpython/mapdisp/statusbar.py:452
+msgid "Display resolution"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:966
-msgid "Create new color rules for vector map"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:455
+#: ../gui/wxpython/gui_modules/preferences.py:1662
+#: ../gui/wxpython/gui_core/preferences.py:697
+#: ../gui/wxpython/mapdisp/statusbar.py:455
+msgid "Constrain display resolution to computational settings"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:977
-#: ../gui/wxpython/modules/colorrules.py:1503
-msgid "Enter vector attribute values or percents:"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:459
+#: ../gui/wxpython/mapdisp/statusbar.py:459
+msgid ""
+"Constrain display resolution to computational region settings. Default value "
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:979
-#: ../gui/wxpython/modules/colorrules.py:1505
-msgid "Enter vector attribute values:"
-msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:483
+#: ../gui/wxpython/mapdisp/statusbar.py:483
+msgid "Map scale"
+msgstr "Kartes mērogs"
-#: ../gui/wxpython/modules/colorrules.py:990
-msgid "Select vector columns"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:497
+#: ../gui/wxpython/mapdisp/statusbar.py:497
+msgid ""
+"As everyone's monitors and resolutions are set differently these values are "
+"not true map scales, but should get you into the right neighborhood."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:992
-msgid "Layer:"
-msgstr "Slānis:"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:550
+#: ../gui/wxpython/mapdisp/statusbar.py:550
+msgid "Go to"
+msgstr "Iet uz"
-#: ../gui/wxpython/modules/colorrules.py:994
-msgid "Attribute column:"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:571
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:635
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:808
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:874
+#: ../gui/wxpython/mapdisp/statusbar.py:571
+#: ../gui/wxpython/mapdisp/statusbar.py:635
+#: ../gui/wxpython/mapdisp/statusbar.py:808
+#: ../gui/wxpython/mapdisp/statusbar.py:874
+msgid "Projection not defined (check the settings)"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:997
-msgid "Load color from column:"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:649
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:821
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:904
+#: ../gui/wxpython/mapdisp/statusbar.py:649
+#: ../gui/wxpython/mapdisp/statusbar.py:821
+#: ../gui/wxpython/mapdisp/statusbar.py:904
+msgid "Error in projection (check the settings)"
msgstr ""
-msgid "Save color to column:"
-msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:681
+#: ../gui/wxpython/gui_modules/preferences.py:1989
+#: ../gui/wxpython/gui_core/preferences.py:1164
+#: ../gui/wxpython/mapdisp/statusbar.py:681
+msgid "Projection"
+msgstr "Projekcija"
-#: ../gui/wxpython/modules/colorrules.py:999
-msgid "Load size from column:"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:683
+#: ../gui/wxpython/mapdisp/statusbar.py:683
+msgid "Use defined projection"
msgstr ""
-msgid "Save size to column:"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:695
+#: ../gui/wxpython/mapdisp/statusbar.py:695
+msgid ""
+"Reproject coordinates displayed in the statusbar. Projection can be defined "
+"in GUI preferences dialog (tab 'Projection')"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1001
-msgid "Load width from column:"
-msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:720
+#: ../gui/wxpython/mapdisp/statusbar.py:720
+msgid "MASK"
+msgstr "MASKA"
-msgid "Save width to column:"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:763
+#: ../gui/wxpython/mapdisp/statusbar.py:763
+msgid "Display geometry"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1005
-msgid "Use color column instead of color table:"
-msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:779
+#: ../gui/wxpython/mapdisp/statusbar.py:779
+msgid "Coordinates"
+msgstr "Koordinātes"
-#: ../gui/wxpython/modules/colorrules.py:1020
-msgid "Add GRASSRGB column to current attribute table."
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:833
+#: ../gui/wxpython/mapdisp/statusbar.py:833
+msgid "Extent"
+msgstr "Apjoms"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:928
+#: ../gui/wxpython/mapdisp/statusbar.py:928
+msgid "Comp. region"
+msgstr "Aprēķinu reģions"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:977
+#: ../gui/wxpython/mapdisp/statusbar.py:977
+msgid "Go to GCP No."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1075
-#: ../gui/wxpython/modules/colorrules.py:1124
-msgid "Import or export color table"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:993
+#: ../gui/wxpython/mapdisp/statusbar.py:993
+msgid "Valid Range:"
+msgstr "Derīgs diapazons:"
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:1053
+#: ../gui/wxpython/mapdisp/statusbar.py:1053
+msgid "RMS error"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1136
+#: ../gui/wxpython/gui_modules/mapdisp_statusbar.py:1056
+#: ../gui/wxpython/mapdisp/statusbar.py:1056
#, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. Do you "
-"want to create and connect new attribute table?"
+msgid "Forward: %(forw)s, Backward: %(back)s"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1139
-msgid "No database connection defined"
+#: ../gui/wxpython/gui_modules/render.py:128
+#: ../gui/wxpython/core/render.py:126
+#, python-format
+msgid "<%(name)s>: layer type <%(type)s> is not supported"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1211
+#: ../gui/wxpython/gui_modules/render.py:157
+#: ../gui/wxpython/core/render.py:155
#, python-format
-msgid ""
-"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
-"table cannot be edited."
+msgid "Command '%s' failed\n"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1359
+#: ../gui/wxpython/gui_modules/render.py:158
+#: ../gui/wxpython/core/render.py:156
#, python-format
-msgid "%s column already exists."
+msgid "Details: %s\n"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1391
-msgid "Please wait, loading data from attribute table..."
+#: ../gui/wxpython/gui_modules/render.py:250
+#: ../gui/wxpython/core/render.py:248
+#, python-format
+msgid "Unsupported map layer type '%s'"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1452
+#: ../gui/wxpython/gui_modules/render.py:413
+#: ../gui/wxpython/core/render.py:399
+msgid "GISBASE not set. You must be in GRASS GIS to run this program."
+msgstr "Nav iestatīts GISBASE parametrs. Šo programmu var darbināt tikai GRASS GIS vidē."
+#: ../gui/wxpython/gui_modules/render.py:426
+#: ../gui/wxpython/gui_modules/mapdisp.py:131
+#: ../gui/wxpython/gui_core/mapdisp.py:109 ../gui/wxpython/core/render.py:412
#, python-format
-msgid ""
-"Number of loaded records reached %d, displaying all the records will be time-"
-"consuming and may lead to computer freezing, do you still want to continue?"
+msgid "GRASS module '%s' not found. Unable to start map display window."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1456
-msgid "Too many records"
+#: ../gui/wxpython/gui_modules/render.py:458
+#: ../gui/wxpython/core/render.py:444
+#, python-format
+msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1498
+#: ../gui/wxpython/gui_modules/render.py:568
+#: ../gui/wxpython/mapdisp/main.py:201
#, python-format
-msgid "Enter vector attribute values or percents %s:"
+msgid "Unable to open file '%(file)s' for writting. Details: %(det)s"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1500
+#: ../gui/wxpython/gui_modules/render.py:657
+#: ../gui/wxpython/core/render.py:620
#, python-format
-msgid "Enter vector attribute values %s:"
+msgid "Unable to zoom to raster map <%s>."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1646
-msgid "Please select column to save values to."
+#: ../gui/wxpython/gui_modules/render.py:658
+#: ../gui/wxpython/gui_modules/render.py:661
+#: ../gui/wxpython/gui_modules/gcmd.py:344 ../gui/wxpython/core/render.py:621
+#: ../gui/wxpython/core/render.py:624 ../gui/wxpython/core/gcmd.py:388
+msgid "Details:"
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1682
-msgid "No color column defined. Operation canceled."
+#: ../gui/wxpython/gui_modules/render.py:660
+#: ../gui/wxpython/core/render.py:623
+#, python-format
+msgid "Unable to zoom to vector map <%s>."
msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1697
-msgid "Thematic mapping for vector map in 3D view"
+#: ../gui/wxpython/gui_modules/render.py:663
+#: ../gui/wxpython/core/render.py:626
+msgid ""
+"Unable to get current geographic extent. Force quiting wxGUI. Please "
+"manually run g.region to fix the problem."
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:39
-msgid "Fetch & install extension from GRASS Addons"
+#: ../gui/wxpython/gui_modules/render.py:897
+#: ../gui/wxpython/gui_modules/render.py:926
+#: ../gui/wxpython/mapdisp/main.py:102 ../gui/wxpython/mapdisp/main.py:131
+#, python-format
+msgid "Unable to read cmdfile '%(cmd)s'. Details: %(det)s"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:50
-msgid "Repository"
+#: ../gui/wxpython/gui_modules/render.py:1043
+#: ../gui/wxpython/core/render.py:945
+#, python-format
+msgid "ERROR: Rendering failed. Details: %s"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:52
-msgid "List of extensions - double-click to install"
+#: ../gui/wxpython/gui_modules/render.py:1100
+#: ../gui/wxpython/gui_modules/render.py:1193
+#: ../gui/wxpython/core/render.py:1002 ../gui/wxpython/core/render.py:1095
+#, python-format
+msgid "Unable to render map layer <%s>."
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:95
-msgid "&Fetch"
-msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:1302
+#, fuzzy, python-format
+msgid "Unable render overlay <%s>."
+msgstr "Jauna vektoru karte"
-#: ../gui/wxpython/modules/extensions.py:96
-msgid "Fetch list of available modules from GRASS Addons SVN repository"
-msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:1341
+msgid "Unable render overlay <%s>"
-#: ../gui/wxpython/modules/extensions.py:100
-msgid "&Install"
+#: ../gui/wxpython/gui_modules/workspace.py:1366
+#: ../gui/wxpython/core/workspace.py:1037
+#, python-format
+msgid "Unable to open file <%s> for reading."
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:101
-msgid "Install selected add-ons GRASS module"
+#: ../gui/wxpython/gui_modules/workspace.py:1379
+#: ../gui/wxpython/core/workspace.py:1050
+#, python-format
+msgid ""
+"Some lines were skipped when reading settings from file <%(file)s>.\n"
+"See 'Command output' window for details.\n"
+"\n"
+"Number of skipped lines: %(line)d"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:104
-msgid "Show g.extension manual page"
+#: ../gui/wxpython/gui_modules/workspace.py:1383
+#: ../gui/wxpython/gui_modules/gcmd.py:90
+#: ../gui/wxpython/gui_modules/dbm.py:2366
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:780
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1856
+#: ../gui/wxpython/wxplot/dialogs.py:781
+#: ../gui/wxpython/core/workspace.py:1054 ../gui/wxpython/core/gcmd.py:134
+#: ../gui/wxpython/mapdisp/mapwindow.py:1748
+msgid "Warning"
+msgstr "Brīdinājums"
+#: ../gui/wxpython/gui_modules/workspace.py:1597
+#: ../gui/wxpython/core/workspace.py:1268
+#, python-format
+msgid " row %d:"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:167
-msgid "Extension not defined"
+#: ../gui/wxpython/gui_modules/goutput.py:234
+#: ../gui/wxpython/gui_core/goutput.py:249
+msgid "Click here to show search module engine"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:190
-msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
+#: ../gui/wxpython/gui_modules/goutput.py:235
+#: ../gui/wxpython/gui_core/goutput.py:250
+msgid "Click here to hide search module engine"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:287
-msgid "Unable to load extensions."
+#: ../gui/wxpython/gui_modules/goutput.py:253
+#: ../gui/wxpython/gui_core/goutput.py:268
+msgid "Output window"
+msgstr "Izvades logs"
+#: ../gui/wxpython/gui_modules/goutput.py:255
+#: ../gui/wxpython/gui_core/goutput.py:270
+msgid "Command prompt"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:328
-msgid "Uninstall GRASS Addons extensions"
+#: ../gui/wxpython/gui_modules/goutput.py:259
+#: ../gui/wxpython/gui_core/goutput.py:274
+msgid "Clear output window content"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:337
-msgid "List of installed extensions"
+#: ../gui/wxpython/gui_modules/goutput.py:261
+#: ../gui/wxpython/gui_core/goutput.py:276
+msgid "Clear command prompt content"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:343
-msgid "&Uninstall"
+#: ../gui/wxpython/gui_modules/goutput.py:265
+#: ../gui/wxpython/gui_core/goutput.py:278
+msgid "Save output window content to the file"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:344
-msgid "Uninstall selected AddOns extensions"
+#: ../gui/wxpython/gui_modules/goutput.py:268
+#: ../gui/wxpython/gui_core/goutput.py:280
+msgid "Abort running command"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:379
-msgid "No extension selected for removal. Operation canceled."
+#: ../gui/wxpython/gui_modules/goutput.py:518
+#: ../gui/wxpython/gui_core/goutput.py:546
+#, python-format
+msgid ""
+"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
+"layer instead."
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:388
+#: ../gui/wxpython/gui_modules/goutput.py:553
+#: ../gui/wxpython/gui_core/goutput.py:586
#, python-format
msgid ""
-"List of files to be removed:\n"
-"%(files)s\n"
+"Unable to run command:\n"
+"%(cmd)s\n"
"\n"
-"Do you want really to remove <%(ext)s> extension?"
+"Option <%(opt)s>: read from standard input is not supported by wxGUI"
msgstr ""
-#: ../gui/wxpython/modules/extensions.py:391
-msgid "Remove extension"
-msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:635
+#: ../gui/wxpython/gui_core/goutput.py:674
+#: ../gui/wxpython/gui_core/goutput.py:820
+msgid "Save file as..."
+msgstr "Saglabāt failu kā..."
-#: ../gui/wxpython/modules/extensions.py:411
-msgid "Extension"
+#: ../gui/wxpython/gui_modules/goutput.py:671
+#: ../gui/wxpython/gui_modules/ghelp.py:346
+#: ../gui/wxpython/gui_core/goutput.py:717
+#: ../gui/wxpython/gui_core/ghelp.py:329
+#, python-format
+msgid "%d modules match"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:37 ../gui/wxpython/modules/vclean.py:119
-msgid "Set up vector cleaning tools"
+#: ../gui/wxpython/gui_modules/goutput.py:770
+#: ../gui/wxpython/gui_core/goutput.py:873
+msgid "Please note that the data are left in inconsistent state and may be corrupted"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:74
-msgid "break lines/boundaries"
+#: ../gui/wxpython/gui_modules/goutput.py:773
+#: ../gui/wxpython/gui_core/goutput.py:875
+msgid "Command aborted"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:75
-msgid "remove duplicates"
+#: ../gui/wxpython/gui_modules/goutput.py:782
+#: ../gui/wxpython/gui_core/goutput.py:862
+#, python-format
+msgid "%d sec"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:76
-msgid "remove dangles"
+#: ../gui/wxpython/gui_modules/goutput.py:785
+#, python-format
+msgid "%d min %d sec"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:77
-msgid "change boundary dangles to lines"
+#: ../gui/wxpython/gui_modules/goutput.py:789
+#: ../gui/wxpython/gui_core/goutput.py:877
+msgid "Command finished"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:78
-msgid "remove bridges"
+#: ../gui/wxpython/gui_modules/gcmd.py:78 ../gui/wxpython/core/gcmd.py:122
+msgid "Reason"
+msgstr "Iemesls"
+#: ../gui/wxpython/gui_modules/gcmd.py:341 ../gui/wxpython/core/gcmd.py:385
+msgid "Execution failed:"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:79
-msgid "change bridges to lines"
+#: ../gui/wxpython/gui_modules/gcmd.py:346
+#: ../gui/wxpython/gui_modules/gcmd.py:350 ../gui/wxpython/core/gcmd.py:390
+#: ../gui/wxpython/core/gcmd.py:394
+msgid "Error: "
+msgstr "Kļūda: "
+#: ../gui/wxpython/gui_modules/gcmd.py:425 ../gui/wxpython/core/gcmd.py:469
+#, python-format
+msgid "Unable to exectute command: '%s'"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:80
-msgid "snap lines/boundaries"
+#: ../gui/wxpython/gui_modules/gmodeler.py:420
+#: ../gui/wxpython/gui_modules/gmodeler.py:482
+#, python-format
+msgid "%s: undefined variable '%s'"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:81
-msgid "remove duplicate area centroids"
+#: ../gui/wxpython/gui_modules/gmodeler.py:1006
+#: ../gui/wxpython/gui_modules/dbm.py:2095
+#: ../gui/wxpython/dbmgr/manager.py:2115
+msgid "Nothing to delete."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:82
-msgid "break polygons"
+#: ../gui/wxpython/gui_modules/toolbars.py:232
+#: ../gui/wxpython/mapdisp/toolbars.py:90
+msgid "3D view mode not available"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:83
-msgid "prune lines/boundaries"
+#: ../gui/wxpython/gui_modules/toolbars.py:233
+#: ../gui/wxpython/gui_modules/toolbars.py:250
+#: ../gui/wxpython/mapdisp/toolbars.py:91
+#: ../gui/wxpython/mapdisp/toolbars.py:108
+#, python-format
+msgid "Reason: %s"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:84
-msgid "remove small areas"
+#: ../gui/wxpython/gui_modules/toolbars.py:234
+#: ../gui/wxpython/mapdisp/toolbars.py:92
+msgid ""
+"Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
+"(hopefully this will be fixed soon). Please keep an eye out for updated "
+"versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:85
-msgid "remove lines/boundaries of zero length"
+#: ../gui/wxpython/gui_modules/toolbars.py:242
+#: ../gui/wxpython/gui_modules/toolbars.py:1153
+#: ../gui/wxpython/mapdisp/toolbars.py:100
+#: ../gui/wxpython/vdigit/toolbars.py:798
+msgid "Digitize"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:86
-msgid "remove small angles at nodes"
+#: ../gui/wxpython/gui_modules/toolbars.py:249
+#: ../gui/wxpython/mapdisp/toolbars.py:107
+msgid "Vector digitizer not available"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:121
-msgid "Choose cleaning tools and set thresholds"
+#: ../gui/wxpython/gui_modules/toolbars.py:251
+#: ../gui/wxpython/mapdisp/toolbars.py:109
+msgid ""
+"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
+"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
+"In the meantime you can use \"v.digit\" from the Develop Vector menu."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:125
-msgid "Select input vector map:"
+#: ../gui/wxpython/gui_modules/toolbars.py:446
+#: ../gui/wxpython/iclass/toolbars.py:66
+msgid "Set map canvas for "
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:131
-msgid " Feature type: "
+#: ../gui/wxpython/gui_modules/toolbars.py:448
+msgid " / Zoom to map"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:135
-msgid "Select output vector map:"
+#: ../gui/wxpython/gui_modules/toolbars.py:814
+#: ../gui/wxpython/vdigit/toolbars.py:133
+#: ../gui/wxpython/vdigit/toolbars.py:451
+msgid "Digitization settings"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:167
-msgid "Copy the current command string to the clipboard (Ctrl+C)"
+#: ../gui/wxpython/gui_modules/toolbars.py:824
+#: ../gui/wxpython/vdigit/toolbars.py:467
+msgid "Break selected lines/boundaries at intersection"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:203
-msgid "line"
+#: ../gui/wxpython/gui_modules/toolbars.py:826
+#: ../gui/wxpython/vdigit/toolbars.py:469
+msgid "Connect selected lines/boundaries"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:204
-msgid "boundary"
+#: ../gui/wxpython/gui_modules/toolbars.py:828
+#: ../gui/wxpython/vdigit/toolbars.py:471
+msgid "Copy categories"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:205
-msgid "centroid"
+#: ../gui/wxpython/gui_modules/toolbars.py:830
+#: ../gui/wxpython/vdigit/toolbars.py:473
+msgid "Copy features from (background) vector map"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:206
-#: ../gui/wxpython/vdigit/preferences.py:433
-msgid "area"
+#: ../gui/wxpython/gui_modules/toolbars.py:832
+#: ../gui/wxpython/vdigit/toolbars.py:475
+msgid "Copy attributes"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:207
-msgid "face"
+#: ../gui/wxpython/gui_modules/toolbars.py:834
+#: ../gui/wxpython/vdigit/toolbars.py:477
+msgid "Feature type conversion"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:359
-#, python-format
-msgid "%s. cleaning tool removed, will be ignored"
+#: ../gui/wxpython/gui_modules/toolbars.py:836
+#: ../gui/wxpython/vdigit/toolbars.py:479
+msgid "Flip selected lines/boundaries"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:361
-msgid "Please select a cleaning tool to remove"
+#: ../gui/wxpython/gui_modules/toolbars.py:838
+#: ../gui/wxpython/vdigit/toolbars.py:481
+msgid "Merge selected lines/boundaries"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:382
-#, python-format
-msgid "%s. cleaning tool moved up"
+#: ../gui/wxpython/gui_modules/toolbars.py:840
+#: ../gui/wxpython/vdigit/toolbars.py:483
+msgid "Snap selected lines/boundaries (only to nodes)"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:384
-msgid "1. cleaning tool can not be moved up "
+#: ../gui/wxpython/gui_modules/toolbars.py:842
+#: ../gui/wxpython/vdigit/toolbars.py:485
+msgid "Split line/boundary"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:386
-msgid "Please select a cleaning tool to move up"
+#: ../gui/wxpython/gui_modules/toolbars.py:844
+#: ../gui/wxpython/vdigit/toolbars.py:487
+msgid "Query features"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:408
-#, python-format
-msgid "%s. cleaning tool moved down"
+#: ../gui/wxpython/gui_modules/toolbars.py:846
+#: ../gui/wxpython/vdigit/toolbars.py:489
+msgid "Z bulk-labeling of 3D lines"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:410
-msgid "Last cleaning tool can not be moved down "
+#: ../gui/wxpython/gui_modules/toolbars.py:1002
+#: ../gui/wxpython/vdigit/toolbars.py:645
+msgid "Vector map is not 3D. Operation canceled."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:412
-msgid "Please select a cleaning tool to move down"
+#: ../gui/wxpython/gui_modules/toolbars.py:1071
+#: ../gui/wxpython/gui_modules/toolbars.py:1185
+#: ../gui/wxpython/gui_modules/toolbars.py:1264
+#: ../gui/wxpython/vdigit/toolbars.py:714
+#: ../gui/wxpython/vdigit/toolbars.py:830
+#: ../gui/wxpython/vdigit/toolbars.py:909
+msgid "Select vector map"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:423
+#: ../gui/wxpython/gui_modules/toolbars.py:1109
+#: ../gui/wxpython/vdigit/toolbars.py:752
#, python-format
-msgid "cleaning tool: '%s'"
+msgid "Please wait, opening vector map <%s> for editing..."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:431
+#: ../gui/wxpython/gui_modules/toolbars.py:1142
#, python-format
-msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
+msgid "Unsupported feature type '%s'. Unable to edit OGR layer <%s>."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:459
-msgid "Name of input vector map"
+#: ../gui/wxpython/gui_modules/toolbars.py:1193
+#: ../gui/wxpython/vdigit/toolbars.py:838
+#, python-format
+msgid "Do you want to save changes in vector map <%s>?"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:460
-msgid "Name for output vector map"
+#: ../gui/wxpython/gui_modules/toolbars.py:1195
+#: ../gui/wxpython/vdigit/toolbars.py:840
+msgid "Save changes?"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:462
-msgid "Threshold"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:464
+#: ../gui/wxpython/gui_modules/toolbars.py:1202
+#: ../gui/wxpython/vdigit/toolbars.py:847
#, python-format
-msgid "'%s' not defined"
+msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:466
+#: ../gui/wxpython/gui_modules/toolbars.py:1212
+#: ../gui/wxpython/vdigit/toolbars.py:857
#, python-format
-msgid ""
-"Some parameters not defined. Operation canceled.\n"
-"\n"
-"%s"
+msgid "Editing of vector map <%s> successfully finished"
msgstr ""
-#: ../gui/wxpython/modules/vclean.py:471
-msgid "Executing selected cleaning operations..."
-msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1271
+#: ../gui/wxpython/gui_modules/toolbars.py:1276
+#: ../gui/wxpython/vdigit/toolbars.py:916
+#: ../gui/wxpython/vdigit/toolbars.py:921
+msgid "New vector map"
-#: ../gui/wxpython/modules/vclean.py:527
-msgid "Vector cleaning command copied to clipboard"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:95
+#: ../gui/wxpython/gui_modules/location_wizard.py:127
+#: ../gui/wxpython/location_wizard/wizard.py:91
msgid "Define GRASS Database and Location Name"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:127
+#: ../gui/wxpython/gui_modules/location_wizard.py:143
+#: ../gui/wxpython/location_wizard/wizard.py:107
+#: ../gui/wxpython/gis_set.py:110
+msgid "GIS Data Directory:"
+msgstr "GIS datu mape:"
+#: ../gui/wxpython/gui_modules/location_wizard.py:159
+#: ../gui/wxpython/location_wizard/wizard.py:123
msgid "Project Location"
-msgstr ""
+msgstr "Projekta novietojums"
-#: ../gui/wxpython/location_wizard/wizard.py:128
-msgid "Name of location directory in GIS Data Directory"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:139
+#: ../gui/wxpython/gui_modules/location_wizard.py:170
+#: ../gui/wxpython/location_wizard/wizard.py:134
#, fuzzy
msgid "Location Title"
msgstr "Novietojuma nosaukums"
-#: ../gui/wxpython/location_wizard/wizard.py:140
-msgid "Optional location title, you can leave this field blank."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:160
-#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for location. Please use only ASCII "
-"characters excluding %(chars)s and space."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:163
-msgid "Invalid location name"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:178
+#: ../gui/wxpython/gui_modules/location_wizard.py:200
+#: ../gui/wxpython/location_wizard/wizard.py:164
msgid "Choose GRASS data directory:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:189
-#: ../gui/wxpython/location_wizard/wizard.py:2059
+#: ../gui/wxpython/gui_modules/location_wizard.py:211
+#: ../gui/wxpython/gui_modules/location_wizard.py:1967
+#: ../gui/wxpython/location_wizard/wizard.py:175
+#: ../gui/wxpython/location_wizard/wizard.py:1993
+#: ../gui/wxpython/scripts/r.li.setup.py:336
msgid "Location already exists in GRASS Database."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:193
+#: ../gui/wxpython/gui_modules/location_wizard.py:215
+#: ../gui/wxpython/location_wizard/wizard.py:179
msgid "Unable to create location"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:206
+#: ../gui/wxpython/gui_modules/location_wizard.py:228
+#: ../gui/wxpython/location_wizard/wizard.py:192
msgid ""
"Title of the location is limited only to one line and 256 characters. The "
"rest of the text will be ignored."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:213
+#: ../gui/wxpython/gui_modules/location_wizard.py:235
msgid "Choose method for creating a new location"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:220
+#: ../gui/wxpython/gui_modules/location_wizard.py:242
+#: ../gui/wxpython/location_wizard/wizard.py:206
msgid "Select coordinate system parameters from a list"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:223
+#: ../gui/wxpython/gui_modules/location_wizard.py:245
+#: ../gui/wxpython/location_wizard/wizard.py:209
msgid "Select EPSG code of spatial reference system"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:225
+#: ../gui/wxpython/gui_modules/location_wizard.py:247
+#: ../gui/wxpython/location_wizard/wizard.py:211
msgid "Read projection and datum terms from a georeferenced data file"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:228
-msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
+#: ../gui/wxpython/gui_modules/location_wizard.py:250
+#: ../gui/wxpython/location_wizard/wizard.py:214
+msgid "Read projection and datum terms from a WKT or PRJ file"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:231
+#: ../gui/wxpython/gui_modules/location_wizard.py:253
+#: ../gui/wxpython/location_wizard/wizard.py:217
msgid "Specify projection and datum terms using custom PROJ.4 parameters"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:234
-msgid "Create a generic Cartesian coordinate system (XY)"
+#: ../gui/wxpython/gui_modules/location_wizard.py:256
+msgid "Create an arbitrary non-earth coordinate system (XY)"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:335
+#: ../gui/wxpython/gui_modules/location_wizard.py:357
+#: ../gui/wxpython/location_wizard/wizard.py:321
msgid "Choose projection"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:351
-#: ../gui/wxpython/location_wizard/wizard.py:852
-#: ../gui/wxpython/location_wizard/wizard.py:1024
-#: ../gui/wxpython/location_wizard/wizard.py:1335
+#: ../gui/wxpython/gui_modules/location_wizard.py:373
+#: ../gui/wxpython/gui_modules/location_wizard.py:874
+#: ../gui/wxpython/gui_modules/location_wizard.py:1037
+#: ../gui/wxpython/gui_modules/location_wizard.py:1302
+#: ../gui/wxpython/location_wizard/wizard.py:337
+#: ../gui/wxpython/location_wizard/wizard.py:838
+#: ../gui/wxpython/location_wizard/wizard.py:1007
+#: ../gui/wxpython/location_wizard/wizard.py:1312
msgid "Code"
msgstr "Kods"
-#: ../gui/wxpython/gmodeler/frame.py:1323
-#: ../gui/wxpython/gmodeler/frame.py:1384
-msgid "Description"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:355
+#: ../gui/wxpython/gui_modules/location_wizard.py:378
+#: ../gui/wxpython/location_wizard/wizard.py:342
msgid "Projection code:"
msgstr "Projekcijas kods:"
-#: ../gui/wxpython/location_wizard/wizard.py:363
-#: ../gui/wxpython/location_wizard/wizard.py:865
-#: ../gui/wxpython/location_wizard/wizard.py:1041
+#: ../gui/wxpython/gui_modules/location_wizard.py:386
+#: ../gui/wxpython/gui_modules/location_wizard.py:888
+#: ../gui/wxpython/gui_modules/location_wizard.py:1050
+#: ../gui/wxpython/location_wizard/wizard.py:350
+#: ../gui/wxpython/location_wizard/wizard.py:852
+#: ../gui/wxpython/location_wizard/wizard.py:1025
msgid "Search in description:"
-msgstr ""
+msgstr "Meklēt pēc apraksta:"
-#: ../gui/wxpython/location_wizard/wizard.py:538
+#: ../gui/wxpython/gui_modules/location_wizard.py:560
+#: ../gui/wxpython/location_wizard/wizard.py:524
#, python-format
msgid "Unable to read list: %s"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:641
+#: ../gui/wxpython/gui_modules/location_wizard.py:663
+#: ../gui/wxpython/location_wizard/wizard.py:627
msgid "Choose projection parameters"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:655
+#: ../gui/wxpython/gui_modules/location_wizard.py:679
+#: ../gui/wxpython/location_wizard/wizard.py:643
msgid "Select datum or ellipsoid (next page)"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:662
+#: ../gui/wxpython/gui_modules/location_wizard.py:685
+#: ../gui/wxpython/location_wizard/wizard.py:649
msgid "Datum with associated ellipsoid"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:665
+#: ../gui/wxpython/gui_modules/location_wizard.py:688
+#: ../gui/wxpython/location_wizard/wizard.py:652
msgid "Ellipsoid only"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:722
+#: ../gui/wxpython/gui_modules/location_wizard.py:745
+#: ../gui/wxpython/location_wizard/wizard.py:709
#, python-format
msgid "You must enter a value for %s"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:734
-#: ../gui/wxpython/location_wizard/wizard.py:753
+#: ../gui/wxpython/gui_modules/location_wizard.py:757
+#: ../gui/wxpython/gui_modules/location_wizard.py:775
+#: ../gui/wxpython/location_wizard/wizard.py:721
+#: ../gui/wxpython/location_wizard/wizard.py:739
#, python-format
msgid " Enter parameters for %s projection "
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:830
+#: ../gui/wxpython/gui_modules/location_wizard.py:798
+#: ../gui/wxpython/location_wizard/wizard.py:762
+msgid "No"
+msgstr "Nē"
+msgid "Yes"
+msgstr "Jā"
+#: ../gui/wxpython/gui_modules/location_wizard.py:852
+#: ../gui/wxpython/location_wizard/wizard.py:816
msgid "Specify geodetic datum"
msgstr ""
msgid "Ellipsoid"
-msgstr ""
+msgstr "Elipsoīds"
-#: ../gui/wxpython/location_wizard/wizard.py:856
+#: ../gui/wxpython/gui_modules/location_wizard.py:879
+#: ../gui/wxpython/location_wizard/wizard.py:843
msgid "Datum code:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:995
+#: ../gui/wxpython/gui_modules/location_wizard.py:1014
+#: ../gui/wxpython/location_wizard/wizard.py:978
msgid "Specify ellipsoid"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1012
-msgid "Earth based"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1015
-msgid "Planetary bodies"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1029
+#: ../gui/wxpython/gui_modules/location_wizard.py:1042
+#: ../gui/wxpython/location_wizard/wizard.py:1013
msgid "Ellipsoid code:"
-msgstr ""
+msgstr "Elipsoīda kods:"
-#: ../gui/wxpython/location_wizard/wizard.py:1161
-#: ../gui/wxpython/location_wizard/wizard.py:1221
+#: ../gui/wxpython/gui_modules/location_wizard.py:1131
+#: ../gui/wxpython/gui_modules/location_wizard.py:1191
+#: ../gui/wxpython/location_wizard/wizard.py:1141
+#: ../gui/wxpython/location_wizard/wizard.py:1201
msgid "Select georeferenced file"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1166
+#: ../gui/wxpython/gui_modules/location_wizard.py:1136
+#: ../gui/wxpython/location_wizard/wizard.py:1146
msgid "Georeferenced file:"
-msgstr ""
+msgstr "Ģeoreferencēts fails:"
-#: ../gui/wxpython/location_wizard/wizard.py:1235
-#: ../gui/wxpython/location_wizard/wizard.py:1292
-msgid "Select Well Known Text (WKT) .prj file"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1205
+#: ../gui/wxpython/gui_modules/location_wizard.py:1262
+#: ../gui/wxpython/location_wizard/wizard.py:1215
+#: ../gui/wxpython/location_wizard/wizard.py:1272
+msgid "Select WKT file"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1240
-#, fuzzy
-msgid "WKT .prj file:"
-msgstr "Fails:"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1210
+#: ../gui/wxpython/location_wizard/wizard.py:1220
+msgid "WKT file:"
+msgstr "WKT fails:"
-#: ../gui/wxpython/location_wizard/wizard.py:1309
+#: ../gui/wxpython/gui_modules/location_wizard.py:1276
+#: ../gui/wxpython/location_wizard/wizard.py:1286
msgid "Choose EPSG Code"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1317
+#: ../gui/wxpython/gui_modules/location_wizard.py:1284
+#: ../gui/wxpython/location_wizard/wizard.py:1294
msgid "Path to the EPSG-codes file:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1471
+#: ../gui/wxpython/gui_modules/location_wizard.py:1286
+#: ../gui/wxpython/gui_modules/preferences.py:2005
+#: ../gui/wxpython/location_wizard/wizard.py:1296
+#: ../gui/wxpython/gui_core/preferences.py:1180
+msgid "EPSG code:"
+msgstr "EPSG kods:"
+msgid "Parameters"
+msgstr "Parametri"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1438
+#: ../gui/wxpython/location_wizard/wizard.py:1448
msgid "Choose EPSG codes file"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1500
+#: ../gui/wxpython/gui_modules/location_wizard.py:1467
+#: ../gui/wxpython/location_wizard/wizard.py:1477
#, python-format
msgid "Unable to read EPGS codes: %s"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1518
+#: ../gui/wxpython/gui_modules/location_wizard.py:1485
+#: ../gui/wxpython/location_wizard/wizard.py:1495
msgid "Choose method of specifying georeferencing parameters"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1526
+#: ../gui/wxpython/gui_modules/location_wizard.py:1493
+#: ../gui/wxpython/location_wizard/wizard.py:1503
msgid "Enter PROJ.4 parameters string:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1582
-#: ../gui/wxpython/location_wizard/wizard.py:1586
+#: ../gui/wxpython/gui_modules/location_wizard.py:1541
+#: ../gui/wxpython/gui_modules/location_wizard.py:1545
+#: ../gui/wxpython/location_wizard/wizard.py:1551
+#: ../gui/wxpython/location_wizard/wizard.py:1555
msgid "Datum transform is required."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1621
-#: ../gui/wxpython/rlisetup/wizard.py:924
+#: ../gui/wxpython/gui_modules/location_wizard.py:1567
+#: ../gui/wxpython/location_wizard/wizard.py:1577
+#: ../gui/wxpython/scripts/r.li.setup.py:591
msgid "Summary"
-msgstr ""
+msgstr "Kopsavilkums"
-#: ../gui/wxpython/location_wizard/wizard.py:1662
+#: ../gui/wxpython/gui_modules/location_wizard.py:1612
+#: ../gui/wxpython/location_wizard/wizard.py:1622
+#: ../gui/wxpython/scripts/r.li.setup.py:613
msgid "GRASS Database:"
-msgstr ""
+msgstr "GRASS datubāze:"
-#: ../gui/wxpython/location_wizard/wizard.py:1668
+#: ../gui/wxpython/gui_modules/location_wizard.py:1618
+#: ../gui/wxpython/location_wizard/wizard.py:1628
+#: ../gui/wxpython/scripts/r.li.setup.py:619
msgid "Location Name:"
-msgstr ""
+msgstr "Novietojuma nosaukums:"
-#: ../gui/wxpython/location_wizard/wizard.py:1674
+#: ../gui/wxpython/gui_modules/location_wizard.py:1624
+#: ../gui/wxpython/location_wizard/wizard.py:1634
msgid "Location Title:"
-msgstr ""
+msgstr "Novietojuma virsraksts:"
-#: ../gui/wxpython/location_wizard/wizard.py:1680
+#: ../gui/wxpython/gui_modules/location_wizard.py:1630
+#: ../gui/wxpython/location_wizard/wizard.py:1640
+#: ../gui/wxpython/scripts/r.li.setup.py:625
msgid "Projection:"
-msgstr ""
+msgstr "Projekcija:"
-#: ../gui/wxpython/location_wizard/wizard.py:1686
-msgid ""
-"PROJ.4 definition:\n"
-" (non-definitive)"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1636
+#: ../gui/wxpython/location_wizard/wizard.py:1646
+#: ../gui/wxpython/scripts/r.li.setup.py:660
+msgid "PROJ.4 definition:"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1789
+#: ../gui/wxpython/gui_modules/location_wizard.py:1709
+#: ../gui/wxpython/location_wizard/wizard.py:1719
+#: ../gui/wxpython/scripts/r.li.setup.py:716
#, python-format
msgid "Do you want to create GRASS location <%s>?"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1790
+#: ../gui/wxpython/gui_modules/location_wizard.py:1710
+#: ../gui/wxpython/location_wizard/wizard.py:1720
+#: ../gui/wxpython/scripts/r.li.setup.py:717
msgid "Create new location?"
-msgstr ""
+msgstr "Izveidot jaunu novietojumu?"
-#: ../gui/wxpython/location_wizard/wizard.py:1834
+#: ../gui/wxpython/gui_modules/location_wizard.py:1750
+#: ../gui/wxpython/location_wizard/wizard.py:1760
msgid "Define new GRASS Location"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1926
+#: ../gui/wxpython/gui_modules/location_wizard.py:1835
+#: ../gui/wxpython/location_wizard/wizard.py:1845
+msgid "Do you want to set the default region extents and resolution now?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1837
+#: ../gui/wxpython/location_wizard/wizard.py:1847
#, python-format
+msgid "Location <%s> created"
+msgstr "Novietojums <%s> ir izveidots:"
+#: ../gui/wxpython/gui_modules/location_wizard.py:1850
+#: ../gui/wxpython/location_wizard/wizard.py:1860
+#, python-format
msgid ""
"Unable to create new location. Location <%(loc)s> not created.\n"
"\n"
"Details: %(err)s"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1934
+#: ../gui/wxpython/gui_modules/location_wizard.py:1858
+#: ../gui/wxpython/location_wizard/wizard.py:1868
msgid "Location wizard canceled. Location not created."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2057
+#: ../gui/wxpython/gui_modules/location_wizard.py:1965
+#: ../gui/wxpython/location_wizard/wizard.py:1991
+#: ../gui/wxpython/scripts/r.li.setup.py:334
msgid "Unable to create new location"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2076
+#: ../gui/wxpython/gui_modules/location_wizard.py:1984
+#: ../gui/wxpython/location_wizard/wizard.py:2010
#, python-format
msgid ""
"Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will "
"need to change the default GIS data directory in the GRASS startup screen."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2081
+#: ../gui/wxpython/gui_modules/location_wizard.py:1989
+#: ../gui/wxpython/location_wizard/wizard.py:2015
+#: ../gui/wxpython/scripts/r.li.setup.py:362
msgid "New GIS data directory"
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2112
+#: ../gui/wxpython/gui_modules/location_wizard.py:2014
+#: ../gui/wxpython/location_wizard/wizard.py:2040
+#: ../gui/wxpython/scripts/r.li.setup.py:523
msgid "EPSG code missing."
msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2123
-#: ../gui/wxpython/location_wizard/wizard.py:2132
+#: ../gui/wxpython/gui_modules/location_wizard.py:2024
+#: ../gui/wxpython/gui_modules/location_wizard.py:2033
+#: ../gui/wxpython/location_wizard/wizard.py:2050
+#: ../gui/wxpython/location_wizard/wizard.py:2059
#, python-format
msgid "File <%s> not found."
-msgstr ""
+msgstr "Fails <%s> nav atrasts."
-#: ../gui/wxpython/location_wizard/dialogs.py:42
+#: ../gui/wxpython/gui_modules/location_wizard.py:2092
+#: ../gui/wxpython/location_wizard/dialogs.py:36
msgid "Set default region extent and resolution"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:89
+#: ../gui/wxpython/gui_modules/location_wizard.py:2139
+#: ../gui/wxpython/location_wizard/dialogs.py:83
msgid "&Set region"
-msgstr ""
+msgstr "&Iestatīt reģionu"
-#: ../gui/wxpython/location_wizard/dialogs.py:119
+#: ../gui/wxpython/gui_modules/location_wizard.py:2169
+#: ../gui/wxpython/location_wizard/dialogs.py:113
msgid "Invalid location selected."
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:136
+#: ../gui/wxpython/gui_modules/location_wizard.py:2186
+#: ../gui/wxpython/location_wizard/dialogs.py:130
msgid "Invalid region"
-msgstr ""
+msgstr "Nederīgs reģions"
-#: ../gui/wxpython/location_wizard/dialogs.py:166
+#: ../gui/wxpython/gui_modules/location_wizard.py:2216
+#: ../gui/wxpython/location_wizard/dialogs.py:160
msgid "Click here to show 3D settings"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:167
+#: ../gui/wxpython/gui_modules/location_wizard.py:2217
+#: ../gui/wxpython/location_wizard/dialogs.py:161
msgid "Click here to hide 3D settings"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:190
-#: ../gui/wxpython/location_wizard/dialogs.py:472
+#: ../gui/wxpython/gui_modules/location_wizard.py:2240
+#: ../gui/wxpython/gui_modules/location_wizard.py:2521
+#: ../gui/wxpython/location_wizard/dialogs.py:184
+#: ../gui/wxpython/location_wizard/dialogs.py:465
#, python-format
msgid "Rows: %d"
-msgstr ""
+msgstr "Rindas: %d"
-#: ../gui/wxpython/location_wizard/dialogs.py:191
-#: ../gui/wxpython/location_wizard/dialogs.py:473
+#: ../gui/wxpython/gui_modules/location_wizard.py:2241
+#: ../gui/wxpython/gui_modules/location_wizard.py:2522
+#: ../gui/wxpython/location_wizard/dialogs.py:185
+#: ../gui/wxpython/location_wizard/dialogs.py:466
#, python-format
msgid "Cols: %d"
-msgstr ""
+msgstr "Kolonas: %d"
-#: ../gui/wxpython/location_wizard/dialogs.py:192
-#: ../gui/wxpython/location_wizard/dialogs.py:474
+#: ../gui/wxpython/gui_modules/location_wizard.py:2242
+#: ../gui/wxpython/gui_modules/location_wizard.py:2523
+#: ../gui/wxpython/location_wizard/dialogs.py:186
+#: ../gui/wxpython/location_wizard/dialogs.py:467
#, python-format
msgid "Cells: %d"
-msgstr ""
+msgstr "Šūnas: %d"
-#: ../gui/wxpython/location_wizard/dialogs.py:234
-#: ../gui/wxpython/location_wizard/dialogs.py:476
+#: ../gui/wxpython/gui_modules/location_wizard.py:2283
+#: ../gui/wxpython/gui_modules/location_wizard.py:2525
+#: ../gui/wxpython/location_wizard/dialogs.py:227
+#: ../gui/wxpython/location_wizard/dialogs.py:469
#, python-format
msgid "Depth: %d"
-msgstr ""
+msgstr "Dziļums: %d"
-#: ../gui/wxpython/location_wizard/dialogs.py:235
-#: ../gui/wxpython/location_wizard/dialogs.py:477
+#: ../gui/wxpython/gui_modules/location_wizard.py:2284
+#: ../gui/wxpython/gui_modules/location_wizard.py:2526
+#: ../gui/wxpython/location_wizard/dialogs.py:228
+#: ../gui/wxpython/location_wizard/dialogs.py:470
#, python-format
msgid "3D Cells: %d"
-msgstr ""
+msgstr "3D šūnas: %d"
-#: ../gui/wxpython/location_wizard/dialogs.py:254
+#: ../gui/wxpython/gui_modules/location_wizard.py:2303
+#: ../gui/wxpython/location_wizard/dialogs.py:247
msgid "T-B resolution"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:317
+#: ../gui/wxpython/gui_modules/location_wizard.py:2366
+#: ../gui/wxpython/location_wizard/dialogs.py:310
msgid "North"
-msgstr ""
+msgstr "Ziemeļi"
-#: ../gui/wxpython/location_wizard/dialogs.py:325
+#: ../gui/wxpython/gui_modules/location_wizard.py:2374
+#: ../gui/wxpython/location_wizard/dialogs.py:318
msgid "West"
-msgstr ""
+msgstr "Rietumi"
-#: ../gui/wxpython/location_wizard/dialogs.py:345
+#: ../gui/wxpython/gui_modules/location_wizard.py:2394
+#: ../gui/wxpython/location_wizard/dialogs.py:338
msgid "East"
-msgstr ""
+msgstr "Austrumi"
-#: ../gui/wxpython/location_wizard/dialogs.py:354
+#: ../gui/wxpython/gui_modules/location_wizard.py:2403
+#: ../gui/wxpython/location_wizard/dialogs.py:347
msgid "South"
-msgstr ""
+msgstr "Dienvidi"
-#: ../gui/wxpython/location_wizard/dialogs.py:358
+#: ../gui/wxpython/gui_modules/location_wizard.py:2407
+#: ../gui/wxpython/location_wizard/dialogs.py:351
msgid "N-S resolution"
-msgstr ""
+msgstr "Z-D izšķirtspēja"
-#: ../gui/wxpython/location_wizard/dialogs.py:366
+#: ../gui/wxpython/gui_modules/location_wizard.py:2415
+#: ../gui/wxpython/location_wizard/dialogs.py:359
msgid "E-W resolution"
-msgstr ""
+msgstr "A-R izšķirtspēja"
-#: ../gui/wxpython/location_wizard/dialogs.py:444
+#: ../gui/wxpython/gui_modules/location_wizard.py:2493
+#: ../gui/wxpython/location_wizard/dialogs.py:437
#, python-format
msgid "Invalid value: %s"
-msgstr ""
+msgstr "Nederīga vētība: %s"
-#: ../gui/wxpython/location_wizard/dialogs.py:528
+#: ../gui/wxpython/gui_modules/location_wizard.py:2578
+#: ../gui/wxpython/location_wizard/dialogs.py:521
msgid "Select datum transformation"
msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:553
+#: ../gui/wxpython/gui_modules/location_wizard.py:2603
+#: ../gui/wxpython/location_wizard/dialogs.py:546
msgid "Select from list of datum transformations"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:43
+#: ../gui/wxpython/gui_modules/gdialogs.py:114
+#: ../gui/wxpython/gui_core/dialogs.py:117
+msgid "Type of element:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:145
+#: ../gui/wxpython/gui_core/dialogs.py:148
+msgid "Select GRASS location and mapset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:146
+#: ../gui/wxpython/gui_core/dialogs.py:149
+msgid "Name of GRASS location:"
+msgstr "GRASS novietojuma nosaukums:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:166
+#: ../gui/wxpython/gui_modules/gdialogs.py:198
+#: ../gui/wxpython/gui_core/dialogs.py:169
+#: ../gui/wxpython/gui_core/dialogs.py:201
+msgid "Name of mapset:"
+msgstr "Karšu kopas nosaukums:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:196
+#: ../gui/wxpython/gui_core/dialogs.py:199
+msgid "Select mapset in GRASS location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:240
+#: ../gui/wxpython/gui_core/dialogs.py:243
+msgid "Name for new vector map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:252
+#: ../gui/wxpython/gui_core/dialogs.py:255
+msgid "Create attribute table"
+msgstr "Izveidot atribūtu tabulu"
+#: ../gui/wxpython/gui_modules/gdialogs.py:267
+#: ../gui/wxpython/gui_modules/preferences.py:1744
+#: ../gui/wxpython/gui_core/preferences.py:818
+#: ../gui/wxpython/gui_core/dialogs.py:270
+msgid "Add created map into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:303
+#: ../gui/wxpython/gui_modules/preferences.py:1963
+#: ../gui/wxpython/gui_core/preferences.py:1137
+#: ../gui/wxpython/gui_core/dialogs.py:306
+msgid "Key column:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:399
+#: ../gui/wxpython/gui_core/dialogs.py:402
#, python-format
+msgid "Unable to create vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:404
+#: ../gui/wxpython/gui_core/dialogs.py:407
+#, python-format
msgid ""
-"Loading imagery lib failed.\n"
-"%s"
+"Invalid or empty key column.\n"
+"Unable to create vector map <%s>."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:79
-msgid "GRASS GIS Supervised Classification Tool"
+#: ../gui/wxpython/gui_modules/gdialogs.py:431
+#: ../gui/wxpython/gui_core/dialogs.py:434
+#, python-format
+msgid ""
+"Vector map <%s> already exists in the current mapset. Do you want to "
+"overwrite it?"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:301
-msgid "IClass Toolbar"
+#: ../gui/wxpython/gui_modules/gdialogs.py:434
+#: ../gui/wxpython/gui_core/dialogs.py:437
+msgid "Overwrite?"
+msgstr "Pārrakstīt?"
+#: ../gui/wxpython/gui_modules/gdialogs.py:491
+#: ../gui/wxpython/gui_core/dialogs.py:494
+#, python-format
+msgid "New vector map <%s> created"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:313
-msgid "IClass Misc Toolbar"
+#: ../gui/wxpython/gui_modules/gdialogs.py:513
+#: ../gui/wxpython/gui_core/dialogs.py:516
+msgid "Load region:"
+msgstr "Ielādēt reģionu:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:517
+#: ../gui/wxpython/gui_core/dialogs.py:520
+msgid "Save region:"
+msgstr "Saglabāt reģionu:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:586
+#: ../gui/wxpython/gui_core/dialogs.py:589
+msgid "Set size and position"
+msgstr "Iestatīt izmēru un novietojumu"
+#: ../gui/wxpython/gui_modules/gdialogs.py:587
+#: ../gui/wxpython/gui_core/dialogs.py:590
+msgid ""
+"Click and drag on the map display to set legend size and position and then "
+"press OK"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:330
-msgid "Digitization Toolbar"
+#: ../gui/wxpython/gui_modules/gdialogs.py:598
+#: ../gui/wxpython/gui_core/dialogs.py:601
+#, python-format
+msgid ""
+"Drag %s with mouse in pointer mode to position.\n"
+"Double-click to change options."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:354
-msgid "Plots"
+#: ../gui/wxpython/gui_modules/gdialogs.py:601
+#: ../gui/wxpython/gui_core/dialogs.py:604
+msgid ""
+"\n"
+"Define raster map name for legend in properties dialog."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:374
-msgid "Preview Display"
+#: ../gui/wxpython/gui_modules/gdialogs.py:650
+#: ../gui/wxpython/gui_core/dialogs.py:653
+#, python-format
+msgid "Legend of raster map <%s>"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:377
-msgid "Training Areas Display"
+#: ../gui/wxpython/gui_modules/gdialogs.py:784
+#: ../gui/wxpython/gui_core/dialogs.py:788
+msgid "Show text object"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:445 ../gui/wxpython/mapdisp/frame.py:1160
-msgid "Zoom to computational region"
+#: ../gui/wxpython/gui_modules/gdialogs.py:823
+#: ../gui/wxpython/gui_modules/preferences.py:1426
+#: ../gui/wxpython/gui_modules/preferences.py:1566
+#: ../gui/wxpython/gui_core/preferences.py:428
+#: ../gui/wxpython/gui_core/preferences.py:601
+#: ../gui/wxpython/gui_core/dialogs.py:827
+msgid "Set font"
+msgstr "Iestatīt fontu"
+#: ../gui/wxpython/gui_modules/gdialogs.py:834
+#: ../gui/wxpython/gui_core/dialogs.py:838
+msgid ""
+"Drag text with mouse in pointer mode to position.\n"
+"Double-click to change options"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:447
-msgid "Adjust Training Area Display to Preview Display"
+#: ../gui/wxpython/gui_modules/gdialogs.py:915
+#: ../gui/wxpython/gui_core/dialogs.py:919
+msgid "Create or edit imagery groups"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:448
-msgid "Adjust Preview display to Training Area Display"
+#: ../gui/wxpython/gui_modules/gdialogs.py:933
+#: ../gui/wxpython/gui_core/dialogs.py:937
+msgid "Apply changes to selected group and close dialog"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:449
-#, fuzzy
-msgid "Display synchronization ON"
-msgstr "Attēlot reģionu"
+#: ../gui/wxpython/gui_modules/gdialogs.py:934
+#: ../gui/wxpython/gui_core/dialogs.py:938
+msgid "Apply changes to selected group"
+msgstr ""
-#: ../gui/wxpython/iclass/frame.py:450
-msgid "Display synchronization OFF"
+#: ../gui/wxpython/gui_modules/gdialogs.py:935
+#: ../gui/wxpython/gui_core/dialogs.py:939
+msgid "Close dialog, changes are not applied"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:520
-msgid "All changes will be lost. Do you want to continue?"
+#: ../gui/wxpython/gui_modules/gdialogs.py:976
+#: ../gui/wxpython/gui_core/dialogs.py:980
+msgid "Select the group you want to edit or enter name of new group:"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:528
-msgid "Import vector map"
+#: ../gui/wxpython/gui_modules/gdialogs.py:987
+#: ../gui/wxpython/gui_core/dialogs.py:991
+msgid "Layers in selected group:"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:547
-#, python-format
-msgid "No areas in vector map <%s>.\n"
+#: ../gui/wxpython/gui_modules/gdialogs.py:999
+#: ../gui/wxpython/gui_core/dialogs.py:1003
+msgid "Select map layers and add them to the list."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:549
-#, python-format
-msgid "Vector map <%s> contains points or lines, these features are ignored."
+#: ../gui/wxpython/gui_modules/gdialogs.py:1003
+#: ../gui/wxpython/gui_core/dialogs.py:1007
+msgid "Remove selected layer(s) from list."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:574
-#, fuzzy, python-format
-msgid "Unable to open vector map <%s>"
-msgstr "Jauna vektoru karte"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1024
+#: ../gui/wxpython/gui_core/dialogs.py:1032
+msgid "Add selected map layers into group"
+msgstr ""
-#: ../gui/wxpython/iclass/frame.py:581
+#: ../gui/wxpython/gui_modules/gdialogs.py:1058
+#: ../gui/wxpython/gui_core/dialogs.py:1065
#, python-format
-msgid "Unable to copy vector features from <%s>"
+msgid "Group <%s> was changed, do you want to apply changes?"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:591
-msgid "Unable to open temporary vector map"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1060
+#: ../gui/wxpython/gui_core/dialogs.py:1067
+msgid "Unapplied changes"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:681
-msgid "No training areas to export."
+#: ../gui/wxpython/gui_modules/gdialogs.py:1132
+#: ../gui/wxpython/gui_core/dialogs.py:1149
+#, python-format
+msgid "No changes to apply in group <%s>."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:693
+#: ../gui/wxpython/gui_modules/gdialogs.py:1135
+#: ../gui/wxpython/gui_core/dialogs.py:1152
#, python-format
-msgid "%d training areas (%d classes) exported to vector map <%s>."
+msgid "Group <%s> was successfully created."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:877
-msgid "Failed to create temporary vector map."
+#: ../gui/wxpython/gui_modules/gdialogs.py:1137
+#: ../gui/wxpython/gui_core/dialogs.py:1154
+#, python-format
+msgid "Group <%s> was successfully changed."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:953
+#: ../gui/wxpython/gui_modules/gdialogs.py:1140
+#: ../gui/wxpython/gui_core/dialogs.py:1157
#, python-format
-msgid "No area in category %s. Category skipped."
+msgid "Creating of new group <%s> failed."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:956
-msgid "Analysis failed."
+#: ../gui/wxpython/gui_modules/gdialogs.py:1142
+#: ../gui/wxpython/gui_core/dialogs.py:1159
+#, python-format
+msgid "Changing of group <%s> failed."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:963
-msgid "results"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1171
+#: ../gui/wxpython/gui_core/dialogs.py:1188
+msgid "No group selected."
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:969
-msgid "No imagery group selected."
+#: ../gui/wxpython/gui_modules/gdialogs.py:1228
+#: ../gui/wxpython/gui_core/dialogs.py:1283
+msgid "Use fully-qualified map names"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:974
-msgid ""
-"Due to recent changes in classes, signatures can be outdated and should be "
-"recalculated. Do you still want to continue?"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1235
+#: ../gui/wxpython/gui_core/dialogs.py:1547
+#, python-format
+msgid "Dynamic series (%s)"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:977
-msgid "Outdated signatures"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1273
+#: ../gui/wxpython/gui_core/dialogs.py:1311
+msgid "Map type:"
+msgstr "Kartes tips:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1291
+#: ../gui/wxpython/gui_core/dialogs.py:1326
+msgid "Select toggle"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:993
-#, python-format
-msgid ""
-"A signature file named %s already exists.\n"
-"Do you want to replace it?"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1298
+#: ../gui/wxpython/gui_core/dialogs.py:1333
+msgid "Mapset:"
+msgstr "Karšu kopa:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1308
+#: ../gui/wxpython/gui_core/dialogs.py:1343
+msgid "Pattern:"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:995 ../gui/wxpython/gmodeler/frame.py:440
-msgid "File already exists"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1320
+#: ../gui/wxpython/gui_core/dialogs.py:1359
+msgid "List of maps:"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1041
-msgid "No imagery group selected. Operation canceled."
+#: ../gui/wxpython/gui_modules/gdialogs.py:1374
+#: ../gui/wxpython/gui_modules/gdialogs.py:2046
+#: ../gui/wxpython/gui_modules/dbm.py:1128
+#: ../gui/wxpython/gui_core/dialogs.py:1412
+#: ../gui/wxpython/gui_core/dialogs.py:2150
+#: ../gui/wxpython/dbmgr/manager.py:1132
+msgid "Select all"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1050
-#, python-format
-msgid ""
-"Group <%(group)s> does not have enough files (it has %(files)d files). "
-"Operation canceled."
+#: ../gui/wxpython/gui_modules/gdialogs.py:1375
+#: ../gui/wxpython/gui_core/dialogs.py:1413
+msgid "Invert selection"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1059
-msgid "No areas given. Operation canceled."
+#: ../gui/wxpython/gui_modules/gdialogs.py:1376
+#: ../gui/wxpython/gui_modules/gdialogs.py:2047
+#: ../gui/wxpython/gui_modules/dbm.py:1129
+#: ../gui/wxpython/gui_core/dialogs.py:1414
+#: ../gui/wxpython/gui_core/dialogs.py:2151
+#: ../gui/wxpython/dbmgr/manager.py:1133
+msgid "Deselect all"
msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1074
-msgid "Vector features are outside raster layers. Operation canceled."
+#: ../gui/wxpython/gui_modules/gdialogs.py:1482
+#: ../gui/wxpython/gui_core/dialogs.py:1572
+msgid "Multiple import"
msgstr ""
-#: ../gui/wxpython/iclass/statistics.py:29
-msgid "Loading imagery lib failed"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1496
+#: ../gui/wxpython/gui_core/dialogs.py:1586
+#, python-format
+msgid " List of %s layers "
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:33
-msgid "Set opacity level"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1501
+#: ../gui/wxpython/gui_core/dialogs.py:1591
+msgid "Layer id"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:35 ../gui/wxpython/iclass/dialogs.py:274
-msgid "Class manager"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1502
+#: ../gui/wxpython/gui_core/dialogs.py:1592
+msgid "Layer name"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:37 ../gui/wxpython/iclass/dialogs.py:42
-#: ../gui/wxpython/iscatt/toolbars.py:43
-msgid "Select imagery group"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1503
+#: ../gui/wxpython/gui_core/dialogs.py:1593
+msgid "Name for GRASS map (editable)"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:39
-msgid "Run analysis"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1510
+#: ../gui/wxpython/gui_modules/ghelp.py:821
+#: ../gui/wxpython/gui_core/dialogs.py:1600
+#: ../gui/wxpython/modules/extensions.py:67
+msgid "Options"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:41 ../gui/wxpython/iclass/dialogs.py:569
-msgid "Save signature file"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1556
+#: ../gui/wxpython/gui_modules/gdialogs.py:1831
+#: ../gui/wxpython/gui_modules/ghelp.py:848
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:136
+#: ../gui/wxpython/gui_core/dialogs.py:1646
+#: ../gui/wxpython/gui_core/dialogs.py:1935
+#: ../gui/wxpython/modules/extensions.py:102
+#: ../gui/wxpython/modules/extensions.py:406
+#: ../gui/wxpython/modules/mcalc_builder.py:132
+msgid "Command dialog"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:43
-msgid "Delete selected map layer"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1710
+#: ../gui/wxpython/gui_core/dialogs.py:1801
+msgid "Add linked layers into layer tree"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:45
-msgid "Export training areas to vector map"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1717
+#: ../gui/wxpython/gui_core/dialogs.py:1808
+msgid "&Link"
+msgstr "&Saite"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1718
+#: ../gui/wxpython/gui_core/dialogs.py:1809
+msgid "Link selected layers"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:47
-msgid "Import training areas from vector map"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1720
+#: ../gui/wxpython/gui_modules/gdialogs.py:1722
+#: ../gui/wxpython/gui_modules/gdialogs.py:1727
+#: ../gui/wxpython/gui_modules/gdialogs.py:1729
+#: ../gui/wxpython/gui_modules/ghelp.py:849
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:137
+#: ../gui/wxpython/gui_core/dialogs.py:1811
+#: ../gui/wxpython/gui_core/dialogs.py:1813
+#: ../gui/wxpython/gui_core/dialogs.py:1818
+#: ../gui/wxpython/gui_core/dialogs.py:1820
+#: ../gui/wxpython/modules/extensions.py:103
+#: ../gui/wxpython/modules/extensions.py:407
+#: ../gui/wxpython/modules/mcalc_builder.py:133
+#, python-format
+msgid "Open %s dialog"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:66
-msgid "Training"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1823
+#: ../gui/wxpython/gui_core/dialogs.py:1927
+msgid "Define output format for vector data"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:70
-msgid "Set map canvas for "
+#: ../gui/wxpython/gui_modules/gdialogs.py:1825
+#: ../gui/wxpython/gui_core/dialogs.py:1929
+msgid "Define output format for raster data"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:72
-msgid "/ Zoom to map"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1836
+#: ../gui/wxpython/gui_core/dialogs.py:1940
+msgid "Set external format and close dialog"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:242
-#: ../gui/wxpython/iclass/toolbars.py:247
-msgid "std dev"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1905
+#: ../gui/wxpython/gui_core/dialogs.py:2009
+msgid "Import DXF layers"
msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:317
-msgid "Add raster map"
+#: ../gui/wxpython/gui_modules/gdialogs.py:1909
+#: ../gui/wxpython/gui_core/dialogs.py:2013
+msgid "Choose DXF file to import"
msgstr ""
-#: ../gui/wxpython/iclass/g.gui.iclass.py:72
-#: ../gui/wxpython/iclass/dialogs.py:202
-msgid "Group <%s> not found"
-msgstr "Karte <%s> nav atrasta."
+#: ../gui/wxpython/gui_modules/gdialogs.py:2114
+#: ../gui/wxpython/gui_core/dialogs.py:2218
+msgid "Set Map Layer Opacity"
+msgstr ""
-#: ../gui/wxpython/iclass/g.gui.iclass.py:102
-#, python-format
-msgid "Loading raster map <%s>..."
+#: ../gui/wxpython/gui_modules/gdialogs.py:2141
+#: ../gui/wxpython/gui_core/dialogs.py:2245
+msgid "opaque"
msgstr ""
-#: ../gui/wxpython/iclass/g.gui.iclass.py:105
-#, python-format
-msgid "Loading training map <%s>..."
+#: ../gui/wxpython/gui_modules/gdialogs.py:2260
+#: ../gui/wxpython/gui_core/dialogs.py:2333
+msgid "Set image size"
msgstr ""
-#: ../gui/wxpython/iclass/plots.py:66
-msgid "Histograms"
+#: ../gui/wxpython/gui_modules/gdialogs.py:2269
+#: ../gui/wxpython/gui_core/dialogs.py:2342
+msgid "Image size"
msgstr ""
-#: ../gui/wxpython/iclass/plots.py:67
-msgid "Coincident plots"
+#: ../gui/wxpython/gui_modules/gdialogs.py:2316
+#: ../gui/wxpython/gui_core/dialogs.py:2389
+msgid "Template:"
+msgstr "Šablons:"
+#: ../gui/wxpython/gui_modules/gdialogs.py:2354
+#: ../gui/wxpython/gui_core/dialogs.py:2427
+msgid "GRASS GIS SQL Query Utility"
msgstr ""
-#: ../gui/wxpython/iclass/plots.py:68
-msgid "Scatter plots"
+#: ../gui/wxpython/gui_modules/gdialogs.py:2365
+#: ../gui/wxpython/gui_core/dialogs.py:2438
+msgid " SQL statement "
msgstr ""
-#: ../gui/wxpython/iclass/plots.py:83
+#: ../gui/wxpython/gui_modules/psmap.py:615
+#, fuzzy
+msgid "North arrow"
+msgstr "Ziemeļu bulta"
+#: ../gui/wxpython/gui_modules/menudata.py:89
+#: ../gui/wxpython/core/menudata.py:84
+msgid "Unknow tag"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:70
+#: ../gui/wxpython/dbmgr/dialogs.py:71
#, python-format
msgid ""
-"Scatter plot functionality is disabled. Reason:\n"
-"Unable to import packages needed for scatter plot.\n"
-"%s"
+"No attribute table found.\n"
+"\n"
+"Do you want to create a new attribute table and defined a link to vector map "
+"<%s>?"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:73 ../gui/wxpython/gcp/manager.py:464
-msgid "Create/edit group..."
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:73
+#: ../gui/wxpython/dbmgr/dialogs.py:74
+msgid "Create table?"
+msgstr "Izveidot tabulu?"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:93
+#: ../gui/wxpython/dbmgr/dialogs.py:94
+msgid "Close dialog on submit"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:79
-msgid "Name of imagery group is missing."
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:105
+#: ../gui/wxpython/dbmgr/dialogs.py:106
+msgid "No attributes found"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:88
-msgid "Name of imagery group:"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:113
+#: ../gui/wxpython/dbmgr/dialogs.py:114
+msgid "Define attributes"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:101
-msgid "Name of imagery subgroup:"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:115
+#: ../gui/wxpython/dbmgr/dialogs.py:116
+msgid "Display attributes"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:184
-msgid "Please choose a subgroup."
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:119
+#: ../gui/wxpython/dbmgr/dialogs.py:120
+msgid "&Reload"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:187
-msgid "Subgroup <%s> not found in group <%s>"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:120
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:564
+#: ../gui/wxpython/dbmgr/dialogs.py:121 ../gui/wxpython/dbmgr/dialogs.py:589
+msgid "&Submit"
+msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:193
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:138
+#: ../gui/wxpython/gui_modules/vdigit.py:953
+#: ../gui/wxpython/dbmgr/dialogs.py:139 ../gui/wxpython/vdigit/dialogs.py:166
+msgid "Feature id:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:403
+#: ../gui/wxpython/dbmgr/dialogs.py:428
+msgid "Unknown"
+msgstr "Nezināms"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:460
+#: ../gui/wxpython/gui_modules/dbm.py:2288
+#: ../gui/wxpython/gui_modules/dbm.py:2403
+#: ../gui/wxpython/gui_modules/dbm.py:2652
+#: ../gui/wxpython/gui_modules/vdigit.py:395
+#: ../gui/wxpython/gui_modules/vdigit.py:397
+#: ../gui/wxpython/gui_modules/vdigit.py:898
+#: ../gui/wxpython/gui_modules/vdigit.py:1342
+#: ../gui/wxpython/dbmgr/dialogs.py:485 ../gui/wxpython/dbmgr/manager.py:2314
+#: ../gui/wxpython/dbmgr/manager.py:2427 ../gui/wxpython/dbmgr/manager.py:2678
+#: ../gui/wxpython/vdigit/preferences.py:362
+#: ../gui/wxpython/vdigit/preferences.py:364
+#: ../gui/wxpython/vdigit/dialogs.py:111 ../gui/wxpython/vdigit/dialogs.py:555
+msgid "Layer"
+msgstr "Slānis"
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:461
+#: ../gui/wxpython/gui_modules/dbm_dialogs.py:578
+#: ../gui/wxpython/gui_modules/vdigit.py:905
+#: ../gui/wxpython/gui_modules/vdigit.py:1343
+#: ../gui/wxpython/dbmgr/dialogs.py:486 ../gui/wxpython/dbmgr/dialogs.py:604
+#: ../gui/wxpython/vdigit/dialogs.py:118 ../gui/wxpython/vdigit/dialogs.py:556
+msgid "Category"
+msgstr "Kategorija"
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:1110
#, python-format
-msgid ""
-"No data found in subgroup <%s> of group <%s>.\n"
+msgid "Failed to read instruction %s: file %s not found."
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:198
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3211
+msgid "properties"
+msgstr "īpašības"
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:5971
#, python-format
-msgid ""
-"No data found in group <%s>.\n"
+msgid "size: %s x %s pts"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:245
-msgid "Name of map is missing."
+#: ../gui/wxpython/gui_modules/vclean.py:37
+msgid "set up vector cleaning tools"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:252
-#: ../gui/wxpython/gmodeler/dialogs.py:77
-msgid "Name of raster map:"
+#: ../gui/wxpython/gui_modules/vclean.py:76
+#: ../gui/wxpython/modules/vclean.py:68
+msgid "break lines/boundaries"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:254
-#: ../gui/wxpython/gmodeler/dialogs.py:79
-msgid "Name of vector map:"
+#: ../gui/wxpython/gui_modules/vclean.py:77
+#: ../gui/wxpython/modules/vclean.py:69
+msgid "remove duplicates"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:289 ../gui/wxpython/iscatt/frame.py:129
-msgid "Classes"
+#: ../gui/wxpython/gui_modules/vclean.py:78
+#: ../gui/wxpython/modules/vclean.py:70
+msgid "remove dangles"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:369 ../gui/wxpython/iscatt/frame.py:375
-msgid "Class name"
+#: ../gui/wxpython/gui_modules/vclean.py:79
+#: ../gui/wxpython/modules/vclean.py:71
+msgid "change boundary dangles to lines"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:402 ../gui/wxpython/iscatt/frame.py:415
-msgid "Please use only ASCII characters."
+#: ../gui/wxpython/gui_modules/vclean.py:80
+#: ../gui/wxpython/modules/vclean.py:72
+msgid "remove bridges"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:512
-msgid "Zoom to training areas of selected class"
+#: ../gui/wxpython/gui_modules/vclean.py:81
+#: ../gui/wxpython/modules/vclean.py:73
+msgid "change bridges to lines"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:626
-msgid "Enter name of signature file:"
+#: ../gui/wxpython/gui_modules/vclean.py:82
+#: ../gui/wxpython/modules/vclean.py:74
+msgid "snap lines/boundaries"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:635
-msgid "Signature file path:"
+#: ../gui/wxpython/gui_modules/vclean.py:83
+#: ../gui/wxpython/modules/vclean.py:75
+msgid "remove duplicate area centroids"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:677
-msgid "Export training areas"
+#: ../gui/wxpython/gui_modules/vclean.py:84
+#: ../gui/wxpython/modules/vclean.py:76
+msgid "break polygons"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:721 ../gui/wxpython/iscatt/dialogs.py:256
-msgid "Enter name of new vector map:"
+#: ../gui/wxpython/gui_modules/vclean.py:85
+#: ../gui/wxpython/modules/vclean.py:77
+msgid "prune lines/boundaries"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:731
-msgid "Export attribute table"
+#: ../gui/wxpython/gui_modules/vclean.py:86
+#: ../gui/wxpython/modules/vclean.py:78
+msgid "remove small areas"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:733
-msgid "Export attribute table containing computed statistical data"
+#: ../gui/wxpython/gui_modules/vclean.py:87
+#: ../gui/wxpython/modules/vclean.py:79
+msgid "remove lines/boundaries of zero length"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:771
-#, python-format
-msgid "Vector map <%s> already exists. Do you want to overwrite it?"
+#: ../gui/wxpython/gui_modules/vclean.py:88
+#: ../gui/wxpython/modules/vclean.py:80
+msgid "remove small angles at nodes"
msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:773
-#, python-format
-msgid "Vector <%s> exists"
+#: ../gui/wxpython/gui_modules/vclean.py:121
+#: ../gui/wxpython/gui_modules/vclean.py:122
+#: ../gui/wxpython/modules/vclean.py:31 ../gui/wxpython/modules/vclean.py:113
+msgid "Set up vector cleaning tools"
msgstr ""
-#: ../gui/wxpython/iclass/digit.py:57
-msgid ""
-"You are trying to create a training area outside the computational region. "
-"Please, use g.region to set the appropriate region first."
+#: ../gui/wxpython/gui_modules/vclean.py:124
+#: ../gui/wxpython/modules/vclean.py:115
+msgid "Choose cleaning tools and set thresholds"
msgstr ""
-#: ../gui/wxpython/iclass/digit.py:66
-msgid ""
-"In order to create a training area, you have to select class first.\n"
-"\n"
-"There is no class yet, do you want to create one?"
+#: ../gui/wxpython/gui_modules/vclean.py:128
+#: ../gui/wxpython/modules/vclean.py:119
+msgid "Select input vector map:"
msgstr ""
-#: ../gui/wxpython/iclass/digit.py:70
-#: ../gui/wxpython/iscatt/controllers.py:290
-msgid "No class selected"
+#: ../gui/wxpython/gui_modules/vclean.py:134
+#: ../gui/wxpython/modules/vclean.py:125
+msgid " Feature type: "
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:31
-msgid "No GRASS-python library found."
+#: ../gui/wxpython/gui_modules/vclean.py:138
+#: ../gui/wxpython/modules/vclean.py:129
+msgid "Select output vector map:"
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:66
-msgid "Input Data"
+#: ../gui/wxpython/gui_modules/vclean.py:168
+#: ../gui/wxpython/gui_modules/menuform.py:510
+#: ../gui/wxpython/gui_core/forms.py:467 ../gui/wxpython/modules/vclean.py:159
+msgid "Copy the current command string to the clipboard (Ctrl+C)"
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:72
-msgid "Point dataset:"
+#: ../gui/wxpython/gui_modules/vclean.py:205
+#: ../gui/wxpython/modules/vclean.py:195
+msgid "line"
+msgstr "līnija"
+#: ../gui/wxpython/gui_modules/vclean.py:206
+#: ../gui/wxpython/modules/vclean.py:196
+msgid "boundary"
+msgstr "robeža"
+#: ../gui/wxpython/gui_modules/vclean.py:207
+#: ../gui/wxpython/modules/vclean.py:197
+msgid "centroid"
+msgstr "centroīds"
+#: ../gui/wxpython/gui_modules/vclean.py:208
+#: ../gui/wxpython/gui_modules/vdigit.py:450
+#: ../gui/wxpython/modules/vclean.py:198
+#: ../gui/wxpython/vdigit/preferences.py:417
+msgid "area"
+msgstr "laukums"
+#: ../gui/wxpython/gui_modules/vclean.py:209
+#: ../gui/wxpython/modules/vclean.py:199
+msgid "face"
+msgstr "fasete"
+#: ../gui/wxpython/gui_modules/vclean.py:363
+#: ../gui/wxpython/modules/vclean.py:355
+#, python-format
+msgid "%s. cleaning tool removed, will be ignored"
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:84
-msgid "Numeric column:"
+#: ../gui/wxpython/gui_modules/vclean.py:365
+#: ../gui/wxpython/modules/vclean.py:357
+msgid "Please select a cleaning tool to remove"
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:95
-msgid "Kriging"
+#: ../gui/wxpython/gui_modules/vclean.py:386
+#: ../gui/wxpython/modules/vclean.py:378
+#, python-format
+msgid "%s. cleaning tool moved up"
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:120
-msgid "Name for the output raster map:"
+#: ../gui/wxpython/gui_modules/vclean.py:388
+#: ../gui/wxpython/modules/vclean.py:380
+msgid "1. cleaning tool can not be moved up "
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:128
-msgid "Export variance map as well: "
+#: ../gui/wxpython/gui_modules/vclean.py:390
+#: ../gui/wxpython/modules/vclean.py:382
+msgid "Please select a cleaning tool to move up"
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:280
-msgid "Kriging Module"
+#: ../gui/wxpython/gui_modules/vclean.py:413
+#: ../gui/wxpython/modules/vclean.py:405
+#, python-format
+msgid "%s. cleaning tool moved down"
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:284
-msgid "Ready."
+#: ../gui/wxpython/gui_modules/vclean.py:415
+#: ../gui/wxpython/modules/vclean.py:407
+msgid "Last cleaning tool can not be moved down "
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:308
-msgid "Variogram fitting"
+#: ../gui/wxpython/gui_modules/vclean.py:417
+#: ../gui/wxpython/modules/vclean.py:409
+msgid "Please select a cleaning tool to move down"
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:318
-msgid "Plot/refresh variogram"
+#: ../gui/wxpython/gui_modules/vclean.py:428
+#: ../gui/wxpython/modules/vclean.py:420
+#, python-format
+msgid "cleaning tool: '%s'"
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:329
-msgid ":"
+#: ../gui/wxpython/gui_modules/vclean.py:436
+#: ../gui/wxpython/modules/vclean.py:428
+#, python-format
+msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:354
-msgid "Kriging techniques"
+#: ../gui/wxpython/gui_modules/vclean.py:457
+#: ../gui/wxpython/modules/vclean.py:468
+msgid "Executing selected cleaning operations..."
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:368
-msgid "Block size:"
+#: ../gui/wxpython/gui_modules/vclean.py:514
+#: ../gui/wxpython/modules/vclean.py:524
+msgid "Vector cleaning command copied to clipboard"
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:401
-msgid "Auto-fit variogram"
+#: ../gui/wxpython/gui_modules/dbm.py:140 ../gui/wxpython/dbmgr/manager.py:145
+msgid "Loading data..."
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:425
-msgid "Model: "
+#: ../gui/wxpython/gui_modules/dbm.py:147 ../gui/wxpython/dbmgr/manager.py:152
+#, python-format
+msgid ""
+"Attribute table <%s> not found. For creating the table switch to 'Manage "
+"layers' tab."
msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:514
-msgid "Work in progress! No functionality provided."
+#: ../gui/wxpython/gui_modules/dbm.py:158 ../gui/wxpython/dbmgr/manager.py:163
+#, python-format
+msgid "Column <%(column)s> not found in in the table <%(table)s>."
msgstr ""
-#: ../gui/wxpython/icons/icon.py:34
+#: ../gui/wxpython/gui_modules/dbm.py:230 ../gui/wxpython/dbmgr/manager.py:234
+msgid "Can display only 256 columns."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:246 ../gui/wxpython/dbmgr/manager.py:250
+msgid "Limit 100000 records."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:263
+#: ../gui/wxpython/gui_modules/dbm.py:809
+#: ../gui/wxpython/gui_modules/dbm.py:1151
+#: ../gui/wxpython/gui_modules/dbm.py:1809
+#: ../gui/wxpython/gui_modules/dbm.py:1831
+#: ../gui/wxpython/gui_modules/dbm.py:1973
+#: ../gui/wxpython/dbmgr/manager.py:267 ../gui/wxpython/dbmgr/manager.py:821
+#: ../gui/wxpython/dbmgr/manager.py:1155 ../gui/wxpython/dbmgr/manager.py:1824
+#: ../gui/wxpython/dbmgr/manager.py:1846 ../gui/wxpython/dbmgr/manager.py:1990
#, python-format
-msgid "Unknown iconset '%s', using default 'grass'...\n"
+msgid "Number of loaded records: %d"
msgstr ""
-#: ../gui/wxpython/icons/icon.py:51
+#: ../gui/wxpython/gui_modules/dbm.py:287 ../gui/wxpython/dbmgr/manager.py:291
+msgid "Unknown value"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:302 ../gui/wxpython/dbmgr/manager.py:306
#, python-format
-msgid "Unable to load icon theme. Reason: %s. Quiting wxGUI..."
+msgid ""
+"Error loading attribute data. Record number: %(rec)d. Unable to convert "
+"value '%(val)s' in key column (%(key)s) to integer.\n"
+"\n"
+"Details: %(detail)s"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:55
-msgid "GRASS Profile Analysis Tool"
+#: ../gui/wxpython/gui_modules/dbm.py:384 ../gui/wxpython/dbmgr/manager.py:388
+msgid "Sort ascending"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:70 ../gui/wxpython/wxplot/profile.py:161
-msgid "Profile of"
+#: ../gui/wxpython/gui_modules/dbm.py:385 ../gui/wxpython/dbmgr/manager.py:389
+msgid "Sort descending"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:86
-#, python-format
-msgid "Distance (%s)"
+#: ../gui/wxpython/gui_modules/dbm.py:388 ../gui/wxpython/dbmgr/manager.py:392
+msgid "Calculate (only numeric columns)"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:88
-msgid "Distance along transect"
+#: ../gui/wxpython/gui_modules/dbm.py:394 ../gui/wxpython/dbmgr/manager.py:398
+msgid "Area size"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:89
-msgid "Cell values"
+#: ../gui/wxpython/gui_modules/dbm.py:395 ../gui/wxpython/dbmgr/manager.py:399
+msgid "Line length"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:154
-msgid "Not all points of profile lie inside computational region."
+#: ../gui/wxpython/gui_modules/dbm.py:396 ../gui/wxpython/dbmgr/manager.py:400
+msgid "Compactness of an area"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:221
-msgid "Raster values"
+#: ../gui/wxpython/gui_modules/dbm.py:397 ../gui/wxpython/dbmgr/manager.py:401
+msgid "Fractal dimension of boundary defining a polygon"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:272
-msgid "You must draw a transect to profile in the map display window."
+#: ../gui/wxpython/gui_modules/dbm.py:398 ../gui/wxpython/dbmgr/manager.py:402
+msgid "Perimeter length of an area"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:273
-msgid "Nothing to profile"
+#: ../gui/wxpython/gui_modules/dbm.py:399 ../gui/wxpython/dbmgr/manager.py:403
+msgid "Number of features for each category"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:335
-msgid "Choose prefix for file(s) where to save profile values..."
+#: ../gui/wxpython/gui_modules/dbm.py:400 ../gui/wxpython/dbmgr/manager.py:404
+msgid "Slope steepness of 3D line"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:337
-msgid "Comma separated value (*.csv)|*.csv"
+#: ../gui/wxpython/gui_modules/dbm.py:401 ../gui/wxpython/dbmgr/manager.py:405
+msgid "Line sinuousity"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:345
-#: ../gui/wxpython/gmodeler/frame.py:1589
-#, python-format
-msgid "File <%s> already exists. Do you want to overwrite this file?"
+#: ../gui/wxpython/gui_modules/dbm.py:402 ../gui/wxpython/dbmgr/manager.py:406
+msgid "Line azimuth"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:347
-msgid "Overwrite file?"
+#: ../gui/wxpython/gui_modules/dbm.py:561
+#: ../gui/wxpython/gui_modules/dbm.py:3082
+#: ../gui/wxpython/dbmgr/manager.py:565 ../gui/wxpython/dbmgr/manager.py:3104
+msgid "GRASS GIS Attribute Table Manager"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:358
+#: ../gui/wxpython/gui_modules/dbm.py:591 ../gui/wxpython/dbmgr/manager.py:595
#, python-format
msgid ""
-"Unable to open file <%s> for writing.\n"
-"Reason: %s"
+"Database connection for vector map <%s> is not defined in DB file. You can "
+"define new connection in 'Manage layers' tab."
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:370
-#, python-format
-msgid ""
-"%d files created:\n"
-"%s"
+#: ../gui/wxpython/gui_modules/dbm.py:595
+#, fuzzy
+msgid "Attribute Table Manager"
+msgstr "GRASS GIS slāņu pārvaldnieks"
+#: ../gui/wxpython/gui_modules/dbm.py:619 ../gui/wxpython/dbmgr/manager.py:621
+msgid "Browse data"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:372
-msgid "No files generated."
+#: ../gui/wxpython/gui_modules/dbm.py:625 ../gui/wxpython/dbmgr/manager.py:627
+msgid "Manage tables"
msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:380
-msgid "Statistics for Profile(s)"
+#: ../gui/wxpython/gui_modules/dbm.py:633 ../gui/wxpython/dbmgr/manager.py:635
+msgid "Manage layers"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:40
-msgid "GRASS GIS Histogramming Tool"
+#: ../gui/wxpython/gui_modules/dbm.py:648 ../gui/wxpython/dbmgr/manager.py:652
+msgid "Close Attribute Table Manager"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:48
-msgid "Histogram of"
+#: ../gui/wxpython/gui_modules/dbm.py:650 ../gui/wxpython/dbmgr/manager.py:654
+msgid "Reload attribute data (selected layer only)"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:49
-#: ../gui/wxpython/wxplot/histogram.py:135
-#: ../gui/wxpython/wxplot/scatter.py:49 ../gui/wxpython/wxplot/scatter.py:50
-#: ../gui/wxpython/wxplot/scatter.py:131 ../gui/wxpython/wxplot/scatter.py:132
-msgid "Raster cell values"
+#: ../gui/wxpython/gui_modules/dbm.py:680 ../gui/wxpython/dbmgr/manager.py:684
+msgid "Attribute data - right-click to edit/manage records"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:50
-#: ../gui/wxpython/wxplot/histogram.py:140
-msgid "Cell counts"
+#: ../gui/wxpython/gui_modules/dbm.py:693
+#: ../gui/wxpython/gui_modules/dbm.py:825
+#: ../gui/wxpython/gui_modules/dbm.py:2420
+#: ../gui/wxpython/gui_modules/dbm.py:2672
+#: ../gui/wxpython/dbmgr/manager.py:697 ../gui/wxpython/dbmgr/manager.py:837
+#: ../gui/wxpython/dbmgr/manager.py:2314 ../gui/wxpython/dbmgr/manager.py:2444
+#: ../gui/wxpython/dbmgr/manager.py:2698
+msgid "Table"
+msgstr "Tabula"
+#: ../gui/wxpython/gui_modules/dbm.py:695
+#: ../gui/wxpython/gui_modules/dbm.py:827
+#: ../gui/wxpython/gui_modules/dbm.py:1005
+#: ../gui/wxpython/dbmgr/manager.py:699 ../gui/wxpython/dbmgr/manager.py:839
+#: ../gui/wxpython/dbmgr/manager.py:1009
+msgid " (readonly)"
+msgstr "(tikai lasīšanai)"
+#: ../gui/wxpython/gui_modules/dbm.py:703 ../gui/wxpython/dbmgr/manager.py:707
+msgid "SQL Query"
+msgstr "SQL vaicājums"
+#: ../gui/wxpython/gui_modules/dbm.py:723 ../gui/wxpython/dbmgr/manager.py:726
+msgid "Apply SELECT statement and reload data records"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:121
+#: ../gui/wxpython/gui_modules/dbm.py:725
+#: ../gui/wxpython/gui_modules/dbm.py:2030
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:458
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:454
+#: ../gui/wxpython/dbmgr/manager.py:728 ../gui/wxpython/dbmgr/manager.py:2047
+msgid "SQL Builder"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:729 ../gui/wxpython/dbmgr/manager.py:732
+msgid "Simple"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:732 ../gui/wxpython/dbmgr/manager.py:735
+msgid "Advanced"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:741
+#: ../gui/wxpython/gui_modules/dbm.py:747
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:108
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:108
+#: ../gui/wxpython/dbmgr/manager.py:749 ../gui/wxpython/dbmgr/manager.py:755
#, python-format
-msgid "Histogram of image group <%s>"
+msgid "Example: %s"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:124
+#: ../gui/wxpython/gui_modules/dbm.py:838
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:87
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:87 ../gui/wxpython/dbmgr/manager.py:850
+msgid "Database connection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:850 ../gui/wxpython/dbmgr/manager.py:862
#, python-format
-msgid "Histogram of raster map <%s>"
+msgid "Table <%s> - right-click to delete column(s)"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:126
+#: ../gui/wxpython/gui_modules/dbm.py:863
+msgid "Manage columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:870
+#: ../gui/wxpython/gui_modules/dbm.py:2235
+#: ../gui/wxpython/dbmgr/manager.py:2260
+msgid "Column name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:898
+msgid "Data length"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:945 ../gui/wxpython/dbmgr/manager.py:951
+msgid "&Rename"
+msgstr "&Pārsaukt"
+#: ../gui/wxpython/gui_modules/dbm.py:1003
+#: ../gui/wxpython/dbmgr/manager.py:1007
#, fuzzy
-msgid "Histogram of selected raster maps"
+msgid "Layers of vector map"
-#: ../gui/wxpython/wxplot/histogram.py:133
-#, python-format
-msgid "Raster cell values %s"
+#: ../gui/wxpython/gui_modules/dbm.py:1016
+#: ../gui/wxpython/dbmgr/manager.py:1020
+msgid "List of layers"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:141
-msgid "Percent of total cells"
+#: ../gui/wxpython/gui_modules/dbm.py:1116
+#: ../gui/wxpython/gui_modules/preferences.py:753
+#: ../gui/wxpython/dbmgr/manager.py:1120 ../gui/wxpython/core/settings.py:804
+msgid "Edit selected record"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:142
-msgid "Area"
+#: ../gui/wxpython/gui_modules/dbm.py:1120
+#: ../gui/wxpython/gui_modules/dbm.py:1360
+#: ../gui/wxpython/dbmgr/manager.py:1124 ../gui/wxpython/dbmgr/manager.py:1376
+msgid "Insert new record"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:225
-msgid "Statistics for Map(s) Histogrammed"
+#: ../gui/wxpython/gui_modules/dbm.py:1121
+#: ../gui/wxpython/dbmgr/manager.py:1125
+msgid "Delete selected record(s)"
msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:229
-#, python-format
-msgid "Statistics for raster map <%s>"
+#: ../gui/wxpython/gui_modules/dbm.py:1122
+#: ../gui/wxpython/dbmgr/manager.py:1126
+msgid "Delete all records"
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:41
-msgid "GRASS Bivariate Scatterplot Tool"
+#: ../gui/wxpython/gui_modules/dbm.py:1131
+#: ../gui/wxpython/dbmgr/manager.py:1135
+msgid "Highlight selected features"
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:48
-msgid "Bivariate Scatterplot"
+#: ../gui/wxpython/gui_modules/dbm.py:1132
+#: ../gui/wxpython/dbmgr/manager.py:1136
+msgid "Highlight selected features and zoom"
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:82 ../gui/wxpython/wxplot/scatter.py:227
-msgid "Nothing to plot."
+#: ../gui/wxpython/gui_modules/dbm.py:1136
+#: ../gui/wxpython/gui_modules/dbm.py:2069
+#: ../gui/wxpython/dbmgr/manager.py:1140 ../gui/wxpython/dbmgr/manager.py:2089
+msgid "Extract selected features"
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:92
-msgid "At least 2 raster maps must be specified"
+#: ../gui/wxpython/gui_modules/dbm.py:1137
+#: ../gui/wxpython/dbmgr/manager.py:1141
+msgid "Delete selected features"
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:113
-msgid "Bivariate Scatterplot of "
+#: ../gui/wxpython/gui_modules/dbm.py:1223
+#, python-format
+msgid ""
+"All data records (%d) will permanently deleted from table. Do you want to "
+"delete them?"
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:136 ../gui/wxpython/wxplot/scatter.py:140
+#: ../gui/wxpython/gui_modules/dbm.py:1371
+#: ../gui/wxpython/dbmgr/manager.py:1387
#, python-format
-msgid ": %s"
+msgid "Record with category number %d already exists in the table."
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:233
-msgid "Regression Statistics for Scatterplot(s)"
+#: ../gui/wxpython/gui_modules/dbm.py:1381
+#: ../gui/wxpython/dbmgr/manager.py:1397
+#, python-format
+msgid "Category number (column %s) is missing."
msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:245
+#: ../gui/wxpython/gui_modules/dbm.py:1395
+#: ../gui/wxpython/gui_modules/dbm.py:1502
+#: ../gui/wxpython/dbmgr/manager.py:1411 ../gui/wxpython/dbmgr/manager.py:1520
#, python-format
-msgid ""
-"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
-"\n"
+msgid "Value '%(value)s' needs to be entered as %(type)s."
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:36
-msgid "Draw/re-draw plot"
+#: ../gui/wxpython/gui_modules/dbm.py:1406
+msgid "Unable to insert new record."
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:38
-msgid "Draw transect in map display window to profile"
+#: ../gui/wxpython/gui_modules/dbm.py:1475
+#: ../gui/wxpython/dbmgr/manager.py:1493
+msgid "Update existing record"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:40
-msgid "Plot options"
+#: ../gui/wxpython/gui_modules/dbm.py:1515
+msgid "Unable to update existing record."
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:42
-msgid "Plot statistics"
+#: ../gui/wxpython/gui_modules/dbm.py:1601
+#: ../gui/wxpython/dbmgr/manager.py:1619
+msgid "Unable to rename column. No column name defined."
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:44
-msgid "Save profile data to CSV file"
+#: ../gui/wxpython/gui_modules/dbm.py:1610
+#: ../gui/wxpython/dbmgr/manager.py:1627
+#, python-format
+msgid ""
+"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
+"exists in the table <%(table)s>."
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:45
-msgid "Quit plot tool"
+#: ../gui/wxpython/gui_modules/dbm.py:1627
+#: ../gui/wxpython/dbmgr/manager.py:1643
+#, python-format
+msgid ""
+"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
+"%(table)s>."
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:435
-msgid "Left Mouse Down at Point:"
+#: ../gui/wxpython/gui_modules/dbm.py:1655
+#: ../gui/wxpython/dbmgr/manager.py:1670
+msgid "Drop selected column"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:464 ../gui/wxpython/wxplot/base.py:510
-#: ../gui/wxpython/wxplot/dialogs.py:557
-msgid "Text settings"
+#: ../gui/wxpython/gui_modules/dbm.py:1658
+#: ../gui/wxpython/dbmgr/manager.py:1673
+msgid "Drop all columns"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:468 ../gui/wxpython/wxplot/base.py:524
-#: ../gui/wxpython/wxplot/dialogs.py:824
-msgid "Plot settings"
+#: ../gui/wxpython/gui_modules/dbm.py:1673
+#: ../gui/wxpython/dbmgr/manager.py:1688
+#, python-format
+msgid ""
+"Selected column '%s' will PERMANENTLY removed from table. Do you want to "
+"drop the column?"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:481
-msgid "This feature is not yet functional"
+#: ../gui/wxpython/gui_modules/dbm.py:1676
+#: ../gui/wxpython/gui_modules/dbm.py:1713
+#: ../gui/wxpython/dbmgr/manager.py:1691 ../gui/wxpython/dbmgr/manager.py:1728
+msgid "Drop column(s)"
msgstr ""
-#: ../gui/wxpython/wxplot/base.py:482
-msgid "Under Construction"
+#: ../gui/wxpython/gui_modules/dbm.py:1710
+#: ../gui/wxpython/dbmgr/manager.py:1725
+#, python-format
+msgid ""
+"Selected columns\n"
+"%s\n"
+"will PERMANENTLY removed from table. Do you want to drop the columns?"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:35
-msgid "Select raster maps to profile"
+#: ../gui/wxpython/gui_modules/dbm.py:1748
+#: ../gui/wxpython/dbmgr/manager.py:1763
+msgid "Unable to add column to the table. No column name defined."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:64
-msgid "Select raster map(s) to profile:"
+#: ../gui/wxpython/gui_modules/dbm.py:1769
+#: ../gui/wxpython/dbmgr/manager.py:1784
+#, python-format
+msgid "Column <%(column)s> already exists in table <%(table)s>."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:107
-msgid "Select pairs of raster maps for scatterplots"
+#: ../gui/wxpython/gui_modules/dbm.py:1934
+#: ../gui/wxpython/gui_modules/dbm.py:1958
+#: ../gui/wxpython/dbmgr/manager.py:1952 ../gui/wxpython/dbmgr/manager.py:1975
+#, python-format
+msgid ""
+"Loading attribute data failed.\n"
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:143
-msgid "Select pairs of raster maps for bivariate scatterplots:"
+#: ../gui/wxpython/gui_modules/dbm.py:1945
+#: ../gui/wxpython/dbmgr/manager.py:1963
+#, python-format
+msgid ""
+"Invalid SQL select statement.\n"
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:158 ../gui/wxpython/wxplot/dialogs.py:405
-msgid "Number of bins (for FP maps)"
+#: ../gui/wxpython/gui_modules/dbm.py:2064
+#: ../gui/wxpython/dbmgr/manager.py:2085
+msgid "Nothing to extract."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:242
-msgid "Statistics"
+#: ../gui/wxpython/gui_modules/dbm.py:2180
+#: ../gui/wxpython/gui_modules/dbm.py:2594
+#: ../gui/wxpython/gui_modules/dbm.py:3019
+#: ../gui/wxpython/dbmgr/manager.py:2205 ../gui/wxpython/dbmgr/manager.py:2620
+#: ../gui/wxpython/dbmgr/manager.py:3041
+#, python-format
+msgid "Drop also linked attribute table (%s)"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:293
-msgid "C&opy"
+#: ../gui/wxpython/gui_modules/dbm.py:2409
+#: ../gui/wxpython/gui_modules/dbm.py:2660
+#: ../gui/wxpython/dbmgr/manager.py:2314 ../gui/wxpython/dbmgr/manager.py:2433
+#: ../gui/wxpython/dbmgr/manager.py:2686
+msgid "Driver"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:294
-msgid "Copy regression statistics the clipboard (Ctrl+C)"
+msgid "Key"
+msgstr "Atslēga"
+#: ../gui/wxpython/gui_modules/dbm.py:2364
+#: ../gui/wxpython/dbmgr/manager.py:2390
+msgid ""
+"Unknown default DB connection. Please define DB connection using db.connect "
+"module."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:323
-msgid "Regression statistics copied to clipboard"
+#: ../gui/wxpython/gui_modules/dbm.py:2385
+#: ../gui/wxpython/dbmgr/manager.py:2409
+msgid "Add layer"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:332
-msgid "Select raster map or imagery group to histogram"
+#: ../gui/wxpython/gui_modules/dbm.py:2395
+#: ../gui/wxpython/dbmgr/manager.py:2419
+msgid "Layer description"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:358
-msgid "Histogram single raster"
+#: ../gui/wxpython/gui_modules/dbm.py:2425
+#: ../gui/wxpython/gui_modules/dbm.py:2457
+#: ../gui/wxpython/gui_modules/dbm.py:2678
+#: ../gui/wxpython/dbmgr/manager.py:2449 ../gui/wxpython/dbmgr/manager.py:2487
+#: ../gui/wxpython/dbmgr/manager.py:2704
+msgid "Key column"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:359
-msgid "Histogram imagery group"
+#: ../gui/wxpython/gui_modules/dbm.py:2430
+#: ../gui/wxpython/dbmgr/manager.py:2454
+msgid "Insert record for each category into table"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:390
-msgid "Select image group:"
+#: ../gui/wxpython/gui_modules/dbm.py:2445
+#: ../gui/wxpython/dbmgr/manager.py:2469
+msgid "You need to add categories by v.category module."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:416
-msgid "Histogram type"
+#: ../gui/wxpython/gui_modules/dbm.py:2452
+#: ../gui/wxpython/dbmgr/manager.py:2482
+msgid "Table name"
+msgstr "Tabulas nosaukums"
+#: ../gui/wxpython/gui_modules/dbm.py:2465
+#: ../gui/wxpython/dbmgr/manager.py:2495
+msgid "&Create table"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:495
-msgid "Selected group must be in current mapset"
+#: ../gui/wxpython/gui_modules/dbm.py:2469
+#: ../gui/wxpython/dbmgr/manager.py:2499
+msgid "&Add layer"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:564
-msgid "Profile title:"
+#: ../gui/wxpython/gui_modules/dbm.py:2473
+#: ../gui/wxpython/dbmgr/manager.py:2503
+msgid "&Set default"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:574
-msgid "Title font size (pts):"
+#: ../gui/wxpython/gui_modules/dbm.py:2537
+#: ../gui/wxpython/dbmgr/manager.py:2474
+msgid "Table description"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:585
-msgid "X-axis label:"
+#: ../gui/wxpython/gui_modules/dbm.py:2577
+#: ../gui/wxpython/dbmgr/manager.py:2603
+msgid "Remove layer"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:595
-msgid "Y-axis label:"
+#: ../gui/wxpython/gui_modules/dbm.py:2580
+#: ../gui/wxpython/dbmgr/manager.py:2606
+msgid "Layer to remove"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:605
-msgid "Label font size (pts):"
+#: ../gui/wxpython/gui_modules/dbm.py:2601
+#: ../gui/wxpython/dbmgr/manager.py:2627
+msgid "&Remove layer"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:627
-msgid "Font family:"
+#: ../gui/wxpython/gui_modules/dbm.py:2645
+#: ../gui/wxpython/dbmgr/manager.py:2671
+msgid "Modify layer"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:641
-msgid "Style:"
+#: ../gui/wxpython/gui_modules/dbm.py:2717
+#: ../gui/wxpython/dbmgr/manager.py:2743
+msgid "&Modify layer"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:655
-msgid "Weight:"
+#: ../gui/wxpython/gui_modules/dbm.py:2765
+#: ../gui/wxpython/dbmgr/manager.py:2791
+msgid ""
+"Unable to get list of tables.\n"
+"Please use db.connect to set database parameters."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:688
-#: ../gui/wxpython/wxplot/dialogs.py:1136
-msgid "Apply changes for the current session and close dialog"
+#: ../gui/wxpython/gui_modules/dbm.py:2863
+#: ../gui/wxpython/dbmgr/manager.py:2888
+msgid "Unable to create new table. Table name or key column name is missing."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:744
+#: ../gui/wxpython/gui_modules/dbm.py:2870
+#: ../gui/wxpython/dbmgr/manager.py:2894
#, python-format
-msgid "Plot text sizes saved to file '%s'."
+msgid "Unable to create new table. Table <%s> already exists in the database."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:802
-msgid "No map or image group selected to plot."
+#: ../gui/wxpython/gui_modules/dbm.py:2909
+#: ../gui/wxpython/dbmgr/manager.py:2932
+#, python-format
+msgid ""
+"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
+"exists."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:844
-msgid "Map/image plotted"
+#: ../gui/wxpython/gui_modules/colorrules.py:75
+#: ../gui/wxpython/modules/colorrules.py:72
+msgid "Check all"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:856
-msgid "Settings for selected map"
+#: ../gui/wxpython/gui_modules/colorrules.py:78
+#: ../gui/wxpython/modules/colorrules.py:75
+msgid "Clear all"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:872
-msgid "Line color"
+#: ../gui/wxpython/gui_modules/colorrules.py:134
+#: ../gui/wxpython/modules/colorrules.py:131
+msgid "Enter vector attribute values"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:879
-#: ../gui/wxpython/vdigit/preferences.py:134
-msgid "Line width"
+#: ../gui/wxpython/gui_modules/colorrules.py:288
+#: ../gui/wxpython/modules/colorrules.py:288
+msgid "Bad color format. Use color format '0:0:0'"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:913
-msgid "Transect segment marker settings"
+#: ../gui/wxpython/gui_modules/colorrules.py:371
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:359
+#: ../gui/wxpython/modules/colorrules.py:373
+#: ../gui/wxpython/wxplot/dialogs.py:355
+msgid "Select raster map:"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:963
-msgid "Scatterplot points"
+#: ../gui/wxpython/gui_modules/colorrules.py:373
+#: ../gui/wxpython/modules/colorrules.py:375
+msgid "Select vector map:"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1014
-msgid "Axis settings"
+#: ../gui/wxpython/gui_modules/colorrules.py:389
+#: ../gui/wxpython/modules/colorrules.py:392
+msgid "Import or export color table:"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1020
-msgid "X-Axis"
+#: ../gui/wxpython/gui_modules/colorrules.py:394
+#: ../gui/wxpython/modules/colorrules.py:397
+msgid "Load color table from file:"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1021
-msgid "Y-Axis"
+#: ../gui/wxpython/gui_modules/colorrules.py:395
+#: ../gui/wxpython/modules/colorrules.py:398
+msgid "Choose file to load color table"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1030
-#, fuzzy
-msgid "Scale"
-msgstr "Mērogs:"
+#: ../gui/wxpython/gui_modules/colorrules.py:396
+#: ../gui/wxpython/modules/colorrules.py:399
+msgid "Load"
+msgstr "Ielādēt"
-#: ../gui/wxpython/wxplot/dialogs.py:1034
-msgid ""
-"Automatic axis scaling, custom max and min, or scale matches data range (min)"
+#: ../gui/wxpython/gui_modules/colorrules.py:397
+#: ../gui/wxpython/modules/colorrules.py:400
+msgid "Type filename or click to choose file and load color table"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1039
-msgid "Custom min"
+#: ../gui/wxpython/gui_modules/colorrules.py:403
+#: ../gui/wxpython/modules/colorrules.py:406
+msgid "Save color table to file:"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1047
-msgid "Custom max"
+#: ../gui/wxpython/gui_modules/colorrules.py:404
+#: ../gui/wxpython/modules/colorrules.py:407
+msgid "Choose file to save color table"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1055
-msgid "Log scale"
+#: ../gui/wxpython/gui_modules/colorrules.py:405
+#: ../gui/wxpython/modules/colorrules.py:408
+msgid "Type filename or click to choose file and save color table"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1079
-msgid "Grid and Legend settings"
+#: ../gui/wxpython/gui_modules/colorrules.py:411
+#: ../gui/wxpython/modules/colorrules.py:414
+msgid "Reload default table"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1084
-msgid "Grid color"
+#: ../gui/wxpython/gui_modules/colorrules.py:500
+#: ../gui/wxpython/iclass/toolbars.py:61
+#: ../gui/wxpython/modules/colorrules.py:504
+msgid "Preview"
+msgstr "Priekšskatījums"
+#: ../gui/wxpython/gui_modules/colorrules.py:504
+#: ../gui/wxpython/modules/colorrules.py:508
+msgid "Show preview of map (current Map Display extent is used)."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1091
-msgid "Show grid"
+#: ../gui/wxpython/gui_modules/colorrules.py:534
+#: ../gui/wxpython/gui_modules/colorrules.py:1659
+#: ../gui/wxpython/modules/colorrules.py:538
+#: ../gui/wxpython/modules/colorrules.py:1676
+msgid "No valid color rules given."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1097
-msgid "Legend font size"
+#: ../gui/wxpython/gui_modules/colorrules.py:566
+#: ../gui/wxpython/gui_modules/menuform.py:1642
+#: ../gui/wxpython/gui_core/forms.py:1649
+#: ../gui/wxpython/modules/colorrules.py:571
+msgid "Nothing to save."
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1107
-msgid "Show legend"
+#: ../gui/wxpython/gui_modules/colorrules.py:599
+#: ../gui/wxpython/modules/colorrules.py:604
+msgid "Invalid color table format"
msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1245
+#: ../gui/wxpython/gui_modules/colorrules.py:676
+#: ../gui/wxpython/modules/colorrules.py:681
#, python-format
-msgid "Plot settings saved to file '%s'."
+msgid "Invalid rule value '%s'. Unable to apply color table."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:136
-msgid "Setup for georectification"
+#: ../gui/wxpython/gui_modules/colorrules.py:751
+#: ../gui/wxpython/modules/colorrules.py:756
+msgid "Create new color table for raster map"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:169 ../gui/wxpython/gcp/manager.py:173
-msgid "Georectifying setup canceled."
+#: ../gui/wxpython/gui_modules/colorrules.py:827
+#: ../gui/wxpython/modules/colorrules.py:834
+msgid "Enter raster category values or percents"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:315
-msgid "Select map type and location/mapset"
+#: ../gui/wxpython/gui_modules/colorrules.py:833
+#: ../gui/wxpython/modules/colorrules.py:840
+msgid "fp range"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:328
-msgid "Map type to georectify"
+#: ../gui/wxpython/gui_modules/colorrules.py:834
+#: ../gui/wxpython/modules/colorrules.py:841
+#, python-format
+msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:336
-msgid "Select source location:"
+#: ../gui/wxpython/gui_modules/colorrules.py:925
+#: ../gui/wxpython/modules/colorrules.py:930
+msgid "Create new color rules for vector map"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:345
-msgid "Select source mapset:"
+#: ../gui/wxpython/gui_modules/colorrules.py:936
+#: ../gui/wxpython/gui_modules/colorrules.py:1457
+#: ../gui/wxpython/modules/colorrules.py:941
+#: ../gui/wxpython/modules/colorrules.py:1467
+msgid "Enter vector attribute values or percents:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:399
-msgid "You must select a valid location before selecting a mapset"
+#: ../gui/wxpython/gui_modules/colorrules.py:938
+#: ../gui/wxpython/gui_modules/colorrules.py:1459
+#: ../gui/wxpython/modules/colorrules.py:943
+#: ../gui/wxpython/modules/colorrules.py:1469
+msgid "Enter vector attribute values:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:412
-msgid "You must select a valid location and mapset in order to continue"
+#: ../gui/wxpython/gui_modules/colorrules.py:948
+#: ../gui/wxpython/modules/colorrules.py:954
+msgid "Select vector columns"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:431
-msgid "Select image/map group to georectify"
+#: ../gui/wxpython/gui_modules/colorrules.py:950
+#: ../gui/wxpython/modules/colorrules.py:956
+msgid "Layer:"
+msgstr "Slānis:"
+#: ../gui/wxpython/gui_modules/colorrules.py:952
+#: ../gui/wxpython/modules/colorrules.py:958
+msgid "Attribute column:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:449
-msgid "Select group:"
+#: ../gui/wxpython/gui_modules/colorrules.py:955
+#: ../gui/wxpython/modules/colorrules.py:961
+msgid "Load color from column:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:460
-msgid "Create group if none exists"
+msgid "Save color to column:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:465
-msgid "Add vector map to group..."
+#: ../gui/wxpython/gui_modules/colorrules.py:957
+#: ../gui/wxpython/modules/colorrules.py:963
+msgid "Load size from column:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:477 ../gui/wxpython/gcp/manager.py:2665
-msgid "Extension for output maps:"
+msgid "Save size to column:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:537
-msgid "You must select a valid image/map group in order to continue"
+#: ../gui/wxpython/gui_modules/colorrules.py:959
+#: ../gui/wxpython/modules/colorrules.py:965
+msgid "Load width from column:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:544
-msgid "You must enter an map name extension in order to continue"
+msgid "Save width to column:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:610
-msgid "Select maps to display for ground control point (GCP) creation"
+#: ../gui/wxpython/gui_modules/colorrules.py:963
+#: ../gui/wxpython/modules/colorrules.py:969
+msgid "Use color column instead of color table:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:618 ../gui/wxpython/gcp/manager.py:2601
-msgid "Select source map to display:"
+#: ../gui/wxpython/gui_modules/colorrules.py:977
+#: ../gui/wxpython/dbmgr/manager.py:873
+#: ../gui/wxpython/modules/colorrules.py:983
+msgid "Add column"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:629 ../gui/wxpython/gcp/manager.py:2606
-msgid "Select target raster map to display:"
+#: ../gui/wxpython/gui_modules/colorrules.py:978
+#: ../gui/wxpython/modules/colorrules.py:984
+msgid "Add GRASSRGB column to current attribute table."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:640 ../gui/wxpython/gcp/manager.py:2611
-msgid "Select target vector map to display:"
+#: ../gui/wxpython/gui_modules/colorrules.py:1033
+#: ../gui/wxpython/gui_modules/colorrules.py:1081
+#: ../gui/wxpython/modules/colorrules.py:1039
+#: ../gui/wxpython/modules/colorrules.py:1088
+msgid "Import or export color table"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:703
-msgid "You must select a source map in order to continue"
+#: ../gui/wxpython/gui_modules/colorrules.py:1093
+#: ../gui/wxpython/modules/colorrules.py:1100
+#, python-format
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file. Do you "
+"want to create and connect new attribute table?"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:729 ../gui/wxpython/gcp/manager.py:759
+#: ../gui/wxpython/gui_modules/colorrules.py:1096
+#: ../gui/wxpython/modules/colorrules.py:1103
+msgid "No database connection defined"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:1168
#, python-format
msgid ""
-"No maps in selected group <%s>.\n"
-"Please edit group or select another group."
+"Selected map <%s> is not in current mapset <%s>. Attribute table cannot be "
+"edited."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:787
-msgid "Manage Ground Control Points"
+#: ../gui/wxpython/gui_modules/colorrules.py:1315
+#: ../gui/wxpython/modules/colorrules.py:1323
+#, python-format
+msgid "%s column already exists."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1040
+#: ../gui/wxpython/gui_modules/colorrules.py:1347
+#: ../gui/wxpython/modules/colorrules.py:1355
+msgid "Please wait, loading data from attribute table..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:1408
+#: ../gui/wxpython/modules/colorrules.py:1416
#, python-format
-msgid "At least %d GCPs required. Operation canceled."
+msgid ""
+"Number of loaded records reached %d, displaying all the records will be time-"
+"consuming and may lead to computer freezing, do you still want to continue?"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1172
-msgid "source"
+#: ../gui/wxpython/gui_modules/colorrules.py:1412
+#: ../gui/wxpython/modules/colorrules.py:1420
+msgid "Too many records"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1174
-msgid "target"
+#: ../gui/wxpython/gui_modules/colorrules.py:1447
+#, python-format
+msgid "(range: %.1f to %.1f)"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1176
-msgid "Set GCP coordinates"
+#: ../gui/wxpython/gui_modules/colorrules.py:1449
+#, python-format
+msgid "(range: %d to %d)"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1177
+#: ../gui/wxpython/gui_modules/colorrules.py:1452
+#: ../gui/wxpython/modules/colorrules.py:1462
#, python-format
-msgid ""
-"Set %(coor)s coordinates for GCP No. %(key)s? \n"
-"\n"
-"East: %(coor0)s \n"
-"North: %(coor1)s"
+msgid "Enter vector attribute values or percents %s:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1243
-msgid "Writing POINTS file failed"
+#: ../gui/wxpython/gui_modules/colorrules.py:1454
+#: ../gui/wxpython/modules/colorrules.py:1464
+#, python-format
+msgid "Enter vector attribute values %s:"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1252
+#: ../gui/wxpython/gui_modules/colorrules.py:1598
+#: ../gui/wxpython/modules/colorrules.py:1610
+msgid "Please select column to save values to."
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:1644
+#: ../gui/wxpython/modules/colorrules.py:1661
+msgid "Thematic mapping for vector map in 3D view"
+msgstr ""
+#: ../gui/wxpython/gui_modules/prompt.py:395
+#: ../gui/wxpython/gui_core/prompt.py:393
#, python-format
-msgid "POINTS file saved for group <%s>"
+msgid "Warning: flag <%(flag)s> not found in '%(module)s'"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1267
-msgid "source mapwin not defined"
+#: ../gui/wxpython/gui_modules/prompt.py:398
+#: ../gui/wxpython/gui_core/prompt.py:396
+#, python-format
+msgid "Warning: option <%(param)s> not found in '%(module)s'"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1272
-msgid "target mapwin not defined"
+#: ../gui/wxpython/gui_modules/prompt.py:620
+#: ../gui/wxpython/gui_core/prompt.py:638
+msgid "Type GRASS command and run by pressing ENTER"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1300
-msgid "Reading POINTS file failed"
+#: ../gui/wxpython/gui_modules/menuform.py:148
+#: ../gui/wxpython/gui_modules/menuform.py:1326
+#: ../gui/wxpython/gui_core/forms.py:1310 ../gui/wxpython/core/utils.py:786
+msgid "Select Color"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1382
+#: ../gui/wxpython/gui_modules/menuform.py:472
+#: ../gui/wxpython/gui_core/forms.py:429
+msgid "Enter parameters for '"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:483
+#: ../gui/wxpython/gui_core/forms.py:440
+msgid "Close this window without executing the command (Ctrl+Q)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:504
+#: ../gui/wxpython/gui_core/forms.py:461
+msgid "Run the command (Ctrl+R)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:524
+#: ../gui/wxpython/gui_core/forms.py:481
+msgid "Show manual page of the command (Ctrl+H)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:545
+#: ../gui/wxpython/gui_core/forms.py:502
+msgid "Add created map(s) into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:560
+#: ../gui/wxpython/gui_core/forms.py:517
+msgid "Close dialog on finish"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:562
+#: ../gui/wxpython/gui_core/forms.py:519
msgid ""
-"Insufficient points defined and active (checked) for selected rectification "
-"method.\n"
-"3+ points needed for 1st order,\n"
-"6+ points for 2nd order, and\n"
-"10+ points for 3rd order."
+"Close dialog when command is successfully finished. Change this settings in "
+"Preferences dialog ('Command' tab)."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1409
-msgid "Rectifying images, please wait..."
+#: ../gui/wxpython/gui_modules/menuform.py:741
+#: ../gui/wxpython/gui_core/forms.py:699
+#, python-format
+msgid "'%s' copied to clipboard"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1449
+#: ../gui/wxpython/gui_modules/menuform.py:804
+#: ../gui/wxpython/gui_modules/menuform.py:817
+#: ../gui/wxpython/gui_core/forms.py:762 ../gui/wxpython/gui_core/forms.py:775
+msgid "Required"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:807
+#: ../gui/wxpython/gui_core/forms.py:765 ../gui/wxpython/gui_core/forms.py:775
+msgid "Optional"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:850
+#: ../gui/wxpython/gui_core/forms.py:809
+msgid "Manual"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:890
+#: ../gui/wxpython/gui_modules/menuform.py:1438
+#: ../gui/wxpython/gui_core/forms.py:849
+#: ../gui/wxpython/gui_core/forms.py:1445
+msgid "Parameterized in model"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:965
+#: ../gui/wxpython/gui_core/forms.py:926
+msgid "[multiple]"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1012
+#: ../gui/wxpython/gui_core/forms.py:973
+msgid "valid range"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1345
+#: ../gui/wxpython/gui_core/forms.py:1329
+#: ../gui/wxpython/gui_core/preferences.py:956
+#: ../gui/wxpython/gui_core/preferences.py:978
+msgid "Transparent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1365
+#: ../gui/wxpython/gui_modules/menuform.py:1420
+#: ../gui/wxpython/gui_core/forms.py:1349
+#: ../gui/wxpython/gui_core/forms.py:1405
#, python-format
-msgid "Transforming <%s>..."
+msgid "Choose %s"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1453
+#: ../gui/wxpython/gui_modules/menuform.py:1393
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:141
+#: ../gui/wxpython/gui_core/forms.py:1378
+#: ../gui/wxpython/modules/mcalc_builder.py:137
+msgid "&Load"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1399
+#: ../gui/wxpython/gui_core/forms.py:1384
+msgid "or enter values interactively"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1614
+#: ../gui/wxpython/gui_core/forms.py:1621
+msgid "Nothing to load."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1646
+#: ../gui/wxpython/gui_core/forms.py:1653
+msgid "Save input as..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1909
+#: ../gui/wxpython/gui_core/forms.py:1939
#, python-format
-msgid "Rectifying vector map <%s>, please wait..."
+msgid "Error in %s"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1486
+#: ../gui/wxpython/gui_modules/menuform.py:2033
+#: ../gui/wxpython/gui_core/forms.py:2043
#, python-format
-msgid "Georectification of vector map <%s> failed"
+msgid "Unable to parse command '%s'"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1493
-msgid "GCP Manager settings"
+#: ../gui/wxpython/gui_modules/menuform.py:2039
+#: ../gui/wxpython/gui_core/forms.py:2049
+#, python-format
+msgid "%(cmd)s: parameter '%(key)s' not available"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1538
-msgid "Quit GCP Manager"
+#: ../gui/wxpython/gui_modules/menuform.py:2218
+#: ../gui/wxpython/gui_core/forms.py:2160
+#, python-format
+msgid "usage: %s <grass command>"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1539
-msgid "Save ground control points?"
+#: ../gui/wxpython/gui_modules/preferences.py:420
+#: ../gui/wxpython/core/settings.py:477
+msgid "Segment break"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1618
-msgid ""
-"Could not calculate RMS Error.\n"
-"Possible error with m.transform."
+#: ../gui/wxpython/gui_modules/preferences.py:480
+#: ../gui/wxpython/core/settings.py:537
+msgid "Data point"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1742
-msgid ""
-"Could not calculate new extends.\n"
+#: ../gui/wxpython/gui_modules/preferences.py:554
+#: ../gui/wxpython/core/settings.py:611
+msgid "animation"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1871
-msgid "Adjust source display to target display"
+#: ../gui/wxpython/gui_modules/preferences.py:748
+#: ../gui/wxpython/core/settings.py:797
+msgid "Collapse all except PERMANENT and current"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1875
-msgid "Adjust target display to source display"
+#: ../gui/wxpython/gui_modules/preferences.py:749
+#: ../gui/wxpython/core/settings.py:798
+msgid "Collapse all except PERMANENT"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1949 ../gui/wxpython/gcp/manager.py:1966
-msgid "source E"
+#: ../gui/wxpython/gui_modules/preferences.py:750
+#: ../gui/wxpython/core/settings.py:799
+msgid "Collapse all except current"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1950 ../gui/wxpython/gcp/manager.py:1967
-msgid "source N"
+#: ../gui/wxpython/gui_modules/preferences.py:751
+#: ../gui/wxpython/core/settings.py:800
+msgid "Collapse all"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1951 ../gui/wxpython/gcp/manager.py:1968
-msgid "target E"
+#: ../gui/wxpython/gui_modules/preferences.py:752
+#: ../gui/wxpython/core/settings.py:801
+msgid "Expand all"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1952 ../gui/wxpython/gcp/manager.py:1969
-msgid "target N"
+#: ../gui/wxpython/gui_modules/preferences.py:754
+#: ../gui/wxpython/core/settings.py:805
+msgid "Display selected"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1953 ../gui/wxpython/gcp/manager.py:1970
-msgid "Forward error"
+#: ../gui/wxpython/gui_modules/preferences.py:762
+#: ../gui/wxpython/core/settings.py:813
+msgid "Classic (labels only)"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1954 ../gui/wxpython/gcp/manager.py:1971
-msgid "Backward error"
+#: ../gui/wxpython/gui_modules/preferences.py:763
+#: ../gui/wxpython/core/settings.py:814
+msgid "Combined (labels and module names)"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2106
-msgid "Invalid coordinate value. Operation canceled."
+#: ../gui/wxpython/gui_modules/preferences.py:764
+#: ../gui/wxpython/core/settings.py:815
+msgid "Professional (module names only)"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2150
-msgid "Create vector map group"
+#: ../gui/wxpython/gui_modules/preferences.py:803
+#: ../gui/wxpython/core/settings.py:859
+msgid "box"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2223
-msgid "Select vector map(s) to add to group:"
+#: ../gui/wxpython/gui_modules/preferences.py:804
+#: ../gui/wxpython/core/settings.py:860
+msgid "sphere"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2270
-msgid "Edit GCP"
+#: ../gui/wxpython/gui_modules/preferences.py:805
+#: ../gui/wxpython/core/settings.py:861
+msgid "cube"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2281
-msgid "Ground Control Point No."
+#: ../gui/wxpython/gui_modules/preferences.py:806
+#: ../gui/wxpython/core/settings.py:862
+msgid "diamond"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2300
-msgid "source E:"
+#: ../gui/wxpython/gui_modules/preferences.py:807
+#: ../gui/wxpython/core/settings.py:863
+msgid "dtree"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2301
-msgid "target E:"
+#: ../gui/wxpython/gui_modules/preferences.py:808
+#: ../gui/wxpython/core/settings.py:864
+msgid "ctree"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2302
-msgid "source N:"
+#: ../gui/wxpython/gui_modules/preferences.py:809
+#: ../gui/wxpython/core/settings.py:865
+msgid "aster"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2303
-msgid "target N:"
+#: ../gui/wxpython/gui_modules/preferences.py:810
+#: ../gui/wxpython/core/settings.py:866
+msgid "gyro"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2440
-msgid "Highlight highest RMS error only"
+#: ../gui/wxpython/gui_modules/preferences.py:811
+#: ../gui/wxpython/core/settings.py:867
+msgid "histogram"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2446
-msgid "Highlight RMS error > M + SD * factor:"
+#: ../gui/wxpython/gui_modules/preferences.py:845
+#: ../gui/wxpython/core/settings.py:901
+#, python-format
+msgid "Unable to read settings file <%s>\n"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2447
+#: ../gui/wxpython/gui_modules/preferences.py:869
+#: ../gui/wxpython/core/settings.py:925
+#, python-format
msgid ""
-"Highlight GCPs with an RMS error larger than \n"
-"mean + standard deviation * given factor. \n"
-"Recommended values for this factor are between 1 and 2."
+"Error: Reading settings from file <%(file)s> failed.\n"
+"\t\tDetails: %(detail)s\n"
+"\t\tLine: '%(line)s'\n"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2464
-msgid "Symbol settings"
+#: ../gui/wxpython/gui_modules/preferences.py:888
+#: ../gui/wxpython/core/settings.py:944
+msgid "Unable to create settings directory"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2489
-msgid "Color for high RMS error:"
+#: ../gui/wxpython/gui_modules/preferences.py:924
+#: ../gui/wxpython/core/settings.py:980
+#, python-format
+msgid ""
+"Writing settings to file <%(file)s> failed.\n"
+"\n"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2506
-msgid "Color for selected GCP:"
+#: ../gui/wxpython/gui_modules/preferences.py:1023
+#: ../gui/wxpython/core/settings.py:1079
+msgid "Unable to set "
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2523
-msgid "Color for unused GCPs:"
+#: ../gui/wxpython/gui_modules/preferences.py:1049
+#: ../gui/wxpython/gui_modules/preferences.py:1055
+#: ../gui/wxpython/core/settings.py:1105 ../gui/wxpython/core/settings.py:1111
+#, python-format
+msgid "Unable to parse settings '%s'"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2539
-msgid "Show unused GCPs"
+#: ../gui/wxpython/gui_modules/preferences.py:1076
+#: ../gui/wxpython/gui_core/preferences.py:58
+msgid "User settings"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2632
-msgid "Rectification"
+#: ../gui/wxpython/gui_modules/preferences.py:1096
+#: ../gui/wxpython/gui_core/preferences.py:78
+msgid "Set to default"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2638
-msgid "Select rectification order"
+#: ../gui/wxpython/gui_modules/preferences.py:1104
+#: ../gui/wxpython/gui_core/preferences.py:86
+msgid "Revert settings to default and apply changes"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2639
-msgid "1st order"
+#: ../gui/wxpython/gui_modules/preferences.py:1166
+#: ../gui/wxpython/gui_core/preferences.py:151
+msgid "Settings applied to current session but not saved"
msgstr ""
-msgid "2nd order"
+#: ../gui/wxpython/gui_modules/preferences.py:1184
+#: ../gui/wxpython/gui_core/preferences.py:178
+#, python-format
+msgid "Settings saved to file '%s'."
msgstr ""
-msgid "3rd order"
+#: ../gui/wxpython/gui_modules/preferences.py:1215
+#: ../gui/wxpython/gui_core/preferences.py:215
+msgid "Key column cannot be empty string."
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2647
-msgid "Select interpolation method:"
+#: ../gui/wxpython/gui_modules/preferences.py:1252
+#: ../gui/wxpython/gui_core/preferences.py:252
+msgid "GUI Settings"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2659
-msgid "clip to computational region in target location"
+#: ../gui/wxpython/gui_modules/preferences.py:1278
+#: ../gui/wxpython/gui_core/preferences.py:280
+msgid "Layer Manager settings"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2699
-msgid "RMS threshold factor must be > 0"
+#: ../gui/wxpython/gui_modules/preferences.py:1289
+#: ../gui/wxpython/gui_core/preferences.py:291
+msgid "Ask when removing map layer from layer tree"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2702
-msgid ""
-"RMS threshold factor is < 1\n"
-"Too many points might be highlighted"
+#: ../gui/wxpython/gui_modules/preferences.py:1299
+#: ../gui/wxpython/gui_core/preferences.py:301
+msgid "Ask when quiting wxGUI or closing display"
msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2849
+#: ../gui/wxpython/gui_modules/preferences.py:1309
+#: ../gui/wxpython/gui_modules/preferences.py:1319
+#: ../gui/wxpython/gui_core/preferences.py:311
+#: ../gui/wxpython/gui_core/preferences.py:321
#, python-format
-msgid "GCP Manager settings saved to file '%s'."
+msgid "Hide '%s' tab (requires GUI restart)"
msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:36
-msgid "Go to GCP No."
+#: ../gui/wxpython/gui_modules/preferences.py:1332
+#: ../gui/wxpython/gui_core/preferences.py:334
+msgid "Automatically copy selected text to clipboard (in Command console)"
msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:53
-msgid "Valid Range:"
+#: ../gui/wxpython/gui_modules/preferences.py:1346
+#: ../gui/wxpython/gui_core/preferences.py:348
+msgid "Workspace settings"
msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:118
-msgid "RMS error"
+#: ../gui/wxpython/gui_modules/preferences.py:1354
+#: ../gui/wxpython/gui_core/preferences.py:356
+msgid "Suppress positioning Map Display Window(s)"
msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:122
-#, python-format
-msgid "Forward: %(forw)s, Backward: %(back)s"
+#: ../gui/wxpython/gui_modules/preferences.py:1366
+#: ../gui/wxpython/gui_core/preferences.py:368
+msgid "Suppress positioning Layer Manager window"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:48
-msgid "GRASS GIS Manage Ground Control Points"
+#: ../gui/wxpython/gui_modules/preferences.py:1377
+#: ../gui/wxpython/gui_core/preferences.py:379
+msgid "Save current window layout as default"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:163
-msgid "GCP List"
+#: ../gui/wxpython/gui_modules/preferences.py:1380
+#: ../gui/wxpython/gui_core/preferences.py:382
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:168
-msgid "Source Display"
+#: ../gui/wxpython/gui_modules/preferences.py:1421
+#: ../gui/wxpython/gui_core/preferences.py:423
+msgid "Font for command output:"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:172
-msgid "Target Display"
+#: ../gui/wxpython/gui_modules/preferences.py:1435
+#: ../gui/wxpython/gui_core/preferences.py:469
+msgid "Appearance settings"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:261
-msgid "GCP Display toolbar"
+#: ../gui/wxpython/gui_modules/preferences.py:1446
+#: ../gui/wxpython/gui_core/preferences.py:480
+msgid "Element list:"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:274
-msgid "GCP Manager toolbar"
+#: ../gui/wxpython/gui_modules/preferences.py:1468
+msgid "Menu style (requires GUI restart):"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:459
-msgid "Zoom to computational region (set with g.region)"
+#: ../gui/wxpython/gui_modules/preferences.py:1492
+#: ../gui/wxpython/gui_core/preferences.py:526
+msgid "Height of map selection popup window (in pixels):"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:463 ../gui/wxpython/mapdisp/frame.py:1161
-msgid "Zoom to default region"
+#: ../gui/wxpython/gui_modules/preferences.py:1516
+#: ../gui/wxpython/gui_core/preferences.py:550
+msgid "Icon theme (requires GUI restart):"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:467 ../gui/wxpython/mapdisp/frame.py:1162
-msgid "Zoom to saved region"
+#: ../gui/wxpython/gui_modules/preferences.py:1546
+#: ../gui/wxpython/gui_core/preferences.py:581
+msgid "Map Display"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:471
-msgid "Set computational region from display"
+#: ../gui/wxpython/gui_modules/preferences.py:1561
+#: ../gui/wxpython/gui_core/preferences.py:596
+msgid "Default font for GRASS displays:"
msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:475 ../gui/wxpython/mapdisp/frame.py:1167
-msgid "Save display geometry to named region"
+#: ../gui/wxpython/gui_modules/preferences.py:1578
+#: ../gui/wxpython/gui_core/preferences.py:613
+msgid "Default display settings"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:146
-msgid "GRASS GIS Interactive Scatter Plot Tool"
+#: ../gui/wxpython/gui_modules/preferences.py:1590
+#: ../gui/wxpython/gui_core/preferences.py:625
+msgid "Display driver:"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:361
-msgid "scatter plot"
+#: ../gui/wxpython/gui_modules/preferences.py:1610
+#: ../gui/wxpython/gui_core/preferences.py:645
+msgid "Statusbar mode:"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:440
-msgid "Maximum limit of categories number was reached."
+#: ../gui/wxpython/gui_modules/preferences.py:1675
+#: ../gui/wxpython/gui_core/preferences.py:710
+msgid "Enable auto-rendering"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:535
-msgid "Rename class"
+#: ../gui/wxpython/gui_modules/preferences.py:1688
+#: ../gui/wxpython/gui_core/preferences.py:723
+msgid "Enable auto-zooming to selected map layer"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:539
+#: ../gui/wxpython/gui_modules/preferences.py:1712
+#: ../gui/wxpython/gui_core/preferences.py:786
#, fuzzy
-msgid "Set color"
-msgstr "Izvēlieties krāsu:"
+msgid "Command dialog settings"
+msgstr "Mainīt iestatījumus"
-#: ../gui/wxpython/iscatt/frame.py:547
-msgid "Hide"
+#: ../gui/wxpython/gui_modules/preferences.py:1734
+#: ../gui/wxpython/gui_core/preferences.py:808
+msgid "Close dialog when command is successfully finished"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:549
-msgid "Show"
+#: ../gui/wxpython/gui_modules/preferences.py:1755
+#: ../gui/wxpython/gui_core/preferences.py:829
+msgid "Allow interactive input"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:560
-msgid "Move to top"
+#: ../gui/wxpython/gui_modules/preferences.py:1765
+#: ../gui/wxpython/gui_core/preferences.py:839
+msgid "Verbosity level:"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:566
-msgid "Move to bottom"
+#: ../gui/wxpython/gui_modules/preferences.py:1784
+#, fuzzy
+msgid "Raster settings"
+msgstr "Rastra iestatījumi"
+#: ../gui/wxpython/gui_modules/preferences.py:1795
+#: ../gui/wxpython/gui_core/preferences.py:880
+msgid "Make null cells opaque"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:574
-msgid "Move category up"
+#: ../gui/wxpython/gui_modules/preferences.py:1806
+#: ../gui/wxpython/gui_core/preferences.py:891
+msgid "Default color table"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:580
-msgid "Move category down"
+#: ../gui/wxpython/gui_modules/preferences.py:1832
+#, fuzzy
+msgid "Vector settings"
+#: ../gui/wxpython/gui_modules/preferences.py:1838
+#: ../gui/wxpython/gui_core/preferences.py:923
+msgid "Display:"
+msgstr "Attēlot:"
+#: ../gui/wxpython/gui_modules/preferences.py:1860
+#: ../gui/wxpython/gui_modules/vdigit.py:377
+#: ../gui/wxpython/gui_core/preferences.py:1034
+#: ../gui/wxpython/vdigit/preferences.py:344
+msgid "Attributes"
+msgstr "Atribūti"
+#: ../gui/wxpython/gui_modules/preferences.py:1868
+#: ../gui/wxpython/gui_core/preferences.py:1042
+msgid "Highlighting"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:588
-msgid "Export class raster"
+#: ../gui/wxpython/gui_modules/preferences.py:1884
+#: ../gui/wxpython/gui_core/preferences.py:1058
+msgid "Line width (in pixels):"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:660
-#, python-format
-msgid "Change opacity of class <%s>"
+#: ../gui/wxpython/gui_modules/preferences.py:1907
+#: ../gui/wxpython/gui_core/preferences.py:1081
+msgid "Data browser"
+msgstr "Datu pārlūks"
+#: ../gui/wxpython/gui_modules/preferences.py:1912
+#: ../gui/wxpython/gui_core/preferences.py:1086
+msgid "Left mouse double click:"
msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:682
-msgid "Empty name was inserted."
+#: ../gui/wxpython/gui_modules/preferences.py:1924
+#: ../gui/wxpython/gui_core/preferences.py:1098
+msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
msgstr ""
-#: ../gui/wxpython/iscatt/core_c.py:23
-msgid "Loading ctypes libs failed"
+#: ../gui/wxpython/gui_modules/preferences.py:1935
+#: ../gui/wxpython/gui_core/preferences.py:1109
+msgid "Ask when deleting data record(s) from table"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:174
-#, fuzzy
-msgid "No data set."
-msgstr "Rastra datu importēšana"
+#: ../gui/wxpython/gui_modules/preferences.py:1956
+#: ../gui/wxpython/gui_core/preferences.py:1130
+msgid "Create table"
+msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:286
-msgid ""
-"In order to select arrea in scatter plot, you have to select class first.\n"
-"\n"
-"There is no class yet, do you want to create one?"
+#: ../gui/wxpython/gui_modules/preferences.py:1996
+#: ../gui/wxpython/gui_core/preferences.py:1171
+msgid "Projection statusbar settings"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:320
-#, python-format
+#: ../gui/wxpython/gui_modules/preferences.py:2022
+#: ../gui/wxpython/gui_core/preferences.py:1197
+msgid "Proj.4 string (required):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:2038
+#: ../gui/wxpython/gui_core/preferences.py:1213
+msgid "EPSG file:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:2053
+#: ../gui/wxpython/gui_core/preferences.py:1228
msgid ""
-"Error occured during computation of scatter plot category:\n"
-"%s"
+"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
+"directly."
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:630
-#, python-format
-msgid "Export scatter plot raster of class <%s>"
+#: ../gui/wxpython/gui_modules/preferences.py:2061
+#: ../gui/wxpython/gui_core/preferences.py:1236
+msgid "&Load EPSG codes"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:647
+#: ../gui/wxpython/gui_modules/preferences.py:2072
+#: ../gui/wxpython/gui_core/preferences.py:1247
+msgid "Coordinates format"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:2081
+#: ../gui/wxpython/gui_core/preferences.py:1256
+#, fuzzy
+msgid "LL projections"
+msgstr "Projekcija"
+#: ../gui/wxpython/gui_modules/preferences.py:2100
+#: ../gui/wxpython/gui_core/preferences.py:1275
+msgid "Precision:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:2138
+#: ../gui/wxpython/gui_core/preferences.py:1313
#, python-format
-msgid "Scatter plot raster of class <%s> exported to raster map <%s>."
+msgid "Unable to read EPSG codes: %s"
msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:650
+#: ../gui/wxpython/gui_modules/preferences.py:2167
+#: ../gui/wxpython/gui_modules/preferences.py:2176
+#: ../gui/wxpython/gui_modules/preferences.py:2186
+#: ../gui/wxpython/gui_core/preferences.py:1342
+#: ../gui/wxpython/gui_core/preferences.py:1351
+#: ../gui/wxpython/gui_core/preferences.py:1360
#, python-format
+msgid "EPSG code %s not found"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:2194
+#: ../gui/wxpython/gui_core/preferences.py:1368
+msgid "Select default display font"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:2277
+#: ../gui/wxpython/gui_core/preferences.py:1474
+msgid "Select font:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:2301
+#: ../gui/wxpython/gui_core/preferences.py:1498
+msgid "Character encoding:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:2419
+#: ../gui/wxpython/gui_core/preferences.py:1616
+msgid "Manage access to mapsets"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:2432
+#: ../gui/wxpython/gui_core/preferences.py:1629
msgid ""
-"Export of scatter plot raster of class <%s> to map <%s> failed.\n"
-"%s"
+"Check a mapset to make it accessible, uncheck it to hide it.\n"
+" Notes:\n"
+" - The current mapset is always accessible.\n"
+" - You may only write to the current mapset.\n"
+" - You may only write to mapsets which you own."
msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:98
-#: ../gui/wxpython/iscatt/iscatt_core.py:148
-msgid "Select category for editing."
+#: ../gui/wxpython/gui_modules/preferences.py:2507
+#: ../gui/wxpython/gui_core/preferences.py:1704
+msgid "Owner"
msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:139
-msgid "Computing of scatter plots failed."
+#: ../gui/wxpython/gui_modules/layertree.py:548
+msgid "Unable to display histogram of raster map."
msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:277
-msgid "Patching category raster conditions file failed."
+#: ../gui/wxpython/gui_modules/layertree.py:661
+#, python-format
+msgid "Set opacity <%s>"
msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:301
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:68
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:68
#, python-format
-msgid ""
-"v.build failed:\n"
-"%s"
+msgid "GRASS SQL Builder (%(type)s): vector map <%(map)s>"
msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:319
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:75
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:75
+msgid "SQL statement not verified"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:117
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:117
+msgid "Set SQL statement to default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:119
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:119
+msgid "Verify"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:120
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:120
+msgid "Verify SQL statement"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:122
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:122
+#, fuzzy
+msgid "Apply SQL statement and close the dialog"
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:124
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:124
+msgid "Close the dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:173
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:173
+msgid "Columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:183
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:183
+msgid "Add on double-click"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:184
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:184
+#, fuzzy
+msgid "columns"
+msgstr "&Tilpumi"
+msgid "values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:195
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:195
+msgid "Values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:204
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:204
+msgid "Get all values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:207
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:207
+msgid "Get sample"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:227
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:227
+msgid "Close dialog on apply"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:427
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:423
+msgid "SQL statement is not valid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:429
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:425
#, python-format
msgid ""
-"v.to.rast failed:\n"
+"SQL statement is not valid.\n"
+"\n"
"%s"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:48
-#, fuzzy
-msgid "Add scatter plot"
-msgstr "Pievienot rastru"
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:431
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:427
+msgid "SQL statement is valid"
+msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:50
-msgid "Select area with polygon"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:38
+#: ../gui/wxpython/wxplot/dialogs.py:34
+msgid "Select raster maps to profile"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:52
-msgid "Pan mode for scatter plots"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:67
+#: ../gui/wxpython/wxplot/dialogs.py:63
+msgid "Select raster map(s) to profile:"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:54
-msgid "Zoom mode for scatter plots (left mouse button, wheel)"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:110
+#: ../gui/wxpython/wxplot/dialogs.py:106
+msgid "Select pairs of raster maps for scatterplots"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:56
-msgid ""
-"Zoom to scatter plot data extend mode (click on scatter plot for zooming to "
-"extend)"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:146
+#: ../gui/wxpython/wxplot/dialogs.py:142
+msgid "Select pairs of raster maps for bivariate scatterplots:"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:58
-msgid "Show/hide class manager"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:161
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:390
+#: ../gui/wxpython/wxplot/dialogs.py:157 ../gui/wxpython/wxplot/dialogs.py:386
+msgid "Number of bins (for FP maps)"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:162
-#: ../gui/wxpython/iscatt/toolbars.py:163
-msgid "Include selected area to class"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:230
+#: ../gui/wxpython/wxplot/dialogs.py:226
+msgid "Statistics"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:165
-#: ../gui/wxpython/iscatt/toolbars.py:166
-msgid "Exclude selected area from class"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:281
+#: ../gui/wxpython/wxplot/dialogs.py:277
+msgid "C&opy"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:168
-#: ../gui/wxpython/vdigit/toolbars.py:124
-msgid "Add new vertex"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:282
+#: ../gui/wxpython/wxplot/dialogs.py:278
+msgid "Copy regression statistics the clipboard (Ctrl+C)"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:169
-msgid "Add new vertex to polygon boundary scatter plot"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:311
+#: ../gui/wxpython/wxplot/dialogs.py:307
+msgid "Regression statistics copied to clipboard"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:171
-msgid "Create selection polygon"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:320
+#: ../gui/wxpython/wxplot/dialogs.py:316
+msgid "Select raster map or imagery group to histogram"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:172
-msgid "Add new vertex between last and first points of the boundary"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:346
+#: ../gui/wxpython/wxplot/dialogs.py:342
+msgid "Histogram single raster"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:174
-#: ../gui/wxpython/vdigit/toolbars.py:145
-msgid "Move vertex"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:347
+#: ../gui/wxpython/wxplot/dialogs.py:343
+msgid "Histogram imagery group"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:175
-msgid "Move boundary vertex"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:374
+#: ../gui/wxpython/wxplot/dialogs.py:370
+msgid "Select image group:"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:177
-#: ../gui/wxpython/vdigit/toolbars.py:148
-msgid "Remove vertex"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:401
+#: ../gui/wxpython/wxplot/dialogs.py:397
+msgid "Histogram type"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:178
-msgid "Remove boundary vertex"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:536
+#: ../gui/wxpython/gui_modules/wxplot.py:435
+#: ../gui/wxpython/wxplot/base.py:428 ../gui/wxpython/wxplot/dialogs.py:537
+msgid "Text settings"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:180
-msgid "Remove polygon (click on scatter plot for removing it's polygon)"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:543
+#: ../gui/wxpython/wxplot/dialogs.py:544
+msgid "Profile title:"
msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:257
-#, fuzzy
-msgid "Add class"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:553
+#: ../gui/wxpython/wxplot/dialogs.py:554
+msgid "Title font size (pts):"
+msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:259
-msgid "Remove selected class"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:564
+#: ../gui/wxpython/wxplot/dialogs.py:565
+msgid "X-axis label:"
msgstr ""
-#: ../gui/wxpython/iscatt/plots.py:42
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:574
+#: ../gui/wxpython/wxplot/dialogs.py:575
+msgid "Y-axis label:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:584
+#: ../gui/wxpython/wxplot/dialogs.py:585
+msgid "Label font size (pts):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:607
+#: ../gui/wxpython/wxplot/dialogs.py:608
+msgid "Font family:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:621
+#: ../gui/wxpython/wxplot/dialogs.py:622
+msgid "Style:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:635
+#: ../gui/wxpython/wxplot/dialogs.py:636
+msgid "Weight:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:667
+#: ../gui/wxpython/wxplot/dialogs.py:668
+msgid "Apply changes for the current session and close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:723
+#: ../gui/wxpython/wxplot/dialogs.py:724
#, python-format
-msgid ""
-"Unable to import matplotlib (try to install it).\n"
-"%s"
+msgid "Plot text settings saved to file '%s'."
msgstr ""
-#: ../gui/wxpython/iscatt/plots.py:533
-msgid "Zoom to scatter plot extend"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:779
+#: ../gui/wxpython/wxplot/dialogs.py:780
+msgid "No map or image group selected to plot."
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:55
-msgid "x axis:"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:801
+#: ../gui/wxpython/gui_modules/wxplot.py:439
+#: ../gui/wxpython/gui_modules/wxplot.py:496
+#: ../gui/wxpython/wxplot/base.py:432 ../gui/wxpython/wxplot/base.py:489
+#: ../gui/wxpython/wxplot/dialogs.py:802
+msgid "Plot settings"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:61
-msgid "y axis:"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:821
+#: ../gui/wxpython/wxplot/dialogs.py:822
+msgid "Map/image plotted"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:96
-msgid "Bands of scatter plots to be added (x y):"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:847
+#: ../gui/wxpython/wxplot/dialogs.py:848
+msgid "Line color"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:134
-msgid "No scatter plots selected."
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:854
+#: ../gui/wxpython/gui_modules/vdigit.py:163
+#: ../gui/wxpython/wxplot/dialogs.py:855
+#: ../gui/wxpython/vdigit/preferences.py:130
+msgid "Line width"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:182
-msgid "Select both x and y bands."
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:888
+#: ../gui/wxpython/wxplot/dialogs.py:889
+msgid "Transect segment marker settings"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:185
-msgid "Selected bands must be different."
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:939
+#: ../gui/wxpython/wxplot/dialogs.py:940
+msgid "Scatterplot points"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:191
-msgid ""
-"Scatter plot with same band combination (regardless x y order) is already "
-"displayed."
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:991
+#: ../gui/wxpython/wxplot/dialogs.py:992
+msgid "Axis settings"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:197
-msgid ""
-"Scatter plot with same bands combination (regardless x y order) has been "
-"already added into the list."
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:997
+#: ../gui/wxpython/wxplot/dialogs.py:998
+msgid "X-Axis"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:295
-#, python-format
-msgid "Raster map <%s> already exists. Do you want to overwrite it?"
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:998
+#: ../gui/wxpython/wxplot/dialogs.py:999
+msgid "Y-Axis"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:297
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1016
+#: ../gui/wxpython/wxplot/dialogs.py:1017
+msgid "Custom min"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1024
+#: ../gui/wxpython/wxplot/dialogs.py:1025
+msgid "Custom max"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1032
+#: ../gui/wxpython/wxplot/dialogs.py:1033
+msgid "Log scale"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1056
+#: ../gui/wxpython/wxplot/dialogs.py:1057
+msgid "Grid and Legend settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1061
+#: ../gui/wxpython/wxplot/dialogs.py:1062
+msgid "Grid color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1068
+#: ../gui/wxpython/wxplot/dialogs.py:1069
+msgid "Show grid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1074
+#: ../gui/wxpython/wxplot/dialogs.py:1075
+msgid "Legend font size"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1084
+#: ../gui/wxpython/wxplot/dialogs.py:1085
+msgid "Show legend"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot_dialogs.py:1224
+#: ../gui/wxpython/wxplot/dialogs.py:1225
#, python-format
-msgid "Raster <%s> exists"
+msgid "Plot settings saved to file '%s'."
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:320
-msgid "Show confidence ellipses"
+#: ../gui/wxpython/gui_modules/ghelp.py:75
+#: ../gui/wxpython/gui_modules/ghelp.py:83
+#: ../gui/wxpython/gui_core/ghelp.py:57 ../gui/wxpython/gui_core/ghelp.py:65
+msgid "description"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:326
-msgid "Selection polygon color:"
+#: ../gui/wxpython/gui_modules/ghelp.py:76
+#: ../gui/wxpython/gui_modules/ghelp.py:85
+#: ../gui/wxpython/gui_core/ghelp.py:58 ../gui/wxpython/gui_core/ghelp.py:67
+msgid "command"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:327
-msgid "Color of selection polygon vertex:"
+#: ../gui/wxpython/gui_modules/ghelp.py:77
+#: ../gui/wxpython/gui_modules/ghelp.py:84
+#: ../gui/wxpython/gui_core/ghelp.py:59 ../gui/wxpython/gui_core/ghelp.py:66
+msgid "keywords"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:328
-msgid "Selected area color:"
+#: ../gui/wxpython/gui_modules/ghelp.py:80
+#: ../gui/wxpython/gui_core/ghelp.py:62
+msgid "Find module(s)"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:342
-msgid "Selected area opacity:"
+#: ../gui/wxpython/gui_modules/ghelp.py:152
+#: ../gui/wxpython/gui_modules/ghelp.py:185
+#: ../gui/wxpython/gui_core/ghelp.py:135 ../gui/wxpython/gui_core/ghelp.py:168
+#, python-format
+msgid "%d modules found"
msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:374
-#, fuzzy
-msgid "Selection style:"
-msgstr "Fonta izmērs:"
+#: ../gui/wxpython/gui_modules/ghelp.py:220
+#: ../gui/wxpython/gui_core/ghelp.py:203
+msgid "Menu tree (double-click to run command)"
+msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:396
+#: ../gui/wxpython/gui_modules/ghelp.py:230
+#: ../gui/wxpython/gui_core/ghelp.py:213
#, fuzzy
-msgid "Ellipses settings:"
-msgstr "Rastra iestatījumi"
+msgid "Run selected command"
+msgstr "Jauna vektoru karte"
-#: ../gui/wxpython/mapdisp/frame.py:74
-msgid "GRASS GIS - Map display"
+#: ../gui/wxpython/gui_modules/ghelp.py:291
+#: ../gui/wxpython/gui_core/ghelp.py:274
+msgid "You must run this command from the menu or command line"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:293
-msgid "Vector Digitizer Toolbar"
+#: ../gui/wxpython/gui_modules/ghelp.py:361
+#: ../gui/wxpython/gui_modules/ghelp.py:1060
+#: ../gui/wxpython/gui_core/widgets.py:349
+#: ../gui/wxpython/modules/extensions.py:314
+msgid "Menu tree"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:314
-#, python-format
-msgid ""
-"Unable to switch to 3D display mode.\n"
-"The Nviz python extension was not found or loaded properly.\n"
-"Switching back to 2D display mode.\n"
-"\n"
-"Details: %s"
+#: ../gui/wxpython/gui_modules/ghelp.py:515
+#: ../gui/wxpython/gui_core/ghelp.py:420
+msgid "Official GRASS site:"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:340
-msgid "Starting 3D view mode..."
+#: ../gui/wxpython/gui_modules/ghelp.py:526
+#: ../gui/wxpython/gui_core/ghelp.py:431
+#, fuzzy
+msgid "SVN Revision:"
+msgstr "Reģions:"
+#: ../gui/wxpython/gui_modules/ghelp.py:537
+#: ../gui/wxpython/gui_core/ghelp.py:442
+msgid "GIS Library Revision:"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:341
-msgid "Please wait, loading data..."
+#: ../gui/wxpython/gui_modules/ghelp.py:556
+#: ../gui/wxpython/gui_core/ghelp.py:496
+msgid "Info"
+msgstr "Informācija"
+#: ../gui/wxpython/gui_modules/ghelp.py:557
+#: ../gui/wxpython/gui_core/ghelp.py:497
+msgid "Copyright"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:413
-msgid "Please wait, unloading data..."
+#: ../gui/wxpython/gui_modules/ghelp.py:558
+#: ../gui/wxpython/gui_core/ghelp.py:498
+msgid "License"
+msgstr "Licence"
+#: ../gui/wxpython/gui_modules/ghelp.py:559
+#: ../gui/wxpython/gui_core/ghelp.py:499
+msgid "Authors"
+msgstr "Autori"
+#: ../gui/wxpython/gui_modules/ghelp.py:560
+#: ../gui/wxpython/gui_core/ghelp.py:500
+msgid "Contributors"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:415
-msgid "Switching back to 2D view mode..."
+#: ../gui/wxpython/gui_modules/ghelp.py:561
+#: ../gui/wxpython/gui_core/ghelp.py:501
+msgid "Extra contributors"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:464 ../gui/wxpython/mapdisp/toolbars.py:97
-#: ../gui/wxpython/vdigit/toolbars.py:844
-msgid "Digitize"
+#: ../gui/wxpython/gui_modules/ghelp.py:562
+#: ../gui/wxpython/gui_core/ghelp.py:502
+msgid "Translators"
+msgstr "Tulkotāji"
+#: ../gui/wxpython/gui_modules/ghelp.py:594
+#: ../gui/wxpython/gui_modules/ghelp.py:619
+#: ../gui/wxpython/gui_modules/ghelp.py:643
+#: ../gui/wxpython/gui_modules/ghelp.py:700
+#: ../gui/wxpython/gui_modules/ghelp.py:760
+#: ../gui/wxpython/gui_core/ghelp.py:537 ../gui/wxpython/gui_core/ghelp.py:561
+#: ../gui/wxpython/gui_core/ghelp.py:585 ../gui/wxpython/gui_core/ghelp.py:642
+#: ../gui/wxpython/gui_core/ghelp.py:704 ../gui/wxpython/gui_core/ghelp.py:854
+#, python-format
+msgid "%s file missing"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:673
+#: ../gui/wxpython/gui_modules/ghelp.py:686
+#: ../gui/wxpython/gui_modules/ghelp.py:746
+#: ../gui/wxpython/gui_core/ghelp.py:628 ../gui/wxpython/gui_core/ghelp.py:690
#, python-format
-msgid "Vector map <%s> opened for editing - skipped."
+msgid "Error when reading file '%s'."
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:679
-msgid "No raster or vector map layer selected for querying."
+#: ../gui/wxpython/gui_modules/ghelp.py:687
+#: ../gui/wxpython/gui_modules/ghelp.py:747
+#: ../gui/wxpython/gui_core/ghelp.py:629 ../gui/wxpython/gui_core/ghelp.py:691
+msgid "Lines:"
+msgstr "Rindas:"
+#: ../gui/wxpython/gui_modules/ghelp.py:705
+#: ../gui/wxpython/gui_modules/ghelp.py:707
+#: ../gui/wxpython/gui_modules/ghelp.py:770
+#: ../gui/wxpython/gui_core/ghelp.py:647 ../gui/wxpython/gui_core/ghelp.py:649
+#: ../gui/wxpython/gui_core/ghelp.py:716
+msgid "E-mail"
+msgstr "E-pasts"
+msgid "Country"
+msgstr "Valsts"
+#: ../gui/wxpython/gui_core/ghelp.py:649
+msgid "OSGeo_ID"
+msgstr "OSGeo_ID"
+#: ../gui/wxpython/gui_modules/ghelp.py:772
+#: ../gui/wxpython/gui_core/ghelp.py:720
+msgid "Language"
+msgstr "Valoda"
+#: ../gui/wxpython/gui_modules/ghelp.py:797
+#: ../gui/wxpython/modules/extensions.py:42
+msgid "Fetch & install extension from GRASS Addons"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1063
-#: ../gui/wxpython/mapdisp/toolbars.py:47
-msgid "Add text layer"
+#: ../gui/wxpython/gui_modules/ghelp.py:806
+#: ../gui/wxpython/modules/extensions.py:52
+msgid "Repository"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1164
-msgid "Set computational region from display extent"
+#: ../gui/wxpython/gui_modules/ghelp.py:808
+#: ../gui/wxpython/modules/extensions.py:54
+msgid "List of extensions"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1165
-msgid "Set computational region from named region"
+#: ../gui/wxpython/gui_modules/ghelp.py:812
+msgid "Fetch full info including description and keywords (takes time)"
msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1168
-msgid "Save computational region to named region"
+#: ../gui/wxpython/gui_modules/ghelp.py:840
+#: ../gui/wxpython/modules/extensions.py:94
+msgid "&Fetch"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:135
-msgid "Map window test frame"
+#: ../gui/wxpython/gui_modules/ghelp.py:841
+#: ../gui/wxpython/modules/extensions.py:95
+msgid "Fetch list of available modules from GRASS Addons SVN repository"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:154
-#, fuzzy
-msgid "Map display test"
-msgstr "Kartes skats"
+#: ../gui/wxpython/gui_modules/ghelp.py:844
+#: ../gui/wxpython/modules/extensions.py:98
+msgid "&Install"
+msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:163
-msgid "Map window API test frame"
+#: ../gui/wxpython/gui_modules/ghelp.py:845
+#: ../gui/wxpython/modules/extensions.py:99
+msgid "Install selected add-ons GRASS module"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:193
-msgid "Map window distance measurement test frame"
+#: ../gui/wxpython/gui_modules/ghelp.py:918
+#: ../gui/wxpython/modules/extensions.py:172
+msgid "Extension not defined"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:224
-msgid "Map window profile tool test frame"
+#: ../gui/wxpython/gui_modules/ghelp.py:933
+#: ../gui/wxpython/modules/extensions.py:187
+msgid "Fetch list of available extensions by clicking on 'Fetch' button"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:271
-msgid "Map window rlisetup test frame"
+#: ../gui/wxpython/gui_modules/ghelp.py:941
+#: ../gui/wxpython/modules/extensions.py:195
+#, python-format
+msgid "%d items match"
msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:332
+#: ../gui/wxpython/gui_modules/ghelp.py:954
+#: ../gui/wxpython/modules/extensions.py:208
+msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/ghelp.py:1223
+#: ../gui/wxpython/gui_core/ghelp.py:994
+msgid "&Next"
+msgstr ""
+#: ../gui/wxpython/gui_modules/ghelp.py:1226
+#: ../gui/wxpython/gui_core/ghelp.py:997
+msgid "&Previous"
+msgstr ""
+#: ../gui/wxpython/gui_modules/utils.py:300 ../gui/wxpython/core/utils.py:298
#, python-format
-msgid "Unknown value %s of test parameter."
+msgid "Vector map <%(map)s>: %(msg)s\n"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:29
-msgid "Query raster/vector map(s)"
+#: ../gui/wxpython/gui_modules/utils.py:523 ../gui/wxpython/core/utils.py:521
+#, python-format
+msgid "failed to open '%s'"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:30
-msgid "Query selected raster/vector map(s)"
+#: ../gui/wxpython/gui_modules/utils.py:772 ../gui/wxpython/core/utils.py:740
+#, python-format
+msgid "ERROR: Unable to determine GRASS version. Details: %s"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:32
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2140
#, fuzzy
-msgid "Show/hide scale bar"
+msgid "Place scalebar"
msgstr "Mērogjosla"
-#: ../gui/wxpython/mapdisp/toolbars.py:34
-msgid "Show/hide legend"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2146
+msgid "Delete last"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:36
-#, fuzzy
-msgid "Show/hide north arrow"
-msgstr "Ziemeļu bulta"
+#: ../gui/wxpython/gui_modules/wxplot.py:406
+#, python-format
+msgid "Left Mouse Down at Point: (%.4f, %.4f)"
+msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:38
-msgid "Analyze map"
+#: ../gui/wxpython/gui_modules/wxplot.py:452
+#: ../gui/wxpython/wxplot/base.py:445
+msgid "This feature is not yet functional"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:39
-msgid "Measuring, profiling, histogramming, ..."
+#: ../gui/wxpython/gui_modules/wxplot.py:453
+#: ../gui/wxpython/wxplot/base.py:446
+msgid "Under Construction"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:41
-msgid "Measure distance"
+#: ../gui/wxpython/gui_modules/wxplot.py:482
+#: ../gui/wxpython/wxplot/base.py:475
+msgid "Histogram text settings"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:43
-msgid "Profile surface map"
+#: ../gui/wxpython/gui_modules/wxplot.py:559
+#: ../gui/wxpython/wxplot/histogram.py:40
+msgid "GRASS Histogramming Tool"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:45
-msgid "Create bivariate scatterplot of raster maps"
+#: ../gui/wxpython/gui_modules/wxplot.py:567
+#: ../gui/wxpython/wxplot/histogram.py:48
+msgid "Histogram of"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:49
-msgid "Create histogram of raster map"
+#: ../gui/wxpython/gui_modules/wxplot.py:568
+#: ../gui/wxpython/gui_modules/wxplot.py:645
+#: ../gui/wxpython/gui_modules/wxplot.py:1104
+#: ../gui/wxpython/gui_modules/wxplot.py:1105
+#: ../gui/wxpython/gui_modules/wxplot.py:1203
+#: ../gui/wxpython/gui_modules/wxplot.py:1209
+#: ../gui/wxpython/wxplot/scatter.py:48 ../gui/wxpython/wxplot/scatter.py:49
+#: ../gui/wxpython/wxplot/scatter.py:143 ../gui/wxpython/wxplot/scatter.py:144
+#: ../gui/wxpython/wxplot/histogram.py:49
+#: ../gui/wxpython/wxplot/histogram.py:126
+msgid "Raster cell values"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:56
-msgid "Rotate 3D scene"
+#: ../gui/wxpython/gui_modules/wxplot.py:569
+#: ../gui/wxpython/gui_modules/wxplot.py:650
+#: ../gui/wxpython/wxplot/histogram.py:50
+#: ../gui/wxpython/wxplot/histogram.py:131
+msgid "Cell counts"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:57
-msgid "Drag with mouse to rotate 3D scene"
+#: ../gui/wxpython/gui_modules/wxplot.py:633
+#: ../gui/wxpython/gui_modules/wxplot.py:635
+#: ../gui/wxpython/wxplot/histogram.py:114
+#: ../gui/wxpython/wxplot/histogram.py:116
+#, python-format
+msgid "Histogram of %s"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:60
-msgid ""
-"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
+#: ../gui/wxpython/gui_modules/wxplot.py:643
+#: ../gui/wxpython/gui_modules/wxplot.py:1201
+#: ../gui/wxpython/gui_modules/wxplot.py:1207
+#: ../gui/wxpython/wxplot/histogram.py:124
+#, python-format
+msgid "Raster cell values %s"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:62
-msgid "Click mouse to zoom"
+#: ../gui/wxpython/gui_modules/wxplot.py:651
+#: ../gui/wxpython/wxplot/histogram.py:132
+msgid "Percent of total cells"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:63
-msgid "Click mouse to unzoom"
+#: ../gui/wxpython/gui_modules/wxplot.py:652
+#: ../gui/wxpython/wxplot/histogram.py:133
+msgid "Area"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:91
-msgid "3D view mode not available"
+#: ../gui/wxpython/gui_modules/wxplot.py:730
+#: ../gui/wxpython/wxplot/histogram.py:215
+msgid "Statistics for Map(s) Histogrammed"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:92
-#: ../gui/wxpython/mapdisp/toolbars.py:106
+#: ../gui/wxpython/gui_modules/wxplot.py:735
#, python-format
-msgid "Reason: %s"
+msgid ""
+"Statistics for %s\n"
+"\n"
+"%s\n"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:105
-msgid "Vector digitizer not available"
+#: ../gui/wxpython/gui_modules/wxplot.py:753
+#: ../gui/wxpython/wxplot/profile.py:53
+msgid "GRASS Profile Analysis Tool"
msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:107
-msgid ""
-"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
-"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
-"In the meantime you can use \"v.digit\" from the Develop Vector menu."
+#: ../gui/wxpython/gui_modules/wxplot.py:764
+#: ../gui/wxpython/gui_modules/wxplot.py:846
+#: ../gui/wxpython/wxplot/profile.py:64 ../gui/wxpython/wxplot/profile.py:151
+msgid "Profile of"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:395
-msgid "Render"
+#: ../gui/wxpython/gui_modules/wxplot.py:779
+#: ../gui/wxpython/wxplot/profile.py:78
+#, python-format
+msgid "Distance (%s)"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:399
-msgid "Enable/disable auto-rendering"
+#: ../gui/wxpython/gui_modules/wxplot.py:781
+#: ../gui/wxpython/wxplot/profile.py:80
+msgid "Distance along transect"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:429
-msgid "Show comp. extent"
+#: ../gui/wxpython/gui_modules/wxplot.py:782
+#: ../gui/wxpython/wxplot/profile.py:81
+msgid "Cell values"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:433
-msgid "Show computational extent"
+#: ../gui/wxpython/gui_modules/wxplot.py:907
+#: ../gui/wxpython/wxplot/profile.py:211
+msgid "Raster values"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:436
-msgid ""
-"Show/hide computational region extent (set with g.region). Display region "
-"drawn as a blue box inside the computational region, computational region "
-"inside a display region as a red box)."
+#: ../gui/wxpython/gui_modules/wxplot.py:958
+#: ../gui/wxpython/wxplot/profile.py:262
+msgid "You must draw a transect to profile in the map display window."
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:484
-msgid "Display mode"
+#: ../gui/wxpython/gui_modules/wxplot.py:959
+#: ../gui/wxpython/wxplot/profile.py:263
+msgid "Nothing to profile"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:491
-msgid ""
-"Align region extent based on display size from center point. Default value "
-"for new map displays can be set up in 'User GUI settings' dialog."
+#: ../gui/wxpython/gui_modules/wxplot.py:1026
+#: ../gui/wxpython/wxplot/profile.py:330
+msgid "Comma separated value (*.csv)|*.csv"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:524
-msgid "Display resolution"
+#: ../gui/wxpython/gui_modules/wxplot.py:1029
+#: ../gui/wxpython/wxplot/profile.py:333
+msgid "Path and prefix (for raster name) to save profile values..."
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:530
-msgid ""
-"Constrain display resolution to computational region settings. Default value "
+#: ../gui/wxpython/gui_modules/wxplot.py:1055
+#: ../gui/wxpython/wxplot/profile.py:359
+msgid "Statistics for Profile(s)"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:567
-msgid "Map scale"
-msgstr "Kartes mērogs"
+#: ../gui/wxpython/gui_modules/wxplot.py:1096
+#: ../gui/wxpython/wxplot/scatter.py:40
+msgid "GRASS Bivariate Scatterplot Tool"
+msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:581
+#: ../gui/wxpython/gui_modules/wxplot.py:1103
+#: ../gui/wxpython/wxplot/scatter.py:47
+msgid "Bivariate Scatterplot"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot.py:1181
+#: ../gui/wxpython/wxplot/scatter.py:125
+msgid "Bivariate Scatterplot of "
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot.py:1292
+#: ../gui/wxpython/wxplot/scatter.py:244
+msgid "Regression Statistics for Scatterplot(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxplot.py:1304
+#, python-format
msgid ""
-"As everyone's monitors and resolutions are set differently these values are "
-"not true map scales, but should get you into the right neighborhood."
+"Regression equation for %s vs. %s:\n"
+"\n"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:634
-msgid "Go to"
-msgstr "Iet uz"
+#: ../gui/wxpython/gui_modules/wxplot.py:1305
+#, python-format
+msgid ""
+" %s = %s + %s(%s)\n"
+"\n"
+msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:655
-#: ../gui/wxpython/mapdisp/statusbar.py:719
-#: ../gui/wxpython/mapdisp/statusbar.py:925
-#: ../gui/wxpython/mapdisp/statusbar.py:991
-msgid "Projection not defined (check the settings)"
+#: ../gui/wxpython/gui_modules/wxplot.py:1306
+#, python-format
+msgid "N = %s\n"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:733
-#: ../gui/wxpython/mapdisp/statusbar.py:938
-#: ../gui/wxpython/mapdisp/statusbar.py:1021
-msgid "Error in projection (check the settings)"
+#: ../gui/wxpython/gui_modules/wxplot.py:1307
+#, python-format
+msgid "R = %s\n"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:767
-msgid "Use defined projection"
+#: ../gui/wxpython/gui_modules/wxplot.py:1308
+#, python-format
+msgid "R-squared = %f\n"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:779
-msgid ""
-"Reproject coordinates displayed in the statusbar. Projection can be defined "
-"in GUI preferences dialog (tab 'Projection')"
+#: ../gui/wxpython/gui_modules/wxplot.py:1309
+#, python-format
+msgid "F = %s\n"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:804
-msgid "MASK"
-msgstr "MASK"
+#: ../gui/wxpython/gui_modules/histogram.py:177
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:664
+#: ../gui/wxpython/modules/histogram.py:176
+#: ../gui/wxpython/mapdisp/mapwindow.py:471
+msgid "Please wait, exporting image..."
+msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:848
-msgid "Display geometry"
+#: ../gui/wxpython/gui_modules/histogram.py:267
+#, fuzzy
+msgid "GRASS GIS Histogram of raster map"
+#: ../gui/wxpython/gui_modules/histogram.py:358
+#: ../gui/wxpython/modules/histogram.py:368
+msgid "Select font for histogram text"
msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:870
-msgid "Coordinates"
-msgstr "Koordinātes"
+#: ../gui/wxpython/gui_modules/wxvdigit.py:48
+#: ../gui/wxpython/vdigit/wxdigit.py:50
+msgid "Digitization Error"
+msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:950
-msgid "Extent"
-msgstr "Apjoms"
+#: ../gui/wxpython/gui_modules/wxvdigit.py:53
+#: ../gui/wxpython/vdigit/wxdigit.py:55
+#, python-format
+msgid "Unable to open vector map <%s>."
+msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:1045
-msgid "Computational region"
+#: ../gui/wxpython/gui_modules/wxvdigit.py:55
+#: ../gui/wxpython/vdigit/wxdigit.py:57
+msgid "No vector map open for editing."
msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:114
+#: ../gui/wxpython/gui_modules/wxvdigit.py:56
+msgid "Operation cancelled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxvdigit.py:63
#, python-format
-msgid "Unsupported command %s."
+msgid ""
+"Writing new feature failed. Operation cancelled.\n"
+"\n"
+"Reason: %s"
msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:176
+#: ../gui/wxpython/gui_modules/wxvdigit.py:72
#, python-format
-msgid "Unable to read cmdfile '%(cmd)s'. Details: %(det)s"
+msgid "Reading feature id %d failed. Operation cancelled."
msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:430
+#: ../gui/wxpython/gui_modules/wxvdigit.py:80
#, python-format
-msgid "Starting map display <%s>..."
+msgid "Database link %d not available. Operation cancelled."
msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:437
-msgid "GRASS GIS Map Display: "
+#: ../gui/wxpython/gui_modules/wxvdigit.py:88
+#, python-format
+msgid "Unable to start database driver <%s>. Operation cancelled."
msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:443
+#: ../gui/wxpython/gui_modules/wxvdigit.py:96
#, python-format
-msgid "Stopping map display <%s>..."
+msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation cancelled."
msgstr ""
-#: ../gui/wxpython/mapdisp/gprint.py:150
-msgid ""
-"There was a problem printing.\n"
-"Perhaps your current printer is not set correctly?"
+#: ../gui/wxpython/gui_modules/wxvdigit.py:104
+#, python-format
+msgid "Unable to execute SQL query '%s'. Operation cancelled."
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:20
-msgid "GRASS GIS Setup for r.li modules"
+#: ../gui/wxpython/gui_modules/wxvdigit.py:112
+#, python-format
+msgid "Feature id %d is marked as dead. Operation cancelled."
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:37
-msgid "Available sampling area configuration files"
+#: ../gui/wxpython/gui_modules/wxvdigit.py:120
+#, python-format
+msgid "Unsupported feature type %d. Operation cancelled."
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:46
-msgid "Remove a configuration file"
+#: ../gui/wxpython/gui_modules/wxvdigit.py:466
+#: ../gui/wxpython/vdigit/wxdigit.py:411
+#, python-format
+msgid "Unknown feature type '%s'"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:49
-msgid "Create a new configuration file"
+#: ../gui/wxpython/gui_modules/wxvdigit.py:471
+#: ../gui/wxpython/vdigit/wxdigit.py:416
+msgid "Not enough points for line"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:52
-msgid "Rename a configuration file"
+#: ../gui/wxpython/gui_modules/mapdisp.py:391
+#: ../gui/wxpython/mapdisp/frame.py:65
+msgid "GRASS GIS - Map display"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:135
-msgid "You have to select a configuration file"
+#: ../gui/wxpython/gui_modules/mapdisp.py:568
+#: ../gui/wxpython/mapdisp/frame.py:245
+msgid "Vector Digitizer Toolbar"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:138
+#: ../gui/wxpython/gui_modules/mapdisp.py:589
+#: ../gui/wxpython/mapdisp/frame.py:266
#, python-format
msgid ""
-"Set te new name for %s \" "
-"\"configuration file"
+"Unable to switch to 3D display mode.\n"
+"The Nviz python extension was not found or loaded properly.\n"
+"Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:140
-msgid "Rename configuration file"
+#: ../gui/wxpython/gui_modules/mapdisp.py:614
+#: ../gui/wxpython/mapdisp/frame.py:291
+msgid "Starting 3D view mode..."
msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:144
-#: ../gui/wxpython/rlisetup/wizard.py:547
-msgid "Draw sampling frame"
+#: ../gui/wxpython/gui_modules/mapdisp.py:616
+#: ../gui/wxpython/mapdisp/frame.py:293
+msgid "Please wait, loading data..."
msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:145
-msgid "Draw sampling frame by clicking and dragging"
+#: ../gui/wxpython/gui_modules/mapdisp.py:673
+#: ../gui/wxpython/mapdisp/frame.py:349
+msgid "Please wait, unloading data..."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:57
-msgid "Create new configuration file for r.li modules"
+#: ../gui/wxpython/gui_modules/mapdisp.py:674
+#: ../gui/wxpython/mapdisp/frame.py:350
+msgid "Switching back to 2D view mode..."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:96
+#: ../gui/wxpython/gui_modules/mapdisp.py:977
+#: ../gui/wxpython/mapdisp/frame.py:654
+msgid "No raster or vector map layer selected for querying."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1023
+#: ../gui/wxpython/mapdisp/frame.py:700
#, python-format
-msgid "Do you want to create r.li configuration file <%s>?"
+msgid "Vector map <%s> opened for editing - skipped."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:98
-msgid "Create new r.li configuration file?"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1028
+#: ../gui/wxpython/mapdisp/frame.py:705
+msgid "Nothing to query."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:111
-msgid "r.li.setup wizard canceled. Configuration file not created."
+#: ../gui/wxpython/gui_modules/mapdisp.py:1079
+#: ../gui/wxpython/mapdisp/frame.py:756
+msgid "No map layer selected for querying."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:295
-msgid "Select maps and define name"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1116
+#: ../gui/wxpython/mapdisp/frame.py:793
+msgid "Nothing found."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:306
-msgid "Name for new configuration file to create"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1242
+#: ../gui/wxpython/mapdisp/toolbars.py:44
+msgid "Create bivariate scatterplot of raster maps"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:318
-msgid "Raster map to use to select areas"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1252
+#: ../gui/wxpython/gui_core/toolbars.py:75
+msgid "Create histogram with d.histogram"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:328
-msgid "Vector map to use to select areas"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1283
+#: ../gui/wxpython/mapdisp/frame.py:924
+#, python-format
+msgid ""
+"Click and drag with left mouse button to measure.%sDouble click with left "
+"button to clear."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:340
-msgid "Define sampling region (region for analysis)"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1289
+#: ../gui/wxpython/mapdisp/frame.py:930
+msgid "Measuring distance"
+msgstr "Attāluma mērīšana"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1292
+#: ../gui/wxpython/mapdisp/frame.py:933
+#, fuzzy
+msgid "Measuring distance:"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1302
+#: ../gui/wxpython/mapdisp/frame.py:943
+#, python-format
+msgid ""
+"Geodesic distance is not yet supported by this tool.\n"
+"Reason: %s"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:342
-#: ../gui/wxpython/rlisetup/wizard.py:600
-msgid "Whole map layer"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1330
+#: ../gui/wxpython/gui_modules/mapdisp.py:1336
+#: ../gui/wxpython/mapdisp/frame.py:971 ../gui/wxpython/mapdisp/frame.py:977
+msgid "segment"
+msgstr "segments"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1331
+#: ../gui/wxpython/gui_modules/mapdisp.py:1337
+#: ../gui/wxpython/mapdisp/frame.py:972 ../gui/wxpython/mapdisp/frame.py:978
+msgid "total distance"
+msgstr "kopējais garums"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1332
+#: ../gui/wxpython/mapdisp/frame.py:973
+msgid "bearing"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:343
+msgid "deg"
+msgstr "grādi"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1476
#, fuzzy
-msgid "Keyboard setting"
-msgstr "Vektoru iestatījumi"
+msgid "Add north arrow"
+msgstr "Ziemeļu bulta"
-#: ../gui/wxpython/rlisetup/wizard.py:344
-msgid "Draw the sampling frame"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1513
+#: ../gui/wxpython/mapdisp/frame.py:1115
+#, fuzzy
+msgid "Scale and North arrow"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1519
+#: ../gui/wxpython/mapdisp/frame.py:1121
+#, fuzzy
+msgid "Show/hide scale and North arrow"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1520
+#: ../gui/wxpython/mapdisp/frame.py:1122
+#, fuzzy
+msgid "scale object"
+msgstr "Mērogjosla"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1550
+#: ../gui/wxpython/mapdisp/frame.py:1152
+msgid "Show/hide legend"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:382
+#: ../gui/wxpython/gui_modules/mapdisp.py:1551
+#: ../gui/wxpython/mapdisp/frame.py:1153
+#, fuzzy
+msgid "legend object"
+msgstr "Leģenda"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1573
+#: ../gui/wxpython/mapdisp/toolbars.py:46
+#: ../gui/wxpython/mapdisp/frame.py:1176
+msgid "Add text layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1668
+#: ../gui/wxpython/mapdisp/frame.py:1271
+msgid "Zoom to computational region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1680
+#: ../gui/wxpython/mapdisp/frame.py:1283
+msgid "Set computational region from display extent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1793
+#: ../gui/wxpython/mapdisp/main.py:316
#, python-format
-msgid "The configuration file %s already exists, please change name"
+msgid "Starting map display <%s>..."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:437
-msgid "Insert sampling frame parameter"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1800
+#: ../gui/wxpython/mapdisp/main.py:323
+msgid "GRASS GIS Map Display: "
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:448
-msgid "Column of upper left corner"
+#: ../gui/wxpython/gui_modules/mapdisp.py:1806
+#: ../gui/wxpython/mapdisp/main.py:329
+#, python-format
+msgid "Stopping map display <%s>..."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:461
-msgid "Row of upper left corner"
+#: ../gui/wxpython/gui_modules/mapdisp_vdigit.py:382
+#: ../gui/wxpython/vdigit/mapwindow.py:382
+msgid "Update categories"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:474
-#: ../gui/wxpython/rlisetup/wizard.py:486
-msgid "Row lenght of sampling frame"
+#: ../gui/wxpython/gui_modules/mapdisp_vdigit.py:505
+#: ../gui/wxpython/gui_modules/mapdisp_vdigit.py:861
+#: ../gui/wxpython/vdigit/mapwindow.py:505
+#: ../gui/wxpython/vdigit/mapwindow.py:871
+msgid "No vector map selected for editing."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:594
-msgid "Insert sampling areas"
+#: ../gui/wxpython/gui_modules/mapdisp_vdigit.py:994
+#: ../gui/wxpython/vdigit/mapwindow.py:1007
+msgid "Z bulk-labeling dialog"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:601
-#, fuzzy
-msgid "Regions"
-msgstr "Reģions"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:55
+#: ../gui/wxpython/modules/mcalc_builder.py:51
+msgid "GRASS GIS Raster Map Calculator"
+msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:602
-msgid "Sample units"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:58
+#: ../gui/wxpython/modules/mcalc_builder.py:54
+msgid "GRASS GIS 3D Raster Map Calculator"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:604
-msgid ""
-"Select areas from the\n"
-"overlayed vector map"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:69
+#: ../gui/wxpython/modules/mcalc_builder.py:65
+msgid "mapcalc statement"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:609
-#: ../gui/wxpython/rlisetup/wizard.py:622
-msgid "This option is not supported yet"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:120
+#: ../gui/wxpython/modules/mcalc_builder.py:116
+msgid "Operators"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:616
-msgid "Choose a method"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:122
+#: ../gui/wxpython/modules/mcalc_builder.py:118
+msgid "Operands"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:617
-msgid "Use keyboard to enter sampling area"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:124
+#: ../gui/wxpython/modules/mcalc_builder.py:120
+msgid "Expression"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:618
-msgid "Use mouse to draw sampling area"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:139
+#: ../gui/wxpython/modules/mcalc_builder.py:135
+msgid "Save expression to file"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:674
-msgid "Function not supported yet"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:142
+#: ../gui/wxpython/modules/mcalc_builder.py:138
+msgid "Load expression from file"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:719
-#: ../gui/wxpython/rlisetup/wizard.py:867
-msgid "Select type of shape"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:146
+#: ../gui/wxpython/modules/mcalc_builder.py:142
+msgid "exponent"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:720
-#: ../gui/wxpython/rlisetup/wizard.py:868
-msgid "Circle"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:148
+#: ../gui/wxpython/modules/mcalc_builder.py:144
+msgid "divide"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:741
-#: ../gui/wxpython/rlisetup/wizard.py:892
-msgid "Width size (in cells)? "
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:150
+#: ../gui/wxpython/modules/mcalc_builder.py:146
+msgid "add"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:742
-#: ../gui/wxpython/rlisetup/wizard.py:893
-msgid "What radius size (in meters)? "
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:152
+#: ../gui/wxpython/modules/mcalc_builder.py:148
+msgid "subtract"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:743
-#: ../gui/wxpython/rlisetup/wizard.py:894
-msgid "Height size (in cells)? "
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:154
+#: ../gui/wxpython/modules/mcalc_builder.py:150
+msgid "modulus"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:744
-#: ../gui/wxpython/rlisetup/wizard.py:895
-msgid "Name of the circle mask"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:156
+#: ../gui/wxpython/modules/mcalc_builder.py:152
+msgid "multiply"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:750
-msgid "Select method of sampling unit distribution"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:161
+#: ../gui/wxpython/modules/mcalc_builder.py:157
+msgid "left shift"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:751
-msgid "Random non overlapping"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:163
+#: ../gui/wxpython/modules/mcalc_builder.py:159
+msgid "right shift"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:752
-msgid "Systematic contiguos"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:165
+#: ../gui/wxpython/modules/mcalc_builder.py:161
+msgid "right shift (unsigned)"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:753
-msgid "Stratified random"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:167
+#: ../gui/wxpython/modules/mcalc_builder.py:163
+msgid "greater than"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:754
-msgid "Systematic non contiguos"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:169
+#: ../gui/wxpython/modules/mcalc_builder.py:165
+msgid "greater than or equal to"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:755
-msgid "Centered over sites"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:171
+#: ../gui/wxpython/modules/mcalc_builder.py:167
+msgid "less than"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:762
-#: ../gui/wxpython/rlisetup/wizard.py:807
-msgid "What number of Sampling Units to use?"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:173
+#: ../gui/wxpython/modules/mcalc_builder.py:169
+msgid "less than or equal to"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:821
-msgid "Insert number of row strates"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:175
+#: ../gui/wxpython/modules/mcalc_builder.py:171
+msgid "equal to"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:822
-msgid "Insert number of column strates"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:177
+#: ../gui/wxpython/modules/mcalc_builder.py:173
+msgid "not equal to"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:828
-msgid "Insert distance between units"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:180
+#: ../gui/wxpython/modules/mcalc_builder.py:176
+msgid "one's complement"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:878
-msgid "Width size (in cells) ?"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:182
+#: ../gui/wxpython/modules/mcalc_builder.py:178
+msgid "NOT"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:885
-msgid "Height size (in cells) ?"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:184
+#: ../gui/wxpython/modules/mcalc_builder.py:180
+msgid "bitwise AND"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:932
-msgid "Configuration file name:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:186
+#: ../gui/wxpython/modules/mcalc_builder.py:182
+msgid "bitwise OR"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:942
-#, fuzzy
-msgid "Raster name:"
-msgstr "Tabulas nosaukums"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:188
+#: ../gui/wxpython/modules/mcalc_builder.py:184
+msgid "logical AND"
+msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:952
-#, fuzzy
-msgid "Vector name:"
-msgstr "&Vektors"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:190
+#: ../gui/wxpython/modules/mcalc_builder.py:186
+msgid "logical AND (ignores NULLs)"
+msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:962
-#, fuzzy
-msgid "Region type:"
-msgstr "Reģions:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:192
+#: ../gui/wxpython/modules/mcalc_builder.py:188
+msgid "logical OR"
+msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:982
-msgid "Sampling area type:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:194
+#: ../gui/wxpython/modules/mcalc_builder.py:190
+msgid "logical OR (ignores NULLs)"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1048
-msgid "Region keybord values:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:196
+#: ../gui/wxpython/modules/mcalc_builder.py:192
+msgid "conditional"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1061
-#: ../gui/wxpython/rlisetup/wizard.py:1085
-msgid "Type of shape:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:209
+#: ../gui/wxpython/modules/mcalc_builder.py:205
+msgid "Name for new 3D raster map to create"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1064
-#: ../gui/wxpython/rlisetup/wizard.py:1088
-msgid "Radius size:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:211
+#: ../gui/wxpython/modules/mcalc_builder.py:207
+msgid "Name for new raster map to create"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1065
-#: ../gui/wxpython/rlisetup/wizard.py:1089
-msgid "Name circle mask:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:215
+#: ../gui/wxpython/modules/mcalc_builder.py:211
+msgid "Insert existing 3D raster map"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1067
-#: ../gui/wxpython/rlisetup/wizard.py:1091
-#, fuzzy
-msgid "Width size:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:217
+#: ../gui/wxpython/modules/mcalc_builder.py:213
+msgid "Insert existing raster map"
+msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1068
-#: ../gui/wxpython/rlisetup/wizard.py:1092
-#, fuzzy
-msgid "Heigth size:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:221
+#: ../gui/wxpython/modules/mcalc_builder.py:217
+msgid "Insert mapcalc function"
+msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1071
-msgid "Method of distribution:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:232
+#: ../gui/wxpython/modules/mcalc_builder.py:228
+msgid "Add created raster map into layer tree"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1074
-msgid "Number sampling units:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:457
+#: ../gui/wxpython/modules/mcalc_builder.py:453
+msgid "You must enter the name of a new raster map to create."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1077
-msgid "Distance between units:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:464
+#: ../gui/wxpython/modules/mcalc_builder.py:460
+msgid "You must enter an expression to create a new raster map."
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1080
-msgid "Number row strates:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:506
+#: ../gui/wxpython/modules/mcalc_builder.py:502
+msgid "Choose a file name to save the expression"
msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1082
-msgid "Number column strates:"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:507
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:528
+#: ../gui/wxpython/modules/mcalc_builder.py:503
+#: ../gui/wxpython/modules/mcalc_builder.py:524
+msgid "Expression file (*)|*"
msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:59
-#, fuzzy
-msgid "GRASS GIS Vector Digitizer"
-msgstr "GRASS GIS slāņu pārvaldnieks"
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:527
+#: ../gui/wxpython/modules/mcalc_builder.py:523
+msgid "Choose a file name to load the expression"
+msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:95
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1814
+#: ../gui/wxpython/mapdisp/mapwindow.py:1706
+msgid "Zoom to saved region extents"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1823
+#: ../gui/wxpython/mapdisp/mapwindow.py:1715
#, python-format
-msgid "Vector digitizer not available. %s"
+msgid "Region <%s> not found. Operation canceled."
msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:100
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1844
+#: ../gui/wxpython/mapdisp/mapwindow.py:1736
+msgid "Save display extents to region file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp_window.py:1854
+#: ../gui/wxpython/mapdisp/mapwindow.py:1746
#, python-format
-msgid ""
-"Vector map <%s> not found in current mapset. New vector map can be created "
-"by providing '-c' flag."
+msgid "Region file <%s> already exists. Do you want to overwrite it?"
msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:105
+#: ../gui/wxpython/gui_modules/gcpmanager.py:628
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2578
+msgid "Select target map to display:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcpmanager.py:965
#, python-format
-msgid "Unable to create new vector map <%s>"
+msgid "At least %d GCPs required. Operation cancelled."
msgstr ""
-#: ../gui/wxpython/vdigit/wxdisplay.py:898
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1052
+msgid "mapwin not defined for "
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1458
#, python-format
-msgid ""
-"Topology for vector map <%s> is not available. Topology is required by "
-"digitizer. Do you want to rebuild topology (takes some time) and open the "
-"vector map for editing?"
+msgid "Vector map <%s> already exists. Change extension name and georectify again."
msgstr ""
-#: ../gui/wxpython/vdigit/wxdisplay.py:902
-msgid "Topology missing"
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1468
+msgid "For all vector maps georectified successfully,"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:31
-#: ../gui/wxpython/vdigit/toolbars.py:150
-msgid "Digitization settings"
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1469
+msgid "you will need to copy any attribute tables"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:57
+#: ../gui/wxpython/gui_modules/gcpmanager.py:1470
+msgid "and reconnect them to the georectified vectors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcpmanager.py:2089
+msgid "Invalid coordinate value. Operation cancelled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:87
+#: ../gui/wxpython/vdigit/preferences.py:53
msgid "Apply changes for this session"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:60
+#: ../gui/wxpython/gui_modules/vdigit.py:90
+#: ../gui/wxpython/vdigit/preferences.py:56
msgid "Close dialog and save changes to user settings file"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:152
+#: ../gui/wxpython/gui_modules/vdigit.py:181
+#: ../gui/wxpython/vdigit/preferences.py:148
msgid "Snapping"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:158
+#: ../gui/wxpython/gui_modules/vdigit.py:187
+#: ../gui/wxpython/vdigit/preferences.py:154
msgid "Snapping threshold"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:165
+#: ../gui/wxpython/gui_modules/vdigit.py:194
+#: ../gui/wxpython/vdigit/preferences.py:161
msgid "screen pixels"
msgstr ""
msgid "map units"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:174
+#: ../gui/wxpython/gui_modules/vdigit.py:203
+#: ../gui/wxpython/vdigit/preferences.py:170
msgid "Snap also to vertex"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:179
-#: ../gui/wxpython/vdigit/preferences.py:623
-#: ../gui/wxpython/vdigit/preferences.py:637
-#: ../gui/wxpython/vdigit/preferences.py:641
+#: ../gui/wxpython/gui_modules/vdigit.py:208
+#: ../gui/wxpython/gui_modules/vdigit.py:635
+#: ../gui/wxpython/gui_modules/vdigit.py:649
+#: ../gui/wxpython/gui_modules/vdigit.py:653
+#: ../gui/wxpython/vdigit/preferences.py:175
+#: ../gui/wxpython/vdigit/preferences.py:603
+#: ../gui/wxpython/vdigit/preferences.py:617
+#: ../gui/wxpython/vdigit/preferences.py:621
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:192
+#: ../gui/wxpython/gui_modules/vdigit.py:221
+#: ../gui/wxpython/vdigit/preferences.py:188
msgid "Select vector features"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:209
+#: ../gui/wxpython/gui_modules/vdigit.py:238
+#: ../gui/wxpython/vdigit/preferences.py:205
msgid "Select threshold"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:222
+#: ../gui/wxpython/gui_modules/vdigit.py:251
+#: ../gui/wxpython/vdigit/preferences.py:218
msgid "Select only features inside of selection bounding box"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:224
-msgid ""
-"By default are selected all features overlapping selection bounding box "
+#: ../gui/wxpython/gui_modules/vdigit.py:253
+#: ../gui/wxpython/vdigit/preferences.py:220
+msgid "By default are selected all features overlapping selection bounding box "
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:227
+#: ../gui/wxpython/gui_modules/vdigit.py:256
+#: ../gui/wxpython/vdigit/preferences.py:223
msgid "Check for duplicates"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:239
-msgid "Digitize lines/boundaries"
+#: ../gui/wxpython/gui_modules/vdigit.py:268
+#: ../gui/wxpython/vdigit/preferences.py:235
+msgid "Digitize line features"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:242
+#: ../gui/wxpython/gui_modules/vdigit.py:271
+#: ../gui/wxpython/vdigit/preferences.py:238
msgid "Break lines at intersection"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:252
-msgid "Digitize areas"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:255
-msgid "Close boundary (snap to the start node)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:265
+#: ../gui/wxpython/gui_modules/vdigit.py:281
+#: ../gui/wxpython/vdigit/preferences.py:248
msgid "Save changes"
msgstr "Saglabāt izmaiņas"
-#: ../gui/wxpython/vdigit/preferences.py:268
+#: ../gui/wxpython/gui_modules/vdigit.py:284
+#: ../gui/wxpython/vdigit/preferences.py:251
msgid "Save changes on exit"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:280
+#: ../gui/wxpython/gui_modules/vdigit.py:296
+#: ../gui/wxpython/vdigit/preferences.py:263
msgid "Query tool"
msgstr "Vaicājumu rīks"
-#: ../gui/wxpython/vdigit/preferences.py:287
+#: ../gui/wxpython/gui_modules/vdigit.py:303
+#: ../gui/wxpython/vdigit/preferences.py:270
msgid "Choose query tool"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:292
+#: ../gui/wxpython/gui_modules/vdigit.py:308
+#: ../gui/wxpython/vdigit/preferences.py:275
msgid "Select by box"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:301
-#: ../gui/wxpython/vdigit/preferences.py:432
+#: ../gui/wxpython/gui_modules/vdigit.py:317
+#: ../gui/wxpython/gui_modules/vdigit.py:449
+#: ../gui/wxpython/vdigit/preferences.py:284
+#: ../gui/wxpython/vdigit/preferences.py:416
msgid "length"
msgstr "garums"
-#: ../gui/wxpython/vdigit/preferences.py:306
+#: ../gui/wxpython/gui_modules/vdigit.py:322
+#: ../gui/wxpython/vdigit/preferences.py:289
msgid "Select lines"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:308
-#: ../gui/wxpython/vdigit/preferences.py:331
+#: ../gui/wxpython/gui_modules/vdigit.py:324
+#: ../gui/wxpython/gui_modules/vdigit.py:347
+#: ../gui/wxpython/vdigit/preferences.py:291
+#: ../gui/wxpython/vdigit/preferences.py:314
msgid "shorter than"
msgstr ""
msgid "longer than"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:324
+#: ../gui/wxpython/gui_modules/vdigit.py:340
+#: ../gui/wxpython/vdigit/preferences.py:307
msgid "dangle"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:329
+#: ../gui/wxpython/gui_modules/vdigit.py:345
+#: ../gui/wxpython/vdigit/preferences.py:312
msgid "Select dangles"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:368
+#: ../gui/wxpython/gui_modules/vdigit.py:384
+#: ../gui/wxpython/vdigit/preferences.py:351
msgid "Digitize new feature"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:373
+#: ../gui/wxpython/gui_modules/vdigit.py:389
+#: ../gui/wxpython/vdigit/preferences.py:356
msgid "Add new record into table"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:379
+#: ../gui/wxpython/gui_modules/vdigit.py:395
+#: ../gui/wxpython/vdigit/preferences.py:362
msgid "Mode"
msgstr "Režīms"
-#: ../gui/wxpython/vdigit/preferences.py:401
+#: ../gui/wxpython/gui_modules/vdigit.py:417
+#: ../gui/wxpython/vdigit/preferences.py:384
msgid "Next to use"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:389
+#: ../gui/wxpython/gui_modules/vdigit.py:405
+#: ../gui/wxpython/vdigit/preferences.py:372
msgid "Category number"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:399
+#: ../gui/wxpython/gui_modules/vdigit.py:415
+#: ../gui/wxpython/vdigit/preferences.py:382
msgid "Category mode"
msgstr ""
msgid "Manual entry"
msgstr ""
msgid "No category"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:414
+#: ../gui/wxpython/gui_modules/vdigit.py:430
+#: ../gui/wxpython/vdigit/preferences.py:397
msgid "Delete existing feature(s)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:419
+#: ../gui/wxpython/gui_modules/vdigit.py:435
+#: ../gui/wxpython/vdigit/preferences.py:402
msgid "Delete record from table"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:429
+#: ../gui/wxpython/gui_modules/vdigit.py:445
+#: ../gui/wxpython/vdigit/preferences.py:412
msgid "Geometry attributes"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:434
+#: ../gui/wxpython/gui_modules/vdigit.py:451
+#: ../gui/wxpython/vdigit/preferences.py:418
msgid "perimeter"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:503
+#: ../gui/wxpython/gui_modules/vdigit.py:517
+#: ../gui/wxpython/vdigit/preferences.py:484
msgid ""
"Note: These settings are stored in the workspace not in the vector digitizer "
"preferences."
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:532
-msgid "Digitize new line segment"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:533
-msgid "Digitize new line/boundary"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:534
+#: ../gui/wxpython/gui_modules/vdigit.py:546
+#: ../gui/wxpython/vdigit/preferences.py:514
msgid "Highlight"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:535
+#: ../gui/wxpython/gui_modules/vdigit.py:547
+#: ../gui/wxpython/vdigit/preferences.py:515
msgid "Highlight (duplicates)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:538
+#: ../gui/wxpython/gui_modules/vdigit.py:550
+#: ../gui/wxpython/vdigit/preferences.py:518
msgid "Boundary (no area)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:539
+#: ../gui/wxpython/gui_modules/vdigit.py:551
+#: ../gui/wxpython/vdigit/preferences.py:519
msgid "Boundary (one area)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:540
+#: ../gui/wxpython/gui_modules/vdigit.py:552
+#: ../gui/wxpython/vdigit/preferences.py:520
msgid "Boundary (two areas)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:541
+#: ../gui/wxpython/gui_modules/vdigit.py:553
+#: ../gui/wxpython/vdigit/preferences.py:521
msgid "Centroid (in area)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:542
+#: ../gui/wxpython/gui_modules/vdigit.py:554
+#: ../gui/wxpython/vdigit/preferences.py:522
msgid "Centroid (outside area)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:543
+#: ../gui/wxpython/gui_modules/vdigit.py:555
+#: ../gui/wxpython/vdigit/preferences.py:523
msgid "Centroid (duplicate in area)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:544
+#: ../gui/wxpython/gui_modules/vdigit.py:556
+#: ../gui/wxpython/vdigit/preferences.py:524
msgid "Node (one line)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:545
+#: ../gui/wxpython/gui_modules/vdigit.py:557
+#: ../gui/wxpython/vdigit/preferences.py:525
msgid "Node (two lines)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:546
+#: ../gui/wxpython/gui_modules/vdigit.py:558
+#: ../gui/wxpython/vdigit/preferences.py:526
msgid "Vertex"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:547
+#: ../gui/wxpython/gui_modules/vdigit.py:559
+#: ../gui/wxpython/vdigit/preferences.py:527
msgid "Area (closed boundary + centroid)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:548
+#: ../gui/wxpython/gui_modules/vdigit.py:560
+#: ../gui/wxpython/vdigit/preferences.py:528
msgid "Direction"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:616
+#: ../gui/wxpython/gui_modules/vdigit.py:628
+#: ../gui/wxpython/vdigit/preferences.py:596
msgid "Snapping disabled"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:618
+#: ../gui/wxpython/gui_modules/vdigit.py:630
+#: ../gui/wxpython/vdigit/preferences.py:598
#, python-format
msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:674
+#: ../gui/wxpython/gui_modules/vdigit.py:686
+#: ../gui/wxpython/vdigit/preferences.py:654
#, python-format
msgid "Vector digitizer settings saved to file <%s>."
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:53
-msgid "Digitization Error"
+#: ../gui/wxpython/gui_modules/vdigit.py:861
+#: ../gui/wxpython/vdigit/dialogs.py:74
+msgid "List of categories - right-click to delete"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:58
-#, python-format
-msgid "Unable to open vector map <%s>."
+#: ../gui/wxpython/gui_modules/vdigit.py:892
+#: ../gui/wxpython/vdigit/dialogs.py:105
+msgid "Add new category"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:60
-msgid "No vector map open for editing."
+#: ../gui/wxpython/gui_modules/vdigit.py:931
+#: ../gui/wxpython/vdigit/dialogs.py:144
+msgid "Ignore changes and close dialog"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:61
-msgid "Operation canceled."
+#: ../gui/wxpython/gui_modules/vdigit.py:933
+#: ../gui/wxpython/vdigit/dialogs.py:146
+msgid "Apply changes and close dialog"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:68
+#: ../gui/wxpython/gui_modules/vdigit.py:1023
+#: ../gui/wxpython/gui_modules/vdigit.py:1242
#, python-format
msgid ""
-"Writing new feature failed. Operation canceled.\n"
-"\n"
-"Reason: %s"
+"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+"Layer and category number must be integer.\n"
+"Layer number must be greater then zero."
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:77
+#: ../gui/wxpython/gui_modules/vdigit.py:1219
+#: ../gui/wxpython/vdigit/dialogs.py:432
+msgid "Unable to update vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1379
+#: ../gui/wxpython/vdigit/dialogs.py:592
#, python-format
-msgid "Reading feature id %d failed. Operation canceled."
+msgid "%d lines selected for z bulk-labeling"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:85
+#: ../gui/wxpython/gui_modules/vdigit.py:1382
+#: ../gui/wxpython/vdigit/dialogs.py:595
+msgid "Set value"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1389
+#: ../gui/wxpython/vdigit/dialogs.py:602
+msgid "Starting value"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1398
+#: ../gui/wxpython/vdigit/dialogs.py:611
+msgid "Step"
+msgstr "Solis"
+#: ../gui/wxpython/gui_modules/vdigit.py:1428
+#: ../gui/wxpython/vdigit/dialogs.py:641
+msgid "List of duplicates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1524
+#: ../gui/wxpython/vdigit/dialogs.py:737
+msgid "Feature id"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1525
+#: ../gui/wxpython/vdigit/dialogs.py:738
+msgid "Layer (Categories)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxvdriver.py:844
+#: ../gui/wxpython/vdigit/wxdisplay.py:887
#, python-format
-msgid "Database link %d not available. Operation canceled."
+msgid ""
+"Topology for vector map <%s> is not available. Topology is required by "
+"digitizer. Do you want to rebuild topology (takes some time) and open the "
+"vector map for editing?"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:93
+#: ../gui/wxpython/gui_modules/wxvdriver.py:848
+#: ../gui/wxpython/vdigit/wxdisplay.py:891
+msgid "Topology missing"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:220
+msgid "Create a generic Cartesian coordinate system (XY)"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:995
+msgid "Earth based"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:998
+msgid "Planetary bodies"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1151
+msgid "PostGIS (PG)"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1164
+msgid "Save current settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1167
+msgid "Delete currently selected settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1413
+msgid "No data source defined, settings is not saved."
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1420
#, python-format
-msgid "Unable to start database driver <%s>. Operation canceled."
+msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:101
+#: ../gui/wxpython/gui_core/gselect.py:1442
+msgid "No settings is defined. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1616
#, python-format
+msgid "Database <%s> not accessible."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2145
+msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:283
+msgid "&Protocol"
+msgstr "&Protokols"
+#: ../gui/wxpython/gui_core/goutput.py:285
msgid ""
-"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+"Toggle to save list of executed commands into file; content saved when "
+"switching off."
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:109
+#: ../gui/wxpython/gui_core/goutput.py:507
+#: ../gui/wxpython/gui_core/goutput.py:802
#, python-format
-msgid "Unable to execute SQL query '%s'. Operation canceled."
+msgid ""
+"Unable to write file '%(filePath)s'.\n"
+"\n"
+"Details: %(error)s"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:117
+#: ../gui/wxpython/gui_core/goutput.py:676
+#: ../gui/wxpython/gui_core/goutput.py:822
#, python-format
-msgid "Feature id %d is marked as dead. Operation canceled."
+msgid "%(txt)s (*.txt)|*.txt|%(files)s (*)|*"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:125
+#: ../gui/wxpython/gui_core/goutput.py:677
+#: ../gui/wxpython/gui_core/goutput.py:823
+msgid "Text files"
+msgstr "Teksta faili"
+msgid "Files"
+msgstr "Faili"
+#: ../gui/wxpython/gui_core/goutput.py:689
#, python-format
-msgid "Unsupported feature type %d. Operation canceled."
+msgid ""
+"Unable to write file '%(path)s'.\n"
+"\n"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:452
+#: ../gui/wxpython/gui_core/goutput.py:692
#, python-format
-msgid "Unknown feature type '%s'"
+msgid "Commands output saved into '%s'"
msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:457
-msgid "Not enough points for line"
+#: ../gui/wxpython/gui_core/goutput.py:807
+#, python-format
+msgid "Commands protocol saved into '%s'"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:109
-msgid "Digitize new point"
+#: ../gui/wxpython/gui_core/goutput.py:865
+#, python-format
+msgid "%(min)d min %(sec)d sec"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:110
-#: ../gui/wxpython/vdigit/toolbars.py:119
-#: ../gui/wxpython/vdigit/toolbars.py:122
-msgid "Left: new point"
+#: ../gui/wxpython/gui_core/toolbars.py:31
+msgid "Display map"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:112
-msgid "Digitize new line"
+#: ../gui/wxpython/gui_core/toolbars.py:32
+msgid "Re-render modified map layers only"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:113
-#: ../gui/wxpython/vdigit/toolbars.py:116
-#: ../gui/wxpython/vdigit/toolbars.py:140
-msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
+#: ../gui/wxpython/gui_core/toolbars.py:34
+msgid "Render map"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:115
-msgid "Digitize new boundary"
+#: ../gui/wxpython/gui_core/toolbars.py:35
+msgid "Force re-rendering all map layers"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:118
-msgid "Digitize new centroid"
+#: ../gui/wxpython/gui_core/toolbars.py:37
+msgid "Erase display"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:121
-msgid "Digitize new area"
+#: ../gui/wxpython/gui_core/toolbars.py:38
+msgid "Erase display canvas with given background color"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:125
-#: ../gui/wxpython/vdigit/toolbars.py:128
-#: ../gui/wxpython/vdigit/toolbars.py:131
-#: ../gui/wxpython/vdigit/toolbars.py:143
-#: ../gui/wxpython/vdigit/toolbars.py:146
-#: ../gui/wxpython/vdigit/toolbars.py:149
-#: ../gui/wxpython/vdigit/toolbars.py:158
-msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
+#: ../gui/wxpython/gui_core/toolbars.py:40
+msgid "Pointer"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:127
-msgid "Delete feature(s)"
+#: ../gui/wxpython/gui_core/toolbars.py:42
+msgid "Zoom in"
+msgstr "Tuvināt"
+#: ../gui/wxpython/gui_core/toolbars.py:43
+msgid "Drag or click mouse to zoom"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:130
-msgid "Delete area(s)"
+#: ../gui/wxpython/gui_core/toolbars.py:45
+msgid "Zoom out"
+msgstr "Tālināt"
+#: ../gui/wxpython/gui_core/toolbars.py:46
+msgid "Drag or click mouse to unzoom"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:133
-msgid "Display/update attributes"
+#: ../gui/wxpython/gui_core/toolbars.py:48
+msgid "Return to previous zoom"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:134
-#: ../gui/wxpython/vdigit/toolbars.py:137
-msgid "Left: Select"
+#: ../gui/wxpython/gui_core/toolbars.py:50
+msgid "Various zoom options"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:136
-msgid "Display/update categories"
+#: ../gui/wxpython/gui_core/toolbars.py:51
+msgid "Zoom to computational, default, saved region, ..."
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:139
-msgid "Edit line/boundary"
+#: ../gui/wxpython/gui_core/toolbars.py:53
+msgid "Zoom to selected map layer(s)"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:142
-msgid "Move feature(s)"
+#: ../gui/wxpython/gui_core/toolbars.py:55
+msgid "Pan"
+msgstr "Pārcentrēt"
+#: ../gui/wxpython/gui_core/toolbars.py:56
+msgid "Drag with mouse to pan"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:151
-msgid "Quit digitizer"
+#: ../gui/wxpython/gui_core/toolbars.py:58
+msgid "Save display to graphic file"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:152
-msgid "Quit digitizer and save changes"
+#: ../gui/wxpython/gui_core/toolbars.py:62
+msgid "Select font"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:153
-msgid "Vector Digitizer manual"
+#: ../gui/wxpython/gui_core/toolbars.py:64
+msgid "Show manual"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:154
-msgid "Show Vector Digitizer manual"
+#: ../gui/wxpython/gui_core/toolbars.py:68
+msgid "Add raster map layer"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:156
-msgid "Additional tools (copy, flip, connect, etc.)"
+#: ../gui/wxpython/gui_core/toolbars.py:70
+msgid "Add vector map layer"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:160
-msgid "Undo"
+#: ../gui/wxpython/gui_core/toolbars.py:72
+msgid "Add map elements"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:161
-msgid "Undo previous changes"
+#: ../gui/wxpython/gui_core/toolbars.py:73
+msgid "Overlay elements like scale and legend onto map"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:163
-msgid "Redo"
+#: ../gui/wxpython/gui_core/mapwindow.py:104
+#, python-format
+msgid ""
+"Error occured during calling of handler: %s \n"
+"Handler was unregistered."
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:164
-msgid "Redo previous changes"
+#: ../gui/wxpython/gui_core/mapwindow.py:173
+#, python-format
+msgid ""
+"Error occured during unregistration of handler: %s \n"
+" Handler was unregistered."
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:509
-msgid "Break selected lines/boundaries at intersection"
+#: ../gui/wxpython/gui_core/mapwindow.py:198
+#, python-format
+msgid "Handler: %s was not registered"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:511
-msgid "Connect selected lines/boundaries"
+#: ../gui/wxpython/gui_core/mapwindow.py:202
+#, python-format
+msgid ""
+" Handler was unregistered"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:513
-msgid "Copy categories"
+#: ../gui/wxpython/gui_core/preferences.py:437
+msgid "Language settings"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:515
-msgid "Copy features from (background) vector map"
+#: ../gui/wxpython/gui_core/preferences.py:447
+msgid "Choose language (requires to save and GRASS restart):"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:517
-msgid "Copy attributes"
+#: ../gui/wxpython/gui_core/preferences.py:502
+msgid "Menu style (requires to save and GUI restart):"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:519
-msgid "Feature type conversion"
+#: ../gui/wxpython/gui_core/preferences.py:736
+msgid "Mouse wheel action:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:521
-msgid "Flip selected lines/boundaries"
+#: ../gui/wxpython/gui_core/preferences.py:751
+msgid "Mouse scrolling direction:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:523
-msgid "Merge selected lines/boundaries"
+#: ../gui/wxpython/gui_core/preferences.py:869
+msgid "Default raster settings"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:525
-msgid "Snap selected lines/boundaries (only to nodes)"
+#: ../gui/wxpython/gui_core/preferences.py:917
+msgid "Default vector settings"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:527
-msgid "Split line/boundary"
+#: ../gui/wxpython/gui_core/preferences.py:944
+msgid "Feature color:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:529
-msgid "Query features"
+#: ../gui/wxpython/gui_core/preferences.py:966
+msgid "Area fill color:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:531
-msgid "Z bulk-labeling of 3D lines"
+#: ../gui/wxpython/gui_core/preferences.py:1009
+msgid "Symbol:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:687
-msgid "Vector map is not 3D. Operation canceled."
+#: ../gui/wxpython/gui_core/dialogs.py:1017
+msgid "Define also sub-group (same name as group)"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:760
-#: ../gui/wxpython/vdigit/toolbars.py:876
-#: ../gui/wxpython/vdigit/toolbars.py:957
-msgid "Select vector map"
+#: ../gui/wxpython/gui_core/dialogs.py:1355
+msgid "Put here regular expression.'.*' means anything, '^' beginning and '$' end."
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:798
-#, python-format
-msgid "Please wait, opening vector map <%s> for editing..."
+#: ../gui/wxpython/gui_core/dialogs.py:1829
+msgid "No layers selected. Operation canceled."
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:832
-#, python-format
-msgid ""
-"Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
+#: ../gui/wxpython/gui_core/dialogs.py:2483
+msgid "Symbols"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:884
-#, python-format
-msgid "Do you want to save changes in vector map <%s>?"
+#: ../gui/wxpython/gui_core/dialogs.py:2510
+msgid "Symbol directory:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:886
-msgid "Save changes?"
+#: ../gui/wxpython/gui_core/dialogs.py:2518
+msgid "Symbol name:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:893
-#, python-format
-msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
+#: ../gui/wxpython/gui_core/ghelp.py:454
+msgid "Python:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:905
-#, python-format
-msgid "Editing of vector map <%s> successfully finished"
+#: ../gui/wxpython/gui_core/ghelp.py:465
+msgid "wxPython:"
msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:964
-#: ../gui/wxpython/vdigit/toolbars.py:969
-msgid "New vector map"
-msgstr "Jauna vektoru karte"
+#: ../gui/wxpython/gui_core/ghelp.py:480
+#, fuzzy
+msgid "Language:"
+msgstr "Valoda"
-#: ../gui/wxpython/vdigit/mapwindow.py:410
-msgid "Update categories"
+#: ../gui/wxpython/gui_core/ghelp.py:503
+msgid "Translation status"
msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:533
-#: ../gui/wxpython/vdigit/mapwindow.py:899
-msgid "No vector map selected for editing."
+#: ../gui/wxpython/gui_core/ghelp.py:724
+msgid "Nation"
msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:541
-msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
+#: ../gui/wxpython/gui_core/ghelp.py:759
+#, python-format
+msgid " %d translated"
msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:1035
-msgid "Z bulk-labeling dialog"
+#: ../gui/wxpython/gui_core/ghelp.py:763 ../gui/wxpython/gui_core/ghelp.py:789
+#, python-format
+msgid " %d fuzzy"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:76
-msgid "List of categories - right-click to delete"
+#: ../gui/wxpython/gui_core/ghelp.py:767 ../gui/wxpython/gui_core/ghelp.py:798
+#, python-format
+msgid " %d untranslated"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:107
-msgid "Add new category"
+#: ../gui/wxpython/gui_core/ghelp.py:780
+#, python-format
+msgid "%d translated"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:146
-msgid "Ignore changes and close dialog"
+#: ../gui/wxpython/gui_core/ghelp.py:851
+#, python-format
+msgid "File <%s> not found"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:238 ../gui/wxpython/vdigit/dialogs.py:457
+#: ../gui/wxpython/dbmgr/dialogs.py:222
#, python-format
-msgid ""
-"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
-"Layer and category number must be integer.\n"
-"Layer number must be greater than zero."
+msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:274
-#: ../gui/wxpython/gmodeler/dialogs.py:745
-#: ../gui/wxpython/gmodeler/dialogs.py:919
-msgid "Delete selected"
+#: ../gui/wxpython/dbmgr/manager.py:881 ../gui/wxpython/dbmgr/manager.py:932
+msgid "Column"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:278
-#: ../gui/wxpython/gmodeler/dialogs.py:746
-#: ../gui/wxpython/gmodeler/dialogs.py:920
-msgid "Delete all"
+#: ../gui/wxpython/dbmgr/manager.py:908
+msgid "Length"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:434
-msgid "Unable to update vector map."
+#: ../gui/wxpython/dbmgr/manager.py:1181
+#, python-format
+msgid ""
+"Selected data records (%d) will be permanently deleted from table. Do you "
+"want to delete them?"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:594
+#: ../gui/wxpython/dbmgr/manager.py:1227
#, python-format
-msgid "%d lines selected for z bulk-labeling"
+msgid ""
+"All data records (%d) will be permanently deleted from table. Do you want to "
+"delete them?"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:597
-msgid "Set value"
+#: ../gui/wxpython/dbmgr/manager.py:1422
+#, python-format
+msgid ""
+"Unable to insert new record.\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:604
-msgid "Starting value"
+#: ../gui/wxpython/dbmgr/manager.py:1533
+#, python-format
+msgid ""
+"Unable to update existing record.\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:613
-msgid "Step"
-msgstr "Solis"
+#: ../gui/wxpython/iclass/toolbars.py:31
+msgid "Set opacity level"
+msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:643
-msgid "List of duplicates"
+#: ../gui/wxpython/iclass/toolbars.py:33 ../gui/wxpython/iclass/dialogs.py:125
+msgid "Class manager"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:739
-msgid "Feature id"
+#: ../gui/wxpython/iclass/toolbars.py:35 ../gui/wxpython/iclass/dialogs.py:37
+msgid "Select imagery group"
msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:740
-msgid "Layer (Categories)"
+#: ../gui/wxpython/iclass/toolbars.py:37
+msgid "Run analysis"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:62
-msgid "GRASS GIS Graphical Modeler"
+#: ../gui/wxpython/iclass/toolbars.py:39 ../gui/wxpython/iclass/dialogs.py:394
+msgid "Save signature file"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:125
-msgid "Model"
+#: ../gui/wxpython/iclass/toolbars.py:43 ../gui/wxpython/iclass/dialogs.py:502
+msgid "Export training areas"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:126
-msgid "Items"
+#: ../gui/wxpython/iclass/toolbars.py:45
+#, fuzzy
+msgid "Import training areas"
+msgstr "Rastra datu importēšana"
+#: ../gui/wxpython/iclass/toolbars.py:61
+msgid "Training"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:127
-#: ../gui/wxpython/gmodeler/model.py:2234
-msgid "Variables"
+#: ../gui/wxpython/iclass/toolbars.py:68
+msgid "/ Zoom to map"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:128
-msgid "Python editor"
+#: ../gui/wxpython/iclass/toolbars.py:218
+#: ../gui/wxpython/iclass/toolbars.py:223
+msgid "std dev"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:198
-msgid "Python script contains local modifications"
+#: ../gui/wxpython/iclass/toolbars.py:264
+msgid "Add raster map"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:200
-#: ../gui/wxpython/gmodeler/frame.py:1650
-msgid "Python script is up-to-date"
+#: ../gui/wxpython/iclass/dialogs.py:45
+msgid "Name of imagery group:"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:215
-msgid "Redrawing model..."
+#: ../gui/wxpython/iclass/dialogs.py:140
+msgid "Classes"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:250
-msgid "Do you want to save changes in the model?"
+#: ../gui/wxpython/iclass/dialogs.py:225
+msgid "Class name"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:252
-msgid "Do you want to store current model settings to model file?"
+#: ../gui/wxpython/iclass/dialogs.py:364
+msgid "Zoom to training areas of selected class"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:258
-msgid "Quit Graphical Modeler"
+#: ../gui/wxpython/iclass/dialogs.py:451
+msgid "Enter name of signature file:"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:312
-msgid "No intermediate data to delete."
+#: ../gui/wxpython/iclass/dialogs.py:460
+msgid "Signature file path:"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:316
-#, python-format
-msgid "Do you want to permanently delete data?%s"
+#: ../gui/wxpython/iclass/dialogs.py:545
+msgid "Enter name of new vector map:"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:317
-msgid "Delete intermediate data?"
+#: ../gui/wxpython/iclass/dialogs.py:553
+msgid "Export attribute table"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:331
+#: ../gui/wxpython/iclass/dialogs.py:555
+msgid "Export attribute table containing computed statistical data"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:593
#, python-format
-msgid "%d maps deleted from current mapset"
+msgid "Vector map <%s> already exists. Do you want to overwrite it?"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:346 ../gui/wxpython/gmodeler/frame.py:461
+#: ../gui/wxpython/iclass/dialogs.py:595
+#, python-format
+msgid "Vector <%s> exists"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:39
+#, python-format
msgid ""
-"Current model is not empty. Do you want to store current settings to model "
-"file?"
+"Loading imagery lib failed.\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:349 ../gui/wxpython/gmodeler/frame.py:464
-msgid "Create new model?"
+#: ../gui/wxpython/iclass/frame.py:72
+msgid "Supervised Classification Tool"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:376
-msgid "Choose model file"
+#: ../gui/wxpython/iclass/frame.py:259
+msgid "IClass Toolbar"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:394
-#, python-format
-msgid "%(items)d items (%(actions)d actions) loaded into model"
+#: ../gui/wxpython/iclass/frame.py:271
+msgid "IClass Misc Toolbar"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:401 ../gui/wxpython/gmodeler/frame.py:438
-#, python-format
-msgid "Model file <%s> already exists. Do you want to overwrite this file?"
+#: ../gui/wxpython/iclass/frame.py:287
+msgid "Digitization Toolbar"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:411 ../gui/wxpython/gmodeler/frame.py:451
-#, python-format
-msgid "File <%s> saved"
+#: ../gui/wxpython/iclass/frame.py:308
+msgid "Plots"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:420
-msgid "Choose file to save current model"
+#: ../gui/wxpython/iclass/frame.py:328
+msgid "Preview Display"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:509
-msgid "Model is empty. Nothing to validate."
+#: ../gui/wxpython/iclass/frame.py:331
+msgid "Training Areas Display"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:513 ../gui/wxpython/gmodeler/model.py:522
-msgid "Validating model..."
+#: ../gui/wxpython/iclass/frame.py:379
+msgid "Adjust Training Area Display to Preview Display"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:519
-#, python-format
-msgid ""
-"Model is not valid.\n"
-"\n"
-"%s"
+#: ../gui/wxpython/iclass/frame.py:383
+msgid "Adjust Preview display to Training Area Display"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:522
-msgid "Model is valid."
+#: ../gui/wxpython/iclass/frame.py:433
+msgid "All changes will be lost. Do you want to continue?"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:583 ../gui/wxpython/gmodeler/frame.py:590
+#: ../gui/wxpython/iclass/frame.py:441
+msgid "Import vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:463
#, python-format
-msgid "Model exported to <%s>"
+msgid "No areas in vector map <%s>.\n"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:724
-msgid "wxGUI Graphical Modeler"
+#: ../gui/wxpython/iclass/frame.py:465
+#, python-format
+msgid "Vector map <%s> contains points or lines, these features are ignored."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:819
+#: ../gui/wxpython/iclass/frame.py:593
+msgid "No training areas to export."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:648
#, python-format
msgid ""
-"Reading model file <%s> failed.\n"
-"Invalid file, unable to parse XML document.\n"
-"\n"
+"Failed to add attribute table. Details:\n"
"%s"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:828
-msgid "Please wait, loading model..."
+#: ../gui/wxpython/iclass/frame.py:787
+msgid "Failed to create temporary vector map."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:888
-msgid "Writing current settings to model file failed."
+#: ../gui/wxpython/iclass/frame.py:857
+#, python-format
+msgid "No area in category %s. Category skipped."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1208
-msgid "Disable"
+#: ../gui/wxpython/iclass/frame.py:860
+msgid "Analysis failed."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1211
-msgid "Enable"
+#: ../gui/wxpython/iclass/frame.py:869
+msgid "No imagery group selected."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1216
-msgid "Add control point"
+#: ../gui/wxpython/iclass/frame.py:874
+msgid ""
+"Due to recent changes in classes, signatures can be outdated and should be "
+"recalculated. Do you still want to continue?"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1218
-msgid "Remove control point"
+#: ../gui/wxpython/iclass/frame.py:877
+msgid "Outdated signatures"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1225
-msgid "Intermediate"
+#: ../gui/wxpython/iclass/frame.py:890
+#, python-format
+msgid ""
+"A signature file named %s already exists.\n"
+"Do you want to replace it?"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1319
-msgid "List of variables - right-click to delete"
+#: ../gui/wxpython/iclass/frame.py:938
+msgid "No imagery group selected. Operation canceled."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1323
-#: ../gui/wxpython/gmodeler/frame.py:1377
-msgid "Default value"
+#: ../gui/wxpython/iclass/frame.py:947
+#, python-format
+msgid ""
+"Group <%(group)s> does not have enough files (it has %(files)d files). "
+"Operation canceled."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1327
-msgid "Add new variable"
+#: ../gui/wxpython/iclass/frame.py:956
+msgid "No areas given. Operation canceled."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1331
-msgid "integer"
+#: ../gui/wxpython/iclass/frame.py:971
+msgid "Vector features are outside raster layers. Operation canceled."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1332
-msgid "float"
+#: ../gui/wxpython/iclass/frame.py:1162
+msgid "results"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1333
-msgid "string"
+#: ../gui/wxpython/iclass/statistics.py:27
+msgid "Loading imagery lib failed"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1336
-msgid "mapset"
+#: ../gui/wxpython/iclass/digit.py:50
+msgid ""
+"In order to create a training area, you have to select class first.\n"
+"\n"
+"There is no class yet, do you want to create one?"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1344
-msgid "Add new variable to the model"
+#: ../gui/wxpython/iclass/digit.py:54
+msgid "No class selected"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1464
-msgid "List of items - right-click to delete"
+#: ../gui/wxpython/iclass/plots.py:51
+msgid "Histograms"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1467
-#: ../gui/wxpython/gmodeler/dialogs.py:412
-#: ../gui/wxpython/gmodeler/dialogs.py:514
-msgid "ID"
+#: ../gui/wxpython/iclass/plots.py:52
+msgid "Coincident plots"
msgstr ""
-msgid "In block"
+#: ../gui/wxpython/icons/icon.py:33
+#, python-format
+msgid "Unknown iconset '%s', using default 'grass'...\n"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1468
-msgid "Command / Condition"
+#: ../gui/wxpython/icons/icon.py:50
+#, python-format
+msgid "Unable to load icon theme. Reason: %s. Quiting wxGUI..."
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1501
-msgid "Python script"
+#: ../gui/wxpython/modules/extensions.py:58
+msgid "Fetch full info including description and keywords"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1505
-msgid "Run python script"
+#: ../gui/wxpython/modules/extensions.py:388
+msgid "Uninstall GRASS Addons extensions"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1508
-msgid "Save python script to file"
+#: ../gui/wxpython/modules/extensions.py:397
+msgid "List of installed extensions"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1511
-msgid ""
-"Refresh python script based on the model.\n"
-"It will discards all local changes."
+#: ../gui/wxpython/modules/extensions.py:403
+msgid "&Uninstall"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1549
+#: ../gui/wxpython/modules/extensions.py:404
+msgid "Uninstall selected AddOns extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:451
+msgid "No extension selected for removal. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:460
#, python-format
-msgid "Unable to launch Python script. %s"
+msgid ""
+"List of files to be removed:\n"
+"%(files)s\n"
+"\n"
+"Do you want really to remove <%(ext)s> extension?"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1573
-msgid "Choose file to save"
+#: ../gui/wxpython/modules/extensions.py:463
+msgid "Remove extension"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1575
-msgid "Python script (*.py)|*.py"
+#: ../gui/wxpython/modules/extensions.py:488
+msgid "Extension"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1591
-msgid "Save file"
+#: ../gui/wxpython/modules/vclean.py:456
+msgid "Name of input vector map"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1626
-msgid ""
-"Python script is locally modificated. Refresh will discard all changes. Do "
-"you really want to continue?"
+#: ../gui/wxpython/modules/vclean.py:457
+msgid "Name for output vector map"
msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1629
-msgid "Update"
-msgstr "Atjaunināt"
+#: ../gui/wxpython/modules/vclean.py:458
+msgid "Tools"
+msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:59
-msgid "model"
+#: ../gui/wxpython/modules/vclean.py:459
+msgid "Threshold"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:60
-msgid "Script generated by wxGUI Graphical Modeler."
+#: ../gui/wxpython/modules/vclean.py:461
+#, python-format
+msgid "'%s' not defined"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:399 ../gui/wxpython/gmodeler/model.py:461
+#: ../gui/wxpython/modules/vclean.py:463
#, python-format
-msgid "undefined variable '%s'"
+msgid ""
+"Some parameters not defined. Operation canceled.\n"
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:494
-msgid "Running model..."
+#: ../gui/wxpython/modules/colorrules.py:1175
+#, python-format
+msgid ""
+"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
+"table cannot be edited."
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:513
-msgid "Model is empty. Nothing to run."
+#: ../gui/wxpython/modules/colorrules.py:1646
+msgid "No color column defined. Operation canceled."
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:528
+#: ../gui/wxpython/modules/histogram.py:266
+msgid "GRASS GIS Histogramming Tool (d.histogram)"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:148 ../gui/wxpython/wxplot/scatter.py:152
#, python-format
+msgid ": %s"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:256
+#, python-format
msgid ""
-"Model is not valid. Do you want to run the model anyway?\n"
+"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
"\n"
-"%s"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:530
-msgid "Run model?"
+#: ../gui/wxpython/wxplot/base.py:35
+msgid "Draw/re-draw plot"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:565
-msgid "Variables below not defined:"
+#: ../gui/wxpython/wxplot/base.py:37
+msgid "Draw transect in map display window to profile"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:674
-msgid "Raster maps"
+#: ../gui/wxpython/wxplot/base.py:39
+msgid "Plot options"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:677
-msgid "3D raster maps"
+#: ../gui/wxpython/wxplot/base.py:41
+msgid "Plot statistics"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1251
-msgid "<not defined>"
+#: ../gui/wxpython/wxplot/base.py:43
+msgid "Save profile data to CSV file"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1361
-msgid "Condition: "
+#: ../gui/wxpython/wxplot/base.py:44
+msgid "Quit plot tool"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1363
-msgid "Condition: not defined"
+#: ../gui/wxpython/wxplot/base.py:399
+msgid "Left Mouse Down at Point:"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1424
-msgid "loop"
+#: ../gui/wxpython/wxplot/profile.py:144
+msgid "Not all points of profile lie inside computational region."
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1471
-msgid "if-else"
+#: ../gui/wxpython/wxplot/dialogs.py:476
+msgid "Selected group must be in current mapset"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:2165
-msgid "Model parameters"
+#: ../gui/wxpython/wxplot/histogram.py:219
+#, python-format
+msgid "Statistics for raster map <%s>"
msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:2182
-msgid "Delete intermediate data when finish"
+#: ../gui/wxpython/core/render.py:1204 ../gui/wxpython/core/render.py:1243
+#, python-format
+msgid "Unable to render overlay <%s>."
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:51
-msgid "Item properties"
+#: ../gui/wxpython/core/gcmd.py:74
+#, python-format
+msgid "ERROR: %s\n"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:58
-msgid "Disabled:"
+#: ../gui/wxpython/core/settings.py:822
+msgid "Zoom and recenter"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:84
-msgid "Action"
+#: ../gui/wxpython/core/settings.py:823
+msgid "Zoom to mouse cursor"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:96
-#: ../gui/wxpython/gmodeler/preferences.py:334
-msgid "Valid:"
+#: ../gui/wxpython/core/settings.py:824
+msgid "Nothing"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:113
-msgid "Invalid:"
+#: ../gui/wxpython/core/settings.py:825
+msgid "Scroll forward to zoom in"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:130
-msgid "Running:"
+#: ../gui/wxpython/core/settings.py:826
+msgid "Scroll back to zoom in"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:151
-#: ../gui/wxpython/gmodeler/preferences.py:270
-#: ../gui/wxpython/gmodeler/preferences.py:355
-msgid "Shape size"
+#: ../gui/wxpython/mapdisp/gprint.py:152
+msgid ""
+"There was a problem printing.\n"
+"Perhaps your current printer is not set correctly?"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:215
-msgid "Raster:"
+#: ../gui/wxpython/mapdisp/toolbars.py:28
+msgid "Query raster/vector map(s)"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:232
-msgid "3D raster:"
+#: ../gui/wxpython/mapdisp/toolbars.py:29
+msgid "Query selected raster/vector map(s)"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:249
-msgid "Vector:"
+#: ../gui/wxpython/mapdisp/toolbars.py:31
+#, fuzzy
+msgid "Add scalebar and north arrow"
+msgstr "Ziemeļu bulta"
+#: ../gui/wxpython/mapdisp/toolbars.py:33
+#, fuzzy
+msgid "Add legend"
+msgstr "Leģenda"
+#: ../gui/wxpython/mapdisp/toolbars.py:37
+msgid "Analyze map"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:322
-msgid "Loop"
+#: ../gui/wxpython/mapdisp/toolbars.py:38
+msgid "Measuring, profiling, histogramming, ..."
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:431
-msgid "Commands"
+#: ../gui/wxpython/mapdisp/toolbars.py:40
+msgid "Measure distance"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:451
-msgid "Apply properties"
+#: ../gui/wxpython/mapdisp/toolbars.py:42
+msgid "Profile surface map"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:472
-msgid "Description:"
+#: ../gui/wxpython/mapdisp/toolbars.py:48
+msgid "Create histogram of raster map"
msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:481
-msgid "Author(s):"
+#: ../gui/wxpython/mapdisp/toolbars.py:50
+#, fuzzy
+msgid "Vector network analysis (experimental, GSoC 2012)"
+msgstr "Vektoru iestatījumi"
+#: ../gui/wxpython/mapdisp/toolbars.py:55
+msgid "Rotate 3D scene"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:48
-msgid "Data properties"
+#: ../gui/wxpython/mapdisp/toolbars.py:56
+msgid "Drag with mouse to rotate 3D scene"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:82
-#: ../gui/wxpython/gmodeler/dialogs.py:95
-msgid "Name of element:"
+#: ../gui/wxpython/mapdisp/toolbars.py:59
+msgid "Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:90
-msgid "Type of element:"
+#: ../gui/wxpython/mapdisp/toolbars.py:61
+msgid "Click mouse to zoom"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:142
-msgid "Add new GRASS module to the model"
+#: ../gui/wxpython/mapdisp/toolbars.py:62
+msgid "Click mouse to unzoom"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:161
-#: ../gui/wxpython/gmodeler/dialogs.py:413
-#: ../gui/wxpython/gmodeler/dialogs.py:515
-msgid "Command"
+#: ../gui/wxpython/mapdisp/mapwindow.py:151
+msgid "Copy coordinates to clipboard"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:231
-msgid ""
-"Command not defined.\n"
-"\n"
-"Unable to add new action to the model."
+#: ../gui/wxpython/mapdisp/mapwindow.py:684
+msgid "Unable to draw registered graphics. The graphics was unregistered."
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:237
+#: ../gui/wxpython/mapdisp/mapwindow.py:2032
+#: ../gui/wxpython/mapdisp/mapwindow.py:2140
#, python-format
-msgid ""
-"'%s' is not a GRASS module.\n"
-"\n"
+msgid "Property does not exist: %s"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:267
-msgid "Relation properties"
+#: ../gui/wxpython/mapdisp/frame.py:1335
+#, python-format
+msgid "wx.vnet not available, run '%s' to install this extension"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:284
-msgid "From"
+#: ../gui/wxpython/gis_set.py:97
+msgid "Choose project location and mapset"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:328
-#, python-format
-msgid "Data: %s"
+#: ../gui/wxpython/gis_set.py:100
+msgid "Manage"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:334
-msgid "Command:"
+#: ../gui/wxpython/gis_set.py:102
+#, python-format
+msgid ""
+"Welcome to GRASS GIS %s\n"
+"The world's leading open source GIS"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:340
-msgid "Option:"
+#: ../gui/wxpython/gis_set.py:106
+msgid ""
+"Select an existing project location and mapset\n"
+"or define a new location"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:355
+#: ../gui/wxpython/gis_set.py:112
msgid ""
-"Relation doesn't start with data item.\n"
-"Unable to add relation."
+"Project location\n"
+"(projection/coordinate system)"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:362
+#: ../gui/wxpython/gis_set.py:115
msgid ""
-"Relation doesn't point to GRASS command.\n"
+"Accessible mapsets\n"
+"(directories of GIS files)"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:375
+#: ../gui/wxpython/gis_set.py:118
msgid ""
-"No relevant option found.\n"
+"Create new mapset\n"
+"in selected location"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:406
-msgid "Condition"
+#: ../gui/wxpython/gis_set.py:121
+msgid "Define new location"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:431
-msgid "Loop properties"
+#: ../gui/wxpython/gis_set.py:124
+msgid ""
+"Rename/delete selected\n"
+"mapset or location"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:437
-msgid "List of items in loop"
+#: ../gui/wxpython/gis_set.py:129
+msgid "Start &GRASS"
+msgstr "Startēt &GRASS"
+#: ../gui/wxpython/gis_set.py:135
+msgid "&Browse"
+msgstr "&Pārlūkot"
+#: ../gui/wxpython/gis_set.py:137
+msgid "&Create mapset"
+msgstr "Izveidot &karšu kopu"
+#: ../gui/wxpython/gis_set.py:139
+msgid "&Location wizard"
+msgstr "&Novietojuma vednis"
+#: ../gui/wxpython/gis_set.py:141
+msgid "Rename mapset"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:440
-msgid "Series"
+msgid "Rename location"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:441
-msgid "Define map series as condition for the loop"
+#: ../gui/wxpython/gis_set.py:142
+msgid "Delete mapset"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:485
-msgid "Define series of maps"
+msgid "Delete location"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:500
-msgid "If-else properties"
+#: ../gui/wxpython/gis_set.py:184
+msgid "Welcome to GRASS GIS"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:506
-msgid "List of items in 'if' block"
+#: ../gui/wxpython/gis_set.py:192
+msgid "Enter GRASS session"
+msgstr "Sākt GRASS sesiju"
+#: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:551
+msgid "Unable to set GRASS database. Check your locale settings."
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:511
-msgid "List of items in 'else' block"
+#: ../gui/wxpython/gis_set.py:226
+#, fuzzy, python-format
+msgid "ERROR: Location <%s> not found"
+msgstr "Karte <%s> nav atrasta."
+#: ../gui/wxpython/gis_set.py:238
+msgid "ERROR: Mapset <%s> not found"
+#: ../gui/wxpython/gis_set.py:420
+msgid ""
+"Mapset <PERMANENT> is required for valid GRASS location.\n"
+"\n"
+"This mapset cannot be renamed."
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:675
+#: ../gui/wxpython/gis_set.py:425 ../gui/wxpython/gis_set.py:460
#, python-format
-msgid "Variable <%s> already exists in the model. Adding variable failed."
+msgid ""
+"Current name: %s\n"
+"\n"
+"Enter new name:"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:704
-msgid "Do you want to delete all variables from the model?"
+#: ../gui/wxpython/gis_set.py:426
+msgid "Rename selected mapset"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:706
-msgid "Delete variables"
+#: ../gui/wxpython/gis_set.py:437
+#, python-format
+msgid ""
+"Unable to rename mapset.\n"
+"\n"
+"Mapset <%s> already exists in location."
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:869
+#: ../gui/wxpython/gis_set.py:449
#, python-format
msgid ""
-"Selected data records (%d) will permanently deleted from table. Do you want "
-"to delete them?"
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:926
-msgid "Normalize"
+#: ../gui/wxpython/gis_set.py:461
+msgid "Rename selected location"
msgstr ""
-#: ../gui/wxpython/core/render.py:135
+#: ../gui/wxpython/gis_set.py:472
#, python-format
-msgid "<%(name)s>: layer type <%(type)s> is not supported"
+msgid ""
+"Unable to rename location.\n"
+"\n"
+"Location <%s> already exists in GRASS database."
msgstr ""
-#: ../gui/wxpython/core/render.py:156
+#: ../gui/wxpython/gis_set.py:485
#, python-format
-msgid "Command '%s' failed\n"
+msgid ""
+"\n"
+"%s"
msgstr ""
-#: ../gui/wxpython/core/render.py:158
-#, python-format
-msgid "Details: %s\n"
+#: ../gui/wxpython/gis_set.py:497
+msgid ""
+"\n"
+"This mapset cannot be deleted."
msgstr ""
-#: ../gui/wxpython/core/render.py:264
+#: ../gui/wxpython/gis_set.py:501
#, python-format
-msgid "Unsupported map layer type '%s'"
+msgid ""
+"Do you want to continue with deleting mapset <%(mapset)s> from location <"
+"%(location)s>?\n"
+"\n"
+"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
msgstr ""
-#: ../gui/wxpython/core/render.py:450
-msgid "GISBASE not set. You must be in GRASS GIS to run this program."
+#: ../gui/wxpython/gis_set.py:506
+msgid "Delete selected mapset"
msgstr ""
-#: ../gui/wxpython/core/render.py:495
-#, python-format
-msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
+#: ../gui/wxpython/gis_set.py:515
+msgid "Unable to delete mapset"
msgstr ""
-#: ../gui/wxpython/core/render.py:595
+#: ../gui/wxpython/gis_set.py:526
#, python-format
-msgid "Invalid map size %d,%d\n"
+msgid ""
+"Do you want to continue with deleting location <%s>?\n"
+"\n"
+"ALL MAPS included in this location will be PERMANENTLY DELETED!"
msgstr ""
-#: ../gui/wxpython/core/render.py:678
-#, python-format
-msgid "Unable to zoom to raster map <%s>."
+#: ../gui/wxpython/gis_set.py:530
+msgid "Delete selected location"
msgstr ""
-#: ../gui/wxpython/core/render.py:679 ../gui/wxpython/core/render.py:682
-#: ../gui/wxpython/core/render.py:685 ../gui/wxpython/core/gcmd.py:397
-msgid "Details:"
+#: ../gui/wxpython/gis_set.py:541
+msgid "Unable to delete location"
msgstr ""
-#: ../gui/wxpython/core/render.py:681
+#: ../gui/wxpython/gis_set.py:700
#, python-format
-msgid "Unable to zoom to vector map <%s>."
+msgid "Mapset <%s> already exists."
msgstr ""
-#: ../gui/wxpython/core/render.py:684
+#: ../gui/wxpython/gis_set.py:705
#, python-format
-msgid "Unable to zoom to 3d raster map <%s>."
+msgid ""
+"Mapset <%s> is reserved for direct read access to OGR layers. Please "
+"consider to use another name for your mapset.\n"
+"\n"
+"Are you really sure that you want to create this mapset?"
msgstr ""
-#: ../gui/wxpython/core/render.py:687
-msgid ""
-"Unable to get current geographic extent. Force quiting wxGUI. Please "
-"manually run g.region to fix the problem."
+#: ../gui/wxpython/gis_set.py:709
+msgid "Reserved mapset name"
msgstr ""
-#: ../gui/wxpython/core/render.py:1004
+#: ../gui/wxpython/gis_set.py:727
#, python-format
-msgid "ERROR: Rendering failed. Details: %s"
+msgid "Unable to create new mapset: %s"
msgstr ""
-#: ../gui/wxpython/core/render.py:1061 ../gui/wxpython/core/render.py:1156
+#: ../gui/wxpython/gis_set.py:744
#, python-format
-msgid "Unable to render map layer <%s>."
+msgid ""
+"GRASS is already running in selected mapset <%(mapset)s>\n"
+"(file %(lock)s found).\n"
+"\n"
+"Concurrent use not allowed.\n"
+"\n"
+"Do you want to try to remove .gislock (note that you need permission for "
+"this operation) and continue?"
msgstr ""
-#: ../gui/wxpython/core/render.py:1265 ../gui/wxpython/core/render.py:1304
-#, python-format
-msgid "Unable to render overlay <%s>."
+#: ../gui/wxpython/gis_set.py:750 ../gui/wxpython/gis_set.py:762
+msgid "Lock file found"
msgstr ""
-#: ../gui/wxpython/core/render.py:1401
-msgid "Downloading data "
+#: ../gui/wxpython/gis_set.py:758
+msgid ""
+"ARE YOU REALLY SURE?\n"
+"\n"
+"If you really are running another GRASS session doing this could corrupt "
+"your data. Have another look in the processor manager just to be sure..."
msgstr ""
-#: ../gui/wxpython/core/render.py:1411
-msgid "Rendering & "
+#: ../gui/wxpython/gis_set.py:773
+#, python-format
+msgid ""
+"Unable to remove '%(lock)s'.\n"
+"\n"
+"Details: %(reason)s"
msgstr ""
-#: ../gui/wxpython/core/render.py:1413
-msgid "Rendering..."
+#: ../gui/wxpython/gis_set.py:801
+msgid "GRASS Quickstart"
msgstr ""
-#: ../gui/wxpython/core/settings.py:484
-msgid "Segment break"
+#: ../gui/wxpython/gis_set.py:874
+msgid "Starting GRASS for the first time"
msgstr ""
-#: ../gui/wxpython/core/settings.py:550
-msgid "Data point"
+#: ../gui/wxpython/gis_set.py:875
+msgid ""
+"GRASS needs a directory in which to store its data. Create one now if you "
+"have not already done so. A popular choice is \"grassdata\", located in your "
+"home directory."
msgstr ""
-#: ../gui/wxpython/core/settings.py:810
-msgid "Collapse all except PERMANENT and current"
+#: ../gui/wxpython/vdigit/wxdigit.py:58
+msgid "Operation canceled."
msgstr ""
-#: ../gui/wxpython/core/settings.py:811
-msgid "Collapse all except PERMANENT"
+#: ../gui/wxpython/vdigit/wxdigit.py:65
+#, python-format
+msgid ""
+"Writing new feature failed. Operation canceled.\n"
+"\n"
+"Reason: %s"
msgstr ""
-#: ../gui/wxpython/core/settings.py:812
-msgid "Collapse all except current"
+#: ../gui/wxpython/vdigit/wxdigit.py:74
+#, python-format
+msgid "Reading feature id %d failed. Operation canceled."
msgstr ""
-#: ../gui/wxpython/core/settings.py:813
-msgid "Collapse all"
+#: ../gui/wxpython/vdigit/wxdigit.py:82
+#, python-format
+msgid "Database link %d not available. Operation canceled."
msgstr ""
-#: ../gui/wxpython/core/settings.py:814
-msgid "Expand all"
+#: ../gui/wxpython/vdigit/wxdigit.py:90
+#, python-format
+msgid "Unable to start database driver <%s>. Operation canceled."
msgstr ""
-#: ../gui/wxpython/core/settings.py:818
-msgid "Display selected"
+#: ../gui/wxpython/vdigit/wxdigit.py:98
+#, python-format
+msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
msgstr ""
-#: ../gui/wxpython/core/settings.py:826
-msgid "Classic (labels only)"
+#: ../gui/wxpython/vdigit/wxdigit.py:106
+#, python-format
+msgid "Unable to execute SQL query '%s'. Operation canceled."
msgstr ""
-#: ../gui/wxpython/core/settings.py:827
-msgid "Combined (labels and module names)"
+#: ../gui/wxpython/vdigit/wxdigit.py:114
+#, python-format
+msgid "Feature id %d is marked as dead. Operation canceled."
msgstr ""
-#: ../gui/wxpython/core/settings.py:828
-msgid "Expert (module names only)"
+#: ../gui/wxpython/vdigit/wxdigit.py:122
+#, python-format
+msgid "Unsupported feature type %d. Operation canceled."
msgstr ""
-#: ../gui/wxpython/core/settings.py:833
-msgid "Basic top"
+#: ../gui/wxpython/vdigit/toolbars.py:92
+msgid "Digitize new point"
msgstr ""
-#: ../gui/wxpython/core/settings.py:834
-msgid "Basic left"
+#: ../gui/wxpython/vdigit/toolbars.py:93
+#: ../gui/wxpython/vdigit/toolbars.py:102
+#: ../gui/wxpython/vdigit/toolbars.py:105
+msgid "Left: new point"
msgstr ""
-#: ../gui/wxpython/core/settings.py:835
-msgid "Fancy green"
+#: ../gui/wxpython/vdigit/toolbars.py:95
+msgid "Digitize new line"
msgstr ""
-#: ../gui/wxpython/core/settings.py:836
-msgid "List left"
+#: ../gui/wxpython/vdigit/toolbars.py:96 ../gui/wxpython/vdigit/toolbars.py:99
+#: ../gui/wxpython/vdigit/toolbars.py:123
+msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
msgstr ""
-#: ../gui/wxpython/core/settings.py:840
-msgid "Zoom and recenter"
+#: ../gui/wxpython/vdigit/toolbars.py:98
+msgid "Digitize new boundary"
msgstr ""
-#: ../gui/wxpython/core/settings.py:841
-msgid "Zoom to mouse cursor"
+#: ../gui/wxpython/vdigit/toolbars.py:101
+msgid "Digitize new centroid"
msgstr ""
-#: ../gui/wxpython/core/settings.py:842
-msgid "Nothing"
+#: ../gui/wxpython/vdigit/toolbars.py:104
+msgid ""
+"Digitize new area (composition of boundaries without category and one "
+"centroid with category)"
msgstr ""
-#: ../gui/wxpython/core/settings.py:843
-msgid "Scroll forward to zoom in"
+#: ../gui/wxpython/vdigit/toolbars.py:107
+msgid "Add new vertex"
msgstr ""
-#: ../gui/wxpython/core/settings.py:844
-msgid "Scroll back to zoom in"
+#: ../gui/wxpython/vdigit/toolbars.py:108
+#: ../gui/wxpython/vdigit/toolbars.py:111
+#: ../gui/wxpython/vdigit/toolbars.py:114
+#: ../gui/wxpython/vdigit/toolbars.py:126
+#: ../gui/wxpython/vdigit/toolbars.py:129
+#: ../gui/wxpython/vdigit/toolbars.py:132
+#: ../gui/wxpython/vdigit/toolbars.py:141
+msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
msgstr ""
-#: ../gui/wxpython/core/settings.py:877
-msgid "box"
+#: ../gui/wxpython/vdigit/toolbars.py:110
+msgid "Delete feature(s)"
msgstr ""
-#: ../gui/wxpython/core/settings.py:878
-msgid "sphere"
+#: ../gui/wxpython/vdigit/toolbars.py:113
+msgid "Delete area(s)"
msgstr ""
-#: ../gui/wxpython/core/settings.py:879
-msgid "cube"
+#: ../gui/wxpython/vdigit/toolbars.py:116
+msgid "Display/update attributes"
msgstr ""
-#: ../gui/wxpython/core/settings.py:880
-msgid "diamond"
+#: ../gui/wxpython/vdigit/toolbars.py:117
+#: ../gui/wxpython/vdigit/toolbars.py:120
+msgid "Left: Select"
msgstr ""
-#: ../gui/wxpython/core/settings.py:881
-msgid "aster"
+#: ../gui/wxpython/vdigit/toolbars.py:119
+msgid "Display/update categories"
msgstr ""
-#: ../gui/wxpython/core/settings.py:882
-msgid "gyro"
+#: ../gui/wxpython/vdigit/toolbars.py:122
+msgid "Edit line/boundary"
msgstr ""
-#: ../gui/wxpython/core/settings.py:883
-msgid "histogram"
+#: ../gui/wxpython/vdigit/toolbars.py:125
+msgid "Move feature(s)"
msgstr ""
-#: ../gui/wxpython/core/settings.py:917
-#, python-format
-msgid "Unable to read settings file <%s>\n"
+#: ../gui/wxpython/vdigit/toolbars.py:128
+msgid "Move vertex"
msgstr ""
-#: ../gui/wxpython/core/settings.py:941
-#, python-format
-msgid ""
-"Error: Reading settings from file <%(file)s> failed.\n"
-"\t\tDetails: %(detail)s\n"
-"\t\tLine: '%(line)s'\n"
+#: ../gui/wxpython/vdigit/toolbars.py:131
+msgid "Remove vertex"
msgstr ""
-#: ../gui/wxpython/core/settings.py:960
-msgid "Unable to create settings directory"
+#: ../gui/wxpython/vdigit/toolbars.py:134
+msgid "Quit digitizer"
msgstr ""
-#: ../gui/wxpython/core/settings.py:996
-#, python-format
-msgid ""
-"Writing settings to file <%(file)s> failed.\n"
-"\n"
-"Details: %(detail)s"
+#: ../gui/wxpython/vdigit/toolbars.py:135
+msgid "Quit digitizer and save changes"
msgstr ""
-#: ../gui/wxpython/core/settings.py:1095
-msgid "Unable to set "
+#: ../gui/wxpython/vdigit/toolbars.py:136
+msgid "Vector Digitizer manual"
msgstr ""
-#: ../gui/wxpython/core/settings.py:1131 ../gui/wxpython/core/settings.py:1141
-#, python-format
-msgid "Unable to parse settings '%s'"
+#: ../gui/wxpython/vdigit/toolbars.py:137
+msgid "Show Vector Digitizer manual"
msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:135
-msgid "Unable to parse user toolboxes XML files. Default files will be loaded."
+#: ../gui/wxpython/vdigit/toolbars.py:139
+msgid "Additional tools (copy, flip, connect, etc.)"
msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:175
-msgid "Unable to create toolboxes directory."
+#: ../gui/wxpython/vdigit/toolbars.py:143
+msgid "Undo"
msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:389
-msgid "Custom toolboxes"
+#: ../gui/wxpython/vdigit/toolbars.py:144
+msgid "Undo previous changes"
msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:455
-msgid "Addons"
+#: ../gui/wxpython/vdigit/toolbars.py:146
+msgid "Redo"
msgstr ""
-#: ../gui/wxpython/core/utils.py:329
-#, python-format
-msgid "Vector map <%(map)s>: %(msg)s\n"
+#: ../gui/wxpython/vdigit/toolbars.py:147
+msgid "Redo previous changes"
msgstr ""
-#: ../gui/wxpython/core/utils.py:556
+#: ../gui/wxpython/vdigit/toolbars.py:786
#, python-format
-msgid "failed to open '%s'"
+msgid "Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
msgstr ""
-#: ../gui/wxpython/core/utils.py:851
-#, python-format
-msgid "ERROR: Unable to determine GRASS version. Details: %s"
+#: ../gui/wxpython/vdigit/mapwindow.py:513
+msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
msgstr ""
-#: ../gui/wxpython/core/utils.py:886
-#, python-format
-msgid "Unable to open file '%s'\n"
+#: ../gui/wxpython/vdigit/preferences.py:512
+msgid "Digitize new line segment"
msgstr ""
-#: ../gui/wxpython/core/utils.py:893
+#: ../gui/wxpython/vdigit/preferences.py:513
+msgid "Digitize new line/boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:236 ../gui/wxpython/vdigit/dialogs.py:455
#, python-format
msgid ""
-"%s: line skipped - unable to parse '%s'\n"
-"Reason: %s\n"
+"Layer number must be greater than zero."
msgstr ""
-#: ../gui/wxpython/core/utils.py:898
-#, python-format
-msgid "Duplicated key: %s\n"
+#: ../gui/wxpython/scripts/vkrige.py:33
+msgid "No GRASS-python library found."
msgstr ""
-#: ../gui/wxpython/core/utils.py:914
-#, python-format
-msgid "Unable to create file '%s'\n"
+#: ../gui/wxpython/scripts/vkrige.py:65
+msgid "Input Data"
msgstr ""
-#: ../gui/wxpython/core/menutree.py:135
-#, python-format
-msgid "Unknow tag %s"
+#: ../gui/wxpython/scripts/vkrige.py:71
+msgid "Point dataset:"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:501
-#, python-format
-msgid ""
-"Unable to run command:\n"
-"%(cmd)s\n"
-"\n"
-"Option <%(opt)s>: read from standard input is not supported by wxGUI"
+#: ../gui/wxpython/scripts/vkrige.py:83
+msgid "Numeric column:"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:596
-#, python-format
-msgid "%d sec"
+#: ../gui/wxpython/scripts/vkrige.py:94
+msgid "Kriging"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:599
-#, python-format
-msgid "%(min)d min %(sec)d sec"
+#: ../gui/wxpython/scripts/vkrige.py:114
+msgid "Output"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:607
-msgid ""
-"Please note that the data are left in inconsistent state and may be corrupted"
+#: ../gui/wxpython/scripts/vkrige.py:118
+msgid "Name for the output raster map:"
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:609
-msgid "Command aborted"
+#: ../gui/wxpython/scripts/vkrige.py:126
+msgid "Export variance map as well: "
msgstr ""
-#: ../gui/wxpython/core/gconsole.py:611
-msgid "Command finished"
+#: ../gui/wxpython/scripts/vkrige.py:267
+msgid "Kriging Module"
msgstr ""
-#: ../gui/wxpython/core/workspace.py:1053
-#, python-format
-msgid "Unable to open file <%s> for reading."
+#: ../gui/wxpython/scripts/vkrige.py:271
+msgid "Ready."
msgstr ""
-#: ../gui/wxpython/core/workspace.py:1066
-#, python-format
-msgid ""
-"Some lines were skipped when reading settings from file <%(file)s>.\n"
-"See 'Command output' window for details.\n"
-"\n"
-"Number of skipped lines: %(line)d"
+#: ../gui/wxpython/scripts/vkrige.py:295
+msgid "Variogram fitting"
msgstr ""
-#: ../gui/wxpython/core/workspace.py:1284
-#, python-format
-msgid " row %d:"
+#: ../gui/wxpython/scripts/vkrige.py:305
+msgid "Plot/refresh variogram"
msgstr ""
-#: ../gui/wxpython/core/ws.py:48
-msgid ""
-"Unable to load GDAL Python bindings.\n"
-"WMS layers can not be displayed without the bindings.\n"
+#: ../gui/wxpython/scripts/vkrige.py:316
+msgid ":"
msgstr ""
-#: ../gui/wxpython/core/gcmd.py:128
-msgid "Reason"
-msgstr "Iemesls"
+#: ../gui/wxpython/scripts/vkrige.py:341
+msgid "Kriging techniques"
+msgstr ""
-#: ../gui/wxpython/core/gcmd.py:394
-msgid "Execution failed:"
+#: ../gui/wxpython/scripts/vkrige.py:355
+msgid "Block size:"
msgstr ""
-#: ../gui/wxpython/core/gcmd.py:478
-#, python-format
-msgid "Unable to exectute command: '%s'"
+#: ../gui/wxpython/scripts/vkrige.py:388
+msgid "Auto-fit variogram"
msgstr ""
-#~ msgid "Measuring distance"
-#~ msgstr "Attāluma mērīšana"
+#: ../gui/wxpython/scripts/vkrige.py:412
+msgid "Model: "
+msgstr ""
-#~ msgid "segment"
-#~ msgstr "segments"
+#: ../gui/wxpython/scripts/vkrige.py:496
+msgid "Work in progress! No functionality provided."
+msgstr ""
-#~ msgid "total distance"
-#~ msgstr "kopējais garums"
+#: ../gui/wxpython/scripts/r.li.setup.py:141
+msgid "I m!"
+msgstr ""
-#~ msgid "&Protocol"
-#~ msgstr "&Protokols"
+#: ../gui/wxpython/scripts/r.li.setup.py:357
+#, python-format
+msgid ""
+"Location <%(loc)s> will be created in GIS data directory <%(dir)s>.You will "
+"need to change the default GIS data directory in the GRASS startup screen."
+msgstr ""
-#~ msgid "deg"
-#~ msgstr "grādi"
+#: ../gui/wxpython/scripts/r.li.setup.py:547
+#: ../gui/wxpython/scripts/r.li.setup.py:571
+#, fuzzy
+msgid "File not found."
-#~ msgid "WMS import"
-#~ msgstr "WMS importēšana"
-#~ msgid "NVIZ (requires Tcl/Tk)"
-#~ msgstr "NVIZ (ir nepieciešams Tcl/Tk)"
-#~ msgid "Version"
-#~ msgstr "Versija"
