[GRASS-SVN] r58629 - grass/trunk/vector/v.delaunay
svn_grass at osgeo.org
Mon Jan 6 15:15:12 PST 2014
Author: neteler
Date: 2014-01-06 15:15:11 -0800 (Mon, 06 Jan 2014)
New Revision: 58629
Added:
grass/trunk/vector/v.delaunay/v_delaunay.png
grass/trunk/vector/v.delaunay/v.delaunay.html
v.delaunay manual: example updated to NC; figure added
Modified: grass/trunk/vector/v.delaunay/v.delaunay.html
--- grass/trunk/vector/v.delaunay/v.delaunay.html 2014-01-06 18:09:28 UTC (rev 58628)
+++ grass/trunk/vector/v.delaunay/v.delaunay.html 2014-01-06 23:15:11 UTC (rev 58629)
@@ -3,48 +3,23 @@
<em>v.delaunay</em> uses an existing vector points map (<b>input</b>)
to create a Delaunay triangulation vector map (<b>output</b>).
<p>
-<br>
-Delaunay triangulation and Voronoi diagram example:
+Delaunay triangulation example (red-yellow points are the data points from which the triangulation was generated):
<center>
-<img src="v_voronoi_delaunay.png" border="1"><br> <!-- installed by v.voronoi -->
-<table border="0" width="590">
-<tr><td><center>
-<i>Delaunay Triangulation (left pane), Voronoi diagram (center pane),
-and both (right pane)</i>
-</center></td></tr>
-</table>
+<img src="v_delaunay.png" border="1">
</center>
<h2>EXAMPLE</h2>
-Commands used with the Spearfish dataset to create the above figure.
+Commands used with the North Carolina dataset to create the above figure (subset shown in figure).
<div class="code"><pre>
- g.region n=4927250 s=4919400 w=588650 e=594850
- d.frame -c fr=one at=0,100,0,33.3333
- d.frame -c fr=two at=0,100,33.3333,66.6667
- d.frame -c fr=three at=0,100,66.6667,100
- v.delaunay -lr in=archsites out=arch_delaunay
- d.frame -s one
- d.vect arch_delaunay
- d.vect archsites color=red fcolor=red size=5 icon=basic/circle
- v.voronoi -l in=archsites out=arch_voronoi
- d.frame -s two
- d.vect arch_voronoi type=line
- d.frame -s three
- d.vect arch_delaunay color=blue
+g.region n=220750 s=219950 w=638300 e=639000 -p
+v.delaunay input=elev_lid792_randpts output=elev_lid792_randpts_delaunay
</pre></div>
<h2>REFERENCES</h2>
-<em>Leonid Guibas and Jorge Stolfi, (1985).
-Primitives for the
+<em>Leonid Guibas and Jorge Stolfi, (1985). Primitives for the
Manipulation of General Subdivisions and the Computation of
Voronoi Diagrams, ACM Transactions on Graphics, Vol 4, No. 2,
April 1985, Pages 74-123
@@ -63,5 +38,5 @@
Paul Kelly, Mentor<br>
Based on "dct" by Geoff Leach, Department of Computer Science, RMIT.<br>
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Added: grass/trunk/vector/v.delaunay/v_delaunay.png
(Binary files differ)
Property changes on: grass/trunk/vector/v.delaunay/v_delaunay.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
