[GRASS-SVN] r58642 - in grass/trunk/gui/wxpython: lmgr modules
svn_grass at osgeo.org
Wed Jan 8 09:23:47 PST 2014
Author: martinl
Date: 2014-01-08 09:23:47 -0800 (Wed, 08 Jan 2014)
New Revision: 58642
grass/trunk/gui/wxpython/lmgr/giface.py
grass/trunk/gui/wxpython/modules/extensions.py
wxGUI/extension: show manual page (via contextual menu)
Modified: grass/trunk/gui/wxpython/lmgr/giface.py
--- grass/trunk/gui/wxpython/lmgr/giface.py 2014-01-08 17:16:33 UTC (rev 58641)
+++ grass/trunk/gui/wxpython/lmgr/giface.py 2014-01-08 17:23:47 UTC (rev 58642)
@@ -15,6 +15,8 @@
@author Vaclav Petras <wenzeslaus gmail.com>
+import os
from grass.pydispatch.signal import Signal
from core.giface import Notification
@@ -144,8 +146,10 @@
def RunCmd(self, *args, **kwargs):
self.lmgr._gconsole.RunCmd(*args, **kwargs)
- def Help(self, entry):
+ def Help(self, entry, online=False):
cmdlist = ['g.manual', 'entry=%s' % entry]
+ if online:
+ cmdlist.append('-o')
self.RunCmd(cmdlist, compReg = False, notification=Notification.NO_NOTIFICATION)
def WriteLog(self, text, wrap = None,
Modified: grass/trunk/gui/wxpython/modules/extensions.py
--- grass/trunk/gui/wxpython/modules/extensions.py 2014-01-08 17:16:33 UTC (rev 58641)
+++ grass/trunk/gui/wxpython/modules/extensions.py 2014-01-08 17:23:47 UTC (rev 58642)
@@ -9,7 +9,7 @@
- extensions::UninstallExtensionWindow
- extensions::CheckListExtension
-(C) 2008-2013 by the GRASS Development Team
+(C) 2008-2014 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -40,7 +40,7 @@
self.parent = parent
self._giface = giface
self.options = dict() # list of options
wx.Frame.__init__(self, parent = parent, id = id, title = title, **kwargs)
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
@@ -109,6 +109,7 @@
self.btnHelp.Bind(wx.EVT_BUTTON, self.OnHelp)
self.tree.selectionChanged.connect(self.OnItemSelected)
self.tree.itemActivated.connect(self.OnItemActivated)
+ self.tree.contextMenu.connect(self.OnContextMenu)
wx.CallAfter(self._fetch)
@@ -197,6 +198,24 @@
self.SetStatusText("", 0)
wx.EndBusyCursor()
+ def OnContextMenu(self, node):
+ if not hasattr (self, "popupID"):
+ self.popupID = dict()
+ for key in ('install', 'help'):
+ self.popupID[key] = wx.NewId()
+ data = node.data
+ if data and 'command' in data:
+ self.popupMenu = wx.Menu()
+ self.popupMenu.Append(self.popupID['install'], text = _("Install"))
+ self.Bind(wx.EVT_MENU, self.OnInstall, id = self.popupID['install'])
+ self.popupMenu.AppendSeparator()
+ self.popupMenu.Append(self.popupID['help'], text = _("Show manual page"))
+ self.Bind(wx.EVT_MENU, self.OnItemHelp, id = self.popupID['help'])
+ self.PopupMenu(self.popupMenu)
+ self.popupMenu.Destroy()
def OnItemActivated(self, node):
data = node.data
@@ -217,6 +236,13 @@
globalvar.UpdateGRASSAddOnCommands()
toolboxesOutdated()
+ def OnItemHelp(self, event):
+ item = self.tree.GetSelected()
+ if not item or 'command' not in item[0].data:
+ return
+ self._giface.Help(entry=item[0].data['command'], online=True)
def OnHelp(self, event):
self._giface.Help(entry='g.extension')
@@ -230,7 +256,6 @@
self.SetStatusText(data.get('description', ''), 0)
self.btnInstall.Enable(True)
class ExtensionTreeModelBuilder:
"""!Tree model of available extensions."""
def __init__(self):
