[GRASS-SVN] r59147 - in grass/trunk: lib/python/script scripts/r.unpack scripts/v.unpack
svn_grass at osgeo.org
Thu Feb 27 02:28:18 PST 2014
Author: lucadelu
Date: 2014-02-27 02:28:18 -0800 (Thu, 27 Feb 2014)
New Revision: 59147
grass/trunk/lib/python/script/core.py
grass/trunk/scripts/r.unpack/r.unpack.py
grass/trunk/scripts/v.unpack/v.unpack.py
r.unpack/v.unpack: fix problems for duplicate names in proj info and units, there is still a problem if second file has more keys, eg south:defined; PEP8 cleaning
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py 2014-02-27 08:09:54 UTC (rev 59146)
+++ grass/trunk/lib/python/script/core.py 2014-02-27 10:28:18 UTC (rev 59147)
@@ -757,8 +757,54 @@
return result
-def _text_to_key_value_dict(filename, sep=":", val_sep=","):
+def _compare_projection(dic):
+ !Check if projection has some possibility of duplicate names like
+ Universal Transverse Mercator and Universe Transverse Mercator and
+ unify them
+ @param dic The dictionary containing information about projection
+ @return The dictionary with the new values if needed
+ # the lookup variable is a list of list, each list contains all the
+ # possible name for a projection system
+ lookup = [['Universal Transverse Mercator', 'Universe Transverse Mercator']]
+ for lo in lookup:
+ for n in range(len(dic['name'])):
+ if dic['name'][n] in lo:
+ dic['name'][n] = lo[0]
+ return dic
+def _compare_units(dic):
+ !Check if units has some possibility of duplicate names like
+ meter and metre and unify them
+ @param dic The dictionary containing information about units
+ # possible name for a units
+ lookup = [['meter', 'metre'], ['meters', 'metres'], ['kilometer',
+ 'kilometre'], ['kilometers', 'kilometres']]
+ for l in lookup:
+ for n in range(len(dic['unit'])):
+ if dic['unit'][n] in l:
+ dic['unit'][n] = l[0]
+ for n in range(len(dic['units'])):
+ if dic['units'][n] in l:
+ dic['units'][n] = l[0]
+ return dic
+def _text_to_key_value_dict(filename, sep=":", val_sep=",", checkproj=False,
+ checkunits=False):
!Convert a key-value text file, where entries are separated
by newlines and the key and value are separated by `sep',
into a key-value dictionary and discover/use the correct
@@ -767,6 +813,9 @@
@param filename The name or name and path of the text file to convert
@param sep The character that separates the keys and values, default is ":"
@param val_sep The character that separates the values of a single key, default is ","
+ @param checkproj True if it has to check some information about projection system
+ @param checkproj True if it has to check some information about units
A text file with this content:
@@ -819,11 +868,16 @@
value_list.append(value_converted)
kvdict[key] = value_list
+ if checkproj:
+ kvdict = _compare_projection(kvdict)
+ if checkunits:
+ kvdict = _compare_units(kvdict)
return kvdict
def compare_key_value_text_files(filename_a, filename_b, sep=":",
- val_sep=",", precision=0.000001):
+ val_sep=",", precision=0.000001,
+ proj=False, units=False):
!Compare two key-value text files
@@ -845,11 +899,15 @@
@param sep character that separates the keys and values, default is ":"
@param val_sep character that separates the values of a single key, default is ","
@param precision precision with which the floating point values are compared
+ @param proj True if it has to check some information about projection system
+ @param units True if it has to check some information about units
@return True if full or almost identical, False if different
- dict_a = _text_to_key_value_dict(filename_a, sep)
- dict_b = _text_to_key_value_dict(filename_b, sep)
+ dict_a = _text_to_key_value_dict(filename_a, sep, checkproj=proj,
+ checkunits=units)
+ dict_b = _text_to_key_value_dict(filename_b, sep, checkproj=proj,
+ checkunits=units)
missing_keys = 0
Modified: grass/trunk/scripts/r.unpack/r.unpack.py
--- grass/trunk/scripts/r.unpack/r.unpack.py 2014-02-27 08:09:54 UTC (rev 59146)
+++ grass/trunk/scripts/r.unpack/r.unpack.py 2014-02-27 10:28:18 UTC (rev 59147)
@@ -40,23 +40,24 @@
import shutil
import tarfile
import atexit
-import filecmp
from grass.script import core as grass
def cleanup():
grass.try_rmdir(tmp_dir)
def main():
infile = options['input']
global tmp_dir
tmp_dir = grass.tempdir()
grass.debug('tmp_dir = %s' % tmp_dir)
if not os.path.exists(infile):
grass.fatal(_("File <%s> not found") % infile)
gisenv = grass.gisenv()
mset_dir = os.path.join(gisenv['GISDBASE'],
gisenv['LOCATION_NAME'],
@@ -64,41 +65,44 @@
input_base = os.path.basename(infile)
shutil.copyfile(infile, os.path.join(tmp_dir, input_base))
os.chdir(tmp_dir)
- tar = tarfile.TarFile.open(name = input_base, mode = 'r')
+ tar = tarfile.TarFile.open(name=input_base, mode='r')
try:
data_name = tar.getnames()[0]
except:
grass.fatal(_("Pack file unreadable"))
if options['output']:
map_name = options['output']
else:
map_name = data_name.split('@')[0]
- gfile = grass.find_file(name = map_name, element = 'cell',
- mapset = '.')
+ gfile = grass.find_file(name=map_name, element='cell', mapset='.')
if gfile['file']:
if os.environ.get('GRASS_OVERWRITE', '0') != '1':
grass.fatal(_("Raster map <%s> already exists") % map_name)
else:
grass.warning(_("Raster map <%s> already exists and will be overwritten") % map_name)
# extract data
tar.extractall()
os.chdir(data_name)
# check projection compatibility in a rather crappy way
diff_result_1 = diff_result_2 = None
proj_info_file_1 = 'PROJ_INFO'
proj_info_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')
- if not grass.compare_key_value_text_files(proj_info_file_1, proj_info_file_2):
+ if not grass.compare_key_value_text_files(filename_a=proj_info_file_1,
+ filename_b=proj_info_file_2,
+ proj=True):
diff_result_1 = grass.diff_files(proj_info_file_1, proj_info_file_2)
proj_units_file_1 = 'PROJ_UNITS'
proj_units_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')
- if not grass.compare_key_value_text_files(proj_units_file_1, proj_units_file_2):
+ if not grass.compare_key_value_text_files(filename_a=proj_units_file_1,
+ filename_b=proj_units_file_2,
+ units=True):
diff_result_2 = grass.diff_files(proj_units_file_1, proj_units_file_2)
if diff_result_1 or diff_result_2:
if flags['o']:
grass.warning(_("Projection information does not match. Proceeding..."))
@@ -110,7 +114,7 @@
grass.warning(_("Difference between PROJ_UNITS file of packed map "
"and of current location:\n{diff}").format(diff=''.join(diff_result_2)))
grass.fatal(_("Projection information does not match. Aborting."))
# install in $MAPSET
for element in ['cats', 'cell', 'cellhd', 'cell_misc', 'colr', 'fcell', 'hist']:
if not os.path.exists(element):
@@ -125,9 +129,9 @@
shutil.copytree('cell_misc', path)
else:
shutil.copyfile(element, os.path.join(mset_dir, element, map_name))
grass.message(_("Raster map <%s> unpacked") % map_name)
if __name__ == "__main__":
options, flags = grass.parser()
atexit.register(cleanup)
Modified: grass/trunk/scripts/v.unpack/v.unpack.py
--- grass/trunk/scripts/v.unpack/v.unpack.py 2014-02-27 08:09:54 UTC (rev 59146)
+++ grass/trunk/scripts/v.unpack/v.unpack.py 2014-02-27 10:28:18 UTC (rev 59147)
@@ -38,74 +38,79 @@
import shutil
import tarfile
import atexit
-import filecmp
from grass.script import db as grassdb
def cleanup():
def main():
# create temporary directory
global tmp_dir
# check if the input file exists
# copy the files to tmp dir
os.chdir(tmp_dir)
try:
except:
# set the output name
else:
# grass env
gisenv['MAPSET'])
new_dir = os.path.join(mset_dir, 'vector', map_name)
- gfile = grass.find_file(name = map_name, element = 'vector',
- mapset = '.')
+ gfile = grass.find_file(name=map_name, element='vector', mapset='.')
overwrite = os.getenv('GRASS_OVERWRITE')
if gfile['file'] and overwrite != '1':
grass.fatal(_("Vector map <%s> already exists") % map_name)
elif overwrite == '1' and gfile['file']:
grass.warning(_("Vector map <%s> already exists and will be overwritten") % map_name)
- grass.run_command('g.remove', quiet = True, vect = map_name)
- shutil.rmtree(new_dir,True)
+ grass.run_command('g.remove', quiet=True, vect=map_name)
+ shutil.rmtree(new_dir, True)
# extract data
tar.extractall()
loc_proj = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')
loc_proj_units = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')
- if not grass.compare_key_value_text_files(os.path.join(tmp_dir,'PROJ_INFO'), loc_proj):
- diff_result_1 = grass.diff_files(os.path.join(tmp_dir,'PROJ_INFO'), loc_proj)
+ if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir,'PROJ_INFO'),
+ filename_b=loc_proj, proj=True):
+ diff_result_1 = grass.diff_files(os.path.join(tmp_dir, 'PROJ_INFO'),
+ loc_proj)
- if not grass.compare_key_value_text_files(os.path.join(tmp_dir,'PROJ_UNITS'), loc_proj_units):
- diff_result_2 = grass.diff_files(os.path.join(tmp_dir,'PROJ_UNITS'), loc_proj_units)
+ if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir,'PROJ_UNITS'),
+ filename_b=loc_proj_units,
+ units=True):
+ diff_result_2 = grass.diff_files(os.path.join(tmp_dir, 'PROJ_UNITS'),
+ loc_proj_units)
if flags['o']:
@@ -128,18 +133,18 @@
dbconn = grassdb.db_connection()
todb = dbconn['database']
# return all tables
- list_fromtable = grass.read_command('db.tables', driver = 'sqlite',
- database = fromdb).splitlines()
+ list_fromtable = grass.read_command('db.tables', driver='sqlite',
+ database=fromdb).splitlines()
# return the list of old connection for extract layer number and key
- dbln = open(os.path.join(new_dir,'dbln'), 'r')
+ dbln = open(os.path.join(new_dir, 'dbln'), 'r')
dbnlist = dbln.readlines()
dbln.close()
# check if dbf or sqlite directory exists
if dbconn['driver'] == 'dbf' and not os.path.exists(os.path.join(mset_dir, 'dbf')):
- os.mkdir(os.path.join(mset_dir, 'dbf'))
+ os.mkdir(os.path.join(mset_dir, 'dbf'))
elif dbconn['driver'] == 'sqlite' and not os.path.exists(os.path.join(mset_dir, 'sqlite')):
- os.mkdir(os.path.join(mset_dir, 'sqlite'))
+ os.mkdir(os.path.join(mset_dir, 'sqlite'))
# for each old connection
for t in dbnlist:
# it split the line of each connection, to found layer number and key
@@ -147,7 +152,7 @@
values = t.split('|')
else:
values = t.split(' ')
from_table = values[1]
layer = values[0].split('/')[0]
# we need to take care about the table name in case of several layer
@@ -158,30 +163,32 @@
to_table = map_name
else:
to_table = from_table
- grass.verbose(_("Coping table <%s> as table <%s>") % (from_table, to_table))
+ grass.verbose(_("Coping table <%s> as table <%s>") % (from_table,
+ to_table))
# copy the table in the default database
- if 0 != grass.run_command('db.copy', to_driver = dbconn['driver'],
- to_database = todb, to_table = to_table,
- from_driver = 'sqlite', from_database = fromdb,
- from_table = from_table):
+ if 0 != grass.run_command('db.copy', to_driver=dbconn['driver'],
+ to_database=todb, to_table=to_table,
+ from_driver='sqlite',
+ from_database=fromdb,
+ from_table=from_table):
grass.fatal(_("Unable to copy table <%s> as table <%s>") % (from_table, to_table))
grass.verbose(_("Connect table <%s> to vector map <%s> at layer <%s>") % \
(to_table, map_name, layer))
# and connect the new tables with the right layer
- if 0 != grass.run_command('v.db.connect', flags = 'o', quiet = True,
- driver = dbconn['driver'], database = todb,
- map = map_name, key = values[2],
- layer = layer, table = to_table):
+ if 0 != grass.run_command('v.db.connect', flags='o', quiet=True,
+ driver=dbconn['driver'], database=todb,
+ map=map_name, key=values[2],
+ layer=layer, table=to_table):
grass.fatal(_("Unable to connect table <%s> to vector map <%s>") % \
(to_table, map_name))
grass.message(_("Vector map <%s> succesfully unpacked") % map_name)
- options, flags = grass.parser()
- atexit.register(cleanup)
- sys.exit(main())
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ sys.exit(main())
