[GRASS-SVN] r58645 - in grass/trunk/gui/wxpython: lmgr modules xml
svn_grass at osgeo.org
Wed Jan 8 12:36:48 PST 2014
Author: martinl
Date: 2014-01-08 12:36:47 -0800 (Wed, 08 Jan 2014)
New Revision: 58645
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/modules/extensions.py
grass/trunk/gui/wxpython/xml/toolboxes.xml
grass/trunk/gui/wxpython/xml/wxgui_items.xml
wxGUI: update extensions wrapper (g.extension.rebuild.all has been removed)
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2014-01-08 19:38:31 UTC (rev 58644)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2014-01-08 20:36:47 UTC (rev 58645)
@@ -65,7 +65,7 @@
from psmap.frame import PsMapFrame
from core.debug import Debug
from gui_core.ghelp import AboutWindow
-from modules.extensions import InstallExtensionWindow, UninstallExtensionWindow
+from modules.extensions import InstallExtensionWindow, ManageExtensionWindow
from lmgr.toolbars import LMWorkspaceToolbar, LMDataToolbar, LMToolsToolbar
from lmgr.toolbars import LMMiscToolbar, LMVectorToolbar, LMNvizToolbar
from lmgr.pyshell import PyShellWindow
@@ -1399,9 +1399,9 @@
win.CentreOnScreen()
win.Show()
- def OnUninstallExtension(self, event):
+ def OnManageExtension(self, event):
"""!Uninstall extension"""
- win = UninstallExtensionWindow(self, size = (650, 300))
+ win = ManageExtensionWindow(self, size = (650, 300))
win.Show()
Modified: grass/trunk/gui/wxpython/modules/extensions.py
--- grass/trunk/gui/wxpython/modules/extensions.py 2014-01-08 19:38:31 UTC (rev 58644)
+++ grass/trunk/gui/wxpython/modules/extensions.py 2014-01-08 20:36:47 UTC (rev 58645)
@@ -6,7 +6,7 @@
Classes:
- extensions::InstallExtensionWindow
- extensions::ExtensionTreeModelBuilder
- - extensions::UninstallExtensionWindow
+ - extensions::ManageExtensionWindow
- extensions::CheckListExtension
(C) 2008-2014 by the GRASS Development Team
@@ -26,7 +26,7 @@
from grass.script import task as gtask
from core import globalvar
-from core.gcmd import GError, RunCommand, GException
+from core.gcmd import GError, RunCommand, GException, GMessage
from core.utils import SetAddOnPath, _
from core.menutree import TreeModel, ModuleNode
from gui_core.widgets import GListCtrl, SearchModuleWidget
@@ -348,9 +348,9 @@
'keywords': '',
'description': ''}
-class UninstallExtensionWindow(wx.Frame):
+class ManageExtensionWindow(wx.Frame):
def __init__(self, parent, id = wx.ID_ANY,
- title = _("Uninstall GRASS Addons extensions"), **kwargs):
+ title = _("Manage installed GRASS Addons extensions"), **kwargs):
self.parent = parent
wx.Frame.__init__(self, parent = parent, id = id, title = title, **kwargs)
@@ -364,12 +364,15 @@
self.extList = CheckListExtension(parent = self.panel)
# buttons
- self.btnUninstall = wx.Button(parent = self.panel, id = wx.ID_ANY,
- label = _("&Uninstall"))
+ self.btnUninstall = wx.Button(parent = self.panel, id = wx.ID_REMOVE)
self.btnUninstall.SetToolTipString(_("Uninstall selected AddOns extensions"))
+ self.btnUpdate = wx.Button(parent = self.panel, id = wx.ID_REFRESH)
+ self.btnUpdate.SetToolTipString(_("Reinstall selected AddOns extensions"))
self.btnClose = wx.Button(parent = self.panel, id = wx.ID_CLOSE)
self.btnUninstall.Bind(wx.EVT_BUTTON, self.OnUninstall)
+ self.btnUpdate.Bind(wx.EVT_BUTTON, self.OnUpdate)
self.btnClose.Bind(wx.EVT_BUTTON, lambda evt: self.Close())
self._layout()
@@ -385,6 +388,7 @@
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
btnSizer.Add(item = self.btnClose, proportion = 0,
flag = wx.RIGHT, border = 5)
+ btnSizer.Add(item = self.btnUpdate, proportion = 0, flag=wx.RIGHT, border=5)
btnSizer.Add(item = self.btnUninstall, proportion = 0)
sizer.Add(item = extSizer, proportion = 1,
@@ -397,13 +401,20 @@
self.Layout()
+ def _getSelectedExtensions(self):
+ eList = self.extList.GetExtensions()
+ if not eList:
+ GMessage(_("No extension selected. "
+ "Operation canceled."),
+ parent = self)
+ return []
+ return eList
def OnUninstall(self, event):
"""!Uninstall selected extensions"""
- eList = self.extList.GetExtensions()
+ eList = self._getSelectedExtensions()
if not eList:
- GError(_("No extension selected for removal. "
- "Operation canceled."),
- parent = self)
return
for ext in eList:
@@ -426,7 +437,18 @@
globalvar.UpdateGRASSAddOnCommands(eList)
toolboxesOutdated()
+ def OnUpdate(self, event):
+ """!Update selected extensions"""
+ if not eList:
+ return
+ log = self.parent.GetLogWindow()
+ for ext in eList:
+ log.RunCmd(['g.extension', 'extension=%s' % ext,
+ 'operation=add'])
class CheckListExtension(GListCtrl):
"""!List of mapset/owner/group"""
def __init__(self, parent):
Modified: grass/trunk/gui/wxpython/xml/toolboxes.xml
--- grass/trunk/gui/wxpython/xml/toolboxes.xml 2014-01-08 19:38:31 UTC (rev 58644)
+++ grass/trunk/gui/wxpython/xml/toolboxes.xml 2014-01-08 20:36:47 UTC (rev 58645)
@@ -593,10 +593,7 @@
<label>Addons extensions</label>
<items>
<wxgui-item name="InstallExtensionFromAddons"/>
- <module-item name="g.extension.rebuild.all">
- <label>Update installed extensions</label>
- </module-item>
- <wxgui-item name="UninstallExtension"/>
+ <wxgui-item name="ManageExtension"/>
</items>
</toolbox>
<toolbox name="DevelopRasterMap">
Modified: grass/trunk/gui/wxpython/xml/wxgui_items.xml
--- grass/trunk/gui/wxpython/xml/wxgui_items.xml 2014-01-08 19:38:31 UTC (rev 58644)
+++ grass/trunk/gui/wxpython/xml/wxgui_items.xml 2014-01-08 20:36:47 UTC (rev 58645)
@@ -285,11 +285,11 @@
<description>Installs new extension from GRASS AddOns SVN repository.</description>
<keywords>general,installation,extensions</keywords>
</wxgui-item>
- <wxgui-item name="UninstallExtension">
- <label>Uninstall extension</label>
- <handler>OnUninstallExtension</handler>
+ <wxgui-item name="ManageExtension">
+ <label>Manage installed extension</label>
+ <handler>OnManageExtension</handler>
<related-module>g.extension</related-module>
- <description>Removes installed GRASS AddOns extension.</description>
+ <description>Updates or removes installed GRASS AddOns extension(s).</description>
</wxgui-item>
<wxgui-item name="ManageRasterColorRulesInteractively">
