[GRASS-SVN] r58600 - grass-addons/grass7/imagery/i.edge
svn_grass at osgeo.org
Fri Jan 3 14:39:58 PST 2014
Author: wenzeslaus
Date: 2014-01-03 14:39:58 -0800 (Fri, 03 Jan 2014)
New Revision: 58600
grass-addons/grass7/imagery/i.edge/i.edge.html
i.edge: add documentation
Modified: grass-addons/grass7/imagery/i.edge/i.edge.html
--- grass-addons/grass7/imagery/i.edge/i.edge.html 2014-01-03 22:17:48 UTC (rev 58599)
+++ grass-addons/grass7/imagery/i.edge/i.edge.html 2014-01-03 22:39:58 UTC (rev 58600)
@@ -1,11 +1,131 @@
<h2>DESCRIPTION</h2>
-<em>i.edge</em> is an edge detector based on the Canny algorithm
+<p>
+<em>i.edge</em> is an edge detector based on the Canny edge detection
+algorithm [Canny1986]. The Canny edge detector is a filter which detects
+a wide range of edges in raster maps and produces thin edges as a raster map.
+<h3>Algorithm</h3>
+<p>
+An edge is considered as a change in gradient which is computed from image digital
+values. There are two main noticeable differences between
+Canny filter and other edge detectors. First, the others algorithm usually
+output broad lines (edges) while Canny filter outputs one-pixel-wide line(s)
+which represents the most probable edge position [Russ2011].
+Second, the Canny filter combines several steps together while
+other filters have only one step and often require some pre- or post-processing to get
+results which allows further processing. However, it must be noted that by applying
+subsequent filters, thresholding and edge thinning one can get similar results also
+from other edge detectors.
+The implementation used for <em>i.edge</em> module is based on code from [Gibara2010].
+<p>
+Canny edge detector is considered as optimal edge detector according to
+these three criteria [Sonka1999]:
+<ol>
+<li>important edges cannot be omitted and only actual edges can be detected as
+edges (no false positives);
+<li>difference in position of the real edge and the detected edge is minimal;
+<li>there is only one detected edge for an edge in original image.
+</ol>
+<p>
+The algorithm consists of a few steps.
+Firstly, the noise is reduced by a Gaussian filter (based on normal distribution); the
+result is smoothed image. Secondly, two orthogonal gradient images are computed.
+These images are combined, so the final gradient can be defined by an angle and
+a magnitude (value). Next step is non-maximum suppression which preserves only
+pixels with magnitude higher than magnitude of other pixels in the direction (and the
+opposite direction) of gradient. Finally, only relevant or significant edges extracted
+by thresholding with hysteresis. This thresholding uses two constants; if a pixel
+magnitude is above the higher one (<em>hT</em>), it is kept.
+Pixels with the magnitude under the lower threshold (<em>lT</em>) are removed.
+Pixels with magnitude values between these two constants
+are kept only when the pixels has some neighbor pixels with magnitude higher than
+the high threshold [Sonka1999].
+<h3>Inputs and parameters</h3>
+The input is a gray scale image (a raster map). Usually, this gray scale
+image is an intensity channel obtained by RGB to HIS conversion. Some other
+possibilities include color edges (obtained from RGB color channels) which
+may give slightly better results [Zimmermann2000]. In theory, <em>i.edge</em>
+module can be applied not only to images but also to digital elevation models
+and other data with abrupt changes in raster values.
+The output is a binary raster where ones denote edges and zeros denote
+everything else. There are also possible byproducts or intermediate products which
+can be part of the output, namely edge angles (gradient orientations).
+By changing parameters of the module one can easily achieve different levels of
+detail. There are 3 parameters which affect the result. A <tt>sigma</tt>
+value and two threshold values, <tt>low_threshold</tt> (<em>lT</em>)
+<tt>high_threshold</tt> (<em>hT</em>). It is recommended to use
+<em>lT</em> and <em>hT</em> threshold values in ratio (computed
+as <em>hT/lT</em>) between 2 and 3 [Sonka1999].
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+# set the region (resolution) to Landsat image
+g.region rast=lsat7_2000_20 at landsat
+# set the region to experimetal area
+g.region n=224016 s=220981 w=637589 e=641223
+# compute PCA for all Landsat maps for year 2002
+i.pca input=`g.mlist pattern="lsat7_2002*" type=rast sep=,` output_prefix=lsat_pca
+# run edge detection on first component
+i.edge input=lsat_pca.1 at PERMANENT output=lsat_pca_1_edges
+# set no edges areas to NULL (for visualization)
+r.null map=lsat_pca_1_edges at PERMANENT setnull=0
+</pre></div>
+<h2>KNOWN ISSUES</h2>
+Computational region shall be set to input map. The module can work only
+on small images since map is loaded into memory.
+Edge strengths (gradient values) are not provided as an output but might be added in the future.
+<h2>REFERENCES</h2>
+<ul>
+<li>J. Canny. <i>A Computational Approach to Edge Detection</i>. In: IEEE Trans.
+Pattern Anal. Mach. Intell. 8.6 (June 1986), pp. 679–698. issn: 0162-8828.</li>
+<li>J.C. Russ. <i>The image processing handbook</i>. CRC, 2011.</li>
+<li>Tom Gibara. <i>Canny Edge Detector Implementation</i>. [Online; accessed 20-June-
+2012]. 2010. URL:
+<a href="http://www.tomgibara.com/computer-vision/canny-edge-detector">
+http://www.tomgibara.com/computer-vision/canny-edge-detector</a>.
+<li>M. Sonka, V. Hlavac, and R. Boyle. <i>Image processing, analysis, and machine
+vision</i>. PWS Pub. Pacific Grove (1999).
+<li>P. Zimmermann. <i>A new framework for automatic building detection analysing
+multiple cue data</i>. In: International Archives of Photogrammetry and Remote
+Sensing 33.B3/2; PART 3 (2000), pp. 1063–1070.</li>
+</ul>
<h2>SEE ALSO</h2>
<em>
-<a href="i.zc.html">i.zc</a>
+<a href="i.zc.html">i.zc</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>
</em>
