[GRASS-SVN] r58631 - grass-addons/grass7/raster/r.diversity
Mon Jan 6 16:03:52 PST 2014
Author: lucadelu
Date: 2014-01-06 16:03:52 -0800 (Mon, 06 Jan 2014)
New Revision: 58631
   grass-addons/grass7/raster/r.diversity/r.diversity.py
fix problem porting to GRASS 7, cosmetics and PEP8 changes
Modified: grass-addons/grass7/raster/r.diversity/r.diversity.py
--- grass-addons/grass7/raster/r.diversity/r.diversity.py	2014-01-06 23:15:49 UTC (rev 58630)
+++ grass-addons/grass7/raster/r.diversity/r.diversity.py	2014-01-07 00:03:52 UTC (rev 58631)
@@ -3,16 +3,16 @@
-# MODULE:	r.diversity
-# AUTHOR(S):	Luca Delucchi
-# PURPOSE:	It calculates the mostly used indices of diversity based on
-#		information theory
+# MODULE:     r.diversity
+# AUTHOR(S):  Luca Delucchi
+# PURPOSE:    It calculates the mostly used indices of diversity based on
+#             information theory
 # COPYRIGHT: (C) 2010-2012 by Luca Delucchi
-#		This program is free software under the GNU General Public
-#		License (>=v2). Read the file COPYING that comes with GRASS
-#		for details.
+#        This program is free software under the GNU General Public
+#        License (>=v2). Read the file COPYING that comes with GRASS
+#        for details.
@@ -25,17 +25,17 @@
 #% type: string
 #% gisprompt: old,cell,raster
 #% key_desc: name
-#% description: Name of input raster map
+#% description: Name of input raster map
 #% required: yes
-#%end
+#%end
 #%option
-#% key: output
+#% key: prefix
 #% type: string
 #% gisprompt: new,cell,raster
 #% key_desc: name
-#% description: Name of output raster map
+#% description: Prefix for output raster map(s)
 #% required: yes
-#%end
+#%end
 #%option
 #% key: alpha
 #% type: double
@@ -52,7 +52,7 @@
 #% description: Size of processing window (odd number only)
 #% answer: 3
 #% required: no
-#%end
+#%end
 #%option
 #% key: method
 #% type: string
@@ -74,23 +74,25 @@
 # import library
-import os, sys, re
+import os
+import sys
 import grass.script as grass
 # main function
 def main():
     # set the home path
-    home=os.path.expanduser('~')
+    home = os.path.expanduser('~')
+    rlidir = os.path.join(home, '.grass7', 'r.li')
     # check if GISBASE is set
     if "GISBASE" not in os.environ:
-	# return an error advice
-	print "You must be in GRASS GIS to run this program."
-	sys.exit(1)
+        # return an error advice
+        grass.fatal(_("You must be in GRASS GIS to run this program."))
     # input raster map
     map_in = options['input']
     # output raster map
-    map_out = options['output']
+    map_out = options['prefix']
     # resolution of moving windows
     res = options['size']
     # alpha value for r.renyi
@@ -100,184 +102,195 @@
     # excluded method
     excludes = options['exclude']
+    resolution = checkValues(res)
-    resolution = checkValues(res)
     if alpha != '':
-	alpha_value = checkValues(alpha,True)
-	print alpha_value
+        alpha_value = checkValues(alpha, True)
     # check if ~/.r.li path exists
-    if not os.path.exists(home + '/.r.li'):
-	# create ~/.r.li
-	os.mkdir(home + '/.r.li')
-	# create ~/.r.li/history
-	os.mkdir(home + '/.r.li/history')
-    else:
-	if not os.path.exists(home + '/.r.li/history'):
+    if not os.path.exists(rlidir):
+        # create ~/.grass7/r.li
+        os.mkdir(rlidir)
     # set overwrite
-    if grass.overwrite():
-        env['GRASS_OVERWRITE'] = '1'
+    overwrite = grass.overwrite()
+    quiet = True
+    if grass.verbosity() > 2:
+        quiet = False
     # if method and exclude option are not null return an error
     if methods != '' and excludes != '':
-	print "You can use method or exclude option not both"
-	sys.exit(1)
+        grass.fatal(_("You can use method or exclude option not both"))
     # if method and exclude option are null calculate all module
     elif methods == '' and excludes == '':
-	# check if alpha_value is set, else return an error
-	if alpha_value == '':
-	    print "Please you must set alpha value for Renyi entropy"
-	    sys.exit(1)
-	calculateAll(home, map_in, map_out, resolution, alpha_value)
+        # check if alpha_value is set, else return an error
+        if alpha_value == '':
+            grass.fatal(_("Please you must set alpha value for Renyi entropy"))
+        calculateAll(rlidir, map_in, map_out, resolution, alpha_value, quiet,
+                     overwrite)
     # calculate method
     elif methods != '':
-	methods = methods.split(',')
-	checkAlpha(methods,alpha_value)
-	calculateM(home, map_in, map_out, resolution, alpha_value,methods)
+        methods = methods.split(',')
+        checkAlpha(methods, alpha_value)
+        calculateM(rlidir, map_in, map_out, resolution, alpha_value, methods,
+                   quiet, overwrite)
     # calculate not excluded index
     elif excludes != '':
-	excludes = excludes.split(',')
-	checkAlpha(excludes,alpha_value,True)
-	calculateE(home, map_in, map_out, resolution, alpha_value,excludes)
+        excludes = excludes.split(',')
+        checkAlpha(excludes, alpha_value, True)
+        calculateE(rlidir, map_in, map_out, resolution, alpha_value, excludes,
+                   quiet, overwrite)
     # remove configuration files
-    removeConfFile(resolution,home)
+    removeConfFile(resolution, rlidir)
     print 'All works are terminated'
 # calculate all index
-def calculateAll(home, map_in, map_out, res, alpha):
+def calculateAll(home, map_in, map_out, res, alpha, quiet, overw):
     # for each resolution create the config file and calculate all index
     for r in res:
-	createConfFile(r,map_in,home)
-	r = str(r)
-	grass.run_command('r.li.simpson', input = map_in, output = map_out +
-	'_simpson_size_' + r, conf = 'conf_diversity_' + r)
-	grass.run_command('r.li.shannon', input = map_in, output = map_out +
-	'_shannon_size_' + r, conf = 'conf_diversity_' + r)
-	grass.run_command('r.li.pielou', input = map_in, output = map_out +
-	'_pielou_size_' + r, conf = 'conf_diversity_' + r)
-	for alp in alpha:
-	    grass.run_command('r.li.renyi', input = map_in, output = map_out+
-	    '_renyi_size_' + r + '_alpha_'+ str(alp), conf =
-	    'conf_diversity_' + r, alpha = alp)
+        createConfFile(r, map_in, home)
+        r = str(r)
+        grass.run_command('r.li.simpson', input=map_in, output=map_out + \
+                          '_simpson_size_' + r, conf='conf_diversity_' + r,
+                          quiet=quiet, overwrite=overw)
+        grass.run_command('r.li.shannon', input=map_in, output=map_out + \
+                          '_shannon_size_' + r, conf='conf_diversity_' + r,
+        grass.run_command('r.li.pielou', input=map_in, output=map_out + \
+                          '_pielou_size_' + r, conf='conf_diversity_' + r,
+        for alp in alpha:
+            grass.run_command('r.li.renyi', input=map_in, output=map_out + \
+                              '_renyi_size_' + r + '_alpha_' + str(alp),
+                              conf='conf_diversity_' + r, alpha=alp,
 # calculate only method included in method option
-def calculateM(home, map_in, map_out, res, alpha, method):
+def calculateM(home, map_in, map_out, res, alpha, method, quiet, overw):
     for r in res:
-	r = str(r)
-	# for each method in method option calculate index
-	for i in method:
-	    if i == 'renyi':
-		for alp in alpha:
-		    map_out + '_renyi_size_' + r + '_alpha_' + str(alp),
-		    conf = 'conf_diversity_' + r, alpha = alp)
-	    else:
-		grass.run_command('r.li.' + i, input = map_in, output = map_out +
-		'_' + i + '_size_' + r, conf = 'conf_diversity_' + r)
+        r = str(r)
+        # for each method in method option calculate index
+        for i in method:
+            if i == 'renyi':
+                for alp in alpha:
+                                      output=map_out + '_renyi_size_' + r + \
+                                      '_alpha_' + str(alp), alpha=alp,
+                else:
+                    grass.run_command('r.li.' + i, input=map_in,
+                                      output=map_out + '_' + i + '_size_' + r,
 # calculate only method excluded with exclude option
-def calculateE(home, map_in, map_out, res, alpha, method):
-    # set a tuple with all index
-    methods = ('simpson','shannon','pielou','renyi')
-    # for each resolution create the config file
+def calculateE(home, map_in, map_out, res, alpha, method, quiet, overw):
+    # set a tuple with all index
+    methods = ('simpson', 'shannon', 'pielou', 'renyi')
+    # for each resolution create the config file
     for r in res:
-	r = str(r)
-	# for each method
-	for i in methods:
-	    # if method it isn't in exclude option it is possible to calculate
-	    if method.count(i) == 0:
-		if i == 'renyi':
-		    for alp in alpha:
-		else:
-		    '_' + i+ '_size_' + r, conf = 'conf_diversity_' + r)
+        r = str(r)
+        # for each method
+        for i in methods:
+            # if method it isn't in exclude option it is possible to calculate
+            if method.count(i) == 0:
+                if i == 'renyi':
+                    for alp in alpha:
+                                          output=map_out + '_renyi_size_' + r \
+                                          + '_alpha_' + str(alp), alpha=alp,
+        else:
+                grass.run_command('r.li.' + i, input=map_in, output=map_out \
+                                  + '_' + i + '_size_' + r,
 # check if alpha value it's set when renyi entropy must be calculate
-def checkAlpha(method,alpha_val,negative=False):
+def checkAlpha(method, alpha_val, negative=False):
     for alpha in alpha_val:
-      # it's used when we check the exclude option
-      if negative:
-	  if method.count('renyi') != 1 and alpha == '':
-	      sys.exit(1)
-      # it's used when we check the method option
-      else:
-	  if method.count('renyi') == 1 and alpha == '':
-	      sys.exit(1)
+        # it's used when we check the exclude option
+        if negative:
+            if method.count('renyi') != 1 and alpha == '':
+        # it's used when we check the method option
+        else:
+            if method.count('renyi') == 1 and alpha == '':
 #create configuration file instead using r.li.setup
-def createConfFile(res,inpumap,home):
+def createConfFile(res, inpumap, home):
     # set the name of conf file
-    confilename = home + '/.r.li/history/conf_diversity_' + str(res)
+    name = 'conf_diversity_' + str(res)
+    confilename = os.path.join(home, name)
     # start the text for the conf file
     outputLine = ['SAMPLINGFRAME 0|0|1|1\n']
     # return r.info about input file
     rinfo = grass.raster_info(inpumap)
     # calculate number of lines
-    rows = (rinfo["north"]-rinfo["south"])/rinfo['nsres']
+    rows = (rinfo["north"] - rinfo["south"]) / rinfo['nsres']
     # calculate number of columns
-    columns = (rinfo['east']-rinfo['west'])/rinfo['ewres']
+    columns = (rinfo['east'] - rinfo['west']) / rinfo['ewres']
     # value for row
-    rV = int(res)/rows
+    rV = int(res) / rows
     # value for column
-    cV = int(res)/columns
+    cV = int(res) / columns
     # append the text for the conf file
-    outputLine.append('SAMPLEAREA -1|-1|'+str(rV)+'|'+str(cV)+'\n')
+    outputLine.append('SAMPLEAREA -1|-1|' + str(rV) + '|' + str(cV) + '\n')
     outputLine.append('MOVINGWINDOW\n')
     # open configuration file
-    fileConf=open(confilename,'w')
-    # write file
+    fileConf = open(confilename, 'w')
+    # write file
     fileConf.writelines(outputLine)
     # close file
     fileConf.close()
 # return a list of resolution
-def checkValues(res,alpha=False):
+def checkValues(res, alpha=False):
     # check if more values are passed
     if res.count(',') == 1:
-	typ = 'values'
-	reso = res.split(',')
-    # check if a range of values are passed
+        typ = 'values'
+        reso = res.split(',')
+    # check if a range of values are passed
     elif res.count('-') == 1:
-	typ = 'range'
-	reso = res.split('-')
+        typ = 'range'
+        reso = res.split('-')
     # else only a value is passed
     else:
-	typ = 'value'
-	reso = [res]
+        typ = 'value'
+        reso = [res]
     # transform string to int and check if is a odd number
     for i in range(len(reso)):
-	# check if is a odd number
-	reso[i] = float(reso[i])
-	if reso[i] % 2 == 0:
-	    # return the error advice
-	    print "The size/alpha setting must be an integer number (found %d)" % reso[i]
-	    sys.exit(1)
+        # check if is a odd number
+        reso[i] = float(reso[i])
+        if reso[i] % 2 == 0:
+            # return the error advice
+            grass.fatal(_("The size/alpha setting must be an integer number " \
+                          "(found %d)" % reso[i]))
     # create a range
     if typ == 'range':
-	    if alpha:
-		print "Range for alpha values it isn't supported"
-		sys.exit(1)
-	    else:
-		reso = range(reso[0],reso[1]+1,2)
+        if alpha:
+            grass.fatal(_("Range for alpha values it isn't supported"))
+        else:
+            reso = range(reso[0], reso[1] + 1, 2)
     return reso
-def removeConfFile(res,home):
+def removeConfFile(res, home):
     for r in res:
-      confilename = home + '/.r.li/history/conf_diversity_' + str(r)
-      os.remove(confilename)
+        confilename = os.path.join(home, 'conf_diversity_' + str(r))
+        os.remove(confilename)
 if __name__ == "__main__":
     options, flags = grass.parser()
