[GRASS-SVN] r58635 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Tue Jan 7 07:40:12 PST 2014
Author: zarch
Date: 2014-01-07 07:40:12 -0800 (Tue, 07 Jan 2014)
New Revision: 58635
grass/trunk/lib/python/pygrass/vector/__init__.py
Add some optional parameter and fix the cat of the geometry features
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2014-01-07 15:38:49 UTC (rev 58634)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2014-01-07 15:40:12 UTC (rev 58635)
@@ -6,18 +6,19 @@
import grass.lib.vector as libvect
from vector_type import VTYPE
-from grass.script.core import gisenv
-import os
+from os.path import join, exists
# import pygrass modules
from grass.pygrass.errors import GrassError, must_be_open
+from grass.pygrass.gis import Location
from geometry import GEOOBJ as _GEOOBJ
from geometry import read_line, read_next_line
+from geometry import Area as _Area
from abstract import Info
-from basic import Bbox, Cats
+from basic import Bbox, Cats, Ilist
_NUMOF = {"areas": libvect.Vect_get_num_areas,
@@ -56,9 +57,9 @@
- def __init__(self, name, mapset=''):
+ def __init__(self, name, mapset='', *args, **kwargs):
# Set map name and mapset
- super(Vector, self).__init__(name, mapset)
+ super(Vector, self).__init__(name, mapset, *args, **kwargs)
self._topo_level = 1
self._class_name = 'Vector'
self.overwrite = False
@@ -188,6 +189,9 @@
cats = Cats(geo_obj.c_cats)
cats.reset()
cats.set(self.n_lines, self.layer)
+ if geo_obj.gtype == _Area.gtype:
+ result = self._write_area(geo_obj)
result = libvect.Vect_write_line(self.c_mapinfo, geo_obj.gtype,
geo_obj.c_points, geo_obj.c_cats)
if result == -1:
@@ -361,7 +365,7 @@
return output
@must_be_open
- def viter(self, vtype):
+ def viter(self, vtype, idonly=False):
"""Return an iterator of vector features
@@ -388,10 +392,13 @@
if vtype in _GEOOBJ.keys():
if _GEOOBJ[vtype] is not None:
+ ids = (indx for indx in xrange(1, self.number_of(vtype) + 1))
+ if idonly:
+ return ids
return (_GEOOBJ[vtype](v_id=indx, c_mapinfo=self.c_mapinfo,
table=self.table,
writable=self.writable)
- for indx in xrange(1, self.number_of(vtype) + 1))
+ for indx in ids)
else:
keys = "', '".join(sorted(_GEOOBJ.keys()))
raise ValueError("vtype not supported, use one of: '%s'" % keys)
@@ -418,11 +425,32 @@
libvect.Vect_rewind(self.c_mapinfo)
@must_be_open
- def cat(self, cat_id):
+ def cat(self, cat_id, vtype, layer=None, generator=False):
"""Return the geometry features with category == cat_id.
+ Parameters
+ cat_id : integer
+ Integer with the category number.
+ vtype : string
+ String of the type of geometry feature that we are looking for.
+ layer : integer, optional
+ Integer of the layer that will be used.
+ generator : bool, optional
+ If True return a generator otherwise it return a list of features.
- return self.read(libvect.Vect_get_line_cat(self.c_mapinfo,
- cat_id, self.layer))
+ if vtype not in _GEOOBJ:
+ keys = "', '".join(sorted(_GEOOBJ.keys()))
+ raise ValueError("vtype not supported, use one of: '%s'" % keys)
+ Obj = _GEOOBJ[vtype]
+ ilist = Ilist()
+ libvect.Vect_cidx_find_all(self.c_mapinfo,
+ layer if layer else self.layer,
+ Obj.gtype, cat_id, ilist.c_ilist)
+ if generator:
+ return (Obj(v_id=v_id, c_mapinfo=self.c_mapinfo) for v_id in ilist)
+ else:
+ return [Obj(v_id=v_id, c_mapinfo=self.c_mapinfo) for v_id in ilist]
@must_be_open
def read(self, feature_id):
@@ -510,7 +538,16 @@
raise GrassError("I can not find the Bbox.")
return bbox
- def close(self, release=True):
+ @must_be_open
+ def select_by_bbox(self, bbox):
+ """Return the BBox of the vecor map
+ bbox = Bbox()
+ if libvect.Vect_get_map_box(self.c_mapinfo, bbox.c_bbox) == 0:
+ raise GrassError("I can not find the Bbox.")
+ return bbox
+ def close(self, build=True, release=True):
"""Close the VectorTopo map, if release is True, the memory
occupied by spatial index is released"""
if release:
